  4. Gelöst: Update Tradfri auf Version 1.2.1
23 Beiträge 6 Kommentatoren 3.8k Aufrufe
  • Espace0401E Offline
    Espace0401E Offline
    Espace0401
    Ich habe heute versucht ein Update auf die Version 1.2.1 durchzuführen. Dieses wird aber mit folgenden Fehlern abgebrochen:
    $ ./iobroker upgrade tradfri
    Update tradfri from @1.1.10 to @1.2.1
    NPM version: 3.10.10
    npm install iobroker.tradfri@1.2.1 --production --save --prefix "/opt/iobroker" (System call)
    npm
     ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/opt/iobroker/node_modules/.bin/npm" "i" "--save" "node-aead-crypto@^1.1.3"
    npm ERR! node v6.11.4
    npm ERR! npm  v2.15.12
    npm ERR! path /root/.npm/node-aead-crypto/1.1.3/packagenpm ERR! code EACCES
    npm ERR!
    errno
     -13
    npm ERR! syscall mkdir
    npm ERR! Error: EACCES: permission denied, mkdir '/root/.npm/node-aead-crypto/1.1.3/package'
    npm
    ERR!     at Error (native)npm
    ERR!  { Error: EACCES: permission denied, mkdir '/root/.npm/node-aead-crypto/1.1.3/package'npm ERR!     at Error (native)
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'mkdir',
    npm ERR!   path: '/root/.npm/node-aead-crypto/1.1.3/package',
    npm
     ERR!   parent: 'node-dtls-client' }npm ERR!
    npm ERR! Please try running this command again as root/Administrator.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/npm-debug.log
    npm
     ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.tradfri@1.2.1" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.11.4
    npm
     ERR! npm  v3.10.10npm ERR! code ELIFECYCLE
    npm ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the node-dtls-client@0.5.4 install script 'node install/postinstall.js'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the node-dtls-client package,
    npm ERR! not with npm itself.
    npm
     ERR! Tell the author that this fails on your system:npm ERR!     node install/postinstall.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs node-dtls-client
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls node-dtls-client
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
    ERROR: Cannot find io-package.json in null
    ERROR: process exited with code 10
    Ich habe dann den Adapter gelöscht und wieder versucht neu zu Installieren mit der Version 1.1.8. Diese Installation wird auch abgeschlossen, jedoch erscheint der Adapter jetzt nicht mehr in der Liste der Instanzen. Unter Adapter steht er allerdings als Installiert.
    Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      code EACCES
      Dir fehlen Rechte. Probiers mal mit
      sudo iobroker upgrade tradfri
      bzw wenn das nicht geht
      cd /opt/iobroker
      sudo npm i iobroker.tradfri --production --unsafe-perm
        Espace0401E Offline
        Espace0401
        Das hat leider nichts gebracht. Der Adapter wird zwar installiert, aber es läuft keine Instanz. Wenn ich ihn wieder lösche erscheint folgendes:
        $ ./iobroker del tradfri
        Delete adapter "tradfri"
        host.ioBroker-RasPi no instances of adapter tradfri found
        host.ioBroker-RasPi Counted 1 adapters for tradfri
        host.ioBroker-RasPi Counted 1 states of tradfri
        host.ioBroker-RasPi Counted 1 states (system.adapter.tradfri.*) from states
        host.ioBroker-RasPi Deleting 2 object(s).
        host.ioBroker-RasPi Deleting 1 state(s).
        npm uninstall iobroker.tradfri --silent --save --prefix "/opt/iobroker" (System call)
        process exited with code 0
        Die Installation lief so ab:
        pi@ioBroker-RasPi:/opt/iobroker $ sudo npm i iobroker.tradfri --production --unsafe-perm
        > node-dtls-client@0.5.4 install /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client
        node-dtls-client: testing NodeJS version
          Version < 10, installing node-aead-crypto...
        npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
        > node-aead-crypto@1.1.3 install /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto
        > node lib/install.js
        running default installation script
        > node-aead-crypto@1.1.3 install:default /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto
        > node-pre-gyp install --fallback-to-build
        [node-aead-crypto] Success: "/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node" is installed via remote
        node-aead-crypto@1.1.3 node_modules/node-aead-crypto
        ├── nan@2.10.0
        └── node-pre-gyp-github@1.3.1 (commander@2.15.1, github@0.2.4)
        iobroker@1.0.0 /opt/iobroker
        └─┬ iobroker.tradfri@1.2.1
          └─┬ node-tradfri-client@1.1.2
            ├─┬ bonjour@3.5.0
            │ ├── array-flatten@2.1.1
            │ ├── deep-equal@1.0.1
            │ ├── dns-equal@1.0.0
            │ ├─┬ dns-txt@2.0.2
            │ │ └── buffer-indexof@1.1.1
            │ ├─┬ multicast-dns@6.2.3
            │ │ ├── dns-packet@1.3.1
            │ │ └── thunky@1.0.2
            │ └── multicast-dns-service-types@1.1.0
            ├─┬ debug@3.1.0
            │ └── ms@2.0.0
            ├─┬ node-coap-client@0.7.2
            │ └─┬ node-dtls-client@0.5.4
            │   └── semver@5.5.0
            └── reflect-metadata@0.1.12
        Vielleicht noch einer eine Idee?
        • wendy2702W Online
          wendy2702W Online
          wendy2702
          Äh…
          Dumme Frage aber du hast nachdem installieren des Adapters auch dann noch ein Instanz erzeugt?
          • G Offline
            Gallemann
            ich bekomme diese Fehler meldung .. könnte mir jemand sagen was ich machen müsste
            Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
            $ ./iobroker add tradfri
            npm install iobroker.tradfri --production --prefix "c:/ioBroker" (System call)
            npm
             WARN invalid config loglevel="notice"
            npm
             WARN deprecated
            node-pre-gyp WARN Pre-built binaries not installable for node-aead-crypto@1.1.3 and node@8.11.1 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
            node-pre-gyp WARN Hit error ENOTDIR: Cannot cd into 'c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64'
            gyp
            ERR!
            configure error
            gyp
             ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp
            ERR!
            stack
                 at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)
            gyp
            ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)gyp
            ERR!
            stack
                 at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
            gyp
            ERR!
            stack
                 at FSReqWrap.oncomplete (fs.js:152:21)
            gyp
            ERR!
            System
             Windows_NT 10.0.16299
            gyp
            ERR!
            command
             "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"
            gyp
            ERR!
            cwd
            gyp
            ERR!
            node -v
             v8.11.1
            gyp
            ERR!
            node-gyp -v
             v3.6.2
            gyp
            ERR!
             not ok
            node-pre-gyp
            ERR! build error
            node-pre-gyp
            ERR!
            stack
             Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)
            node-pre-gyp
            ERR!
            stack
                 at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
            node-pre-gyp
            ERR!
            stack
                 at emitTwo (events.js:126:13)
            node-pre-gyp
            ERR!
             stack
                 at ChildProcess.emit (events.js:214:7)
            node-pre-gyp
            ERR!
            stack
                 at maybeClose (internal/child_process.js:925:16)
            node-pre-gyp
            ERR!
            stack
                 at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
            node-pre-gyp
            ERR!
            System
            node-pre-gyp
            ERR!
            command
             "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp
            ERR!
            cwd
            node-pre-gyp
            ERR!
            node -v
             v8.11.1
            node-pre-gyp
            ERR!
            node-pre-gyp -v
             v0.9.1
            node-pre-gyp
            ERR!
            not ok
            npm
            ERR!
            npm
            ERR!
            argv
             "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "run" "install:default"
            npm
            ERR!
            node
             v8.11.1
            npm
            ERR!
            npm
             v2.15.12
            npm
            ERR!
            code
             ELIFECYCLE
            npm
            ERR!
             node-aead-crypto@1.1.3 install:default: `node-pre-gyp install --fallback-to-build`
            npm
            ERR!
             Exit status 1
            npm
            ERR!
            npm
            ERR!
             Failed at the node-aead-crypto@1.1.3 install:default script 'node-pre-gyp install --fallback-to-build'.
            npm
            ERR!
             This is most likely a problem with the node-aead-crypto package,
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
                 npm bugs node-aead-crypto
            npm
            npm
            ERR!
            npm
            ERR!
                 npm owner ls node-aead-crypto
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
                 c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
            child_process.js:644
                throw err;
            Error: Command failed: npm run install:default
                at checkExecSyncError (child_process.js:601:13)
                at execSync (child_process.js:641:13)
                at Object. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\lib\install.js:22:1)
                at Module._compile (module.js:652:30)
                at Object.Module._extensions..js (module.js:663:10)
                at Module.load (module.js:565:32)
                at tryModuleLoad (module.js:505:12)
                at Function.Module._load (module.js:497:3)
                at Function.Module.runMain (module.js:693:10)
                at startup (bootstrap_node.js:188:16)
            npm
            ERR! Windows_NT 10.0.16299
            npm
            ERR!
            argv
             "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
            npm
            ERR!
            node
             v8.11.1
            npm
            ERR!
            npm
             v2.15.12
            npm
            ERR!
            code
             ELIFECYCLE
            npm
            ERR!
             node-aead-crypto@1.1.3 install: `node lib/install.js`
            npm
            ERR!
             Exit status 1
            npm
            ERR!
            npm
             ERR!
             Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
            npm
            ERR! This is most likely a problem with the node-aead-crypto package,npm ERR!
            npm
            ERR!
            npm
            ERR!
                 node lib/install.js
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm
            ERR!
            npm ERR!
            npm
            ERR!
            npm ERR!
            npm
            ERR!
                 c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
            npm
            ERR!
            code ELIFECYCLE
            npm
            ERR!
            errno
            npm
            ERR!
             node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
            npm
            ERR!
            npm
            ERR!
             Failed at the node-dtls-client@0.5.4 install script.
            npm
            ERR!
             This is probably not a problem with npm. There is likely additional logging output above.
            npm
            ERR!
             A complete log of this run can be found in:
            npm
            ERR!
                 C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-05T09_26_14_900Z-debug.log
            host.Gallemann-PC create instance tradfri
            ERROR: host.Gallemann-PC error: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
            ERROR: process exited with code 20</anonymous></anonymous></anonymous>
            • wendy2702W Online
              wendy2702W Online
              wendy2702
              Könnte sein das deine NPM Version zu alt ist.
              Wenn ich das richtig gesehen habe irgendwas mit 2.x
              • G Offline
                Gallemann
                jetzt bekomme ich diesen fehler
                NPM version: 5.6.0
                ERROR: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!NPM 5 is only supported starting with version 5.7.1!
                Please use "npm install -g npm@4" to downgrade npm to 4.x or
                use "npm install -g npm@>=5.7.1" to install a supported version of npm 5!
                You need to make sure to repeat this step after installing an update to NodeJS and/or npm
                aber wenn ich npm -v eingebe bekomme ich version 6.0.0
                c:\ioBroker>npm install -g npm@>=5.7.1
                c:\ioBroker>npm -v
                6.0.0
                c:\ioBroker>
                welche eingabe müsste ich eingeben das ich ihn installiert bekomme
                  AlCalzoneA Offline
                  AlCalzone
                  Jetzt hast du doch 6.0.0, das ist >= 5.7.1. Müsste also gehen?!
                    Espace0401E Offline
                    Espace0401
                    @wendy2702:
                    Äh…
                    9DBF4C22-CA3B-4EFE-ACE7-9153510B639F.jpeg `
                    Es gibt keine dummen Fragen….... Schäm. Du hast den Punkt getroffen. Manchmal sieht man vor lauter Bäumen den Wald nicht mehr. Danke!!!
                    Geholfen hat bei mir tatsächlich das:
                    cd /opt/iobroker
                    und anschließend natürlich Instanz erzeugen.
                    • G Offline
                      Gallemann
                      @AlCalzone:
                      Jetzt hast du doch 6.0.0, das ist >= 5.7.1. Müsste also gehen?! `
                      Leider nein.. bekomme es nicht drauf
                      Fertig mit Fehler: host.Gallemann-PC Cannot install tradfri
                        AlCalzoneA Offline
                        AlCalzone
                        @Gallemann:
                        Fertig mit Fehler: host.Gallemann-PC Cannot install tradfri `
                        Steht da noch mehr?
                        Edit: Ich sehe gerade das in deinem alten Post:
                        Wie alt ist deine Installation? Diese Struktur wird schon ewig nicht mehr unterstützt :shock:
                        • G Offline
                          Gallemann
                          heute komplett neu installiert leider immer noch nicht… soll wohl nicht bei mir sein
                          npm WARN invalid config loglevel="notice"
                          npm
                           WARN deprecated
                          gyp
                          ERR! configure error
                          gyp
                          ERR!
                          stack
                          ERR!
                           stack
                               at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)
                          gyp
                          ERR!
                          stack
                          gyp
                          ERR!
                          stack
                          gyp
                          ERR!
                          System
                          gyp
                          ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp
                          ERR!
                          cwd c:\ioBroker\node_modules\node-aead-crypto
                          gyp ERR! node -v
                           v8.11.1
                          gyp
                          ERR!
                           node-gyp -v
                           v3.6.2gyp ERR!
                          not ok
                          node-pre-gyp
                           ERR! build error
                          node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                          ERR!
                           stack
                          node-pre-gyp ERR! stack
                          node-pre-gyp
                          ERR!
                          stack     at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          System
                          node-pre-gyp
                          ERR!
                          command
                          node-pre-gyp ERR!
                          cwd
                          node-pre-gyp
                          ERR!
                          node -v
                           v8.11.1
                          node-pre-gyp
                          ERR!
                          node-pre-gyp -v
                           v0.9.1
                          node-pre-gyp
                          ERR!
                           not ok
                          npm
                          ERR!
                          npm
                           ERR! argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "run" "install:default"
                          npm
                          ERR!
                          node v8.11.1npm ERR!
                          npm
                           v2.15.12
                          npm
                           ERR!
                           code ELIFECYCLE
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm
                          ERR!
                          npm
                          ERR! Failed at the node-aead-crypto@1.1.3 install:default script 'node-pre-gyp install --fallback-to-build'.npm
                          ERR!
                          npm
                          ERR!
                          npm ERR!     node-pre-gyp install --fallback-to-build
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                           ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                              throw err;
                          npm
                          npm
                          ERR!
                          argv
                          npm
                          ERR!
                          node
                           v8.11.1
                          npm
                          ERR!
                           npm
                           v2.15.12
                          npm
                          ERR!
                          code ELIFECYCLE
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                               node lib/install.js
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm ERR!
                          npm
                           ERR!
                          npm
                          ERR!
                          npm ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          code
                           ELIFECYCLE
                          npm
                          ERR!
                          errno
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm
                          ERR!
                          npm ERR! Failed at the node-dtls-client@0.5.4 install script.npm ERR!
                          npm ERR! A complete log of this run can be found in:npm
                          ERR!
                               C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_22_42_185Z-debug.log
                          host.Gallemann-PC install adapter tradfri
                          npm
                          gyp
                          ERR!
                          configure error
                          gyp
                          ERR!
                          stack
                          gyp
                          ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp
                          ERR!
                          stack
                          gyp
                          ERR!
                          stack
                          gyp
                          ERR!
                          stack
                          gyp
                          ERR!
                          System
                          gyp
                          ERR!
                          command
                           "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp ERR!
                          cwd
                           c:\ioBroker\node_modules\node-aead-cryptogyp ERR!
                          node -v
                           v8.11.1
                          gyp ERR! node-gyp -v v3.6.2gyp ERR!
                          not ok
                          node-pre-gyp
                          ERR!
                          build error
                          node-pre-gyp
                          ERR!
                           stack
                           Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
                          stack
                               at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp
                           ERR!
                          stack
                          node-pre-gyp
                           ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                           ERR! System Windows_NT 10.0.16299
                          node-pre-gyp
                           ERR!
                           command
                           "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
                          ERR!
                          cwd
                          node-pre-gyp
                          ERR!
                          node -v
                           v8.11.1
                          node-pre-gyp
                          ERR!
                          node-pre-gyp -v
                           v0.9.1
                          node-pre-gyp ERR! not ok
                          npm
                          ERR!
                          npm
                          ERR!
                          argv
                          npm
                          ERR!
                          node
                           v8.11.1
                          npm
                           ERR! npm  v2.15.12
                          npm
                          ERR!
                          code
                           ELIFECYCLE
                          npm
                          ERR!
                          npm
                           ERR! Exit status 1
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                           ERR!
                               npm owner ls node-aead-cryptonpm
                          ERR!
                          npm
                          ERR!
                          npm ERR!     c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
                              throw err;
                          npm
                          ERR!
                          npm
                           ERR! argv
                          npm
                          ERR! node v8.11.1
                          npm
                          ERR!
                           npm  v2.15.12
                          npm
                           ERR!
                          code
                           ELIFECYCLE
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm
                          ERR!
                           npm ERR! Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          npm ERR!
                               node lib/install.js
                          npm
                           ERR!
                           You can get information on how to open an issue for this project with:npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR! npm
                          ERR!
                          npm
                          npm
                          ERR!
                          npm ERR!     c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
                          npm
                          npm
                          ERR!
                          errno
                          npm
                           ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
                          npm
                          ERR!
                          npm
                          ERR!
                          ERR!
                          ERR!
                               C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_18_890Z-debug.log
                          npm
                          npm
                           WARN deprecated
                          gyp
                          ERR!
                          configure error
                          gyp
                          ERR!
                          gyp
                          ERR!
                           stack
                          gyp
                           ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp
                          ERR!
                          stack
                          gyp
                          ERR! System Windows_NT 10.0.16299gyp
                          ERR!
                          command
                          gyp
                          ERR!
                          gyp ERR! node -v
                           v8.11.1
                          gyp
                          ERR!
                          node-gyp -v
                           v3.6.2
                          gyp
                          ERR!
                          not ok
                          node-pre-gyp
                          ERR!
                          build error
                          node-pre-gyp
                          ERR!
                          stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                           ERR! stack     at maybeClose (internal/child_process.js:925:16)node-pre-gyp
                          ERR!
                          stack
                          node-pre-gyp
                          ERR!
                          System
                          node-pre-gyp
                          ERR!
                          command "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
                          node-pre-gyp
                          ERR! cwd
                          node-pre-gyp
                          ERR!
                          node -v
                           v8.11.1
                          node-pre-gyp
                          ERR!
                          node-pre-gyp -v
                           v0.9.1
                          node-pre-gyp
                          ERR!
                          not ok
                          npm
                          ERR!
                          npm
                          npm
                          ERR! node
                           v8.11.1
                          npm
                          ERR!
                          npm
                           v2.15.12
                          npm
                           ERR!
                           code ELIFECYCLE
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                           ERR!
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                              throw err;
                          npm
                          npm
                          ERR!
                          argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
                          npm ERR! node v8.11.1
                          npm
                          ERR!
                          npm
                           v2.15.12
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                           Exit status 1
                          npm
                          ERR!
                          npm
                           ERR!
                          npm
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                               node lib/install.js
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          npm
                           ERR!
                           code ELIFECYCLE
                          npm
                          ERR!
                           errno 1
                          npm
                          ERR!
                          npm
                           ERR!
                           Exit status 1
                          npm
                          ERR!
                           npm
                          ERR!
                               C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_53_017Z-debug.log
                          ERROR: host.Gallemann-PC Cannot install tradfri
                          ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                            Bei dir fehlt Python¡
                            @Gallemann:
                            Error: Can't find Python executable "python" `
                            Rainer
                              AlCalzoneA Offline
                              AlCalzone
                              @Homoran:
                              @Gallemann:
                              npm install --global --add-python-to-path windows-build-tools
                              auf einer Konsole mit Administratorrechten ausführen.
                                baeckerman83
                                Bei mir funktioniert die Installation des Adapaters auch nicht. Wäre super wenn du mal schauen könntest.
                                Ich habe node v6.14.2 und iobroker 1.2.3
                                Ich versuche die Installation auf dem Slave. Ist ein Raspi mit Raspbian.
                                pi@iobrokerslave:/opt/iobroker $ sudo iobroker add tradfri
                                npm install iobroker.tradfri --production --prefix "/opt/iobroker" (System call)
                                npm ERR! Linux 4.14.34-v7+
                                npm ERR! node v6.14.2
                                npm ERR! errno -13
                                npm ERR!  { Error: EACCES: permission denied, mkdir '/root/.npm/node-aead-crypto/1.1.3/package'
                                npm ERR!   parent: 'node-dtls-client' }
                                npm ERR!
                                npm ERR!     /opt/iobroker/node_modules/node-dtls-client/npm-debug.log
                                npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.tradfri" "--production" "--prefix" "/opt/iobroker"
                                npm ERR! npm  v3.10.10
                                npm ERR!
                                npm ERR! Tell the author that this fails on your system:
                                npm ERR!     /opt/iobroker/npm-debug.log
                                npm ERR! code 1
                                host.iobrokerslave install adapter tradfri
                                npm ERR! errno -13
                                npm ERR!
                                npm ERR!
                                npm ERR! code 1
                                npm ERR! errno -13
                                npm ERR!
                                npm ERR!
                                npm ERR! code 1
                                host.iobrokerslave Cannot install tradfri
                                • wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  Welche NPM Version?
                                  npm -v
                                      baeckerman83
                                      Und ich habe die 3.10.10
                                      sudo npm i iobroker.tradfri –production --unsafe-perm
                                      Damit hat das installieren geklappt. Die Instanz anlegen ging dann aber auch nur über die Konsole mit iobroker add tradfri
                                      Warum der Weg mit dem Plus nicht geht weiß ich nicht, das ist schade, aber vielleicht ist der andere Weg besser. Läuft jetzt! Danke für deine Arbeit!
                                        AlCalzoneA Offline
                                        AlCalzone
                                        Das ist leider eine der Auswirkungen von Rechteproblemen in Zusammenhang mit npm. Wir müssen da noch ein paar offene Fragen klären, damit gänzlich auf sudo verzichtet werden kann und damit hoffentlich diese Probleme endlich aus der Welt sind.
                                        • G Offline
                                          Gallemann
                                          hat leider wieder nicht geklappt
                                          ` > PS C:\iobroker> npm i iobroker.tradfri –production --unsafe-perm
                                          npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
                                          npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp-github
                                          npm ERR! path C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
                                          npm ERR! code ENOENT
                                          npm ERR! errno -4058
                                          npm ERR! syscall access
                                          npm ERR! enoent ENOENT: no such file or directory, access 'C:\iobroker\node_modules\node-aead-crypto\node_modules\nan'
                                          npm ERR! enoent This is related to npm not being able to find a file.
                                          npm ERR! enoent
                                          npm ERR! C:\Users\Gallemann\AppData\Roaming\npm-cache_logs\2018-05-10T16_01_14_205Z-debug.log `
