  4. Gelöst: Update Tradfri auf Version 1.2.1
    6.0k
23 Beiträge 6 Kommentatoren 3.8k Aufrufe
  • Espace0401E Offline
    Espace0401E Offline
    Espace0401
    Das hat leider nichts gebracht. Der Adapter wird zwar installiert, aber es läuft keine Instanz. Wenn ich ihn wieder lösche erscheint folgendes:
    $ ./iobroker del tradfri
    Delete adapter "tradfri"
    host.ioBroker-RasPi no instances of adapter tradfri found
    host.ioBroker-RasPi Counted 1 adapters for tradfri
    host.ioBroker-RasPi Counted 1 states of tradfri
    host.ioBroker-RasPi Counted 1 states (system.adapter.tradfri.*) from states
    host.ioBroker-RasPi Deleting 2 object(s).
    host.ioBroker-RasPi Deleting 1 state(s).
    npm uninstall iobroker.tradfri --silent --save --prefix "/opt/iobroker" (System call)
    process exited with code 0
    Die Installation lief so ab:
    pi@ioBroker-RasPi:/opt/iobroker $ sudo npm i iobroker.tradfri --production --unsafe-perm
    > node-dtls-client@0.5.4 install /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client
    > node install/postinstall.js
    node-dtls-client: testing NodeJS version
      Version < 10, installing node-aead-crypto...
    npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
    > node-aead-crypto@1.1.3 install /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto
    > node lib/install.js
    running default installation script
    > node-aead-crypto@1.1.3 install:default /opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto
    > node-pre-gyp install --fallback-to-build
    [node-aead-crypto] Success: "/opt/iobroker/node_modules/iobroker.tradfri/node_modules/node-dtls-client/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node" is installed via remote
    node-aead-crypto@1.1.3 node_modules/node-aead-crypto
    ├── nan@2.10.0
    └── node-pre-gyp-github@1.3.1 (commander@2.15.1, github@0.2.4)
    iobroker@1.0.0 /opt/iobroker
    └─┬ iobroker.tradfri@1.2.1
      └─┬ node-tradfri-client@1.1.2
        ├─┬ bonjour@3.5.0
        │ ├── array-flatten@2.1.1
        │ ├── deep-equal@1.0.1
        │ ├── dns-equal@1.0.0
        │ ├─┬ dns-txt@2.0.2
        │ │ └── buffer-indexof@1.1.1
        │ ├─┬ multicast-dns@6.2.3
        │ │ ├── dns-packet@1.3.1
        │ │ └── thunky@1.0.2
        │ └── multicast-dns-service-types@1.1.0
        ├─┬ debug@3.1.0
        │ └── ms@2.0.0
        ├─┬ node-coap-client@0.7.2
        │ └─┬ node-dtls-client@0.5.4
        │   └── semver@5.5.0
        └── reflect-metadata@0.1.12
    Vielleicht noch einer eine Idee?
    Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
    • wendy2702W Online
      wendy2702W Online
      Äh…
      Dumme Frage aber du hast nachdem installieren des Adapters auch dann noch ein Instanz erzeugt?
      • G Offline
        Gallemann
        ich bekomme diese Fehler meldung .. könnte mir jemand sagen was ich machen müsste
        Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
        $ ./iobroker add tradfri
        npm install iobroker.tradfri --production --prefix "c:/ioBroker" (System call)
        npm
         WARN invalid config loglevel="notice"
        npm
         WARN deprecated
        node-pre-gyp WARN Pre-built binaries not installable for node-aead-crypto@1.1.3 and node@8.11.1 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
        node-pre-gyp WARN Hit error ENOTDIR: Cannot cd into 'c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64'
        gyp
        ERR!
        configure error
        gyp
         ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp
        ERR!
        stack
             at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)
        gyp
        ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)gyp
        ERR!
        stack
             at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
        gyp
        ERR!
        stack
             at FSReqWrap.oncomplete (fs.js:152:21)
        gyp
        ERR!
        System
         Windows_NT 10.0.16299
        gyp
        ERR!
        command
         "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"
        gyp
        ERR!
        cwd
        gyp
        ERR!
        node -v
         v8.11.1
        gyp
        ERR!
        node-gyp -v
         v3.6.2
        gyp
        ERR!
         not ok
        node-pre-gyp
        ERR! build error
        node-pre-gyp
        ERR!
        stack
         Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)
        node-pre-gyp
        ERR!
        stack
             at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
        node-pre-gyp
        ERR!
        stack
             at emitTwo (events.js:126:13)
        node-pre-gyp
        ERR!
         stack
             at ChildProcess.emit (events.js:214:7)
        node-pre-gyp
        ERR!
        stack
             at maybeClose (internal/child_process.js:925:16)
        node-pre-gyp
        ERR!
        stack
             at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
        node-pre-gyp
        ERR!
        System
        node-pre-gyp
        ERR!
        command
         "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp
        ERR!
        cwd
        node-pre-gyp
        ERR!
        node -v
         v8.11.1
        node-pre-gyp
        ERR!
        node-pre-gyp -v
         v0.9.1
        node-pre-gyp
        ERR!
        not ok
        npm
        ERR!
        npm
        ERR!
        argv
         "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "run" "install:default"
        npm
        ERR!
        node
         v8.11.1
        npm
        ERR!
        npm
         v2.15.12
        npm
        ERR!
        code
         ELIFECYCLE
        npm
        ERR!
         node-aead-crypto@1.1.3 install:default: `node-pre-gyp install --fallback-to-build`
        npm
        ERR!
         Exit status 1
        npm
        ERR!
        npm
        ERR!
         Failed at the node-aead-crypto@1.1.3 install:default script 'node-pre-gyp install --fallback-to-build'.
        npm
        ERR!
         This is most likely a problem with the node-aead-crypto package,
        npm
        ERR!
         not with npm itself.
        npm
        ERR!
         Tell the author that this fails on your system:
        npm
        ERR!
        npm
        ERR!
         You can get information on how to open an issue for this project with:
        npm
        ERR!
             npm bugs node-aead-crypto
        npm
        ERR! Or if that isn't available, you can get their info via:
        npm
        ERR!
        npm
        ERR!
             npm owner ls node-aead-crypto
        npm
        ERR!
         There is likely additional logging output above.
        npm
        ERR!
         Please include the following file with any support request:
        npm
        ERR!
             c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
        child_process.js:644
            throw err;
        Error: Command failed: npm run install:default
            at checkExecSyncError (child_process.js:601:13)
            at execSync (child_process.js:641:13)
            at Object. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\lib\install.js:22:1)
            at Module._compile (module.js:652:30)
            at Object.Module._extensions..js (module.js:663:10)
            at Module.load (module.js:565:32)
            at tryModuleLoad (module.js:505:12)
            at Function.Module._load (module.js:497:3)
            at Function.Module.runMain (module.js:693:10)
            at startup (bootstrap_node.js:188:16)
        npm
        ERR! Windows_NT 10.0.16299
        npm
        ERR!
        argv
         "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
        npm
        ERR!
        node
         v8.11.1
        npm
        ERR!
        npm
         v2.15.12
        npm
        ERR!
        code
         ELIFECYCLE
        npm
        ERR!
         node-aead-crypto@1.1.3 install: `node lib/install.js`
        npm
        ERR!
         Exit status 1
        npm
        ERR!
        npm
         ERR!
         Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
        npm
        ERR! This is most likely a problem with the node-aead-crypto package,npm ERR!
        npm
        ERR!
        npm
        ERR!
             node lib/install.js
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm
        ERR!
        npm ERR!
        npm
        ERR!
        npm ERR!
        npm
        ERR!
             c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
        npm
        ERR!
        code ELIFECYCLE
        npm
        ERR!
        errno
        npm
        ERR!
         node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
        npm
        ERR!
        npm
        ERR!
         Failed at the node-dtls-client@0.5.4 install script.
        npm
        ERR!
         This is probably not a problem with npm. There is likely additional logging output above.
        npm
        ERR!
         A complete log of this run can be found in:
        npm
        ERR!
             C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-05T09_26_14_900Z-debug.log
        host.Gallemann-PC create instance tradfri
        ERROR: host.Gallemann-PC error: reading io-package.json Error: ENOENT: no such file or directory, open 'c:\ioBroker\node_modules\iobroker.js-controller\adapter\tradfri\io-package.json'
        ERROR: process exited with code 20</anonymous></anonymous></anonymous>
        • wendy2702W Online
          wendy2702W Online
          Könnte sein das deine NPM Version zu alt ist.
          Wenn ich das richtig gesehen habe irgendwas mit 2.x
          • G Offline
            Gallemann
            jetzt bekomme ich diesen fehler
            NPM version: 5.6.0
            ERROR: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!NPM 5 is only supported starting with version 5.7.1!
            Please use "npm install -g npm@4" to downgrade npm to 4.x or
            use "npm install -g npm@>=5.7.1" to install a supported version of npm 5!
            You need to make sure to repeat this step after installing an update to NodeJS and/or npm
            aber wenn ich npm -v eingebe bekomme ich version 6.0.0
            c:\ioBroker>npm install -g npm@>=5.7.1
            c:\ioBroker>npm -v
            6.0.0
            c:\ioBroker>
            welche eingabe müsste ich eingeben das ich ihn installiert bekomme
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              Jetzt hast du doch 6.0.0, das ist >= 5.7.1. Müsste also gehen?!
                Espace0401E Offline
                Espace0401
                @wendy2702:
                Äh…
                9DBF4C22-CA3B-4EFE-ACE7-9153510B639F.jpeg `
                Es gibt keine dummen Fragen….... Schäm. Du hast den Punkt getroffen. Manchmal sieht man vor lauter Bäumen den Wald nicht mehr. Danke!!!
                Geholfen hat bei mir tatsächlich das:
                cd /opt/iobroker
                und anschließend natürlich Instanz erzeugen.
                • G Offline
                  Gallemann
                  @AlCalzone:
                  Jetzt hast du doch 6.0.0, das ist >= 5.7.1. Müsste also gehen?! `
                  Leider nein.. bekomme es nicht drauf
                  Fertig mit Fehler: host.Gallemann-PC Cannot install tradfri
                    AlCalzoneA Offline
                    AlCalzone
                    @Gallemann:
                    Fertig mit Fehler: host.Gallemann-PC Cannot install tradfri `
                    Steht da noch mehr?
                    Edit: Ich sehe gerade das in deinem alten Post:
                    Wie alt ist deine Installation? Diese Struktur wird schon ewig nicht mehr unterstützt :shock:
                    • G Offline
                      Gallemann
                      heute komplett neu installiert leider immer noch nicht… soll wohl nicht bei mir sein
                      npm WARN invalid config loglevel="notice"
                      npm
                       WARN deprecated
                      gyp
                      ERR! configure error
                      gyp
                      ERR!
                      stack
                      ERR!
                       stack
                           at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp ERR! stack     at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:508:16)
                      gyp
                      ERR!
                      stack
                      gyp
                      ERR!
                      stack
                      gyp
                      ERR!
                      System
                      gyp
                      ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp
                      ERR!
                      cwd c:\ioBroker\node_modules\node-aead-crypto
                      gyp ERR! node -v
                       v8.11.1
                      gyp
                      ERR!
                       node-gyp -v
                       v3.6.2gyp ERR!
                      not ok
                      node-pre-gyp
                       ERR! build error
                      node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                      ERR!
                       stack
                      node-pre-gyp ERR! stack
                      node-pre-gyp
                      ERR!
                      stack     at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      System
                      node-pre-gyp
                      ERR!
                      command
                      node-pre-gyp ERR!
                      cwd
                      node-pre-gyp
                      ERR!
                      node -v
                       v8.11.1
                      node-pre-gyp
                      ERR!
                      node-pre-gyp -v
                       v0.9.1
                      node-pre-gyp
                      ERR!
                       not ok
                      npm
                      ERR!
                      npm
                       ERR! argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "run" "install:default"
                      npm
                      ERR!
                      node v8.11.1npm ERR!
                      npm
                       v2.15.12
                      npm
                       ERR!
                       code ELIFECYCLE
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                      ERR!
                      npm
                      ERR! Failed at the node-aead-crypto@1.1.3 install:default script 'node-pre-gyp install --fallback-to-build'.npm
                      ERR!
                      npm
                      ERR!
                      npm ERR!     node-pre-gyp install --fallback-to-build
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                       ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                          throw err;
                      npm
                      npm
                      ERR!
                      argv
                      npm
                      ERR!
                      node
                       v8.11.1
                      npm
                      ERR!
                       npm
                       v2.15.12
                      npm
                      ERR!
                      code ELIFECYCLE
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                       Tell the author that this fails on your system:npm ERR!
                           node lib/install.js
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm ERR!
                      npm
                       ERR!
                      npm
                      ERR!
                      npm ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      errno
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                      ERR!
                      npm ERR! Failed at the node-dtls-client@0.5.4 install script.npm ERR!
                      npm ERR! A complete log of this run can be found in:npm
                      ERR!
                           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_22_42_185Z-debug.log
                      host.Gallemann-PC install adapter tradfri
                      npm
                      gyp
                      ERR!
                      configure error
                      gyp
                      ERR!
                      stack
                      gyp
                      ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:483:19)gyp
                      ERR!
                      stack
                      gyp
                      ERR!
                      stack
                      gyp
                      ERR!
                      stack
                      gyp
                      ERR!
                      System
                      gyp
                      ERR!
                      command
                       "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "configure" "--fallback-to-build" "--module=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64\\node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=c:\\ioBroker\\node_modules\\node-aead-crypto\\build\\Release\\node-v57-win32-x64" "--napi_version=1" "--node_abi_napi=napi"gyp ERR!
                      cwd
                       c:\ioBroker\node_modules\node-aead-cryptogyp ERR!
                      node -v
                       v8.11.1
                      gyp ERR! node-gyp -v v3.6.2gyp ERR!
                      not ok
                      node-pre-gyp
                      ERR!
                      build error
                      node-pre-gyp
                      ERR!
                       stack
                       Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
                      stack
                           at ChildProcess. <anonymous>(c:\ioBroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp\lib\util\compile.js:83:29)node-pre-gyp
                       ERR!
                      stack
                      node-pre-gyp
                       ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                       ERR! System Windows_NT 10.0.16299
                      node-pre-gyp
                       ERR!
                       command
                       "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
                      ERR!
                      cwd
                      node-pre-gyp
                      ERR!
                      node -v
                       v8.11.1
                      node-pre-gyp
                      ERR!
                      node-pre-gyp -v
                       v0.9.1
                      node-pre-gyp ERR! not ok
                      npm
                      ERR!
                      npm
                      ERR!
                      argv
                      npm
                      ERR!
                      node
                       v8.11.1
                      npm
                       ERR! npm  v2.15.12
                      npm
                      ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      npm
                       ERR! Exit status 1
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR! not with npm itself.
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR! You can get information on how to open an issue for this project with:
                      npm
                      ERR!
                      npm ERR! Or if that isn't available, you can get their info via:
                      npm
                      ERR!
                      npm
                       ERR!
                           npm owner ls node-aead-cryptonpm
                      ERR!
                      npm
                      ERR!
                      npm ERR!     c:\ioBroker\node_modules\node-aead-crypto\npm-debug.log
                          throw err;
                      npm
                      ERR!
                      npm
                       ERR! argv
                      npm
                      ERR! node v8.11.1
                      npm
                      ERR!
                       npm  v2.15.12
                      npm
                       ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                      ERR!
                       npm ERR! Failed at the node-aead-crypto@1.1.3 install script 'node lib/install.js'.
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR! Tell the author that this fails on your system:
                      npm ERR!
                           node lib/install.js
                      npm
                       ERR!
                       You can get information on how to open an issue for this project with:npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR! npm
                      ERR!
                      npm
                      ERR! There is likely additional logging output above.
                      npm
                      ERR!
                      npm ERR!     c:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-dtls-client\npm-debug.log
                      npm
                       ERR! code ELIFECYCLE
                      npm
                      ERR!
                      errno
                      npm
                       ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`npm ERR! Exit status 1
                      npm
                      ERR!
                      npm
                      ERR!
                      ERR!
                      ERR!
                           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_18_890Z-debug.log
                      npm
                      npm
                       WARN deprecated
                      gyp
                      ERR!
                      configure error
                      gyp
                      ERR!
                      gyp
                      ERR!
                       stack
                      gyp
                       ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp
                      ERR!
                      stack
                      gyp
                      ERR! System Windows_NT 10.0.16299gyp
                      ERR!
                      command
                      gyp
                      ERR!
                      gyp ERR! node -v
                       v8.11.1
                      gyp
                      ERR!
                      node-gyp -v
                       v3.6.2
                      gyp
                      ERR!
                      not ok
                      node-pre-gyp
                      ERR!
                      build error
                      node-pre-gyp
                      ERR!
                      stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64\node_aead_crypto.node --module_name=node_aead_crypto --module_path=c:\ioBroker\node_modules\node-aead-crypto\build\Release\node-v57-win32-x64 --napi_version=1 --node_abi_napi=napi' (1)node-pre-gyp ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                       ERR! stack     at maybeClose (internal/child_process.js:925:16)node-pre-gyp
                      ERR!
                      stack
                      node-pre-gyp
                      ERR!
                      System
                      node-pre-gyp
                      ERR!
                      command "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\node-aead-crypto\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
                      node-pre-gyp
                      ERR! cwd
                      node-pre-gyp
                      ERR!
                      node -v
                       v8.11.1
                      node-pre-gyp
                      ERR!
                      node-pre-gyp -v
                       v0.9.1
                      node-pre-gyp
                      ERR!
                      not ok
                      npm
                      ERR!
                      npm
                      npm
                      ERR! node
                       v8.11.1
                      npm
                      ERR!
                      npm
                       v2.15.12
                      npm
                       ERR!
                       code ELIFECYCLE
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                       ERR!
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                          throw err;
                      npm
                      npm
                      ERR!
                      argv "C:\\Program Files\\nodejs\\node.exe" "c:\\ioBroker\\node_modules\\npm\\bin\\npm-cli.js" "i" "--save" "node-aead-crypto@1.1.3"
                      npm ERR! node v8.11.1
                      npm
                      ERR!
                      npm
                       v2.15.12
                      npm
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                      ERR!
                      npm
                       ERR!
                      npm
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                           node lib/install.js
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                      ERR!
                      npm
                       ERR!
                       code ELIFECYCLE
                      npm
                      ERR!
                       errno 1
                      npm
                      ERR!
                      npm
                       ERR!
                       Exit status 1
                      npm
                      ERR!
                       npm
                      ERR!
                           C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-05-08T17_23_53_017Z-debug.log
                      ERROR: host.Gallemann-PC Cannot install tradfri
                      ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                        Bei dir fehlt Python¡
                        @Gallemann:
                        Error: Can't find Python executable "python" `
                          AlCalzoneA Offline
                          AlCalzone
                          @Homoran:
                          @Gallemann:
                          npm install --global --add-python-to-path windows-build-tools
                          auf einer Konsole mit Administratorrechten ausführen.
                            baeckerman83
                            Bei mir funktioniert die Installation des Adapaters auch nicht. Wäre super wenn du mal schauen könntest.
                            Ich habe node v6.14.2 und iobroker 1.2.3
                            Ich versuche die Installation auf dem Slave. Ist ein Raspi mit Raspbian.
                            pi@iobrokerslave:/opt/iobroker $ sudo iobroker add tradfri
                            npm install iobroker.tradfri --production --prefix "/opt/iobroker" (System call)
                            npm ERR! Linux 4.14.34-v7+
                            npm ERR! argv "/usr/bin/node" "/opt/iobroker/node_modules/.bin/npm" "i" "--save" "node-aead-crypto@^1.1.3"
                            npm ERR! node v6.14.2
                            npm ERR! npm  v2.15.12
                            npm ERR! path /root/.npm/node-aead-crypto/1.1.3/package
                            npm ERR! code EACCES
                            npm ERR! errno -13
                            npm ERR! syscall mkdir
                            npm ERR! Error: EACCES: permission denied, mkdir '/root/.npm/node-aead-crypto/1.1.3/package'
                            npm ERR!     at Error (native)
                            npm ERR!  { Error: EACCES: permission denied, mkdir '/root/.npm/node-aead-crypto/1.1.3/package'
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'mkdir',
                            npm ERR!   path: '/root/.npm/node-aead-crypto/1.1.3/package',
                            npm ERR!   parent: 'node-dtls-client' }
                            npm ERR!
                            npm ERR! Please try running this command again as root/Administrator.
                            npm ERR! Please include the following file with any support request:
                            npm ERR!     /opt/iobroker/node_modules/node-dtls-client/npm-debug.log
                            npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.tradfri" "--production" "--prefix" "/opt/iobroker"
                            npm ERR! npm  v3.10.10
                            npm ERR! code ELIFECYCLE
                            npm ERR! node-dtls-client@0.5.4 install: `node install/postinstall.js`
                            npm ERR! Exit status 243
                            npm ERR!
                            npm ERR! Failed at the node-dtls-client@0.5.4 install script 'node install/postinstall.js'.
                            npm ERR! Make sure you have the latest version of node.js and npm installed.
                            npm ERR! If you do, this is most likely a problem with the node-dtls-client package,
                            npm ERR! not with npm itself.
                            npm ERR! Tell the author that this fails on your system:
                            npm ERR!     node install/postinstall.js
                            npm ERR! You can get information on how to open an issue for this project with:
                            npm ERR!     npm bugs node-dtls-client
                            npm ERR!     npm owner ls node-dtls-client
                            npm ERR! There is likely additional logging output above.
                            npm ERR!     /opt/iobroker/npm-debug.log
                            npm ERR! code 1
                            host.iobrokerslave install adapter tradfri
                            npm ERR! errno -13
                            npm ERR!
                            npm ERR!
                            npm ERR! code 1
                            npm ERR! errno -13
                            npm ERR!
                            npm ERR!
                            npm ERR! code 1
                            host.iobrokerslave Cannot install tradfri
                            • wendy2702W Online
                              wendy2702W Online
                              Welche NPM Version?
                              npm -v
                                  baeckerman83
                                  Und ich habe die 3.10.10
                                  sudo npm i iobroker.tradfri –production --unsafe-perm
                                  Damit hat das installieren geklappt. Die Instanz anlegen ging dann aber auch nur über die Konsole mit iobroker add tradfri
                                  Warum der Weg mit dem Plus nicht geht weiß ich nicht, das ist schade, aber vielleicht ist der andere Weg besser. Läuft jetzt! Danke für deine Arbeit!
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Das ist leider eine der Auswirkungen von Rechteproblemen in Zusammenhang mit npm. Wir müssen da noch ein paar offene Fragen klären, damit gänzlich auf sudo verzichtet werden kann und damit hoffentlich diese Probleme endlich aus der Welt sind.
                                    • G Offline
                                      Gallemann
                                      hat leider wieder nicht geklappt
                                      ` > PS C:\iobroker> npm i iobroker.tradfri –production --unsafe-perm
                                      npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
                                      npm WARN checkPermissions Missing write access to C:\iobroker\node_modules\node-aead-crypto\node_modules\node-pre-gyp-github
                                      npm ERR! path C:\iobroker\node_modules\node-aead-crypto\node_modules\nan
                                      npm ERR! code ENOENT
                                      npm ERR! errno -4058
                                      npm ERR! syscall access
                                      npm ERR! enoent ENOENT: no such file or directory, access 'C:\iobroker\node_modules\node-aead-crypto\node_modules\nan'
                                      npm ERR! enoent This is related to npm not being able to find a file.
                                      npm ERR! enoent
                                      npm ERR! C:\Users\Gallemann\AppData\Roaming\npm-cache_logs\2018-05-10T16_01_14_205Z-debug.log `
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Hast du das als Administrator gemacht?
                                        • G Offline
                                          Gallemann
                                          ja..
