    2. FLiTZi
    F
    • Following 1
    • Posts 12
    FLiTZi
    @FLiTZi
    12
    FLiTZi Follow
    Latest posts made by FLiTZi
    • RE: [Javascript] Midas (Aquatemp) Poolheizung
      Einmal Bilder für @oxident
      F
      FLiTZi
    • RE: [gelöst] Script Batteriespeicher voll = Wärmepumpe an
      WOW! Vielen Dank, so läuft es super!!! 1000 Dank 🙂
      anbei nochmal die Lösung!
      var modus, timeoutWP, verzWP, timeoutPumpe, verzPumpe;
      modus = getState('0_userdata.0.Poolheizung.mode').val;
      on({ id: 'solax.0.data.soc' /* Inverter DC-Battery Energy SOC */, change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        let oldValue = obj.oldState.val;
        if ((obj.state ? obj.state.val : '') >= 16) {
          console.info('Speicher 100%');
          modus = '1';
          verzWP = 60000;
          verzPumpe = 0;
        } else if ((obj.state ? obj.state.val : '') < 15) {
          console.info('Speicher 90%');
          modus = '-1';
          verzWP = 0;
          verzPumpe = 60000;
        if (modus != getState('0_userdata.0.Poolheizung.mode').val) {
          timeoutWP = setTimeout(async () => {
            timeoutWP = null;
            setState('0_userdata.0.Poolheizung.mode' /* Modus */, modus);
          }, parseInt(verzWP));
          timeoutPumpe = setTimeout(async () => {
            timeoutPumpe = null;
            setState('shelly.0.shellyplus1#441793d6c02c#1.Relay0.Switch' /* Schalter */, (modus == true));
          }, parseInt(verzPumpe));
      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
      F
      FLiTZi
      ahh ich versteh es nicht, sorry. bin erst ein paar Tage in der Materie
      F
      FLiTZi
      Danke dir! muss ich aber nicht noch den Shelly von der Poolpumpe bestimmen ? der wird doch jetzt gar nicht an oder aus geschaltet oder ? Also es muss doch der "Switch" bzw "Schalter" noch eingefügt werden oder ?
      F
      FLiTZi
      @flitzi
      okay, also mittlerweile habe ich das ganze hinbekommen. jetzt muss nur noch die Poolpumpe(Shelly) vor der wärmepumpe angehen.
      hat da noch jemand eine Idee ?
      F
      FLiTZi
      Ja das hatte ich kurz vor deinem Post auch schonmal versucht, hat leider auch nicht geklappt.
      F
      FLiTZi
      das ist aus Objekte -> Mode -> Rechtsklick -> Bleistift
      insgesamt habe ich das Script hier her link text
      das Script an sich funktioniert. Also ich kann die Wärmepumpe per iobroker Manuell steuern.
      F
      FLiTZi
        "common": {
          "read": true,
          "write": true,
          "type": "string",
          "states": "-1:off;0:cool;1:heat;2:auto",
          "name": "Modus",
          "def": "",
          "role": "state"
        "native": {},
        "type": "state",
        "from": "system.adapter.javascript.0",
        "user": "system.user.admin",
        "ts": 1714588450044,
        "_id": "0_userdata.0.Poolheizung.mode"
      F
      FLiTZi
      ich bin noch nicht so lange in dem Thema, ich weiß jetzt nicht was ich machen soll, kannst du es mir genauer erklären?
      F
      FLiTZi
      @homoran ok sorry, kommt nicht wieder vor.
      F
      FLiTZi
