  4. [Javascript] Midas (Aquatemp) Poolheizung
    6.3k
359 Beiträge 25 Kommentatoren 103.9k Aufrufe 25 Beobachtet
  • O oxident
    @europer Hmm, sieht nicht gut aus.
    Hast Du denn auch mal versucht, im Skript nichts zu verändern und nur den Datenpunkt auf 53° zu stellen?
    europerE Offline
    europerE Offline
    europer
    #210
    @oxident ja, erst original gelassen dann Varianten von den json Teil geändert aber ich werde den orginal noch einmal testen
    • O oxident
      europerE Offline
      europerE Offline
      europer
      #211
      @oxident ja, hab jetzt Original Scrip, nur meine Parameter für die Abfrage ist etwas anders weil die ja bei jeden etwas anders sind. Hier die RAW JSON Rückgabe Informationen. Vielleicht hilft die für die Kommando?:
      	"value": "1",
      	"code": "Power"
      	"value": "2",
      	"code": "Mode"
      	"value": "0",
      	"code": "Manual-mute"
      	"value": "0",
      	"code": "O01"
      	"value": "0",
      	"code": "O02"
      	"value": "0",
      	"code": "O03"
      	"value": "0",
      	"code": "O04"
      	"value": "0",
      	"code": "O05"
      	"value": "0",
      	"code": "O06"
      	"value": "100",
      	"code": "O07"
      	"value": "34",
      	"code": "O08"
      	"value": "0",
      	"code": "O09"
      	"value": "21.5",
      	"code": "T01"
      	"value": "36.5",
      	"code": "T02"
      	"value": "52.0",
      	"code": "T03"
      	"value": "4.0",
      	"code": "T04"
      	"value": "6.0",
      	"code": "T05"
      	"value": "57.5",
      	"code": "T06"
      	"value": "52.0",
      	"code": "T10"
      	"value": "0",
      	"code": "2074"
      	"value": "0",
      	"code": "2075"
      	"value": "0",
      	"code": "2076"
      	"value": "0",
      	"code": "2077"
      	"value": "0",
      	"code": "H03"
      	"value": "0",
      	"code": "Set_Temp"
      	"value": "55.0",
      	"code": "R01"
      	"value": "7.5",
      	"code": "R03"
      	"value": "0",
      	"code": "R04"
      	"value": "55.0",
      	"code": "R05"
      	"value": "200",
      	"code": "R06"
      	"value": "0",
      	"code": "R07"
      	"value": "-5.0",
      	"code": "R08"
      	"value": "5.0",
      	"code": "R09"
      	"value": "25.0",
      	"code": "R10"
      	"value": "-15.0",
      	"code": "R12"
      	"value": "45.0",
      	"code": "R14"
      	"value": "78.0",
      	"code": "R15"
      	"value": "0",
      	"code": "R17"
      	"value": "1.0",
      	"code": "R18"
      	"value": "65.0",
      	"code": "R19"
      	"value": "55.0",
      	"code": "R20"
      	"value": "0",
      	"code": "S01"
      	"value": "0",
      	"code": "S03"
      	"value": "0",
      	"code": "S04"
      	"value": "0",
      	"code": "S05"
      	"value": "0",
      	"code": "S06"
      	"value": "1",
      	"code": "H01"
      	"value": "0",
      	"code": "H03"
      	"value": "0",
      	"code": "H07"
      	"value": "23205",
      	"code": "1158"
      	"value": "0",
      	"code": "1159"
      O 1 Antwort Letzte Antwort
      • europerE europer
        	"value": "1",
        	"code": "Power"
        	"value": "2",
        	"code": "Mode"
        	"value": "0",
        	"value": "0",
        	"code": "O01"
        	"value": "0",
        	"code": "O02"
        	"value": "0",
        	"code": "O03"
        	"value": "0",
        	"code": "O04"
        	"value": "0",
        	"code": "O05"
        	"value": "0",
        	"code": "O06"
        	"value": "100",
        	"code": "O07"
        	"value": "34",
        	"code": "O08"
        	"value": "0",
        	"code": "O09"
        	"value": "21.5",
        	"code": "T01"
        	"value": "36.5",
        	"code": "T02"
        	"value": "52.0",
        	"code": "T03"
        	"value": "4.0",
        	"code": "T04"
        	"value": "6.0",
        	"code": "T05"
        	"value": "57.5",
        	"code": "T06"
        	"value": "52.0",
        	"code": "T10"
        	"value": "0",
        	"code": "2074"
        	"value": "0",
        	"code": "2075"
        	"value": "0",
        	"code": "2076"
        	"value": "0",
        	"code": "2077"
        	"value": "0",
        	"code": "H03"
        	"value": "0",
        	"code": "Set_Temp"
        	"value": "55.0",
        	"code": "R01"
        	"value": "7.5",
        	"code": "R03"
        	"value": "0",
        	"code": "R04"
        	"value": "55.0",
        	"code": "R05"
        	"value": "200",
        	"code": "R06"
        	"value": "0",
        	"code": "R07"
        	"value": "-5.0",
        	"code": "R08"
        	"value": "5.0",
        	"code": "R09"
        	"value": "25.0",
        	"code": "R10"
        	"value": "-15.0",
        	"code": "R12"
        	"value": "45.0",
        	"code": "R14"
        	"value": "78.0",
        	"code": "R15"
        	"value": "0",
        	"code": "R17"
        	"value": "1.0",
        	"code": "R18"
        	"value": "65.0",
        	"code": "R19"
        	"value": "55.0",
        	"code": "R20"
        	"value": "0",
        	"code": "S01"
        	"value": "0",
        	"code": "S03"
        	"value": "0",
        	"code": "S04"
        	"value": "0",
        	"code": "S05"
        	"value": "0",
        	"code": "S06"
        	"value": "1",
        	"code": "H01"
        	"value": "0",
        	"code": "H03"
        	"value": "0",
        	"code": "H07"
        	"value": "23205",
        	"code": "1158"
        	"value": "0",
        	"code": "1159"
        O Online
        O Online
        oxident
        #212
        @europer Was sofort auffällt ist, dass Set_Temp 0 ist. Komisch.
        Es wäre natürlich gut zu wissen, welchen Parameter Deine App sendet, wenn Du die Temperatur änderst!
        Die angefragten Werte passen aber, oder?
        • O Online
          O Online
          oxident
          #213
          Mal eine Frage in die Runde: Hat jemand mal geschaut, ob man die Parameter in der App (Code ist 022) tunen kann?
          Mich wundert z.B. dass O01 (Compressor) bei mir immer Off ist. Hat das eventuell mit den Intervall-Settings zu tun?
          Auf der anderen Seite habe ich negative Suction-Temps bei 15°C Außentemperatur.
          Oder anders gefragt, welche Werte werden Euch im Betrieb angezeigt?
          • H Offline
            hs911
            #214
            Hi zusammen,
            leider meckert Javascript bei neueren Versionen wegen der Verwendung von request:
            request package is deprecated - please use httpGet (or a stable lib like axios) instead!
            Einfaches Ersetzen von request durch httpGet sowie herausnehmen der Variable bringt leider nichts, das Script stellt dann komplett den Dienst ein. Wie müsste es denn in neu aussehen?
            Viele Grüße
            O 2 Antworten Letzte Antwort
            • H hs911
              Hi zusammen,
              Viele Grüße
              O Online
              O Online
              oxident
              #215
              @hs911 Da kann ich derzeit leider noch nicht helfen. Das Skript ist ziemlich angewachsen und die Verwendung der anderen Module würde einen kompletten Rewrite bedeuten.
              Aber vielleicht möchte ja jemand helfen (eventuell sogar beim Umbacken in einen Adapter)?
              • H Offline
                hs911
                #216
                gibt es denn irgendwo eine Option, die die Verwendung von request weiterhin erlaubt?
                • H hs911
                  O Online
                  O Online
                  oxident
                  #217
                  @hs911 Naja, erlaubt ist sie ja noch. Die Warnungen nerven halt ;-)
                  Aber früher oder später schaffen wir auch die Migration auf Axios. Man muss halt ganz penibel darauf achten, dass das Skript exakt die App "emuliert" und da braucht es bei Axios (oder httpGet/put) noch ein paar Kniffe.
                  Bis dahin aber gerne einfach weiter nutzen.
                  • H hs911
                    Hi zusammen,
                    Viele Grüße
                    O Online
                    O Online
                    oxident
                    #218
                    @hs911 Ich habe das Skript jetzt auf Axios umgestellt. Die aktuelle Version könnt ihr aus dem ersten Beitrag kopieren.
                    Falls möglich, speichert Euch die alte Version bitte trotzdem noch irgendwie ab und testet zunächst alle Funktionen. Müsste eigentlich funktionieren ;-)
                    • F Offline
                      FLiTZi
                      #219
                      Einmal Bilder für @oxident
                      • O oxident
                        Entwicklung des Skripts eingestellt -> bitte den Adapter https://github.com/MiRo1310/ioBroker.midas-aquatemp testen
                        Hallo!
                        Ich habe eine Poolsana InverPro Wärmepumpe (Hersteller ist Midas) mit WLAN-Modul für meinen Pool und dachte mir, das kann man bestimmt integrieren ;-)
                        Ihr müsst im oberen Teil des Skripts Eure Zugangsdaten eintragen. Dann noch, ganz wichtig, den apiLevel entweder auf 1 (für Anlagen, die schon vor einigen Monaten registriert wurden) oder 3 (für neuere Anlagen) setzen. Im Zweifelsfall beide Werte probieren.
                        Hierbei auch wichtig: Bitte legt Euch einen Zweit-Account an und "teilt" Eure Anlage dann mit diesem. Dies kann man über die App erledigen. Hintergrund ist der, dass der Hersteller immer nur einen gleichzeitigen Login erlaubt.
                        Ein- und Ausschalten der Wärmepumpe läuft über den DP "mode". Mit dem DP "silent" kann der Flüstermodus (verringerte Leistung) geschaltet werden und "tempSet" steuert die Zieltemperatur.
                        Die restlichen DP sind nur-lesend und hoffentlich selbsterklärend.
                        Wenn alles geklappt hat, dann findet ihr unter 0.userdata.0/Poolheizung folgende Datenpunkte:
                        // Midas Poolheizung
                        // v0.0.12
                        // Changelog:
                        // 0.0.12: Ausgangstemperatur des Kompressors (exhaust) sowie Produkt- und Geräte-ID hinzugefügt
                        //         neue Produkt-IDs hinzugefügt (ungetestet)
                        // 0.0.11: Request zu Acios migriert
                        // 0.0.10: Weitere Parameter für andere Gerätetypen hinzugefügt
                        // 0.0.8: Testweise Unterstützung von neu registrierten Anlagen
                        // 0.0.7: Kleinigkeiten überarbeitet
                        //        weitere Modelle hinzugefügt
                        // 0.0.6: Gültigkeitsprüfung des Zertifikats deaktiviert (Dank an znyde)
                        //        Kompatibilität mit Promo Next Modellen durch generische Product-ID (Dank an znyde)
                        // 0.0.5: weitere Abfragewerte hinzugefügt (Kompressor- und Ansaugtemperatur)
                        // 0.0.4: Tokenverfall jetzt 60min nach Skriptstart und nicht zu jeder vollen Stunde (Dank an dering)
                        // 0.0.3: Datenpunkte beim Start automatisch anlegen (Dank an Andy200877)
                        // 0.0.2: Token bei jedem Set-Vorgang prüfen und ggf. neu anfordern (Dank an dering)
                        // ANFANG konfigurierbare Elemente -----
                        const username = "EMAIL";
                        var password = "KENNWORT";
                        const interval = 30; // Abfrageintervall in Sekunden
                        const dpRoot = "0_userdata.0.Poolheizung"; // Stammordner der Datenpunkte
                        const apilevel = 3;   // 1: AquaTemp-Accounts, die vor v.1.5.8 erstellt wurden
                                              // 2: HiTemp-Accounts
                                              // 3: AquaTemp-Accounts, die mit neueren App-Versionen erstellt wurden
                        var debugLevel = 0;   // 0: keine erweiterten Informationen protokollieren
                                                // 1: Debug-Informationen protokollieren
                        // ENDE --------------------------------
                        var cloudURL;
                        var token = "";
                        var tokenRefreshTimer;
                        var device = "";
                        // ProductIDs:
                        // Gruppe 1:
                        // 1132174963097280512: Midas/Poolsana InverPro
                        const AQUATEMP_POOLSANA="1132174963097280512";
                        // Gruppe 2:
                        // 1442284873216843776:
                        const AQUATEMP_OTHER1="1442284873216843776";
                        var product = "";
                        var reachable = false;
                        const axios = require('axios');
                        function setupEndpoints() {
                            if(apilevel==1) {
                                cloudURL = "https://cloud.linked-go.com/cloudservice/api";
                            } else if(apilevel==2) {
                            } else if(apilevel==3) {
                                cloudURL = "https://cloud.linked-go.com:449/crmservice/api";
                                password = require('crypto').createHash('md5').update(password).digest("hex");
                            printLog("API-Level " + apilevel, 1);
                        function clearValues() {
                            saveValue("error", true, "boolean");
                            saveValue("consumption", 0, "number");
                            saveValue("state", false, "boolean");
                            saveValue("rawJSON", null, "string");
                        function saveValue(key, value, sType) {
                            var dp = dpRoot + "." + key;
                            if ( !existsState(dp )) {
                                printLog("Schreibe in NEUEN Datenpunkt: " + dp + " - " + value, 1);
                                createState(dp,value,{name: key,  type: 'number', role: 'value'}, function () {});
                            } else {
                                printLog("Schreibe in Datenpunkt: " + dp + " - " + value, 1);
                                setState(dp,value,true);
                        function findCodeVal(result, code) {
                            //log(code + " " + result.length);
                            //log(result);
                            printLog("Suche Wert " + code, 1);
                            for(var i=0; i<result.length; i++) {
                                //log(result[i].code);
                                printLog(result[i].code, 1);
                                if(result[i].code.indexOf(code) >= 0) {
                                    printLog("Wert gefunden: " + result[i].value, 1);
                                    return result[i].value;
                            return "";
                        function createobjects() {
                            log ("erstelle Objekte");
                            createState(dpRoot + '.ambient', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Umgebungstemperatur"});
                            createState(dpRoot + '.connection', {read: true, write: false,  type: "boolean", role: "state", name: "Verbindung", def: false});
                            createState(dpRoot + '.consumption', {read: true, write: false,  type: "number", unit:"W", role: "value.power", name: "Stromverbrauch", def: 0});
                            createState(dpRoot + '.error', {read: true, write: false,  type: "boolean", role: "state", name: "Fehler", def: false});
                            createState(dpRoot + '.errorCode', {read: true, write: false,  type: "string", name: "Fehlercode", def: ""});
                            createState(dpRoot + '.errorLevel', {read: true, write: false,  type: "number", name: "Fehlerlevel"});
                            createState(dpRoot + '.errorMessage', {read: true, write: false,  type: "string", name: "Fehlermeldung", def: ""});
                            createState(dpRoot + '.mode', {read: true, write: true,  type: "string", states: "-1:off;0:cool;1:heat;2:auto", name: "Modus", def: ""});
                            createState(dpRoot + '.rotor', {read: true, write: false,  type: "number", unit:"rpm", def: 0, name: "Lüfterdrehzahl"});
                            createState(dpRoot + '.silent', {read: true, write: true,  type: "boolean", role: "state", name: "Silent", def: false});
                            createState(dpRoot + '.state', {read: true, write: false,  type: "boolean", role: "state", name: "Status", def: false});
                            createState(dpRoot + '.tempIn', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Eingangstemperatur"});
                            createState(dpRoot + '.tempOut', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Ausgangstemperatur"});
                            createState(dpRoot + '.tempSet', {read: true, write: true,  type: "number", unit:"°C", role: "level.temperature", name: "Solltemperatur"});
                            createState(dpRoot + '.suctionTemp', {read: true, write: false,  type: "number", unit:"°C", name: "Luftansaugtemperatur"});
                            createState(dpRoot + '.coilTemp', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Kompressortemperatur"});
                            createState(dpRoot + '.exhaust', {read: true, write: false,  type: "number", unit:"°C", role: "value.temperature", name: "Kompressorausgang"});
                            createState(dpRoot + '.ProductCode', {read: true, write: false,  type: "string", name: "Produktcode"});
                            createState(dpRoot + '.DeviceCode', {read: true, write: false,  type: "string", name: "Geräte-ID"});
                            createState(dpRoot + '.rawJSON', {read: true, write: false,  type: "array", name: "komplette Rückgabe"});
                        function updateToken() {
                            if(token=="") {
                                printLog("Token Neuanforderung");
                                var options;
                                var sUrl="";
                                if(apilevel<3) {
                                    sUrl = cloudURL + '/app/user/login.json';
                                    options = {
                                        "user_name": username, "password": password, "type": "2"
                                } else {
                                    sUrl = cloudURL + '/app/user/login';
                                    options = {
                                        "userName": username, "password": password, "type": "2"
                                axios.post(sUrl, options)
                                        .then(function (response) {
                                            printLog("Login-Antwort: " + response.data);
                                            if(response.status==200) {
                                                if(apilevel<3) {
                                                    token = response.data.object_result["x-token"];
                                                } else {
                                                    token = response.data.objectResult["x-token"];
                                                printLog("Login ok! Token " + token);
                                                //log("Token " + token);
                                                updateDeviceID();
                                            } else {
                                                // Error!
                                                printLog("Login-Fehler in updateToken(): " + response.data);
                                                token = "";
                                                saveValue("connection", false, "boolean");
                                            .catch(function (error) {
                                                // Error!
                                                printLog("Login-Fehler in updateToken(): " + error);
                                                token = "";
                            } else {
                                // Token war ok
                                updateDeviceID();
                        function updateDeviceID() {
                            if(token!="") {
                                var sURL;
                                if(apilevel<3) {
                                    sURL = cloudURL + '/app/device/deviceList.json';
                                } else {
                                    sURL = cloudURL + '/app/device/deviceList';
                                axios.post(sURL, {
                                    "productIds": [
                                        "1132174963097280512",
                                        "1245226668902080512",
                                        "1656269521923575808",
                                        "1663080854333558784",
                                        "1596427678569979904",
                                        "1674238226096406528",
                                        "1650063968998252544",
                                        "1668781858447085568",
                                        "1186904563333062656",
                                        "1158905952238313472",
                                        "1442284873216843776",
                                        "1732565142225256450",
                                        "1548963836789501952",
                                        "1669159229372477440",
                                        "1650758828508766208",
                                        "1664085465655808000"
                                    headers: { "x-token": token },
                                        printLog("DeviceList: " + JSON.stringify(response.data));
                                        if(response.data.error_code==0) {
                                            if(apilevel<3) {
                                                device = response.data.object_result[0].device_code;
                                                product = response.data.object_result[0].product_id;
                                                reachable = (response.data.object_result[0].device_status=="ONLINE");
                                            } else {
                                                device = response.data.objectResult[0].deviceCode;
                                                product = response.data.objectResult[0].productId;
                                                reachable = (response.data.objectResult[0].deviceStatus=="ONLINE");
                                            printLog("DeviceCode: " + device + ", ProductID: " + product + ", DeviceStatus: " + reachable);
                                            saveValue("DeviceCode", device, "string");
                                            saveValue("ProductCode", product, "string");
                                            if(reachable) {
                                                saveValue("connection", true, "boolean");
                                                if(device!="") updateDeviceStatus(device);
                                            } else {
                                                // offline
                                                device = "";
                                        } else {
                                            // Login-Fehler
                                            log("Fehler in updateDeviceID(): " + JSON.stringify(response.data), "error");
                                            token = "";
                                            device = "";
                                            reachable = false;
                                    } else {
                                        // Login-Fehler
                                        token = "";
                                        device = "";
                                        reachable = false;
                                        // Login-Fehler
                                        log("Fehler in updateDeviceID(): " + error, "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                        function updateDeviceStatus(devicecode) {
                            if(token!="") {
                                var sURL="";
                                if(apilevel<3) {
                                    sURL=cloudURL + '/app/device/getDeviceStatus.json';
                                } else {
                                    sURL=cloudURL + '/app/device/getDeviceStatus';
                                axios.post(sURL, {
                                    "device_code": devicecode,
                                    "deviceCode": devicecode
                                    printLog("DeviceStatus: " + response.data);
                                    if(parseInt(response.data.error_code)==0) {
                                        if(apilevel<3) {
                                            if(response.data.object_result["is_fault"]==true) {
                                                // TODO: Fehlerbeschreibung abrufen
                                                //clearValues();
                                                updateDeviceDetails(devicecode);
                                                updateDeviceErrorMsg(devicecode);
                                            } else {
                                                // kein Fehler
                                                saveValue("error", false, "boolean");
                                                saveValue("errorMessage", "", "string");
                                                saveValue("errorCode", "", "string");
                                                saveValue("errorLevel", 0, "number");
                                        } else {
                                            if(response.data.objectResult["is_fault"]==true) {
                                                //clearValues();
                                            } else {
                                                // kein Fehler
                                    } else {
                                        log("Fehler in updateDeviceStatus(): " + JSON.stringify(response.data), "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                                    // Login-Fehler
                                    log("Fehler in updateDeviceStatus(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDeviceErrorMsg(devicecode) {
                            if(token!="") {
                                var optionsDev;
                                var sURL="";
                                if(apilevel<3) {
                                    sURL=cloudURL + '/app/device/getFaultDataByDeviceCode.json';
                                } else {
                                    sURL=cloudURL + '/app/device/getFaultDataByDeviceCode';
                                axios.post(sURL, {
                                        if(apilevel<3) {
                                            saveValue("errorMessage", response.data.object_result[0].description, "string");
                                            saveValue("errorCode", response.data.object_result[0].fault_code, "string");
                                            saveValue("errorLevel", response.data.object_result[0].error_level, "string");
                                        } else {
                                            saveValue("errorMessage", response.data.objectResult[0].description, "string");
                                            saveValue("errorCode", response.data.objectResult[0].fault_code, "string");
                                            saveValue("errorLevel", response.data.objectResult[0].error_level, "string");
                                    } else {
                                        // Login-Fehler
                                        token = "";
                                        device = "";
                                    // Login-Fehler
                                    log("Fehler in updateDeviceErrorMsg(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDeviceDetails(devicecode) {
                            // AXIOS
                            if(token!="") {
                                var optionsDev;
                                var sURL;
                                if(apilevel<3) {
                                    sURL = cloudURL + '/app/device/getDataByCode.json';
                                } else {
                                    sURL = cloudURL + '/app/device/getDataByCode';
                                axios.post(sURL, {
                                    "deviceCode": devicecode,
                                    "protocal_codes":[
                                                "Power",
                                                "Mode",
                                                "Manual-mute",
                                                "T01",
                                                "T02",
                                                "2074",
                                                "2075",
                                                "2076",
                                                "2077",
                                                "H03",
                                                "Set_Temp",
                                                "R08",
                                                "R09",
                                                "R10",
                                                "R11",
                                                "R01",
                                                "R02",
                                                "R03",
                                                "T03",
                                                "1158",
                                                "1159",
                                                "F17",
                                                "H02",
                                                "T04",
                                                "T05",
                                                "T06",
                                                "T07",
                                                "T14",
                                                "T17",
                                                "T1",
                                                "T2",
                                                "T3",
                                                "T4",
                                                "T5",
                                                "T6",
                                                "T7"],
                                    "protocalCodes":[
                                                "Power",
                                                "Mode",
                                                "Manual-mute",
                                                "T01",
                                                "T02",
                                                "2074",
                                                "2075",
                                                "2076",
                                                "2077",
                                                "H03",
                                                "Set_Temp",
                                                "R08",
                                                "R09",
                                                "R10",
                                                "R11",
                                                "R01",
                                                "R02",
                                                "R03",
                                                "T03",
                                                "1158",
                                                "1159",
                                                "F17",
                                                "H02",
                                                "T04",
                                                "T05",
                                                "T06",
                                                "T07",
                                                "T14",
                                                "T17",
                                                "T1",
                                                "T2",
                                                "T3",
                                                "T4",
                                                "T5",
                                                "T6",
                                                "T7"]
                        //            log(response.data)
                                    printLog("DeviceDetails: " + response.data);
                                        if(apilevel<3) {
                                            if(debugLevel==1) saveValue("rawJSON", response.data.object_result, "string");
                                            if(findCodeVal(response.data.object_result, "Power")=="1") {
                                                if(product==AQUATEMP_POOLSANA) {
                                                    // Stromverbrauch T07 x T14 in Watt
                                                    saveValue("consumption", parseFloat(findCodeVal(response.data.object_result, "T07")) * parseFloat(findCodeVal(response.data.object_result, "T14")), "number");
                                                    // Luftansaug-Temperatur T01
                                                    saveValue("suctionTemp", parseFloat(findCodeVal(response.data.object_result, "T01")), "number");
                                                    // Inlet-Temperatur T02
                                                    saveValue("tempIn", parseFloat(findCodeVal(response.data.object_result, "T02")), "number");
                                                    // outlet-Temperatur T03
                                                    saveValue("tempOut", parseFloat(findCodeVal(response.data.object_result, "T03")), "number");
                                                    // Coil-Temperatur T04
                                                    saveValue("coilTemp", parseFloat(findCodeVal(response.data.object_result, "T04")), "number");
                                                    // Umgebungs-Temperatur T05
                                                    saveValue("ambient", parseFloat(findCodeVal(response.data.object_result, "T05")), "number");
                                                    // Kompressorausgang-Temperatur T06
                                                    saveValue("exhaust", parseFloat(findCodeVal(response.data.object_result, "T06")), "number");
                                                } else if (product==AQUATEMP_OTHER1) {
                                                    // Stromverbrauch T7 x T14 in Watt
                                                    saveValue("consumption", parseFloat(findCodeVal(response.data.object_result, "T7")) * parseFloat(findCodeVal(response.data.object_result, "T14")), "number");
                                                    // Luftansaug-Temperatur T1
                                                    saveValue("suctionTemp", parseFloat(findCodeVal(response.data.object_result, "T1")), "number");
                                                    // Inlet-Temperatur T2
                                                    saveValue("tempIn", parseFloat(findCodeVal(response.data.object_result, "T2")), "number");
                                                    // outlet-Temperatur T3
                                                    saveValue("tempOut", parseFloat(findCodeVal(response.data.object_result, "T3")), "number");
                                                    // Coil-Temperatur T4
                                                    saveValue("coilTemp", parseFloat(findCodeVal(response.data.object_result, "T4")), "number");
                                                    // Umgebungs-Temperatur T5
                                                    saveValue("ambient", parseFloat(findCodeVal(response.data.object_result, "T5")), "number");
                                                    // Kompressorausgang-Temperatur T6
                                                    saveValue("exhaust", parseFloat(findCodeVal(response.data.object_result, "T6")), "number");
                                                // Lüfter-Drehzahl T17
                                                saveValue("rotor", parseInt(findCodeVal(response.data.object_result, "T17")), "number");
                                            } else {
                                                saveValue("rotor", 0, "number");
                                            // Ziel-Temperatur Set_Temp
                                            //saveValue("tempSet", parseFloat(findCodeVal(body.object_result, "Set_Temp")), "number");
                                            // Ziel-Temperatur anhand Modus
                                            if(findCodeVal(response.data.object_result,"Mode") == 1) {
                                                // Heiz-Modus (-> R02)
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.object_result, "R02")), "number");
                                            } else if(findCodeVal(response.data.object_result,"Mode") == 0) {
                                                // Kühl-Modus (-> R01)
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.object_result, "R01")), "number");
                                            } else if(findCodeVal(response.data.object_result,"Mode") == 2) {
                                                // Auto-Modus (-> R03)
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.object_result, "R03")), "number");
                                            // Flüstermodus Manual-mute
                                            if(findCodeVal(response.data.object_result, "Manual-mute")=="1") {
                                                saveValue("silent", true, "boolean");
                                            } else {
                                                saveValue("silent", false, "boolean");
                                            // Zustand Power
                                                saveValue("state", true, "boolean");
                                                saveValue("mode", findCodeVal(response.data.object_result,"Mode"), "string");
                                            } else {
                                                saveValue("mode", "-1", "string");
                                            // Durchlauf ENDE
                                        } else {
                                            if(debugLevel==1) saveValue("rawJSON", response.data.objectResult, "string");
                                            if(findCodeVal(response.data.objectResult, "Power")=="1") {
                                                    saveValue("consumption", parseFloat(findCodeVal(response.data.objectResult, "T07")) * parseFloat(findCodeVal(response.data.objectResult, "T14")), "number");
                                                    saveValue("suctionTemp", parseFloat(findCodeVal(response.data.objectResult, "T01")), "number");
                                                    saveValue("tempIn", parseFloat(findCodeVal(response.data.objectResult, "T02")), "number");
                                                    saveValue("tempOut", parseFloat(findCodeVal(response.data.objectResult, "T03")), "number");
                                                    saveValue("coilTemp", parseFloat(findCodeVal(response.data.objectResult, "T04")), "number");
                                                    saveValue("ambient", parseFloat(findCodeVal(response.data.objectResult, "T05")), "number");
                                                    saveValue("exhaust", parseFloat(findCodeVal(response.data.objectResult, "T06")), "number");
                                                    saveValue("consumption", parseFloat(findCodeVal(response.data.objectResult, "T7")) * parseFloat(findCodeVal(response.data.objectResult, "T14")), "number");
                                                    saveValue("suctionTemp", parseFloat(findCodeVal(response.data.objectResult, "T1")), "number");
                                                    saveValue("tempIn", parseFloat(findCodeVal(response.data.objectResult, "T2")), "number");
                                                    saveValue("tempOut", parseFloat(findCodeVal(response.data.objectResult, "T3")), "number");
                                                    saveValue("coilTemp", parseFloat(findCodeVal(response.data.objectResult, "T4")), "number");
                                                    saveValue("ambient", parseFloat(findCodeVal(response.data.objectResult, "T5")), "number");
                                                    saveValue("exhaust", parseFloat(findCodeVal(response.data.objectResult, "T6")), "number");
                                                saveValue("rotor", parseInt(findCodeVal(response.data.objectResult, "T17")), "number");
                                            } else {
                                            //saveValue("tempSet", parseFloat(findCodeVal(body.objectResult, "Set_Temp")), "number");
                                            if(findCodeVal(response.data.objectResult,"Mode") == 1) {
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.objectResult, "R02")), "number");
                                            } else if(findCodeVal(response.data.objectResult,"Mode") == 0) {
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.objectResult, "R01")), "number");
                                            } else if(findCodeVal(response.data.objectResult,"Mode") == 2) {
                                                saveValue("tempSet", parseFloat(findCodeVal(response.data.objectResult, "R03")), "number");
                                            if(findCodeVal(response.data.objectResult, "Manual-mute")=="1") {
                                            } else {
                                            // Zustand Power
                                                saveValue("mode", findCodeVal(response.data.objectResult,"Mode"), "string");
                                            } else {
                                            // Durchlauf ENDE
                                    } else {
                                        // Login-Fehler
                                        log("Fehler in updateDeviceDetails(): " + JSON.stringify(response.data), "error");
                                        token = "";
                                        device = "";
                                    // Login-Fehler
                                    log("Fehler in updateDeviceDetails(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDevicePower(devicecode, power) {
                            var powerOpt;
                            var powerMode = 2;
                            if(power==-1) {
                                // aus
                                powerOpt = 0;
                                powerMode = -1;
                            } else if(power==0) {
                                // an und kühlen
                                powerOpt = 1;
                                powerMode = 0;
                            } else if(power==1) {
                                // an und heizen
                                powerOpt = 1;
                                powerMode = 1;
                            } else if(power==2) {
                                // an und auto
                                powerOpt = 1;
                                powerMode = 2;
                            } else {
                                log("ungülter Zustand!");
                                return;
                            if(token!="") {
                                var sURL="";
                                if(apilevel<3) {
                                    sURL=cloudURL + '/app/device/control.json';
                                } else {
                                    sURL=cloudURL + '/app/device/control';
                                axios.post(sURL, {
                                    "param": [{
                                        "protocol_code": "Power",
                                        "protocolCode": "Power",
                                        "value": powerOpt
                                        saveValue("mode", power.toString(), "string");
                                        if(power>=0) updateDeviceMode(device, power);
                                    } else {
                                        log("Fehler in updateDevicePower(): " + response.data, "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                                    // Login-Fehler
                                    log("Fehler in updateDevicePower(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDeviceMode(devicecode, mode) {
                            if(token!="") {
                                var sURL="";
                                if(apilevel<3) {
                                } else {
                                axios.post(sURL, {
                                    "param": [{
                                        "protocol_code": "mode",
                                        "protocolCode": "mode",
                                        "value": mode
                                        saveValue("mode", mode, "string");
                                    } else {
                                        log("Fehler in updateDeviceMode(): " + response.data, "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                                    // Login-Fehler
                                    log("Fehler in updateDeviceMode(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDeviceSilent(devicecode, silent) {
                            var silentMode;
                            if(silent) {
                                silentMode = "1";
                            } else {
                                silentMode = "0";
                            if(token!="") {
                                var sURL="";
                                if(apilevel<3) {
                                } else {
                                axios.post(sURL, {
                                    "param": [{
                                        "protocol_code": "Manual-mute",
                                        "protocolCode": "Manual-mute",
                                        "value": silentMode
                                        saveValue("silent", silent, "boolean");
                                    } else {
                                        log("Fehler in updateDeviceSilent(): " + response.data, "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                                    // Login-Fehler
                                    log("Fehler in updateDeviceSilent(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function updateDeviceSetTemp(devicecode, temperature) {
                            var sTemperature = temperature.toString().replace(",", ".");
                            var sMode = getState(dpRoot + ".mode").val;
                            if(sMode=="-1") {
                                //log("Gerät einschalten um Temperatur zu ändern!", 'warn');
                                return;
                            } else if(sMode=="0") {
                                sMode = "R01"; // Kühlen
                            } else if(sMode=="1") {
                                sMode = "R02"; // Heizen
                            } else if(sMode=="2") {
                                sMode = "R03"; // Auto
                            if(token!="") {
                                var sURL="";
                                if(apilevel<3) {
                                } else {
                                axios.post(sURL, {
                                    "param": [
                                        "protocol_code": "R01",
                                        "protocolCode": "R01",
                                        "value": sTemperature
                                        "protocol_code": "R02",
                                        "protocolCode": "R02",
                                        "protocol_code": "R03",
                                        "protocolCode": "R03",
                                        "protocol_code": "Set_Temp",
                                        "protocolCode": "Set_Temp",
                                        saveValue("tempSet", temperature, "number");
                                    } else {
                                        log("Fehler in updateDeviceSetTemp(): " + response.data, "error");
                                        token = "";
                                        device = "";
                                        reachable = false;
                                    // Login-Fehler
                                    log("Fehler in updateDeviceSetTemp(): " + error, "error");
                                    token = "";
                                    device = "";
                                    reachable = false;
                        function printLog(sMsg, minLevel = 1) {
                            if(debugLevel>=minLevel) {
                                log(sMsg);
                        function productIsAquaTemp(productid) {
                        // Beginn des Skripts
                        setupEndpoints();
                        createobjects(); // DPs anlegen
                        clearValues();
                        updateToken(); // Zugriffstoken erfragen und aktuelle Werte lesen
                        schedule('*/' + interval + ' * * * * *', function () {
                            // regelmäßig Token und Zustand abfragen
                            updateToken();
                            // gewünschte Änderungen ausführen
                            if(!getState(dpRoot + ".mode").ack) {
                                updateDevicePower(device, getState(dpRoot + ".mode").val);
                            if(!getState(dpRoot + ".silent").ack) {
                                updateDevicePower(device, getState(dpRoot + ".silent").val);
                        tokenRefreshTimer = setInterval(function () {
                            // Token verfällt nach 60min
                            token = "";
                            //log("Token nach Intervall verworfen.")
                            updateToken();
                        }, 3600000);
                        on({id: dpRoot + ".mode", change: "ne", ack: false}, function (obj) {
                            updateToken();
                        on({id: dpRoot + ".silent", change: "ne", ack: false}, function (obj) {
                            updateToken();
                            updateDeviceSilent(device, getState(dpRoot + ".silent").val);
                        on({id: dpRoot + ".tempSet", change: "ne", ack: false}, function (obj) {
                            updateToken();
                            updateDeviceSetTemp(device, getState(dpRoot + ".tempSet").val);
                        Getestet wurde das Skript bisher mit folgenden Wärmepumpen:
                        Poolsana InverPro 21
                        Andere Modelle müssten eigentlich auch funktionieren, jedoch gibt es im Skript noch einen Bug bei der Zuordnung der Werte. Schlaue Ideen sehr erwünscht ;-)
                        Michael RolingM Offline
                        Michael Roling
                        #220
                        @oxident Vielen Dank für das Skript, leider bekomme ich keine Verbindung zum Account. Ich habe Poolsana InverPro 17. Aber das ist ja erstmal egal, solange ich mich garnicht einloggen kann. Haste eine Idee was ich probieren kann? Wenn ich auf apilevel 3 gehe bekomme ich als response nur das hier { error_code: '-1', error_msg: '密码错误', error_msg_code: '1400034', isReusltSuc: false }
                        • Michael RolingM Michael Roling
                          O Online
                          O Online
                          oxident
                          #221
                          @michael-roling Hmm, das ist eigentlich ziemlich die gleiche Heizung, die ich auch habe. Sollte also zu schaffen sein!
                          Apilevel 3 ist definitiv richtig.
                          Die Fehlermeldung scheint ja "falsches Passwort" zu bedeuten. Das hatte ich in der Tat bisher noch nicht. Jedoch ist es so, dass die Kennwort vor der Übermittlung nochmal durch einen Algorithmus gejagt wird. Der könnte eventuell buggy sein und komisch auf Sonderzeichen reagieren.
                          Daher würde ich an Deiner Stelle erstmal probieren, ob Du das Passwort für den Zweitaccount (nutzt Du doch bestimmt, oder?) ggf. etwas "entschärfen" kannst. Groß-/Kleinbuchstaben und Zahlen klappen definitiv stressfrei.
                          Michael RolingM 2 Antworten Letzte Antwort
                          • O oxident
                            Michael Roling
                            #222
                            @oxident ja zweitaccount habe ich angelegt. Das mit den Sonderzeichen könnte das Problem sein. Werde ich mal testen. Danke.
                            • O oxident
                              Michael Roling
                              #223
                              @oxident Daran lag es wirklich, jetzt muss ich aber sicherlich noch was anpassen, da nicht alle werte in die states geschrieben werden. Wie wäre es wenn wir daraus direkt einen Adapter machen würden?
                                O Online
                                O Online
                                oxident
                                #224
                                @michael-roling Ja, ein Adapter wär schon fein, übersteigt aber meine Fähigkeiten. Außerdem ist das Skript schon mächtig "gewachsen". Freiwillige vor ;-)
                                Manche States werden vom Aquatemp-Server nur zurückgegeben, wenn die Heizung an ist. Könnte es daran liegen?
                                Michael RolingM 1 Antwort Letzte Antwort
                                • O oxident
                                  Michael Roling
                                  #225
                                  @oxident im json scheinen die Daten zu sein. Habe aber nur flüchtig drüber geschaut. Wenn du nichts drauf entgegen hast würde ich mich dran machen alles in einen Adapter zu stecken.
                                    O Online
                                    O Online
                                    oxident
                                    #226
                                    @michael-roling Das wäre Hammer. Arbeite natürlich auch gerne mit ... wo ich kann!
                                    • O oxident
                                      Michael Roling
                                      #227
                                      @oxident okay dann werde ich das angehen. Woher hast du die Daten für die cloud?
                                        O Online
                                        O Online
                                        oxident
                                        #228
                                        @michael-roling Letzten Endes findest Du die grundsätzliche Vorgehensweise unter https://github.com/radical-squared/aquatemp
                                        Anfangs musste ich noch einiges für die hiesigen Modelle selber heraustüfteln, aber mittlerweile ist das Github-Projekt sehr mächtig geworden und dürfte auch alle Modelle, die hierzulande gebrandet werden unterstützen.
                                        • O oxident
                                          Michael Roling
                                          #229
                                          @oxident Moin. Ich bin mit dem Adapter angefangen. Hast du ne Idee was wir als Icon nutzen könnten? Einen Bug habe ich aber aktuell noch. Und zwar bei refetch der Daten scheitert der request. Obwohl der Token übergeben wird. Da muss ich noch mal nachschauen warum das nicht geht. Translationen muss ich auch noch einbauen.
