    2. Hawkiobroker 0
    H
    • Posts 22
    Hawkiobroker 0
    @Hawkiobroker 0
    22
    Hawkiobroker 0 Follow
    Latest posts made by Hawkiobroker 0
    • RE: Javascript Adapter 7.8.0 stuerzt ab
      @knopers1 @haus-automatisierung habe jetzt 7.9.2 installiert. Die Instanz schmiert immer noch ab:
      host.iobrokerSchozach01
      2024-03-18 20:20:11.558	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
      2024-03-18 20:20:11.558	error	Caught by controller[14]: 18: 0x170e179 [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[14]: 17: 0xdf5326 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[14]: 16: 0x10550cf v8::internal::JsonParser<unsigned char>::ParseJson() [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[14]: 15: 0x105453e v8::internal::JsonParser<unsigned char>::ParseJsonValue() [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[14]: 14: 0x104d5a9 v8::internal::JsonParser<unsigned char>::BuildJsonArray(v8::internal::JsonParser<unsigned char>::JsonContinuation const&, v8::base::SmallVector<v8::internal::Handle<v8::internal::Object>, 16ul, std::allocator<v8::internal::Handle<v8::internal::Object> > > const&) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[13]: 13: 0xf2699e v8::internal::Factory::NewJSArray(v8::internal::ElementsKind, int, int, v8::internal::ArrayStorageAllocationMode, v8::internal::AllocationType) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[12]: 12: 0xf26895 v8::internal::Factory::NewJSArrayStorage(v8::internal::ElementsKind, int, v8::internal::ArrayStorageAllocationMode) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[11]: 11: 0xf12b05 v8::internal::FactoryBase<v8::internal::Factory>::NewFixedArrayWithFiller(v8::internal::Handle<v8::internal::Map>, int, v8::internal::Handle<v8::internal::Oddball>, v8::internal::AllocationType) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[10]: 10: 0xf1298c v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawArray(int, v8::internal::AllocationType) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[9]: 9: 0xf1b3c0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-18 20:20:11.557	error	Caught by controller[8]: 8: 0xf3ae47 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[7]: 7: 0xf39a7e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[6]: 6: 0xf5f38d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[5]: 5: 0xf4ceb5 [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[4]: 4: 0xd6f957 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[3]: 3: 0xd6f5b0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[2]: 2: 0xa9a7f8 [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[1]: 1: 0xb95be0 node::Abort() [io.javascript.0]
      2024-03-18 20:20:11.556	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      2024-03-18 20:20:11.556	error	Caught by controller[0]: <--- JS stacktrace --->
      2024-03-18 20:20:11.555	error	Caught by controller[0]: [31460:0x629d870] 63706 ms: Mark-sweep (reduce) 2046.8 (2081.9) -> 2046.7 (2082.2) MB, 2291.8 / 0.0 ms (+ 191.9 ms in 48 steps since start of marking, biggest step 17.6 ms, walltime since start of marking 2566 ms) (average mu = 0.251, current mu = 0.0[31460:0x629d870] 66864 ms: Mark-sweep (reduce) 2047.6 (2082.2) -> 2047.6 (2083.2) MB, 3150.6 / 0.0 ms (average mu = 0.141, current mu = 0.002) allocation failure; scavenge might not succeed
      2024-03-18 20:20:11.555	error	Caught by controller[0]: <--- Last few GCs --->
      H
      Hawkiobroker 0
      @haus-automatisierung anbei das iobroker log:
      2024-03-14 13:35:40.682 - info: javascript.0 (10004) starting. Version 7.9.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.19.1, js-controller: 5.0.19
      2024-03-14 13:35:40.821 - info: javascript.0 (10004) requesting all states
      2024-03-14 13:35:40.823 - info: javascript.0 (10004) requesting all objects
      2024-03-14 13:36:19.711 - info: javascript.0 (10004) received all objects
      2024-03-14 13:36:40.336 - info: host.iobrokerSchozach01 "system.adapter.javascript.0" disabled
      2024-03-14 13:36:40.340 - info: host.iobrokerSchozach01 stopInstance system.adapter.javascript.0 (force=false, process=true)
      2024-03-14 13:36:40.514 - info: host.iobrokerSchozach01 stopInstance system.adapter.javascript.0 send kill signal
      2024-03-14 13:36:41.519 - info: host.iobrokerSchozach01 stopInstance system.adapter.javascript.0 killing pid 10004
      2024-03-14 13:36:41.865 - error: host.iobrokerSchozach01 Caught by controller[0]: <--- Last few GCs --->
      2024-03-14 13:36:41.865 - error: host.iobrokerSchozach01 Caught by controller[0]: [10004:0x6500870] 60437 ms: Mark-sweep (reduce) 2046.6 (2081.9) -> 2046.5 (2082.2) MB, 2194.3 / 0.0 ms (+ 240.2 ms in 54 steps since start of marking, biggest step 11.7 ms, walltime since start of marking 2517 ms) (average mu = 0.246, current mu = 0.0[10004:0x6500870] 63786 ms: Mark-sweep (reduce) 2047.5 (2082.2) -> 2047.5 (2083.2) MB, 3343.8 / 0.0 ms (average mu = 0.130, current mu = 0.001) allocation failure; scavenge might not succeed
      2024-03-14 13:36:41.865 - error: host.iobrokerSchozach01 Caught by controller[0]: <--- JS stacktrace --->
      2024-03-14 13:36:41.865 - error: host.iobrokerSchozach01 Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[1]: 1: 0xb95be0 node::Abort() [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[2]: 2: 0xa9a7f8 [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[3]: 3: 0xd6f5b0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[4]: 4: 0xd6f957 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[5]: 5: 0xf4ceb5 [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[6]: 6: 0xf5f38d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[7]: 7: 0xf39a7e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[8]: 8: 0xf3ae47 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[9]: 9: 0xf1b3c0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.javascript.0]
      2024-03-14 13:36:41.866 - error: host.iobrokerSchozach01 Caught by controller[10]: 10: 0xf1298c v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[11]: 11: 0xf12b05 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[12]: 12: 0xf26895 v8::internal::Factory::NewJSArrayStorage(v8::internal::ElementsKind, int, v8::internal::ArrayStorageAllocationMode) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[13]: 13: 0xf2699e v8::internal::Factory::NewJSArray(v8::internal::ElementsKind, int, int, v8::internal::ArrayStorageAllocationMode, v8::internal::AllocationType) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[14]: 14: 0x104d3e5 v8::internal::JsonParser::BuildJsonArray(v8::internal::JsonParser::JsonContinuation const&, v8::base::SmallVector, 16ul, std::allocator > > const&) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[15]: 15: 0x105453e v8::internal::JsonParser::ParseJsonValue() [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[16]: 16: 0x10550cf v8::internal::JsonParser::ParseJson() [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[17]: 17: 0xdf5326 v8::internal::Builtin_JsonParse(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
      2024-03-14 13:36:41.867 - error: host.iobrokerSchozach01 Caught by controller[18]: 18: 0x170e179 [io.javascript.0]
      2024-03-14 13:36:41.867 - warn: host.iobrokerSchozach01 instance system.adapter.javascript.0 terminated due to SIGABRT
      2024-03-14 13:36:41.867 - info: host.iobrokerSchozach01 instance system.adapter.javascript.0 terminated with code null ()
      H
      Hawkiobroker 0
      @hawkiobroker-0 Habe mittlerweile auch 7.9.0 probiert. Laeuft auch NICHT; stuerzt (ohne Skripte) in kurzer Zeit ab.
      H
      Hawkiobroker 0
      @knopers1 7.9.0 habe ich noch nicht probiert. 7.8.0 stuerzt bei mir immer ab, auch nachdem ich alle Skripte geloescht habe. Bei Ideen gerne melden.
      H
      Hawkiobroker 0
      Habe nun alle Skripte geloescht und javascript Adapter deinstalliert. iobroker neu gestartet. Danach den javascript adapter wieder instaliert.
      => Das Problem besteht weiterhin.
      Good ideas welcome!
      H
      Hawkiobroker 0
      @wildbill nochmals Danke! Auch das habe ich schon ausprobiert.
      Alle Skripte angehalten und iobroker und den Server neu gestartet.
      H
      Hawkiobroker 0
      @wildbill der Fehler tritt immer auf, auch wenn alle Skripte angehalten sind. Ich bin da als Nicht-Experte ratlos. Hast Du noch eine Idee?
      H
      Hawkiobroker 0
      @thomas-braun said in Javascript Adapter 7.8.0 stuerzt ab:
      @hawkiobroker-0
      Da bin ich überfragt. Vielleicht @paul53 mal fragen. 🙂
      @paul53 Kannst Du bei meinem Problem helfen? Vielen Dank im Voraus!
      H
      Hawkiobroker 0
      @thomas-braun gibt es eine Moeglichkeit zu sehen, welches Skript das Problem verursacht? Besten Dank!
      H
      Hawkiobroker 0
      @thomas-braun ist das so richtig eingestellt?
      H
      Hawkiobroker 0
