    2. Frosch 23
    F
    • Posts 12
    Frosch 23
    @Frosch 23
    12
    Location Saarland
    Frosch 23 Follow
    Latest posts made by Frosch 23
    • RE: vis funktioniert Nicht nach Update von node.js
      iob diag ergibt:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : v8.0.1
      Virtualization  : Unknown (buanet/Synology?)
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       12:29:36 up 14 days, 19:37,  0 users,  load average: 0.24, 0.23, 0.25
      CPU threads: 2
      *** Time and Time Zones ***
      Fri Jul 28 10:29:36 UTC 2023
      Fri Jul 28 12:29:36 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             17G        2.7G        7.1G        108M        8.0G         14G
      Swap:            12G          0B         12G
      Total:           30G        2.7G         19G
              17836 M total memory
               2706 M used memory
               5947 M active memory
               4006 M inactive memory
               7107 M free memory
                 60 M buffer memory
               7961 M swap cache
              12749 M total swap
                  0 M used swap
              12749 M free swap
      *** FILESYSTEM ***
      Filesystem        Type   Size  Used Avail Use% Mounted on
      /dev/vg1/volume_1 btrfs  889G  8.4G  881G   1% /
      tmpfs             tmpfs   64M     0   64M   0% /dev
      tmpfs             tmpfs  8.8G     0  8.8G   0% /sys/fs/cgroup
      shm               tmpfs   64M     0   64M   0% /dev/shm
      /dev/vg1/volume_1 btrfs  889G  8.4G  881G   1% /opt/iobroker
      tmpfs             tmpfs  8.8G     0  8.8G   0% /proc/acpi
      tmpfs             tmpfs  8.8G     0  8.8G   0% /proc/scsi
      tmpfs             tmpfs  8.8G     0  8.8G   0% /sys/firmware
      [Thu Jul 13 16:52:14 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Thu Jul 13 16:52:14 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jul 13 16:52:15 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Thu Jul 13 16:52:15 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jul 13 16:52:20 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Thu Jul 13 16:52:20 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Jul 13 16:52:20 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/96abe3365b486341f937c50329452ff1a999250b362c2487cca8a6be80dee044]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=302,subvol=/@syno/@docker/btrfs/subvolumes/96abe3365b486341f937c50329452ff1a999250b362c2487cca8a6be80dee044
      |-/opt/iobroker    /dev/vg1/volume_1[/@syno/@docker/volumes/4e009e52d4c8c9014dd9b3c5f83c32ade2e66d1daa8b143becec6333d21fc9c3/_data]          btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno
      /var:
      33M     /var/
      30M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      161M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      367M    /opt/iobroker/iobroker-data/
      190M    /opt/iobroker/iobroker-data/files
      74M     /opt/iobroker/iobroker-data/history
      60M     /opt/iobroker/iobroker-data/backup-objects
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/states.jsonl
      18M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.59233a80.js.map
      8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
           18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
       *** 18.16.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : buanet-iobroker1                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : buanet-iobroker1                         -  enabled
      + system.adapter.bshb.0                   : bshb                  : buanet-iobroker1                         -  enabled
        system.adapter.daswetter.0              : daswetter             : buanet-iobroker1                         -  enabled
        system.adapter.devices.0                : devices               : buanet-iobroker1                         - disabled
      + system.adapter.discovery.0              : discovery             : buanet-iobroker1                         -  enabled
        system.adapter.dwd.0                    : dwd                   : buanet-iobroker1                         -  enabled
      + system.adapter.email.0                  : email                 : buanet-iobroker1                         -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : buanet-iobroker1                         -  enabled
        system.adapter.flot.0                   : flot                  : buanet-iobroker1                         - disabled
      + system.adapter.followthesun.0           : followthesun          : buanet-iobroker1                         -  enabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : buanet-iobroker1                         -  enabled
      + system.adapter.fronius.0                : fronius               : buanet-iobroker1                         -  enabled
      + system.adapter.fronius.1                : fronius               : buanet-iobroker1                         -  enabled
      + system.adapter.harmony.0                : harmony               : buanet-iobroker1                         -  enabled
      + system.adapter.history.0                : history               : buanet-iobroker1                         -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : buanet-iobroker1                         -  enabled
        system.adapter.ical.0                   : ical                  : buanet-iobroker1                         -  enabled
      + system.adapter.javascript.0             : javascript            : buanet-iobroker1                         -  enabled
      + system.adapter.luxtronik2.0             : luxtronik2            : buanet-iobroker1                         -  enabled, port: 8214
      + system.adapter.netatmo.0                : netatmo               : buanet-iobroker1                         -  enabled
      + system.adapter.s7.0                     : s7                    : buanet-iobroker1                         -  enabled
      + system.adapter.sonoff.0                 : sonoff                : buanet-iobroker1                         -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : buanet-iobroker1                         - disabled
        system.adapter.tr-064.0                 : tr-064                : buanet-iobroker1                         - disabled
      + system.adapter.trashschedule.0          : trashschedule         : buanet-iobroker1                         -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : buanet-iobroker1                         - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : buanet-iobroker1                         -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : buanet-iobroker1                         - disabled
        system.adapter.vis.0                    : vis                   : buanet-iobroker1                         -  enabled
      + system.adapter.web.0                    : web                   : buanet-iobroker1                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bshb"         : 0.2.4    , installed 0.2.4
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.4.1    , installed 0.4.1
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "s7"           : 1.3.15   , installed 1.3.15
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Objects and States
      Objects:        15027
      States:         13262
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 5
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       35648938   -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       35645417   -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       35645408   -
      tcp        0      0 127.0.0.11:44876        0.0.0.0:*               LISTEN      0          35642734   -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       35646160   -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       35652920   -
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       35651455   -
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       35651456   -
      udp        0      0 127.0.0.11:39063        0.0.0.0:*                           0          35642733   -
      2023-07-28 12:28:42.045  - warn: luxtronik2.0 (17069) Unknown data item parameters.solarPumpDeaerate
      2023-07-28 12:28:42.045  - warn: luxtronik2.0 (17069) Unknown data item parameters.runDeaerate
      2023-07-28 12:29:02.338  - warn: luxtronik2.0 (17069) Unknown data item parameters.solarPumpDeaerate
      2023-07-28 12:29:02.339  - warn: luxtronik2.0 (17069) Unknown data item parameters.runDeaerate
      2023-07-28 12:29:22.638  - warn: luxtronik2.0 (17069) Unknown data item parameters.solarPumpDeaerate
      2023-07-28 12:29:22.638  - warn: luxtronik2.0 (17069) Unknown data item parameters.runDeaerate
      2023-07-28 12:29:42.949  - warn: luxtronik2.0 (17069) Unknown data item parameters.solarPumpDeaerate
      2023-07-28 12:29:42.949  - warn: luxtronik2.0 (17069) Unknown data item parameters.runDeaerate
      2023-07-28 12:30:00.044  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 started with pid 17636
      2023-07-28 12:30:02.358  - info: dwd.0 (17636) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
      2023-07-28 12:30:03.255  - warn: luxtronik2.0 (17069) Unknown data item parameters.solarPumpDeaerate
      2023-07-28 12:30:03.255  - warn: luxtronik2.0 (17069) Unknown data item parameters.runDeaerate
      2023-07-28 12:30:03.997  - info: dwd.0 (17636) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-28 12:30:04.069  - info: host.buanet-iobroker1 instance system.adapter.daswetter.0 started with pid 17666
      2023-07-28 12:30:04.525  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-28 12:30:05.794  - info: daswetter.0 (17666) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
      2023-07-28 12:30:08.094  - info: host.buanet-iobroker1 instance system.adapter.ical.0 started with pid 17876
      2023-07-28 12:30:10.507  - info: ical.0 (17876) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
      2023-07-28 12:30:11.413  - info: ical.0 (17876) processing URL: EVS https://calendar.google.com/calendar/ical/ef5pndka0mcg8h1oamtoeh1ods%40group.calendar.google.com/private-072651ea6547399856750ee79ba8dead/basic.ics
      2023-07-28 12:30:12.352  - info: ical.0 (17876) processing URL: Lena & Frosch https://calendar.google.com/calendar/ical/fea9jdj6u1clr7oudn6eeu9ds0%40group.calendar.google.com/private-3f2ae9335eb2156992340cc09f214a05/basic.ics
      2023-07-28 12:30:14.199  - info: ical.0 (17876) processing URL: Frosch https://calendar.google.com/calendar/ical/tofrog%40gmail.com/private-a9dedef5677564a9ee9c8b28f77ecb80/basic.ics
      2023-07-28 12:30:15.150  - warn: trashschedule.0 (561) no events matches type "Graue Tonne" with match "Restabfalltonne"
      2023-07-28 12:30:15.196  - warn: trashschedule.0 (561) no events matches type "Gelbe Tonne" with match "Gelbe"
      2023-07-28 12:30:15.239  - warn: trashschedule.0 (561) no events matches type "Bio Tonne" with match "Bio"
      2023-07-28 12:30:15.312  - warn: trashschedule.0 (561) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule!
      iob diag has finished.
      posted in Installation
      F
      Frosch 23
      ich hab endlcih mal wieder Zeit mich um mein Problem zu kümmern und greife das Thema nochmal auf, weil es immer noch nicht so funktioniert wie es soll.
      Nur zur Info: RAM hab ich aufgerüstet, und es wird auch richtig erkannt und angezeigt. (Synology NAS, DS220+ läuft perfekt)
      Jetzt wieder zum ursprünglichen Problem: Verbindungsfehler/no connection nur im Vis Editor
      In meinem Ursprünglichen iobroker läuft die VIS und ich kann alles bedienen, aber nichts mehr editieren.
      So wie ich gelesen habe, sollte ich alle Adapter, die mit VIS zu tun haben (vis, vis-inventwo, vis-icontwo und vis-timeandweather) löschen und neuinstallieren.
      Bevor ich das mache, würde ich gerne ein Backup von meinem kompletten Docker machen. (nicht, dass nachher nichts mehr geht)
      Kann mir jemand beschreiben, wie ein Docker-Backup gemachtwerden kann? Nach der Beschreibung, die ich gefunden habe, im Portainer über "Duplicate/Edit" wird leider nur eine neue Instanz erzeugt und dich erhalte einen leeren iobroker. Das erhalte ich auch wenn ich einen neuen Container mit iobroker erstelle.
      Egal wie, wenn ich einen leeren Docker container mit iobroker habe, habe ich versucht das Backup mit Backitup zu installieren. Nur danach geht in der neuen Instanz nichts mehr. Irgendwie komme ich nicht weiter.
      Kann mir jemand beschreiben, wie ich meinen laufenden iobroker wieder funktionsfähig bekomme oder einen Link schicken, wie ich das Bakup (funktionsfähig) installieren kann. Ich hab schon viel gesucht, bin aber wahrscheinlich zu blöd die richtige Anleitung zu finden. Wahrscheinlich ist es ganz einfach, aber...
      Danke für eure Bemühungen
      F
      Frosch 23
      @homoran said in vis funktioniert Nicht nach Update von node.js:
      @frosch-23 sagte in vis funktioniert Nicht nach Update von node.js:
      Mem: 1.8G 1.4G 99M 1.0M 294M 193M
      deine Meinung
      sieht das nciht nach einem Speicherprobelm aus:
      kann ich nicht teilen.
      Kenne die Docker Installationen nicht, aber knapp 2 GB RAM erscheinen mir sehr wenig
      hm, ich frag mich zwar warum in ioBroker -> Host nur ~14% als benutzt stehen. Aber ich muss euch Recht geben. 99MB frei ist wenig.
      Liegt das an meinem Synology Nas DS220+, der Installation im Docker oder an irgendwelchen Einstellungen? (Dockker installation über Portainer) Wenn ich das richtig weiß (bitte korrigiert mich) kann ich auf 8GB erweitern. Braucht die Installation so viel und das ist dann die Lösung oder ist bei der Wiederherstellung etwas schief gelaufen? Vorher kam keine Melddung. Kann aber heute nicht mehr sagen ob es vielleicht knapp war.
      F
      Frosch 23
      Und das hat jetzt genau an welcher Stelle mit deinem Betriebssystem zu tun?
      nichts. Ich mag linux und will es besser kennenlernen.
      Aber wieder zum Thema:
      Ich hab mich wohl zu früh gefreut:
      zum Einen gibt es seit der Wiederherstellung probleme mit dem Speicher:
      Aber wenn ich auf den Host gehe sieht das nciht nach einem Speicherprobelm aus:
      zum Anderen hab ich noch Probelme bei der VIS: VerbindungsfehlerVerbindungsfehler.JPG
      iob diag ergibt folgendes:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : v8.0.1
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
       13:25:26 up 6 days, 10:35,  0 users,  load average: 0.41, 0.20, 0.14
      CPU threads: 2
      Fri Jun 23 11:25:26 UTC 2023
      Fri Jun 23 13:25:26 CEST 2023
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           3.1G        1.5G        1.6G
      Total:          4.9G        2.9G        1.7G
               1753 M total memory
               1359 M used memory
                531 M active memory
                525 M inactive memory
                 99 M free memory
                  0 M buffer memory
                293 M swap cache
               3101 M total swap
               1545 M used swap
               1556 M free swap
      *** FILESYSTEM ***
      /dev/vg1/volume_1 btrfs  889G  5.4G  884G   1% /
      tmpfs             tmpfs  877M     0  877M   0% /sys/fs/cgroup
      /dev/vg1/volume_1 btrfs  889G  5.4G  884G   1% /opt/iobroker
      tmpfs             tmpfs  877M     0  877M   0% /proc/acpi
      tmpfs             tmpfs  877M     0  877M   0% /proc/scsi
      tmpfs             tmpfs  877M     0  877M   0% /sys/firmware
      [Sat Jun 17 02:50:03 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Jun 17 02:50:03 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Jun 17 02:50:04 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Jun 17 02:50:04 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Jun 17 02:50:09 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Jun 17 02:50:09 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Jun 17 02:50:10 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Jun 17 02:50:10 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Sat Jun 17 02:50:46 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      |-/opt/iobroker    /dev/vg1/volume_1[/@syno/@docker/volumes/4e009e52d4c8c9014dd9b3c5f83c32ade2e66d1daa8b143becec6333d21fc9c3/_data]          btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/volumes/4e009e52d4c8c9014dd9b3c5f83c32ade2e66d1daa8b143becec6333d21fc9c3/_data
      |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/resolv.conf
      |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hostname
      `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/20447e8ee1f4b8a252285c6eb4bc9e291a442963cc2c9aa59419cb6e87a22455/hosts
      /var:
      16M     /var/
      13M     /var/lib/dpkg
      13M     /var/lib
      12M     /var/lib/dpkg/info
      1.9M    /var/cache/debconf
      46M     /opt/iobroker/backups/
      299M    /opt/iobroker/iobroker-data/
      58M     /opt/iobroker/iobroker-data/backup-objects
      45M     /opt/iobroker/iobroker-data/files/devices.admin
      16M     /opt/iobroker/iobroker-data/states.jsonl
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Vielleicht sieht einer der Profis ja was hier nicht rundläuft.
      Danke fürs Helfen
      F
      Frosch 23
      @bahnuhr
      ja, die richtige Vorgehensweise...
      Dafür kenn ich mich mit den ganzen Linux-geraffel nicht gut genug aus. - leider 😧
      Trotzdem DANKE für eure Unterstützung!
      F
      Frosch 23
      @frosch-23
      Ich hab es gefunden.... in den Tiefen dieses Forums stand irgendwo, dass man nicht:
      iobroker install vis@1.4.0
      sondern
      iobroker upgrade vis@1.4.0
      zum downgrade nehmen muss. danach geht wieder alles.
      Danke nochmals an alle die mich bei dem Problem unterstützt haben.
      F
      Frosch 23
      Edit: gelöscht
      F
      Frosch 23
      @glasfaser
      Guten Morgen,
      zunächst möchte ich auf eure Fragen eingehen:
      als stiller mitleser habe
      Ich beschäftige mich schon seit mehreren Jahren mit dem Thema rund um SmartHome. Leider reicht die Zeit nicht um richtig dran zu beliben und so gehe ich von Zeit zu Zeit die Themen an.
      Das sehe ich nicht so , warum hast du mir in deinem anderen alten Thread nicht geantwortet
      Nun ja, am wahrscheinlichsten ist, dass ich das Problem damals anders gelöst hatte und somit die Frage überflüssig war. Wenn ich dann vergessen habe zu Antworten lag das bestimmt nicht an einer bösen Absicht, sondern eher daran, dass ich es in meiner Struddeligkeit vergessen habe.
      PS: Das MacVLAN habe ich am laufen, auch die Multicast Adaper funktionieren. Jetzt hab ich nur ncoh ein neues Problem: Mit OpenVPN komme ich nicht mehr auf meinen ioBroker. Wenn ich mal Zeit hab...
      Nun zum eigentlichen Problem:
      Nach dem Update von node.js war mein ioBroker, als ich das UI aufgerufen hatte leer. Nur Backitup war drin. Bei VIS bin ich mir grade nicht sicher. Und ja, ich hab VIS nicht vor dem Wiederherstellen installiert. Aber wie komme ich nun raus aus dem Schlamassel? Neuen Docker aufsetzen und dann das Prozedere nochmal? Vis->Backitup, oder gibt es eine andere Lösung?
      Danke schonmal für die Antworten, und bitte nicht böse sein wenn ich etwas brauche zum Testen und zurückschreiben.
      Anbei noch die iob Diag:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : v8.0.1
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      06:57:28 up 45 days,  4:02,  0 users,  load average: 0.28, 0.28, 0.17
      CPU threads: 2
      Tue Jun  6 04:57:28 UTC 2023
      Tue Jun  6 06:57:28 CEST 2023
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            1.8G        1.2G        159M        1.0M        353M        302M
      Swap:           3.1G        1.2G        1.9G
      Total:          4.9G        2.4G        2.1G
               1753 M total memory
               1240 M used memory
                477 M active memory
                500 M inactive memory
                159 M free memory
                  0 M buffer memory
                352 M swap cache
               3101 M total swap
               1154 M used swap
               1947 M free swap
      *** FILESYSTEM ***
      /dev/vg1/volume_1 btrfs  889G  5.9G  884G   1% /
      /dev/vg1/volume_1 btrfs  889G  5.9G  884G   1% /opt/iobroker
      [Sat Apr 22 02:54:41 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Apr 22 02:54:41 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Apr 22 02:54:42 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Apr 22 02:54:42 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Apr 22 02:54:47 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Apr 22 02:54:47 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Apr 22 02:54:48 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Sat Apr 22 02:54:48 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Sat Apr 22 02:55:22 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      /                  /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/fea930021a2c117bca511fa2dd45b8fd34d8efb3720fed6120841c476f454e02]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=292,subvol=/@syno/@docker/btrfs/subvolumes/fea930021a2c117bca511fa2dd45b8fd34d8efb3720fed6120841c476f454e02
      |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/resolv.conf
      |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/hostname
      `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/b3199280fb44eec8f0426cdedd9f1d11569c8fd644986453207c0f2b07074543/hosts
      /var:
      33M     /var/
      30M     /var/lib
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      16M     /opt/iobroker/backups/
      241M    /opt/iobroker/iobroker-data/
      164M    /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      50M     /opt/iobroker/iobroker-data/backup-objects
      42M     /opt/iobroker/iobroker-data/files/devices.admin
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.05e58ebd.js.map
      8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      *** 18.16.0-deb-1nodesource1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
        system.adapter.luxtronik2.1             : luxtronik2            : buanet-iobroker1                         - disabled, port: 8214
      + instance is alive
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
      Adapter    "s7"           : 1.3.14   , installed 1.3.14
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Objects and States
      Objects:        11497
      States:         10155
      Pending Updates: 0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       178374467  -
      tcp        0      0 127.0.0.11:42430        0.0.0.0:*               LISTEN      0          178311130  -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       178372313  -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       178372292  -
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       178376385  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       178370474  -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       178377508  -
      udp        0      0 127.0.0.11:45390        0.0.0.0:*                           0          178311129  -
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       178376386  -
      2023-06-06 06:42:13.573  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:44:43.971  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:45:00.030  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 started with pid 739
      2023-06-06 06:45:01.129  - info: dwd.0 (739) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
      2023-06-06 06:45:01.759  - info: dwd.0 (739) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-06 06:45:02.278  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-06 06:45:04.051  - info: host.buanet-iobroker1 instance system.adapter.daswetter.0 started with pid 754
      2023-06-06 06:45:05.148  - info: daswetter.0 (754) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
      2023-06-06 06:45:11.737  - info: daswetter.0 (754) still wrong data structure from server received! repaired...
      2023-06-06 06:45:13.304  - info: daswetter.0 (754) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-06-06 06:45:13.811  - info: daswetter.0 (754) cleaned everything up...
      2023-06-06 06:45:13.821  - info: host.buanet-iobroker1 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-06 06:47:13.871  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:49:43.816  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:50:00.025  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 started with pid 1025
      2023-06-06 06:50:01.120  - info: dwd.0 (1025) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
      2023-06-06 06:50:01.525  - info: dwd.0 (1025) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-06 06:50:02.046  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-06 06:52:13.568  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:54:43.794  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      2023-06-06 06:55:00.024  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 started with pid 1454
      2023-06-06 06:55:01.693  - info: dwd.0 (1454) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
      2023-06-06 06:55:02.307  - info: dwd.0 (1454) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-06 06:55:02.835  - info: host.buanet-iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-06 06:57:13.798  - warn: fronius.0 (2328) State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions
      Press any key for a summary
      Copy text starting here:
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 4.4.180+
      Installation:           Docker
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
      Mem:            1.8G        1.3G        195M        1.0M        293M        278M
      Active iob-Instances:   20
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                11497
      States:                 10156
      Size of iob-Database:
      4.3M    /opt/iobroker/iobroker-data/states.jsonl
      =================== END OF SUMMARY ==================
      F
      Frosch 23
    • vis funktioniert Nicht nach Update von node.js
      Hallo comunity,
      als stiller mitleser habe ich in den letzen Jahren schon so einiges hinbekommen. Leider bin ich heute an meine Grenzen gestoßen.
      Vorweg: ich habe einen ioBroker im Docker von André (buanet) auf einer Synology Nas am laufen.
      Heute habe ich mich an das längst überfällige update von node.js getraut und dachte mit dem Backup (über Backitup) bin ich gut gerüstet.
      Hier mal ein riesen DANKESCHÖN an André für die klasse Arbeit und die gute Tutorials!
      Das Update hab ich nach der Anleitung von André: [https://smarthome.buanet.de/2020/10/iobroker-docker-container-updates-upgrades/](link url)
      durchgeführt. Das hat auch alles funktioniert, außer, dass der ioBroker komlett leer war. Also keine Adapter installiert waren.
      Was solls, dachte ich mir: Backitup -> wieder herstellen. Auch das hat funktioniert, außer VIS.
      Vis funktioniert nicht mehr.
      Unter /opt/iobroker/node_modules hat der ordner iobroker.vis gefehlt
      Also Vis mit ```
      npm install vis@1.4.16
      Wenn ich in den Instanzen auf die Einstellungen von Vis klicke bekomme ich diese Fehlermeldung: File index_m.html not found
      Kann mir einer der Profis sagen, wie ich den Fehler finden und beheben kann? in welchen Logs muss ich nachsehen?
      Ich hoffe nur, dass die ganzen Einstellungen und Bilder die ich angelegt habe nicht weg sind. hier stecken mehrere Tag, nein Wochen Arbeit drin.
      Vielen Dank
      Frosch
      F
      Frosch 23
    • Backup in neuen ioBroker (Docker) installieren
      Hallo Gemeinde,
      Ich hab ein „gefährliches“ Halbwissen da ich schon geraume Zeit mit Pi‘s, homematic, iobroker usw. herumexperimentiere.
      Jetzt hab ich aber ein Problem und komme nicht dahinter…
      Ich habe einen Docker mit buanet-iobroker auf meiner DS220+ mit zwei kleinen Problemen am laufen. Hier sei ein Dankeschön an André für seine Arbeit am Docker Image und seine Beschreibungen gerichtet.
      1. /opt/iobroker ist lokal
      2. Netzwerk ist Bridged (und das macht mir Probleme)
      Beides möchte ich ändern damit ich den container updaten kann und mit macvlan arbeiten. Hat den Vorteil, dass die multicast Adapter funktionieren sollen. Da ich am laufenden System nicht arbeiten möchte hab ich mir einen neuen Container gemach, iobroker installiert, Backup mit Backitup vom laufenden System erstellt und wieder im neuen iobroker mit Backitup hergestellt. Danach ich aber die Admin-Oberfläche nichtmetrischen erreichbar. Bindings hab ich wieder hergestellt.
      Hat noch jemand eine Idee? Ich Weiß nicht mehr nach was ich suchen soll. Zudem müsste ich ein neues Backup einspielen, da das Problem schon vor 2 Monaten entstand und seit dem auf der Suche nach einer Lösung bin.
      F
      Frosch 23
