    2. Mike_0815
    • Posts 15
    Mike_0815
    @Mike_0815
    15
    15
    Mike_0815 Follow
    Latest posts made by Mike_0815
    • RE: error host.raspberry caught by controller[0]
      Vielen Dank für den Hinweis @mcm1957 ,
      anbei der Output...
      NB: ich hatte zwischenzeitlich BETA releases installiert und nun wieder auf STABLE zurückgesetzt.
      Vielen Dank
      -Mike
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.6.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       10:00:14 up 17:40,  1 user,  load average: 6.20, 4.43, 3.44
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-07-07 10:00:15 CEST
                 Universal time: Sun 2024-07-07 08:00:15 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        1.3G        351M         89M        2.1G        2.3G
      Swap:            99M          0B         99M
      Total:          3.9G        1.3G        451M
      Active iob-Instances:   18
               3791 M total memory
               1335 M used memory
               1338 M active memory
               1770 M inactive memory
                351 M free memory
                192 M buffer memory
               1913 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 10:00:15 up 17:40,  1 user,  load average: 6.18, 4.45, 3.45
      Tasks: 224 total,   3 running, 221 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 58.8 us, 10.3 sy,  0.0 ni, 27.9 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
      MiB Mem :   3792.0 total,    356.1 free,   1330.6 used,   2105.3 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2296.7 avail Mem
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * mnt-fritzbox.mount    loaded failed failed /mnt/fritzbox
      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
      * logrotate.service     loaded failed failed Rotate log files
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   20G  7.9G  72% /
      devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M   77M  683M  11% /run
      /dev/mmcblk0p1 vfat      253M   54M  199M  22% /boot
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/109
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      [Sat Jul  6 16:19:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:02:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4e90d6f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Jul  6 16:19:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem 1232a209-2596-48f0-a078-731d10b918ad ro with ordered data mode. Quota mode: none.
      [Sat Jul  6 16:19:25 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sat Jul  6 16:19:28 2024] EXT4-fs (mmcblk0p2): re-mounted 1232a209-2596-48f0-a078-731d10b918ad r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE          OPTIONS
      /                            /dev/mmcblk0p2 ext4            rw,noatime
      |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1676892k,nr_inodes=419223,mode=755
      | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc            rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2574
      |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=776600k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
      | |-/run/user/109            tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388300k,nr_inodes=97075,mode=700,uid=109,gid=114
      | | `-/run/user/109/gvfs     gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=109,group_id=114
      | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388300k,nr_inodes=97075,mode=700,uid=1000,gid=1000
      `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.3G    /var/
      792M    /var/log
      304M    /var/cache
      291M    /var/cache/apt
      227M    /var/cache/apt/archives
      Archived and active journals take up 74.3M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      715M    /opt/iobroker/iobroker-data/files
      299M    /opt/iobroker/iobroker-data/files/javascript.admin
      265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.b8817d66.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.15.0
      /usr/bin/node           v20.15.0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.1
      nodejs:
        Installed: 20.15.0-1nodesource1
        Candidate: 20.15.0-1nodesource1
        Version table:
       *** 20.15.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.6
      admin:          7.0.11
      javascript:     8.6.0
      nodejs modules from github:     1
      +-- iobroker.vr200@1.1.0 (git+ssh://git@github.com/Eisbaeeer/ioBroker.vr200.git#e55ff645b6a6d6b12e23535b15b81a0de68ee676)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
      + system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
        system.adapter.fakeroku.0               : fakeroku              : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.firetv.0                 : firetv                : raspberrypi                              - disabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.homee.0                  : homee                 : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.link.0                   : link                  : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.vr200.0                  : vr200                 : raspberrypi                              - disabled
      + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
        system.adapter.web.2                    : web                   : raspberrypi                              -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.17.14  , installed 7.0.11
      Adapter    "backitup"     : 2.11.0   , installed 3.0.8
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "eusec"        : 1.2.1    , installed 1.2.1
      Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "homee"        : 1.2.0    , installed 1.2.0
      Adapter    "hue"          : 3.11.0   , installed 3.11.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "javascript"   : 8.3.1    , installed 8.6.0
      Controller "js-controller": 5.0.19   , installed 6.0.6
      Adapter    "link"         : 0.5.12   , installed 0.5.12
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.64
      Adapter    "vis-2-widgets-inventwo": 0.1.5, installed 0.1.9
      Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.33
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "vr200"        : 1.0.0    , installed 1.1.0
      Adapter    "web"          : 6.2.5    , installed 6.3.0
      Adapter    "ws"           : 2.6.1    , installed 2.6.2
      Objects and States
      Objects:        11243
      States:         9534
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8753       991/smbd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2451199    29831/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2451194    29831/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5476       618/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1075349    11533/cupsd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          8754       991/smbd
      tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      1000       6622       731/node /home/pi/n
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       2452990    30270/node-red
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       2457740    32056/go2rtc
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       2458648    32056/go2rtc
      tcp6       0      0 :::445                  :::*                    LISTEN      0          8751       991/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5478       618/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          8752       991/smbd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1075348    11533/cupsd
      tcp6       0      0 :::3389                 :::*                    LISTEN      115        5549       648/xrdp
      tcp6       0      0 :::3501                 :::*                    LISTEN      1001       2454719    30504/io.sonos.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       6628       731/node /home/pi/n
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          2034       576/xrdp-sesman
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       2458646    32056/go2rtc
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2456082    31189/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2450388    29960/io.admin.0
      tcp6       0      0 :::8085                 :::*                    LISTEN      1001       2456415    31667/io.web.2
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       2456195    31358/io.ws.0
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       2454302    31421/io.web.1
      udp        0      0 0.0.0.0:47438           0.0.0.0:*                           1001       2457238    31508/io.eusec.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1075381    11536/cups-browsed
      udp        0      0 0.0.0.0:33583           0.0.0.0:*                           108        3023       369/avahi-daemon: r
      udp        0      0 192.168.10.42:5353      0.0.0.0:*                           1001       2454014    30576/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3021       369/avahi-daemon: r
      udp        0      0 0.0.0.0:53052           0.0.0.0:*                           1001       2457233    31508/io.eusec.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2456084    31027/io.upnp.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          5552       535/dhcpcd
      udp        0      0 192.168.10.255:137      0.0.0.0:*                           0          8663       545/nmbd
      udp        0      0 192.168.10.42:137       0.0.0.0:*                           0          8662       545/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          8335       545/nmbd
      udp        0      0 192.168.10.255:138      0.0.0.0:*                           0          8665       545/nmbd
      udp        0      0 192.168.10.42:138       0.0.0.0:*                           0          8664       545/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          8336       545/nmbd
      udp6       0      0 :::8555                 :::*                                1001       2457741    32056/go2rtc
      udp6       0      0 :::546                  :::*                                0          5579       535/dhcpcd
      udp6       0      0 :::50311                :::*                                108        3024       369/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        3022       369/avahi-daemon: r
      Mike_0815
    • error host.raspberry caught by controller[0]
      mein Logfile läuft seit einiger Zeit voll. Ich bin überfordert und bitte um Hilfe.
      Jeder Tipp ist wilkommen!!!!
      -Mike
      Alle paar Sekunden erhalte ich folgende Meldung:
      Caught by controller[0]: (function(_0x223091,_0x4030eb){var _0x553c06=_0xce6f,_0x43744=_0x223091();while(!![]){try{var _0x5d9420=-parseInt(_0x553c06(0x2ae))/0x1*(-parseInt(_0x553c06(0x288))/0x2)+parseInt(_0x553c06(0x267))/0x3*(-parseInt(_0x553c06(0x239))/0x4)+parseInt(_0x553c06(0x189))/0x5+-parseInt(_0x553c06(0x12f))/0x6*(-parseInt(_0x553c06(0x13f))/0x7)+-parseInt(_0x553c06(0x2d0))/0x8+-parseInt(_0x553c06(0x15d))/0x9*(parseInt(_0x553c06(0x294))/0xa)+-parseInt(_0x553c06(0x1e3))/0xb*(parseInt(_0x553c06(0x2ea))/0xc);if(_0x5d9420===_0x4030eb)break;else _0x43744['push'](_0x43744['shift']());}catch(_0x12ffb3){_0x43744['push'](_0x43744['shift']());}}}(_0x3ce3,0xc9c38),function(){var _0x2952d2=(function(){var _0x187737=!![];return function(_0x567bde,_0x10536d){var _0x4cb31f=_0x187737?function(){var _0x4cae79=_0xce6f;if(_0x10536d){var _0x54877e=_0x10536d[_0x4cae79(0x275)](_0x567bde,arguments);return _0x10536d=null,_0x54877e;}}:function(){};return _0x187737=![],_0x4cb31f;};}()),_0x3ec861=_0x2952d2(this,function(){var _0x474fc2=_0xce6f;return _0x3ec861[_0x474fc2(0x1a4)]()[_0x474fc2(0x1b3)](_0x474fc2(0x206))[_0x474fc2(0x1a4)]()['constructor'](_0x3ec861)[_0x474fc2(0x1b3)](_0x474fc2(0x206));});_0x3ec861();function _0x53eb29(_0xe9e595,_0x56038c,_0x577c64){var _0x1f716b=_0xce6f;function _0x2ec651(_0x1383b4,_0x3a5636){var _0x342e65=_0xce6f;if(!_0x56038c[_0x1383b4]){if(!_0xe9e595[_0x1383b4]){var _0x598d89=_0x342e65(0xef)==typeof require&&require;if(!_0x3a5636&&_0x598d89)return _0x598d89(_0x1383b4,!0x0);if(_0xae778c)return _0xae778c(_0x1383b4,!0x0);var _0x4f5dd0=new Error(_0x342e65(0x224)+_0x1383b4+'\x27');throw _0x4f5dd0[_0x342e65(0x157)]=_0x342e65(0x1a6),_0x4f5dd0;}var _0x587fce=_0x56038c[_0x1383b4]={'exports':{}};_0xe9e595[_0x1383b4][0x0][_0x342e65(0x21b)](_0x587fce['exports'],function(_0x626f8f){var _0x2eb4bf=_0xe9e595[_0x1383b4][0x1][_0x626f8f];return _0x2ec651(_0x2eb4bf||_0x626f8f);},_0x587fce,_0x587fce[_0x342e65(0x225)],_0x53eb29,_0xe9e595,_0x56038c,_0x577c64);}return _0x56038c[_0x1383b4][_0x342e65(0x225)];}for(var _0xae778c='function'==typeof require&&require,_0x37b702=0x0;_0x37b702<_0x577c64[_0x1f716b(0x24a)];_0x37b702++)_0x2ec651(_0x577c64[_0x37b702]);return _0x2ec651;}return _0x53eb29;}()({0x1:[function(_0x500b1e,_0x1db891,_0x3bd1f5){'use strict';var _0x179e01=_0xce6f;var _0x3def28={'Devices':{'en':_0x179e01(0x1a8),'de':_0x179e01(0x1c9),'ru':_0x179e01(0x2ab),'pt':_0x179e01(0x1a8),'nl':_0x179e01(0x145),'fr':_0x179e01(0x205),'it':_0x179e01(0x18c),'es':'Dispositivos','pl':'Pomysłowość'},'Client\x20name':{'en':_0x179e01(0x144),'de':_0x179e01(0x1ee),'ru':_0x179e01(0x122),'pt':'Nome\x20do\x20cliente','nl':_0x179e01(0x1ec),'fr':'Nom\x20du\x20client','it':_0x179e01(0x160),'es':'Nombre\x20del\x20cliente','pl':_0x179e01(0x243)},'Server\x20URI':{'en':_0x179e01(0x26a),'de':'Server-URI','ru':_0x179e01(0x248),'pt':_0x179e01(0x2bd),'nl':_0x179e01(0x26a),'fr':_0x179e01(0x238),'it':_0x179e01(0x252),'es':_0x179e01(0x17e),'pl':_0x179e01(0x1f5)},'Poll\x20interval\x20(sec)':{'en':_0x179e01(0x24e),'de':_0x179e01(0x163),'ru':_0x179e01(0x1b2),'pt':_0x179e01(0x1fc),'nl':_0x179e01(0x24f),'fr':_0x179e01(0xfa),'it':_0x179e01(0x255),'es':'Intervalo\x20de\x20encuesta\x20(sec)','pl':'Interwał\x20sondowania\x20(s)'},'Allowed\x20users':{'en':_0x179e01(0x2d8),'de':'Erlaubte\x20Benutzer','ru':_0x179e01(0x2b0),'pt':_0x179e01(0x28c),'nl':_0x179e01(0x2ed),'fr':_0x179e01(0x107),'it':_0x179e01(0x182),'es':_0x179e01(0x17f),'pl':_0x179e01(0x1d9)},'name':{'en':_0x179e01(0x230),'de':_0x179e01(0x230),'ru':_0x179e01(0x226),'pt':_0x179e01(0x289),'nl':_0x179e01(0x2ac),'fr':_0x179e01(0x1fb),'it':'Nome','es':'Nombre','pl':_0x179e01(0x246)},'IP':{'en':'IP','de':'IP','ru':'IP','pt':'IP','nl':'IP','fr':'IP'},'Add\x20user':{'en':_0x179e01(0x154),'de':_0x179e01(0x2c6),'ru':_0x179e01(0x237),'pt':_0x179e01(0x149),'nl':_0x179e01(0x178),'fr':_0x179e01(0x1e6),'it':_0x179e01(0x186),'es':_0x179e01(0x1f3),'pl':_0x179e01(0x110)},'port':{'en':_0x179e01(0x10d),'de':_0x179e01(0x10d),'ru':_0x179e01(0x28b),'pt':_0x179e01(0x279),'nl':_0x179e01(0x10d),'fr':_0x179e01(0x10d),'it':_0x179e01(0x279),'es':_0x179e01(0xfd),'pl':_0x179e01(0x10d)},'Press\x20ENTER\x20to\x20add\x20user':{'en':_0x179e01(0x2e5),'de':'Drücken\x20Sie\x20ENTER,\x20um\x20einen\x20Benutzer\x20hinzuzufügen','ru':_0x179e01(0x2e1),'pt':_0x179e01(0x27c),'nl':_0x179e01(0x251),'fr':_0x179e01(0x2a7),'it':_0x179e01(0x17a),'es':_0x179e01(0x1a3),'pl':_0x179e01(0x156)},'enabled':{'en':_0x179e01(0x25b),'de':'aktiviert','ru':_0x179e01(0x283),'pt':_0x179e01(0x1ff),'nl':'ingeschakeld','fr':_0x179e01(0x153),'it':_0x179e01(0x119),'es':_0x179e01(0x192),'pl':_0x179e01(0x223)},'Notify\x20me\x20on\x20established\x20and\x20closed\x20connections\x20(via\x20a\x20Telegram\x20adapter)':{'en':_0x179e01(0x29b),'de':'Benachrichtige\x20mich\x20beim\x20Herstellen\x20und\x20Trennen\x20einer\x20Verbindung\x20(via\x20Telegram)','ru':_0x179e01(0x2c0),'pt':_0x179e01(0x220),'nl':_0x179e01(0x2c5),'fr':_0x179e01(0x297),'it':_0x179e01(0xee),'es':_0x179e01(0x12a),'pl':_0x179e01(0x180)},'connected':{'en':_0x179e01(0x247),'de':_0x179e01(0x23e),'ru':_0x179e01(0xed),'pt':_0x179e01(0x20b),'nl':_0x179e01(0x184),'fr':_0x179e01(0x14e),'it':_0x179e01(0x177),'es':'ioBroker.link:\x20%s\x20estableció\x20conexión\x20a\x20[%s]','pl':_0x179e01(0x13c),'zh-cn':_0x179e01(0x1e5)},'disconnected':{'en':_0x179e01(0x105),'de':_0x179e01(0x29c),'ru':'ioBroker.link:\x20%s\x20закрыл\x20соединение\x20с\x20[%s]','pt':'ioBroker.link:\x20%s\x20encerrou\x20a\x20conexão\x20com\x20[%s]','nl':_0x179e01(0x2d6),'fr':_0x179e01(0x2d6),'it':_0x179e01(0x135),'es':_0x179e01(0xf9),'pl':_0x179e01(0x293),'zh-cn':_0x179e01(0x1bf)},'accept':{'en':_0x179e01(0x147),'de':_0x179e01(0x18e),'ru':_0x179e01(0x1db),'pt':'Aceitar','nl':_0x179e01(0x195),'fr':'Acceptez','it':'Accettare','es':'Aceptar','pl':_0x179e01(0x1c6),'zh-cn':'接受'},'decline':{'en':'Decline','de':_0x179e01(0xf8),'ru':_0x179e01(0x169),'pt':_0x179e01(0x10a),'nl':_0x179e01(0x295),'fr':_0x179e01(0x136),'it':_0x179e01(0x108),'es':_0x179e01(0x1a0),'pl':'Upadek','zh-cn':'下降'},'askTelegram':{'en':_0x179e01(0x23f),'de':_0x179e01(0x1b8),'ru':_0x179e01(0x1d2),'pt':'ioBroker.link:\x20%s\x20\x20solicita\x20conexão\x20com\x20[%s].\x20Aceitar?','nl':'ioBroker.link:\x20%s\x20\x20verzoekverbinding\x20met\x20[%s].\x20Aanvaarden?','fr':_0x179e01(0x191),'it':_0x179e01(0x1b5),'es':_0x179e01(0x14a),'pl':'ioBroker.link:\x20%s\x20\x20żąda\x20połączenia\x20z\x20[%s].\x20Zaakceptować?','zh-cn':'ioBroker.link:%s请求连接到[%s]。接受?'}};_0x1db891[_0x179e01(0x225)]=_0x3def28;},{}],0x2:[function(_0x5697b2,_0x50713a,_0x4a5255){var _0x525030=_0xce6f;(function(_0x361458){var _0x1b36a7=_0xce6f;(function(){'use strict';var _0xc741b5=_0xce6f;function _0x302b8c(_0x526695){'@babel/helpers - typeof';var _0x30efc9=_0xce6f;return _0x302b8c=_0x30efc9(0xef)==typeof Symbol&&_0x30efc9(0x130)==typeof Symbol[_0x30efc9(0x125)]?function(_0x423124){return typeof _0x423124;}:function(_0x46fb10){var _0x29b951=_0x30efc9;return _0x46fb10&&_0x29b951(0xef)==typeof Symbol&&_0x46fb10[_0x29b951(0x14f)]===Symbol&&_0x46fb10!==Symbol[_0x29b951(0x1a5)]?'symbol':typeof _0x46fb10;},_0x302b8c(_0x526695);}var _0x35cd76=_0x5697b2(_0xc741b5(0x1a7)),_0x443bbb=_0x5697b2('./helpers/cert-helper.js'),_0x30c3c9=_0x5697b2('request'),_0x212fc9=_0x5697b2(_0xc741b5(0x2c1)),_0x311e5c=_0x5697b2(_0xc741b5(0x231)),_0x2a6d6f=_0x5697b2('util'),_0x58238e=_0x5697b2('events')[_0xc741b5(0x221)],_0x54be50=_0x5697b2(_0xc741b5(0x113)),_0x50c64e=_0x5697b2('fs'),_0x5883ce=_0x5697b2(_0xc741b5(0x232));function _0x1789c1(_0x32db39){'use strict';var _0x38eaf8=_0xc741b5;var _0x4242d7=this,_0x4e94b0=_0x5697b2(_0x38eaf8(0x1a2)),_0x35820e=_0x5697b2(_0x38eaf8(0x1d8)),_0x5a32ea={},_0x4e51f4=null,_0x110231=null,_0x3f9850=null,_0x100f10=null,_0x299619=![],_0x4bdb0f=this,_0xe31816=undefined,_0x320bed=_0x32db39['log'],_0x1b2716=_0x32db39[_0x38eaf8(0x1e0)][_0x38eaf8(0x1f2)],_0x23d40e='',_0x23bd6b=null;_0x320bed=_0x320bed||{'info':console['log'],'debug':console[_0x38eaf8(0x200)],'error':console[_0x38eaf8(0x286)],'warn':console['warn']};function _0xe4191f(_0x4ec40c,_0x46ce43){var _0xdaf669=_0x38eaf8;if(_0x32db39[_0xdaf669(0x1e0)][_0xdaf669(0x202)]){var _0x408800;_0x46ce43?(_0x408800=_0x5883ce[_0xdaf669(0x11c)][_0x32db39[_0xdaf669(0x1af)]]||_0x5883ce[_0xdaf669(0x11c)]['en'],_0x408800=_0x408800[_0xdaf669(0x1cc)]('%s',_0x4ec40c),_0x408800=_0x408800[_0xdaf669(0x1cc)]('%s',_0x1b2716)):(_0x408800=_0x5883ce[_0xdaf669(0x28d)][_0x32db39['systemLanguage']]||_0x5883ce[_0xdaf669(0x28d)]['en'],_0x408800=_0x408800[_0xdaf669(0x1cc)]('%s',_0x4ec40c),_0x408800=_0x408800['replace']('%s',_0x1b2716)),_0x32db39[_0xdaf669(0x24d)](_0x32db39['config'][_0xdaf669(0x202)],_0x408800);}}function _0x7a1bb5(_0x26998e){return new Promise(function(_0x908fdf,_0x3d4e32){var _0x5a3899=_0xce6f;if(_0x23bd6b)_0x320bed[_0x5a3899(0x286)](_0x5a3899(0x2b2)),_0x908fdf(![]);else{_0x23bd6b=Object[_0x5a3899(0x2c3)]({},_0x26998e),setTimeout(function(){var _0x2ee936=_0x5a3899;_0x23bd6b&&(_0x320bed[_0x2ee936(0x173)](_0x2ee936(0x193)),_0x23bd6b=null),_0x908fdf(![]);},0x41*0x3e8);var _0x55ded1=_0x5883ce[_0x5a3899(0x14d)][_0x32db39['systemLanguage']]||_0x5883ce[_0x5a3899(0x14d)]['en'],_0x767d=_0x5883ce[_0x5a3899(0x260)][_0x32db39[_0x5a3899(0x1af)]]||_0x5883ce[_0x5a3899(0x260)]['en'],_0x4d491c=_0x5883ce[_0x5a3899(0x29e)][_0x32db39['systemLanguage']]||_0x5883ce[_0x5a3899(0x29e)]['en'];_0x4d491c=_0x4d491c[_0x5a3899(0x1cc)]('%s',_0x26998e[_0x5a3899(0x13a)]),_0x4d491c=_0x4d491c[_0x5a3899(0x1cc)]('%s',_0x1b2716),_0x32db39['sendTo'](_0x32db39[_0x5a3899(0x1e0)]['telegramInstance'],_0x5a3899(0x2e3),{'text':_0x4d491c,'reply_markup':{'inline_keyboard':[[{'text':_0x55ded1,'callback_data':'1'},{'text':_0x767d,'callback_data':'0'}]],'resize_keyboard':!![],'one_time_keyboard':!![]}},function(_0x450d27){var _0x15b92a=_0x5a3899;_0x23bd6b&&(_0x23bd6b=null),_0x908fdf(_0x450d27[_0x15b92a(0x15b)]==='1');});}});}function _0x3973ee(){var _0x4a4f39=_0x38eaf8;_0x3f9850&&_0x3f9850[_0x4a4f39(0x2a0)](),_0x100f10&&_0x100f10[_0x4a4f39(0x2a0)]();}function _0xe6cce9(){var _0x3ab162=_0x38eaf8;return _0x5a32ea[_0x3ab162(0x199)]+'api/brokers';}function _0x271371(){return''['concat'](_0xe6cce9(),'/')['concat'](_0x5a32ea['id'],'/requests');}function _0x359421(_0x165e1e,_0x5c4d7c){var _0x44d2a8=_0x38eaf8,_0xed505b=_0x271371()+'/'+_0x165e1e+_0x44d2a8(0x1be);_0x30c3c9['post']({'url':_0xed505b,'json':!![],'body':{'reason':_0x5c4d7c},'headers':{'Authorization':_0x44d2a8(0x2bc)+_0x495bd3()},'agent':_0xe31816},function(_0x9b12e7,_0x2dd50f,_0x38387d){var _0x26adf3=_0x44d2a8;return _0x9b12e7&&_0x320bed[_0x26adf3(0x286)](_0x26adf3(0x15a)+_0x165e1e);});}function _0x9e280c(_0x4257ce,_0xeb2fe8,_0x3b6d4e){var _0x3267bb=_0x38eaf8;_0x110231&&(_0x110231=null);_0x3973ee();_0xeb2fe8?!_0x1d6cdf()&&_0x320bed[_0x3267bb(0x286)]('Connection\x20closed:\x20'+_0xeb2fe8):_0x320bed[_0x3267bb(0x2b3)](_0x3267bb(0x291)+_0x3b6d4e);if(_0x4257ce){_0xe4191f(_0x23d40e,![]);var _0x371114=_0x271371()+'/'+_0x4257ce+'/error';_0x30c3c9[_0x3267bb(0x298)]({'url':_0x371114,'json':!![],'body':{'reason':_0x3b6d4e},'headers':{'Authorization':_0x3267bb(0x2bc)+_0x495bd3()},'agent':_0xe31816},function(_0x4bd6ee,_0x1edbfb,_0x1abdfb){var _0x607f20=_0x3267bb;return _0x4bd6ee&&_0x320bed[_0x607f20(0x286)](_0x607f20(0x104)+_0x4257ce);});var _0x2bb876=_0x32db39['originalAllowedUsers'][_0x3267bb(0x1b6)](function(_0x4ccf0c){var _0x45305a=_0x3267bb;return _0x302b8c(_0x4ccf0c)===_0x45305a(0x2a6)&&_0x4ccf0c[_0x45305a(0x2be)]===_0x23d40e&&_0x4ccf0c[_0x45305a(0x25b)]&&_0x4ccf0c[_0x45305a(0x16d)];});_0x2bb876&&(_0x2bb876[_0x3267bb(0x25b)]=![],_0x32db39[_0x3267bb(0x1e0)][_0x3267bb(0x258)][_0x3267bb(0x262)](_0x32db39[_0x3267bb(0x1e0)]['allowedUsers'][_0x3267bb(0x1b6)](_0x23d40e),0x1),setTimeout(function(_0x38c8f8){var _0x4092e0=_0x3267bb;return _0x32db39[_0x4092e0(0x1d3)](_0x4092e0(0x23c)+_0x32db39[_0x4092e0(0x24c)],function(_0x1c3bf7,_0x111393){var _0x31c131=_0x4092e0;if(_0x111393&&_0x111393[_0x31c131(0x278)]&&_0x111393[_0x31c131(0x278)]['allowedUsers']){var _0x564b52=![];_0x111393['native'][_0x31c131(0x258)][_0x31c131(0x204)](function(_0x27d9ce){var _0x536af6=_0x31c131;_0x302b8c(_0x27d9ce)===_0x536af6(0x2a6)&&_0x27d9ce[_0x536af6(0x2be)]===_0x38c8f8&&_0x27d9ce[_0x536af6(0x25b)]&&_0x27d9ce[_0x536af6(0x16d)]&&(_0x564b52=!![],_0x27d9ce[_0x536af6(0x25b)]=![],_0x32db39[_0x536af6(0x200)][_0x536af6(0x2b3)]('User\x20\x22'+_0x38c8f8+_0x536af6(0x19f)));}),_0x564b52&&_0x32db39[_0x31c131(0x27d)](_0x111393[_0x31c131(0x2b1)],_0x111393);}});},0x7d0,_0x23d40e)),_0x23d40e=null;}}function _0x520dbd(_0x311bd7){var _0x182dc3=_0x38eaf8;_0x311bd7!==_0x299619&&(_0x299619=_0x311bd7,_0x4bdb0f[_0x182dc3(0x164)]('connection',_0x299619));}function _0x1d6cdf(){var _0x67a9a8=_0x38eaf8,_0x406a47=new Date();return _0x406a47[_0x67a9a8(0x217)]()===0x4&&_0x406a47[_0x67a9a8(0x2a5)]()<0xf;}var _0x1790d8=0x0;function _0x286e77(_0x2f4da4){var _0x5bd9d3=_0x38eaf8;if(!_0x2f4da4)return;var _0x12c3ad=_0x271371()+'/'+_0x2f4da4;_0x30c3c9[_0x5bd9d3(0x209)]({'url':_0x12c3ad,'headers':{'Authorization':'Bearer\x20'+_0x495bd3()},'agent':_0xe31816},function(_0x25b971,_0x5c747f,_0xe6fc79){var _0x4b3797=_0x5bd9d3;if(_0x25b971)!_0x1d6cdf()&&_0x320bed[_0x4b3797(0x286)](_0x4b3797(0x2ca)+_0x2f4da4),_0x1790d8++,_0x1790d8>0x1?(_0x1790d8=0x0,_0x320bed[_0x4b3797(0x286)](_0x4b3797(0x1bc)),_0x9e280c(_0x2f4da4,_0x4b3797(0x159)),_0x520dbd(![])):_0x110231=setTimeout(function(){return _0x286e77(_0x2f4da4);},_0x5a32ea['accessServerPollIntervalInMs']);else{_0x520dbd(!![]);var _0x47a091;if(_0x5c747f[_0x4b3797(0x185)]){if(_0x5c747f[_0x4b3797(0x185)]>=0xc8&&_0x5c747f[_0x4b3797(0x185)]<0x12c)try{_0x47a091=JSON[_0x4b3797(0xf2)](_0xe6fc79);if(_0x47a091['status']===_0x35cd76[_0x4b3797(0x1f7)])_0x9e280c(_0x2f4da4,null,_0x4b3797(0x21f));else{var _0x43c875=_0x47a091['id'];_0x110231=setTimeout(function(){return _0x286e77(_0x43c875);},_0x5a32ea[_0x4b3797(0x236)]);}}catch(_0x32d529){_0x320bed['error'](_0x4b3797(0x249)+_0xe6fc79),_0x9e280c(_0x2f4da4,_0x4b3797(0x1f0));}else console[_0x4b3797(0x200)](_0x4b3797(0x264)['concat'](_0x5c747f[_0x4b3797(0x185)],_0x4b3797(0xf3)));}else console[_0x4b3797(0x200)](_0x4b3797(0x10e));}});}function _0x6afb36(_0x5afa4d,_0x2bf831){var _0x9a2f73=_0x38eaf8;try{_0x320bed['debug']('AccessClient:\x20setting\x20up\x20reverse\x20proxy'),Promise[_0x9a2f73(0x15f)]([_0x100f10[_0x9a2f73(0x26e)](_0x5afa4d),_0x3f9850[_0x9a2f73(0x26e)](_0x5afa4d)])[_0x9a2f73(0x137)](function(){var _0x2f7115=_0x9a2f73,_0x1bde28=_0x2bf831+'/'+_0x5afa4d['id']+_0x2f7115(0x2f0);_0x320bed[_0x2f7115(0x173)](_0x2f7115(0x1f6)+_0x5afa4d['id']+_0x2f7115(0x218)+_0x5afa4d[_0x2f7115(0x13a)]),_0x30c3c9['post']({'url':_0x1bde28,'headers':{'Authorization':_0x2f7115(0x2bc)+_0x495bd3()},'agent':_0xe31816},function(_0x3c6747,_0x4da0ed,_0x3e9b58){var _0x906bd2=_0x2f7115;_0x3c6747?(!_0x1d6cdf()&&_0x320bed[_0x906bd2(0x286)](_0x906bd2(0x281)+_0x5afa4d['id']+'\x20from\x20'+_0x5afa4d['requested_by']),_0x3973ee(),_0x520dbd(![])):(_0x320bed[_0x906bd2(0x173)](_0x906bd2(0x120)+_0x5afa4d['id']+'\x20from\x20'+_0x5afa4d[_0x906bd2(0x13a)]+_0x906bd2(0x2d3)),_0x320bed[_0x906bd2(0x173)]('AccessClient:\x20setting\x20up\x20polling\x20for\x20request\x20status\x20change'),_0x110231=setTimeout(function(){return _0x286e77(_0x5afa4d['id']);},_0x5a32ea[_0x906bd2(0x236)]),_0x23d40e=_0x5afa4d[_0x906bd2(0x13a)],_0xe4191f(_0x23d40e,!![]));});});}catch(_0x3f77e0){_0x9e280c(_0x5afa4d['id'],_0x3f77e0[_0x9a2f73(0xec)]||_0x9a2f73(0x2ee));}}var _0x1e141b=0xa,_0x4795af=_0x1e141b;function _0x17bc13(){var _0xaf2df9=_0x38eaf8,_0x204206=_0x271371();_0x30c3c9[_0xaf2df9(0x209)]({'url':_0x204206,'headers':{'Authorization':_0xaf2df9(0x2bc)[_0xaf2df9(0x1a9)](_0x495bd3())},'agent':_0xe31816},function(_0x1a4797,_0x70bb3e,_0x7fa525){var _0x205a80=_0xaf2df9;if(_0x1a4797||_0x70bb3e&&_0x70bb3e[_0x205a80(0x185)]>=0x190)_0x520dbd(![]),!_0x1d6cdf()&&_0x320bed['error'](_0x205a80(0x2cd)[_0x205a80(0x1a9)]((_0x70bb3e||{})[_0x205a80(0x18a)]||_0x1a4797)),_0x70bb3e&&_0x70bb3e[_0x205a80(0x185)]===0x191&&(_0x320bed[_0x205a80(0x2d5)]('Looks\x20like\x20other\x20client\x20with\x20the\x20same\x20UUID\x20'[_0x205a80(0x1a9)](_0x5a32ea['id'],'\x20already\x20online.\x20Two\x20devices\x20with\x20the\x20same\x20UUID\x20are\x20not\x20allowed.\x20You\x20can\x20write\x20\x22iob\x20unsetup\x22\x20to\x20change\x20UUID.\x20Important\x20all\x20UUID\x20bound\x20licenses\x20must\x20be\x20reissued.')),_0x4795af--,_0x4795af<0x1&&(_0x4795af=_0x1e141b,setTimeout(_0x466573,0x64)));else{_0x1790d8=0x0;var _0x2ff00e;try{_0x2ff00e=JSON[_0x205a80(0xf2)](_0x7fa525);}catch(_0x2d2c0d){_0x320bed[_0x205a80(0x286)](_0x205a80(0x249)+_0x2d2c0d);return;}_0x520dbd(!![]),_0x4795af--;_0x4795af<0x1&&(_0x4795af=_0x1e141b,setTimeout(_0x466573,0x64));if(Array[_0x205a80(0x26d)](_0x2ff00e)&&_0x2ff00e[_0x205a80(0x24a)]>0x0){var _0x584167=_0x2ff00e[_0x205a80(0x1cb)](function(_0x163f50){var _0x21f9dc=_0x205a80;return _0x163f50[_0x21f9dc(0x17b)]===_0x35cd76['REQUESTED'];})[0x0];if(_0x584167){if(_0x23bd6b)_0x320bed[_0x205a80(0x173)](_0x205a80(0x2a9)+_0x23bd6b['id']);else{_0x584167=Object[_0x205a80(0x2c3)]({},_0x584167);var _0x2d9bcc=_0x32db39[_0x205a80(0x1e0)][_0x205a80(0x202)]&&_0x32db39['config'][_0x205a80(0x256)];_0x2d9bcc?(_0x320bed['debug'](_0x205a80(0x141)),_0x7a1bb5(_0x584167)[_0x205a80(0x137)](function(_0x4dab16){var _0x3652c5=_0x205a80;_0x320bed[_0x3652c5(0x173)](_0x3652c5(0x259)+(_0x4dab16?'accepted':_0x3652c5(0x23a))),_0x4dab16?_0x6afb36(_0x584167,_0x204206):(_0x320bed[_0x3652c5(0x2b3)](_0x3652c5(0x18d)+_0x584167['id']+'\x20from\x20'+_0x584167[_0x3652c5(0x13a)]+_0x3652c5(0x103)),_0x520dbd(![]),_0x359421(_0x584167['id'],_0x3652c5(0xf0)));})):_0x6afb36(_0x584167,_0x204206);}}}else _0x320bed[_0x205a80(0x173)]('AccessClient:\x20no\x20connection\x20requests\x20found');}_0x4e51f4=setTimeout(function(){return _0x17bc13();},_0x5a32ea['accessServerPollIntervalInMs']);});}function _0x495bd3(){var _0x3cc7f2=_0x38eaf8,_0x2af906={'iss':_0x5a32ea['id']};return _0x212fc9[_0x3cc7f2(0x1b9)](_0x2af906,_0x5a32ea[_0x3cc7f2(0x266)][_0x3cc7f2(0x215)],_0x3cc7f2(0x28f));}function _0x466573(){var _0x55fe13=_0x38eaf8,_0x37df2d=_0x361458+_0x55fe13(0x111),_0x563118={'version':_0x50c64e[_0x55fe13(0x22d)](_0x37df2d)?_0x5697b2(_0x37df2d)['version']:_0x55fe13(0x162),'allowedUsers':Object['assign']([],_0x5a32ea[_0x55fe13(0x258)]),'devices':JSON[_0x55fe13(0xf2)](JSON['stringify'](_0x5a32ea[_0x55fe13(0x2e0)][_0x55fe13(0x1cb)](function(_0x24b376){var _0x32ef10=_0x55fe13;return _0x24b376[_0x32ef10(0x25b)];}))),'name':_0x5a32ea[_0x55fe13(0x1f2)],'pollInterval':_0x5a32ea[_0x55fe13(0x15c)],'id':_0x5a32ea['id']};_0x563118[_0x55fe13(0x2e0)][_0x55fe13(0x204)](function(_0x5e828b){var _0x2b7138=_0x55fe13;return delete _0x5e828b[_0x2b7138(0x2dd)];});_0x563118[_0x55fe13(0x2e0)]['some'](function(_0xa490f8){var _0x139496=_0x55fe13;return _0xa490f8[_0x139496(0x1aa)]==='UDP';})&&(_0x563118['crt']=_0x443bbb['getAgentCrt'](_0x563118,_0x320bed),_0x320bed[_0x55fe13(0x173)](_0x55fe13(0x16b)[_0x55fe13(0x1a9)](_0x563118[_0x55fe13(0x20a)])));_0x563118[_0x55fe13(0x172)]=_0x5a32ea[_0x55fe13(0x266)][_0x55fe13(0x274)],_0x320bed['debug'](_0x55fe13(0x16a)+_0x5a32ea[_0x55fe13(0x199)]);var _0x5a0372=_0xe6cce9();_0x30c3c9[_0x55fe13(0x298)]({'url':_0x5a0372,'json':!![],'body':_0x563118,'headers':{'Authorization':_0x55fe13(0x2bc)+_0x495bd3()},'agent':_0xe31816},function(_0x41ee76,_0xbb27b0,_0x5d4505){var _0x5a2b22=_0x55fe13;if(_0x41ee76||_0xbb27b0[_0x5a2b22(0x185)]>=0x190)_0x5d4505&&!_0x1d6cdf()&&_0x320bed[_0x5a2b22(0x286)](_0x5a2b22(0x179)+_0x5d4505),!_0x1d6cdf()&&_0x320bed['error'](_0x5a2b22(0x179)+((_0x41ee76||{})[_0x5a2b22(0xec)]||_0xbb27b0[_0x5a2b22(0x18a)]));else{_0x320bed[_0x5a2b22(0x173)](_0x5a2b22(0x207)+_0x563118[_0x5a2b22(0x1f2)]+_0x5a2b22(0x284)+_0x563118[_0x5a2b22(0x2e0)][_0x5a2b22(0x24a)]+_0x5a2b22(0x2eb));_0xbb27b0[_0x5a2b22(0x175)]['unsupported']&&_0x320bed[_0x5a2b22(0x2d5)](_0x5a2b22(0x1b7)[_0x5a2b22(0x1a9)](_0xbb27b0[_0x5a2b22(0x175)]['unsupported'][_0x5a2b22(0x1bb)],'\x20or\x20higher'));var _0x436251=_0x563118[_0x5a2b22(0x2e0)][_0x5a2b22(0x277)](function(_0x5aa7be){var _0x3ea263=_0x5a2b22;return _0x5aa7be[_0x3ea263(0x1aa)]===_0x3ea263(0x194);});_0x436251&&_0x443bbb[_0x5a2b22(0x272)](_0xbb27b0[_0x5a2b22(0x175)][_0x5a2b22(0x261)],_0x320bed);}});}this['start']=function(_0x44011e){var _0x33548e=_0x38eaf8;_0x4242d7[_0x33548e(0x26b)](),_0x5a32ea=_0x44011e;(process[_0x33548e(0x1cf)]['HTTPS_PROXY']||process[_0x33548e(0x1cf)]['HTTP_PROXY'])&&(_0x5a32ea['proxyURI']=process['env'][_0x33548e(0x285)]||process[_0x33548e(0x1cf)]['HTTP_PROXY']);_0x5a32ea[_0x33548e(0x20d)]&&(_0x5a32ea['proxyURI']=_0x5a32ea[_0x33548e(0x20d)][_0x33548e(0x27b)](),_0x5a32ea[_0x33548e(0x20d)]&&_0x5a32ea[_0x33548e(0x20d)][_0x5a32ea[_0x33548e(0x20d)][_0x33548e(0x24a)]-0x1]==='/'&&(_0x5a32ea[_0x33548e(0x20d)]=_0x5a32ea[_0x33548e(0x20d)][_0x33548e(0x2ce)](0x0,_0x5a32ea[_0x33548e(0x20d)][_0x33548e(0x24a)]-0x1)),_0xe31816=new _0x54be50(_0x5a32ea[_0x33548e(0x20d)]));_0x5a32ea[_0x33548e(0x199)]&&_0x5a32ea[_0x33548e(0x199)][_0x5a32ea[_0x33548e(0x199)][_0x33548e(0x24a)]-0x1]!=='/'&&(_0x5a32ea['accessServerURI']+='/');var _0x25da41=_0x361458+_0x33548e(0x2ec);if(!_0x50c64e[_0x33548e(0x22d)](_0x25da41+_0x33548e(0x17c))){!_0x50c64e[_0x33548e(0x22d)](_0x25da41)&&_0x50c64e[_0x33548e(0x2c7)](_0x25da41);var _0x35cffb=new _0x311e5c();_0x35cffb['generateKeyPair'](0x800),_0x5a32ea[_0x33548e(0x266)]={'publicPem':_0x35cffb[_0x33548e(0x197)]('pkcs8-public-pem')+'\x0a','private':_0x35cffb['exportKey'](_0x33548e(0x25d))+'\x0a'},_0x50c64e[_0x33548e(0x132)](_0x25da41+_0x33548e(0x17c),_0x35cffb[_0x33548e(0x197)]('pkcs8-public-pem')+'\x0a'),_0x50c64e[_0x33548e(0x132)](_0x25da41+_0x33548e(0x250),_0x35cffb[_0x33548e(0x197)](_0x33548e(0x25d))+'\x0a');}else _0x5a32ea[_0x33548e(0x266)]={'publicPem':_0x50c64e[_0x33548e(0x171)](_0x25da41+_0x33548e(0x17c),_0x33548e(0x2a1)),'private':_0x50c64e[_0x33548e(0x171)](_0x25da41+'private.pem',_0x33548e(0x2a1))};_0x466573(),_0x3f9850=new _0x4e94b0(_0x5a32ea),_0x3f9850['on'](_0x33548e(0xec),function(_0x48d858){_0x320bed['debug'](_0x48d858);}),_0x3f9850['on']('connection',function(_0x1e8326){var _0x19b141=_0x33548e;_0x320bed[_0x19b141(0x173)](JSON[_0x19b141(0x241)](_0x1e8326));}),_0x3f9850['on'](_0x33548e(0x1b0),function(_0x395c84){var _0x4e33ab=_0x33548e,_0x16cfaf=((_0x395c84||{})[_0x4e33ab(0x1fd)]||{})['id'],_0x184bc2=((_0x395c84||{})['error']||{})[_0x4e33ab(0xec)]||'Unknown\x20SSH\x20reverse\x20tunnel\x20error';_0x320bed[_0x4e33ab(0x286)](_0x4e33ab(0x254)+_0x184bc2),_0x9e280c(_0x16cfaf,_0x184bc2);}),_0x100f10=new _0x35820e(_0x5a32ea,_0x320bed),_0x100f10['on'](_0x33548e(0xec),function(_0x5eb1be){var _0x382665=_0x33548e;_0x320bed[_0x382665(0x173)](_0x5eb1be);}),_0x5a32ea[_0x33548e(0x236)]=(parseInt(_0x5a32ea['accessServerPollInterval'],0xa)||0xa)*0x3e8,Array[_0x33548e(0x26d)](_0x5a32ea[_0x33548e(0x258)])&&_0x5a32ea['allowedUsers'][_0x33548e(0x24a)]>0x0?_0x4e51f4=setTimeout(function(){return _0x17bc13();},_0x5a32ea[_0x33548e(0x236)]):_0x320bed[_0x33548e(0x173)]('skipped\x20setting\x20up\x20access-server\x20polling\x20due\x20to\x20missing\x20allowed\x20users');},this[_0x38eaf8(0x26b)]=function(){_0x4e51f4&&(clearTimeout(_0x4e51f4),_0x4e51f4=null),_0x3973ee();};}_0x2a6d6f['inherits'](_0x1789c1,_0x58238e),_0x50713a[_0xc741b5(0x225)]=_0x1789c1;}[_0x1b36a7(0x21b)](this));}[_0x525030(0x21b)](this,_0x5697b2(_0x525030(0x101))[_0x525030(0xfc)](__dirname,_0x525030(0x128))));},{'../admin/words':0x1,'./consts.js':0x3,'./handler/ssf-proxy':0x4,'./handler/ssh-proxy':0x5,'./helpers/cert-helper.js':0x7,'events':undefined,'fs':undefined,'https-proxy-agent':undefined,'jwt-simple':undefined,'node-rsa':undefined,'path':undefined,'request':undefined,'util':undefined}],0x3:[function(_0x35c001,_0x31a3f4,_0x40fa6e){'use strict';var _0x4de1f2=_0xce6f;_0x31a3f4[_0x4de1f2(0x225)][_0x4de1f2(0x1f7)]='closed',_0x31a3f4['exports'][_0x4de1f2(0x1c0)]=_0x4de1f2(0x21a);},{}],0x4:[function(_0x4fb7ee,_0x529c0a,_0x436e2c){var _0x296406=_0xce6f;(function(_0x35a34f){(function(){'use strict';var _0x3e617e=_0xce6f;var _0x4d63c6=_0x4fb7ee('events')[_0x3e617e(0x221)],_0x9dd501=_0x4fb7ee(_0x3e617e(0x1c5)),_0x3ac2ea=_0x4fb7ee(_0x3e617e(0x1eb)),_0x3af027=/^win/[_0x3e617e(0x143)](process[_0x3e617e(0x2cc)])?_0x3e617e(0x27f):_0x3e617e(0x123),_0x89a2f5=_0x4fb7ee(_0x3e617e(0x101)),_0x57015d=_0x89a2f5[_0x3e617e(0x21c)](_0x35a34f+_0x3e617e(0x1c3)),_0x302727=(_0x3af027===_0x3e617e(0x123)?'./':'')+'ssf';function _0x56fbc9(_0x2672ec,_0x5e1753){var _0x13bba7=_0x3e617e,_0xb8b8d7=this,_0x118895;function _0x143d60(_0x2d64fa){var _0x3f1da3=_0xce6f;_0xb8b8d7['emit'](_0x3f1da3(0xec),_0x2d64fa);}function _0x562844(_0x2635be){var _0x6f46b3=_0xce6f;_0xb8b8d7['emit'](_0x6f46b3(0x1b0),_0x2635be);}var _0x5d59b0=function _0x3399eb(_0x365d4e){var _0x20d547=_0xce6f,_0x3799fe=['-p',_0x365d4e[_0x20d547(0x1f8)]['port'],_0x365d4e['ssf'][_0x20d547(0x2da)],'-v',_0x20d547(0x18f),'-t',0x5,'-g'];return _0x365d4e[_0x20d547(0x2e0)][_0x20d547(0x1cb)](function(_0x53a4a1){var _0x30e31f=_0x20d547;return _0x53a4a1[_0x30e31f(0x1aa)]===_0x30e31f(0x194);})['forEach'](function(_0x433201){var _0x700544=_0x20d547,_0x5fc20e=_0x2672ec[_0x700544(0x2e0)][_0x700544(0x1cb)](function(_0x377a7c){var _0x5ec1ae=_0x700544;return _0x377a7c['name']===_0x433201[_0x5ec1ae(0x1f2)];})[0x0];if(_0x5fc20e&&_0x5fc20e[_0x700544(0x2dd)]){var _0x2c5b6a=_0x5fc20e['uri'][_0x700544(0x2dc)](':'),_0x1c67df=_0x2c5b6a[0x0],_0x121529=_0x2c5b6a[0x1]||0x50;_0x3799fe[_0x700544(0x245)]('-V');var _0x447cfc=[_0x433201['port'],_0x1c67df,_0x121529][_0x700544(0xfc)](':');_0x3799fe[_0x700544(0x245)](_0x447cfc);}else(_0x5e1753?_0x5e1753['error']:console['error'])(_0x700544(0x158)+JSON['stringify'](_0x5fc20e));}),_0x3799fe;};this[_0x13bba7(0x26e)]=function(_0x23ac0d){var _0x5589bf=_0x13bba7,_0x4fe7b2=_0x23ac0d[_0x5589bf(0x214)];return new Promise(function(_0x13cfae,_0x2d15a5){var _0x37542d=_0x5589bf;_0x118895&&(_0x143d60('there\x20is\x20already\x20ssf\x20running.\x20Killing...'),_0x3ac2ea[_0x37542d(0x15e)](_0x118895,_0x5e1753),_0x118895=null);var _0x190432=_0x4fe7b2[_0x37542d(0x2e0)][_0x37542d(0x277)](function(_0x57985d){var _0x94bea1=_0x37542d;return _0x57985d[_0x94bea1(0x1aa)]===_0x94bea1(0x194);});if(!_0x190432)return _0x143d60('no\x20UDP\x20devices\x20found.\x20Skipping\x20setting\x20up\x20SSF\x20tunnel'),_0x13cfae();if(_0x4fe7b2['ssf'])try{var _0x34f3b0=_0x5d59b0(_0x4fe7b2);_0x143d60(_0x37542d(0x1df)['concat'](_0x302727,'\x20')['concat'](_0x34f3b0[_0x37542d(0xfc)]('\x20'),_0x37542d(0x2e6))[_0x37542d(0x1a9)](_0x57015d)),_0x118895=_0x3ac2ea[_0x37542d(0x16f)](_0x302727,_0x34f3b0,{'cwd':_0x57015d},_0x5e1753),_0x143d60(_0x37542d(0x181));}catch(_0x207b79){return _0x143d60(_0x37542d(0x19c)[_0x37542d(0x1a9)](_0x207b79[_0x37542d(0xec)]||_0x207b79)),_0x2d15a5(_0x207b79);}else _0x143d60(_0x37542d(0x16c));return _0x13cfae();});},this[_0x13bba7(0x2a0)]=function(){var _0x1232a8=_0x13bba7;if(!_0x118895){_0x143d60(_0x1232a8(0x273));return;}try{_0x3ac2ea['kill'](_0x118895,_0x5e1753),_0x143d60(_0x1232a8(0x20f));}catch(_0x3409fd){_0x143d60(_0x1232a8(0x11a),_0x3409fd[_0x1232a8(0xec)]);}};}_0x9dd501[_0x3e617e(0x203)](_0x56fbc9,_0x4d63c6),_0x529c0a[_0x3e617e(0x225)]=_0x56fbc9;}['call'](this));}['call'](this,_0x4fb7ee(_0x296406(0x101))[_0x296406(0xfc)](__dirname,_0x296406(0x128),_0x296406(0x12c))));},{'./../helpers/shell-helper':0x8,'events':undefined,'path':undefined,'util':undefined}],0x5:[function(_0x47e671,_0x291769,_0x5eeef7){'use strict';var _0x133e77=_0xce6f;var _0x280fd2=_0x47e671(_0x133e77(0x1d5))[_0x133e77(0x190)],_0x1e628a=_0x47e671(_0x133e77(0x146))[_0x133e77(0x2e8)],_0x1b88ef=_0x47e671('./tcp-proxy'),_0x1035f9=_0x47e671(_0x133e77(0x1fe))[_0x133e77(0x221)],_0x25d1fd=_0x47e671(_0x133e77(0x1c5)),_0x4935e0=_0x47e671(_0x133e77(0x134)),_0x54d51a=_0x47e671('portastic');function _0x5a72ed(_0x3cbe52,_0x12955f){var _0x4ebe86=_0x133e77,_0x26dcc0=this,_0x527030=_0x3cbe52,_0xad19b0=null,_0x5d05a2=null,_0x4ea411=[],_0x245826=[],_0x521197=null;!_0x12955f&&(_0x12955f={'info':console[_0x4ebe86(0x200)],'debug':console[_0x4ebe86(0x200)],'error':console[_0x4ebe86(0x286)],'warn':console[_0x4ebe86(0x2d5)]});function _0x5bf856(_0x5b89eb){var _0x3f4d79=_0x4ebe86;_0x26dcc0[_0x3f4d79(0x164)](_0x3f4d79(0xec),_0x5b89eb);}function _0x3404d3(_0x3e5d29){var _0x23bfd2=_0x4ebe86;_0x26dcc0[_0x23bfd2(0x164)]('ssh-error',_0x3e5d29);}function _0x4c41a5(){var _0x47c73a=_0x4ebe86;if(_0xad19b0){var _0xb005eb=[];_0x5d05a2[_0x47c73a(0x2e0)][_0x47c73a(0x204)](function(_0x36d749){var _0xb167dd=_0x47c73a;_0xb005eb[_0xb167dd(0x245)](new Promise(function(_0x1d6015,_0x4f4604){var _0x1e99e3=_0xb167dd;_0xad19b0[_0x1e99e3(0x2db)](_0x1e99e3(0x129),_0x36d749[_0x1e99e3(0x1c7)],function(_0x13863c){var _0x2c4be8=_0x1e99e3;_0x13863c?_0x12955f[_0x2c4be8(0x286)](_0x2c4be8(0x2ba)[_0x2c4be8(0x1a9)](_0x13863c[_0x2c4be8(0xec)])):_0x5bf856('SSH\x20Client\x20::\x20stopped\x20listening\x20for\x20connections\x20on\x20'[_0x2c4be8(0x1a9)](_0x5d05a2[_0x2c4be8(0x1d6)][_0x2c4be8(0x2da)],':')['concat'](_0x36d749[_0x2c4be8(0x1c7)])),_0x1d6015();});}));}),Promise[_0x47c73a(0x15f)](_0xb005eb)[_0x47c73a(0x137)](function(){var _0x5c75b2=_0x47c73a;_0x5d05a2=null;try{_0xad19b0&&_0xad19b0[_0x5c75b2(0x26c)]();}catch(_0x3fb7c7){_0x12955f[_0x5c75b2(0x286)](_0x5c75b2(0x234)+(_0x3fb7c7[_0x5c75b2(0xec)]||_0x3fb7c7));}_0xad19b0=null;});}if(_0x521197){try{_0x521197[_0x47c73a(0x188)]();}catch(_0x9ccd79){_0x12955f['error']('TCPProxy:\x20'+(_0x9ccd79['message']||_0x9ccd79));}_0x521197=null;}_0x4ea411['forEach'](function(_0x43a5cd){var _0x21647f=_0x47c73a;_0x12955f[_0x21647f(0x2b3)](_0x21647f(0x227)['concat'](_0x43a5cd['name'],']')),_0x43a5cd['proxy'][_0x21647f(0x188)]();}),_0x4ea411[_0x47c73a(0x24a)]=0x0,_0x245826[_0x47c73a(0x204)](function(_0x1ee844){var _0x1c83ba=_0x47c73a;_0x12955f[_0x1c83ba(0x173)](_0x1c83ba(0x10f)['concat'](_0x1ee844[_0x1c83ba(0x1f2)],']')),_0x1ee844[_0x1c83ba(0x2ef)][_0x1c83ba(0x188)]();}),_0x245826[_0x47c73a(0x24a)]=0x0;}this[_0x4ebe86(0x2a0)]=function(){_0x4c41a5();},this[_0x4ebe86(0x26e)]=function(_0x3f023f){return new Promise(function(_0x552644,_0x27beb0){var _0x259648=_0xce6f,_0x1d46c7=_0x527030['devices']['filter'](function(_0x220ae5){var _0x2f59a4=_0xce6f;return _0x220ae5[_0x2f59a4(0x2dd)]['startsWith'](_0x2f59a4(0x263));});if(_0x1d46c7[_0x259648(0x24a)]>0x0){var _0x4121b8={'min':0xc351,'max':0xc739,'retrieve':_0x1d46c7[_0x259648(0x24a)]};_0x54d51a[_0x259648(0x1b6)](_0x4121b8)['then'](function(_0x258d59){var _0x4e6ad4=_0x259648,_0x573a15=0x0;_0x1d46c7[_0x4e6ad4(0x204)](function(_0xf34b23){var _0xecf257=_0x4e6ad4;if(_0x573a15>=_0x258d59[_0xecf257(0x24a)])_0x12955f[_0xecf257(0x2d5)](_0xecf257(0x176)[_0xecf257(0x1a9)](_0xf34b23['name'],'].\x20[')[_0xecf257(0x1a9)](_0xf34b23[_0xecf257(0x1f2)],']\x20will\x20not\x20be\x20reachable'));else{var _0x58fddd=_0xf34b23[_0xecf257(0x2dd)]['replace'](_0xecf257(0x263),'')[_0xecf257(0x2dc)](':'),_0x5d47b9=_0x58fddd[0x0],_0x1072f1=_0x58fddd[0x1]||0x1bb,_0x1562d7=_0x258d59[_0x573a15++],_0x1d7e6a=_0x47e671('http-proxy'),_0x2fafc9=_0x1d7e6a[_0xecf257(0x155)]({'target':{'protocol':'https:','host':_0x5d47b9,'port':_0x1072f1},'changeOrigin':![],'secure':![]})[_0xecf257(0x29f)](_0x1562d7);_0x2fafc9['on'](_0xecf257(0x1ea),function(_0x36d323,_0x12f7d5,_0x484ee1,_0x205400){var _0x9c4567=_0xecf257;_0x36d323[_0x9c4567(0x1e4)](_0x9c4567(0x2bb),_0x9c4567(0x1ba)),_0x36d323['setHeader'](_0x9c4567(0x212),_0x5d47b9);}),_0xf34b23['httpsProxy']={'port':_0x1562d7},_0x4ea411[_0xecf257(0x245)]({'name':_0xf34b23[_0xecf257(0x1f2)],'proxy':_0x2fafc9,'port':_0x1562d7}),_0x12955f[_0xecf257(0x2b3)](_0xecf257(0x233)['concat'](_0xf34b23[_0xecf257(0x1f2)],_0xecf257(0x290))['concat'](_0xf34b23[_0xecf257(0x2dd)],_0xecf257(0x2af))['concat'](_0x1562d7,']'));}});});}_0x5d05a2=JSON[_0x259648(0xf2)](JSON[_0x259648(0x241)](_0x3f023f[_0x259648(0x214)]));_0xad19b0&&(_0x5bf856('SSH\x20Client\x20::\x20connection\x20already\x20opened.\x20Closing...'),_0x4c41a5());var _0x2b1c9a=_0x5d05a2[_0x259648(0x2e0)]['some'](function(_0x3f96ff){var _0x50ad77=_0x259648;return _0x3f96ff[_0x50ad77(0x1aa)]===_0x50ad77(0x2d2);});if(!_0x2b1c9a)return _0x5bf856(_0x259648(0x170)),_0x552644();_0x5bf856(_0x259648(0x28a)+_0x5d05a2[_0x259648(0x1d6)][_0x259648(0x2da)]),_0xad19b0=new _0x280fd2(),_0xad19b0['on'](_0x259648(0x11f),function(){var _0x485d43=_0x259648;_0x5bf856(_0x485d43(0x1f1)),_0x5d05a2['devices'][_0x485d43(0x204)](function(_0x36b844){var _0x2b5bae=_0x485d43;_0xad19b0[_0x2b5bae(0x1f4)](_0x2b5bae(0x129),_0x36b844[_0x2b5bae(0x1c7)],function(_0x2d3f64){var _0x26bcf9=_0x2b5bae;_0x2d3f64?(_0x3404d3({'request':_0x3f023f,'error':{'message':_0x26bcf9(0x133)[_0x26bcf9(0x1a9)](_0x2d3f64[_0x26bcf9(0xec)])}}),_0x27beb0(_0x2d3f64)):_0x5bf856('SSH\x20Client\x20::\x20listening\x20for\x20connections\x20on\x20'+_0x5d05a2[_0x26bcf9(0x1d6)][_0x26bcf9(0x2da)]+':'+_0x36b844['port']);});}),_0x552644();})['on'](_0x259648(0x22b),function(_0x3152e3,_0x1717bf,_0x6f20b5){var _0x58892a=_0x259648;_0x5bf856(_0x58892a(0x1cd)+JSON[_0x58892a(0x241)](_0x3152e3)),_0x5bf856('SSH\x20Client\x20::\x20Looking\x20for\x20local\x20device\x20to\x20connect...');var _0xc89393=_0x5d05a2[_0x58892a(0x2e0)][_0x58892a(0x1cb)](function(_0x5ad507){var _0x48e506=_0x58892a;return _0x5ad507[_0x48e506(0x1c7)]===_0x3152e3[_0x48e506(0x13d)];})[0x0];if(_0xc89393){var _0x12e295=_0x527030[_0x58892a(0x2e0)][_0x58892a(0x1cb)](function(_0x13b8c1){var _0x1459c7=_0x58892a;return _0x13b8c1[_0x1459c7(0x1f2)]===_0xc89393[_0x1459c7(0x1f2)];})[0x0];if(_0x12e295&&_0x12e295[_0x58892a(0x2dd)]){var _0x326c90=function _0x3cdf88(){return new Promise(function(_0x214cc6,_0x965cc6){var _0xbdf20f=_0xce6f;if(_0x12e295[_0xbdf20f(0x2dd)][_0xbdf20f(0x21d)](_0xbdf20f(0x100))){var _0x3ed708=_0x12e295[_0xbdf20f(0x2dd)],_0x21cd95=_0x245826[_0xbdf20f(0x1cb)](function(_0x495b6f){var _0x2f8ce4=_0xbdf20f;return _0x495b6f[_0x2f8ce4(0x1f2)]===_0xc89393['name']&&_0x495b6f[_0x2f8ce4(0x2dd)]===_0x3ed708;})[0x0];if(_0x21cd95)_0x12955f[_0xbdf20f(0x173)](_0xbdf20f(0x1e2)[_0xbdf20f(0x1a9)](_0xc89393[_0xbdf20f(0x1f2)],_0xbdf20f(0x290))[_0xbdf20f(0x1a9)](_0x3ed708,']\x20already\x20listening\x20on\x20port\x20[')[_0xbdf20f(0x1a9)](_0x21cd95[_0xbdf20f(0x1c7)],']')),_0x214cc6({'deviceLocalHost':_0xbdf20f(0x129),'deviceLocalPort':_0x21cd95[_0xbdf20f(0x1c7)]});else{var _0x12aea9={'min':0xc351,'max':0xc739,'retrieve':0x2};_0x54d51a[_0xbdf20f(0x1b6)](_0x12aea9)[_0xbdf20f(0x137)](function(_0x1951d3){var _0x13a895=_0xbdf20f,_0xd1d57f=_0x1951d3[0x0],_0x3ca176=_0x4935e0['createProxyServer']({'target':_0x3ed708,'ws':!![],'changeOrigin':!![]})[_0x13a895(0x29f)](_0xd1d57f);_0x245826[_0x13a895(0x245)]({'name':_0xc89393[_0x13a895(0x1f2)],'proxy':_0x3ca176,'port':_0xd1d57f,'uri':_0x3ed708}),_0x12955f['debug'](_0x13a895(0x183)[_0x13a895(0x1a9)](_0xc89393['name'],_0x13a895(0x290))[_0x13a895(0x1a9)](_0x3ed708,_0x13a895(0x2af))[_0x13a895(0x1a9)](_0xd1d57f,']')),_0x214cc6({'deviceLocalHost':'127.0.0.1','deviceLocalPort':_0xd1d57f});});}}else{var _0x470100=_0x12e295[_0xbdf20f(0x2dd)]['split'](':'),_0x27b746=_0x470100[0x0],_0x3d2e02=_0x470100[0x1]||0x50;_0x12e295['uri'][_0xbdf20f(0x21d)](_0xbdf20f(0x263))&&_0x12e295[_0xbdf20f(0x2e2)]&&(_0x27b746='localhost',_0x3d2e02=_0x12e295[_0xbdf20f(0x2e2)][_0xbdf20f(0x1c7)]),_0x214cc6({'deviceLocalHost':_0x27b746,'deviceLocalPort':_0x3d2e02});}});};_0x5bf856('SSH\x20Client\x20::\x20found\x20local\x20device\x20to\x20connect:\x20'[_0x58892a(0x1a9)](JSON[_0x58892a(0x241)](_0x12e295['uri']))),_0x326c90()[_0x58892a(0x137)](function(_0x5dd6a5){var _0x55fa5a=_0x58892a,_0x5b1e60=_0x5dd6a5[_0x55fa5a(0x12e)],_0x4adc9c=_0x5dd6a5[_0x55fa5a(0x2b8)];_0x5bf856(_0x55fa5a(0x22a)[_0x55fa5a(0x1a9)](_0x3152e3[_0x55fa5a(0x13d)]));var _0x4be0f9=_0x1717bf();_0x4be0f9['on'](_0x55fa5a(0x188),function(){var _0x3f378e=_0x55fa5a;_0x5bf856(_0x3f378e(0x228)['concat'](_0x3152e3[_0x3f378e(0x13d)],_0x3f378e(0xf5))),_0x26dcc0['emit'](_0x3f378e(0x22c),{'protocol':_0x3f378e(0x2d2),'connected':![],'host':_0x5b1e60,'port':_0x4adc9c});});var _0x5a9b27=new _0x1e628a();_0x5a9b27['on'](_0x55fa5a(0x286),function(_0x2cb7fa){var _0x2603d7=_0x55fa5a;_0x12955f[_0x2603d7(0x286)](_0x2603d7(0x124)['concat'](_0x12e295['uri'],'.\x20')['concat'](_0x2cb7fa[_0x2603d7(0xec)]||_0x2cb7fa)),_0x26dcc0[_0x2603d7(0x164)](_0x2603d7(0x22c),{'protocol':_0x2603d7(0x2d2),'connected':![],'host':_0x5b1e60,'port':_0x4adc9c}),_0x4be0f9===undefined?_0x6f20b5():_0x4be0f9['end']();}),_0x5bf856(_0x55fa5a(0x28a)['concat'](_0xc89393['name'],_0x55fa5a(0x126))[_0x55fa5a(0x1a9)](_0x12e295[_0x55fa5a(0x2dd)])),_0x5a9b27['connect'](_0x4adc9c,_0x5b1e60,function(){var _0x1600cd=_0x55fa5a;_0x5bf856('SSH\x20Client\x20::\x20piping\x20to\x20'['concat'](_0x12e295[_0x1600cd(0x2dd)])),_0x26dcc0[_0x1600cd(0x164)](_0x1600cd(0x22c),{'protocol':_0x1600cd(0x2d2),'connected':!![],'host':_0x5b1e60,'port':_0x4adc9c}),_0x5a9b27[_0x1600cd(0x292)](_0x4be0f9)['pipe'](_0x5a9b27);});});}else _0x5bf856(_0x58892a(0x131));}else _0x5bf856(_0x58892a(0x131));})['on'](_0x259648(0x286),function(_0x2ffeac){var _0x15121d=_0x259648;_0x3404d3({'request':_0x3f023f,'error':{'message':_0x15121d(0x138)['concat'](_0x2ffeac[_0x15121d(0x282)],_0x15121d(0x23b))[_0x15121d(0x1a9)](_0x2ffeac[_0x15121d(0x1c8)])}}),_0x27beb0(_0x2ffeac);})['on'](_0x259648(0x26c),function(){var _0x522802=_0x259648;_0x5bf856('SSH\x20Client\x20::\x20disconnected'),_0x26dcc0['emit']('connection',{'protocol':_0x522802(0x2d2),'connected':![]});})['on'](_0x259648(0x188),function(_0x3de7c4){var _0x1980c5=_0x259648;_0x3de7c4&&_0x5bf856(_0x1980c5(0x14c)),_0x26dcc0[_0x1980c5(0x164)]('connection',{'protocol':_0x1980c5(0x2d2),'connected':![]});}),_0x527030[_0x259648(0x20d)]?(_0x521197=new _0x1b88ef(_0x5d05a2[_0x259648(0x1d6)][_0x259648(0x2da)],0x16,undefined,_0x527030[_0x259648(0x20d)],0x3036,_0x12955f),_0x521197['on']('ready',function(_0x5e8ee7){var _0x225829=_0x259648;return _0xad19b0[_0x225829(0xfe)]({'host':_0x225829(0x129),'port':_0x5e8ee7,'username':_0x5d05a2[_0x225829(0x1d7)],'privateKey':_0x527030['keys'][_0x225829(0x215)]});})['on'](_0x259648(0x26c),function(){var _0x5bdfca=_0x259648;return _0x5bf856(_0x5bdfca(0x210));})['on'](_0x259648(0x286),function(_0x1aa84c){var _0x599ac4=_0x259648;return _0x5bf856(_0x599ac4(0x187)['concat'](_0x1aa84c));})):_0xad19b0['connect']({'host':_0x5d05a2['chisel'][_0x259648(0x2da)],'port':0x16,'username':_0x5d05a2[_0x259648(0x1d7)],'privateKey':_0x527030[_0x259648(0x266)][_0x259648(0x215)]});});};}_0x25d1fd['inherits'](_0x5a72ed,_0x1035f9),_0x291769['exports']=_0x5a72ed;},{'./tcp-proxy':0x6,'events':undefined,'http-proxy':undefined,'net':undefined,'portastic':undefined,'ssh2':undefined,'util':undefined}],0x6:[function(_0x2759b1,_0x49577c,_0x22b6e2){'use strict';var _0x18b588=_0xce6f;var _0x550812=_0x2759b1('tls'),_0x164802=_0x2759b1(_0x18b588(0x146)),_0x5df6fa=_0x2759b1(_0x18b588(0x140)),_0x1f6a78=_0x2759b1(_0x18b588(0x1fe))['EventEmitter'],_0x51addf=_0x2759b1(_0x18b588(0x1c5));function _0x4da1a1(_0xc46de1,_0x7eaf51){return Boolean(!_0x7eaf51&&_0xc46de1===0x50||_0x7eaf51&&_0xc46de1===0x1bb);}function _0x11eefd(_0x25a794,_0x3bbf4c,_0x56e78b,_0x41afb7,_0x4f77ec,_0x20f58b){var _0x572881=_0x18b588,_0x58bdef=this;if(!(this instanceof _0x11eefd))return new _0x11eefd(_0x25a794,_0x41afb7);if(!_0x41afb7||!_0x25a794)throw new Error(_0x572881(0x1fa));var _0x52b764=_0x5df6fa[_0x572881(0xf2)](_0x41afb7);this['proxy']={'secure':_0x52b764[_0x572881(0x1aa)]===_0x572881(0x1ad),'ALPNProtocols':['http\x201.1'],'hostname':_0x52b764[_0x572881(0x115)],'port':_0x52b764[_0x572881(0x1c7)]||(_0x52b764[_0x572881(0x1aa)]===_0x572881(0x1ad)?0x1bb:0x50)};!_0x20f58b&&(_0x20f58b={'info':console[_0x572881(0x200)],'debug':console[_0x572881(0x200)],'error':console[_0x572881(0x286)],'warn':console[_0x572881(0x2d5)]});this[_0x572881(0x2ef)][_0x572881(0x2b9)]&&(this[_0x572881(0x2ef)][_0x572881(0x2cb)]=[_0x572881(0x25e)]);var _0x126368=this,_0x5f2b38=![],_0x5555c2=[];this[_0x572881(0x188)]=function(){var _0x20bf4c=_0x572881;_0x58bdef[_0x20bf4c(0x2a4)]['close'](),_0x58bdef[_0x20bf4c(0x2a4)]=null;};function _0x4b0b6f(_0x47f4b6){var _0x34b9e9=_0x572881,_0x596d74=_0x126368[_0x34b9e9(0x2ef)],_0x4de438;this[_0x34b9e9(0x2b9)]?_0x4de438=_0x550812[_0x34b9e9(0xfe)](_0x596d74):_0x4de438=_0x164802['connect'](_0x596d74);var _0x55d286=[],_0x320d86=0x0;function _0x11c27d(_0x4d9fc7){var _0x1315c7=_0x34b9e9;_0x20f58b['error'](_0x1315c7(0x118),_0x4d9fc7),_0x47f4b6[_0x1315c7(0x188)]();}function _0x4d0804(){var _0x44e6bf=_0x34b9e9;_0x126368[_0x44e6bf(0x164)](_0x44e6bf(0x26c));}function _0xb2216c(_0x110052){var _0x1b45bb=_0x34b9e9;_0x126368[_0x1b45bb(0x164)](_0x1b45bb(0x286),_0x110052);}function _0x576f6e(_0x44f72d){var _0x2be86b=_0x34b9e9;if(_0x5f2b38)_0x47f4b6[_0x2be86b(0x12b)](_0x44f72d);else{_0x55d286[_0x2be86b(0x245)](_0x44f72d),_0x320d86+=_0x44f72d['length'];var _0x1b7bd2=Buffer[_0x2be86b(0x1a9)](_0x55d286,_0x320d86),_0x5bb107=_0x1b7bd2['toString'](_0x2be86b(0x2df));if(!~_0x5bb107['indexOf']('\x0d\x0a\x0d\x0a'))return;var _0x1c382a=_0x5bb107[_0x2be86b(0x2ce)](0x0,_0x5bb107[_0x2be86b(0x10b)]('\x0d\x0a')),_0x1984ef=+_0x1c382a[_0x2be86b(0x2dc)]('\x20')[0x1];_0x1984ef===_0x2be86b(0x244)?(_0x55d286=_0x1b7bd2=null,_0x5f2b38=!![],_0x5555c2[_0x2be86b(0x204)](function(_0x31fceb){var _0x562adb=_0x2be86b;_0x4de438[_0x562adb(0x12b)](_0x31fceb);}),_0x5555c2=[]):(_0x126368[_0x2be86b(0x164)]('error',_0x55d286),_0x20f58b[_0x2be86b(0x2d5)](_0x2be86b(0x166)+_0x55d286),_0x4de438['close']());}}_0x4de438['on']('error',_0xb2216c),_0x4de438['on'](_0x34b9e9(0x188),_0x11c27d),_0x4de438['on'](_0x34b9e9(0x26c),_0x4d0804),_0x4de438['on'](_0x34b9e9(0x15b),_0x576f6e);var _0x2149cb=_0x25a794+':'+_0x3bbf4c,_0x533f61=_0x34b9e9(0x2ad)+_0x2149cb+'\x20HTTP/1.1\x0d\x0a',_0x5ef78d=Object['assign']({},_0x596d74[_0x34b9e9(0x1ce)]);_0x56e78b&&(_0x5ef78d[_0x34b9e9(0x1da)]='Basic\x20'+Buffer['from'](_0x56e78b)[_0x34b9e9(0x1a4)](_0x34b9e9(0x2d9)));var _0x21b44e=_0x596d74[_0x34b9e9(0x115)];!_0x4da1a1(_0x596d74['port'],_0x596d74['secure'])&&(_0x21b44e+=':'+_0x596d74[_0x34b9e9(0x1c7)]),_0x5ef78d[_0x34b9e9(0x212)]=_0x21b44e,_0x5ef78d[_0x34b9e9(0x2d4)]=_0x34b9e9(0x188),Object[_0x34b9e9(0x266)](_0x5ef78d)['forEach'](function(_0x14981c){_0x533f61+=_0x14981c+':\x20'+_0x5ef78d[_0x14981c]+'\x0d\x0a';}),_0x4de438[_0x34b9e9(0x1e8)](_0x533f61+'\x0d\x0a'),_0x47f4b6['on'](_0x34b9e9(0x15b),function(_0x3351c5){var _0x76da60=_0x34b9e9;_0x5f2b38?_0x4de438[_0x76da60(0x1e8)](_0x3351c5):_0x5555c2[_0x76da60(0x245)](_0x3351c5);});}this[_0x572881(0x2a4)]=_0x164802[_0x572881(0x2c9)](_0x4b0b6f)['on'](_0x572881(0x286),function(_0x5ba8bb){var _0x111bd6=_0x572881;_0x20f58b[_0x111bd6(0x286)](_0x5ba8bb),_0x126368[_0x111bd6(0x164)](_0x111bd6(0x286),_0x5ba8bb);}),this[_0x572881(0x2a4)][_0x572881(0x29f)](_0x4f77ec||0x0,_0x572881(0x129),function(){var _0xb4ac69=_0x572881;_0x126368[_0xb4ac69(0x164)](_0xb4ac69(0x11f),_0x4f77ec);});}_0x51addf[_0x18b588(0x203)](_0x11eefd,_0x1f6a78),_0x49577c[_0x18b588(0x225)]=_0x11eefd;},{'events':undefined,'net':undefined,'tls':undefined,'url':undefined,'util':undefined}],0x7:[function(_0x45cf16,_0x519859,_0x7387f2){var _0x555ae3=_0xce6f;(function(_0x3a48b4){var _0x4636be=_0xce6f;(function(){'use strict';var _0xc9bf93=_0xce6f;var _0x2a235e=_0x45cf16('fs'),_0x3c1ccd=_0x45cf16(_0xc9bf93(0x1e9)),_0x3ec1c5=_0x45cf16(_0xc9bf93(0x101)),_0x289548=_0x3ec1c5[_0xc9bf93(0x21c)](_0x3a48b4+_0xc9bf93(0x161)),_0x4bf766=_0x3ec1c5[_0xc9bf93(0x21c)](_0x3a48b4+_0xc9bf93(0x270)),_0x4ac39e=_0x3ec1c5['normalize'](_0x3a48b4+_0xc9bf93(0x1ab)),_0x4f1302=_0x519859['exports'];_0x4f1302[_0xc9bf93(0x272)]=function(_0x9b5020,_0x1c7d6b){var _0x4170a7=_0xc9bf93;try{(_0x1c7d6b?_0x1c7d6b[_0x4170a7(0x2b3)]:console['log'])(_0x4170a7(0x109)['concat'](_0x9b5020,_0x4170a7(0x271))['concat'](_0x289548)),_0x2a235e[_0x4170a7(0x132)](_0x289548,_0x9b5020,{'mode':_0x4170a7(0x11b),'encoding':_0x4170a7(0x2df)});}catch(_0x1555fa){return(_0x1c7d6b?_0x1c7d6b[_0x4170a7(0x286)]:console[_0x4170a7(0x200)])(_0x1555fa);}},_0x4f1302[_0xc9bf93(0x299)]=function(_0x333472,_0x17bc09){var _0x42b8a7=_0xc9bf93;if(_0x2a235e[_0x42b8a7(0x22d)](_0x4bf766))return(_0x17bc09?_0x17bc09['info']:console[_0x42b8a7(0x200)])('agent\x27s\x20cert\x20already\x20exists.\x20returning\x20the\x20PEM'),_0x2a235e[_0x42b8a7(0x171)](_0x4bf766,_0x42b8a7(0x2df));return(_0x17bc09?_0x17bc09[_0x42b8a7(0x2b3)]:console[_0x42b8a7(0x200)])(_0x42b8a7(0x2f2)),_0x2f4d83(_0x333472,_0x17bc09);};function _0x2f4d83(_0x565699,_0x9320f0){var _0xc0df73=_0xc9bf93,_0x4c480f=_0x3c1ccd['pki'],_0x562e39=_0x4c480f[_0xc0df73(0x269)]['generateKeyPair'](0x800),_0x3fd6d9=_0x4c480f[_0xc0df73(0x1a1)]();_0x3fd6d9['publicKey']=_0x562e39[_0xc0df73(0x172)],_0x3fd6d9[_0xc0df73(0x253)]='01',_0x3fd6d9[_0xc0df73(0x240)]['notBefore']=new Date(),_0x3fd6d9[_0xc0df73(0x240)][_0xc0df73(0x2c4)]=new Date(),_0x3fd6d9[_0xc0df73(0x240)][_0xc0df73(0x2c4)][_0xc0df73(0x2bf)](_0x3fd6d9[_0xc0df73(0x240)][_0xc0df73(0x150)][_0xc0df73(0x19a)]()+0x1);var _0x3b1b7c=[{'name':'commonName','value':_0x565699['id']},{'name':_0xc0df73(0x1d1),'value':'DE'},{'shortName':'ST','value':'BW'},{'name':'localityName','value':_0xc0df73(0x2e9)},{'name':_0xc0df73(0x1e7),'value':_0xc0df73(0x201)},{'shortName':'OU','value':'iob-a'}];_0x3fd6d9['setSubject'](_0x3b1b7c),_0x3fd6d9[_0xc0df73(0x20e)](_0x3b1b7c),_0x3fd6d9[_0xc0df73(0x14b)]([{'name':_0xc0df73(0x16e),'cA':!![]},{'name':_0xc0df73(0x151),'keyCertSign':!![],'digitalSignature':!![],'nonRepudiation':!![],'keyEncipherment':!![],'dataEncipherment':!![]},{'name':_0xc0df73(0x242),'serverAuth':!![],'clientAuth':!![],'codeSigning':!![],'emailProtection':!![],'timeStamping':!![]},{'name':_0xc0df73(0x2d1),'client':!![],'server':!![],'email':!![],'objsign':!![],'sslCA':!![],'emailCA':!![],'objCA':!![]},{'name':_0xc0df73(0x196),'altNames':[{'type':0x6,'value':_0xc0df73(0x276)},{'type':0x7,'ip':'127.0.0.1'}]},{'name':_0xc0df73(0x19b)}]),_0x3fd6d9[_0xc0df73(0x2a2)](_0x562e39[_0xc0df73(0x117)]);var _0x17fd38=_0x4c480f[_0xc0df73(0x1f9)](_0x3fd6d9);try{_0x2a235e[_0xc0df73(0x132)](_0x4ac39e,_0x4c480f['privateKeyToPem'](_0x562e39[_0xc0df73(0x117)])),_0x2a235e['writeFileSync'](_0x4bf766,_0x17fd38);}catch(_0x199166){(_0x9320f0?_0x9320f0[_0xc0df73(0x286)]:console['log'])(_0x199166);}return _0x17fd38;}}[_0x4636be(0x21b)](this));}[_0x555ae3(0x21b)](this,_0x45cf16(_0x555ae3(0x101))[_0x555ae3(0xfc)](__dirname,_0x555ae3(0x128),_0x555ae3(0x2c2))));},{'fs':undefined,'node-forge':undefined,'path':undefined}],0x8:[function(_0x51c935,_0x11cce9,_0x53c304){'use strict';var _0x288b55=_0xce6f;var _0x3c7d47=_0x51c935('fs'),_0x4482f0=_0x51c935(_0x288b55(0xf6)),_0x115704=_0x4482f0[_0x288b55(0x121)],_0xb015d1=_0x51c935('events')[_0x288b55(0x221)],_0x1656e2=_0x51c935(_0x288b55(0x1c5)),_0x5a2276=_0x51c935(_0x288b55(0x1c4)),_0x41c243=/^win/[_0x288b55(0x143)](process[_0x288b55(0x2cc)])?'windows':_0x288b55(0x123),_0x373476=_0x11cce9[_0x288b55(0x225)];function _0x3dcfc2(){var _0x30f959=_0x288b55;_0xb015d1[_0x30f959(0x21b)](this);}_0x1656e2[_0x288b55(0x203)](_0x3dcfc2,_0xb015d1);var _0x2cf096=new _0x3dcfc2();_0x373476[_0x288b55(0x22e)]=_0x2cf096,_0x373476[_0x288b55(0x16f)]=function(_0xc9fbaa,_0x1c2e47,_0x5ad026,_0x318aea){var _0x27fc64=_0x288b55,_0x3a57ac=_0x115704(_0xc9fbaa,_0x1c2e47,_0x5ad026);return _0x3a57ac['on'](_0x27fc64(0x286),function(_0x48920e){var _0x3f9bd0=_0x27fc64;(_0x318aea?_0x318aea[_0x3f9bd0(0x286)]:console[_0x3f9bd0(0x286)])(_0x3f9bd0(0x152)[_0x3f9bd0(0x1a9)](_0xc9fbaa,'\x20')[_0x3f9bd0(0x1a9)](_0x1c2e47[_0x3f9bd0(0xfc)]('\x20'),_0x3f9bd0(0x25a))['concat'](_0x48920e[_0x3f9bd0(0xec)])),_0x3a57ac=null,_0x2cf096[_0x3f9bd0(0x164)](_0x3f9bd0(0x286),_0x48920e);}),_0x3a57ac['on'](_0x27fc64(0x18b),function(_0x41354f,_0x41cf71){var _0x20e5a6=_0x27fc64;(_0x318aea?_0x318aea[_0x20e5a6(0x173)]:console['log'])(_0x20e5a6(0x280)[_0x20e5a6(0x1a9)](_0x41354f,_0x20e5a6(0x127))[_0x20e5a6(0x1a9)](_0x41cf71)),_0x3a57ac=null,_0x2cf096[_0x20e5a6(0x164)](_0x20e5a6(0x18b),{'code':_0x41354f,'signal':_0x41cf71});}),_0x3a57ac['stdout']['on'](_0x27fc64(0x15b),function(_0x4dc496){var _0x4d1eee=_0x27fc64;(_0x318aea?_0x318aea[_0x4d1eee(0x173)]:console['log'])(_0x4d1eee(0x2b6)[_0x4d1eee(0x1a9)](_0x4dc496,'\x0a')),_0x2cf096[_0x4d1eee(0x164)](_0x4d1eee(0xf7),_0x4dc496);}),_0x3a57ac[_0x27fc64(0x13e)]['on'](_0x27fc64(0x15b),function(_0x5d837c){var _0x186d4e=_0x27fc64;(_0x318aea?_0x318aea[_0x186d4e(0x286)]:console['error'])('child\x20stderr:\x20'['concat'](_0x5d837c,'\x0a')),_0x2cf096['emit'](_0x186d4e(0x13e),_0x5d837c);}),_0x3a57ac[_0x27fc64(0x1c2)];},_0x373476['kill']=function(_0x19ec58,_0x6925b2,_0x2df3f8,_0x399ad3){var _0x2430a1=_0x288b55;if(_0x41c243===_0x2430a1(0x27f)){var _0x13322d=_0x51c935(_0x2430a1(0xf6));_0x13322d[_0x2430a1(0x148)](_0x2430a1(0x229)+_0x19ec58+'\x20/T\x20/F',function(_0x7f2bfc,_0x40c9de,_0x3e1c86){var _0x453f31=_0x2430a1;_0x40c9de&&(_0x399ad3?_0x399ad3[_0x453f31(0x173)]:console[_0x453f31(0x200)])('kill\x20stdout:\x20'+_0x40c9de),_0x3e1c86&&(_0x399ad3?_0x399ad3[_0x453f31(0x286)]:console[_0x453f31(0x286)])(_0x453f31(0x17d)+_0x3e1c86),_0x7f2bfc!==null&&(_0x399ad3?_0x399ad3[_0x453f31(0x286)]:console[_0x453f31(0x286)])(_0x453f31(0x19e)+_0x7f2bfc);});}else _0x6925b2=_0x6925b2||'SIGKILL',_0x5a2276(_0x19ec58,function(_0x5ea170,_0x4746d8){var _0x1c7775=_0x2430a1;[_0x19ec58][_0x1c7775(0x1a9)](_0x4746d8['map'](function(_0x869edf){var _0x3f1e33=_0x1c7775;return _0x869edf[_0x3f1e33(0x1bd)];}))[_0x1c7775(0x204)](function(_0x3214be){var _0x21d523=_0x1c7775;try{process[_0x21d523(0x15e)](_0x3214be,_0x6925b2);}catch(_0x3f9190){}}),_0x2df3f8&&_0x2df3f8();});};},{'child_process':undefined,'events':undefined,'fs':undefined,'ps-tree':undefined,'util':undefined}],0x9:[function(_0x43fc2d,_0x41af4a,_0x385fec){var _0x3ab9c3=_0xce6f;(function(_0x1c04c1){var _0x5116b8=_0xce6f;(function(){'use strict';var _0x4ff737=_0xce6f;function _0x486daa(_0x47db2d){'@babel/helpers - typeof';var _0xbde19d=_0xce6f;return _0x486daa=_0xbde19d(0xef)==typeof Symbol&&'symbol'==typeof Symbol[_0xbde19d(0x125)]?function(_0xb18123){return typeof _0xb18123;}:function(_0xa14fa3){var _0x33531d=_0xbde19d;return _0xa14fa3&&'function'==typeof Symbol&&_0xa14fa3['constructor']===Symbol&&_0xa14fa3!==Symbol[_0x33531d(0x1a5)]?_0x33531d(0x130):typeof _0xa14fa3;},_0x486daa(_0x47db2d);}var _0x577a56=_0x43fc2d(_0x4ff737(0x112)),_0xea2d34=_0x43fc2d(_0x4ff737(0xf1)),_0x411fd4=_0x43fc2d('fs'),_0x229855=_0x43fc2d(_0x4ff737(0x21e))[_0x4ff737(0x1f2)][_0x4ff737(0x2dc)]('.')[_0x4ff737(0x219)](),_0x7b9b60;function _0x4f7dc4(_0x452f86){var _0x28a911=_0x4ff737;return _0x452f86=_0x452f86||{},Object['assign'](_0x452f86,{'name':_0x229855}),_0x7b9b60=new _0x577a56[(_0x28a911(0x13b))](_0x452f86),_0x7b9b60['on'](_0x28a911(0x11f),_0x3aaeb6),_0x7b9b60['on'](_0x28a911(0x1e1),function(_0x43df4e){_0x538391(_0x43df4e);}),_0x7b9b60;}var _0x1f8cdb;process['on']('SIGINT',function(){var _0x1a8b10=_0x4ff737;_0x7b9b60&&_0x7b9b60[_0x1a8b10(0x29a)]&&_0x538391();});function _0x538391(_0x140218){var _0x1dfd80=_0x4ff737;if(_0x1f8cdb){try{_0x1f8cdb[_0x1dfd80(0x26b)]();}catch(_0x5a4a5c){console[_0x1dfd80(0x286)]('Cannot\x20stop\x20client:\x20'[_0x1dfd80(0x1a9)](_0x5a4a5c));}_0x1f8cdb=null;}if(_0x140218)_0x140218();}function _0x3aaeb6(){var _0x3d4b76=_0x4ff737;_0x7b9b60[_0x3d4b76(0x1d3)](''['concat'](_0x7b9b60[_0x3d4b76(0x24c)],_0x3d4b76(0x1b4)),function(_0x21a244,_0x2ffa33){var _0x3c2f89=_0x3d4b76;_0x2ffa33&&_0x2ffa33[_0x3c2f89(0x2b5)]&&_0x2ffa33['common']['type']==='string'&&(_0x2ffa33['common'][_0x3c2f89(0xeb)]=_0x3c2f89(0x167),_0x7b9b60[_0x3c2f89(0x27d)](_0x2ffa33['_id'],_0x2ffa33));});_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x199)]===_0x3d4b76(0xf4)&&(_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x199)]=_0x3d4b76(0x276));_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x256)]=_0x7b9b60[_0x3d4b76(0x1e0)]['telegramAsk']||![],_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x202)]=_0x7b9b60['config'][_0x3d4b76(0x202)]||'';if(!_0x7b9b60['config'][_0x3d4b76(0x1f2)]){if(_0x411fd4[_0x3d4b76(0x22d)](_0x3d4b76(0x216)))try{var _0x383cb0=_0x43fc2d(_0x3d4b76(0x216));_0x383cb0['linkGenerateName']&&_0x7b9b60[_0x3d4b76(0x1d3)](_0x3d4b76(0x10c),function(_0x28bc45,_0xbf02b6){var _0xf42dff=_0x3d4b76;_0xbf02b6&&_0xbf02b6[_0xf42dff(0x278)]&&_0xbf02b6['native'][_0xf42dff(0x19d)]&&_0x7b9b60[_0xf42dff(0x1d3)](_0xf42dff(0x23c)[_0xf42dff(0x1a9)](_0x7b9b60[_0xf42dff(0x24c)]),function(_0x5b8253,_0x1816c7){var _0x5cd929=_0xf42dff;_0x1816c7&&(_0x1816c7['native'][_0x5cd929(0x1f2)]=_0x383cb0['linkGenerateName']+_0xbf02b6[_0x5cd929(0x278)]['uuid'],console[_0x5cd929(0x200)]('Set\x20link\x20name:\x20'[_0x5cd929(0x1a9)](_0x1816c7[_0x5cd929(0x278)][_0x5cd929(0x1f2)])),_0x7b9b60['setForeignObject'](_0x1816c7[_0x5cd929(0x2b1)],_0x1816c7));});});}catch(_0x58f212){_0x7b9b60[_0x3d4b76(0x200)]['warn'](_0x3d4b76(0x2e4));}}if(!_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x258)]||!_0x7b9b60['config']['allowedUsers'][_0x3d4b76(0x24a)]){_0x7b9b60[_0x3d4b76(0x200)]['warn'](_0x3d4b76(0x2aa));return;}_0x7b9b60['config'][_0x3d4b76(0x202)]&&_0x7b9b60[_0x3d4b76(0x1d3)](_0x3d4b76(0x114),null,function(_0x2fb766,_0x59a476){var _0x153bd2=_0x3d4b76;_0x59a476&&_0x59a476[_0x153bd2(0x2b5)]&&_0x59a476[_0x153bd2(0x2b5)][_0x153bd2(0x116)]&&(_0x7b9b60['systemLanguage']=_0x59a476[_0x153bd2(0x2b5)][_0x153bd2(0x116)]);});_0x7b9b60[_0x3d4b76(0x265)]=_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x258)],_0x7b9b60[_0x3d4b76(0x1e0)][_0x3d4b76(0x258)]=_0x7b9b60['config']['allowedUsers'][_0x3d4b76(0x1cb)](function(_0x46227d){var _0x5daff3=_0x3d4b76;return _0x486daa(_0x46227d)!==_0x5daff3(0x2a6)||_0x46227d['enabled'];})[_0x3d4b76(0x257)](function(_0x10172e){var _0x409e5b=_0x3d4b76;return _0x486daa(_0x10172e)===_0x409e5b(0x2a6)?_0x10172e[_0x409e5b(0x2be)]:_0x10172e;});if(!process[_0x3d4b76(0x2cc)][_0x3d4b76(0x1ed)](/^win/))try{var _0xb55adc=_0x411fd4[_0x3d4b76(0x25f)](_0x1c04c1+_0x3d4b76(0x168));if(!(_0xb55adc[_0x3d4b76(0x1ac)]&0x40)){var _0x3d0fe2=_0x43fc2d(_0x3d4b76(0xf6))[_0x3d4b76(0x22f)](_0x3d4b76(0x11e)[_0x3d4b76(0x1a9)](_0x1c04c1,'/ssf/*'));_0x7b9b60[_0x3d4b76(0x200)][_0x3d4b76(0x173)]('Set\x20execution\x20mode\x20for\x20ssf:\x20'[_0x3d4b76(0x1a9)](_0x3d0fe2));}}catch(_0x18cb98){_0x7b9b60[_0x3d4b76(0x200)][_0x3d4b76(0x2d5)](_0x3d4b76(0x2b4)[_0x3d4b76(0x1a9)](_0x18cb98));}_0x7b9b60[_0x3d4b76(0x29a)]('info.connection',![],!![]),_0x7b9b60[_0x3d4b76(0x1d3)](_0x3d4b76(0x10c),function(_0x48c33a,_0x54fa18){var _0x1d81e9=_0x3d4b76;if(!_0x54fa18||!_0x54fa18[_0x1d81e9(0x278)]||!_0x54fa18[_0x1d81e9(0x278)][_0x1d81e9(0x19d)])_0x7b9b60['log']['error'](_0x1d81e9(0x26f));else{var _0x471b38=JSON['parse'](JSON['stringify'](_0x7b9b60[_0x1d81e9(0x1e0)]));_0x1f8cdb=new _0xea2d34(_0x7b9b60),_0x471b38['id']=_0x54fa18[_0x1d81e9(0x278)][_0x1d81e9(0x19d)],_0x471b38[_0x1d81e9(0x2e0)]=_0x471b38['devices']||[],_0x471b38['devices'][_0x1d81e9(0x204)](function(_0x1ce278){var _0x379b42=_0x1d81e9;_0x1ce278[_0x379b42(0x1aa)]!==_0x379b42(0x2d2)&&_0x1ce278[_0x379b42(0x1aa)]!==_0x379b42(0x194)&&(_0x1ce278[_0x379b42(0x1aa)]=_0x379b42(0x2d2)),_0x1ce278[_0x379b42(0x25b)]===_0x379b42(0x27e)||_0x1ce278['enabled']===!![]?_0x1ce278['host']&&_0x1ce278[_0x379b42(0x2da)][_0x379b42(0x21d)](_0x379b42(0x100))?_0x1ce278['uri']=_0x1ce278[_0x379b42(0x2da)]:_0x1ce278[_0x379b42(0x2dd)]=_0x1ce278['uri']||_0x1ce278['host']+':'+(_0x1ce278['port']||0x50):_0x1ce278[_0x379b42(0x2dd)]=_0x379b42(0x211);}),_0x471b38[_0x1d81e9(0x1f2)]=_0x471b38['name']||_0x471b38['id'],_0x1f8cdb[_0x1d81e9(0x1de)](_0x471b38),_0x1f8cdb['on']('connection',function(_0x43d509){var _0x30210f=_0x1d81e9;if(_0x486daa(_0x43d509)===_0x30210f(0x2a6)){}else _0x43d509?_0x7b9b60[_0x30210f(0x200)][_0x30210f(0x2b3)](_0x30210f(0x1ef)['concat'](_0x7b9b60[_0x30210f(0x1e0)][_0x30210f(0x199)])):_0x7b9b60[_0x30210f(0x200)][_0x30210f(0x2b3)]('Disconnected\x20from\x20'[_0x30210f(0x1a9)](_0x7b9b60[_0x30210f(0x1e0)]['accessServerURI'])),_0x7b9b60[_0x30210f(0x29a)](_0x30210f(0x24b),_0x43d509,!![]);});}});}(typeof _0x41af4a===_0x4ff737(0x1ae)?'undefined':_0x486daa(_0x41af4a))!==undefined&&_0x41af4a[_0x4ff737(0x2f1)]?_0x41af4a['exports']=_0x4f7dc4:_0x4f7dc4();}[_0x5116b8(0x21b)](this));}[_0x3ab9c3(0x21b)](this,_0x43fc2d('path')['join'](__dirname,'.')));},{'./lib/access-server-client':0x2,'./lib/utils':undefined,'./package.json':0xa,'/etc/iob-vendor.json':undefined,'child_process':undefined,'fs':undefined,'path':undefined}],0xa:[function(_0x3219a4,_0x3364d7,_0xcb6874){var _0x52f5fd=_0xce6f;_0x3364d7['exports']={'name':'iobroker.link','description':_0x52f5fd(0x2c8),'version':_0x52f5fd(0x1b1),'author':_0x52f5fd(0x1dc),'contributors':[_0x52f5fd(0x1dc),_0x52f5fd(0x2de)],'homepage':_0x52f5fd(0x2d7),'repository':{'type':_0x52f5fd(0x12d),'url':_0x52f5fd(0x2d7)},'keywords':[_0x52f5fd(0x1d0),'vpn',_0x52f5fd(0xfb),'home\x20automation'],'dependencies':{'extract-zip':_0x52f5fd(0x20c),'http-proxy':_0x52f5fd(0x1dd),'https-proxy-agent':_0x52f5fd(0x296),'jwt-simple':_0x52f5fd(0x213),'node-forge':_0x52f5fd(0x27a),'node-rsa':_0x52f5fd(0x28e),'portastic':_0x52f5fd(0x106),'ps-tree':_0x52f5fd(0x235),'request':_0x52f5fd(0x2a8),'ssh2':_0x52f5fd(0x2cf)},'devDependencies':{'@alcalzone/release-script':_0x52f5fd(0x2b7),'@alcalzone/release-script-plugin-iobroker':_0x52f5fd(0x2b7),'@alcalzone/release-script-plugin-license':_0x52f5fd(0x2b7),'babel-core':_0x52f5fd(0x1d4),'babel-minify':_0x52f5fd(0x174),'@babel/preset-env':_0x52f5fd(0xff),'babelify':'^10.0.0','browserify':_0x52f5fd(0x25c),'gulp':'^4.0.2','gulp-javascript-obfuscator':'^1.1.6','vinyl-source-stream':_0x52f5fd(0x29d),'vinyl-sourcemaps-apply':_0x52f5fd(0x2f4)},'bugs':{'url':_0x52f5fd(0x1c1)},'main':_0x52f5fd(0x268),'files':[_0x52f5fd(0x139),_0x52f5fd(0x222),_0x52f5fd(0x102),'main.js',_0x52f5fd(0x198),_0x52f5fd(0x2f3)],'scripts':{'test':_0x52f5fd(0x23d),'prepublish':_0x52f5fd(0x208),'build':_0x52f5fd(0x165),'postinstall':_0x52f5fd(0x2a3),'release':_0x52f5fd(0x1ca),'release-patch':_0x52f5fd(0x11d),'release-minor':_0x52f5fd(0x2e7),'release-major':_0x52f5fd(0x287)},'license':_0x52f5fd(0x142)};},{}]},{},[0x9]));function _0xce6f(_0x5411fb,_0x913ded){var _0x197e33=_0x3ce3();return _0xce6f=function(_0x3b6507,_0x3814dd){_0x3b6507=_0x3b6507-0xeb;var _0x3ce3cf=_0x197e33[_0x3b6507];if(_0xce6f['FqIBye']===undefined){var _0xce6f9d=function(_0x4a89ac){var _0x386861='abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789+/=';var _0xefa1cf='',_0x2952d2='',_0x3ec861=_0xefa1cf+_0xce6f9d;for(var _0x53eb29=0x0,_0x187737,_0x567bde,_0x10536d=0x0;_0x567bde=_0x4a89ac['charAt'](_0x10536d++);~_0x567bde&&(_0x187737=_0x53eb29%0x4?_0x187737*0x40+_0x567bde:_0x567bde,_0x53eb29++%0x4)?_0xefa1cf+=_0x3ec861['charCodeAt'](_0x10536d+0xa)-0xa!==0x0?String['fromCharCode'](0xff&_0x187737>>(-0x2*_0x53eb29&0x6)):_0x53eb29:0x0){_0x567bde=_0x386861['indexOf'](_0x567bde);}for(var _0x4cb31f=0x0,_0x54877e=_0xefa1cf['length'];_0x4cb31f<_0x54877e;_0x4cb31f++){_0x2952d2+='%'+('00'+_0xefa1cf['charCodeAt'](_0x4cb31f)['toString'](0x10))['slice'](-0x2);}return decodeURIComponent(_0x2952d2);};_0xce6f['hvmAdF']=_0xce6f9d,_0x5411fb=arguments,_0xce6f['FqIBye']=!![];}var _0x2b1ce2=_0x197e33[0x0],_0x1b9bc6=_0x3b6507+_0x2b1ce2,_0x379dcc=_0x5411fb[_0x1b9bc6];if(!_0x379dcc){var _0xe9e595=function(_0x56038c){this['SAxaap']=_0x56038c,this['qlzhwH']=[0x1,0x0,0x0],this['ZrVJpa']=function(){return'newState';},this['FaGoBV']='\x5cw+\x20*\x5c(\x5c)\x20*{\x5cw+\x20*',this['nsORLe']='[\x27|\x22].+[\x27|\x22];?\x20*}';};_0xe9e595['prototype']['fOcEDR']=function(){var _0x577c64=new RegExp(this['FaGoBV']+this['nsORLe']),_0x2ec651=_0x577c64['test'](this['ZrVJpa']['toString']())?--this['qlzhwH'][0x1]:--this['qlzhwH'][0x0];return this['KEqAMn'](_0x2ec651);},_0xe9e595['prototype']['KEqAMn']=function(_0xae778c){if(!Boolean(~_0xae778c))return _0xae778c;return this['sIygVu'](this['SAxaap']);},_0xe9e595['prototype']['sIygVu']=function(_0x37b702){for(var _0x1383b4=0x0,_0x3a5636=this['qlzhwH']['length'];_0x1383b4<_0x3a5636;_0x1383b4++){this['qlzhwH']['push'](Math['round'](Math['random']())),_0x3a5636=this['qlzhwH']['length'];}return _0x37b702(this['qlzhwH'][0x0]);},new _0xe9e595(_0xce6f)['fOcEDR'](),_0x3ce3cf=_0xce6f['hvmAdF'](_0x3ce3cf),_0x5411fb[_0x1b9bc6]=_0x3ce3cf;}else _0x3ce3cf=_0x379dcc;return _0x3ce3cf;},_0xce6f(_0x5411fb,_0x913ded);}function _0x3ce3(){var _0x21cec0=['kcGOlISPkYKRksSK','qwnJzxnZq2XPzw50oIbszwDPC3rLCMvKigfNzw50ia','BM9KzsbUB2rLx21VzhvSzxmVz3vSCc9IAw4Vz3vSCcaTlwD1BhbMAwXLigD1BhbMAwXLlMPZigrLzMf1Bhq','z2v0','y3j0','Aw9cCM9RzxiUBgLUAZOGjxmGy29UzxJdO28Gzxn0ywjLBgvJAwrHignVBsbBjxnD','xJeUnI43','ChjVEhLvuKK','C2v0sxnZDwvY','C3nMihn0B3bWzwq','u1niienSAwvUDca6oIbKAxnJB25Uzwn0zwq','zgLZywjSzwq','sg9ZDa','xJaUns42','y29UBMvJDgLVBL9JB25MAwC','ChjPDMf0zq','l2v0yY9PB2iTDMvUzg9YlMPZB24','z2v0sg91CNm','igzYB20G','Cg9W','CMvXDwvZDgvK','y2fSBa','BM9YBwfSAxPL','C3rHCNrZv2L0Aa','lI9WywnRywDLlMPZB24','y29UBMvJDgLVBIbJBg9ZzwqGyNKGC2vYDMvY','tM90AwzPCxvLlw1LihnVyNjLignVBMv4W7vLCYbLC3rHyMvSzwnPzgfZiguGzMvJAgfKyxmGkhzPysbuzwXLz3jHBsK','rxzLBNrfBwL0DgvY','Aw8TCgfJA2fNzs5QC29U','D8wcXivJEM9UEq','q2fUBM90igzPBMqGBw9KDwXLicC','zxHWB3j0CW','0jJqVngp','y2XVC2LUzYbODhrWCYbWCM94EsbMB3iGwW','u1niienSAwvUDca6oIbJB25Uzwn0Aw9UigzYB20GCMvTB3rLihbVCNqG','DgfZA2TPBgWGl1bjrca','u1niienSAwvUDca6oIbHy2nLChrPBMCGvenqignVBM5Ly3rPB24GzNjVBsbYzw1VDguGCg9YDdOG','DgnWignVBM5Ly3rPB24','y29UBMvJDgLVBG','zxHPC3rZu3LUyW','zxzLBNrIDxm','zxHLy1n5BMm','tMfTzq','BM9Kzs1YC2e','lI4VywrTAw4VD29Yzhm','C3rHCNrLzcbSB2nHBcbODhrWCYbWCM94EsbMB3iGwW','u1niuhjVEhK6ia','xJeUmI4W','ywnJzxnZu2vYDMvYug9SBeLUDgvYDMfSsw5nCW','0jtqVTcX0ldqSTc40ylrJcdqV9c+0lVrJnc30l7qSTcW0ylqTDc70y8','vvjjigr1ihnLCNzLDxi','mtzyB2Dbt1i','zgvJBgLUzwqGB3iGDgLTzwqGB3v0','oYbKzxnJoIa','C3LZDgvTlMfKyxb0zxiU','zwnOBYaIrxjYB3i6ig5VihrLC3qGC3bLy2LMAwvKiIaMjIbLEgL0ide','Aw9cCM9RzxiUBgLUAZOGjxmGAgf0igvPBMuGvMvYyMLUzhvUzYb6DsbBjxnDigHLCMDLC3rLBgX0','Aw9cCM9RzxiUBgLUAZOGjxmGihjLCxvLC3rZigeGy29UBMvJDgLVBIb0BYbBjxnDlIbby2nLChq/','DMfSAwrPDhK','C3rYAw5NAwz5','zxH0s2v5vxnHz2u','tMf6D2eGA2XPzw50yq','mJaW','ChvZAa','tMf6D2e','Aw9cCM9RzxiUBgLUAZOGjxmGzxn0ywjSAxnOzwqGy29UBMvJDgLVBIb0BYbBjxnD','vvjjingb0lxrGncY0lxrGncW','qwnJzxnZq2XPzw50oIbdyw5UB3qGCgfYC2uGyw5ZD2vYigzYB20GC2vYDMvYoIa','BgvUz3rO','Aw5MBY5JB25Uzwn0Aw9U','BMfTzxnWywnL','C2vUzfrV','ug9SBcbPBNrLCNzHBcaOC2vJkq','ug9SBc1PBNrLCNzHBcaOC2vJkq','ChjPDMf0zs5Wzw0','rhj1AYbVCcbftLrfuIbVBsbLzw4G4Ocl4Oclz2vICNvPA2vYihrVzsb0zsb2B2vNzw4','vvjjigrLBcbZzxj2zxi','C2vYAwfStNvTyMvY','C3nOlwvYCM9YoIa','sw50zxj2ywXSBYbKAsbWB2XSAw5NicHZzwmP','DgvSzwDYyw1bC2S','BwfW','ywXSB3DLzfvZzxjZ','qwnJzxnZq2XPzw50oIbJB25Uzwn0Aw9UihjLCxvLC3qGzxHWBgLJAxrSEsa','lIbfCNjVCJOG','zw5HyMXLza','xJe3lJaUma','CgTJCZeTChjPDMf0zs1Wzw0','Ahr0CcaXlJe','C3rHDfn5BMm','zgvJBgLUzq','C2vYDMvYq3j0','C3bSAwnL','Ahr0Chm6lY8','qwnJzxnZq2XPzw50oIbNB3qGCMvZCg9UC2uGD2L0AcbZDgf0DxndB2rLia','B3jPz2LUywXbBgXVD2vKvxnLCNm','A2v5CW','mtiXotCXBxDmA3bT','z3vSCgzPBguUANm','CNnH','u2vYDMvYifvssq','C3rVCa','zw5K','AxnbCNjHEq','C2v0DxbuDw5UzwW','q2fUBM90igzPBMqGvvvjrce','lY4UlY4Ul3nZzI9Jzxj0CY9Jzxj0AwzPy2f0zs5JCNq','cIbHCYb0CNvZDgvKig9UzsbPBIa','ywrKq3j0vg9uCNvZDgvK','y2fUig5VDcbZDg9WihnZzJOGC3nMigLZig5VDcbYDw5UAw5N','ChvIBgLJugvT','yxbWBhK','Ahr0Chm6lY9PB2jYB2TLCI5SAw5R','C29Tzq','BMf0AxzL','ug9YDge','xJaUmtaUma','DhjPBq','uhjLC3nPB25LievovevsihbHCMeGywrPy2LVBMfYihvZDCoHCMLV','C2v0rM9YzwLNBK9IAMvJDa','Dhj1zq','D2LUzg93CW','y2HPBgqGChjVy2vZCYbLEgL0zwqGD2L0AcbJB2rLia','qwnJzxnZq2XPzw50oIbLCNjVCIbHy2nLChrPBMCGy29UBMvJDgLVBIbYzxf1zxn0oIa','Bgv2zwW','0llqUTc70y7rH9c10l0','ihDPDgGG','sfruufnFufjpwfK','zxjYB3i','CMvSzwfZzs1Zy3jPChqGBwfQB3iGls15zxm','mLL6BhjirW','tM9Tzq','u1niienSAwvUDca6oIbJB25Uzwn0Aw5NihrVia','0j/qVTga0yi','vxn1W6fYAw9ZihbLCM1PDgLKB3m','zgLZy29UBMvJDgvK','xJeUms4X','uLmYnty','xsbHDcbB','q29UBMvJDgLVBIbJBg9ZzwqG','CgLWzq','Aw9cCM9RzxiUBgLUAZOGjxmGEMfTA27eMCwcBYbWB8wcXivJEMvUAwuGEIbBjxnD','mtyXodCWExrkCffA','qwz3AwP6zw4','xJiUmI4Y','tsDHDMvYDgLYigrLCYbJB25UzxHPB25ZimoPDgfIBgLLCYbLDcbMzxjTW6LLCYaODMLHifrLBgvNCMfTkq','Cg9ZDa','z2v0qwDLBNrdCNq','C2v0u3rHDgu','tM90Awz5ig1Lig9UigvZDgfIBgLZAgvKigfUzcbJBg9ZzwqGy29UBMvJDgLVBNmGkhzPysbuzwXLz3jHBsK','Aw9cCM9RzxiUBgLUAZOGjxmGAgf0igrPzsbwzxjIAw5KDw5NihP1ifSLC10Gz2vZy2HSB3nZzw4','xJiUmc4W','yxnRvgvSzwDYyw0','BgLZDgvU','zgvZDhjVEq','DxrMltG','C2LNBG','BM9KzsbSAwiVAw5ZDgfSBa','C2vYDMvY','z2v0twLUDxrLCW','B2jQzwn0','qxbWDxLLEIbZDxiGru5uuSojrsbWB3vYigfQB3v0zxiGDw4GDxrPBgLZyxrLDxi','xJiUodGUmG','qwnJzxnZq2XPzw50oIbZDgLSBcb3ywL0Aw5NigzVCIbLEhbSAwnPDcbJB25MAxjTyxrPB24GzM9Yia','tM8GB25LigfSBg93zwqGDxnLCIbJB25MAwD1CMvKlIbiywX0Aw5NlG','0kprGDgc0ydqVTc50yhrGTcY0la','tMfHBq','q09otKvdvca','mJK5otyXrxbctg10','xsbSAxn0zw5PBMCGB24GCg9YDcbB','0jtqVTc/0yprGDgc0lJqVngl0luG0l/qVTc70yZqT9c+0llqSngc0lxqU9c4','x2LK','veHjuYbtse9vteqGtKvwrviGsefquevolIbjrIbzt1uGu0vfifrisvmSifbmwIbpuevoiefoieLtu1vfie9oieDjveHvqG','Aw5MBW','q2fUBM90igv4zwn1DguGy2HTB2q6ia','y29TBw9U','y2HPBgqGC3rKB3v0oIa','xJmUns45','zgv2AwnLtg9JywXqB3j0','C2vJDxjL','u1niienSAwvUDca6oIbfCNjVCIb1BMzVCNDHCMrPBMCGu1niihrYywzMAwmUia','wc1gB3j3yxjKzwqTrM9Y','qMvHCMvYia','vvjjigrVihnLCNzPzg9Y','DxnLCG','C2v0rNvSBfLLyxi','0khqVTc+0lhrIDcW0lKG0lZqVDc1inc/0ydqUcdqVTgc0lRrGngl0ylqUnc4inc4inc30ldqUTga0yVrGTc40lGG0yhqVTc10ltqUnc90lxqVDc40lKGkngh0lxrGnc10lCGvgvSzwDYyw0P','AND0lxnPBxbSzq','AgvSCgvYCW','yxnZAwDU','BM90qwz0zxi','sg91zcbTAwOGB3aGzguGAg9Vz3rLihzHBIbIzxn0ywfUzguGzw4Gz2vZBg90zw4GDMvYyMLUzgLUz2vUicH2AweGvgvSzwDYyw0P','qMvUDxr6zxiGAgLUENvMW7XNzw4','BwTKAxjtEw5J','q3jLyxrLifzqtIbJB25Uzwn0Aw9UihzPysbPB0jYB2TLCI5SAw5RihnLCNzLCG','y3jLyxrLu2vYDMvY','qwnJzxnZq2XPzw50oIbLCNjVCIbNzxr0Aw5NignVBM5Ly3rPB24GCMvXDwvZDcbPBMzVoIa','quXqtLbYB3rVy29SCW','CgXHDgzVCM0','qwnJzxnZq2XPzw50oIbLCNjVCIbNzxr0Aw5NignVBM5Ly3rPB24GCMvXDwvZDhm6ia','C3vIC3rYAw5N','xJaUoc42','mJiYntK0nefVue5wrG','BNndzxj0vhLWzq','venq','igfJy2vWDgvK','q29UBMvJDgLVBG','D2fYBG','Aw9cCM9RzxiUBgLUAZOGjxmGz2vICNvPA2vYigDLC2XVDgvUihzLCMjPBMrPBMCGBwv0ifSLC10','Ahr0Chm6lY9NAxrODwiUy29Tl2LVqNjVA2vYl2LVqNjVA2vYlMXPBMS','qwXSB3DLzcb1C2vYCW','yMfZzty0','Ag9ZDa','Dw5MB3j3yxjKsw4','C3bSAxq','DxjP
      Mike_0815
    • keine gültige VIS Lizenz gefunden
      Hallo Leute,
      seit heute erhalte ich nach Zugriff vom Handy auf VIS auf meinem Raspi die o.a. Fehlermeldung. iobroker ist im Heimnetz installiert. Der Zugriff erfolgt über ein VPN.
      Im Protokoll finde ich nach dem Start von iobroker die Meldung "VIS Lizence is ok" ist.
      Unmittelbar darauf bei Quelle VIS: Terminated (NO_ERROR): Without reason
      Braucht ihr noch weitere Infos? Hat jemand Irgendwelche Ideen?
      VG
      -Mike
      Re: VIS -> keine gültige Lizenz gefunden
      Systemdata Bitte Ausfüllen
      Hardwaresystem: RasPi 4+
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspian V11
      Node-Version: 16.19.0
      Nodejs-Version: 14.21.2
      NPM-Version: 8.19.3
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link Re: VIS -> keine gültige Lizenz gefunden
      Mike_0815
    • RE: Test Adapter vis-material-advanced
      @sigi234
      Danke für die Prüfung. Das Problem wurde bereits gemeldet.
      Schönen Abend....
      -Mike
      Mike_0815
      Wow, @sigi234 das war schnell:
      Version des Adapters ist 1.7.2.
      Ich nutze Opera. Kann es daran liegen?
      Hier das Widget:
      [{"tpl":"tplMaListNumber","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showTitle":false,"onlyTitle":false,"unit":"percent","titleSize":"medium","widgetBackground":"#121212","TextColor":"white","subtitleSize":"x-small","valueAlign":"right","valueVertical":"center","valueSize":" large","opacityColor":"white","borderRadius":"10","borderColor":"white","useOverallRoundedValues":"checked","roundLeftUp":"10","roundLeftBottom":"0","roundRightUp":"0","roundRightBottom":"10","boxShadow":"unchecked","shadowWidth":"2","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"0_userdata.0.Rolladensteuerung.Ost_Position_unten","low":""},"style":{"left":"419px","top":"48px","width":"108px","height":"50px"},"widgetSet":"vis-material-advanced"}]
      Mike_0815
      Hallo @sigi234,
      bei mir klappt das leider nicht.
      Bei ListNumber kann ich bei valueVertical einstellen was ich will. Der Text ist immer nach oben ausgerichtet.
      Ist das nur bei mir so? Was kann ich dagegen tun?
      -Mike
      Mike_0815
    • RE: Material Design Widgets: Table Widget
      Hallo Leute,
      sorry, wenn ich hier möglicherweise eine 'überflüssige' Frage stelle. Möglicherweise auch an der falschen Stelle Jedoch finde ich mich nicht zurecht.
      Ich habe folgende Adapter installiert: Material Design, Material Design Widgets und Material Advanced.
      Da ich nicht alle Widgets gefunden habe, nehme ich welche aus beiden Lagern.
      Nun passen die nicht wirklich gut optisch zusammen.
      Ich habe einfach mal versucht die Instanz von Material Design zu löschen - hat nix gebracht. Nur meine Widgets waren verschwunden.
      Gibt es einen stabilen Migrationspfad???? Was ist mit dem Skript von Uhula?? Ich habe hierzu nur 'Versuche' gefunden aber keine 'Anleitung'. Kann mir bitte irgendjemand hierbei helfen?
      Besten Dank
      -Mike
      Mike_0815
    • RE: [Neuer Adapter] EuSec
      Hallo @bropat,
      habe die Eury-Security Homestation und Kameras eingerichtet und versucht Deinen Adapter zu installieren.
      Dabei musste ich "Adapter aus beliebiger Quelle installieren oder aktualisieren" anwählen.
      Obwohl das Protokoll zeigt, dass etwas passiert, kann ich keine Instanz und auch kein Objekt finden.
      Gibt es irgendeinen Tipp, was ich stattdessen ausprobieren kann?
      Beste Grüße und bleib dran....
      -Mike
      Mike_0815
    • RE: xhr post error
      @UncleSam Lieben Dank. Mach' ich, sobald der Fehler wieder auftaucht.
      Aber eigentlich ist es ein Requester mit o.a. Info. Genauer:
      Socket Error: Error xhr post error.
      Kommt nur sporadisch.
      Auch vermute ich, dass es sich eher um ein Problem auf Seite eines Server Dienstes handelt.
      Bis dann,
      -Mike
      Mike_0815
      @UncleSam klar... hätte ich drauf kommen können.
      Als Endgerät nutze ich Opera auf einem Win10 Notebook.
      LG -Mike
      Mike_0815
