    2. Ingo
    I
    • Topics 13
    • Posts 216
    • Groups 2
    Ingo
    @Ingo
    57
    216
    Ingo Follow
    Pro Starter
    Latest posts made by Ingo
    • RE: Adapter web.0 bleibt rot
      @ingo ich hoffe so ist es recht ?
      I
      Ingo
      @ingo
      neuer Versuch...
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: IoBroker
               Icon name: computer-vm
                 Chassis: vm
              Machine ID: b7d48423f4654e16ab87db4dcac3f10a
                 Boot ID: 65d31b2bfd8d418ab17b91b86d8e69bd
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-10-amd64
            Architecture: x86-64
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:15:02 up 1 day,  1:59,  2 users,  load average: 1.35, 0.86, 0.40
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Mon 2023-09-25 19:15:02 CEST
                 Universal time: Mon 2023-09-25 17:15:02 UTC
                       RTC time: Mon 2023-09-25 17:15:03
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.0G        1.0G        418M        0.0K        1.5G        1.8G
      Swap:           3.1G        0.0K        3.1G
      Total:          6.1G        1.0G        3.5G
               2987 M total memory
               1019 M used memory
                671 M active memory
               1474 M inactive memory
                418 M free memory
                323 M buffer memory
               1225 M swap cache
               3069 M total swap
                  0 M used swap
               3069 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.5G     0  1.5G   0% /dev
      tmpfs          tmpfs     299M  488K  299M   1% /run
      /dev/sda1      ext4       17G   12G  4.7G  71% /
      tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     299M     0  299M   0% /run/user/0
      [Sun Sep 24 17:15:14 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Sep 24 17:15:15 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.3G    /var/
      696M    /var/cache
      688M    /var/cache/apt
      619M    /var/cache/apt/archives
      506M    /var/log
      Archived and active journals take up 488.1M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      2.6G    /opt/iobroker/iobroker-data/
      2.1G    /opt/iobroker/iobroker-data/history
      400M    /opt/iobroker/iobroker-data/files
      140M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      9.1M    /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js
      9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/local/bin/npm              6.13.7
      /usr/local/bin/npx              6.13.7
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      npm WARN npm npm does not support Node.js v18.17.1
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11, 12, 13, 14.
      npm WARN npm You can find the latest version at https://nodejs.org/
      npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
      npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@5.0.4
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.3.5
      javascript:     7.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : IoBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : IoBroker                                 - disabled
        system.adapter.ebus.0                   : ebus                  : IoBroker                                 - disabled
        system.adapter.echarts.0                : echarts               : IoBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : IoBroker                                 -  enabled
      + system.adapter.history.0                : history               : IoBroker                                 -  enabled
        system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 - disabled
        system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 - disabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 - disabled, port: 0
        system.adapter.ical.0                   : ical                  : IoBroker                                 - disabled
        system.adapter.ical.1                   : ical                  : IoBroker                                 - disabled
        system.adapter.ical.2                   : ical                  : IoBroker                                 - disabled
        system.adapter.ical.3                   : ical                  : IoBroker                                 - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: IoBroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : IoBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : IoBroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : IoBroker                                 -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : IoBroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoBroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: IoBroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IoBroker                                 -  enabled
      + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : IoBroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : IoBroker                                 - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : IoBroker                                 -  enabled
        system.adapter.netatmo-crawler.1        : netatmo-crawler       : IoBroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : IoBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.nut.0                    : nut                   : IoBroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
        system.adapter.pushover.0               : pushover              : IoBroker                                 - disabled
        system.adapter.sayit.0                  : sayit                 : IoBroker                                 - disabled
        system.adapter.sayit.1                  : sayit                 : IoBroker                                 - disabled
        system.adapter.shelly.0                 : shelly                : IoBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : IoBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sql.0                    : sql                   : IoBroker                                 - disabled
      + system.adapter.systeminfo.0             : systeminfo            : IoBroker                                 -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 - disabled
        system.adapter.tr-064.0                 : tr-064                : IoBroker                                 - disabled
        system.adapter.vis-bars.0               : vis-bars              : IoBroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IoBroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : IoBroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IoBroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : IoBroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : IoBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : IoBroker                                 -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : IoBroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : IoBroker                                 -  enabled
        system.adapter.vis-map.0                : vis-map               : IoBroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 -  enabled
        system.adapter.vis-players.0            : vis-players           : IoBroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : IoBroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : IoBroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
        system.adapter.web.0                    : web                   : IoBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : IoBroker                                 - disabled
        system.adapter.zigbee.0                 : zigbee                : IoBroker                                 - disabled, port: tcp://192.168.2.194:20108
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
      Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "ebus"         : 3.2.2    , installed 3.2.2
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-icons8" : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "synology"     : 3.0.0    , installed 2.1.13 [Updatable]
      Adapter    "systeminfo"   : 1.1.0    , installed 1.0.0  [Updatable]
      Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
      Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        5850
      States:         3350
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 156
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3203928    1917093/iobroker.js
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3203921    1917093/iobroker.js
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       3206859    1917801/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13732      424/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       3204681    1917197/node-red
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3204633    1917114/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13734      424/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       3207597    1918542/io.simple-a
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        10828      365/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          380        316/dhclient
      udp        0      0 0.0.0.0:57421           0.0.0.0:*                           106        10830      365/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                106        10829      365/avahi-daemon: r
      udp6       0      0 :::54003                :::*                                106        10831      365/avahi-daemon: r
      2023-09-25 19:14:43.656  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-25 19:14:43.656  - error: host.IoBroker Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-25 19:14:43.656  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:23:47
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:  {
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:   requireStack: [
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js',
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]:   ]
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]: }
      2023-09-25 19:14:43.657  - error: host.IoBroker Caught by controller[0]: Node.js v18.17.1
      2023-09-25 19:14:43.657  - error: host.IoBroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-09-25 19:14:43.658  - info: host.IoBroker Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2023-09-25 19:15:00.085  - info: host.IoBroker instance system.adapter.netatmo-crawler.1 started with pid 1923194
      2023-09-25 19:15:01.263  - info: netatmo-crawler.1 (1923194) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
      2023-09-25 19:15:01.297  - info: netatmo-crawler.1 (1923194) Getting data for stationid:70:ee:50:06:b8:3e
      2023-09-25 19:15:01.587  - info: netatmo-crawler.1 (1923194) Getting data for stationid:70:ee:50:36:a1:f6
      2023-09-25 19:15:02.283  - info: netatmo-crawler.1 (1923194) Getting data for stationid:70:ee:50:59:02:ea
      2023-09-25 19:15:02.995  - info: netatmo-crawler.1 (1923194) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2023-09-25 19:15:03.517  - info: host.IoBroker instance system.adapter.netatmo-crawler.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-25 19:15:04.097  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 started with pid 1923340
      2023-09-25 19:15:05.493  - info: netatmo-crawler.0 (1923340) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
      2023-09-25 19:15:05.532  - info: netatmo-crawler.0 (1923340) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2023-09-25 19:15:06.061  - info: host.IoBroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      I
      Ingo
      @thomas-braun manchmal hilft ein kleiner Denkanstoß...
      also, iob diag
      es gibt Mecker über node.js, habe ich gelöscht, neu installiert, gefixt, hat trotzdem nix gebracht...
      ich habe die Ausgabe von iob diag in einen Spoiler gesetzt, beim Absenden kommt Fehler...
      Ich gebs gleich auf....
      I
      Ingo
      @homoran bitte, welche Konfiguration möchtest du sehen ?
      und welche Zwangsübersetzung ?
      I
      Ingo
      @thomas-braun kriege jedesmal die Meldung:
      Leider darf der Benutzer ingo »/usr/bin/iob diag« als root auf IoBroker nicht ausführen.
      Grrrrr
      I
      Ingo
      @crunchip einmal im Verzeichnis web.0, da dies nix gebracht hat, noch im Verzeichnis /opt/iobroker, brachte aber auch nix.#+
      I
      Ingo
    • Adapter web.0 bleibt rot
      Hallo zusammen, das Problem hat sich erledigt. Ich habe noch eine SD-Karte mit einer Installation für den Raspi gefunden.
      Dort werde ich die Views rausexportieren können. Etwas Anpassungsarbeit wird nötig sein.
      Die Installation auf der Synology läuft, meine "Haupt-View" habe ich dort schon einspielen können.
      Vielen Dank für eure Bemühungen.
      Grüße Ingo
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC i3
      Arbeitsspeicher: 8GB
      Festplattenart: SSD 120 GB
      Betriebssystem: Proxmox
      Node-Version: 5.0.12
      Nodejs-Version: 18.15.0
      NPM-Version: 6.13.7
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Hallo zusammen. Ich habe einige Probleme mit IoBroker. Nach dem Update mehrerer Adapter ist ein Crash aufgetreten.
      IoBroker neu gestartet, alles schien gut.
      Erst Tage später habe ich bemerkt, das der web-Adapter nicht mehr lief.
      Da ich nur 3 Backups sichere, war es dafür zu spät.
      web.0 bleibt rot, auch bei Verbunden mit Host, Lebenszeichen und Verbunden mit Gerät oder Dienst.
      Ich habe web.0 ausgeschaltet und einen weiteren web-Adapter installiert und diesen auf Port 8085 gelegt, genau das selbe.
      Iobroker läuft auf einem älteren kleinen PC unter Proxmox. Ist jahrelang top gelaufen.
      Ich habe Zugriff auf die Admin-Oberfläche, und über Proxmox auf die Konsole. Da der Iobroker sowieso seit längerem
      auf eine Synology umziehen sollte, brauche ich von der Proxmox-Installation eigentlich nur noch die Views.
      wie könnte man das bewerkstelligen ????
      Das Log sagt aus, wenn ich web.0 neu starte:
      Fehler	Instanz System.Adapter.Web.0 mit Code 1 beendet (JS_CONTROLLER_STOPPED)
      Der Neuaufbau für den Adapter system.adapter.web.0 war in 3 Versuchen nicht erfolgreich.
      Der Adapter wird nicht erneut gestartet. Bitte führen Sie "npm install --production" im Adapterverzeichnis manuell aus.
      Gastgeber. IoBroker
      Habe ich natürlich versucht, hat aber nicht geklappt.
      schon mal Danke für eure Bemühungen !
      Grüße Ingo
      I
      Ingo
    • RE: Einrichten Grafana mit InFlux DB auf ioBroker - Windows 10
      @spinotti Moin, ich habe es mit Influx und Grafana aufgegeben, nachdem ich ECharts entdeckt habe.
      Ist noch in der Entwicklung (irgendwas mit V0.4...) funktioniert für meine Bedürfnisse ausreichend.
      Soll Flot ablösen. Mal sehen, wenn es fertig ist, wieviel man damit loggen kann. Bei mir sind es momentan
      gerade 5 States, geloggt mit History.
      Grüße Ingo
      I
      Ingo
      @spinotti Hast du da Influxdb 2 ?
      Ich kämpfe auch gerade mit einer derartigen Installation, bis ich gestern irgendwo gelesen habe, Influxdb 2 wird noch
      nicht durch den Adapter unterstützt.
      Mein System läuft auf einem NUC mit Proxmox, 3 VM´s, IoBroker, Raspberrymatic und Influx (1.x) mit Grafana.
      Lief auch ein paar Tage tadellos, dann sollte Proxmox nach einem Update neu gestartet werden, seitdem habe ich
      keine Verbindung mehr zu meiner Datenbank. Schon stundenlang gefrickelt, aber ohne Erfolg. Zu geringe Linux-
      Kenntnisse.
      Grüße Ingo
      I
      Ingo
    • RE: [Ausverkauft] Zigbee Fernbedienung 20 Tasten (anpassbar)
      Hallo Linusmann,
      Ich hätte gern 2 solcher Fernbedienungen.
      Wie ist die Vorgehensweise ?
      Grüße Ingo
      posted in Marktplatz
      I
      Ingo
