nodejs in veralteter Installation nicht updatebar
Hallo zusammen
Ich habe ein Problem mit der Aktualisierung von nodejsIch startete mit sudo apt update, gefolgt von sudo apt full-upgrade.
Danach ein iob stop, iob fix.
Danach iob nodejs-updateHier kommt nun folgendes:
pi@Homee:~ $ iob nodejs-update [INFO] No specific version given. Installing recommended version from Node.js v.22 tree. [INFO] Current Node.js version: not installed [INFO] Stopping ioBroker with 'iob stop'... [INFO] ioBroker stopped successfully. [INFO] Node.js paths are correct. [INFO] Removing old Node.js versions... [INFO] Setting up NodeSource repository for Node.js 22... [INFO] Downloading NodeSource GPG key... [INFO] Verifying GPG key fingerprint... [INFO] GPG key fingerprint verified successfully: 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 [INFO] Creating NodeSource repository file... [INFO] Setting repository pin priority... [INFO] NodeSource repository configured successfully and will remain in the system. [INFO] Checking if nodejs package is on hold... [INFO] nodejs package is not on hold. [INFO] Updating package lists... OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease Holen:3 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] OK:4 http://deb.debian.org/debian bookworm-updates InRelease Holen:5 https://packages.grafana.com/oss/deb stable InRelease [7.660 B] Holen:6 https://apt.grafana.com stable InRelease [7.660 B] OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease Holen:8 https://repos.influxdata.com/debian stable InRelease [6.922 B] OK:9 http://archive.raspberrypi.com/debian bookworm InRelease Holen:10 https://repos.influxdata.com/debian bookworm InRelease [12,9 kB] Fehl:3 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Fehl:5 https://packages.grafana.com/oss/deb stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Fehl:6 https://apt.grafana.com stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Fehl:8 https://repos.influxdata.com/debian stable InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Fehl:10 https://repos.influxdata.com/debian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Paketlisten werden gelesen… Fertig W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://packages.grafana.com/oss/deb stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://apt.grafana.com stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B W: GPG-Fehler: https://repos.influxdata.com/debian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B E: Das Depot »https://repos.influxdata.com/debian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). [ERROR] Failed to update package lists. [INFO] Cleaning up temporary files...Denke irgendwo liegt hier ein Fehler. Kann mir jemand helfen?
Danke!Ergänzung: Ich habe es jetzt schon mehrfach probiert.
Beim ersten mal kam folgendes:pi@Homee:~ $ iob nodejs-update [sudo] Passwort für pi: [INFO] No specific version given. Installing recommended version from Node.js v.22 tree. [INFO] Current Node.js version: v20.20.2 [INFO] Stopping ioBroker with 'iob stop'... [INFO] ioBroker stopped successfully. [INFO] Node.js paths are correct. [INFO] Removing old Node.js versions... (Lese Datenbank ... 272685 Dateien und Verzeichnisse sind derzeit installiert.) Entfernen von nodejs (20.20.2-1nodesource1) ... Trigger für man-db (2.11.2-2) werden verarbeitet ... [INFO] Setting up NodeSource repository for Node.js 22... [INFO] Downloading NodeSource GPG key... [INFO] Verifying GPG key fingerprint... [ERROR] NodeSource GPG key fingerprint mismatch! Expected: 6F71F525282841EEDAF851B42F59B5F99B1BE0B4, Got: pubrsa20482016-05-23[SC] [INFO] Cleaning up temporary files...Auch eine Installation einer älteren Version klappt nicht.
Hallo zusammen
Sogar zwei. Sowohl das Grafana wie das Influx-Repo sind veraltet. Installier die nochmal.
Siehe:https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
Hallo zusammen
Bestimmt fliegen da einen Dinge um die Ohren, wenn man damit was anfangen kann, ist das i.O.
Die Reihenfolge hatte ich mir mal aufgeschrieben.
So ging es dann los:pi@Homee:~ $ sudo apt update Holen:1 http://deb.debian.org/debian bookworm InRelease [151 kB] Holen:2 http://deb.debian.org/debian-security bookworm-security InRelease [34,8 kB] Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB] Holen:4 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] Holen:5 http://archive.raspberrypi.com/debian bookworm InRelease [55,0 kB] Holen:6 https://apt.grafana.com stable InRelease [7.660 B] Holen:7 https://packages.grafana.com/oss/deb stable InRelease [7.660 B] OK:8 https://deb.nodesource.com/node_20.x nodistro InRelease Holen:9 https://repos.influxdata.com/debian stable InRelease [6.922 B] Holen:10 https://repos.influxdata.com/debian bookworm InRelease [12,9 kB] Holen:11 http://deb.debian.org/debian bookworm/main arm64 Packages [8.689 kB] Fehl:4 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Holen:12 http://deb.debian.org/debian bookworm/main armhf Packages [8.506 kB] Holen:13 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [581 kB] Fehl:6 https://apt.grafana.com stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Holen:14 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [582 kB] Fehl:7 https://packages.grafana.com/oss/deb stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Holen:15 http://deb.debian.org/debian bookworm/main Translation-en [6.107 kB] Fehl:9 https://repos.influxdata.com/debian stable InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Holen:16 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [333 kB] Holen:17 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [309 kB] Holen:18 http://deb.debian.org/debian-security bookworm-security/main Translation-en [209 kB] Holen:19 http://deb.debian.org/debian-security bookworm-security/contrib armhf Packages [752 B] Holen:20 http://deb.debian.org/debian-security bookworm-security/contrib arm64 Packages [1.100 B] Holen:21 http://deb.debian.org/debian-security bookworm-security/contrib Translation-en [1.068 B] Holen:22 http://deb.debian.org/debian-security bookworm-security/non-free armhf Packages [480 B] Holen:23 http://deb.debian.org/debian-security bookworm-security/non-free arm64 Packages [5.956 B] Holen:24 http://deb.debian.org/debian-security bookworm-security/non-free Translation-en [5.340 B] Holen:25 http://deb.debian.org/debian-security bookworm-security/non-free-firmware arm64 Packages [508 B] Holen:26 http://deb.debian.org/debian-security bookworm-security/non-free-firmware Translation-en [648 B] Fehl:10 https://repos.influxdata.com/debian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Paketlisten werden gelesen… Fertig N: Für das Depot »http://deb.debian.org/debian bookworm InRelease« wurde der »Version«-Wert von »12.14« in »12.15« geändert. W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://apt.grafana.com stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://packages.grafana.com/oss/deb stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B W: GPG-Fehler: https://repos.influxdata.com/debian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B E: Das Depot »https://repos.influxdata.com/debian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). pi@Homee:~ $ sudo apt full-upgrade Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paketaktualisierung (Upgrade) wird berechnet… Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libbasicusageenvironment1 libc++1-16 libc++abi1-16 libcamera0.2 libcamera0.3 libcamera0.4 libgroupsock8 liblivemedia77 libqt5qmlworkerscript5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libunwind-16 libwlroots12 libwpe-1.0-1 libwpebackend-fdo-1.0-1 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-headers-6.6.28+rpt-common-rpi linux-headers-6.6.31+rpt-common-rpi linux-headers-6.6.47+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-kbuild-6.6.20+rpt linux-kbuild-6.6.28+rpt linux-kbuild-6.6.31+rpt linux-kbuild-6.6.47+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt lxplug-network python3-gi-cairo python3-v4l2 qml-module-qtgraphicaleffects qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. Die folgenden NEUEN Pakete werden installiert: libxcb-cursor0 linux-headers-6.12.96+rpt-common-rpi linux-headers-6.12.96+rpt-rpi-2712 linux-headers-6.12.96+rpt-rpi-v8 linux-image-6.12.96+rpt-rpi-2712 linux-image-6.12.96+rpt-rpi-v8 linux-kbuild-6.12.96+rpt Die folgenden Pakete werden aktualisiert (Upgrade): base-files bluez ca-certificates chromium chromium-browser chromium-browser-l10n chromium-common chromium-l10n chromium-sandbox curl gir1.2-gtk-3.0 gtk-update-icon-cache hplip hplip-data imagemagick-6-common libappstream4 libarchive13 libbluetooth3 libcaca0 libcurl3-gnutls libcurl4 libegl-mesa0 libexpat1 libexpat1-dev libgbm1 libgd3 libgif-dev libgif7 libgl1-mesa-dev libgl1-mesa-dri libglapi-mesa libglx-mesa0 libgraphite2-3 libgraphite2-dev libgtk-3-0 libgtk-3-common libhpmud0 libjavascriptcoregtk-4.1-0 liblzma-dev liblzma5 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6 libnfs13 libnss3 libpam-chksshpwd libpam-modules libpam-modules-bin libpam-runtime libpam0g libpam0g-dev libpoppler-cpp0v5 libpoppler-glib8 libpoppler126 libprotobuf-lite32 libprotobuf32 libpython3.11 libpython3.11-dev libpython3.11-minimal libpython3.11-stdlib librabbitmq4 libsane-hpaio libvncclient1 libwebkit2gtk-4.1-0 libxfont2 libxml2 libxmlb2 linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 linux-libc-dev mesa-libgallium mesa-vdpau-drivers mesa-vulkan-drivers p7zip p7zip-full poppler-utils printer-driver-hpcups printer-driver-postscript-hp python3-httplib2 python3-urllib3 python3.11 python3.11-dev python3.11-minimal python3.11-venv rpi-imager rsync unzip wireless-regdb xserver-common xserver-xorg-core xz-utils 93 aktualisiert, 7 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen 389 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 142 MB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://deb.debian.org/debian bookworm/main arm64 base-files arm64 12.4+deb12u15 [70,9 kB] Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g-dev arm64 1.5.2-6+rpt2+deb12u2 [168 kB] Holen:3 http://deb.debian.org/debian bookworm/main arm64 liblzma-dev arm64 5.4.1-1+deb12u1 [256 kB] Holen:4 http://deb.debian.org/debian bookworm/main arm64 liblzma5 arm64 5.4.1-1+deb12u1 [200 kB] Holen:5 http://deb.debian.org/debian bookworm/main arm64 libxml2 arm64 2.9.14+dfsg-1.3~deb12u6 [620 kB] Holen:6 http://deb.debian.org/debian-security bookworm-security/main arm64 imagemagick-6-common all 8:6.9.11.60+dfsg-1.6+deb12u13 [175 kB] Holen:7 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickcore-6.q16-6 arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [1.606 kB] Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g arm64 1.5.2-6+rpt2+deb12u2 [104 kB] Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules-bin arm64 1.5.2-6+rpt2+deb12u2 [100 kB] Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules arm64 1.5.2-6+rpt2+deb12u2 [405 kB] Holen:11 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickwand-6.q16-6 arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [359 kB] Holen:12 http://deb.debian.org/debian-security bookworm-security/main arm64 libexpat1-dev arm64 2.5.0-1+deb12u3 [281 kB] Holen:13 http://deb.debian.org/debian-security bookworm-security/main arm64 libexpat1 arm64 2.5.0-1+deb12u3 [87,9 kB] Holen:14 http://deb.debian.org/debian bookworm/main arm64 python3.11-dev arm64 3.11.2-6+deb12u8 [621 kB] Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 bluez arm64 5.66-1+rpt2+deb12u2 [1.619 kB] Holen:16 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-dev arm64 3.11.2-6+deb12u8 [4.394 kB] Holen:17 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-runtime all 1.5.2-6+rpt2+deb12u2 [209 kB] Holen:18 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-l10n all 1:151.0.7922.173-1~deb12u1+rpt1 [20,6 MB] Holen:19 http://deb.debian.org/debian bookworm/main arm64 libpython3.11 arm64 3.11.2-6+deb12u8 [1.841 kB] Holen:20 http://deb.debian.org/debian bookworm/main arm64 python3.11-venv arm64 3.11.2-6+deb12u8 [5.888 B] Holen:21 http://deb.debian.org/debian bookworm/main arm64 python3.11 arm64 3.11.2-6+deb12u8 [574 kB] Holen:22 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-stdlib arm64 3.11.2-6+deb12u8 [1.750 kB] Holen:23 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium arm64 1:151.0.7922.173-1~deb12u1+rpt1 [107 MB] Holen:24 http://deb.debian.org/debian bookworm/main arm64 python3.11-minimal arm64 3.11.2-6+deb12u8 [1.861 kB] Holen:25 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-minimal arm64 3.11.2-6+deb12u8 [811 kB] Holen:26 http://deb.debian.org/debian bookworm/main arm64 rsync arm64 3.2.7-1+deb12u6 [405 kB] Holen:27 http://deb.debian.org/debian-security bookworm-security/main arm64 ca-certificates all 20250419~deb12u1 [162 kB] Holen:28 http://deb.debian.org/debian bookworm/main arm64 xz-utils arm64 5.4.1-1+deb12u1 [471 kB] Holen:29 http://deb.debian.org/debian-security bookworm-security/main arm64 libxfont2 arm64 1:2.0.6-1+deb12u1 [124 kB] Holen:30 http://deb.debian.org/debian-security bookworm-security/main arm64 libnss3 arm64 2:3.87.1-1+deb12u4 [1.216 kB] Holen:31 http://deb.debian.org/debian bookworm/main arm64 curl arm64 7.88.1-10+deb12u15 [310 kB] Holen:32 http://deb.debian.org/debian bookworm/main arm64 libcurl4 arm64 7.88.1-10+deb12u15 [367 kB] Holen:33 http://deb.debian.org/debian-security bookworm-security/main arm64 printer-driver-postscript-hp arm64 3.22.10+dfsg0-2+deb12u1 [1.212 kB] Holen:34 http://deb.debian.org/debian-security bookworm-security/main arm64 libsane-hpaio arm64 3.22.10+dfsg0-2+deb12u1 [134 kB] Holen:35 http://deb.debian.org/debian-security bookworm-security/main arm64 hplip arm64 3.22.10+dfsg0-2+deb12u1 [205 kB] Holen:36 http://deb.debian.org/debian-security bookworm-security/main arm64 libhpmud0 arm64 3.22.10+dfsg0-2+deb12u1 [106 kB] Holen:37 http://deb.debian.org/debian-security bookworm-security/main arm64 hplip-data all 3.22.10+dfsg0-2+deb12u1 [6.681 kB] Holen:38 http://deb.debian.org/debian-security bookworm-security/main arm64 printer-driver-hpcups arm64 3.22.10+dfsg0-2+deb12u1 [267 kB] Holen:39 http://deb.debian.org/debian bookworm/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u15 [362 kB] Holen:40 http://deb.debian.org/debian bookworm/main arm64 libxmlb2 arm64 0.3.22-1~deb12u1 [57,2 kB] Holen:41 http://deb.debian.org/debian bookworm/main arm64 libappstream4 arm64 0.16.1-2+b1 [183 kB] Holen:42 http://deb.debian.org/debian-security bookworm-security/main arm64 libarchive13 arm64 3.6.2-1+deb12u5 [318 kB] Holen:43 http://deb.debian.org/debian bookworm/main arm64 libcaca0 arm64 0.99.beta20-3+deb12u1 [196 kB] Holen:44 http://deb.debian.org/debian-security bookworm-security/main arm64 libgd3 arm64 2.3.3-9+deb12u1 [113 kB] Holen:45 http://deb.debian.org/debian bookworm/main arm64 libgif-dev arm64 5.2.1-2.5+deb12u1 [45,9 kB] Holen:46 http://deb.debian.org/debian bookworm/main arm64 libgif7 arm64 5.2.1-2.5+deb12u1 [42,6 kB] Holen:47 http://deb.debian.org/debian bookworm/main arm64 libgraphite2-dev arm64 1.3.14-1+deb12u1 [19,8 kB] Holen:48 http://deb.debian.org/debian bookworm/main arm64 libgraphite2-3 arm64 1.3.14-1+deb12u1 [68,7 kB] Holen:49 http://deb.debian.org/debian bookworm/main arm64 libwebkit2gtk-4.1-0 arm64 2.50.6-1~deb12u2 [20,9 MB] Holen:50 http://deb.debian.org/debian bookworm/main arm64 libjavascriptcoregtk-4.1-0 arm64 2.50.6-1~deb12u2 [6.244 kB] Holen:51 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-common arm64 1:151.0.7922.173-1~deb12u1+rpt1 [43,0 MB] Holen:52 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickcore-6.q16-6-extra arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [177 kB] Holen:53 http://deb.debian.org/debian-security bookworm-security/main arm64 libnfs13 arm64 4.0.0-1+deb12u1 [94,1 kB] Holen:54 http://deb.debian.org/debian-security bookworm-security/main arm64 poppler-utils arm64 22.12.0-2+deb12u3 [177 kB] Holen:55 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler-glib8 arm64 22.12.0-2+deb12u3 [123 kB] Holen:56 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler-cpp0v5 arm64 22.12.0-2+deb12u3 [39,8 kB] Holen:57 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler126 arm64 22.12.0-2+deb12u3 [1.753 kB] Holen:58 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-sandbox arm64 1:151.0.7922.173-1~deb12u1+rpt1 [149 kB] Holen:59 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-common all 2:21.1.7-3+rpt3+deb12u13 [2.388 kB] Holen:60 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-xorg-core arm64 2:21.1.7-3+rpt3+deb12u13 [4.049 kB] Holen:61 http://archive.raspberrypi.com/debian bookworm/main arm64 libgl1-mesa-dri arm64 24.2.8-1~bpo12+rpt5 [55,0 kB] Holen:62 http://archive.raspberrypi.com/debian bookworm/main arm64 libglx-mesa0 arm64 24.2.8-1~bpo12+rpt5 [204 kB] Holen:63 http://deb.debian.org/debian bookworm/main arm64 libprotobuf-lite32 arm64 3.21.12-3+deb12u1 [241 kB] Holen:64 http://archive.raspberrypi.com/debian bookworm/main arm64 libegl-mesa0 arm64 24.2.8-1~bpo12+rpt5 [162 kB] Holen:65 http://archive.raspberrypi.com/debian bookworm/main arm64 libgbm1 arm64 24.2.8-1~bpo12+rpt5 [49,5 kB] Holen:66 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-libgallium arm64 24.2.8-1~bpo12+rpt5 [11,1 MB] Holen:67 http://deb.debian.org/debian bookworm/main arm64 libprotobuf32 arm64 3.21.12-3+deb12u1 [822 kB] Holen:68 http://archive.raspberrypi.com/debian bookworm/main arm64 libglapi-mesa arm64 24.2.8-1~bpo12+rpt5 [77,4 kB] Holen:69 http://archive.raspberrypi.com/debian bookworm/main arm64 libgtk-3-common all 1:3.24.38-2~deb12u3+rpi1+rpt1 [8.917 kB] Holen:70 http://archive.raspberrypi.com/debian bookworm/main arm64 libgtk-3-0 arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [3.747 kB] Holen:71 http://deb.debian.org/debian-security bookworm-security/main arm64 librabbitmq4 arm64 0.11.0-1+deb12u3 [40,3 kB] Holen:72 http://deb.debian.org/debian bookworm/main arm64 libvncclient1 arm64 0.9.14+dfsg-1+deb12u2 [181 kB] Holen:73 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser all 1:151.0.7922.173-1~deb12u1+rpt1 [141 kB] Holen:74 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser-l10n all 1:151.0.7922.173-1~deb12u1+rpt1 [141 kB] Holen:75 http://archive.raspberrypi.com/debian bookworm/main arm64 gir1.2-gtk-3.0 arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [302 kB] Holen:76 http://archive.raspberrypi.com/debian bookworm/main arm64 gtk-update-icon-cache arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [50,1 kB] Holen:77 http://deb.debian.org/debian bookworm/main arm64 libxcb-cursor0 arm64 0.1.4-1 [16,6 kB] Holen:78 http://archive.raspberrypi.com/debian bookworm/main arm64 libbluetooth3 arm64 5.66-1+rpt2+deb12u2 [129 kB] Holen:79 http://deb.debian.org/debian-security bookworm-security/main arm64 p7zip-full arm64 16.02+really26.02+dfsg-0+deb12u1 [1.284 kB] Holen:80 http://archive.raspberrypi.com/debian bookworm/main arm64 libgl1-mesa-dev arm64 24.2.8-1~bpo12+rpt5 [20,1 kB] Holen:81 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-chksshpwd arm64 1.5.2-6+rpt2+deb12u2 [47,7 kB] Holen:82 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-common-rpi all 1:6.12.96-1+rpt1 [8.772 kB] Holen:83 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.96+rpt-rpi-2712 arm64 1:6.12.96-1+rpt1 [32,7 MB] Holen:84 http://deb.debian.org/debian-security bookworm-security/main arm64 p7zip arm64 16.02+really26.02+dfsg-0+deb12u1 [403 kB] Holen:85 http://deb.debian.org/debian-security bookworm-security/main arm64 python3-httplib2 all 0.20.4-3+deb12u1 [39,0 kB] Holen:86 http://deb.debian.org/debian bookworm/main arm64 python3-urllib3 all 1.26.12-1+deb12u4 [114 kB] Holen:87 http://deb.debian.org/debian-security bookworm-security/main arm64 unzip arm64 6.0-28+deb12u1 [158 kB] Holen:88 http://deb.debian.org/debian bookworm/main arm64 wireless-regdb all 2026.05.30-1~deb12u1 [12,6 kB] Holen:89 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-6.12.96+rpt arm64 1:6.12.96-1+rpt1 [1.194 kB] Holen:90 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.347 kB] Holen:91 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.96+rpt-rpi-v8 arm64 1:6.12.96-1+rpt1 [32,7 MB] Holen:92 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.347 kB] Holen:93 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.160 B] Holen:94 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.160 B] Holen:95 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.428 B] Holen:96 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.432 B] Holen:97 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-dev all 1:6.12.96-1+rpt1 [2.315 kB] Holen:98 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-vdpau-drivers arm64 24.2.8-1~bpo12+rpt5 [20,7 kB] Holen:99 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-vulkan-drivers arm64 24.2.8-1~bpo12+rpt5 [9.287 kB] Holen:100 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-imager arm64 2.0.11-1 [33,2 MB] Es wurden 389 MB in 29 s geholt (13,2 MB/s). Changelogs werden gelesen... Fertig Extrahiere Vorlagen aus Paketen: 100% Vorkonfiguration der Pakete ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../base-files_12.4+deb12u15_arm64.deb ... Entpacken von base-files (12.4+deb12u15) über (12.4+deb12u14) ... base-files (12.4+deb12u15) wird eingerichtet ... Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam0g-dev_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam0g-dev:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... Vorbereitung zum Entpacken von .../libpam0g_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam0g:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam0g:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules-bin_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-modules-bin (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-modules-bin (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-modules:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-modules:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../bluez_5.66-1+rpt2+deb12u2_arm64.deb ... Entpacken von bluez (5.66-1+rpt2+deb12u2) über (5.66-1+rpt1+deb12u2) ... Vorbereitung zum Entpacken von .../liblzma-dev_5.4.1-1+deb12u1_arm64.deb ... Entpacken von liblzma-dev:arm64 (5.4.1-1+deb12u1) über (5.4.1-1) ... Vorbereitung zum Entpacken von .../liblzma5_5.4.1-1+deb12u1_arm64.deb ... Entpacken von liblzma5:arm64 (5.4.1-1+deb12u1) über (5.4.1-1) ... liblzma5:arm64 (5.4.1-1+deb12u1) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../00-libxml2_2.9.14+dfsg-1.3~deb12u6_arm64.deb ... Entpacken von libxml2:arm64 (2.9.14+dfsg-1.3~deb12u6) über (2.9.14+dfsg-1.3~deb12u5) ... Vorbereitung zum Entpacken von .../01-imagemagick-6-common_8%3a6.9.11.60+dfsg-1.6+deb12u13_all.deb ... Entpacken von imagemagick-6-common (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../02-libmagickcore-6.q16-6_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickcore-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../03-libmagickwand-6.q16-6_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickwand-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../04-libexpat1-dev_2.5.0-1+deb12u3_arm64.deb ... Entpacken von libexpat1-dev:arm64 (2.5.0-1+deb12u3) über (2.5.0-1+deb12u2) ... Vorbereitung zum Entpacken von .../05-libexpat1_2.5.0-1+deb12u3_arm64.deb ... Entpacken von libexpat1:arm64 (2.5.0-1+deb12u3) über (2.5.0-1+deb12u2) ... Vorbereitung zum Entpacken von .../06-python3.11-dev_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-dev (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../07-libpython3.11-dev_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-dev:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../08-libpython3.11_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../09-python3.11-venv_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-venv (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../10-python3.11_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../11-libpython3.11-stdlib_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-stdlib:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../12-python3.11-minimal_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-minimal (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../13-libpython3.11-minimal_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-minimal:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../14-rsync_3.2.7-1+deb12u6_arm64.deb ... Entpacken von rsync (3.2.7-1+deb12u6) über (3.2.7-1+deb12u5) ... Vorbereitung zum Entpacken von .../15-libpam-runtime_1.5.2-6+rpt2+deb12u2_all.deb ... Entpacken von libpam-runtime (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-runtime (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../00-ca-certificates_20250419~deb12u1_all.deb ... Entpacken von ca-certificates (20250419~deb12u1) über (20230311+deb12u1) ... Vorbereitung zum Entpacken von .../01-xz-utils_5.4.1-1+deb12u1_arm64.deb ... Entpacken von xz-utils (5.4.1-1+deb12u1) über (5.4.1-1) ... Vorbereitung zum Entpacken von .../02-chromium-l10n_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-l10n (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../03-chromium_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../04-chromium-common_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium-common (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../05-chromium-sandbox_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium-sandbox (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../06-xserver-common_2%3a21.1.7-3+rpt3+deb12u13_all.deb ... Entpacken von xserver-common (2:21.1.7-3+rpt3+deb12u13) über (2:21.1.7-3+rpt3+deb12u12) ... Vorbereitung zum Entpacken von .../07-libxfont2_1%3a2.0.6-1+deb12u1_arm64.deb ... Entpacken von libxfont2:arm64 (1:2.0.6-1+deb12u1) über (1:2.0.6-1) ... Vorbereitung zum Entpacken von .../08-xserver-xorg-core_2%3a21.1.7-3+rpt3+deb12u13_arm64.deb ... Entpacken von xserver-xorg-core (2:21.1.7-3+rpt3+deb12u13) über (2:21.1.7-3+rpt3+deb12u12) ... Vorbereitung zum Entpacken von .../09-libgl1-mesa-dri_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgl1-mesa-dri:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../10-libglx-mesa0_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libglx-mesa0:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../11-libegl-mesa0_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libegl-mesa0:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../12-libgbm1_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgbm1:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../13-mesa-libgallium_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-libgallium:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../14-libglapi-mesa_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libglapi-mesa:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../15-libnss3_2%3a3.87.1-1+deb12u4_arm64.deb ... Entpacken von libnss3:arm64 (2:3.87.1-1+deb12u4) über (2:3.87.1-1+deb12u2) ... Vorbereitung zum Entpacken von .../16-libgtk-3-common_1%3a3.24.38-2~deb12u3+rpi1+rpt1_all.deb ... Entpacken von libgtk-3-common (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../17-libgtk-3-0_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von libgtk-3-0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../18-chromium-browser_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-browser (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../19-chromium-browser-l10n_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-browser-l10n (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../20-curl_7.88.1-10+deb12u15_arm64.deb ... Entpacken von curl (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../21-libcurl4_7.88.1-10+deb12u15_arm64.deb ... Entpacken von libcurl4:arm64 (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../22-gir1.2-gtk-3.0_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von gir1.2-gtk-3.0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../23-gtk-update-icon-cache_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von gtk-update-icon-cache (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../24-printer-driver-postscript-hp_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von printer-driver-postscript-hp (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../25-libsane-hpaio_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von libsane-hpaio:arm64 (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../26-hplip_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von hplip (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../27-libhpmud0_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von libhpmud0:arm64 (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../28-hplip-data_3.22.10+dfsg0-2+deb12u1_all.deb ... Entpacken von hplip-data (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../29-printer-driver-hpcups_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von printer-driver-hpcups (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../30-libcurl3-gnutls_7.88.1-10+deb12u15_arm64.deb ... Entpacken von libcurl3-gnutls:arm64 (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../31-libxmlb2_0.3.22-1~deb12u1_arm64.deb ... Entpacken von libxmlb2:arm64 (0.3.22-1~deb12u1) über (0.3.10-2) ... Vorbereitung zum Entpacken von .../32-libappstream4_0.16.1-2+b1_arm64.deb ... Entpacken von libappstream4:arm64 (0.16.1-2+b1) über (0.16.1-2) ... Vorbereitung zum Entpacken von .../33-libarchive13_3.6.2-1+deb12u5_arm64.deb ... Entpacken von libarchive13:arm64 (3.6.2-1+deb12u5) über (3.6.2-1+deb12u4) ... Vorbereitung zum Entpacken von .../34-libbluetooth3_5.66-1+rpt2+deb12u2_arm64.deb ... Entpacken von libbluetooth3:arm64 (5.66-1+rpt2+deb12u2) über (5.66-1+rpt1+deb12u2) ... Vorbereitung zum Entpacken von .../35-libcaca0_0.99.beta20-3+deb12u1_arm64.deb ... Entpacken von libcaca0:arm64 (0.99.beta20-3+deb12u1) über (0.99.beta20-3) ... Vorbereitung zum Entpacken von .../36-libgd3_2.3.3-9+deb12u1_arm64.deb ... Entpacken von libgd3:arm64 (2.3.3-9+deb12u1) über (2.3.3-9) ... Vorbereitung zum Entpacken von .../37-libgif-dev_5.2.1-2.5+deb12u1_arm64.deb ... Entpacken von libgif-dev:arm64 (5.2.1-2.5+deb12u1) über (5.2.1-2.5) ... Vorbereitung zum Entpacken von .../38-libgif7_5.2.1-2.5+deb12u1_arm64.deb ... Entpacken von libgif7:arm64 (5.2.1-2.5+deb12u1) über (5.2.1-2.5) ... Vorbereitung zum Entpacken von .../39-libgl1-mesa-dev_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgl1-mesa-dev:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../40-libgraphite2-dev_1.3.14-1+deb12u1_arm64.deb ... Entpacken von libgraphite2-dev:arm64 (1.3.14-1+deb12u1) über (1.3.14-1) ... Vorbereitung zum Entpacken von .../41-libgraphite2-3_1.3.14-1+deb12u1_arm64.deb ... Entpacken von libgraphite2-3:arm64 (1.3.14-1+deb12u1) über (1.3.14-1) ... Vorbereitung zum Entpacken von .../42-libwebkit2gtk-4.1-0_2.50.6-1~deb12u2_arm64.deb ... Entpacken von libwebkit2gtk-4.1-0:arm64 (2.50.6-1~deb12u2) über (2.50.6-1~deb12u1) ... Vorbereitung zum Entpacken von .../43-libjavascriptcoregtk-4.1-0_2.50.6-1~deb12u2_arm64.deb ... Entpacken von libjavascriptcoregtk-4.1-0:arm64 (2.50.6-1~deb12u2) über (2.50.6-1~deb12u1) ... Vorbereitung zum Entpacken von .../44-libmagickcore-6.q16-6-extra_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickcore-6.q16-6-extra:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../45-libnfs13_4.0.0-1+deb12u1_arm64.deb ... Entpacken von libnfs13:arm64 (4.0.0-1+deb12u1) über (4.0.0-1) ... Vorbereitung zum Entpacken von .../46-libpam-chksshpwd_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... Vorbereitung zum Entpacken von .../47-poppler-utils_22.12.0-2+deb12u3_arm64.deb ... Entpacken von poppler-utils (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../48-libpoppler-glib8_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler-glib8:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../49-libpoppler-cpp0v5_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler-cpp0v5:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../50-libpoppler126_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler126:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../51-libprotobuf-lite32_3.21.12-3+deb12u1_arm64.deb ... Entpacken von libprotobuf-lite32:arm64 (3.21.12-3+deb12u1) über (3.21.12-3) ... Vorbereitung zum Entpacken von .../52-libprotobuf32_3.21.12-3+deb12u1_arm64.deb ... Entpacken von libprotobuf32:arm64 (3.21.12-3+deb12u1) über (3.21.12-3) ... Vorbereitung zum Entpacken von .../53-librabbitmq4_0.11.0-1+deb12u3_arm64.deb ... Entpacken von librabbitmq4:arm64 (0.11.0-1+deb12u3) über (0.11.0-1+deb12u1) ... Vorbereitung zum Entpacken von .../54-libvncclient1_0.9.14+dfsg-1+deb12u2_arm64.deb ... Entpacken von libvncclient1:arm64 (0.9.14+dfsg-1+deb12u2) über (0.9.14+dfsg-1+deb12u1) ... Vormals nicht ausgewähltes Paket libxcb-cursor0:arm64 wird gewählt. Vorbereitung zum Entpacken von .../55-libxcb-cursor0_0.1.4-1_arm64.deb ... Entpacken von libxcb-cursor0:arm64 (0.1.4-1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-common-rpi wird gewählt. Vorbereitung zum Entpacken von .../56-linux-headers-6.12.96+rpt-common-rpi_1%3a6.12.96-1+rpt1_all.deb ... Entpacken von linux-headers-6.12.96+rpt-common-rpi (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-image-6.12.96+rpt-rpi-2712 wird gewählt. Vorbereitung zum Entpacken von .../57-linux-image-6.12.96+rpt-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-kbuild-6.12.96+rpt wird gewählt. Vorbereitung zum Entpacken von .../58-linux-kbuild-6.12.96+rpt_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-kbuild-6.12.96+rpt (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-rpi-2712 wird gewählt. Vorbereitung zum Entpacken von .../59-linux-headers-6.12.96+rpt-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-image-6.12.96+rpt-rpi-v8 wird gewählt. Vorbereitung zum Entpacken von .../60-linux-image-6.12.96+rpt-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-rpi-v8 wird gewählt. Vorbereitung zum Entpacken von .../61-linux-headers-6.12.96+rpt-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) ... Vorbereitung zum Entpacken von .../62-linux-headers-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-rpi-2712 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../63-linux-headers-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-rpi-v8 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../64-linux-image-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-rpi-2712 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../65-linux-image-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-rpi-v8 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../66-linux-libc-dev_1%3a6.12.96-1+rpt1_all.deb ... Entpacken von linux-libc-dev (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../67-mesa-vdpau-drivers_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-vdpau-drivers:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../68-mesa-vulkan-drivers_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-vulkan-drivers:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../69-p7zip-full_16.02+really26.02+dfsg-0+deb12u1_arm64.deb ... Entpacken von p7zip-full (16.02+really26.02+dfsg-0+deb12u1) über (16.02+really25.01+dfsg-0+deb12u1) ... Vorbereitung zum Entpacken von .../70-p7zip_16.02+really26.02+dfsg-0+deb12u1_arm64.deb ... Entpacken von p7zip (16.02+really26.02+dfsg-0+deb12u1) über (16.02+really25.01+dfsg-0+deb12u1) ... Vorbereitung zum Entpacken von .../71-python3-httplib2_0.20.4-3+deb12u1_all.deb ... Entpacken von python3-httplib2 (0.20.4-3+deb12u1) über (0.20.4-3) ... Vorbereitung zum Entpacken von .../72-python3-urllib3_1.26.12-1+deb12u4_all.deb ... Entpacken von python3-urllib3 (1.26.12-1+deb12u4) über (1.26.12-1+deb12u3) ... Vorbereitung zum Entpacken von .../73-rpi-imager_2.0.11-1_arm64.deb ... Entpacken von rpi-imager (2.0.11-1) über (2.0.6) ... Vorbereitung zum Entpacken von .../74-unzip_6.0-28+deb12u1_arm64.deb ... Entpacken von unzip (6.0-28+deb12u1) über (6.0-28) ... Vorbereitung zum Entpacken von .../75-wireless-regdb_2026.05.30-1~deb12u1_all.deb ... Entpacken von wireless-regdb (2026.05.30-1~deb12u1) über (2026.02.04-1~deb12u1) ... libexpat1:arm64 (2.5.0-1+deb12u3) wird eingerichtet ... libgraphite2-3:arm64 (1.3.14-1+deb12u1) wird eingerichtet ... mesa-vulkan-drivers:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... mesa-vdpau-drivers:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... gtk-update-icon-cache (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... librabbitmq4:arm64 (0.11.0-1+deb12u3) wird eingerichtet ... imagemagick-6-common (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... Neue Version der Konfigurationsdatei /etc/ImageMagick-6/policy.xml wird installiert ... libcaca0:arm64 (0.99.beta20-3+deb12u1) wird eingerichtet ... libpam0g-dev:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... libxmlb2:arm64 (0.3.22-1~deb12u1) wird eingerichtet ... unzip (6.0-28+deb12u1) wird eingerichtet ... wireless-regdb (2026.05.30-1~deb12u1) wird eingerichtet ... linux-libc-dev (1:6.12.96-1+rpt1) wird eingerichtet ... libcurl3-gnutls:arm64 (7.88.1-10+deb12u15) wird eingerichtet ... libnss3:arm64 (2:3.87.1-1+deb12u4) wird eingerichtet ... libnfs13:arm64 (4.0.0-1+deb12u1) wird eingerichtet ... chromium-sandbox (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... libvncclient1:arm64 (0.9.14+dfsg-1+deb12u2) wird eingerichtet ... ca-certificates (20250419~deb12u1) wird eingerichtet ... Updating certificates in /etc/ssl/certs... rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL 21 added, 13 removed; done. bluez (5.66-1+rpt2+deb12u2) wird eingerichtet ... libgraphite2-dev:arm64 (1.3.14-1+deb12u1) wird eingerichtet ... libjavascriptcoregtk-4.1-0:arm64 (2.50.6-1~deb12u2) wird eingerichtet ... libexpat1-dev:arm64 (2.5.0-1+deb12u3) wird eingerichtet ... libxcb-cursor0:arm64 (0.1.4-1) wird eingerichtet ... xz-utils (5.4.1-1+deb12u1) wird eingerichtet ... linux-image-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.12.96+rpt-rpi-v8 '/boot/initrd.img-6.12.96+rpt-rpi-v8' -> '/boot/firmware/initramfs8' /etc/kernel/postinst.d/z50-raspi-firmware: '/boot/vmlinuz-6.12.96+rpt-rpi-v8' -> '/boot/firmware/kernel8.img' libgd3:arm64 (2.3.3-9+deb12u1) wird eingerichtet ... linux-image-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... libpoppler126:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libglapi-mesa:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... python3-urllib3 (1.26.12-1+deb12u4) wird eingerichtet ... liblzma-dev:arm64 (5.4.1-1+deb12u1) wird eingerichtet ... libgif7:arm64 (5.2.1-2.5+deb12u1) wird eingerichtet ... libprotobuf32:arm64 (3.21.12-3+deb12u1) wird eingerichtet ... libgif-dev:arm64 (5.2.1-2.5+deb12u1) wird eingerichtet ... libbluetooth3:arm64 (5.66-1+rpt2+deb12u2) wird eingerichtet ... libgl1-mesa-dev:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... python3-httplib2 (0.20.4-3+deb12u1) wird eingerichtet ... libprotobuf-lite32:arm64 (3.21.12-3+deb12u1) wird eingerichtet ... libcurl4:arm64 (7.88.1-10+deb12u15) wird eingerichtet ... chromium-common (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... libpython3.11-minimal:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... curl (7.88.1-10+deb12u15) wird eingerichtet ... poppler-utils (22.12.0-2+deb12u3) wird eingerichtet ... xserver-common (2:21.1.7-3+rpt3+deb12u13) wird eingerichtet ... linux-image-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.12.96+rpt-rpi-2712 '/boot/initrd.img-6.12.96+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712' /etc/kernel/postinst.d/z50-raspi-firmware: '/boot/vmlinuz-6.12.96+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img' linux-kbuild-6.12.96+rpt (1:6.12.96-1+rpt1) wird eingerichtet ... libpoppler-cpp0v5:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libhpmud0:arm64 (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... libxfont2:arm64 (1:2.0.6-1+deb12u1) wird eingerichtet ... libxml2:arm64 (2.9.14+dfsg-1.3~deb12u6) wird eingerichtet ... linux-headers-6.12.96+rpt-common-rpi (1:6.12.96-1+rpt1) wird eingerichtet ... libsane-hpaio:arm64 (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... p7zip (16.02+really26.02+dfsg-0+deb12u1) wird eingerichtet ... libgtk-3-common (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... rsync (3.2.7-1+deb12u6) wird eingerichtet ... rsync.service is a disabled or a static unit not running, not starting it. python3.11-minimal (3.11.2-6+deb12u8) wird eingerichtet ... mesa-libgallium:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libpoppler-glib8:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libgbm1:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libarchive13:arm64 (3.6.2-1+deb12u5) wird eingerichtet ... linux-headers-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libpython3.11-stdlib:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... libgl1-mesa-dri:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... xserver-xorg-core (2:21.1.7-3+rpt3+deb12u13) wird eingerichtet ... hplip-data (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... p7zip-full (16.02+really26.02+dfsg-0+deb12u1) wird eingerichtet ... libappstream4:arm64 (0.16.1-2+b1) wird eingerichtet ... printer-driver-postscript-hp (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... linux-image-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libmagickcore-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... libegl-mesa0:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... linux-headers-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... linux-headers-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libmagickwand-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... rpi-imager (2.0.11-1) wird eingerichtet ... printer-driver-hpcups (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... chromium (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... linux-headers-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... python3.11 (3.11.2-6+deb12u8) wird eingerichtet ... libglx-mesa0:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libpython3.11:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... libmagickcore-6.q16-6-extra:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... python3.11-venv (3.11.2-6+deb12u8) wird eingerichtet ... libpython3.11-dev:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... chromium-l10n (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... chromium-browser (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... chromium-browser-l10n (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... hplip (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... Creating/updating hplip user account... python3.11-dev (3.11.2-6+deb12u8) wird eingerichtet ... Trigger für libc-bin (2.36-9+rpt2+deb12u14) werden verarbeitet ... Trigger für systemd (252.39-1~deb12u2) werden verarbeitet ... Trigger für man-db (2.11.2-2) werden verarbeitet ... Trigger für dbus (1.14.10-1~deb12u1) werden verarbeitet ... Trigger für shared-mime-info (2.2-1) werden verarbeitet ... Trigger für mailcap (3.70+nmu1) werden verarbeitet ... Trigger für desktop-file-utils (0.26-1) werden verarbeitet ... Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ... Trigger für cups (2.4.2-3+deb12u9) werden verarbeitet ... Trigger für gnome-menus (3.36.0-1.1) werden verarbeitet ... Trigger für libglib2.0-0:arm64 (2.74.6-2+deb12u9) werden verarbeitet ... libgtk-3-0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... gir1.2-gtk-3.0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... libwebkit2gtk-4.1-0:arm64 (2.50.6-1~deb12u2) wird eingerichtet ... Trigger für ca-certificates (20250419~deb12u1) werden verarbeitet ... Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done. Running hooks in /etc/ca-certificates/update.d... done. Trigger für libc-bin (2.36-9+rpt2+deb12u14) werden verarbeitet ... -
und wenn das erledigt ist?
Wenn deine Paketverwaltung wieder funktioniert, dann funktioniert auch der nodejs-update Befehl wieder.
Und das Bookworm-Release solltest du langsam auch mal auf Debian 13 'Trixie' hieven.
Wie hieve ich das?
So ging es dann los:pi@Homee:~ $ sudo apt update Holen:1 http://deb.debian.org/debian bookworm InRelease [151 kB] Holen:2 http://deb.debian.org/debian-security bookworm-security InRelease [34,8 kB] Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB] Holen:4 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] Holen:5 http://archive.raspberrypi.com/debian bookworm InRelease [55,0 kB] Holen:6 https://apt.grafana.com stable InRelease [7.660 B] Holen:7 https://packages.grafana.com/oss/deb stable InRelease [7.660 B] OK:8 https://deb.nodesource.com/node_20.x nodistro InRelease Holen:9 https://repos.influxdata.com/debian stable InRelease [6.922 B] Holen:10 https://repos.influxdata.com/debian bookworm InRelease [12,9 kB] Holen:11 http://deb.debian.org/debian bookworm/main arm64 Packages [8.689 kB] Fehl:4 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Holen:12 http://deb.debian.org/debian bookworm/main armhf Packages [8.506 kB] Holen:13 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [581 kB] Fehl:6 https://apt.grafana.com stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Holen:14 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [582 kB] Fehl:7 https://packages.grafana.com/oss/deb stable InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> Holen:15 http://deb.debian.org/debian bookworm/main Translation-en [6.107 kB] Fehl:9 https://repos.influxdata.com/debian stable InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Holen:16 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [333 kB] Holen:17 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [309 kB] Holen:18 http://deb.debian.org/debian-security bookworm-security/main Translation-en [209 kB] Holen:19 http://deb.debian.org/debian-security bookworm-security/contrib armhf Packages [752 B] Holen:20 http://deb.debian.org/debian-security bookworm-security/contrib arm64 Packages [1.100 B] Holen:21 http://deb.debian.org/debian-security bookworm-security/contrib Translation-en [1.068 B] Holen:22 http://deb.debian.org/debian-security bookworm-security/non-free armhf Packages [480 B] Holen:23 http://deb.debian.org/debian-security bookworm-security/non-free arm64 Packages [5.956 B] Holen:24 http://deb.debian.org/debian-security bookworm-security/non-free Translation-en [5.340 B] Holen:25 http://deb.debian.org/debian-security bookworm-security/non-free-firmware arm64 Packages [508 B] Holen:26 http://deb.debian.org/debian-security bookworm-security/non-free-firmware Translation-en [648 B] Fehl:10 https://repos.influxdata.com/debian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B Paketlisten werden gelesen… Fertig N: Für das Depot »http://deb.debian.org/debian bookworm InRelease« wurde der »Version«-Wert von »12.14« in »12.15« geändert. W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://apt.grafana.com stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details. W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://packages.grafana.com/oss/deb stable InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com> W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B W: GPG-Fehler: https://repos.influxdata.com/debian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY DA61C26A0585BD3B E: Das Depot »https://repos.influxdata.com/debian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). pi@Homee:~ $ sudo apt full-upgrade Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paketaktualisierung (Upgrade) wird berechnet… Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libbasicusageenvironment1 libc++1-16 libc++abi1-16 libcamera0.2 libcamera0.3 libcamera0.4 libgroupsock8 liblivemedia77 libqt5qmlworkerscript5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libunwind-16 libwlroots12 libwpe-1.0-1 libwpebackend-fdo-1.0-1 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-headers-6.6.28+rpt-common-rpi linux-headers-6.6.31+rpt-common-rpi linux-headers-6.6.47+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-kbuild-6.6.20+rpt linux-kbuild-6.6.28+rpt linux-kbuild-6.6.31+rpt linux-kbuild-6.6.47+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt lxplug-network python3-gi-cairo python3-v4l2 qml-module-qtgraphicaleffects qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. Die folgenden NEUEN Pakete werden installiert: libxcb-cursor0 linux-headers-6.12.96+rpt-common-rpi linux-headers-6.12.96+rpt-rpi-2712 linux-headers-6.12.96+rpt-rpi-v8 linux-image-6.12.96+rpt-rpi-2712 linux-image-6.12.96+rpt-rpi-v8 linux-kbuild-6.12.96+rpt Die folgenden Pakete werden aktualisiert (Upgrade): base-files bluez ca-certificates chromium chromium-browser chromium-browser-l10n chromium-common chromium-l10n chromium-sandbox curl gir1.2-gtk-3.0 gtk-update-icon-cache hplip hplip-data imagemagick-6-common libappstream4 libarchive13 libbluetooth3 libcaca0 libcurl3-gnutls libcurl4 libegl-mesa0 libexpat1 libexpat1-dev libgbm1 libgd3 libgif-dev libgif7 libgl1-mesa-dev libgl1-mesa-dri libglapi-mesa libglx-mesa0 libgraphite2-3 libgraphite2-dev libgtk-3-0 libgtk-3-common libhpmud0 libjavascriptcoregtk-4.1-0 liblzma-dev liblzma5 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6 libnfs13 libnss3 libpam-chksshpwd libpam-modules libpam-modules-bin libpam-runtime libpam0g libpam0g-dev libpoppler-cpp0v5 libpoppler-glib8 libpoppler126 libprotobuf-lite32 libprotobuf32 libpython3.11 libpython3.11-dev libpython3.11-minimal libpython3.11-stdlib librabbitmq4 libsane-hpaio libvncclient1 libwebkit2gtk-4.1-0 libxfont2 libxml2 libxmlb2 linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 linux-libc-dev mesa-libgallium mesa-vdpau-drivers mesa-vulkan-drivers p7zip p7zip-full poppler-utils printer-driver-hpcups printer-driver-postscript-hp python3-httplib2 python3-urllib3 python3.11 python3.11-dev python3.11-minimal python3.11-venv rpi-imager rsync unzip wireless-regdb xserver-common xserver-xorg-core xz-utils 93 aktualisiert, 7 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen 389 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 142 MB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://deb.debian.org/debian bookworm/main arm64 base-files arm64 12.4+deb12u15 [70,9 kB] Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g-dev arm64 1.5.2-6+rpt2+deb12u2 [168 kB] Holen:3 http://deb.debian.org/debian bookworm/main arm64 liblzma-dev arm64 5.4.1-1+deb12u1 [256 kB] Holen:4 http://deb.debian.org/debian bookworm/main arm64 liblzma5 arm64 5.4.1-1+deb12u1 [200 kB] Holen:5 http://deb.debian.org/debian bookworm/main arm64 libxml2 arm64 2.9.14+dfsg-1.3~deb12u6 [620 kB] Holen:6 http://deb.debian.org/debian-security bookworm-security/main arm64 imagemagick-6-common all 8:6.9.11.60+dfsg-1.6+deb12u13 [175 kB] Holen:7 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickcore-6.q16-6 arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [1.606 kB] Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam0g arm64 1.5.2-6+rpt2+deb12u2 [104 kB] Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules-bin arm64 1.5.2-6+rpt2+deb12u2 [100 kB] Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-modules arm64 1.5.2-6+rpt2+deb12u2 [405 kB] Holen:11 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickwand-6.q16-6 arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [359 kB] Holen:12 http://deb.debian.org/debian-security bookworm-security/main arm64 libexpat1-dev arm64 2.5.0-1+deb12u3 [281 kB] Holen:13 http://deb.debian.org/debian-security bookworm-security/main arm64 libexpat1 arm64 2.5.0-1+deb12u3 [87,9 kB] Holen:14 http://deb.debian.org/debian bookworm/main arm64 python3.11-dev arm64 3.11.2-6+deb12u8 [621 kB] Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 bluez arm64 5.66-1+rpt2+deb12u2 [1.619 kB] Holen:16 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-dev arm64 3.11.2-6+deb12u8 [4.394 kB] Holen:17 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-runtime all 1.5.2-6+rpt2+deb12u2 [209 kB] Holen:18 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-l10n all 1:151.0.7922.173-1~deb12u1+rpt1 [20,6 MB] Holen:19 http://deb.debian.org/debian bookworm/main arm64 libpython3.11 arm64 3.11.2-6+deb12u8 [1.841 kB] Holen:20 http://deb.debian.org/debian bookworm/main arm64 python3.11-venv arm64 3.11.2-6+deb12u8 [5.888 B] Holen:21 http://deb.debian.org/debian bookworm/main arm64 python3.11 arm64 3.11.2-6+deb12u8 [574 kB] Holen:22 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-stdlib arm64 3.11.2-6+deb12u8 [1.750 kB] Holen:23 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium arm64 1:151.0.7922.173-1~deb12u1+rpt1 [107 MB] Holen:24 http://deb.debian.org/debian bookworm/main arm64 python3.11-minimal arm64 3.11.2-6+deb12u8 [1.861 kB] Holen:25 http://deb.debian.org/debian bookworm/main arm64 libpython3.11-minimal arm64 3.11.2-6+deb12u8 [811 kB] Holen:26 http://deb.debian.org/debian bookworm/main arm64 rsync arm64 3.2.7-1+deb12u6 [405 kB] Holen:27 http://deb.debian.org/debian-security bookworm-security/main arm64 ca-certificates all 20250419~deb12u1 [162 kB] Holen:28 http://deb.debian.org/debian bookworm/main arm64 xz-utils arm64 5.4.1-1+deb12u1 [471 kB] Holen:29 http://deb.debian.org/debian-security bookworm-security/main arm64 libxfont2 arm64 1:2.0.6-1+deb12u1 [124 kB] Holen:30 http://deb.debian.org/debian-security bookworm-security/main arm64 libnss3 arm64 2:3.87.1-1+deb12u4 [1.216 kB] Holen:31 http://deb.debian.org/debian bookworm/main arm64 curl arm64 7.88.1-10+deb12u15 [310 kB] Holen:32 http://deb.debian.org/debian bookworm/main arm64 libcurl4 arm64 7.88.1-10+deb12u15 [367 kB] Holen:33 http://deb.debian.org/debian-security bookworm-security/main arm64 printer-driver-postscript-hp arm64 3.22.10+dfsg0-2+deb12u1 [1.212 kB] Holen:34 http://deb.debian.org/debian-security bookworm-security/main arm64 libsane-hpaio arm64 3.22.10+dfsg0-2+deb12u1 [134 kB] Holen:35 http://deb.debian.org/debian-security bookworm-security/main arm64 hplip arm64 3.22.10+dfsg0-2+deb12u1 [205 kB] Holen:36 http://deb.debian.org/debian-security bookworm-security/main arm64 libhpmud0 arm64 3.22.10+dfsg0-2+deb12u1 [106 kB] Holen:37 http://deb.debian.org/debian-security bookworm-security/main arm64 hplip-data all 3.22.10+dfsg0-2+deb12u1 [6.681 kB] Holen:38 http://deb.debian.org/debian-security bookworm-security/main arm64 printer-driver-hpcups arm64 3.22.10+dfsg0-2+deb12u1 [267 kB] Holen:39 http://deb.debian.org/debian bookworm/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u15 [362 kB] Holen:40 http://deb.debian.org/debian bookworm/main arm64 libxmlb2 arm64 0.3.22-1~deb12u1 [57,2 kB] Holen:41 http://deb.debian.org/debian bookworm/main arm64 libappstream4 arm64 0.16.1-2+b1 [183 kB] Holen:42 http://deb.debian.org/debian-security bookworm-security/main arm64 libarchive13 arm64 3.6.2-1+deb12u5 [318 kB] Holen:43 http://deb.debian.org/debian bookworm/main arm64 libcaca0 arm64 0.99.beta20-3+deb12u1 [196 kB] Holen:44 http://deb.debian.org/debian-security bookworm-security/main arm64 libgd3 arm64 2.3.3-9+deb12u1 [113 kB] Holen:45 http://deb.debian.org/debian bookworm/main arm64 libgif-dev arm64 5.2.1-2.5+deb12u1 [45,9 kB] Holen:46 http://deb.debian.org/debian bookworm/main arm64 libgif7 arm64 5.2.1-2.5+deb12u1 [42,6 kB] Holen:47 http://deb.debian.org/debian bookworm/main arm64 libgraphite2-dev arm64 1.3.14-1+deb12u1 [19,8 kB] Holen:48 http://deb.debian.org/debian bookworm/main arm64 libgraphite2-3 arm64 1.3.14-1+deb12u1 [68,7 kB] Holen:49 http://deb.debian.org/debian bookworm/main arm64 libwebkit2gtk-4.1-0 arm64 2.50.6-1~deb12u2 [20,9 MB] Holen:50 http://deb.debian.org/debian bookworm/main arm64 libjavascriptcoregtk-4.1-0 arm64 2.50.6-1~deb12u2 [6.244 kB] Holen:51 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-common arm64 1:151.0.7922.173-1~deb12u1+rpt1 [43,0 MB] Holen:52 http://deb.debian.org/debian-security bookworm-security/main arm64 libmagickcore-6.q16-6-extra arm64 8:6.9.11.60+dfsg-1.6+deb12u13 [177 kB] Holen:53 http://deb.debian.org/debian-security bookworm-security/main arm64 libnfs13 arm64 4.0.0-1+deb12u1 [94,1 kB] Holen:54 http://deb.debian.org/debian-security bookworm-security/main arm64 poppler-utils arm64 22.12.0-2+deb12u3 [177 kB] Holen:55 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler-glib8 arm64 22.12.0-2+deb12u3 [123 kB] Holen:56 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler-cpp0v5 arm64 22.12.0-2+deb12u3 [39,8 kB] Holen:57 http://deb.debian.org/debian-security bookworm-security/main arm64 libpoppler126 arm64 22.12.0-2+deb12u3 [1.753 kB] Holen:58 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-sandbox arm64 1:151.0.7922.173-1~deb12u1+rpt1 [149 kB] Holen:59 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-common all 2:21.1.7-3+rpt3+deb12u13 [2.388 kB] Holen:60 http://archive.raspberrypi.com/debian bookworm/main arm64 xserver-xorg-core arm64 2:21.1.7-3+rpt3+deb12u13 [4.049 kB] Holen:61 http://archive.raspberrypi.com/debian bookworm/main arm64 libgl1-mesa-dri arm64 24.2.8-1~bpo12+rpt5 [55,0 kB] Holen:62 http://archive.raspberrypi.com/debian bookworm/main arm64 libglx-mesa0 arm64 24.2.8-1~bpo12+rpt5 [204 kB] Holen:63 http://deb.debian.org/debian bookworm/main arm64 libprotobuf-lite32 arm64 3.21.12-3+deb12u1 [241 kB] Holen:64 http://archive.raspberrypi.com/debian bookworm/main arm64 libegl-mesa0 arm64 24.2.8-1~bpo12+rpt5 [162 kB] Holen:65 http://archive.raspberrypi.com/debian bookworm/main arm64 libgbm1 arm64 24.2.8-1~bpo12+rpt5 [49,5 kB] Holen:66 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-libgallium arm64 24.2.8-1~bpo12+rpt5 [11,1 MB] Holen:67 http://deb.debian.org/debian bookworm/main arm64 libprotobuf32 arm64 3.21.12-3+deb12u1 [822 kB] Holen:68 http://archive.raspberrypi.com/debian bookworm/main arm64 libglapi-mesa arm64 24.2.8-1~bpo12+rpt5 [77,4 kB] Holen:69 http://archive.raspberrypi.com/debian bookworm/main arm64 libgtk-3-common all 1:3.24.38-2~deb12u3+rpi1+rpt1 [8.917 kB] Holen:70 http://archive.raspberrypi.com/debian bookworm/main arm64 libgtk-3-0 arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [3.747 kB] Holen:71 http://deb.debian.org/debian-security bookworm-security/main arm64 librabbitmq4 arm64 0.11.0-1+deb12u3 [40,3 kB] Holen:72 http://deb.debian.org/debian bookworm/main arm64 libvncclient1 arm64 0.9.14+dfsg-1+deb12u2 [181 kB] Holen:73 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser all 1:151.0.7922.173-1~deb12u1+rpt1 [141 kB] Holen:74 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser-l10n all 1:151.0.7922.173-1~deb12u1+rpt1 [141 kB] Holen:75 http://archive.raspberrypi.com/debian bookworm/main arm64 gir1.2-gtk-3.0 arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [302 kB] Holen:76 http://archive.raspberrypi.com/debian bookworm/main arm64 gtk-update-icon-cache arm64 1:3.24.38-2~deb12u3+rpi1+rpt1 [50,1 kB] Holen:77 http://deb.debian.org/debian bookworm/main arm64 libxcb-cursor0 arm64 0.1.4-1 [16,6 kB] Holen:78 http://archive.raspberrypi.com/debian bookworm/main arm64 libbluetooth3 arm64 5.66-1+rpt2+deb12u2 [129 kB] Holen:79 http://deb.debian.org/debian-security bookworm-security/main arm64 p7zip-full arm64 16.02+really26.02+dfsg-0+deb12u1 [1.284 kB] Holen:80 http://archive.raspberrypi.com/debian bookworm/main arm64 libgl1-mesa-dev arm64 24.2.8-1~bpo12+rpt5 [20,1 kB] Holen:81 http://archive.raspberrypi.com/debian bookworm/main arm64 libpam-chksshpwd arm64 1.5.2-6+rpt2+deb12u2 [47,7 kB] Holen:82 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-common-rpi all 1:6.12.96-1+rpt1 [8.772 kB] Holen:83 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.96+rpt-rpi-2712 arm64 1:6.12.96-1+rpt1 [32,7 MB] Holen:84 http://deb.debian.org/debian-security bookworm-security/main arm64 p7zip arm64 16.02+really26.02+dfsg-0+deb12u1 [403 kB] Holen:85 http://deb.debian.org/debian-security bookworm-security/main arm64 python3-httplib2 all 0.20.4-3+deb12u1 [39,0 kB] Holen:86 http://deb.debian.org/debian bookworm/main arm64 python3-urllib3 all 1.26.12-1+deb12u4 [114 kB] Holen:87 http://deb.debian.org/debian-security bookworm-security/main arm64 unzip arm64 6.0-28+deb12u1 [158 kB] Holen:88 http://deb.debian.org/debian bookworm/main arm64 wireless-regdb all 2026.05.30-1~deb12u1 [12,6 kB] Holen:89 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-6.12.96+rpt arm64 1:6.12.96-1+rpt1 [1.194 kB] Holen:90 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.347 kB] Holen:91 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.96+rpt-rpi-v8 arm64 1:6.12.96-1+rpt1 [32,7 MB] Holen:92 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.96+rpt-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.347 kB] Holen:93 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.160 B] Holen:94 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.160 B] Holen:95 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-2712 arm64 1:6.12.96-1+rpt1 [1.428 B] Holen:96 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-v8 arm64 1:6.12.96-1+rpt1 [1.432 B] Holen:97 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-dev all 1:6.12.96-1+rpt1 [2.315 kB] Holen:98 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-vdpau-drivers arm64 24.2.8-1~bpo12+rpt5 [20,7 kB] Holen:99 http://archive.raspberrypi.com/debian bookworm/main arm64 mesa-vulkan-drivers arm64 24.2.8-1~bpo12+rpt5 [9.287 kB] Holen:100 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-imager arm64 2.0.11-1 [33,2 MB] Es wurden 389 MB in 29 s geholt (13,2 MB/s). Changelogs werden gelesen... Fertig Extrahiere Vorlagen aus Paketen: 100% Vorkonfiguration der Pakete ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../base-files_12.4+deb12u15_arm64.deb ... Entpacken von base-files (12.4+deb12u15) über (12.4+deb12u14) ... base-files (12.4+deb12u15) wird eingerichtet ... Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam0g-dev_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam0g-dev:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... Vorbereitung zum Entpacken von .../libpam0g_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam0g:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam0g:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules-bin_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-modules-bin (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-modules-bin (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-modules:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-modules:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../bluez_5.66-1+rpt2+deb12u2_arm64.deb ... Entpacken von bluez (5.66-1+rpt2+deb12u2) über (5.66-1+rpt1+deb12u2) ... Vorbereitung zum Entpacken von .../liblzma-dev_5.4.1-1+deb12u1_arm64.deb ... Entpacken von liblzma-dev:arm64 (5.4.1-1+deb12u1) über (5.4.1-1) ... Vorbereitung zum Entpacken von .../liblzma5_5.4.1-1+deb12u1_arm64.deb ... Entpacken von liblzma5:arm64 (5.4.1-1+deb12u1) über (5.4.1-1) ... liblzma5:arm64 (5.4.1-1+deb12u1) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../00-libxml2_2.9.14+dfsg-1.3~deb12u6_arm64.deb ... Entpacken von libxml2:arm64 (2.9.14+dfsg-1.3~deb12u6) über (2.9.14+dfsg-1.3~deb12u5) ... Vorbereitung zum Entpacken von .../01-imagemagick-6-common_8%3a6.9.11.60+dfsg-1.6+deb12u13_all.deb ... Entpacken von imagemagick-6-common (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../02-libmagickcore-6.q16-6_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickcore-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../03-libmagickwand-6.q16-6_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickwand-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../04-libexpat1-dev_2.5.0-1+deb12u3_arm64.deb ... Entpacken von libexpat1-dev:arm64 (2.5.0-1+deb12u3) über (2.5.0-1+deb12u2) ... Vorbereitung zum Entpacken von .../05-libexpat1_2.5.0-1+deb12u3_arm64.deb ... Entpacken von libexpat1:arm64 (2.5.0-1+deb12u3) über (2.5.0-1+deb12u2) ... Vorbereitung zum Entpacken von .../06-python3.11-dev_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-dev (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../07-libpython3.11-dev_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-dev:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../08-libpython3.11_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../09-python3.11-venv_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-venv (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../10-python3.11_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../11-libpython3.11-stdlib_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-stdlib:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../12-python3.11-minimal_3.11.2-6+deb12u8_arm64.deb ... Entpacken von python3.11-minimal (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../13-libpython3.11-minimal_3.11.2-6+deb12u8_arm64.deb ... Entpacken von libpython3.11-minimal:arm64 (3.11.2-6+deb12u8) über (3.11.2-6+deb12u7) ... Vorbereitung zum Entpacken von .../14-rsync_3.2.7-1+deb12u6_arm64.deb ... Entpacken von rsync (3.2.7-1+deb12u6) über (3.2.7-1+deb12u5) ... Vorbereitung zum Entpacken von .../15-libpam-runtime_1.5.2-6+rpt2+deb12u2_all.deb ... Entpacken von libpam-runtime (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... libpam-runtime (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... (Lese Datenbank ... 251946 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../00-ca-certificates_20250419~deb12u1_all.deb ... Entpacken von ca-certificates (20250419~deb12u1) über (20230311+deb12u1) ... Vorbereitung zum Entpacken von .../01-xz-utils_5.4.1-1+deb12u1_arm64.deb ... Entpacken von xz-utils (5.4.1-1+deb12u1) über (5.4.1-1) ... Vorbereitung zum Entpacken von .../02-chromium-l10n_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-l10n (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../03-chromium_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../04-chromium-common_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium-common (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../05-chromium-sandbox_1%3a151.0.7922.173-1~deb12u1+rpt1_arm64.deb ... Entpacken von chromium-sandbox (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../06-xserver-common_2%3a21.1.7-3+rpt3+deb12u13_all.deb ... Entpacken von xserver-common (2:21.1.7-3+rpt3+deb12u13) über (2:21.1.7-3+rpt3+deb12u12) ... Vorbereitung zum Entpacken von .../07-libxfont2_1%3a2.0.6-1+deb12u1_arm64.deb ... Entpacken von libxfont2:arm64 (1:2.0.6-1+deb12u1) über (1:2.0.6-1) ... Vorbereitung zum Entpacken von .../08-xserver-xorg-core_2%3a21.1.7-3+rpt3+deb12u13_arm64.deb ... Entpacken von xserver-xorg-core (2:21.1.7-3+rpt3+deb12u13) über (2:21.1.7-3+rpt3+deb12u12) ... Vorbereitung zum Entpacken von .../09-libgl1-mesa-dri_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgl1-mesa-dri:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../10-libglx-mesa0_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libglx-mesa0:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../11-libegl-mesa0_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libegl-mesa0:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../12-libgbm1_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgbm1:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../13-mesa-libgallium_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-libgallium:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../14-libglapi-mesa_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libglapi-mesa:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../15-libnss3_2%3a3.87.1-1+deb12u4_arm64.deb ... Entpacken von libnss3:arm64 (2:3.87.1-1+deb12u4) über (2:3.87.1-1+deb12u2) ... Vorbereitung zum Entpacken von .../16-libgtk-3-common_1%3a3.24.38-2~deb12u3+rpi1+rpt1_all.deb ... Entpacken von libgtk-3-common (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../17-libgtk-3-0_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von libgtk-3-0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../18-chromium-browser_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-browser (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../19-chromium-browser-l10n_1%3a151.0.7922.173-1~deb12u1+rpt1_all.deb ... Entpacken von chromium-browser-l10n (1:151.0.7922.173-1~deb12u1+rpt1) über (1:149.0.7827.102-1~deb12u1+rpt1) ... Vorbereitung zum Entpacken von .../20-curl_7.88.1-10+deb12u15_arm64.deb ... Entpacken von curl (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../21-libcurl4_7.88.1-10+deb12u15_arm64.deb ... Entpacken von libcurl4:arm64 (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../22-gir1.2-gtk-3.0_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von gir1.2-gtk-3.0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../23-gtk-update-icon-cache_1%3a3.24.38-2~deb12u3+rpi1+rpt1_arm64.deb ... Entpacken von gtk-update-icon-cache (1:3.24.38-2~deb12u3+rpi1+rpt1) über (1:3.24.38-2~deb12u2+rpt7+rpi1) ... Vorbereitung zum Entpacken von .../24-printer-driver-postscript-hp_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von printer-driver-postscript-hp (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../25-libsane-hpaio_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von libsane-hpaio:arm64 (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../26-hplip_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von hplip (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../27-libhpmud0_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von libhpmud0:arm64 (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../28-hplip-data_3.22.10+dfsg0-2+deb12u1_all.deb ... Entpacken von hplip-data (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../29-printer-driver-hpcups_3.22.10+dfsg0-2+deb12u1_arm64.deb ... Entpacken von printer-driver-hpcups (3.22.10+dfsg0-2+deb12u1) über (3.22.10+dfsg0-2) ... Vorbereitung zum Entpacken von .../30-libcurl3-gnutls_7.88.1-10+deb12u15_arm64.deb ... Entpacken von libcurl3-gnutls:arm64 (7.88.1-10+deb12u15) über (7.88.1-10+deb12u14) ... Vorbereitung zum Entpacken von .../31-libxmlb2_0.3.22-1~deb12u1_arm64.deb ... Entpacken von libxmlb2:arm64 (0.3.22-1~deb12u1) über (0.3.10-2) ... Vorbereitung zum Entpacken von .../32-libappstream4_0.16.1-2+b1_arm64.deb ... Entpacken von libappstream4:arm64 (0.16.1-2+b1) über (0.16.1-2) ... Vorbereitung zum Entpacken von .../33-libarchive13_3.6.2-1+deb12u5_arm64.deb ... Entpacken von libarchive13:arm64 (3.6.2-1+deb12u5) über (3.6.2-1+deb12u4) ... Vorbereitung zum Entpacken von .../34-libbluetooth3_5.66-1+rpt2+deb12u2_arm64.deb ... Entpacken von libbluetooth3:arm64 (5.66-1+rpt2+deb12u2) über (5.66-1+rpt1+deb12u2) ... Vorbereitung zum Entpacken von .../35-libcaca0_0.99.beta20-3+deb12u1_arm64.deb ... Entpacken von libcaca0:arm64 (0.99.beta20-3+deb12u1) über (0.99.beta20-3) ... Vorbereitung zum Entpacken von .../36-libgd3_2.3.3-9+deb12u1_arm64.deb ... Entpacken von libgd3:arm64 (2.3.3-9+deb12u1) über (2.3.3-9) ... Vorbereitung zum Entpacken von .../37-libgif-dev_5.2.1-2.5+deb12u1_arm64.deb ... Entpacken von libgif-dev:arm64 (5.2.1-2.5+deb12u1) über (5.2.1-2.5) ... Vorbereitung zum Entpacken von .../38-libgif7_5.2.1-2.5+deb12u1_arm64.deb ... Entpacken von libgif7:arm64 (5.2.1-2.5+deb12u1) über (5.2.1-2.5) ... Vorbereitung zum Entpacken von .../39-libgl1-mesa-dev_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von libgl1-mesa-dev:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../40-libgraphite2-dev_1.3.14-1+deb12u1_arm64.deb ... Entpacken von libgraphite2-dev:arm64 (1.3.14-1+deb12u1) über (1.3.14-1) ... Vorbereitung zum Entpacken von .../41-libgraphite2-3_1.3.14-1+deb12u1_arm64.deb ... Entpacken von libgraphite2-3:arm64 (1.3.14-1+deb12u1) über (1.3.14-1) ... Vorbereitung zum Entpacken von .../42-libwebkit2gtk-4.1-0_2.50.6-1~deb12u2_arm64.deb ... Entpacken von libwebkit2gtk-4.1-0:arm64 (2.50.6-1~deb12u2) über (2.50.6-1~deb12u1) ... Vorbereitung zum Entpacken von .../43-libjavascriptcoregtk-4.1-0_2.50.6-1~deb12u2_arm64.deb ... Entpacken von libjavascriptcoregtk-4.1-0:arm64 (2.50.6-1~deb12u2) über (2.50.6-1~deb12u1) ... Vorbereitung zum Entpacken von .../44-libmagickcore-6.q16-6-extra_8%3a6.9.11.60+dfsg-1.6+deb12u13_arm64.deb ... Entpacken von libmagickcore-6.q16-6-extra:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) über (8:6.9.11.60+dfsg-1.6+deb12u10) ... Vorbereitung zum Entpacken von .../45-libnfs13_4.0.0-1+deb12u1_arm64.deb ... Entpacken von libnfs13:arm64 (4.0.0-1+deb12u1) über (4.0.0-1) ... Vorbereitung zum Entpacken von .../46-libpam-chksshpwd_1.5.2-6+rpt2+deb12u2_arm64.deb ... Entpacken von libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u2) über (1.5.2-6+rpt2+deb12u1) ... Vorbereitung zum Entpacken von .../47-poppler-utils_22.12.0-2+deb12u3_arm64.deb ... Entpacken von poppler-utils (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../48-libpoppler-glib8_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler-glib8:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../49-libpoppler-cpp0v5_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler-cpp0v5:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../50-libpoppler126_22.12.0-2+deb12u3_arm64.deb ... Entpacken von libpoppler126:arm64 (22.12.0-2+deb12u3) über (22.12.0-2+deb12u2) ... Vorbereitung zum Entpacken von .../51-libprotobuf-lite32_3.21.12-3+deb12u1_arm64.deb ... Entpacken von libprotobuf-lite32:arm64 (3.21.12-3+deb12u1) über (3.21.12-3) ... Vorbereitung zum Entpacken von .../52-libprotobuf32_3.21.12-3+deb12u1_arm64.deb ... Entpacken von libprotobuf32:arm64 (3.21.12-3+deb12u1) über (3.21.12-3) ... Vorbereitung zum Entpacken von .../53-librabbitmq4_0.11.0-1+deb12u3_arm64.deb ... Entpacken von librabbitmq4:arm64 (0.11.0-1+deb12u3) über (0.11.0-1+deb12u1) ... Vorbereitung zum Entpacken von .../54-libvncclient1_0.9.14+dfsg-1+deb12u2_arm64.deb ... Entpacken von libvncclient1:arm64 (0.9.14+dfsg-1+deb12u2) über (0.9.14+dfsg-1+deb12u1) ... Vormals nicht ausgewähltes Paket libxcb-cursor0:arm64 wird gewählt. Vorbereitung zum Entpacken von .../55-libxcb-cursor0_0.1.4-1_arm64.deb ... Entpacken von libxcb-cursor0:arm64 (0.1.4-1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-common-rpi wird gewählt. Vorbereitung zum Entpacken von .../56-linux-headers-6.12.96+rpt-common-rpi_1%3a6.12.96-1+rpt1_all.deb ... Entpacken von linux-headers-6.12.96+rpt-common-rpi (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-image-6.12.96+rpt-rpi-2712 wird gewählt. Vorbereitung zum Entpacken von .../57-linux-image-6.12.96+rpt-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-kbuild-6.12.96+rpt wird gewählt. Vorbereitung zum Entpacken von .../58-linux-kbuild-6.12.96+rpt_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-kbuild-6.12.96+rpt (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-rpi-2712 wird gewählt. Vorbereitung zum Entpacken von .../59-linux-headers-6.12.96+rpt-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-image-6.12.96+rpt-rpi-v8 wird gewählt. Vorbereitung zum Entpacken von .../60-linux-image-6.12.96+rpt-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) ... Vormals nicht ausgewähltes Paket linux-headers-6.12.96+rpt-rpi-v8 wird gewählt. Vorbereitung zum Entpacken von .../61-linux-headers-6.12.96+rpt-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) ... Vorbereitung zum Entpacken von .../62-linux-headers-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-rpi-2712 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../63-linux-headers-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-headers-rpi-v8 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../64-linux-image-rpi-2712_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-rpi-2712 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../65-linux-image-rpi-v8_1%3a6.12.96-1+rpt1_arm64.deb ... Entpacken von linux-image-rpi-v8 (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../66-linux-libc-dev_1%3a6.12.96-1+rpt1_all.deb ... Entpacken von linux-libc-dev (1:6.12.96-1+rpt1) über (1:6.12.87-1+rpt1~bookworm) ... Vorbereitung zum Entpacken von .../67-mesa-vdpau-drivers_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-vdpau-drivers:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../68-mesa-vulkan-drivers_24.2.8-1~bpo12+rpt5_arm64.deb ... Entpacken von mesa-vulkan-drivers:arm64 (24.2.8-1~bpo12+rpt5) über (24.2.8-1~bpo12+rpt4) ... Vorbereitung zum Entpacken von .../69-p7zip-full_16.02+really26.02+dfsg-0+deb12u1_arm64.deb ... Entpacken von p7zip-full (16.02+really26.02+dfsg-0+deb12u1) über (16.02+really25.01+dfsg-0+deb12u1) ... Vorbereitung zum Entpacken von .../70-p7zip_16.02+really26.02+dfsg-0+deb12u1_arm64.deb ... Entpacken von p7zip (16.02+really26.02+dfsg-0+deb12u1) über (16.02+really25.01+dfsg-0+deb12u1) ... Vorbereitung zum Entpacken von .../71-python3-httplib2_0.20.4-3+deb12u1_all.deb ... Entpacken von python3-httplib2 (0.20.4-3+deb12u1) über (0.20.4-3) ... Vorbereitung zum Entpacken von .../72-python3-urllib3_1.26.12-1+deb12u4_all.deb ... Entpacken von python3-urllib3 (1.26.12-1+deb12u4) über (1.26.12-1+deb12u3) ... Vorbereitung zum Entpacken von .../73-rpi-imager_2.0.11-1_arm64.deb ... Entpacken von rpi-imager (2.0.11-1) über (2.0.6) ... Vorbereitung zum Entpacken von .../74-unzip_6.0-28+deb12u1_arm64.deb ... Entpacken von unzip (6.0-28+deb12u1) über (6.0-28) ... Vorbereitung zum Entpacken von .../75-wireless-regdb_2026.05.30-1~deb12u1_all.deb ... Entpacken von wireless-regdb (2026.05.30-1~deb12u1) über (2026.02.04-1~deb12u1) ... libexpat1:arm64 (2.5.0-1+deb12u3) wird eingerichtet ... libgraphite2-3:arm64 (1.3.14-1+deb12u1) wird eingerichtet ... mesa-vulkan-drivers:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... mesa-vdpau-drivers:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... gtk-update-icon-cache (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... librabbitmq4:arm64 (0.11.0-1+deb12u3) wird eingerichtet ... imagemagick-6-common (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... Neue Version der Konfigurationsdatei /etc/ImageMagick-6/policy.xml wird installiert ... libcaca0:arm64 (0.99.beta20-3+deb12u1) wird eingerichtet ... libpam0g-dev:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... libxmlb2:arm64 (0.3.22-1~deb12u1) wird eingerichtet ... unzip (6.0-28+deb12u1) wird eingerichtet ... wireless-regdb (2026.05.30-1~deb12u1) wird eingerichtet ... linux-libc-dev (1:6.12.96-1+rpt1) wird eingerichtet ... libcurl3-gnutls:arm64 (7.88.1-10+deb12u15) wird eingerichtet ... libnss3:arm64 (2:3.87.1-1+deb12u4) wird eingerichtet ... libnfs13:arm64 (4.0.0-1+deb12u1) wird eingerichtet ... chromium-sandbox (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... libpam-chksshpwd:arm64 (1.5.2-6+rpt2+deb12u2) wird eingerichtet ... libvncclient1:arm64 (0.9.14+dfsg-1+deb12u2) wird eingerichtet ... ca-certificates (20250419~deb12u1) wird eingerichtet ... Updating certificates in /etc/ssl/certs... rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL 21 added, 13 removed; done. bluez (5.66-1+rpt2+deb12u2) wird eingerichtet ... libgraphite2-dev:arm64 (1.3.14-1+deb12u1) wird eingerichtet ... libjavascriptcoregtk-4.1-0:arm64 (2.50.6-1~deb12u2) wird eingerichtet ... libexpat1-dev:arm64 (2.5.0-1+deb12u3) wird eingerichtet ... libxcb-cursor0:arm64 (0.1.4-1) wird eingerichtet ... xz-utils (5.4.1-1+deb12u1) wird eingerichtet ... linux-image-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.12.96+rpt-rpi-v8 '/boot/initrd.img-6.12.96+rpt-rpi-v8' -> '/boot/firmware/initramfs8' /etc/kernel/postinst.d/z50-raspi-firmware: '/boot/vmlinuz-6.12.96+rpt-rpi-v8' -> '/boot/firmware/kernel8.img' libgd3:arm64 (2.3.3-9+deb12u1) wird eingerichtet ... linux-image-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... libpoppler126:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libglapi-mesa:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... python3-urllib3 (1.26.12-1+deb12u4) wird eingerichtet ... liblzma-dev:arm64 (5.4.1-1+deb12u1) wird eingerichtet ... libgif7:arm64 (5.2.1-2.5+deb12u1) wird eingerichtet ... libprotobuf32:arm64 (3.21.12-3+deb12u1) wird eingerichtet ... libgif-dev:arm64 (5.2.1-2.5+deb12u1) wird eingerichtet ... libbluetooth3:arm64 (5.66-1+rpt2+deb12u2) wird eingerichtet ... libgl1-mesa-dev:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... python3-httplib2 (0.20.4-3+deb12u1) wird eingerichtet ... libprotobuf-lite32:arm64 (3.21.12-3+deb12u1) wird eingerichtet ... libcurl4:arm64 (7.88.1-10+deb12u15) wird eingerichtet ... chromium-common (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... libpython3.11-minimal:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... curl (7.88.1-10+deb12u15) wird eingerichtet ... poppler-utils (22.12.0-2+deb12u3) wird eingerichtet ... xserver-common (2:21.1.7-3+rpt3+deb12u13) wird eingerichtet ... linux-image-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.12.96+rpt-rpi-2712 '/boot/initrd.img-6.12.96+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712' /etc/kernel/postinst.d/z50-raspi-firmware: '/boot/vmlinuz-6.12.96+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img' linux-kbuild-6.12.96+rpt (1:6.12.96-1+rpt1) wird eingerichtet ... libpoppler-cpp0v5:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libhpmud0:arm64 (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... libxfont2:arm64 (1:2.0.6-1+deb12u1) wird eingerichtet ... libxml2:arm64 (2.9.14+dfsg-1.3~deb12u6) wird eingerichtet ... linux-headers-6.12.96+rpt-common-rpi (1:6.12.96-1+rpt1) wird eingerichtet ... libsane-hpaio:arm64 (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... p7zip (16.02+really26.02+dfsg-0+deb12u1) wird eingerichtet ... libgtk-3-common (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... rsync (3.2.7-1+deb12u6) wird eingerichtet ... rsync.service is a disabled or a static unit not running, not starting it. python3.11-minimal (3.11.2-6+deb12u8) wird eingerichtet ... mesa-libgallium:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libpoppler-glib8:arm64 (22.12.0-2+deb12u3) wird eingerichtet ... libgbm1:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libarchive13:arm64 (3.6.2-1+deb12u5) wird eingerichtet ... linux-headers-6.12.96+rpt-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libpython3.11-stdlib:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... libgl1-mesa-dri:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... xserver-xorg-core (2:21.1.7-3+rpt3+deb12u13) wird eingerichtet ... hplip-data (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... p7zip-full (16.02+really26.02+dfsg-0+deb12u1) wird eingerichtet ... libappstream4:arm64 (0.16.1-2+b1) wird eingerichtet ... printer-driver-postscript-hp (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... linux-image-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libmagickcore-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... libegl-mesa0:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... linux-headers-6.12.96+rpt-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... linux-headers-rpi-2712 (1:6.12.96-1+rpt1) wird eingerichtet ... libmagickwand-6.q16-6:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... rpi-imager (2.0.11-1) wird eingerichtet ... printer-driver-hpcups (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... chromium (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... linux-headers-rpi-v8 (1:6.12.96-1+rpt1) wird eingerichtet ... python3.11 (3.11.2-6+deb12u8) wird eingerichtet ... libglx-mesa0:arm64 (24.2.8-1~bpo12+rpt5) wird eingerichtet ... libpython3.11:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... libmagickcore-6.q16-6-extra:arm64 (8:6.9.11.60+dfsg-1.6+deb12u13) wird eingerichtet ... python3.11-venv (3.11.2-6+deb12u8) wird eingerichtet ... libpython3.11-dev:arm64 (3.11.2-6+deb12u8) wird eingerichtet ... chromium-l10n (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... chromium-browser (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... chromium-browser-l10n (1:151.0.7922.173-1~deb12u1+rpt1) wird eingerichtet ... hplip (3.22.10+dfsg0-2+deb12u1) wird eingerichtet ... Creating/updating hplip user account... python3.11-dev (3.11.2-6+deb12u8) wird eingerichtet ... Trigger für libc-bin (2.36-9+rpt2+deb12u14) werden verarbeitet ... Trigger für systemd (252.39-1~deb12u2) werden verarbeitet ... Trigger für man-db (2.11.2-2) werden verarbeitet ... Trigger für dbus (1.14.10-1~deb12u1) werden verarbeitet ... Trigger für shared-mime-info (2.2-1) werden verarbeitet ... Trigger für mailcap (3.70+nmu1) werden verarbeitet ... Trigger für desktop-file-utils (0.26-1) werden verarbeitet ... Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ... Trigger für cups (2.4.2-3+deb12u9) werden verarbeitet ... Trigger für gnome-menus (3.36.0-1.1) werden verarbeitet ... Trigger für libglib2.0-0:arm64 (2.74.6-2+deb12u9) werden verarbeitet ... libgtk-3-0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... gir1.2-gtk-3.0:arm64 (1:3.24.38-2~deb12u3+rpi1+rpt1) wird eingerichtet ... libwebkit2gtk-4.1-0:arm64 (2.50.6-1~deb12u2) wird eingerichtet ... Trigger für ca-certificates (20250419~deb12u1) werden verarbeitet ... Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done. Running hooks in /etc/ca-certificates/update.d... done. Trigger für libc-bin (2.36-9+rpt2+deb12u14) werden verarbeitet ...Joh, akuter Pflege-Notstand. Und eine Graphische Oberfläche ist da auch installiert.
Zum Hieven:https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
Das habe ich jetzt gemacht:
pi@Homee:~ $ sudo rm /etc/apt/sources.list.d/grafana* sudo rm /etc/apt/keyrings/grafana* sudo apt-get install -y wget gnupg sudo mkdir -p /etc/apt/keyrings/ sudo wget -O /etc/apt/keyrings/grafana.asc https://apt.grafana.com/gpg-full.key sudo chmod 644 /etc/apt/keyrings/grafana.asc echo "deb [signed-by=/etc/apt/keyrings/grafana.asc] https://apt.grafana.com stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list sudo apt-get update sudo apt-get install grafana Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig wget ist schon die neueste Version (1.21.3-1+deb12u1). gnupg ist schon die neueste Version (2.2.40-1.1+deb12u2). Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libbasicusageenvironment1 libc++1-16 libc++abi1-16 libcamera0.2 libcamera0.3 libcamera0.4 libgroupsock8 liblivemedia77 libqt5qmlworkerscript5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libunwind-16 libwlroots12 libwpe-1.0-1 libwpebackend-fdo-1.0-1 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-headers-6.12.75+rpt-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-headers-6.6.28+rpt-common-rpi linux-headers-6.6.31+rpt-common-rpi linux-headers-6.6.47+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-kbuild-6.12.75+rpt linux-kbuild-6.6.20+rpt linux-kbuild-6.6.28+rpt linux-kbuild-6.6.31+rpt linux-kbuild-6.6.47+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt lxplug-network musl python3-gi-cairo python3-v4l2 qml-module-qtgraphicaleffects qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert. --2026-09-02 20:20:15-- https://apt.grafana.com/gpg-full.key Auflösen des Hostnamens apt.grafana.com (apt.grafana.com)… 2a04:4e42:8d::729, 146.75.118.217 Verbindungsaufbau zu apt.grafana.com (apt.grafana.com)|2a04:4e42:8d::729|:443 … verbunden. HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK Länge: 7881 (7,7K) [text/plain] Wird in »/etc/apt/keyrings/grafana.asc« gespeichert. /etc/apt/keyrings/grafana.asc 100%[========================================================================================================================================>] 7,70K --.-KB/s in 0,001s 2026-09-02 20:20:15 (10,3 MB/s) - »/etc/apt/keyrings/grafana.asc« gespeichert [7881/7881] deb [signed-by=/etc/apt/keyrings/grafana.asc] https://apt.grafana.com stable main OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease Holen:3 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] OK:4 http://archive.raspberrypi.com/debian bookworm InRelease OK:5 http://deb.debian.org/debian bookworm-updates InRelease OK:6 https://apt.grafana.com stable InRelease OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease Holen:8 https://repos.influxdata.com/debian stable InRelease [6.922 B] Fehl:3 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Paketlisten werden gelesen… Fertig W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig grafana ist schon die neueste Version (13.2.0). Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libbasicusageenvironment1 libc++1-16 libc++abi1-16 libcamera0.2 libcamera0.3 libcamera0.4 libgroupsock8 liblivemedia77 libqt5qmlworkerscript5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libunwind-16 libwlroots12 libwpe-1.0-1 libwpebackend-fdo-1.0-1 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-headers-6.12.75+rpt-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-headers-6.6.28+rpt-common-rpi linux-headers-6.6.31+rpt-common-rpi linux-headers-6.6.47+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-kbuild-6.12.75+rpt linux-kbuild-6.6.20+rpt linux-kbuild-6.6.28+rpt linux-kbuild-6.6.31+rpt linux-kbuild-6.6.47+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt lxplug-network musl python3-gi-cairo python3-v4l2 qml-module-qtgraphicaleffects qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert. pi@Homee:~ $ sudo rm /etc/apt/sources.list.d/influx* sudo rm /etc/apt/keyrings/influx* curl --silent --location -O https://repos.influxdata.com/influxdata-archive.key gpg --show-keys --with-fingerprint --with-colons ./influxdata-archive.key 2>&1 | grep -q '^fpr:\+24C975CBA61A024EE1B631787C3D57159FC2F927:$' && cat influxdata-archive.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive.gpg > /dev/null echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list rm influxdata-archive.key rm: das Entfernen von '/etc/apt/keyrings/influx*' ist nicht möglich: Datei oder Verzeichnis nicht gefunden deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable mainJetzt:
iob nodejs-update? -
iob nodejs-update?Sauber neugestartet? Da war ja ein Kernel-Update und sonstiges kritisches Zeug dabei.
Dann malsudo apt updatezeigen.
pi@Homee:~ $ sudo apt update OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease OK:3 http://deb.debian.org/debian bookworm-updates InRelease Holen:4 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] OK:5 https://apt.grafana.com stable InRelease Holen:6 https://repos.influxdata.com/debian stable InRelease [6.922 B] OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease OK:8 http://archive.raspberrypi.com/debian bookworm InRelease Fehl:4 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Paketlisten werden gelesen… Fertig W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). pi@Homee:~ $ -
pi@Homee:~ $ sudo apt update OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease OK:3 http://deb.debian.org/debian bookworm-updates InRelease Holen:4 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] OK:5 https://apt.grafana.com stable InRelease Holen:6 https://repos.influxdata.com/debian stable InRelease [6.922 B] OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease OK:8 http://archive.raspberrypi.com/debian bookworm InRelease Fehl:4 http://archive.raspbian.org/raspbian bookworm InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E Paketlisten werden gelesen… Fertig W: GPG-Fehler: http://archive.raspbian.org/raspbian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E E: Das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« ist nicht signiert. N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert. N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8). pi@Homee:~ $Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9165938D90FDDD2E
Versuch mal:
sudo gpg --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E sudo gpg --export 9165938D90FDDD2E | sudo tee /etc/apt/trusted.gpg.d/raspberrypi-archive-keyring.gpg > /dev/null sudo apt update -
pi@Homee:~ $ sudo gpg --keyserver keyserver.ubuntu.com --recv-keys 9165938D90FDDD2E gpg: /root/.gnupg/trustdb.gpg: trust-db erzeugt gpg: Schlüssel 9165938D90FDDD2E: Öffentlicher Schlüssel "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>" importiert gpg: Anzahl insgesamt bearbeiteter Schlüssel: 1 gpg: importiert: 1 pi@Homee:~ $ sudo gpg --export 9165938D90FDDD2E | sudo tee /etc/apt/trusted.gpg.d/raspberrypi-archive-keyring.gpg > /dev/null pi@Homee:~ $ sudo apt update OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease Holen:3 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] OK:4 http://archive.raspberrypi.com/debian bookworm InRelease OK:5 http://deb.debian.org/debian bookworm-updates InRelease OK:6 https://apt.grafana.com stable InRelease OK:7 https://deb.nodesource.com/node_22.x nodistro InRelease Holen:8 https://repos.influxdata.com/debian stable InRelease [6.922 B] Holen:9 http://archive.raspbian.org/raspbian bookworm/non-free Sources [150 kB] Holen:10 http://archive.raspbian.org/raspbian bookworm/contrib Sources [94,5 kB] Holen:11 http://archive.raspbian.org/raspbian bookworm/main Sources [13,8 MB] Holen:12 http://archive.raspbian.org/raspbian bookworm/main armhf Packages [14,5 MB] Holen:13 http://archive.raspbian.org/raspbian bookworm/contrib armhf Packages [62,3 kB] Holen:14 http://archive.raspbian.org/raspbian bookworm/non-free armhf Packages [118 kB] Es wurden 28,7 MB in 25 s geholt (1.165 kB/s). Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Aktualisierung für 5 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. N: Das Laden der konfigurierten Datei »main/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. N: Das Laden der konfigurierten Datei »contrib/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. N: Das Laden der konfigurierten Datei »non-free/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. pi@Homee:~ $ -
Och menno. Es könnte ja auch mal klappen!
*** ioBroker Diagnosis *** Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen The following checks may give hints to potential malconfigurations or errors, please post them in our forum: https://forum.iobroker.net Just copy and paste the Summary Page, including the ``` characters at start and end. It helps us to help you! ************************************************************************** * Some output is masked. For full results please use 'iob diag --unmask' * ************************************************************************** Press any key to continue========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 12 (bookworm) Static hostname: Homee Icon name: computer Kernel: Linux 6.12.96+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 901 days ago (on 2024-03-15). Systemuptime and Load: 20:44:18 up 13 min, 3 users, load average: 0.09, 0.15, 0.16 CPU threads : 4 *** LIFE CYCLE STATUS *** ERROR: Package 'distro-info' is not installed. Please do: sudo apt update && sudo apt install distro-info Alternatively execute the 'iob fix' pi@Homee:~ $ -
Meine Reihenfolge war bisher immer folgende:
sudo apt update
sudo apt fill-upgradeiob stop
iob fix
iob update
iob upgrade selfsudo reboot
Das hatte ich erst im Juli gemacht, meine ich.
@SMS Das Ding ist aber auch mit Sicherheit auch von einer Vorversion auf Debian 12 gehoben worden. Hat aber nicht richtig funktioniert...
pi@Homee:~ $ sudo apt update && sudo apt install distro-info OK:1 http://deb.debian.org/debian bookworm InRelease OK:2 http://deb.debian.org/debian-security bookworm-security InRelease OK:3 http://archive.raspberrypi.com/debian bookworm InRelease OK:4 http://deb.debian.org/debian bookworm-updates InRelease OK:5 https://apt.grafana.com stable InRelease OK:6 https://deb.nodesource.com/node_22.x nodistro InRelease Holen:7 https://repos.influxdata.com/debian stable InRelease [6.922 B] Holen:8 http://archive.raspbian.org/raspbian bookworm InRelease [15,0 kB] Es wurden 21,9 kB in 2 s geholt (14,5 kB/s). Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Aktualisierung für 5 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. N: Das Laden der konfigurierten Datei »main/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. N: Das Laden der konfigurierten Datei »contrib/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. N: Das Laden der konfigurierten Datei »non-free/binary-arm64/Packages« wird übersprungen, da das Depot »http://archive.raspbian.org/raspbian bookworm InRelease« die Architektur »arm64« nicht unterstützt. Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt: chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra edid-decode libbasicusageenvironment1 libc++1-16 libc++abi1-16 libcamera0.2 libcamera0.3 libcamera0.4 libgroupsock8 liblivemedia77 libqt5qmlworkerscript5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libunwind-16 libwlroots12 libwpe-1.0-1 libwpebackend-fdo-1.0-1 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.47+rpt-common-rpi linux-headers-6.12.75+rpt-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-headers-6.6.28+rpt-common-rpi linux-headers-6.6.31+rpt-common-rpi linux-headers-6.6.47+rpt-common-rpi linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.74+rpt-common-rpi linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-kbuild-6.12.75+rpt linux-kbuild-6.6.20+rpt linux-kbuild-6.6.28+rpt linux-kbuild-6.6.31+rpt linux-kbuild-6.6.47+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt lxplug-network musl python3-gi-cairo python3-v4l2 qml-module-qtgraphicaleffects qml-module-qtquick-controls2 qml-module-qtquick-layouts qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2 Verwenden Sie »sudo apt autoremove«, um sie zu entfernen. Vorgeschlagene Pakete: shunit2 Die folgenden NEUEN Pakete werden installiert: distro-info 0 aktualisiert, 1 neu installiert, 0 zu entfernen und 5 nicht aktualisiert. Es müssen 17,6 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 158 kB Plattenplatz zusätzlich benutzt. Holen:1 http://deb.debian.org/debian bookworm/main arm64 distro-info arm64 1.5+deb12u1 [17,6 kB] Es wurden 17,6 kB in 0 s geholt (351 kB/s). Vormals nicht ausgewähltes Paket distro-info wird gewählt. (Lese Datenbank ... 258043 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../distro-info_1.5+deb12u1_arm64.deb ... Entpacken von distro-info (1.5+deb12u1) ... distro-info (1.5+deb12u1) wird eingerichtet ... Trigger für man-db (2.11.2-2) werden verarbeitet ... pi@Homee:~ $Dann brauche ich jetzt kein
iob fixoder doch nochmal? -
sudo apt update
iob fix
iob update
