  4. Nach Umzug des Rechners startet VIS nicht mehr!
    5.8k
38 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • L LaBamba
    system.adapter.admin.0 in version "7.8.23" started with pid 1087
    2026-05-17 22:29:56.312  - error: host.ronny-ThinkCentre-M910q iobroker npm-install: host.ronny-ThinkCentre-M910q Unknown packet name flot. Please install packages from outside the repository using "iobroker url <url-or-package>"!
    2026-05-17 22:29:56.312  - error: host.ronny-ThinkCentre-M910q iobroker npm-install: adapter "flot" cannot be installed: Unknown packet name flot. Please install packages from outside the repository using "iobroker url <url-or-package>"!
    2026-05-17 22:30:06.444  - warn: host.ronny-ThinkCentre-M910q startInstance cannot find adapter "viessmannapi@2.4.4". Try to install it... 1 attempt
    2026-05-17 22:30:06.445  - info: host.ronny-ThinkCentre-M910q iobroker install viessmannapi@2.4.4 using installedFrom
    zigbee.0.00158d0005867bf4.temperature (Count=56), Alias=false
    2026-05-17 22:30:17.745  - error: host.ronny-ThinkCentre-M910q iobroker npm-install: host.ronny-ThinkCentre-M910q Unknown packet name viessmannapi. Please install packages from outside the repository using "iobroker url <url-or-package>"!adapter "viessmannapi" cannot be installed: Unknown packet name viessmannapi. Please install packages from outside the repository using "iobroker url <url-or-package>"!
    2026-05-17 22:30:19.942  - warn: host.ronny-ThinkCentre-M910q startInstance cannot find adapter "vis-material-webfont@0.0.3". Try to install it... 1 attempt
    2026-05-17 22:30:19.942  - info: host.ronny-ThinkCentre-M910q iobroker install vis-material-webfont@0.0.3 using installedFrom
    2026-05-17 22:30:21.771  - info: host.ronny-ThinkCentre-M910q instance system.adapter.alarm.0 in version "3.7.6" started with pid 1274
    2026-05-17 22:30:23.575  - warn: javascript.0 (1147) Cannot install custom npm package "fs@latest": Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/fs/index.js' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
    2026-05-17 22:30:23.753  - error: host.ronny-ThinkCentre-M910q iobroker npm-install: host.ronny-ThinkCentre-M910q Unknown packet name vis-material-webfont. Please install packages from outside the repository using "iobroker url <url-or-package>"!adapter "vis-material-webfont" cannot be installed: Unknown packet name vis-material-webfont. Please install packages from outside the repository using "iobroker url <url-or-package>"!
    2026-05-17 22:30:23.940  - info: host.ronny-ThinkCentre-M910q instance system.adapter.alexa2.0 in version "3.27.4" started with pid 1303
    2026-05-17 22:30:24.156  - info: pushover.0 (1215) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:30:24.176  - error: pushover.0 (1215) Cannot send notification while not configured
    2026-05-17 22:30:24.223  - info: telegram.0 (1227) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:30:57.868  - error: rpi2.0 (1573) No Value found for cpu_voltage
    2026-05-17 22:30:57.868  - error: rpi2.0 (1573) No Value found for mem_arm
    2026-05-17 22:30:57.868  - error: rpi2.0 (1573) No Value found for mem_gpu
    2026-05-17 22:31:02.159  - warn: senec.0 (1628) Usage of SENEC App API configured but initial connection failed. Check credentials and connection to SENEC App API. API Polling turned of automatically until restart.
    2026-05-17 22:31:26.316  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000003: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:26.450  - info: daswetter.0 (1738) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:31:26.634  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000004: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:27.210  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000006: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:27.500  - info: host.ronny-ThinkCentre-M910q instance system.adapter.discovery.0 in version "5.0.0" started with pid 1768
    2026-05-17 22:31:27.530  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000007: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:27.850  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000008: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:28.106  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x000000000000009: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:28.426  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x0000000000000010: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:28.746  - error: yeelight-2.1 (1722) Exception at calling getValues() for light 0x0000000006629883: Error [ERR_SOCKET_CLOSED_BEFORE_CONNECTION]: Socket closed before the connection was established
    2026-05-17 22:31:51.132  - warn: tankerkoenig.3 (1828) City is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.132  - warn: tankerkoenig.3 (1828) Street is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.132  - warn: tankerkoenig.3 (1828) House number is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.132  - warn: tankerkoenig.3 (1828) Post code is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.132  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station TOTAL - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) City is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Street is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) House number is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Post code is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station VARO - B19. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) City is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Street is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) House number is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Post code is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station RAN - STUTTGARTER ST. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.133  - warn: tankerkoenig.3 (1828) City is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Street is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) House number is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Post code is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station ARAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) City is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Street is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) House number is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Post code is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station TOTAL - KANTSTR. WÜ. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) City is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Street is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) House number is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Post code is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station OMV – SCHWEINFURTER . Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.134  - warn: tankerkoenig.3 (1828) City is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Street is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) House number is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Post code is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station SHELL – SCHWEINFURTE. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) City is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Street is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) House number is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Post code is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station HEINRICH – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) City is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Street is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) House number is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Post code is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station AGIP – GERBRUNN. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) City is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.135  - warn: tankerkoenig.3 (1828) Street is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.136  - warn: tankerkoenig.3 (1828) House number is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.136  - warn: tankerkoenig.3 (1828) Post code is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.136  - warn: tankerkoenig.3 (1828) Latitude is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.136  - warn: tankerkoenig.3 (1828) Longitude is missing in config from station HERM - GIEBELSTADT. Please check your configuration or reconfigure the stations => edit station => save
    2026-05-17 22:31:51.977  - info: alexa2.0 (1303) Initialization Done ...
    alles mit warnung oder fehler
    @LaBamba sagte:
    Du sollst aber nicht die Warnings und Errors zeigen sondern den ungefilterten Start von vis.
      @LaBamba sagte:
      das ist zu viel um das allles hier rein zu kopieren
      Dann ist dein LogLevel zu hoch.
      Es interessieren auch erstmal nur die Meldungen zum Start von vis.
      Edit: Mein Log von heute Mitternacht an hat z. B. gerade jetzt 27 Zeilen:
      echad@chet:~ $ iob logs | wc -l
      27
      echad@chet:~ $
      Da sehe ich ungewöhnliches Verhalten auch ohne LogViewer. Wenn da mal mehr als 50 Zeilen drin stehen weiß ich sofort, da stimmt irgendwas nicht.
      LaBamba
      @Thomas-Braun sagte:
      kommt befehl nicht gefunden!
      • L LaBamba
        @LaBamba immer alles zeigen!
        • L LaBamba
          @LaBamba sagte:
          Egal, war auch nicht für dich zur Eingabe gedacht.
          L 1 Antwort Letzte Antwort
            @LaBamba sagte:
            LaBamba
            @Thomas-Braun
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-bars.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-history.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-material-webfont.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-material.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-metro.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-players.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-plumb.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-rgraph.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis.0 (force=false, process=false)
            2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.web.0 (force=false, process=true)
            2026-05-17 22:29:25.352 - info: javascript.0 (2956) script.js.common.ALP600.Kamera_Türklingel: Stopping script
            2026-05-17 22:29:25.355 - info: tr-064.0 (1550) terminating
            2026-05-17 22:29:25.347 - info: senec.0 (2542) cleaned everything up...
            2026-05-17 22:29:25.354 - info: hm-rpc.0 (3032) xmlrpc -> 192.168.178.39:42010/ init ["http://192.168.178.59:42010",""]
            2026-05-17 22:29:25.327 - info: vis-inventwo.0 (1726) cleaned everything up...
            2026-05-17 22:29:25.381 - info: admin.0 (2226) <== Disconnect system.user.admin from 192.168.178.31 admin
            2026-05-17 22:29:25.387 - info: vis-inventwo.0 (1726) terminating
            2026-05-17 22:29:25.388 - info: vis-inventwo.0 (1726) Terminated (NO_ERROR): Without reason
            TERMINATE_YOURSELF
            2026-05-17 22:29:25.718 - info: vis-inventwo.0 (1726) Got terminate signal TERMINATE_YOURSELF
            2026-05-17 22:29:25.877 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-inventwo.0 send kill signal
            2026-05-17 22:29:25.877 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.web.0 send kill signal
            2026-05-17 22:29:25.894 - info: vis-inventwo.0 (1726) terminating
            states
            2026-05-17 22:30:52.367 - info: host.ronny-ThinkCentre-M910q instance system.adapter.nuki-extended.0 in version "2.7.0" started with pid 1545
            2026-05-17 22:30:53.016 - info: fronius.0 (1509) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.fronius, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:30:53.709 - info: javascript.0 (1147) script.js.common.ALP600.Kamera_Türklingel: start JavaScript (Blockly)
            2026-05-17 22:30:53.711 - info: hm-rpc.0 (1533) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:30:53.722 - info: javascript.0 (1147) script.js.common.ALP600.Kamera_Türklingel: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2026-05-17 22:30:53.722 - info: javascript.0 (1147) script.js.common.ALP600.Schnappschussbilder_von_APL600_in_VIS_2_Bilder: start JavaScript (Javascript/js)
            2026-05-17 22:30:53.725 - info: javascript.0 (1147) script.js.common.ALP600.Schnappschussbilder_von_APL600_in_VIS_2_Bilder: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2026-05-17 22:30:53.725 - info: javascript.0 (1147) script.js.common.ALP600.Türklingel_automatische_Layer_Änderung!: start JavaScript (Blockly)
            2026-05-17 22:31:53.120 - info: vis-google-fonts.0 (1864) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:31:53.829 - info: vis-google-fonts.0 (1864) Terminated (NO_ERROR): Without reason
            2026-05-17 22:31:54.471 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis-google-fonts.0 terminated while should be started once
            2026-05-17 22:31:54.793 - info: hm-rpc.0 (1533) Connected
            2026-05-17 22:31:55.524 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis-inventwo.0 in version "3.3.5" started with pid 1880
            2026-05-17 22:31:56.056 - info: tankerkoenig.3 (1828) Start first request
            2026-05-17 22:31:56.880 - info: vis-inventwo.0 (1880) starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:31:57.741 - info: tr-064.0 (1676) forEachConfiguredDevice: in GetSpecificHostEntry 0(Xiaomi-von-Ronny/E0:DC:FF:F5:7E:E5) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2026-05-17 22:32:00.832 - info: vis.0 (1935) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:32:01.012 - info: host.ronny-ThinkCentre-M910q instance system.adapter.daswetter.0 in version "3.2.3" started with pid 1951
            2026-05-17 22:32:02.174 - info: vis.0 (1935) Terminated (NO_ERROR): Without reason
            2026-05-17 22:32:02.412 - info: daswetter.0 (1951) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.22.2, js-controller: 7.0.7
            2026-05-17 22:32:02.839 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis.0 terminated while should be started once
            2026-05-17 22:32:03.507 - info: host.ronny-ThinkCentre-M910q instance system.adapter.web.0 in version "8.0.0" started with pid 1967
            2026-05-17 22:32:05.163 - info: web.0 (1967) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
            alles mit vis drin
            • L Offline
              LaBamba
              Könnte es daran liegen das der Server erst die IP Adresse 22 hatte. Darauf wurde der IO-Broker installiert. Dann wurde die IP Adresse auf 59 geändert. Ich hatte iobroker fix durchgeführt
                @LaBamba bitte konfig von web zeigen
                Homoran sagte:
                Konfig=Konfiguration
                • L LaBamba
                  @Thomas-Braun
                  TERMINATE_YOURSELF
                  states
                  alles mit vis drin
                  @LaBamba sagte:
                  alles mit vis drin
                  Es brauch auch anderes was nicht unbedingt explizit "vis" enthält!
                  Aber warum startest du jedesmal alles neu?
                    Homoran sagte:
                    LaBamba
                    Sonst steht nichts drin!
                    • L LaBamba
                      @LaBamba sagte:
                      Immerhin, dass die IP egal ist und der Port stimmt
                      Was erscheint wenn du IP:8082 aufruft?
                      Screenshot bitte
                        @LaBamba sagte:
                        Screenshot bitte
                        LaBamba
                        bei vis runtime
                        bei vis kommt:Bildschirmfoto 2026-05-17 um 23.16.23.png
                        • L Offline
                          LaBamba
                          welches betriebssystem wäre den besonders geeignet. vielleicht setze ich den rechner nochmal neu auf
                          • L Offline
                            LaBamba
                            da float Grafiken auch nicht geht, scheinen das mehrere Probleme zu sein
                              Das war nicht was ich schrieb!!
                              Bring erst mal deine Installation in Ordnung.
                              Laut log ist der immer noch dabei zu installieren, mit einigen Problemen, an die du ran musst.
                              Ich seh mir das dann morgen nochmal an
                              • L LaBamba
                                @LaBamba sagte:
                                Ich würde ein Debian 13 'Trixie' als Unterbau verwenden. Natürlich ohne das ganze Desktop-Gerümpel.
                                • L Offline
                                  LaBamba
                                  Guten Morgen, ich werde alles neu Installieren und Debian 13 'Trixie' als Unterbau verwenden. Dann den Iobroker installieren und nur den Backup Adapter installieren. Danach versuche ich nochmals das Backup einzuspielen.
                                  • L LaBamba
                                    LaBamba
                                    LaBamba sagte:
                                    @homoran @thomas-braun
                                    • L LaBamba
                                      LaBamba sagte:
                                      @LaBamba sagte:
                                      Der backitup ist nicht ohne Grund schon in der Installation von ioBroker dabei 😉
                                      Und nimm Trixie ohne Desktop
