  4. Nach Umzug des Rechners startet VIS nicht mehr!
    5.8k
38 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • L LaBamba
    @Thomas-Braun
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-bars.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-google-fonts.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-history.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-inventwo.0 (force=false, process=true)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-material-webfont.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-material.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-metro.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-players.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-plumb.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-rgraph.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis.0 (force=false, process=false)
    2026-05-17 22:29:25.339 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.web.0 (force=false, process=true)
    2026-05-17 22:29:25.352 - info: javascript.0 (2956) script.js.common.ALP600.Kamera_Türklingel: Stopping script
    2026-05-17 22:29:25.355 - info: tr-064.0 (1550) terminating
    2026-05-17 22:29:25.347 - info: senec.0 (2542) cleaned everything up...
    2026-05-17 22:29:25.354 - info: hm-rpc.0 (3032) xmlrpc -> 192.168.178.39:42010/ init ["http://192.168.178.59:42010",""]
    2026-05-17 22:29:25.327 - info: vis-inventwo.0 (1726) cleaned everything up...
    2026-05-17 22:29:25.381 - info: admin.0 (2226) <== Disconnect system.user.admin from 192.168.178.31 admin
    2026-05-17 22:29:25.387 - info: vis-inventwo.0 (1726) terminating
    2026-05-17 22:29:25.388 - info: vis-inventwo.0 (1726) Terminated (NO_ERROR): Without reason
    TERMINATE_YOURSELF
    2026-05-17 22:29:25.718 - info: vis-inventwo.0 (1726) Got terminate signal TERMINATE_YOURSELF
    2026-05-17 22:29:25.877 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.vis-inventwo.0 send kill signal
    2026-05-17 22:29:25.877 - info: host.ronny-ThinkCentre-M910q stopInstance system.adapter.web.0 send kill signal
    2026-05-17 22:29:25.894 - info: vis-inventwo.0 (1726) terminating
    2026-05-17 22:30:19.942 - warn: host.ronny-ThinkCentre-M910q startInstance cannot find adapter "vis-material-webfont@0.0.3". Try to install it... 1 attempt
    2026-05-17 22:30:19.942 - info: host.ronny-ThinkCentre-M910q iobroker install vis-material-webfont@0.0.3 using installedFrom
    2026-05-17 22:30:21.771 - info: host.ronny-ThinkCentre-M910q instance system.adapter.alarm.0 in version "3.7.6" started with pid 1274
    2026-05-17 22:30:23.575 - warn: javascript.0 (1147) Cannot install custom npm package "fs@latest": Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/fs/index.js' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
    2026-05-17 22:30:23.753 - error: host.ronny-ThinkCentre-M910q iobroker npm-install: host.ronny-ThinkCentre-M910q Unknown packet name vis-material-webfont. Please install packages from outside the repository using "iobroker url <url-or-package>"!adapter "vis-material-webfont" cannot be installed: Unknown packet name vis-material-webfont. Please install packages from outside the repository using "iobroker url <url-or-package>"!
    states
    2026-05-17 22:30:52.367 - info: host.ronny-ThinkCentre-M910q instance system.adapter.nuki-extended.0 in version "2.7.0" started with pid 1545
    2026-05-17 22:30:53.016 - info: fronius.0 (1509) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.fronius, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:30:53.709 - info: javascript.0 (1147) script.js.common.ALP600.Kamera_Türklingel: start JavaScript (Blockly)
    2026-05-17 22:30:53.711 - info: hm-rpc.0 (1533) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:30:53.722 - info: javascript.0 (1147) script.js.common.ALP600.Kamera_Türklingel: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-05-17 22:30:53.722 - info: javascript.0 (1147) script.js.common.ALP600.Schnappschussbilder_von_APL600_in_VIS_2_Bilder: start JavaScript (Javascript/js)
    2026-05-17 22:30:53.725 - info: javascript.0 (1147) script.js.common.ALP600.Schnappschussbilder_von_APL600_in_VIS_2_Bilder: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2026-05-17 22:30:53.725 - info: javascript.0 (1147) script.js.common.ALP600.Türklingel_automatische_Layer_Änderung!: start JavaScript (Blockly)
    2026-05-17 22:31:51.977 - info: alexa2.0 (1303) Initialization Done ...
    2026-05-17 22:31:53.120 - info: vis-google-fonts.0 (1864) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:31:53.829 - info: vis-google-fonts.0 (1864) Terminated (NO_ERROR): Without reason
    2026-05-17 22:31:54.471 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2026-05-17 22:31:54.793 - info: hm-rpc.0 (1533) Connected
    2026-05-17 22:31:55.524 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis-inventwo.0 in version "3.3.5" started with pid 1880
    2026-05-17 22:31:56.056 - info: tankerkoenig.3 (1828) Start first request
    2026-05-17 22:31:56.880 - info: vis-inventwo.0 (1880) starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:31:57.741 - info: tr-064.0 (1676) forEachConfiguredDevice: in GetSpecificHostEntry 0(Xiaomi-von-Ronny/E0:DC:FF:F5:7E:E5) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-05-17 22:32:00.832 - info: vis.0 (1935) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:32:01.012 - info: host.ronny-ThinkCentre-M910q instance system.adapter.daswetter.0 in version "3.2.3" started with pid 1951
    2026-05-17 22:32:02.174 - info: vis.0 (1935) Terminated (NO_ERROR): Without reason
    2026-05-17 22:32:02.412 - info: daswetter.0 (1951) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.22.2, js-controller: 7.0.7
    2026-05-17 22:32:02.839 - info: host.ronny-ThinkCentre-M910q instance system.adapter.vis.0 terminated while should be started once
    2026-05-17 22:32:03.507 - info: host.ronny-ThinkCentre-M910q instance system.adapter.web.0 in version "8.0.0" started with pid 1967
    2026-05-17 22:32:05.163 - info: web.0 (1967) starting. Version 8.0.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.0.7
    alles mit vis drin
    @LaBamba sagte:
    alles mit vis drin
    Es brauch auch anderes was nicht unbedingt explizit "vis" enthält!
    Aber warum startest du jedesmal alles neu?
      Homoran sagte:
      @LaBamba bitte konfig von web zeigen
      Konfig=Konfiguration
      LaBamba
      Sonst steht nichts drin!
      • L LaBamba
        @LaBamba sagte:
        Immerhin, dass die IP egal ist und der Port stimmt
        Was erscheint wenn du IP:8082 aufruft?
        Screenshot bitte
        L 1 Antwort Letzte Antwort
          @LaBamba sagte:
          Screenshot bitte
          LaBamba
          bei vis runtime
          bei vis kommt:Bildschirmfoto 2026-05-17 um 23.16.23.png
          • L Offline
            LaBamba
            welches betriebssystem wäre den besonders geeignet. vielleicht setze ich den rechner nochmal neu auf
            • L Offline
              LaBamba
              da float Grafiken auch nicht geht, scheinen das mehrere Probleme zu sein
                Das war nicht was ich schrieb!!
                Bring erst mal deine Installation in Ordnung.
                Laut log ist der immer noch dabei zu installieren, mit einigen Problemen, an die du ran musst.
                Ich seh mir das dann morgen nochmal an
                • L LaBamba
                  @LaBamba sagte:
                  Ich würde ein Debian 13 'Trixie' als Unterbau verwenden. Natürlich ohne das ganze Desktop-Gerümpel.
                  • L Offline
                    LaBamba
                    Guten Morgen, ich werde alles neu Installieren und Debian 13 'Trixie' als Unterbau verwenden. Dann den Iobroker installieren und nur den Backup Adapter installieren. Danach versuche ich nochmals das Backup einzuspielen.
                    • L LaBamba
                      LaBamba
                      LaBamba sagte:
                      @homoran @thomas-braun
                      • L LaBamba
                        LaBamba sagte:
                        @LaBamba sagte:
                        Der backitup ist nicht ohne Grund schon in der Installation von ioBroker dabei 😉
                        Und nimm Trixie ohne Desktop
