Betatest ioBroker.icloud 0.2.x
Wir kommen der Sache näher.
Log mit v2.0.3:2026-09-06 10:13:10.589 - debug: icloud.0 (1246) [icloud.js] [auth] authenticateWebService "calendar" → POST https://setup.icloud.com/setup/ws/1/accountLogin 2026-09-06 10:13:11.088 - debug: icloud.0 (1246) [icloud.js] [auth] authenticateWebService "calendar" response status: 421 2026-09-06 10:13:11.089 - debug: icloud.0 (1246) [icloud.js] [calendar] GET https://p198-calendarws.icloud.com/ca/events?clientBuildNumber=2534Project66&clientMasteringNumber=xxxxxxx&clientId=xxxxxxxxxxxxxxxxxx&dsid=xxxxxxxxxxx&startDate=2026-09-01&endDate=2026-09-30&lang=en-us&usertz=Europe%2FBerlin 2026-09-06 10:13:12.152 - warn: icloud.0 (1246) [icloud.js] [calendar] /startup failed but /events answered (54 event(s)) — Apple serves this account's events but not its calendar list. Please check whether Calendar is enabled for iCloud on your Apple devices and whether icloud.com/calendar works in a browser. 2026-09-06 10:13:12.153 - warn: icloud.0 (1246) Calendar refresh failed: WEBSERVICE_REAUTH_REQUIRED:calendar 2026-09-06 10:13:12.153 - debug: icloud.0 (1246) Calendar refresh scheduled every 60 minIm Browser kann ich die im Log genannte URL (iCloud.com/calendar) erfolgreich aufrufen.
@ticaki
sieht gut aus: der Workaround (v2.0.4) scheint erst mal zu funktionieren. Die Calender werden jetzt bei mir erfolgreich gesynced:2026-09-06 13:33:26.409 - info: host.iobroker "system.adapter.icloud.0" enabled 2026-09-06 13:33:27.587 - info: host.iobroker instance system.adapter.icloud.0 in version "2.0.4" (non-npm: ticaki/ioBroker.icloud#565c6094a470da57f1e4e8304d5af47ae6f8c61a) started with pid 12540 2026-09-06 13:33:29.514 - warn: icloud.0 (12540) This instance has 6669 objects, the limit for this instance is set to 5000. 2026-09-06 13:33:29.517 - info: icloud.0 (12540) starting. Version 2.0.4 (non-npm: ticaki/ioBroker.icloud#565c6094a470da57f1e4e8304d5af47ae6f8c61a) in /opt/iobroker/node_modules/iobroker.icloud, node: v22.23.2, js-controller: 7.2.2 2026-09-06 13:33:35.063 - info: icloud.0 (12540) Logged in as: xxxxxxxxxxxx 2026-09-06 13:33:35.063 - info: icloud.0 (12540) Country: DEU, Locale: de-de_DE 2026-09-06 13:33:35.064 - info: icloud.0 (12540) Available iCloud services (31): account, archivews, calendar, ckdatabasews, cksharews, contacts, contactsweb, developerapi, docws, drivews, findme, geows, iwmb, iworkexportws, iworkthumbnailws, keyvalue, mail, mcc, mccgateway, mpp, notes, photos, photosupload, premiummailsettings, push, reminders, settings, sharedlibrary, sharedstreams, ubiquity, uploadimagews 2026-09-06 13:33:38.437 - info: icloud.0 (12540) FindMy ready — 5 device(s): 2 own, 11 family, 0 accessories; 5/5 with location 2026-09-06 13:33:42.611 - warn: icloud.0 (12540) [icloud.js] [calendar] /startup failed but /events answered (54 event(s) in 4 calendar(s)) — Apple serves this account's events but not its calendar list. Continuing with a calendar list reconstructed from the events: calendars without events in the queried range are missing and no titles, colours or flags are available for the others. 2026-09-06 13:33:52.930 - info: icloud.0 (12540) Calendar ready — 4 calendar(s), 81 upcoming event(s) this month 2026-09-06 13:33:54.052 - info: icloud.0 (12540) Account storage ready — 80713 / 204800 MB used (39.4%) 2026-09-06 13:33:54.053 - info: icloud.0 (12540) iCloud connection established successfullyVielen Dank dir schon mal.
Jetzt muss ich mich mal durch die dadurch entstandene Objekte-Struktur im ioBroker kämpfen, die ja, wie im Log auch erwähnt, nicht die Titel, Farben, etc. beinhalten. Aber das schaffe ich heute nicht mehr. -
Bei mir klappt der Kalender auch, schon mal Danke dafür. Jetzt muss ich mir nur noch eine Logik überlegen wie ich auf die Kalender-Events reagieren kann, ohne haufenweise Last zu erzeugen.
A.
@Asgothian
vielleicht ist der teil der readme dann was für dich: https://github.com/ticaki/ioBroker.icloud/blob/main/README_GERMAN.md#kalender--sendto-apihoffe da funktioniert noch alles, habs das am anfang alles durchgetestet bin aber noch dazu gekommen es auch wirklich zu nutzen.
@Asgothian
@ticaki Danke, das hatte ich mir angeschaut - mit den Daten komm ich hin - das sieht gut aus. Was ich heraus finden muss wie ich mitbekomme wann der Kalender aktualisert wird, so das ich die Termine in Shedules umwandeln kann um Status-States zu setzen - und wieder weg zu machen. Und das ganze mit so wenig Last wie geht.
A.
dann ein weiterer versuch um die fehlenden daten von woanders zu bekommen (titel farbe etc)
v2.0.5dann ein weiterer versuch um die fehlenden daten von woanders zu bekommen (titel farbe etc)
v2.0.5Bei mir funktioniert es jetzt auch. Danke dir vielmals.
Werde mich jetzt mal daran machen, die Termine aus den diversen iCloud-Kalendern in eine Form zu bringen (json??), die man gut für eine Terminübersicht verwenden kann.
was ich gut finden würde ist ein 'klassisches' JSON, jeweils für konfigurierbare Anzahl von Tagen T ab einem Delta D:
Heute - D: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
Heute - D+1: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
heute - D + T-1: { [Uhrzeit, Kalender, Benennung, Dauer, Alarm], ...}
Bei mir klappt die Verifizierung per SMS nicht. Nun alle Versuche für paar Std. aufgebraucht. Noch jemand aktuell das Problem?
Ich hatte dass Problem. Siehe hier: https://forum.iobroker.net/topic/84325/betatest-iobroker.icloud-0.2.x/95?_=1788790691731
Nach Installation der 2.0.4 war es weg.
A.
A.
A.
Unter der 2.0.4 ebenfalls dasselbe Problem :/
A.
icloud.0 2026-09-08 10:31:17.411 info Admin UI: requesting MFA code via SMS icloud.0 2026-09-08 10:30:41.601 info Admin UI: requesting MFA code via SMS icloud.0 2026-09-08 10:30:33.412 warn MFA required — enter the 6-digit Apple code into state mfa.code icloud.0 2026-09-08 10:30:29.908 info starting. Version 2.0.4 (non-npm: https://www.npmjs.com/package/iobroker.icloud) in /opt/iobroker/node_modules/iobroker.icloud, node: v22.23.2, js-controller: 7.2.2 host.ioBroker 2026-09-08 10:30:28.090 info instance system.adapter.icloud.0 in version "2.0.4" (non-npm: https://www.npmjs.com/package/iobroker.icloud) started with pid 13531 host.ioBroker 2026-09-08 10:30:24.168 info instance system.adapter.icloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
Node.js:
v22.23.2
NPM:
10.9.8
admin
v8.0.11 -
}was ich gut finden würde ist ein 'klassisches' JSON, jeweils für konfigurierbare Anzahl von Tagen T ab einem Delta D:
}Folgende Attribute würde ich mir je Termin-Eintrag im json wünschen:
- Termin-Titel (slot.title)
- Ganztagestermin (slot.allDay)
- Start-Uhrzeit (slot.startDate)
- Dauer (slot.duration)
- Ende-Zeit (slot.endDate)
- Beschreibung (slot.description)
- Ort (slot.location)
- Kalender-Quelle (calendar.name)
- Kalender-Farbe (calendar.color) [nice-to-have]
Und wie oben von @asgothian bereits geschrieben, am besten in der Adapter-Config konfigurierbar, welche Kalender für das JSON berücksichtigt werden sollen und welchen Zeitraum (nach vorne und zurück vom aktuellem Datum).
Node.js:
v22.23.2
NPM:
10.9.8
admin
v8.0.11Krys sagte:
Node.js:
v22.23.2
NPM:
10.9.8
admin
v8.0.11Hab noch 2.0.3 & 2.0.4 probiert.
Es ist weiterhin der SMS-Code falsch.Schade.
