  2. English
  3. Off Topic
  4. Solaredge - modbus
  • Monatsrückblick Oktober 2026 ist online!
  • Mitmachen: Sprich „ioBroker“ ein – für ein lokales Aktivierungswort
  • Neuer Blogbeitrag: KI in ioBroker, vom Helfer im Admin bis zum eigenen Smart Assistant
Solaredge - modbus
1 Beiträge 1 Kommentatoren 1.4k Aufrufe
Dieses Thema wurde aufgespalten von [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana Homoran
  • W
    W
    walker-bho
    Hi all,
    I have a SE8K-RWB48BFN4 with a three-phase Backup Interface (BIEU3P) and a SolarEdge Home Battery 48V (3 modules, 14.55 kWh). The hardware commissioning appears correct — BIEU3P is physically installed, RS485 wiring is in place, battery is charging/discharging normally.
    However, during blackout tests the system does not hold island mode: loads power up for ~1 second, then the inverter shuts down, retries every 10-15 seconds in a loop.
    Reading the inverter via Modbus TCP (port 1502) I found that register 63250 (proprietary SolarEdge, community-identified as "Backup Enable") reads 0 on my system.
    My question: on your SE8K-RWB48 or SE10K-RWB48 with a working Backup Interface, what value does register 63250 return?
    from pymodbus.client import ModbusTcpClient
    client = ModbusTcpClient('YOUR_INVERTER_IP', port=1502, timeout=5)
    client.connect()
    r = client.read_holding_registers(address=63250, count=1, device_id=1)
    print(f"Register 63250: {r.registers[0]}")
    client.close()
    I expect the value should be 1 on a correctly commissioned system, but I would appreciate confirmation from someone whose backup is actually working.
    Thanks in advance.
    • HomoranH Homoran verschob dieses Thema von Praktische Anwendungen (Showcase) am
    84.2k
    1.4m
