  4. Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana
    6.4k
75 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
  • M marcelinho
    @crunchip
    hier iob diag von meiner alten Micro SD:
    107*** BASE SYSTEM ***
    Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model        : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
    21:18:05 up 53 min,  1 user,  load average: 0.31, 0.42, 0.59
    CPU threads: 4
    107*** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    107*** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    107*** TIME AND TIMEZONES ***
                   Local time: Fri 2026-01-02 21:18:05 CET
               Universal time: Fri 2026-01-02 20:18:05 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    107*** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    107*** DISPLAY-SERVER SETUP ***
    Display-Server:     false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    107*** MEMORY ***
    Mem:            4.0G        3.0G        365M        610K        673M        966M
    Swap:           209M        209M        516K
    Total:          4.2G        3.2G        365M
    Active iob-Instances:     28
             3796 M total memory
             2874 M used memory
             1981 M active memory
             1256 M inactive memory
              348 M free memory
               55 M buffer memory
              587 M swap cache
              199 M total swap
              199 M used swap
                0 M free swap
    107*** top - Table Of Processes  ***
    top - 21:18:06 up 54 min,  1 user,  load average: 0.31, 0.42, 0.59
    Tasks: 232 total,   1 running, 231 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 11.1 us, 11.1 sy,  0.0 ni, 66.7 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.9 total,    348.3 free,   2874.9 used,    642.8 buff/cache
    MiB Swap:    200.0 total,      0.5 free,    199.5 used.    922.0 avail Mem
    107*** FAILED SERVICES ***
    0 loaded units listed.
    107*** DMESG CRITICAL ERRORS ***
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    sudo: a password is required
    No critical errors detected
    107*** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/mmcblk0p2 ext4       29G   18G  9.3G  66% /
    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
    tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
    sudo
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    Archived and active journals take up 170.2M in the file system.
    /opt/iobroker/backups:
    145M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/history
    236M    /opt/iobroker/iobroker-data/files
    109M    /opt/iobroker/iobroker-data/backup-objects
    47M    /opt/iobroker/iobroker-data/files/admin.admin
    49M    /opt/iobroker/iobroker-data/objects.jsonl
    24M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
    107*** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    107*** NodeJS-Installation ***
    /usr/bin/nodejs     v22.21.1
    /usr/bin/node         v22.21.1
    /usr/bin/npm         11.6.4
    /usr/bin/npx         11.6.4
    /usr/bin/corepack     0.34.0
    nodejs:
      Installed: 22.21.1-1nodesource1
      Candidate: 22.21.1-1nodesource1
      Version table:
    *** 22.21.1-1nodesource1 100
            100 /var/lib/dpkg/status
    No problems detected
    Errors in npm tree: 0
    107*** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3217)
    Core adapters versions
    js-controller:     7.0.7
    admin:         7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
    + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.sun2000.0                : sun2000               : raspberrypi                              -  enabled, port: 502
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daikin"       : 1.5.1    , installed 1.5.1
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lg-thinq"     : 1.1.3    , installed 1.1.3
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "openhab"      : 1.2.0    , installed 1.2.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "sun2000"      : 2.3.5    , installed 2.3.5
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.8
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    auf meiner neuen Micro SD Karte sind alle Adapter Identisch zu meiner alten Micro SD Karte aus backitup wiederhergestellt, installiert und "grün".
    MQTT Adapter ist ebenfalls grün, Zigbee2mqtt geht nicht über Web Socket.. Mosquitto ist ebenfalls installiert.
    Was benötigst du noch? (kann Dir alle Daten von Zigbee2mqtt aus der json geben falls benötigt von der alten Karte)
    Aber ich habe glaube einen grundlegenden Fehler nach der Installation gemacht, ich habe keinen seperaten user angelegt. Er lässt mich auch nicht auf der neuen Karte "iob diag" machen. Könnte das damit zusammenhängen?
    pi@raspberrypi:~ $ iob diag
    [sudo] password for iobroker:
    Was influx betrifft und Grafana -- bin ich noch nicht gekommen, möchte erst Zigbee2mqtt zum laufen bekommen das zumindest mal wieder meine Automationen, Lichter etc. laufen.
    crunchipC Offline
    crunchipC Offline
    @marcelinho sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
    darum habe ich oben gelistet, was installiert war und ist (Mosquitto trage ich nach) dann sollte dir selbst auffallen was fehlt
    naja, das Grundgerüst sollte schon passen
    • MartinPM MartinP
      So lange das Web-Interface des externen zigbee2mqtt Servers nicht läuft ist die Fehlersuche von iobroker aus meiner Meinung nach wenig erfolgversprechend...
      Kommst Du mit dem Browser auf die Seite
      http://192.168.2.198:8080/#/settings/settings
      marcelinho
      @MartinP ja komme ich aber da muss ich alles einstellen obwohl ich die YAML konfiguriert habe.
      • M marcelinho
        @crunchip
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        iobroker
        HOME=/home/iobroker
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:
        107*** MEMORY ***
                 3796 M total memory
                 2874 M used memory
                  348 M free memory
                   55 M buffer memory
                  587 M swap cache
                  199 M total swap
                  199 M used swap
                    0 M free swap
        sudo
        /var:
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm         11.6.4
        /usr/bin/npx         11.6.4
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:         7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Natürlich.
        Mit welchem user hast du denn den ioBroker installiert?
        Diesem user werden dann im Zuge der Installation auch die passenden Rechte übertragen.
        Nach der iob-Installation einmal reboot und als erste Aktion dann ein
        iob stop
        iob fix
        iob start
        schließt die Installation final ab.
        • M marcelinho
          crunchipC Offline
          crunchipC Offline
          ich weiß zwar nicht was mit backitup alles bei z2m gesichert wird, gehe aber mal davon aus, wenn man das zurückspielt, nichts mehr eingestellt werden muss, andernfalls passt ggf etwas mit deinen Rechten nicht. Allerdings mit fehlender yaml z2m gar nicht erst starten dürfte
            marcelinho
            @crunchip das heisst ich installiere z2m und mosquitto manuell über SSH und das hat nichts mit dem z2m adapter in iobroker zu tun, richtig?
            • M marcelinho
              crunchipC Offline
              crunchipC Offline
              @marcelinho na der zigbee2mqtt Adapter ist der eine Baustein, ohne den anderen Baustein z2m installiert zu haben geht der Adapter nicht. Mosquitto ist dafür auch nicht zwingend nötig
              zeig mal die Ausgabe von
              systemctl status zigbee2mqtt.service
                marcelinho
                schrieb am zuletzt editiert von marcelinho
                @crunchip
                pi@raspberrypi:~/zigbee2mqtt $ systemctl status zigbee2mqtt
                ● zigbee2mqtt.service - Zigbee2MQTT
                     Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                     Active: active (running) since Mon 2026-01-05 23:10:43 CET; 3min 43s ago
                 Invocation: 79bf1356b73f443196ef4396a24b1f7e
                   Main PID: 4504 (npm start)
                      Tasks: 19 (limit: 3920)
                        CPU: 2.499s
                     CGroup: /system.slice/zigbee2mqtt.service
                             ├─4504 "npm start"
                             ├─4515 sh -c "node index.js"
                             └─4516 node index.js
                Jan 05 23:10:43 raspberrypi systemd[1]: Started zigbee2mqtt.service - Zigbee2MQTT.
                Jan 05 23:10:44 raspberrypi npm[4504]: > zigbee2mqtt@2.7.2 start
                Jan 05 23:10:44 raspberrypi npm[4504]: > node index.js
                Jan 05 23:10:44 raspberrypi npm[4516]: Starting Zigbee2MQTT without watchdog.
                Jan 05 23:10:45 raspberrypi npm[4516]: Onboarding page is available at http://0.0.0.0:8080/
                pi@raspberrypi:~/zigbee2mqtt $ journalctl -u zigbee2mqtt -f
                • M marcelinho
                  @crunchip
                          CPU: 2.499s
                               ├─4504 "npm start"
                  crunchipC Offline
                  crunchipC Offline
                  active (running)
                  ist installiert (ergänze ich oben) und v 2.7.2 läuft, passt, aber laut
                  denke die sind noch angelegt von dem backitup das ich eingespielt habe
                  Zigbee2MQTT Version: 1.35.1
                  https://github.com/Koenkk/zigbee2mqtt/discussions/24198
                  hast du dies eigentlich gemacht?
                  https://forum.iobroker.net/post/1318134
                  • MartinPM Online
                    MartinPM Online
                    MartinP
                    Falls der Service nicht bewusst gerade gestartet wurde, scheint er keine lange Lebensdauer zu haben ...
                    Könnte sein, dass der Service nur kurz läuft, und sich dann aufgrund Fehlern neu startet ...
                    • MartinPM MartinP
                      crunchipC Offline
                      crunchipC Offline
                      @MartinP sagte in Hilfestellung Raspi4: Zigbee2Mqtt, InfluxDB, Grafana:
                      geh mal davon aus, da er ja die Karte wechseln muss
                        marcelinho
                        @crunchip danke für eure Hilfe und Mühe, ich glaube ich mach die Karte nochmal neu. Ich sehe vor lauter Bäumen keinen Wald mehr. Sitz schon seit 4 Tagen dran. Ich werde jetzt nochmal die Karte flashen mit Pi OS Light wie von @thomas-braun beschrieben und ioBroker neu aufsetzen. Wie lege ich den Benutzer neu an und gebe Ihm die rechte dazu, hatte das bisher glaube ich noch nie gemacht. Dann installiere ich Mosquitto dann node.js und dann https://www.zigbee2mqtt.io/guide/installation/01_linux.html Werde danach dann backitup einspielen. Bei meiner alten Karte ist das schon 3 Jahre her und hab da auch mit viel Ausdauer irgendwie zum laufen gebracht.
                        • M marcelinho
                          Das läuft alles über den RaspberryOS bzw. den ioBroker-Installer:
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          Mosquitto musst du separat installieren, nodejs kommt mit dem ioBroker-Installer zusammen.
                          • skvarelS Online
                            skvarelS Online
                            skvarel
                            Ich weiss nicht, ob ich es überlesen haben ABER, ohne einen mqtt Server startet Zigbee2mqqt nicht.
                            Ich habe zum Beispiel Mosquitto auf der selben Hardware wie zigbee2mqtt und hole mir die Geräte dann über WS in den ioBroker.
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              crunchipC Offline
                              crunchipC Offline
                              @skvarel hat er ja, den mqtt im iobroker, nen externen mosquitto
                              zur Not braucht man beides nicht und nimmt den internen Dummy
                              ich geh eher davon aus, das seine yaml nicht passt, da auf dem alten noch v1.x lief und seine neue Installation von z2m nun v2.x beinhaltet
                                marcelinho
                                @crunchip würde heissen ich müsste alles neu einbinden wenn die yaml nicht passt?
                                • M marcelinho
                                  crunchipC Offline
                                  crunchipC Offline
                                  @marcelinho Ne, aber anpassen siehe oben https://forum.iobroker.net/post/1318524
                                    marcelinho
                                    @crunchip also ich hab jetzt den Zigbee2mqtt Adapter mit Hilfe von euch zum laufen gebracht und er ist grün. Jedoch werden jetzt alle Datenpunkte unter dem mqtt Adapter bei den Objekten angezeigt und nicht mehr unter zigbee2mqtt. Meine ganzen Scipte sowie VIS ist natürlich auf zigbee2mqtt Objekte ausgelegt. Ich denke/hoffe das ist jetzt nur noch Einstellungssache. Was etwas komisch ist, Mqqt Adapter war vorher als Server/Broker jetzt geht es nur als Client/Subscriper, sonst meckert er das Port 1885 belegt ist. Ich habe Mosquitto auf Port 1885 am laufen und mqtt mit Benutzer und Passwort. Die müssen doch alle gleich sein oder? Der Zigbee2Mqtt Adapter läuft auch unter Port 1885 und ist per :8080 Web erreichbar aber es sind keine Geräte vorhanden obwohl die Yaml wie folgt aussieht:
                                    homeassistant:
                                      enabled: false
                                    frontend:
                                      enabled: true
                                      port: 8080
                                      host: 0.0.0.0
                                    mqtt:
                                      base_topic: zigbee2mqtt
                                      server: mqtt://localhost:1885
                                      user: XXX
                                      password: XXX
                                    serial:
                                      adapter: zstack
                                      port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914a>
                                    advanced:
                                      pan_id: 19452
                                      ext_pan_id:
                                        - 72
                                        - 200
                                        - 193
                                        - 101
                                        - 193
                                        - 116
                                        - 146
                                        - 56
                                      channel: 11
                                      network_key:
                                        - 249
                                        - 141
                                        - 167
                                        - 140
                                        - 102
                                        - 102
                                        - 126
                                        - 74
                                        - 119
                                        - 102
                                        - 162
                                        - 222
                                        - 69
                                        - 128
                                        - 250
                                        - 3
                                    version: 4
                                    Zumindest hab ich einmal ein kleines Erfolgserlebnis, jetzt muss ich nur noch die ganzen Geräte wie ursprünglich bekommen. Dann kann ich mich um Influx und Grafana kümmern.
                                    crunchipC 2 Antworten Letzte Antwort
                                    • M marcelinho
                                      homeassistant:
                                        enabled: false
                                      frontend:
                                        enabled: true
                                        port: 8080
                                        host: 0.0.0.0
                                      mqtt:
                                        user: XXX
                                        password: XXX
                                      serial:
                                        adapter: zstack
                                      advanced:
                                        pan_id: 19452
                                        ext_pan_id:
                                          - 72
                                          - 200
                                          - 193
                                          - 101
                                          - 193
                                          - 116
                                          - 146
                                          - 56
                                        channel: 11
                                        network_key:
                                          - 249
                                          - 141
                                          - 167
                                          - 140
                                          - 102
                                          - 102
                                          - 126
                                          - 74
                                          - 119
                                          - 102
                                          - 162
                                          - 222
                                          - 69
                                          - 128
                                          - 250
                                          - 3
                                      version: 4
                                      crunchipC Offline
                                      crunchipC Offline
                                      Ja, indem du den Port anpasst
                                      • M marcelinho
                                        homeassistant:
                                          enabled: false
                                        frontend:
                                          enabled: true
                                          port: 8080
                                          host: 0.0.0.0
                                        mqtt:
                                          user: XXX
                                          password: XXX
                                        serial:
                                          adapter: zstack
                                        advanced:
                                          pan_id: 19452
                                          ext_pan_id:
                                            - 72
                                            - 200
                                            - 193
                                            - 101
                                            - 193
                                            - 116
                                            - 146
                                            - 56
                                          channel: 11
                                          network_key:
                                            - 249
                                            - 141
                                            - 167
                                            - 140
                                            - 102
                                            - 102
                                            - 126
                                            - 74
                                            - 119
                                            - 102
                                            - 162
                                            - 222
                                            - 69
                                            - 128
                                            - 250
                                            - 3
                                        version: 4
                                        crunchipC Offline
                                        crunchipC Offline
                                        Komisch ist das nicht, eher normal
                                        Erkläre doch bitte für was und wie du
                                        • iobroker mqtt server
                                        • Mosquitto
                                        • Z2M
                                          Mit dem gleichen Port auf deinem alten System laufen hattest
                                          marcelinho
                                          @crunchip ich weis nicht genau was du meinst. Ich hatte Mosquitto wohl nur für Testzwecke installiert (damals nur Benutzer und Passwort aufgeschrieben) mqtt Adapter ist auf Server mit 0.0.0.0:1885 eingestellt gewesen. Der Z2M war auf Websocket. Da ich mir meine alte Karte Debian 12 wohl mit Trixie upgrade zerschossen hab und nicht mehr per SSH drauf komme kann ich leider nicht mehr schauen welcher Port Mosquitto war. Die alte Karte geht noch, aber per SSH leider nicht mehr. Ich würde ungern alle meine Geräte neu einbinden müssen. Obwohl ich denke das ich seit 1 Woche schon versuche Yaml, mqtt und z2m anzupassen es schon längst erledigt wäre. Ich versteh glaube ich das ganze Konstrukt nicht wirklich. Wer mit wem kommuniziert und wer was genau braucht. Wenn ich es schaffe die Adapter grün zu bekommen dann bekomme ich nicht die Geräte rein durch das Backup. Irgendwie dreh ich mich leider im Kreis...
                                          M arteckA 2 Antworten Letzte Antwort
