  4. BackItUp sichert InfluxDB nicht mehr
    6.5k
36 Beiträge 3 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • L Offline
    legro
    schrieb am zuletzt editiert von legro
    BackItUp sichert kein InfluxDB mehr.
    Ausgabe während der Backup-Erstellung ..
    20:57:41.395DEBUGinfluxDBInfluxDB-Backup started ...
    20:57:41.398DEBUGinfluxDBStart InfluxDB Backup ...
    20:57:41.430DEBUGinfluxDBInfluxDB-Backup for is finish
    20:57:41.434DEBUGinfluxDBdone
    Und das findet man in den Protokollen ..
    backitup.0
    2025-11-21 20:57:43.643	debug	[iobroker/zigbee] Found zigbee databases: zigbee.0
    backitup.0
    2025-11-21 20:57:42.736	debug	[iobroker/influxDB] done
    backitup.0
    2025-11-21 20:57:42.736	debug	[iobroker/influxDB] InfluxDB-Backup for is finish
    backitup.0
    2025-11-21 20:57:42.736	error	[iobroker] Error: Command failed: influx backup --bucket db_iobroker --host http://192.168.4.200:8086 -t <hier steht mein Token> "/opt/iobroker/backups/influxDB_2025_11_21-20_57_42_ioBroker_backupiobroker"/bin/sh: 1: influx: not found
    backitup.0
    2025-11-21 20:57:42.736	error	[iobroker/influxDB] /bin/sh: 1: influx: not found
    backitup.0
    2025-11-21 20:57:42.736	error	[iobroker/influxDB] Error: Command failed: influx backup --bucket db_iobroker --host http://192.168.4.200:8086 -t cX1d4c3DYcKSQNJOoQRev12kMgEvOnCN5Afc2XK0XrxbxbAaZglgbjKfpNX9VtEiez4TUjDZSC1epnPgYBsf7g== "/opt/iobroker/backups/influxDB_2025_11_21-20_57_42_ioBroker_backupiobroker"
    backitup.0
    2025-11-21 20:57:42.736	debug	[iobroker/influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_11_21-20_57_42_ioBroker_backupiobroker" successfully deleted
    backitup.0
    2025-11-21 20:57:42.733	debug	[iobroker/influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_11_21-20_57_42_ioBroker_backupiobroker"
    backitup.0
    2025-11-21 20:57:42.730	debug	[iobroker/influxDB] InfluxDB Backup tmp directory created
    backitup.0
    2025-11-21 20:57:42.728	debug	[iobroker/influxDB] Start InfluxDB Backup ...
    backitup.0
    2025-11-21 20:57:42.728	debug	[iobroker/influxDB] InfluxDB-Backup started ...
    InfluxDB läuft auf einer Synology 923+ in Docker, ioBroker läuft auf einem Pi 5.
    Dies ist meine Konfiguration des InfluxDB-Adapters ..
    Weiß jemand Rat?
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    • L legro
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      Weiß jemand Rat?
      @legro sagte in BackItUp sichert InfluxDB nicht mehr:
      Es fehlt der client.
      L 1 Antwort Letzte Antwort
        legro
        @Thomas-Braun sagte in BackItUp sichert InfluxDB nicht mehr:
        Wo fehlt der und wie kann ich diesen Fehler reparieren?
        Wenn ich den die Verbindung Adapter ->InfluxDB teste, erhalte ich ein OK.
        • L legro
          @legro
          sudo apt install influxdb2-cli
          auf dem Raspberry.
            @legro
            auf dem Raspberry.
            legro
            Leider erhalte ich bloß einen weiteren Fehler ..
            pi@Pi5:~ $ sudo apt install influxdb2-cli
            Reading package lists... Done
            Building dependency tree... Done
            E: Unable to locate package influxdb2-cli
            pi@Pi5:~ $
            • L legro
              pi@Pi5:~ $
              @legro
              Ist die influx-Quelle angelegt?
              sudo apt update
              apt policy influx*
                @legro
                sudo apt update
                apt policy influx*
                legro
                @Thomas-Braun
                pi@Pi5:/ $ sudo apt install influxdb2-cli
                pi@Pi5:/ $ sudo apt update
                apt policy influx*
                Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [54.9 kB]
                Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [283 kB]
                Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [268 kB]
                Err:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
                Get:8 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [559 kB]
                Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [560 kB]
                W: GPG error: https://deb.nodesource.com/node_22.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
                E: The repository 'https://deb.nodesource.com/node_22.x nodistro InRelease' is not signed.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                influxdb-client:
                  Installed: (none)
                  Candidate: 1.6.7~rc0-1+b13
                  Version table:
                     1.6.7~rc0-1+b13 500
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb:
                  Installed: (none)
                  Version table:
                     1.6.7~rc0-1+b13 500
                Leider erhalte ich anschließend denselben Fehler beim Installieren wie zuvor.
                • L Offline
                  legro
                  @Thomas-Braun
                  Vorgeschichte ..
                  Ich bin ja von meine Pi 4 -> Pi 5 umgezogen. Ist hier ggf. verloren gegangen?
                  Auf dem Pi 4 habe ich als Installationquelle die sog. "phantastischen Repositories" installiert.
                  • L legro
                    @Thomas-Braun
                    apt policy influx*
                    influxdb-client:
                      Installed: (none)
                      Version table:
                         1.6.7~rc0-1+b13 500
                    influxdb-dev:
                      Installed: (none)
                      Candidate: (none)
                      Version table:
                    influxdb:
                      Installed: (none)
                      Version table:
                         1.6.7~rc0-1+b13 500
                    Weil die Quelle nicht angelegt wurde...
                    Stell dich in dein home und leg es danach an:
                    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                    • L legro
                      @Thomas-Braun
                      Vorgeschichte ..
                      Externe Quellen müssen neu angelegt werden.
                        legro
                        Oh, da wird meine Dokumentation noch länger. ;-)
                        Ich habe nun die Quellen neu angelegt. Anschließend sudo apt update & upgrade durchgeführt. Leider war das Ganze nicht erfolgreich.
                        influxdb2-cli is already the newest version (2.7.5-2).
                        The following packages were automatically installed and are no longer required:
                          libunwind8 linux-headers-6.12.34+rpt-common-rpi linux-kbuild-6.12.34+rpt rpicam-apps-lite
                        Use 'sudo apt autoremove' to remove them.
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        L Thomas BraunT 2 Antworten Letzte Antwort
                        • L legro
                          legro
                          Nach meiner Dokumentation hatte ich bei der Vorbereitung des Umzugs den Pi 5 nicht nur mit dem neuesten OS ausgestattet, sondern ich hatte vorsorglich bereits alle Repositories eingepflegt bevor ich mittels BackItUp den Umzug einläutete.
                          • L legro
                            Heißt: Das Paket ist schon installiert.
                              legro
                              @Thomas-Braun
                              Ich habe das Backup erneut angestoßen: Es funktioniert! Super! Vielen Dank für deine wieder einmal großartige Unterstützung!
                              21:47:14.466DEBUGinfluxDBStart InfluxDB Backup ...
                              21:47:14.472DEBUGinfluxDBInfluxDB Backup tmp directory created
                              21:48:27.395DEBUGinfluxDBPacked 202MB so far...
                              21:48:37.472DEBUGinfluxDBPacked 406MB so far...
                              21:48:47.414DEBUGinfluxDBPacked 612MB so far...
                              21:48:57.400DEBUGinfluxDBPacked 797MB so far...
                              21:49:02.837DEBUGinfluxDBBackup created: /opt/iobroker/backups/influxDB_2025_11_21-21_47_15_ioBroker_backupiobroker.tar.gz
                              21:49:02.968DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_11_21-21_47_15_ioBroker_backupiobroker"
                              21:49:04.731DEBUGinfluxDBdone
                              Der Pi4 -> Pi5 ist wie Trabbi -> BMW ;-)
                              • L Offline
                                Laser
                                schrieb am zuletzt editiert von Laser
                                Bei mir wird influxdb seit 4 Wochen nicht mehr gesichert. Änderungen seit dem- nur Linux- Updates.
                                Backitup bleibt mit 100% CPU Auslastung hier stehen:
                                13:34:37.871DEBUGinfluxDBInfluxDB-Backup started ...
                                13:34:37.904DEBUGinfluxDBStart InfluxDB Backup ...
                                13:34:37.911DEBUGinfluxDBInfluxDB Backup tmp directory created
                                in der Konsole:
                                xxxx@neuheizung:~ $ ls
                                export influxdb2-client-2.7.5-linux-arm64.tar.gz README.md
                                influx influxdb2-client-2.7.5-linux-arm64.tar.gz.1
                                influxdata-archive.key LICENSE
                                die Zeile mit "export" ist rot
                                • L Laser
                                  in der Konsole:
                                  @Laser
                                  Das hast du nicht ordentlich über deinen Paketmanager installiert, scheint mir.
                                  NUTZ das Ding, dafür ist er ja da! Mit tar.gz machst du auf einem Debian i.d.R. gar nichts.
                                  • L Offline
                                    Laser
                                    Ich soll was genau über den Paketmanager installieren? Backitup? Influx habe ich seit über 1 Jahr nicht angefasst. Bis vor 4 Wochen funktionierte das Backup ja.
                                    sudo apt update und sudo apt upgrade gemacht.
                                    • L Laser
                                      @Laser sagte in BackItUp sichert InfluxDB nicht mehr:
                                      Zeig mal die Ausgabe davon. Ich befürchte, du hast da u. u. eine doppelte Installation.
                                      Einmal über den Paketmanager und dann eine 'wilde' Installation am Paketmanager vorbei.
                                      Warum sollte da sonst ein tarball in dem Verzeichnis liegen?
                                      • L Offline
                                        Laser
                                        Update:
                                        xxxx@neuheizung:~ $ sudo apt update
                                        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Get:4 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                                        Get:6 https://packages.grafana.com/enterprise/deb stable InRelease [7,660 B]
                                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Get:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [270 kB]
                                        Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [285 kB]
                                        Err:6 https://packages.grafana.com/enterprise/deb stable InRelease
                                          The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                        Fetched 666 kB in 4s (185 kB/s)
                                        2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                        W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                        W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                        W: Some index files failed to download. They have been ignored, or old ones used instead.
                                        • L Offline
                                          Laser
                                          Upgrade (die Vorversion ist natürlich weg):
                                          wieso gehen die Code-Tags nicht mehr?
                                          xxxx@neuheizung:~ $ sudo apt upgrade
                                          Calculating upgrade... Done
                                            linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.20+rpt-rpi-2712
                                            linux-headers-6.12.20+rpt-rpi-v8 linux-headers-6.12.25+rpt-common-rpi
                                            linux-headers-6.12.25+rpt-rpi-2712 linux-headers-6.12.25+rpt-rpi-v8
                                            linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.51+rpt-rpi-2712
                                            linux-headers-6.6.51+rpt-rpi-v8 linux-headers-6.6.62+rpt-common-rpi
                                            linux-headers-6.6.62+rpt-rpi-2712 linux-headers-6.6.62+rpt-rpi-v8
                                            linux-headers-6.6.74+rpt-common-rpi linux-headers-6.6.74+rpt-rpi-2712
                                            linux-headers-6.6.74+rpt-rpi-v8 linux-image-6.12.20+rpt-rpi-2712
                                            linux-image-6.12.20+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712
                                            linux-image-6.12.25+rpt-rpi-v8 linux-image-6.6.51+rpt-rpi-2712
                                            linux-image-6.6.51+rpt-rpi-v8 linux-image-6.6.62+rpt-rpi-2712
                                            linux-image-6.6.62+rpt-rpi-v8 linux-image-6.6.74+rpt-rpi-2712
                                            linux-image-6.6.74+rpt-rpi-v8 linux-kbuild-6.12.20+rpt
                                            linux-kbuild-6.12.25+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt
                                            linux-kbuild-6.6.74+rpt
                                          The following packages have been kept back:
                                            raspi-utils
                                          The following packages will be upgraded:
                                            rpi-eeprom
                                          1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                                          Need to get 3,940 kB of archives.
                                          After this operation, 5,245 kB of additional disk space will be used.
                                          Do you want to continue? [Y/n] y
                                          Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 28.9-1 [3,940 kB]
                                          Fetched 3,940 kB in 2s (2,295 kB/s)
                                          Reading changelogs... Done
                                          (Reading database ... 207535 files and directories currently installed.)
                                          Preparing to unpack .../rpi-eeprom_28.9-1_all.deb ...
                                          Unpacking rpi-eeprom (28.9-1) over (28.7-1~bookworm) ...
                                          Setting up rpi-eeprom (28.9-1) ...
                                          Processing triggers for man-db (2.11.2-2) ...
