  4. BackItUp sichert InfluxDB nicht mehr
    6.5k
36 Beiträge 3 Kommentatoren 1.5k Aufrufe 4 Beobachtet
    @legro
    sudo apt install influxdb2-cli
    auf dem Raspberry.
    legro
    @Thomas-Braun sagte in BackItUp sichert InfluxDB nicht mehr:
    Leider erhalte ich bloß einen weiteren Fehler ..
    pi@Pi5:~ $ sudo apt install influxdb2-cli
    Reading package lists... Done
    E: Unable to locate package influxdb2-cli
    pi@Pi5:~ $
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    • L legro
      pi@Pi5:~ $
      @legro
      Ist die influx-Quelle angelegt?
      sudo apt update
      apt policy influx*
      L 1 Antwort Letzte Antwort
        @legro
        sudo apt update
        apt policy influx*
        legro
        @Thomas-Braun
        pi@Pi5:/ $ sudo apt install influxdb2-cli
        pi@Pi5:/ $ sudo apt update
        apt policy influx*
        Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
        Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
        Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [54.9 kB]
        Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
        Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [283 kB]
        Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [268 kB]
        Err:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        Get:8 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [559 kB]
        Get:9 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [560 kB]
        W: GPG error: https://deb.nodesource.com/node_22.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        E: The repository 'https://deb.nodesource.com/node_22.x nodistro InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b13
          Version table:
             1.6.7~rc0-1+b13 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb:
          Installed: (none)
          Version table:
             1.6.7~rc0-1+b13 500
        Leider erhalte ich anschließend denselben Fehler beim Installieren wie zuvor.
        • L Offline
          legro
          @Thomas-Braun
          Vorgeschichte ..
          Ich bin ja von meine Pi 4 -> Pi 5 umgezogen. Ist hier ggf. verloren gegangen?
          Auf dem Pi 4 habe ich als Installationquelle die sog. "phantastischen Repositories" installiert.
          • L legro
            @Thomas-Braun
            apt policy influx*
            influxdb-client:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1+b13 500
            influxdb-dev:
              Installed: (none)
              Candidate: (none)
              Version table:
            influxdb:
              Installed: (none)
              Version table:
                 1.6.7~rc0-1+b13 500
            @legro sagte in BackItUp sichert InfluxDB nicht mehr:
            Weil die Quelle nicht angelegt wurde...
            Stell dich in dein home und leg es danach an:
            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
            • L legro
              @Thomas-Braun
              Vorgeschichte ..
              Externe Quellen müssen neu angelegt werden.
                legro
                schrieb am zuletzt editiert von legro
                Oh, da wird meine Dokumentation noch länger. ;-)
                Ich habe nun die Quellen neu angelegt. Anschließend sudo apt update & upgrade durchgeführt. Leider war das Ganze nicht erfolgreich.
                influxdb2-cli is already the newest version (2.7.5-2).
                The following packages were automatically installed and are no longer required:
                  libunwind8 linux-headers-6.12.34+rpt-common-rpi linux-kbuild-6.12.34+rpt rpicam-apps-lite
                Use 'sudo apt autoremove' to remove them.
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                L Thomas BraunT 2 Antworten Letzte Antwort
                • L legro
                  legro
                  Nach meiner Dokumentation hatte ich bei der Vorbereitung des Umzugs den Pi 5 nicht nur mit dem neuesten OS ausgestattet, sondern ich hatte vorsorglich bereits alle Repositories eingepflegt bevor ich mittels BackItUp den Umzug einläutete.
                  • L legro
                    Heißt: Das Paket ist schon installiert.
                      legro
                      @Thomas-Braun
                      Ich habe das Backup erneut angestoßen: Es funktioniert! Super! Vielen Dank für deine wieder einmal großartige Unterstützung!
                      21:47:14.466DEBUGinfluxDBStart InfluxDB Backup ...
                      21:47:14.472DEBUGinfluxDBInfluxDB Backup tmp directory created
                      21:48:27.395DEBUGinfluxDBPacked 202MB so far...
                      21:48:37.472DEBUGinfluxDBPacked 406MB so far...
                      21:48:47.414DEBUGinfluxDBPacked 612MB so far...
                      21:48:57.400DEBUGinfluxDBPacked 797MB so far...
                      21:49:02.837DEBUGinfluxDBBackup created: /opt/iobroker/backups/influxDB_2025_11_21-21_47_15_ioBroker_backupiobroker.tar.gz
                      21:49:02.968DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_11_21-21_47_15_ioBroker_backupiobroker"
                      21:49:04.731DEBUGinfluxDBdone
                      Der Pi4 -> Pi5 ist wie Trabbi -> BMW ;-)
                      • L Offline
                        Laser
                        schrieb am zuletzt editiert von Laser
                        Bei mir wird influxdb seit 4 Wochen nicht mehr gesichert. Änderungen seit dem- nur Linux- Updates.
                        Backitup bleibt mit 100% CPU Auslastung hier stehen:
                        13:34:37.871DEBUGinfluxDBInfluxDB-Backup started ...
                        13:34:37.904DEBUGinfluxDBStart InfluxDB Backup ...
                        13:34:37.911DEBUGinfluxDBInfluxDB Backup tmp directory created
                        in der Konsole:
                        xxxx@neuheizung:~ $ ls
                        export influxdb2-client-2.7.5-linux-arm64.tar.gz README.md
                        influx influxdb2-client-2.7.5-linux-arm64.tar.gz.1
                        influxdata-archive.key LICENSE
                        die Zeile mit "export" ist rot
                        • L Laser
                          in der Konsole:
                          @Laser
                          Das hast du nicht ordentlich über deinen Paketmanager installiert, scheint mir.
                          NUTZ das Ding, dafür ist er ja da! Mit tar.gz machst du auf einem Debian i.d.R. gar nichts.
                          • L Offline
                            Laser
                            Ich soll was genau über den Paketmanager installieren? Backitup? Influx habe ich seit über 1 Jahr nicht angefasst. Bis vor 4 Wochen funktionierte das Backup ja.
                            sudo apt update und sudo apt upgrade gemacht.
                            • L Laser
                              @Laser sagte in BackItUp sichert InfluxDB nicht mehr:
                              Zeig mal die Ausgabe davon. Ich befürchte, du hast da u. u. eine doppelte Installation.
                              Einmal über den Paketmanager und dann eine 'wilde' Installation am Paketmanager vorbei.
                              Warum sollte da sonst ein tarball in dem Verzeichnis liegen?
                              • L Offline
                                Laser
                                Update:
                                xxxx@neuheizung:~ $ sudo apt update
                                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                Get:4 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                                Hit:5 https://repos.influxdata.com/debian stable InRelease
                                Get:6 https://packages.grafana.com/enterprise/deb stable InRelease [7,660 B]
                                Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Get:8 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [270 kB]
                                Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [285 kB]
                                Err:6 https://packages.grafana.com/enterprise/deb stable InRelease
                                  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                Fetched 666 kB in 4s (185 kB/s)
                                2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                • L Offline
                                  Laser
                                  Upgrade (die Vorversion ist natürlich weg):
                                  wieso gehen die Code-Tags nicht mehr?
                                  xxxx@neuheizung:~ $ sudo apt upgrade
                                  Calculating upgrade... Done
                                    linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.20+rpt-rpi-2712
                                    linux-headers-6.12.20+rpt-rpi-v8 linux-headers-6.12.25+rpt-common-rpi
                                    linux-headers-6.12.25+rpt-rpi-2712 linux-headers-6.12.25+rpt-rpi-v8
                                    linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.51+rpt-rpi-2712
                                    linux-headers-6.6.51+rpt-rpi-v8 linux-headers-6.6.62+rpt-common-rpi
                                    linux-headers-6.6.62+rpt-rpi-2712 linux-headers-6.6.62+rpt-rpi-v8
                                    linux-headers-6.6.74+rpt-common-rpi linux-headers-6.6.74+rpt-rpi-2712
                                    linux-headers-6.6.74+rpt-rpi-v8 linux-image-6.12.20+rpt-rpi-2712
                                    linux-image-6.12.20+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712
                                    linux-image-6.12.25+rpt-rpi-v8 linux-image-6.6.51+rpt-rpi-2712
                                    linux-image-6.6.51+rpt-rpi-v8 linux-image-6.6.62+rpt-rpi-2712
                                    linux-image-6.6.62+rpt-rpi-v8 linux-image-6.6.74+rpt-rpi-2712
                                    linux-image-6.6.74+rpt-rpi-v8 linux-kbuild-6.12.20+rpt
                                    linux-kbuild-6.12.25+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt
                                    linux-kbuild-6.6.74+rpt
                                  The following packages have been kept back:
                                    raspi-utils
                                  The following packages will be upgraded:
                                    rpi-eeprom
                                  1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                                  Need to get 3,940 kB of archives.
                                  After this operation, 5,245 kB of additional disk space will be used.
                                  Do you want to continue? [Y/n] y
                                  Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 28.9-1 [3,940 kB]
                                  Fetched 3,940 kB in 2s (2,295 kB/s)
                                  Reading changelogs... Done
                                  (Reading database ... 207535 files and directories currently installed.)
                                  Preparing to unpack .../rpi-eeprom_28.9-1_all.deb ...
                                  Unpacking rpi-eeprom (28.9-1) over (28.7-1~bookworm) ...
                                  Setting up rpi-eeprom (28.9-1) ...
                                  Processing triggers for man-db (2.11.2-2) ...
                                  • L Laser
                                      raspi-utils
                                      rpi-eeprom
                                    Solche Ausgaben aus dem Terminal bitte in CodeTags, danke.
                                    raspi-utils
                                    sudo apt upgrade raspi-utils
                                    Und dann die Kiste einmal sauber durchstarten.
                                    iob stop
                                    sudo reboot
                                    • L Laser
                                        raspi-utils
                                        rpi-eeprom
                                      @Laser
                                      Und dann legst du das grafana-Repository nochmal danach neu an:
                                      • L Offline
                                        Laser
                                        Die Code Tags werden mir nicht mehr angeboten. Muß mal einen anderen Browser nehmen. z.Zt. Edge
                                        Liegt vermutlich an meinem verwendeten "schnell antworten" Code Tags gehen.
                                        Aber Backitup bleibt immer noch hängen...
                                        • L Laser
                                          Ligt vermutlich an meinem verwendeten "schnell antworten"
                                          Du darfst dir gerne Zeit für ein ordentliches Posting nehmen.
