  4. BackItUp sichert InfluxDB nicht mehr
    6.5k
36 Beiträge 3 Kommentatoren 1.5k Aufrufe 4 Beobachtet
  • L Laser
    Upgrade (die Vorversion ist natürlich weg):
    wieso gehen die Code-Tags nicht mehr?
    xxxx@neuheizung:~ $ sudo apt upgrade
    Reading package lists... Done
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.20+rpt-rpi-2712
      linux-headers-6.12.20+rpt-rpi-v8 linux-headers-6.12.25+rpt-common-rpi
      linux-headers-6.12.25+rpt-rpi-2712 linux-headers-6.12.25+rpt-rpi-v8
      linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.51+rpt-rpi-2712
      linux-headers-6.6.51+rpt-rpi-v8 linux-headers-6.6.62+rpt-common-rpi
      linux-headers-6.6.62+rpt-rpi-2712 linux-headers-6.6.62+rpt-rpi-v8
      linux-headers-6.6.74+rpt-common-rpi linux-headers-6.6.74+rpt-rpi-2712
      linux-headers-6.6.74+rpt-rpi-v8 linux-image-6.12.20+rpt-rpi-2712
      linux-image-6.12.20+rpt-rpi-v8 linux-image-6.12.25+rpt-rpi-2712
      linux-image-6.12.25+rpt-rpi-v8 linux-image-6.6.51+rpt-rpi-2712
      linux-image-6.6.51+rpt-rpi-v8 linux-image-6.6.62+rpt-rpi-2712
      linux-image-6.6.62+rpt-rpi-v8 linux-image-6.6.74+rpt-rpi-2712
      linux-image-6.6.74+rpt-rpi-v8 linux-kbuild-6.12.20+rpt
      linux-kbuild-6.12.25+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt
      linux-kbuild-6.6.74+rpt
    Use 'sudo apt autoremove' to remove them.
    The following packages have been kept back:
      raspi-utils
    The following packages will be upgraded:
      rpi-eeprom
    1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
    Need to get 3,940 kB of archives.
    After this operation, 5,245 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 28.9-1 [3,940 kB]
    Fetched 3,940 kB in 2s (2,295 kB/s)
    Reading changelogs... Done
    (Reading database ... 207535 files and directories currently installed.)
    Preparing to unpack .../rpi-eeprom_28.9-1_all.deb ...
    Unpacking rpi-eeprom (28.9-1) over (28.7-1~bookworm) ...
    Setting up rpi-eeprom (28.9-1) ...
    Processing triggers for man-db (2.11.2-2) ...
    @Laser sagte in BackItUp sichert InfluxDB nicht mehr:
    Solche Ausgaben aus dem Terminal bitte in CodeTags, danke.
    raspi-utils
    sudo apt upgrade raspi-utils
    Und dann die Kiste einmal sauber durchstarten.
    iob stop
    sudo reboot
    • L Laser
        raspi-utils
        rpi-eeprom
      @Laser
      Und dann legst du das grafana-Repository nochmal danach neu an:
      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
      • L Offline
        Laser
        schrieb am zuletzt editiert von Laser
        Die Code Tags werden mir nicht mehr angeboten. Muß mal einen anderen Browser nehmen. z.Zt. Edge
        Liegt vermutlich an meinem verwendeten "schnell antworten" Code Tags gehen.
        Aber Backitup bleibt immer noch hängen...
        • L Laser
          Ligt vermutlich an meinem verwendeten "schnell antworten"
          Du darfst dir gerne Zeit für ein ordentliches Posting nehmen.
          • L Offline
            Laser
            Code Tags gehen wieder. Habe die vorherigen Beiträge korrigiert. Ebenso den Rechtschreibfehler bei "ligt".
            Nur Backitup funktioniert immer noch nicht. Bleibt wie vorher stehen.
            "Wilde Installation" -warum sollte ich etwas "wild" installieren? Zumindest nicht absichtlich.
            • L Laser
              @Laser
              Was tust du dann mit den beiden Dateien in deinem /home?
              influxdb2-client-2.7.5-linux-arm64.tar.gz
              influxdb2-client-2.7.5-linux-arm64.tar.gz1
              Für eine ordentliche Installation via Paketmanager braucht man die nicht.
              Paketquellen aufgeräumt?
              Was sagt denn
              iob diag
              zum Gesamtzustand der Kiste?
              • L Offline
                Laser
                Wie diese beiden Dateien dort hinkommen, weiß ich nicht (mehr).
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                 Static hostname: neuheizung
                       Icon name: computer
                          Kernel: Linux 6.12.47+rpt-rpi-v8
                    Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 4 Model B Rev 1.5
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 15:13:07 up 24 min,  2 users,  load average: 2.27, 2.96, 2.57
                CPU threads: 4
                *** LIFE CYCLE STATUS ***
                Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                               Local time: Thu 2025-12-04 15:13:07 CET
                           Universal time: Thu 2025-12-04 14:13:07 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                otto
                HOME=/home/otto
                GROUPS=otto adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                *** DISPLAY-SERVER SETUP ***
                Display-Server:         false
                Unit display-manager.service could not be found.
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:            8.2G        2.5G        1.7G        1.2M        4.1G        5.7G
                Swap:           209M          0B        209M
                Total:          8.4G        2.5G        1.9G
                Active iob-Instances:   28
                         7819 M total memory
                         2365 M used memory
                         2809 M active memory
                         3195 M inactive memory
                         1624 M free memory
                           47 M buffer memory
                         3875 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                top - 15:13:08 up 24 min,  2 users,  load average: 2.27, 2.96, 2.57
                Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 10.0 us, 10.0 sy,  0.0 ni, 60.0 id, 10.0 wa,  0.0 hi, 10.0 si,  0.0 st
                MiB Mem :   7819.8 total,   1623.0 free,   2367.0 used,   3922.7 buff/cache
                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5452.8 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                29 CRITICAL ERRORS DETECTED!
                Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                *** FILESYSTEM ***
                udev           devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                /dev/sda2      ext4      110G   61G   44G  59% /
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
                tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                [Thu Dec  4 14:48:56 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=522926e5-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Thu Dec  4 14:48:59 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                [Thu Dec  4 14:49:01 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                Show mounted filesystems:
                TARGET           SOURCE    FSTYPE OPTIONS
                /                /dev/sda2 ext4   rw,noatime
                `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                36G     /var/
                34G     /var/lib/influxdb/engine/data/7b6dd0929a6bb818/autogen
                Archived and active journals take up 1023.5M in the file system.
                /opt/iobroker/backups:
                9.5G    /opt/iobroker/backups/
                814M    /opt/iobroker/backups/influxDB_2025_02_01-10_20_38_backupiobroker
                4.0K    /opt/iobroker/backups/influxDB_2023_11_20-10_53_21_backupiobroker
                /opt/iobroker/iobroker-data:
                7.5G    /opt/iobroker/iobroker-data/
                7.0G    /opt/iobroker/iobroker-data/history
                406M    /opt/iobroker/iobroker-data/files
                98M     /opt/iobroker/iobroker-data/backup-objects
                73M     /opt/iobroker/iobroker-data/files/vis-2
                26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                20M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
                /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE82E1IJ-if00-port0
                *** ZigBee Settings ***
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.19.6
                /usr/bin/node           v20.19.6
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.34.1
                nodejs:
                  Installed: 20.19.6-1nodesource1
                  Candidate: 20.19.6-1nodesource1
                  Version table:
                 *** 20.19.6-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                        100 /var/lib/dpkg/status
                     20.19.5-1nodesource1 1001
                     20.19.4-1nodesource1 1001
                     20.19.3-1nodesource1 1001
                     20.19.2-1nodesource1 1001
                     20.19.1-1nodesource1 1001
                     20.19.0-1nodesource1 1001
                     20.18.3-1nodesource1 1001
                     20.18.2-1nodesource1 1001
                     20.18.1-1nodesource1 1001
                     20.18.0-1nodesource1 1001
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     18.20.4+dfsg-1~deb12u1 500
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                debian11            debian11 (version: 4.0.24, hostname: debian11      , dead, uptime: 198)
                neuheizung          neuheizung (version: 7.0.7, hostname: neuheizung    , alive, uptime: 1438)
                Core adapters versions
                js-controller:  7.0.7
                admin:          7.7.19
                javascript:     9.0.11
                nodejs modules from github:     1
                +-- iobroker.vedirect@0.3.3 (git+ssh://git@github.com/DrozmotiX/ioBroker.vedirect.git#0a83b8b987ee94d0c49f2ee7299bbb8d5d329dde)
                Adapter State
                + system.adapter.admin.1                  : admin                 : neuheizung                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alias-manager.0          : alias-manager         : neuheizung                               - disabled
                + system.adapter.backitup.0               : backitup              : neuheizung                               -  enabled
                + system.adapter.discovery.0              : discovery             : neuheizung                               -  enabled
                + system.adapter.echarts.0                : echarts               : neuheizung                               -  enabled
                + system.adapter.email.0                  : email                 : neuheizung                               -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : neuheizung                               -  enabled
                  system.adapter.flot.0                   : flot                  : neuheizung                               - disabled
                + system.adapter.history.0                : history               : neuheizung                               -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : neuheizung                               -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : neuheizung                               -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : neuheizung                               -  enabled, port: 0
                  system.adapter.i2c.0                    : i2c                   : neuheizung                               - disabled
                + system.adapter.influxdb.0               : influxdb              : neuheizung                               -  enabled, port: 8086
                + system.adapter.javascript.0             : javascript            : neuheizung                               -  enabled
                + system.adapter.modbus.0                 : modbus                : neuheizung                               -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : neuheizung                               -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.opendtu.0                : opendtu               : neuheizung                               -  enabled
                + system.adapter.opendtu.1                : opendtu               : neuheizung                               -  enabled
                + system.adapter.opendtu.2                : opendtu               : neuheizung                               -  enabled
                + system.adapter.owfs.0                   : owfs                  : neuheizung                               -  enabled, port: 4304
                + system.adapter.rpi2.0                   : rpi2                  : neuheizung                               -  enabled
                + system.adapter.shelly.0                 : shelly                : neuheizung                               -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shelly.1                 : shelly                : neuheizung                               -  enabled, port: 1884, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : neuheizung                               -  enabled
                + system.adapter.simple-api.0             : simple-api            : neuheizung                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.sourceanalytix.0         : sourceanalytix        : neuheizung                               -  enabled
                + system.adapter.vedirect.0               : vedirect              : neuheizung                               -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : neuheizung                               -  enabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : neuheizung                               -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : neuheizung                               - disabled
                  system.adapter.vis-material.0           : vis-material          : neuheizung                               - disabled
                  system.adapter.vis-metro.0              : vis-metro             : neuheizung                               - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : neuheizung                               - disabled
                  system.adapter.vis.0                    : vis                   : neuheizung                               -  enabled
                + system.adapter.web.0                    : web                   : neuheizung                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Upgrade policy: none
                Installed ioBroker-Adapters
                Used repository: stable
                Adapter    "admin"        : 7.7.19   , installed 7.7.19
                Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                Adapter    "email"        : 2.0.4    , installed 2.0.4
                Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                Controller "js-controller": 7.0.7    , installed 7.0.7
                Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                Adapter    "owfs"         : 0.7.0    , installed 0.7.0
                Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                Adapter    "web"          : 7.0.8    , installed 7.0.8
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Objects and States
                Objects:        4514
                States:         3686
                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:4 https://repos.influxdata.com/debian stable InRelease
                Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6361       731/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       6885       909/iobroker.js-con
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       976        909/iobroker.js-con
                tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       9424       1141/io.hm-rpc.0
                tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       9453       1156/io.hm-rpc.1
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       10947      1355/io.shelly.1
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       9689       1385/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9634       1278/io.shelly.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          6363       731/sshd: /usr/sbin
                tcp6       0      0 :::3000                 :::*                    LISTEN      106        6928       908/grafana
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        6849       789/influxd
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9748       1430/io.simple-api.
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7305       939/io.admin.1
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13210      1464/io.web.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4920       574/avahi-daemon: r
                udp        0      0 0.0.0.0:35882           0.0.0.0:*                           104        4922       574/avahi-daemon: r
                udp6       0      0 fe80::75d1:70aa:4ea:546 :::*                                0          6414       676/NetworkManager
                udp6       0      0 :::5353                 :::*                                104        4921       574/avahi-daemon: r
                udp6       0      0 :::42613                :::*                                104        4923       574/avahi-daemon: r
                2025-12-04 14:51:10.912  - error: shelly.1 (1355) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'replace')
                2025-12-04 14:51:10.917  - error: shelly.1 (1355) [MQTT] Unable to get mqttprefix of client with id "shellypmminig3-543204701224"
                2025-12-04 14:51:12.448  - error: shelly.0 (1278) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-543204508220"
                2025-12-04 14:51:12.589  - error: shelly.0 (1278) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-80646fdbcf04"
                2025-12-04 14:51:13.460  - error: shelly.0 (1278) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'replace')
                2025-12-04 14:51:13.461  - error: shelly.0 (1278) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-543204505ee4"
                2025-12-04 14:51:16.076  - info: host.neuheizung instance system.adapter.web.0 in version "7.0.8" started with pid 1464
                2025-12-04 14:51:20.078  - info: host.neuheizung instance system.adapter.vis-2.0 in version "2.13.4" started with pid 1475
                2025-12-04 14:51:28.103  - info: host.neuheizung instance system.adapter.energiefluss.0 in version "3.6.2" started with pid 1505
                2025-12-04 14:51:33.143  - warn: energiefluss.0 (1505) The adapter could not find the state alias.0.ZaehlerET.zaehler-Watt! Please review your configuration of the adapter!
                2025-12-04 14:51:34.015  - info: host.neuheizung instance system.adapter.vis.0 terminated while should be started once
                2025-12-04 15:01:43.937  - error: hm-rega.0 (1086) post request error: socket hang up
                2025-12-04 15:01:43.942  - error: hm-rega.0 (1086) CCU 192.168.2.85 unreachable
                2025-12-04 15:05:56.744  - warn: opendtu.2 (1370) setInverterLimit axios error: Error: socket hang up
                2025-12-04 15:08:19.912  - warn: host.neuheizung "system.host.debian11" is offline
                2025-12-04 15:10:22.983  - info: host.neuheizung stopInstance system.adapter.backitup.0 (force=false, process=true)
                2025-12-04 15:10:23.034  - info: host.neuheizung stopInstance system.adapter.backitup.0 send kill signal
                2025-12-04 15:10:23.694  - info: host.neuheizung instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-12-04 15:10:27.575  - info: host.neuheizung instance system.adapter.backitup.0 in version "3.3.10" started with pid 3313
                2025-12-04 15:10:33.642  - error: backitup.0 (3313) Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.57/backup /opt/iobroker/backups
                mount error(16): Device or resource busy
                Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                2025-12-04 15:14:07.211  - warn: host.neuheizung "system.host.debian11" is offline
                2025-12-04 15:14:07.497  - warn: host.neuheizung "system.host.debian11" is offline
                iob diag has finished.
                Soll ich "bookworm" ersetzen oder erst mal nicht?
                • L Laser
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  otto
                  HOME=/home/otto
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           209M          0B        209M
                           7819 M total memory
                           2365 M used memory
                           1624 M free memory
                             47 M buffer memory
                           3875 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  *** FILESYSTEM ***
                  /var:
                  36G     /var/
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.19
                  javascript:     9.0.11
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        4514
                  States:         3686
                  Pending Updates: 0
                  Solltest du machen.
                  Dringendst anschauen!
                  Die Datenbank ist natürlich auch riesig:
                  nodejs v20.19.6
                  Nodejs auf v22 bringen.
                  Per
                  iob nodejs-update
                  Für grafana fehlt das Repository. Anlegen.
                  am besten.
                  Soll das Backup der influxdb auf die CIFS-Freigabe erfolgen? Da klemmt es jedenfalls:
                  • L Offline
                    Laser
                    Ich werde das jetzt abarbeiten!
                    • L Offline
                      Laser
                      Habe das System aktualisiert. Auf die CIFS-Freigabe wird auch das iobroker und Grafana gesichert. Das funktioniert. Warum hat die influx.db Sicherung keinen Zugriff?```
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 13 (trixie)
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       17:09:02 up 38 min,  1 user,  load average: 4.25, 3.28, 2.37
                      CPU threads: 4
                      Operating System is the current Debian stable version codenamed 'trixie'!
                      Current issues:
                      This system needs to be REBOOTED!
                                     Local time: Thu 2025-12-04 17:09:03 CET
                                 Universal time: Thu 2025-12-04 16:09:03 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      otto
                      HOME=/home/otto
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/otto
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            8.2G        2.8G         89M         14M        5.5G        5.4G
                      Swap:           209M          0B        209M
                      Total:          8.4G        2.8G        299M
                      Active iob-Instances:   27
                               7819 M total memory
                               2628 M used memory
                               3078 M active memory
                               4375 M inactive memory
                                 85 M free memory
                                 84 M buffer memory
                               5126 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 17:09:04 up 38 min,  1 user,  load average: 4.25, 3.28, 2.37
                      Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 26.2 us,  4.9 sy,  0.0 ni, 49.2 id, 18.0 wa,  0.0 hi,  1.6 si,  0.0 st
                      MiB Mem :   7819.7 total,     82.4 free,   2627.1 used,   5215.4 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5192.6 avail Mem
                      15 CRITICAL ERRORS DETECTED!
                      *** FILESYSTEM ***
                      tmpfs          tmpfs     1.6G   11M  1.6G   1% /run
                      /dev/sda2      ext4      110G   60G   45G  57% /
                      tmpfs          tmpfs     3.9G  2.8M  3.9G   1% /tmp
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                      /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
                      tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                      [Thu Dec  4 16:30:27 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=522926e5-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Thu Dec  4 16:30:31 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                      [Thu Dec  4 16:30:33 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                      /var:
                      36G     /var/
                      Archived and active journals take up 1009M in the file system.
                      9.7G    /opt/iobroker/backups/
                      402M    /opt/iobroker/iobroker-data/files
                      47M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/nodejs         v22.21.0
                      /usr/bin/node           v22.21.0
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      /usr/bin/corepack       0.34.0
                      nodejs:
                        Installed: 22.21.0-1nodesource1
                        Candidate: 22.21.0-1nodesource1
                        Version table:
                       *** 22.21.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           20.19.2+dfsg-1 500
                              500 http://deb.debian.org/debian trixie/main arm64 Packages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      neuheizung          neuheizung (version: 7.0.7, hostname: neuheizung    , alive, uptime: 1774)
                      admin:          7.7.19
                      javascript:     9.0.11
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        4491
                      States:         3671
                      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                      W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                      Hit:1 http://deb.debian.org/debian trixie InRelease
                      Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                      Hit:5 https://repos.influxdata.com/debian stable InRelease
                      Hit:6 https://apt.grafana.com stable InRelease
                      Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7652       1094/exim4
                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       33099      14861/io.mqtt.0
                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       31353      14831/io.shelly.1
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       31316      14801/io.shelly.0
                      tcp        0      0 192.168.2.54:2001       0.0.0.0:*               LISTEN      1001       32038      14637/io.hm-rpc.1
                      tcp        0      0 192.168.2.54:2010       0.0.0.0:*               LISTEN      1001       32903      14626/io.hm-rpc.0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7510       834/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       29396      14425/iobroker.js-c
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       29391      14425/iobroker.js-c
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          8368       834/sshd: /usr/sbin
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7653       1094/exim4
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        7007       850/influxd
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32386      14907/io.simple-api
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32444      14937/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30981      14447/io.admin.1
                      udp        0      0 0.0.0.0:42177           0.0.0.0:*                           104        7295       636/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7293       636/avahi-daemon: r
                      udp6       0      0 :::34902                :::*                                104        7296       636/avahi-daemon: r
                      udp6       0      0 fe80::75d1:70aa:4ea:546 :::*                                0          6823       721/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        7294       636/avahi-daemon: r
                      2025/12/04 16:55:47 INFO: Downloading metadata snapshot
                      2025/12/04 16:55:47 INFO: Backing up TSM for shard 1
                      2025/12/04 16:57:01 INFO: Backing up TSM for shard 2
                      2025/12/04 16:58:35 INFO: Backing up TSM for shard 3
                      2025/12/04 16:59:57 INFO: Backing up TSM for shard 4
                      2025/12/04 17:01:16 INFO: Backing up TSM for shard 5
                      2025/12/04 17:02:59 INFO: Backing up TSM for shard 12
                      Error: failed to backup bucket data: failed to download snapshot of shard 12: stat /opt/iobroker/backups/influxDB_2025_12_04-16_55_46_backupiobroker/20251204T155547Z.12.tar.gz: no such file or directory
                      2025-12-04 17:06:40.261  - warn: modbus.0 (14664) Error: undefined
                      2025-12-04 17:06:40.262  - error: modbus.0 (14664) Request timed out.
                      2025-12-04 17:06:40.263  - error: modbus.0 (14664) Cannot write single register [1]: {"err":"timeout","timeout":5000}
                      2025-12-04 17:06:40.461  - warn: modbus.0 (14664) [DevID_1] Poll error count: 6 code: "App Timeout"
                      2025-12-04 17:07:46.270  - warn: modbus.0 (14664) Error: undefined
                      2025-12-04 17:07:46.272  - error: modbus.0 (14664) Request timed out.
                      2025-12-04 17:07:46.272  - error: modbus.0 (14664) Cannot write single register [1]: {"err":"timeout","timeout":5000}
                      2025-12-04 17:07:46.469  - warn: modbus.0 (14664) [DevID_1] Poll error count: 7 code: "App Timeout"
                      2025-12-04 17:08:52.281  - warn: modbus.0 (14664) Error: undefined
                      2025-12-04 17:08:52.281  - error: modbus.0 (14664) Request timed out.
                      2025-12-04 17:08:52.282  - error: modbus.0 (14664) Cannot write single register [1]: {"err":"timeout","timeout":5000}
                      2025-12-04 17:08:52.478  - warn: modbus.0 (14664) [DevID_1] Poll error count: 8 code: "App Timeout"
                      2025-12-04 17:09:58.297  - warn: modbus.0 (14664) Error: undefined
                      2025-12-04 17:09:58.297  - error: modbus.0 (14664) Request timed out.
                      2025-12-04 17:09:58.298  - error: modbus.0 (14664) Cannot write single register [1]: {"err":"timeout","timeout":5000}
                      2025-12-04 17:09:58.500  - warn: modbus.0 (14664) [DevID_1] Poll error count: 9 code: "App Timeout"
                      Meldung im iob:
                      Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
                      influxDB: Error: Command failed: influx backup --bucket iobroker -t KTLmduvh_2ocvh25GueyRrQmob_hcMaVqg2XJUnEuE2iFYhhretw-PtP-sBEAsQiQOD0u68fhpwFnmrBAZeSmg== "/opt/iobroker/backups/influxDB_2025_12_04-16_55_46_backupiobroker"
                      grafana: Grafana is not available!
                      Grafana hat es irgenwie gekillt- ist weg!
                      EDIT- Neuinstall- Alles wieder vorhanden.
                      Werde das Backup nochmal starten und nicht abbrechen.
                      • L Offline
                        Laser
                        nochmal Backup angestoßen. Auf meinem Sicherungs-NAS Updates durchgeführt. Geschrieben wird wieder. Aber ein rückholbares influx-Backup ist nicht vorhanden. Jetzt (Ausschnitt mit influx) :
                        influxDB: Error: Command failed: influx backup --bucket iobroker -t KTLmduvh_2ocvh25GueyRrQmob_hcMaVqg2XJUnEuE2iFYhhretw-PtP-sBEAsQiQOD0u68fhpwFnmrBAZeSmg== "/opt/iobroker/backups/influxDB_2025_12_04-17_22_55_backupiobroker"
                        2025/12/04 17:22:56 INFO: Downloading metadata snapshot
                        2025/12/04 17:22:56 INFO: Backing up TSM for shard 1
                        2025/12/04 17:24:09 INFO: Backing up TSM for shard 2
                        2025/12/04 17:25:43 INFO: Backing up TSM for shard 3
                        2025/12/04 17:27:06 INFO: Backing up TSM for shard 4
                        2025/12/04 17:28:30 INFO: Backing up TSM for shard 5
                        2025/12/04 17:30:10 INFO: Backing up TSM for shard 12
                        2025/12/04 17:33:04 INFO: Backing up TSM for shard 20
                        2025/12/04 17:35:41 INFO: Backing up TSM for shard 28
                        2025/12/04 17:37:28 INFO: Backing up TSM for shard 36
                        2025/12/04 17:39:17 INFO: Backing up TSM for shard 44
                        2025/12/04 17:41:38 INFO: Backing up TSM for shard 52
                        2025/12/04 17:44:15 INFO: Backing up TSM for shard 60
                        2025/12/04 17:47:02 INFO: Backing up TSM for shard 68
                        2025/12/04 17:50:07 INFO: Backing up TSM for shard 76
                        2025/12/04 17:53:06 INFO: Backing up TSM for shard 84
                        2025/12/04 17:55:13 INFO: Backing up TSM for shard 92
                        Error: failed to backup bucket data: failed to download snapshot of shard 92: stat /opt/iobroker/backups/influxDB_2025_12_04-17_22_55_backupiobroker/20251204T162256Z.92.tar.gz: no such file or directory
                        • L Laser
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          otto
                          HOME=/home/otto
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   7819 M total memory
                                   2628 M used memory
                                     85 M free memory
                                     84 M buffer memory
                                   5126 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          36G     /var/
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.4
                          /usr/bin/npx            10.9.4
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.19
                          javascript:     9.0.11
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        4491
                          States:         3671
                          Pending Updates: 0
                          Meldung im iob:
                          Da sind Doubletten drin.
                          • L Offline
                            Laser
                            Steht exakt 2x das Gleiche drin. Habe 1* gelöscht.
                            • L Laser
                              Ja, deswegen ja auch die Doubletten...
                              • L Offline
                                Laser
                                Einfach mal abgewartet, was passiert. Heute wurde das Backup zur vorprogrammierten Zeit erstellt. Im IOBroker - BackItUp wurde nichts geändert. Lediglich der NAS wurde aktualisiert. Ob das die Ursache war?
                                • L Laser
                                  Ein aktuelles System ist nie verkehrt. Viele Dinge erledigen sich halt mit dem jeweils letzten Versionsstand.
