  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 119.7k Aufrufe
  • D
    D
    DAndre
    #221
    Не хочет
    ` > Поставь 2 npm:
    Код:
    cd /opt/iobroker
    sudo npm install -g npm@latest-2
    sudo npm install iobroker.js-controller –production `
    andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller --production
    ! > iobroker.js-controller@0.11.1 install /opt/iobroker/node_modules/iobroker.js-controller
    node lib/setup.js setup first
    ! fs.js:549
    return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    ! Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
    at Error (native)
    at Object.fs.openSync (fs.js:549:18)
    at Object.fs.writeFileSync (fs.js:1156:15)
    at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:536:23
    at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:557:11)
    at Module._compile (module.js:409:26)
    at Object.Module._extensions..js (module.js:416:10)
    at Module.load (module.js:343:32)
    at Function.Module._load (module.js:300:12)
    npm ERR! Linux 4.4.0-31-generic
    npm ERR! argv "/usr/bin/nodejs" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! node v4.4.7
    npm ERR! npm v2.15.9
    npm ERR! code ELIFECYCLE
    ! npm ERR! iobroker.js-controller@0.11.1 install: node lib/setup.js setup first
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.11.1 install script 'node lib/setup.js setup first'.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node lib/setup.js setup first
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs iobroker.js-controller
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:
    npm ERR! /opt/iobroker/npm-debug.log
    andrey@server:/opt/iobroker$</anonymous>
    <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
    Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
    • BluefoxB
      #222
      cd /opt/iobroker
      sudo chmod 777 * -R
      • D
        D
        DAndre
        #223
        не…...
        ! andrey@server:/opt/iobroker$ sudo chmod 777 * -R
        ! andrey@server:/opt/iobroker$ sudo npm install iobroker.js-controller –production
        ! > node lib/setup.js setup first
        ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/readable-stream requires isarray@'~1.0.0' but will load
        ! npm WARN unmet dependency /opt/iobroker/node_modules/isarray,
        ! npm WARN unmet dependency which is version 0.0.1
        ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires aws4@'^1.2.1' but will load
        ! npm WARN unmet dependency /opt/iobroker/node_modules/aws4,
        ! npm WARN unmet dependency which is version 0.4.2
        ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires qs@'~6.1.0' but will load
        ! npm WARN unmet dependency /opt/iobroker/node_modules/qs,
        ! npm WARN unmet dependency which is version 6.2.1
        ! npm WARN unmet dependency /opt/iobroker/node_modules/npm/node_modules/request requires tough-cookie@'~2.2.0' but will load
        ! npm WARN unmet dependency /opt/iobroker/node_modules/tough-cookie,
        ! npm WARN unmet dependency which is version 2.3.0
        ! iobroker.js-controller@0.11.1 node_modules/iobroker.js-controller
        ! ├── semver@4.3.6
        ! └── yargs@3.32.0 (camelcase@2.1.1, window-size@0.1.4)
        100000 извинений. после sudo iobroker restart Обновился и кажется работает :D :D
        • Z
          Z
          znammut
          #224
          Здравствуйте, у вас там косяк давно продолжающийся, в шелл скриптах перенос каретки виндузовый наблюдается. От этого не все работают. Это при первоначальной инсталляции точно.
          С уважением
          • BluefoxB
            #225
            @znammut:
            С уважением `
            В следующей версии будет поправлено. Спасибо.
            • A
              A
              andrey99986
              #226
              Какая версия nodejs рекомендуется?
              Сейчас поставил последнюю - v6.5.0, работает, но мало ли что…
              Как правильно инсталлировать ( в каком каталоге) node-red-node-serialport (https://www.npmjs.com/package/node-red-node-serialport) , чтобы node-red нормально его увидел?
              Iobroker установлен в /home/iobroker.
              Node-red при запуске логах ругается на отсутствие файлов "serialport.node".
              • E
                E
                electric
                #227
                @andrey99986:
                Сейчас поставил последнюю - v6.5.0, работает, но мало ли что… `
                Рекомендуется версия LTS (на данный момент 4.5.0)
                @andrey99986:
                Node-red при запуске логах ругается на отсутствие файлов "serialport.node". `
                Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля.
                • A
                  A
                  andrey99986
                  #228
                  @electric:
                  Если открыть настройки node-red, то там есть строка для ввода "Дополнительные NPM Модули" (через запятую), туда можно ввести название нужного модуля. `
                  Это понятно, но прежде чем вносить надо же его (serialport) установить - или драйвер сам с инета скачает и поставит?
                  • E
                    E
                    electric
                    #229
                    @andrey99986:
                    или драйвер сам с инета скачает и поставит? `
                    Именно! ;)
                    • A
                      A
                      andrey99986
                      #230
                      Отлично.
                      В данный момент в закладке "Драйвера" - только установленные, в логе "warning: Cannot read "http://download.iobroker.net/sources-dist.json""
                      Часто такое бывает?
                      • I
                        I
                        instalator
                        #231
                        @andrey99986:
                        Отлично.
                        Часто такое бывает? `
                        Бывает иногда, скоро заработает.
                        Высокий уровень Децибел вреден для здоровья!
                        http://blog.instalator.ru/
                        • V
                          V
                          Vlad_k
                          #232
                          ставлю брокер на очередную плату от планшета на процике Allwinner A33, сам брокер встал работает но при установке Javascript драйвера вываливает ошибки:
                          ! android@localhost:/opt/iobroker$ sudo npm install iobroker.javascript –production --prefix "/opt/iobroker"
                          ! npm WARN engine form-data@2.0.0: wanted: {"node":">= 0.12"} (current: {"node":"0.10.47","npm":"2.15.1"})
                          ! npm ERR! tar.unpack untar error /root/.npm/har-validator/2.0.6/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/node-uuid/1.4.7/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.3/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/http-signature/1.1.1/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/delayed-stream/1.0.0/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/tough-cookie/2.3.1/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/qs/6.2.1/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/cron-parser/1.1.0/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/mime-db/1.24.0/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/asynckit/0.4.0/package.tgz
                          ! npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.0.6/package.tgz
                          ! npm ERR! Linux 3.4.39
                          ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--prefix" "/opt/iobroker"
                          ! npm ERR! node v0.10.47
                          ! npm ERR! npm v2.15.1
                          ! npm ERR! code ENOSPC
                          ! npm ERR! errno 54
                          ! npm ERR! nospc ENOSPC, write
                          ! npm ERR! nospc This is most likely not a problem with npm itself
                          ! npm ERR! nospc and is related to insufficient space on your system.
                          ! npm ERR! /opt/iobroker/npm-debug.log
                          чем полечить?
                          • I
                            I
                            instalator
                            #233
                            @Vlad_k:
                            ! npm ERR! errno 54
                            чем полечить? `
                            Это не помогает?
                            • BluefoxB
                              #234
                              @Vlad_k:
                              ! npm ERR! errno 54
                              чем полечить? `
                              ENOSPC => error: no space
                              Так что полечи новой карточкой
                              • V
                                V
                                Vlad_k
                                #235
                                @Bluefox:
                                Так что полечи новой карточкой `
                                linux ставил на системную флешку забыл про сд карту… но подчистил место и все зашуршало.
                                ПС только счас заметил при одинаковом кол-ве работающих драйверов, линукс брокер жрет всего 100 метров а под виндой 361 оперативы, почему такая разница большая?
                                и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему
                                • H
                                  H
                                  Haus
                                  #236
                                  @Vlad_k:
                                  @Bluefox:
                                  и еще хотелка появилась, надо сделать экспорт списка установленных драйверов, для импорта и установки на чистую систему `
                                  Копируешь папку iobroker-data и все твои наработки, драйвера в новой системе.
                                  Если смотришь в админе то это только ioBroker данные, если перезапустишь iob ситуация может изменится.
                                  js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                  admin: 3.6.0
                                  javascript: 4.1.10
                                  web: 2.4.1 vis: 1.1.10
                                  cloud: 2.6.2
                                  Server: DELL FX170 / linux: Debian 9.5 Stretch
                                  Adapter: MegaD-2561, Mega-ES…
                                  • R
                                    R
                                    radon
                                    #237
                                    Ставил на виртуальные машины:
                                    • на Debian так и не встал, жаловался то на curl, то на https, в конце концов что-то его не устроило в python-rpi.gpio
                                    т.е. по сути до iobroker так и не дошло.
                                    • На ubuntu встало без проблем, что на версию с графическим интерфейсом. что на версию админ (хотя тут в консоли что-то страшное с кодировкой) iobroker заработал нормально
                                    • На Windows встал тоже без проблем.
                                    Вопрос:
                                    Как поставить на Debian? какого пакета не хватает?
                                    Образ брал с официального сайта, DVD
                                    • H
                                      H
                                      Haus
                                      #238
                                      @radon:
                                      Вопрос:
                                      Образ брал с официального сайта, DVD `
                                      Голый Debian всё под root
                                      apt-get update
                                      apt-get upgrade
                                      apt-get install curl build-essential
                                      curl -sL https://deb.nodesource.com/setup_4.x | bash -
                                      apt-get install -y nodejs
                                      mkdir /opt/iobroker
                                      cd /opt/iobroker
                                      npm install iobroker --unsafe-perm
                                      как то так
                                      admin: 3.6.0
                                      javascript: 4.1.10
                                      cloud: 2.6.2
                                      • E
                                        E
                                        evgeny_nd
                                        #239
                                        @Haus:
                                        @radon:
                                        Вопрос:
                                        apt-get update
                                        apt-get upgrade
                                        mkdir /opt/iobroker
                                        cd /opt/iobroker
                                        как то так `
                                        Подтверждаю что на Debian это рабочая инструкция, за исключением того что нужно добавить еще одну строку до "npm istall iobroker…"
                                        ln -s /usr/bin/nodejs /usr/bin/node
                                        и было бы хорошо, если бы это все выложили на оф. сайт (русскоязычный) в разделе установка.
                                        • BluefoxB
                                          #240
                                          http://www.iobroker.net/docu/?page_id=5637&lang=ru
