  4. Javascript: Probleme mit readdir : feature oder bug?
    6.6k
6 Beiträge 3 Kommentatoren 454 Aufrufe 2 Beobachtet
  • E Offline
    ente34
    Ich habe alle Adapter von stable auf latest ge-updated.
    Dabei ist mir aufgefallen, dass in Scripts das 'readdir' Fehler wirft
    const fs = require('fs');
    const util = require('util');
    const my_readdir = util.promisify(fs.readdir);
    const searchDir = '/tmp';
    async function FindFile(dir) {
        let rc = '';
        //console.log('### '+dir);
        try {
            let files = [];
            files = await my_readdir(dir);
            for (let file of files) {
                let fullpath = dir + '/' + file;
                rc = fullpath;
        } catch (e) {
            console.log(e);
        } finally {
            return rc;
    function execPromise(command) {
        return new Promise(function(resolve, reject) {
            exec(command, (error, stdout, stderr) => {
                if (error) {
                    //console.log(stderr);
                    reject(error);
                    return;
                resolve(stdout.trim());
    try {
        let result = FindFile(searchDir);
        //let result = await execPromise(`find ${searchDir} -type f `);
        log(result);
    } catch (e) {
        console.error(e.message);
    Es gibt die folgende log-Meldung:
    javascript.0
    	2025-07-27 11:42:01.749	info	script.js.Test.readdir: TypeError: Cannot read properties of undefined (reading 'ProtectFs') at readdir (/opt/iobroker/node_modules/iobroker.javascript/src/lib/protectFs.ts:625:14) at node:internal/util:438:7 at new Promise (<anonymous>) at readdir (node:internal/util:424:12) at FindFile (script.js.Test.readdir:114:23) at script.js.Test.readdir:142:18 at script.js.Test.readdir:152:3 at Script.runInContext (node:vm:149:12) at Script.runInNewContext (node:vm:154:17) at JavaScript.execute (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:2203:27)
    Die Alternative mit exec funktioniert.
    HomoranH haus-automatisierungH 2 Antworten Letzte Antwort
    • E ente34
          let rc = '';
          try {
              let files = [];
                  rc = fullpath;
          } catch (e) {
              console.log(e);
          } finally {
              return rc;
                  if (error) {
                      reject(error);
                      return;
      try {
          log(result);
      } catch (e) {
      javascript.0
      @ente34 sagte in Javascript: Probleme mit readdir : feature oder bug?:
      warum denn das?
      Damit hast du jetzt überall Betaversionen, die jede für sich noch Bugs enthalten kann.
      Zu jedem Adapter gibt es daher Betatester Threads im Forum, oder Issuetracking auf Github
      E 1 Antwort Letzte Antwort
        warum denn das?
        ente34
        @homoran Alles klar, danke für den Hinweis!
        • E ente34
              let rc = '';
              try {
                  let files = [];
                      rc = fullpath;
              } catch (e) {
                  console.log(e);
              } finally {
                  return rc;
                      if (error) {
                          reject(error);
                          return;
          try {
              log(result);
          } catch (e) {
          javascript.0
          haus-automatisierungH Offline
          Dafür gibt es eigentlich fs/promises. https://nodejs.org/api/fs.html#fspromisesreaddirpath-options
          Im Adapter wird fs vom node core überschrieben, damit man in manche Verzeichnisse nicht manuell schreibt (wie iobroker-data/files). Mit einem einfachen Beispiel als Bug melden (bist ja Beta-Tester).
          📚 Meine Dokumentation
            ente34
            @haus-automatisierung sagte in Javascript: Probleme mit readdir : feature oder bug?:
            Danke für die schnelle Antwort!
            Wo genau melden, javascript-Adapter, js-controller, ...?
            • E ente34
              javascript-Adapter
              https://github.com/ioBroker/ioBroker.javascript/issues
