  4. Anfrage Tahoma/Somfy IO Adapter
    5.2k
611 Beiträge 103 Kommentatoren 289.7k Aufrufe 86 Beobachtet
  • SparkyCHS Offline
    SparkyCHS Offline
    SparkyCH
    #141
    Hallo zusammen
    ich habe Probleme, den Adapter zu starten. Im Log erscheinen folgenden Meldungen:
    tahoma.0	2021-07-09 07:27:29.067	warn	(17898) Terminated (UNCAUGHT_EXCEPTION): Without reason
    tahoma.0	2021-07-09 07:27:29.065	info	(17898) terminating
    tahoma.0	2021-07-09 07:27:28.678	error	(17898) The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
    tahoma.0	2021-07-09 07:27:28.678	error	at processImmediate (internal/timers.js:463:21)
    tahoma.0	2021-07-09 07:27:28.678	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
    tahoma.0	2021-07-09 07:27:28.678	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
    tahoma.0	2021-07-09 07:27:28.678	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
    tahoma.0	2021-07-09 07:27:28.678	error	(17898) Error: The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
    tahoma.0	2021-07-09 07:27:28.677	error	(17898) unhandled promise rejection: The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
    tahoma.0	2021-07-09 07:27:28.677	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tahoma.0	2021-07-09 07:27:28.634	error	(17898) The state contains the forbidden properties relaunch, absence!
    tahoma.0	2021-07-09 07:27:28.633	error	at processImmediate (internal/timers.js:463:21)
    tahoma.0	2021-07-09 07:27:28.633	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
    tahoma.0	2021-07-09 07:27:28.633	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
    tahoma.0	2021-07-09 07:27:28.633	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
    tahoma.0	2021-07-09 07:27:28.633	error	(17898) Error: The state contains the forbidden properties relaunch, absence!
    tahoma.0	2021-07-09 07:27:28.632	error	(17898) unhandled promise rejection: The state contains the forbidden properties relaunch, absence!
    tahoma.0	2021-07-09 07:27:28.632	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tahoma.0	2021-07-09 07:27:28.629	error	(17898) The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
    tahoma.0	2021-07-09 07:27:28.629	error	at processImmediate (internal/timers.js:463:21)
    tahoma.0	2021-07-09 07:27:28.629	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
    tahoma.0	2021-07-09 07:27:28.629	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
    tahoma.0	2021-07-09 07:27:28.629	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
    tahoma.0	2021-07-09 07:27:28.629	error	(17898) Error: The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
    tahoma.0	2021-07-09 07:27:28.626	error	(17898) unhandled promise rejection: The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
    tahoma.0	2021-07-09 07:27:28.625	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tahoma.0	2021-07-09 07:27:27.194	info	(17898) [INFO] Configured polling interval: 20000
    tahoma.0	2021-07-09 07:27:27.170	info	(17898) [START] Starting adapter tahoma v0.3.2
    tahoma.0	2021-07-09 07:27:27.068	info	(17898) starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.1, js-controller: 3.2.16
    Verhalten: Ich starte den Adapter neu, die Ampel wechselt von rot nach orange, dann auf grün, nach einer Sekunde zurück auf orange, anschliessend wieder rot.
    Mein Setting: Neue Installation auf Raspberry 4, sonst sind praktisch noch keine Adapter installiert.
    Könnt ihr mir einen Tipp geben, was ich hier unternehmen könnte? Leider verstehe ich im Log nicht alles. Vielen Dank für eure Inputs.
    W 1 Antwort Letzte Antwort
    • SparkyCHS SparkyCH
      Hallo zusammen
      W Offline
      W Offline
      Willi-Wunder
      schrieb am zuletzt editiert von Willi-Wunder
      #142
      hab leider auch das Problem, dass der Adapter nicht mehr läuft. Ging bis vor ein paar Wochen eigentlich noch. Weiß nicht, ob es evtl an der neuen Firmware der Tahoma Box liegt, kamen in letzter Zeit ein paar, aktuell Tahoma Version 2021.2.4-17. Mein log sieht so aus:
      tahoma.0
      	2021-07-17 22:00:16.391	info	Login failed three times, waiting 2 minutes before retrying.
      tahoma.0
      	2021-07-17 22:00:16.389	warn	error during tahomalink request: undefined ->401 retry login
      tahoma.0
      	2021-07-17 22:00:16.180	warn	error during tahomalink request: undefined ->401 retry login
      tahoma.0
      	2021-07-17 22:00:16.096	warn	error during tahomalink request: undefined ->401 retry login
      tahoma.0
      	2021-07-17 22:00:16.018	warn	error during tahomalink request: undefined ->401 retry login
      tahoma.0
      	2021-07-17 22:00:15.924	warn	error during tahomalink request: undefined ->401 retry login
      tahoma.0
      	2021-07-17 22:00:15.674	info	[INFO] Configured polling interval: 20000
      tahoma.0
      	2021-07-17 22:00:15.637	info	[START] Starting adapter tahoma v0.3.3
      tahoma.0
      	2021-07-17 22:00:15.597	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
      host.raspberrypi
      	2021-07-17 22:00:13.926	info	instance system.adapter.tahoma.0 started with pid 2008
      host.raspberrypi
      	2021-07-17 21:59:43.880	info	Restart adapter system.adapter.tahoma.0 because enabled
      host.raspberrypi
      	2021-07-17 21:59:43.879	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      tahoma.0
      	2021-07-17 21:59:43.804	warn	Cannot get view: Connection is closed.
      tahoma.0
      	2021-07-17 21:59:43.803	warn	Cannot get view: Connection is closed.
      tahoma.0
      	2021-07-17 21:59:43.648	warn	get state error: DB closed
      tahoma.0
      	2021-07-17 21:59:42.914	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      tahoma.0
      	2021-07-17 21:59:42.913	info	terminating
      tahoma.0
      	2021-07-17 21:59:42.670	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.669	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2021-07-17 21:59:42.668	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.667	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2021-07-17 21:59:42.621	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.620	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2021-07-17 21:59:42.620	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.619	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2021-07-17 21:59:42.576	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.576	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2021-07-17 21:59:42.573	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
      tahoma.0
      	2021-07-17 21:59:42.572	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      tahoma.0
      	2021-07-17 21:59:41.840	info	[INFO] Configured polling interval: 20000
      tahoma.0
      	2021-07-17 21:59:41.761	info	[START] Starting adapter tahoma v0.3.3
      tahoma.0
      	2021-07-17 21:59:41.729	info	starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
      Anmeldung über die Web Oberfläche ist gerade auch gesperrt, (Too many requests, try again later)
      Hab schon gelesen, dass dieser Adapter leider nicht mehr gepflegt wird, vielleicht kann aber jemand anderes noch helfen, würde mich auch sehr freuen. Bei Somfy wird auch aktuell viel geändert, bis ende des Jahres soll es eine einheitliche App (Android - iOS) gegeben mit der die Box auch voll konfiguriert werden werden kann. Tahoma Premium Box und neue Switch Box soll eine App bekommen.....nur als Info wen es interessiert :-)
      Hab den Adapter schon mal paar Stunden ausgeschaltet gehabt und dann nochmal probiert, ging auch nicht. Auch eine Neuinstallation blieb erfolglos.
      Gruß Willi
      K 1 Antwort Letzte Antwort
      • W Willi-Wunder
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        tahoma.0
        Gruß Willi
        kassmann
        #143
        @willi-wunder bei mir das gleiche 😖
        • K kassmann
          W Offline
          W Offline
          Willi-Wunder
          #144
          Scheint ja bei einigen nicht mehr zu funktionieren. Liegt es an der neuen Version in der Tahoma Box oder evtl. an der neuen JS Version im iobroker? Kann hier mal jemand schreiben ob es aktuell überhaupt noch funktioniert und welche Versionen er hat? Würde vermutlich eine Fehlersuche erleichtern, weiß nicht wo ich ansetzen soll.......
          Habe momentan am laufen:
          Node.js v12.22.2
          JS 3.3.14
          Tahoma Adapter 0.3.2 / 0.3.3
          Tahoma Box 2021.2.4-17
          Vielen Dank.
          Gruß Willi
          integer63I K 2 Antworten Letzte Antwort
          • W Willi-Wunder
            Node.js v12.22.2
            JS 3.3.14
            Vielen Dank.
            Gruß Willi
            integer63I Offline
            integer63I Offline
            integer63
            #145
            @willi-wunder Bei mir läuft der Adapter - allerdings mit einer Connexoon Box:
            Node.js v12.16.3
            JS 3.1.4
            Tahoma Adapter 0.3.3
            Connexoon Box 2021.2.4
            • W Willi-Wunder
              Node.js v12.22.2
              JS 3.3.14
              Vielen Dank.
              Gruß Willi
              kassmann
              #146
              @willi-wunder bei mir läuft es stockend, immer mal Aussetzer, dann muss ich den Adapter für 5 Minuten stoppen und anschließend wieder starten… dann läuft es wieder für ein paar Tage.
              Raspi 4
              Node.js 14.17.2
              TaHoma Adapter 0.3.3
              TaHoma Box 2021.2.4-17
              • K kassmann
                Raspi 4
                Node.js 14.17.2
                W Offline
                W Offline
                Willi-Wunder
                #147
                @kassmann
                Welchen JS-Controller hast du am laufen? Befürchte das es hier an der neuen Version 3.3x liegen könnte.
                Bei einem Freund mit der Version3.2.16 läuft es auch noch.......
                Bei wem läuft es mit der 3.3x?
                Schade das der Entwickler des Adapters nicht mehr weiter macht, muss man aber so akzeptieren.
                Frage als Laie, könnte dies jemand anderes auch übernehmen? Hab leider vom Programmieren keinen Plan.....
                Gruß Willi
                K YellowballY 2 Antworten Letzte Antwort
                • W Willi-Wunder
                  @kassmann
                  Gruß Willi
                  kassmann
                  #148
                  @willi-wunder Servus, ich habe JS-Controller 3.3.14 installiert
                  • W Willi-Wunder
                    @kassmann
                    Gruß Willi
                    YellowballY Offline
                    YellowballY Offline
                    Yellowball
                    #149
                    @willi-wunder Ich habe Version 3.3.8 und bei mir funktioniert der Adapter (noch). Allerdings starte ich ihn jeden Morgen um 4:00 Uhr morgens über ein Script neu. Damit vermeide ich jetzt weitestgehend die Login-Fehler. Ich hoffe sehr dass sich mal jemand über den Adapter hermacht, weil ich 3 Somfy IO-Komponenten im Einsatz habe: 2 x Markisensteuerung und 1 x Dimmer für Sommergarten-Spots.
                    ioBroker | Raspberry Pi Zero,1,2,3,4 | Proxmox | Philips HUE | AVM | Broadlink Pro| Amazon Echo Dot, Echo, Echo Show | KODI | u.v.m
                    E 1 Antwort Letzte Antwort
                    • YellowballY Yellowball
                      el_malto
                      #150
                      @yellowball sagte in Anfrage Tahoma/Somfy IO Adapter:
                      Kleiner Tipp auch wenn OT: Du musst nicht extra ein Skript dafür machen. Unter "Instanzen" einfach den "Expertenmodus" einschalten und dann bekommst du eine neue Spalte mit "Neu starten". Da kannst du dann die Zeit eintragen.
                      YellowballY 1 Antwort Letzte Antwort
                      • E el_malto
                        YellowballY Offline
                        YellowballY Offline
                        Yellowball
                        #151
                        @el_malto sagte in Anfrage Tahoma/Somfy IO Adapter:
                        Ich weiß, aber das bringt leider nichts, denn zwischen Stop und Start sollten ca. 20 Minuten liegen, weil man sonst wieder den obskuren Login-Fehler bekommt, obwohl das Passwort richtig ist. Daher stoppe ich per Script die Instanz, 20 Minuten Delay und dann Start.
                          W Offline
                          W Offline
                          Willi-Wunder
                          #152
                          Also ich bekomme den Adpater nicht mehr zum Laufen. Timeout auch schon auf 50000 gestellt, zuvor paar Stunden abgeschaltet gehabt und dann auch nochmal die Zugangsdaten neu eingegeben. Leuchtet kurz mal grün für 1-2 sek. danach wieder rot. Tja, wenn sich keiner mehr für die Adapterpflege findet war es das wohl..... sehr schade.
                          ExcodiburE 1 Antwort Letzte Antwort
                          • W Willi-Wunder
                            ExcodiburE Offline
                            ExcodiburE Offline
                            Excodibur
                            #153
                            @willi-wunder Bei mir funktioniert der Tahoma-Adapter im Moment einwandfrei. Bei Somfy sind für den 3. August Wartungsarbeiten angekündigt, aber wie gesagt, im Moment läuft es.
                            Da ich den Adapter für unsere IO Rolläden selbst verwende, würde ich im Ernstfall auch selbst den Code patchen, oder ganz reimplementieren, falls Somfy z.B. massiv die API umstellen würde. Aktuell funktionier es bei mir sowohl mit aktuellen Adaptern + JS-Controller auf stable, als auch latest (Beta) Branch.
                            Kannst du hier vielleicht mal Logausgaben posten (oder im Adapter ein Issue aufmachen und hier verlinken)? Idealerweise mit DEBUG-Loglevel.
                            • ExcodiburE Excodibur
                              W Offline
                              W Offline
                              Willi-Wunder
                              #154
                              @excodibur
                              Vielen Dank für deine Info. Dachte es liegt tatsächlich an den neuen Versionen vom iobroker. Haben ja doch einige das Problem mit dem Adapter was man so ließt. Das heißt du könntest den Adapter am laufen erhalten wenn ich das richtig verstehe? :-)
                              Somfy ist momentan viel mit der Switch und der Classic Box beschäftigt, soll ja spätestens nächstes Frühjahr nur noch eine Software dafür geben.....
                              Hier mein Log:
                              2021-08-01 21:01:11.182 - info: host.raspberrypi "system.adapter.tahoma.0" enabled
                              2021-08-01 21:01:11.386 - info: host.raspberrypi instance system.adapter.tahoma.0 started with pid 16504
                              2021-08-01 21:01:12.745 - debug: tahoma.0 (16504) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2021-08-01 21:01:12.781 - debug: tahoma.0 (16504) Objects client ready ... initialize now
                              2021-08-01 21:01:12.784 - debug: tahoma.0 (16504) Objects create System PubSub Client
                              2021-08-01 21:01:12.786 - debug: tahoma.0 (16504) Objects create User PubSub Client
                              2021-08-01 21:01:12.787 - debug: tahoma.0 (16504) Objects client initialize lua scripts
                              2021-08-01 21:01:12.811 - debug: tahoma.0 (16504) Objects connected to redis: 127.0.0.1:9001
                              2021-08-01 21:01:12.820 - debug: tahoma.0 (16504) objectDB connected
                              2021-08-01 21:01:12.822 - debug: tahoma.0 (16504) Redis States: Use Redis connection: 127.0.0.1:9000
                              2021-08-01 21:01:12.831 - debug: tahoma.0 (16504) States create System PubSub Client
                              2021-08-01 21:01:12.832 - debug: tahoma.0 (16504) States create User PubSub Client
                              2021-08-01 21:01:12.840 - debug: tahoma.0 (16504) States connected to redis: 127.0.0.1:9000
                              2021-08-01 21:01:12.841 - debug: tahoma.0 (16504) statesDB connected
                              2021-08-01 21:01:13.064 - info: tahoma.0 (16504) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
                              2021-08-01 21:01:13.095 - info: tahoma.0 (16504) [START] Starting adapter tahoma v0.3.3
                              2021-08-01 21:01:13.132 - info: tahoma.0 (16504) [INFO] Configured polling interval: 50000
                              2021-08-01 21:01:13.133 - debug: tahoma.0 (16504) [START] Started Adapter
                              2021-08-01 21:01:13.136 - debug: tahoma.0 (16504) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/login with payload: +++redacted+++
                              2021-08-01 21:01:13.330 - debug: tahoma.0 (16504) stateChange tahoma.0.update {"val":false,"ack":true,"ts":1627844473319,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551065625}
                              2021-08-01 21:01:13.493 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/enduser/mainAccount with payload:{}
                              2021-08-01 21:01:13.518 - debug: tahoma.0 (16504) stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1627844473514,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1627844473514}
                              2021-08-01 21:01:13.577 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup with payload:{}
                              2021-08-01 21:01:13.582 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/actionGroups with payload:{}
                              2021-08-01 21:01:13.692 - debug: tahoma.0 (16504) setState actionGroups.Öffnen.oid => 10aa67c7-a17e-4ab2-96f0-f98656463d9c
                              2021-08-01 21:01:13.693 - debug: tahoma.0 (16504) setState actionGroups.Öffnen.commands.execute => false
                              2021-08-01 21:01:13.694 - debug: tahoma.0 (16504) setState actionGroups.Schließen.oid => 171e14e2-a1fa-4a51-a874-dc72a4f9dd09
                              2021-08-01 21:01:13.694 - debug: tahoma.0 (16504) setState actionGroups.Schließen.commands.execute => false
                              2021-08-01 21:01:13.695 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_ein.oid => a5b7218e-9378-4dfe-8b16-6237dcf1c2b7
                              2021-08-01 21:01:13.695 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_ein.commands.execute => false
                              2021-08-01 21:01:13.700 - debug: tahoma.0 (16504) setState actionGroups.Lüften.oid => a69a2669-a0db-4f54-a4f5-96a9eed64628
                              2021-08-01 21:01:13.701 - debug: tahoma.0 (16504) setState actionGroups.Lüften.commands.execute => false
                              2021-08-01 21:01:13.701 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_aus.oid => f811d8aa-c0ca-4347-9739-9cdf4b1424c9
                              2021-08-01 21:01:13.702 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_aus.commands.execute => false
                              2021-08-01 21:01:13.716 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Öffnen.oid {"val":"10aa67c7-a17e-4ab2-96f0-f98656463d9c","ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                              2021-08-01 21:01:13.720 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Öffnen.commands.execute {"val":false,"ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                              2021-08-01 21:01:13.724 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Schließen.oid {"val":"171e14e2-a1fa-4a51-a874-dc72a4f9dd09","ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                              2021-08-01 21:01:13.727 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Schließen.commands.execute {"val":false,"ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                              2021-08-01 21:01:13.733 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_ein.oid {"val":"a5b7218e-9378-4dfe-8b16-6237dcf1c2b7","ack":true,"ts":1627844473711,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                              2021-08-01 21:01:13.735 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_ein.commands.execute {"val":false,"ack":true,"ts":1627844473711,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                              2021-08-01 21:01:13.736 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüften.oid {"val":"a69a2669-a0db-4f54-a4f5-96a9eed64628","ack":true,"ts":1627844473713,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066075}
                              2021-08-01 21:01:13.739 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüften.commands.execute {"val":false,"ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066101}
                              2021-08-01 21:01:13.743 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_aus.oid {"val":"f811d8aa-c0ca-4347-9739-9cdf4b1424c9","ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066102}
                              2021-08-01 21:01:13.746 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_aus.commands.execute {"val":false,"ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066232}
                              2021-08-01 21:01:13.947 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.gatewayId => xxxx-xxxx-xxxx
                              2021-08-01 21:01:13.948 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.type => 29
                              2021-08-01 21:01:13.949 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.subType => 14
                              2021-08-01 21:01:13.949 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.placeOID => b80f5c61-7e8e-4862-9705-1a1fc4b2e4ff
                              2021-08-01 21:01:13.950 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.alive => false
                              2021-08-01 21:01:13.950 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.timeReliable => false
                              2021-08-01 21:01:13.951 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.connectivity.status => OK
                              2021-08-01 21:01:13.951 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.connectivity.protocolVersion => 2021.2.4
                              2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.upToDate => false
                              2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.updateStatus => UP_TO_DATE
                              2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.syncInProgress => false
                              2021-08-01 21:01:13.953 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.mode => ACTIVE
                              2021-08-01 21:01:13.953 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.functions => INTERNET_AUTHORIZATION,SCENARIO_DOWNLOAD,SCENARIO_AUTO_LAUNCHING,SCENARIO_TELECO_LAUNCHING,INTERNET_UPLOAD,INTERNET_UPDATE,TRIGGERS_SENSORS
                              2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.creationTime => 1469357137000
                              2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.lastUpdateTime => 1619290314000
                              2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.city => Traumland
                              2021-08-01 21:01:13.955 - debug: tahoma.0 (16504) setState location.country => Germany
                              2021-08-01 21:01:13.955 - debug: tahoma.0 (16504) setState location.postalCode => 66666
                              2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.addressLine1 => Himmelstor 7
                              2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.addressLine2 => 0
                              2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.timezone => Europe/Berlin
                              2021-08-01 21:01:13.957 - debug: tahoma.0 (16504) setState location.longitude => 11.5713
                              2021-08-01 21:01:13.957 - debug: tahoma.0 (16504) setState location.latitude => 49.9456
                              2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightMode => 2
                              2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightAngle => CIVIL
                              2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightCity => berlin
                              2021-08-01 21:01:13.959 - debug: tahoma.0 (16504) setState location.summerSolsticeDuskMinutes => 1290
                              2021-08-01 21:01:13.959 - debug: tahoma.0 (16504) setState location.winterSolsticeDuskMinutes => 990
                              2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.twilightOffsetEnabled => false
                              2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.dawnOffset => 0
                              2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.duskOffset => -15
                              2021-08-01 21:01:13.961 - debug: tahoma.0 (16504) setState location.countryCode => DE
                              2021-08-01 21:01:13.961 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack) => 0
                              2021-08-01 21:01:13.962 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack).deviceURL => homekit://xxxx-xxxx-xxxx/stack
                              2021-08-01 21:01:13.962 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack).commands.deleteControllers => false
                              2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm => 0
                              2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm.deviceURL => internal://xxxx-xxxx-xxxx/alarm/0
                              2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm.states.core:NameState => TSK Alarm
                              2021-08-01 21:01:13.964 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:CurrentAlarmModeState => off
                              2021-08-01 21:01:13.964 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:AlarmDelayState => 60
                              2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:TargetAlarmModeState => off
                              2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:IntrusionDetectedState => notDetected
                              2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmOff => false
                              2021-08-01 21:01:13.966 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmOn => false
                              2021-08-01 21:01:13.966 - debug: tahoma.0 (16504) setState devices.Alarm.commands.arm => false
                              2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.disarm => false
                              2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.getName => false
                              2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.off => false
                              2021-08-01 21:01:13.968 - debug: tahoma.0 (16504) setState devices.Alarm.commands.on => false
                              2021-08-01 21:01:13.968 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshAlarmDelay => false
                              2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshCurrentAlarmMode => false
                              2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshIntrusionDetected => false
                              2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmPartial1 => false
                              2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmPartial2 => false
                              2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste => 0
                              2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.deviceURL => internal://xxxx-xxxx-xxxx/pod/0
                              2021-08-01 21:01:13.971 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:NameState => Box
                              2021-08-01 21:01:13.971 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.internal:BatteryStatusState => no
                              2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:CyclicButtonState => stop
                              2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.internal:LightingLedPodModeState => 0.2
                              2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:CountryCodeState => DE
                              2021-08-01 21:01:13.973 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:LocalIPv4AddressState => 192.168.2.140
                              2021-08-01 21:01:13.973 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.getName => false
                              2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.update => false
                              2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.activateCalendar => false
                              2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.deactivateCalendar => false
                              2021-08-01 21:01:13.975 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshBatteryStatus => false
                              2021-08-01 21:01:13.975 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshPodMode => false
                              2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshUpdateStatus => false
                              2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.setPodLedOff => false
                              2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.setPodLedOn => false
                              2021-08-01 21:01:13.977 - debug: tahoma.0 (16504) setState devices.Stehlampe => 0
                              2021-08-01 21:01:13.977 - debug: tahoma.0 (16504) setState devices.Stehlampe.deviceURL => io://xxxx-xxxx-xxxx/11816111
                              2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:NameState => Stehlampe
                              2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:StatusState => available
                              2021-08-01 21:01:13.979 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:13.979 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:RSSILevelState => 88
                              2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:OnOffState => off
                              2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.getName => false
                              2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.identify => false
                              2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.off => false
                              2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.on => false
                              2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.startIdentify => false
                              2021-08-01 21:01:13.982 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.stopIdentify => false
                              2021-08-01 21:01:13.982 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer => 0
                              2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.deviceURL => io://xxxx-xxxx-xxxx/1211100
                              2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:NameState => 3. Esszimmer
                              2021-08-01 21:01:13.984 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:13.984 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:StatusState => available
                              2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:RSSILevelState => 100
                              2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:MovingState => false
                              2021-08-01 21:01:13.986 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ManufacturerSettingsState => [object Object]
                              2021-08-01 21:01:13.988 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-08-01 21:01:13.988 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:13.991 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              at Immediate. (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23)
                              2021-08-01 21:01:13.992 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:13.993 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ClosureState => 0
                              2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ClosureState:slow => 0
                              2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:OpenClosedState => open
                              2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:Memorized1PositionState => 41
                              2021-08-01 21:01:13.995 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:TargetClosureState => 0
                              2021-08-01 21:01:13.995 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:TargetClosureState:slow => 0
                              2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.close => false
                              2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.close:slow => false
                              2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.down => false
                              2021-08-01 21:01:13.997 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.down:slow => false
                              2021-08-01 21:01:13.997 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.getName => false
                              2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.identify => false
                              2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.my => false
                              2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.open => false
                              2021-08-01 21:01:13.999 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.open:slow => false
                              2021-08-01 21:01:13.999 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.startIdentify => false
                              2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.stop => false
                              2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.stopIdentify => false
                              2021-08-01 21:01:14.001 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.up => false
                              2021-08-01 21:01:14.001 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.up:slow => false
                              2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.sendIOKey => false
                              2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe => 0
                              2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.deviceURL => io://xxxx-xxxx-xxxx/12362917
                              2021-08-01 21:01:14.004 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:NameState => 2. Küche Türe
                              2021-08-01 21:01:14.004 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.io:PriorityLockOriginatorState => user
                              2021-08-01 21:01:14.005 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:PriorityLockTimerState => 7650
                              2021-08-01 21:01:14.005 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.io:PriorityLockLevelState => userLevel2
                              2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:StatusState => available
                              2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:RSSILevelState => 84
                              2021-08-01 21:01:14.007 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:MovingState => false
                              2021-08-01 21:01:14.007 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:ClosureState => 0
                              2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:OpenClosedState => open
                              2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:Memorized1PositionState => 60
                              2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:TargetClosureState => 0
                              2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.close => false
                              2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.down => false
                              2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.getName => false
                              2021-08-01 21:01:14.010 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.identify => false
                              2021-08-01 21:01:14.010 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.my => false
                              2021-08-01 21:01:14.011 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.open => false
                              2021-08-01 21:01:14.014 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:14.014 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.startIdentify => false
                              2021-08-01 21:01:14.015 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.stop => false
                              2021-08-01 21:01:14.018 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.stopIdentify => false
                              2021-08-01 21:01:14.019 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.up => false
                              2021-08-01 21:01:14.019 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.020 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.sendIOKey => false
                              2021-08-01 21:01:14.023 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.024 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:14.024 - debug: tahoma.0 (16504) setState devices.Temp__Sensor => 0
                              2021-08-01 21:01:14.025 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.deviceURL => io://xxxx-xxxx-xxxx/12415680
                              2021-08-01 21:01:14.025 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:StatusState => available
                              2021-08-01 21:01:14.026 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.026 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:RSSILevelState => 78
                              2021-08-01 21:01:14.027 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:TemperatureState => 17.400000000000034
                              2021-08-01 21:01:14.027 - debug: tahoma.0 (16504) setState devices.Dachboden => 0
                              2021-08-01 21:01:14.028 - debug: tahoma.0 (16504) setState devices.Dachboden.deviceURL => io://xxxx-xxxx-xxxx/13336923
                              2021-08-01 21:01:14.028 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:StatusState => available
                              2021-08-01 21:01:14.030 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.030 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:RSSILevelState => 60
                              2021-08-01 21:01:14.031 - debug: tahoma.0 (16504) setState devices.EG_Flur => 0
                              2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.deviceURL => io://xxxx-xxxx-xxxx/13571339
                              2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:StatusState => available
                              2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:RSSILevelState => 76
                              2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.1_OG_Emma => 0
                              2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.deviceURL => io://xxxx-xxxx-xxxx/13982509
                              2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:StatusState => available
                              2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:RSSILevelState => 82
                              2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur => 0
                              2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur.deviceURL => io://xxxx-xxxx-xxxx/14696015
                              2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.038 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.042 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.042 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:StatusState => available
                              2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:RSSILevelState => 76
                              2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern => 0
                              2021-08-01 21:01:14.044 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.deviceURL => io://xxxx-xxxx-xxxx/14704656
                              2021-08-01 21:01:14.044 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:StatusState => available
                              2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:RSSILevelState => 100
                              2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.IO_(14918158) => 0
                              2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.IO_(14918158).deviceURL => io://xxxx-xxxx-xxxx/14918158
                              2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.discoverSomfyUnsetActuators => false
                              2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.joinNetwork => false
                              2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.resetNetworkSecurity => false
                              2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.shareNetwork => false
                              2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur => 0
                              2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.deviceURL => io://xxxx-xxxx-xxxx/3045215
                              2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.io:MaintenanceSensorPartBatteryState => low
                              2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:StatusState => available
                              2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:SensorDefectState => maintenanceRequired
                              2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:RSSILevelState => 74
                              2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer => 0
                              2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.deviceURL => io://xxxx-xxxx-xxxx/3268948
                              2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:NameState => 5. Wohnzimmer
                              2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:StatusState => available
                              2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:RSSILevelState => 100
                              2021-08-01 21:01:14.053 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:MovingState => false
                              2021-08-01 21:01:14.053 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ManufacturerSettingsState => [object Object]
                              2021-08-01 21:01:14.054 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-08-01 21:01:14.054 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.054 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.055 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.055 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ClosureState => 0
                              2021-08-01 21:01:14.056 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ClosureState:slow => 0
                              2021-08-01 21:01:14.056 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:OpenClosedState => open
                              2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:Memorized1PositionState => 49
                              2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:TargetClosureState => 0
                              2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:TargetClosureState:slow => 0
                              2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.close => false
                              2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.close:slow => false
                              2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.down => false
                              2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.down:slow => false
                              2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.getName => false
                              2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.identify => false
                              2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.my => false
                              2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.open => false
                              2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.open:slow => false
                              2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.startIdentify => false
                              2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.stop => false
                              2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.stopIdentify => false
                              2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.up => false
                              2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.up:slow => false
                              2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.sendIOKey => false
                              2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.Sunis => 0
                              2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.deviceURL => io://xxxx-xxxx-xxxx/3700079
                              2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:StatusState => available
                              2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.069 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:RSSILevelState => 68
                              2021-08-01 21:01:14.070 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:LuminanceState => 120
                              2021-08-01 21:01:14.070 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2 => 0
                              2021-08-01 21:01:14.071 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.deviceURL => io://xxxx-xxxx-xxxx/3802238
                              2021-08-01 21:01:14.071 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:SmokeState => notDetected
                              2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.io:MaintenanceRadioPartBatteryState => normal
                              2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.io:MaintenanceSensorPartBatteryState => normal
                              2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:StatusState => available
                              2021-08-01 21:01:14.073 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.073 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:RSSILevelState => 78
                              2021-08-01 21:01:14.074 - debug: tahoma.0 (16504) setState devices.4__Balkontüre => 0
                              2021-08-01 21:01:14.074 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.deviceURL => io://xxxx-xxxx-xxxx/5209602
                              2021-08-01 21:01:14.075 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:NameState => 4. Balkontüre
                              2021-08-01 21:01:14.075 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:14.076 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:StatusState => available
                              2021-08-01 21:01:14.076 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.077 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:RSSILevelState => 100
                              2021-08-01 21:01:14.077 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:MovingState => false
                              2021-08-01 21:01:14.078 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ManufacturerSettingsState => [object Object]
                              2021-08-01 21:01:14.079 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-08-01 21:01:14.080 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.081 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.081 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:14.083 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ClosureState => 0
                              2021-08-01 21:01:14.084 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ClosureState:slow => 0
                              2021-08-01 21:01:14.084 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:OpenClosedState => open
                              2021-08-01 21:01:14.085 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:Memorized1PositionState => 48
                              2021-08-01 21:01:14.086 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:TargetClosureState => 0
                              2021-08-01 21:01:14.087 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:TargetClosureState:slow => 0
                              2021-08-01 21:01:14.088 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.close => false
                              2021-08-01 21:01:14.089 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.close:slow => false
                              2021-08-01 21:01:14.089 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.down => false
                              2021-08-01 21:01:14.090 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.down:slow => false
                              2021-08-01 21:01:14.095 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.getName => false
                              2021-08-01 21:01:14.095 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.identify => false
                              2021-08-01 21:01:14.096 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.my => false
                              2021-08-01 21:01:14.097 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.open => false
                              2021-08-01 21:01:14.098 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.open:slow => false
                              2021-08-01 21:01:14.099 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:14.100 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.startIdentify => false
                              2021-08-01 21:01:14.101 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.stop => false
                              2021-08-01 21:01:14.102 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.stopIdentify => false
                              2021-08-01 21:01:14.103 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.up => false
                              2021-08-01 21:01:14.104 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.up:slow => false
                              2021-08-01 21:01:14.105 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.106 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.sendIOKey => false
                              2021-08-01 21:01:14.107 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.107 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:14.108 - debug: tahoma.0 (16504) setState devices.Sunis_2 => 0
                              2021-08-01 21:01:14.108 - debug: tahoma.0 (16504) setState devices.Sunis_2.deviceURL => io://xxxx-xxxx-xxxx/5728116
                              2021-08-01 21:01:14.109 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:StatusState => available
                              2021-08-01 21:01:14.109 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:14.110 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:RSSILevelState => 100
                              2021-08-01 21:01:14.110 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:LuminanceState => 73
                              2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche => 0
                              2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche.deviceURL => io://xxxx-xxxx-xxxx/7806987
                              2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:NameState => 1. Küche
                              2021-08-01 21:01:14.112 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:14.112 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:StatusState => available
                              2021-08-01 21:01:14.113 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:DiscreteRSSILevelState => normal
                              2021-08-01 21:01:14.113 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:RSSILevelState => 72
                              2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:MovingState => false
                              2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:ClosureState => 0
                              2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:OpenClosedState => open
                              2021-08-01 21:01:14.115 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:Memorized1PositionState => 46
                              2021-08-01 21:01:14.115 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:TargetClosureState => 0
                              2021-08-01 21:01:14.116 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.close => false
                              2021-08-01 21:01:14.116 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.down => false
                              2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.getName => false
                              2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.identify => false
                              2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.my => false
                              2021-08-01 21:01:14.118 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.open => false
                              2021-08-01 21:01:14.118 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:14.119 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.startIdentify => false
                              2021-08-01 21:01:14.119 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.stop => false
                              2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.stopIdentify => false
                              2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.up => false
                              2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.121 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.sendIOKey => false
                              2021-08-01 21:01:14.121 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.OGP_(00000BE8) => 0
                              2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.OGP_(00000BE8).deviceURL => ogp://xxxx-xxxx-xxxx/00000BE8
                              2021-08-01 21:01:14.123 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge => 0
                              2021-08-01 21:01:14.123 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.deviceURL => ogp://xxxx-xxxx-xxxx/039575E9
                              2021-08-01 21:01:14.124 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.states.core:NameState => OGP Siegenia Bridge
                              2021-08-01 21:01:14.124 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.commands.discover => false
                              2021-08-01 21:01:14.125 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.commands.identify => false
                              2021-08-01 21:01:14.125 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge => 0
                              2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.deviceURL => ogp://xxxx-xxxx-xxxx/09E45393
                              2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.states.core:NameState => OGP Intesis Bridge
                              2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.commands.discover => false
                              2021-08-01 21:01:14.127 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.commands.identify => false
                              2021-08-01 21:01:14.131 - debug: tahoma.0 (16504) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/logout with payload:{}
                              2021-08-01 21:01:14.409 - info: tahoma.0 (16504) terminating
                              2021-08-01 21:01:14.411 - warn: tahoma.0 (16504) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              2021-08-01 21:01:15.382 - error: tahoma.0 (16504) Cannot find view "system" for search "state" : Connection is closed.
                              2021-08-01 21:01:47.146 - debug: tahoma.0 (16558) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2021-08-01 21:01:47.202 - debug: tahoma.0 (16558) Objects client ready ... initialize now
                              2021-08-01 21:01:47.205 - debug: tahoma.0 (16558) Objects create System PubSub Client
                              2021-08-01 21:01:47.206 - debug: tahoma.0 (16558) Objects create User PubSub Client
                              2021-08-01 21:01:47.207 - debug: tahoma.0 (16558) Objects client initialize lua scripts
                              2021-08-01 21:01:47.223 - debug: tahoma.0 (16558) Objects connected to redis: 127.0.0.1:9001
                              2021-08-01 21:01:47.233 - debug: tahoma.0 (16558) objectDB connected
                              2021-08-01 21:01:47.235 - debug: tahoma.0 (16558) Redis States: Use Redis connection: 127.0.0.1:9000
                              2021-08-01 21:01:47.243 - debug: tahoma.0 (16558) States create System PubSub Client
                              2021-08-01 21:01:47.245 - debug: tahoma.0 (16558) States create User PubSub Client
                              2021-08-01 21:01:47.252 - debug: tahoma.0 (16558) States connected to redis: 127.0.0.1:9000
                              2021-08-01 21:01:47.254 - debug: tahoma.0 (16558) statesDB connected
                              2021-08-01 21:01:47.490 - info: tahoma.0 (16558) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
                              2021-08-01 21:01:47.523 - info: tahoma.0 (16558) [START] Starting adapter tahoma v0.3.3
                              2021-08-01 21:01:47.557 - info: tahoma.0 (16558) [INFO] Configured polling interval: 50000
                              2021-08-01 21:01:47.557 - debug: tahoma.0 (16558) [START] Started Adapter
                              2021-08-01 21:01:47.569 - debug: tahoma.0 (16558) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/login with payload: +++redacted+++
                              2021-08-01 21:01:47.757 - debug: tahoma.0 (16558) stateChange tahoma.0.update {"val":false,"ack":true,"ts":1627844507752,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551065625}
                              2021-08-01 21:01:47.897 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/enduser/mainAccount with payload:{}
                              2021-08-01 21:01:47.921 - debug: tahoma.0 (16558) stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1627844507918,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1627844507918}
                              2021-08-01 21:01:47.990 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup with payload:{}
                              2021-08-01 21:01:47.995 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/actionGroups with payload:{}
                              2021-08-01 21:01:48.084 - debug: tahoma.0 (16558) setState actionGroups.Öffnen.oid => 10aa67c7-a17e-4ab2-96f0-f98656463d9c
                              2021-08-01 21:01:48.084 - debug: tahoma.0 (16558) setState actionGroups.Öffnen.commands.execute => false
                              2021-08-01 21:01:48.085 - debug: tahoma.0 (16558) setState actionGroups.Schließen.oid => 171e14e2-a1fa-4a51-a874-dc72a4f9dd09
                              2021-08-01 21:01:48.086 - debug: tahoma.0 (16558) setState actionGroups.Schließen.commands.execute => false
                              2021-08-01 21:01:48.086 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_ein.oid => a5b7218e-9378-4dfe-8b16-6237dcf1c2b7
                              2021-08-01 21:01:48.087 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_ein.commands.execute => false
                              2021-08-01 21:01:48.087 - debug: tahoma.0 (16558) setState actionGroups.Lüften.oid => a69a2669-a0db-4f54-a4f5-96a9eed64628
                              2021-08-01 21:01:48.088 - debug: tahoma.0 (16558) setState actionGroups.Lüften.commands.execute => false
                              2021-08-01 21:01:48.093 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_aus.oid => f811d8aa-c0ca-4347-9739-9cdf4b1424c9
                              2021-08-01 21:01:48.094 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_aus.commands.execute => false
                              2021-08-01 21:01:48.109 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Öffnen.oid {"val":"10aa67c7-a17e-4ab2-96f0-f98656463d9c","ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                              2021-08-01 21:01:48.111 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Öffnen.commands.execute {"val":false,"ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                              2021-08-01 21:01:48.115 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Schließen.oid {"val":"171e14e2-a1fa-4a51-a874-dc72a4f9dd09","ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                              2021-08-01 21:01:48.118 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Schließen.commands.execute {"val":false,"ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                              2021-08-01 21:01:48.119 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_ein.oid {"val":"a5b7218e-9378-4dfe-8b16-6237dcf1c2b7","ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                              2021-08-01 21:01:48.119 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_ein.commands.execute {"val":false,"ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                              2021-08-01 21:01:48.127 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüften.oid {"val":"a69a2669-a0db-4f54-a4f5-96a9eed64628","ack":true,"ts":1627844508104,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066075}
                              2021-08-01 21:01:48.129 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüften.commands.execute {"val":false,"ack":true,"ts":1627844508105,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066101}
                              2021-08-01 21:01:48.137 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_aus.oid {"val":"f811d8aa-c0ca-4347-9739-9cdf4b1424c9","ack":true,"ts":1627844508117,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066102}
                              2021-08-01 21:01:48.138 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_aus.commands.execute {"val":false,"ack":true,"ts":1627844508129,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066232}
                              2021-08-01 21:01:48.310 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.gatewayId => xxxx-xxxx-xxxx
                              2021-08-01 21:01:48.310 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.type => 29
                              2021-08-01 21:01:48.311 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.subType => 14
                              2021-08-01 21:01:48.312 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.placeOID => b80f5c61-7e8e-4862-9705-1a1fc4b2e4ff
                              2021-08-01 21:01:48.312 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.alive => false
                              2021-08-01 21:01:48.313 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.timeReliable => false
                              2021-08-01 21:01:48.313 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.connectivity.status => OK
                              2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.connectivity.protocolVersion => 2021.2.4
                              2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.upToDate => false
                              2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.updateStatus => UP_TO_DATE
                              2021-08-01 21:01:48.315 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.syncInProgress => false
                              2021-08-01 21:01:48.315 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.mode => ACTIVE
                              2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.functions => INTERNET_AUTHORIZATION,SCENARIO_DOWNLOAD,SCENARIO_AUTO_LAUNCHING,SCENARIO_TELECO_LAUNCHING,INTERNET_UPLOAD,INTERNET_UPDATE,TRIGGERS_SENSORS
                              2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState location.creationTime => 1469357137000
                              2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState location.lastUpdateTime => 1619290314000
                              2021-08-01 21:01:48.317 - debug: tahoma.0 (16558) setState location.city => Traumland
                              2021-08-01 21:01:48.317 - debug: tahoma.0 (16558) setState location.country => Germany
                              2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.postalCode => 66666
                              2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.addressLine1 => Himmelstor 7
                              2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.addressLine2 => 0
                              2021-08-01 21:01:48.319 - debug: tahoma.0 (16558) setState location.timezone => Europe/Berlin
                              2021-08-01 21:01:48.319 - debug: tahoma.0 (16558) setState location.longitude => 11.5713
                              2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.latitude => 49.9456
                              2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.twilightMode => 2
                              2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.twilightAngle => CIVIL
                              2021-08-01 21:01:48.321 - debug: tahoma.0 (16558) setState location.twilightCity => berlin
                              2021-08-01 21:01:48.321 - debug: tahoma.0 (16558) setState location.summerSolsticeDuskMinutes => 1290
                              2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.winterSolsticeDuskMinutes => 990
                              2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.twilightOffsetEnabled => false
                              2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.dawnOffset => 0
                              2021-08-01 21:01:48.323 - debug: tahoma.0 (16558) setState location.duskOffset => -15
                              2021-08-01 21:01:48.323 - debug: tahoma.0 (16558) setState location.countryCode => DE
                              2021-08-01 21:01:48.324 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack) => 0
                              2021-08-01 21:01:48.324 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack).deviceURL => homekit://xxxx-xxxx-xxxx/stack
                              2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack).commands.deleteControllers => false
                              2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.Alarm => 0
                              2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.Alarm.deviceURL => internal://xxxx-xxxx-xxxx/alarm/0
                              2021-08-01 21:01:48.326 - debug: tahoma.0 (16558) setState devices.Alarm.states.core:NameState => TSK Alarm
                              2021-08-01 21:01:48.326 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:CurrentAlarmModeState => off
                              2021-08-01 21:01:48.327 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:AlarmDelayState => 60
                              2021-08-01 21:01:48.330 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:TargetAlarmModeState => off
                              2021-08-01 21:01:48.331 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:IntrusionDetectedState => notDetected
                              2021-08-01 21:01:48.331 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmOff => false
                              2021-08-01 21:01:48.332 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmOn => false
                              2021-08-01 21:01:48.332 - debug: tahoma.0 (16558) setState devices.Alarm.commands.arm => false
                              2021-08-01 21:01:48.333 - debug: tahoma.0 (16558) setState devices.Alarm.commands.disarm => false
                              2021-08-01 21:01:48.333 - debug: tahoma.0 (16558) setState devices.Alarm.commands.getName => false
                              2021-08-01 21:01:48.334 - debug: tahoma.0 (16558) setState devices.Alarm.commands.off => false
                              2021-08-01 21:01:48.334 - debug: tahoma.0 (16558) setState devices.Alarm.commands.on => false
                              2021-08-01 21:01:48.335 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshAlarmDelay => false
                              2021-08-01 21:01:48.335 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshCurrentAlarmMode => false
                              2021-08-01 21:01:48.336 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshIntrusionDetected => false
                              2021-08-01 21:01:48.336 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmPartial1 => false
                              2021-08-01 21:01:48.337 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmPartial2 => false
                              2021-08-01 21:01:48.337 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste => 0
                              2021-08-01 21:01:48.338 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.deviceURL => internal://xxxx-xxxx-xxxx/pod/0
                              2021-08-01 21:01:48.338 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:NameState => Box
                              2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.internal:BatteryStatusState => no
                              2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:CyclicButtonState => stop
                              2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.internal:LightingLedPodModeState => 0.2
                              2021-08-01 21:01:48.340 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:CountryCodeState => DE
                              2021-08-01 21:01:48.340 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:LocalIPv4AddressState => 192.168.2.140
                              2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.getName => false
                              2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.update => false
                              2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.activateCalendar => false
                              2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.deactivateCalendar => false
                              2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshBatteryStatus => false
                              2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshPodMode => false
                              2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshUpdateStatus => false
                              2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.setPodLedOff => false
                              2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.setPodLedOn => false
                              2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe => 0
                              2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe.deviceURL => io://xxxx-xxxx-xxxx/11816111
                              2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:NameState => Stehlampe
                              2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:StatusState => available
                              2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:RSSILevelState => 88
                              2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:OnOffState => off
                              2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.getName => false
                              2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.identify => false
                              2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.off => false
                              2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.on => false
                              2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.startIdentify => false
                              2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.stopIdentify => false
                              2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer => 0
                              2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.deviceURL => io://xxxx-xxxx-xxxx/1211100
                              2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:NameState => 3. Esszimmer
                              2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:PriorityLockTimerState => 0
                              2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:StatusState => available
                              2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:RSSILevelState => 100
                              2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:MovingState => false
                              2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ManufacturerSettingsState => [object Object]
                              2021-08-01 21:01:48.353 - error: tahoma.0 (16558) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2021-08-01 21:01:48.354 - error: tahoma.0 (16558) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:48.357 - error: tahoma.0 (16558) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23)
                              at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21)
                              at processImmediate (internal/timers.js:463:21)
                              2021-08-01 21:01:48.357 - error: tahoma.0 (16558) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                              2021-08-01 21:01:48.358 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ClosureState => 0
                              2021-08-01 21:01:48.359 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ClosureState:slow => 0
                              2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:OpenClosedState => open
                              2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:Memorized1PositionState => 41
                              2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:TargetClosureState => 0
                              2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:TargetClosureState:slow => 0
                              2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.close => false
                              2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.close:slow => false
                              2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.down => false
                              2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.down:slow => false
                              2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.getName => false
                              2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.identify => false
                              2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.my => false
                              2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.open => false
                              2021-08-01 21:01:48.364 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.open:slow => false
                              2021-08-01 21:01:48.364 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.refreshMemorized1Position => false
                              2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.startIdentify => false
                              2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.stop => false
                              2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.stopIdentify => false
                              2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.up => false
                              2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.up:slow => false
                              2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.keepOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.sendIOKey => false
                              2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                              2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.unpairAllOneWayControllers => false
                              2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe => 0
                              2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.deviceURL => io://xxxx-xxxx-xxxx/12362917
                              2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:NameState => 2. Küche Türe
                              2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.io:PriorityLockOriginatorState => user
                              2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:PriorityLockTimerState => 7650
                              2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.io:PriorityLockLevelState => userLevel2
                              2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:StatusState => available
                              2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:DiscreteRSSILevelState => good
                              2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:RSSILevelState => 84
                              2021-08-01 21:01:48.371 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:MovingState => false
                              2021-08-01 21:01:48.371 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:ClosureState => 0
                              Vielen Dank für deine Unterstützung.
                              Gruß Willi
                              W 1 Antwort Letzte Antwort
                              • W Willi-Wunder
                                @excodibur
                                Vielen Dank für deine Info. Dachte es liegt tatsächlich an den neuen Versionen vom iobroker. Haben ja doch einige das Problem mit dem Adapter was man so ließt. Das heißt du könntest den Adapter am laufen erhalten wenn ich das richtig verstehe? :-)
                                Somfy ist momentan viel mit der Switch und der Classic Box beschäftigt, soll ja spätestens nächstes Frühjahr nur noch eine Software dafür geben.....
                                Hier mein Log:
                                2021-08-01 21:01:11.182 - info: host.raspberrypi "system.adapter.tahoma.0" enabled
                                2021-08-01 21:01:11.386 - info: host.raspberrypi instance system.adapter.tahoma.0 started with pid 16504
                                2021-08-01 21:01:12.745 - debug: tahoma.0 (16504) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2021-08-01 21:01:12.781 - debug: tahoma.0 (16504) Objects client ready ... initialize now
                                2021-08-01 21:01:12.784 - debug: tahoma.0 (16504) Objects create System PubSub Client
                                2021-08-01 21:01:12.786 - debug: tahoma.0 (16504) Objects create User PubSub Client
                                2021-08-01 21:01:12.787 - debug: tahoma.0 (16504) Objects client initialize lua scripts
                                2021-08-01 21:01:12.811 - debug: tahoma.0 (16504) Objects connected to redis: 127.0.0.1:9001
                                2021-08-01 21:01:12.820 - debug: tahoma.0 (16504) objectDB connected
                                2021-08-01 21:01:12.822 - debug: tahoma.0 (16504) Redis States: Use Redis connection: 127.0.0.1:9000
                                2021-08-01 21:01:12.831 - debug: tahoma.0 (16504) States create System PubSub Client
                                2021-08-01 21:01:12.832 - debug: tahoma.0 (16504) States create User PubSub Client
                                2021-08-01 21:01:12.840 - debug: tahoma.0 (16504) States connected to redis: 127.0.0.1:9000
                                2021-08-01 21:01:12.841 - debug: tahoma.0 (16504) statesDB connected
                                2021-08-01 21:01:13.064 - info: tahoma.0 (16504) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
                                2021-08-01 21:01:13.095 - info: tahoma.0 (16504) [START] Starting adapter tahoma v0.3.3
                                2021-08-01 21:01:13.132 - info: tahoma.0 (16504) [INFO] Configured polling interval: 50000
                                2021-08-01 21:01:13.133 - debug: tahoma.0 (16504) [START] Started Adapter
                                2021-08-01 21:01:13.136 - debug: tahoma.0 (16504) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/login with payload: +++redacted+++
                                2021-08-01 21:01:13.330 - debug: tahoma.0 (16504) stateChange tahoma.0.update {"val":false,"ack":true,"ts":1627844473319,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551065625}
                                2021-08-01 21:01:13.493 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/enduser/mainAccount with payload:{}
                                2021-08-01 21:01:13.518 - debug: tahoma.0 (16504) stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1627844473514,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1627844473514}
                                2021-08-01 21:01:13.577 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup with payload:{}
                                2021-08-01 21:01:13.582 - debug: tahoma.0 (16504) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/actionGroups with payload:{}
                                2021-08-01 21:01:13.692 - debug: tahoma.0 (16504) setState actionGroups.Öffnen.oid => 10aa67c7-a17e-4ab2-96f0-f98656463d9c
                                2021-08-01 21:01:13.693 - debug: tahoma.0 (16504) setState actionGroups.Öffnen.commands.execute => false
                                2021-08-01 21:01:13.694 - debug: tahoma.0 (16504) setState actionGroups.Schließen.oid => 171e14e2-a1fa-4a51-a874-dc72a4f9dd09
                                2021-08-01 21:01:13.694 - debug: tahoma.0 (16504) setState actionGroups.Schließen.commands.execute => false
                                2021-08-01 21:01:13.695 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_ein.oid => a5b7218e-9378-4dfe-8b16-6237dcf1c2b7
                                2021-08-01 21:01:13.695 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_ein.commands.execute => false
                                2021-08-01 21:01:13.700 - debug: tahoma.0 (16504) setState actionGroups.Lüften.oid => a69a2669-a0db-4f54-a4f5-96a9eed64628
                                2021-08-01 21:01:13.701 - debug: tahoma.0 (16504) setState actionGroups.Lüften.commands.execute => false
                                2021-08-01 21:01:13.701 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_aus.oid => f811d8aa-c0ca-4347-9739-9cdf4b1424c9
                                2021-08-01 21:01:13.702 - debug: tahoma.0 (16504) setState actionGroups.Lüftung_aus.commands.execute => false
                                2021-08-01 21:01:13.716 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Öffnen.oid {"val":"10aa67c7-a17e-4ab2-96f0-f98656463d9c","ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                                2021-08-01 21:01:13.720 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Öffnen.commands.execute {"val":false,"ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                                2021-08-01 21:01:13.724 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Schließen.oid {"val":"171e14e2-a1fa-4a51-a874-dc72a4f9dd09","ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                                2021-08-01 21:01:13.727 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Schließen.commands.execute {"val":false,"ack":true,"ts":1627844473710,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                                2021-08-01 21:01:13.733 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_ein.oid {"val":"a5b7218e-9378-4dfe-8b16-6237dcf1c2b7","ack":true,"ts":1627844473711,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                                2021-08-01 21:01:13.735 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_ein.commands.execute {"val":false,"ack":true,"ts":1627844473711,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                                2021-08-01 21:01:13.736 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüften.oid {"val":"a69a2669-a0db-4f54-a4f5-96a9eed64628","ack":true,"ts":1627844473713,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066075}
                                2021-08-01 21:01:13.739 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüften.commands.execute {"val":false,"ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066101}
                                2021-08-01 21:01:13.743 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_aus.oid {"val":"f811d8aa-c0ca-4347-9739-9cdf4b1424c9","ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066102}
                                2021-08-01 21:01:13.746 - debug: tahoma.0 (16504) stateChange tahoma.0.actionGroups.Lüftung_aus.commands.execute {"val":false,"ack":true,"ts":1627844473732,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066232}
                                2021-08-01 21:01:13.947 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.gatewayId => xxxx-xxxx-xxxx
                                2021-08-01 21:01:13.948 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.type => 29
                                2021-08-01 21:01:13.949 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.subType => 14
                                2021-08-01 21:01:13.949 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.placeOID => b80f5c61-7e8e-4862-9705-1a1fc4b2e4ff
                                2021-08-01 21:01:13.950 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.alive => false
                                2021-08-01 21:01:13.950 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.timeReliable => false
                                2021-08-01 21:01:13.951 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.connectivity.status => OK
                                2021-08-01 21:01:13.951 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.connectivity.protocolVersion => 2021.2.4
                                2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.upToDate => false
                                2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.updateStatus => UP_TO_DATE
                                2021-08-01 21:01:13.952 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.syncInProgress => false
                                2021-08-01 21:01:13.953 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.mode => ACTIVE
                                2021-08-01 21:01:13.953 - debug: tahoma.0 (16504) setState xxxx-xxxx-xxxx.functions => INTERNET_AUTHORIZATION,SCENARIO_DOWNLOAD,SCENARIO_AUTO_LAUNCHING,SCENARIO_TELECO_LAUNCHING,INTERNET_UPLOAD,INTERNET_UPDATE,TRIGGERS_SENSORS
                                2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.creationTime => 1469357137000
                                2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.lastUpdateTime => 1619290314000
                                2021-08-01 21:01:13.954 - debug: tahoma.0 (16504) setState location.city => Traumland
                                2021-08-01 21:01:13.955 - debug: tahoma.0 (16504) setState location.country => Germany
                                2021-08-01 21:01:13.955 - debug: tahoma.0 (16504) setState location.postalCode => 66666
                                2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.addressLine1 => Himmelstor 7
                                2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.addressLine2 => 0
                                2021-08-01 21:01:13.956 - debug: tahoma.0 (16504) setState location.timezone => Europe/Berlin
                                2021-08-01 21:01:13.957 - debug: tahoma.0 (16504) setState location.longitude => 11.5713
                                2021-08-01 21:01:13.957 - debug: tahoma.0 (16504) setState location.latitude => 49.9456
                                2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightMode => 2
                                2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightAngle => CIVIL
                                2021-08-01 21:01:13.958 - debug: tahoma.0 (16504) setState location.twilightCity => berlin
                                2021-08-01 21:01:13.959 - debug: tahoma.0 (16504) setState location.summerSolsticeDuskMinutes => 1290
                                2021-08-01 21:01:13.959 - debug: tahoma.0 (16504) setState location.winterSolsticeDuskMinutes => 990
                                2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.twilightOffsetEnabled => false
                                2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.dawnOffset => 0
                                2021-08-01 21:01:13.960 - debug: tahoma.0 (16504) setState location.duskOffset => -15
                                2021-08-01 21:01:13.961 - debug: tahoma.0 (16504) setState location.countryCode => DE
                                2021-08-01 21:01:13.961 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack) => 0
                                2021-08-01 21:01:13.962 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack).deviceURL => homekit://xxxx-xxxx-xxxx/stack
                                2021-08-01 21:01:13.962 - debug: tahoma.0 (16504) setState devices.HOMEKIT_(stack).commands.deleteControllers => false
                                2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm => 0
                                2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm.deviceURL => internal://xxxx-xxxx-xxxx/alarm/0
                                2021-08-01 21:01:13.963 - debug: tahoma.0 (16504) setState devices.Alarm.states.core:NameState => TSK Alarm
                                2021-08-01 21:01:13.964 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:CurrentAlarmModeState => off
                                2021-08-01 21:01:13.964 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:AlarmDelayState => 60
                                2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:TargetAlarmModeState => off
                                2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.states.internal:IntrusionDetectedState => notDetected
                                2021-08-01 21:01:13.965 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmOff => false
                                2021-08-01 21:01:13.966 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmOn => false
                                2021-08-01 21:01:13.966 - debug: tahoma.0 (16504) setState devices.Alarm.commands.arm => false
                                2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.disarm => false
                                2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.getName => false
                                2021-08-01 21:01:13.967 - debug: tahoma.0 (16504) setState devices.Alarm.commands.off => false
                                2021-08-01 21:01:13.968 - debug: tahoma.0 (16504) setState devices.Alarm.commands.on => false
                                2021-08-01 21:01:13.968 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshAlarmDelay => false
                                2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshCurrentAlarmMode => false
                                2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.refreshIntrusionDetected => false
                                2021-08-01 21:01:13.969 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmPartial1 => false
                                2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Alarm.commands.alarmPartial2 => false
                                2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste => 0
                                2021-08-01 21:01:13.970 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.deviceURL => internal://xxxx-xxxx-xxxx/pod/0
                                2021-08-01 21:01:13.971 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:NameState => Box
                                2021-08-01 21:01:13.971 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.internal:BatteryStatusState => no
                                2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:CyclicButtonState => stop
                                2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.internal:LightingLedPodModeState => 0.2
                                2021-08-01 21:01:13.972 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:CountryCodeState => DE
                                2021-08-01 21:01:13.973 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.states.core:LocalIPv4AddressState => 192.168.2.140
                                2021-08-01 21:01:13.973 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.getName => false
                                2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.update => false
                                2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.activateCalendar => false
                                2021-08-01 21:01:13.974 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.deactivateCalendar => false
                                2021-08-01 21:01:13.975 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshBatteryStatus => false
                                2021-08-01 21:01:13.975 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshPodMode => false
                                2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.refreshUpdateStatus => false
                                2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.setPodLedOff => false
                                2021-08-01 21:01:13.976 - debug: tahoma.0 (16504) setState devices.Sensitive_Taste.commands.setPodLedOn => false
                                2021-08-01 21:01:13.977 - debug: tahoma.0 (16504) setState devices.Stehlampe => 0
                                2021-08-01 21:01:13.977 - debug: tahoma.0 (16504) setState devices.Stehlampe.deviceURL => io://xxxx-xxxx-xxxx/11816111
                                2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:NameState => Stehlampe
                                2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:13.978 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:StatusState => available
                                2021-08-01 21:01:13.979 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:13.979 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:RSSILevelState => 88
                                2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.states.core:OnOffState => off
                                2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.getName => false
                                2021-08-01 21:01:13.980 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.identify => false
                                2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.off => false
                                2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.on => false
                                2021-08-01 21:01:13.981 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.startIdentify => false
                                2021-08-01 21:01:13.982 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.stopIdentify => false
                                2021-08-01 21:01:13.982 - debug: tahoma.0 (16504) setState devices.Stehlampe.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer => 0
                                2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.deviceURL => io://xxxx-xxxx-xxxx/1211100
                                2021-08-01 21:01:13.983 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:NameState => 3. Esszimmer
                                2021-08-01 21:01:13.984 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:13.984 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:StatusState => available
                                2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:RSSILevelState => 100
                                2021-08-01 21:01:13.985 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:MovingState => false
                                2021-08-01 21:01:13.986 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ManufacturerSettingsState => [object Object]
                                2021-08-01 21:01:13.988 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-01 21:01:13.988 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:13.991 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                at Immediate. (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23)
                                2021-08-01 21:01:13.992 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:13.993 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ClosureState => 0
                                2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:ClosureState:slow => 0
                                2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:OpenClosedState => open
                                2021-08-01 21:01:13.994 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:Memorized1PositionState => 41
                                2021-08-01 21:01:13.995 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:TargetClosureState => 0
                                2021-08-01 21:01:13.995 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.states.core:TargetClosureState:slow => 0
                                2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.close => false
                                2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.close:slow => false
                                2021-08-01 21:01:13.996 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.down => false
                                2021-08-01 21:01:13.997 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.down:slow => false
                                2021-08-01 21:01:13.997 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.getName => false
                                2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.identify => false
                                2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.my => false
                                2021-08-01 21:01:13.998 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.open => false
                                2021-08-01 21:01:13.999 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.open:slow => false
                                2021-08-01 21:01:13.999 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.startIdentify => false
                                2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.stop => false
                                2021-08-01 21:01:14.000 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.stopIdentify => false
                                2021-08-01 21:01:14.001 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.up => false
                                2021-08-01 21:01:14.001 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.up:slow => false
                                2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.sendIOKey => false
                                2021-08-01 21:01:14.002 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.3__Esszimmer.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe => 0
                                2021-08-01 21:01:14.003 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.deviceURL => io://xxxx-xxxx-xxxx/12362917
                                2021-08-01 21:01:14.004 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:NameState => 2. Küche Türe
                                2021-08-01 21:01:14.004 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.io:PriorityLockOriginatorState => user
                                2021-08-01 21:01:14.005 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:PriorityLockTimerState => 7650
                                2021-08-01 21:01:14.005 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.io:PriorityLockLevelState => userLevel2
                                2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:StatusState => available
                                2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.006 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:RSSILevelState => 84
                                2021-08-01 21:01:14.007 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:MovingState => false
                                2021-08-01 21:01:14.007 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:ClosureState => 0
                                2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:OpenClosedState => open
                                2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:Memorized1PositionState => 60
                                2021-08-01 21:01:14.008 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.states.core:TargetClosureState => 0
                                2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.close => false
                                2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.down => false
                                2021-08-01 21:01:14.009 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.getName => false
                                2021-08-01 21:01:14.010 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.identify => false
                                2021-08-01 21:01:14.010 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.my => false
                                2021-08-01 21:01:14.011 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.open => false
                                2021-08-01 21:01:14.014 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:14.014 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.startIdentify => false
                                2021-08-01 21:01:14.015 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.stop => false
                                2021-08-01 21:01:14.018 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.stopIdentify => false
                                2021-08-01 21:01:14.019 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.up => false
                                2021-08-01 21:01:14.019 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.020 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.sendIOKey => false
                                2021-08-01 21:01:14.023 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.024 - debug: tahoma.0 (16504) setState devices.2__Küche_Türe.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:14.024 - debug: tahoma.0 (16504) setState devices.Temp__Sensor => 0
                                2021-08-01 21:01:14.025 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.deviceURL => io://xxxx-xxxx-xxxx/12415680
                                2021-08-01 21:01:14.025 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:StatusState => available
                                2021-08-01 21:01:14.026 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.026 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:RSSILevelState => 78
                                2021-08-01 21:01:14.027 - debug: tahoma.0 (16504) setState devices.Temp__Sensor.states.core:TemperatureState => 17.400000000000034
                                2021-08-01 21:01:14.027 - debug: tahoma.0 (16504) setState devices.Dachboden => 0
                                2021-08-01 21:01:14.028 - debug: tahoma.0 (16504) setState devices.Dachboden.deviceURL => io://xxxx-xxxx-xxxx/13336923
                                2021-08-01 21:01:14.028 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.029 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:StatusState => available
                                2021-08-01 21:01:14.030 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.030 - debug: tahoma.0 (16504) setState devices.Dachboden.states.core:RSSILevelState => 60
                                2021-08-01 21:01:14.031 - debug: tahoma.0 (16504) setState devices.EG_Flur => 0
                                2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.deviceURL => io://xxxx-xxxx-xxxx/13571339
                                2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.032 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:StatusState => available
                                2021-08-01 21:01:14.033 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.EG_Flur.states.core:RSSILevelState => 76
                                2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.1_OG_Emma => 0
                                2021-08-01 21:01:14.034 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.deviceURL => io://xxxx-xxxx-xxxx/13982509
                                2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.035 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:StatusState => available
                                2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.036 - debug: tahoma.0 (16504) setState devices.1_OG_Emma.states.core:RSSILevelState => 82
                                2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur => 0
                                2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur.deviceURL => io://xxxx-xxxx-xxxx/14696015
                                2021-08-01 21:01:14.037 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.038 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.042 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.042 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:StatusState => available
                                2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.KG_Flur.states.core:RSSILevelState => 76
                                2021-08-01 21:01:14.043 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern => 0
                                2021-08-01 21:01:14.044 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.deviceURL => io://xxxx-xxxx-xxxx/14704656
                                2021-08-01 21:01:14.044 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:StatusState => available
                                2021-08-01 21:01:14.045 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.1_OG_Eltern.states.core:RSSILevelState => 100
                                2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.IO_(14918158) => 0
                                2021-08-01 21:01:14.046 - debug: tahoma.0 (16504) setState devices.IO_(14918158).deviceURL => io://xxxx-xxxx-xxxx/14918158
                                2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.discoverSomfyUnsetActuators => false
                                2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.joinNetwork => false
                                2021-08-01 21:01:14.047 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.resetNetworkSecurity => false
                                2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.IO_(14918158).commands.shareNetwork => false
                                2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur => 0
                                2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.deviceURL => io://xxxx-xxxx-xxxx/3045215
                                2021-08-01 21:01:14.048 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.io:MaintenanceSensorPartBatteryState => low
                                2021-08-01 21:01:14.049 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:StatusState => available
                                2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:SensorDefectState => maintenanceRequired
                                2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.050 - debug: tahoma.0 (16504) setState devices.1_OG_Flur.states.core:RSSILevelState => 74
                                2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer => 0
                                2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.deviceURL => io://xxxx-xxxx-xxxx/3268948
                                2021-08-01 21:01:14.051 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:NameState => 5. Wohnzimmer
                                2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:StatusState => available
                                2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.052 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:RSSILevelState => 100
                                2021-08-01 21:01:14.053 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:MovingState => false
                                2021-08-01 21:01:14.053 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ManufacturerSettingsState => [object Object]
                                2021-08-01 21:01:14.054 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-01 21:01:14.054 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.054 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.055 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.055 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ClosureState => 0
                                2021-08-01 21:01:14.056 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:ClosureState:slow => 0
                                2021-08-01 21:01:14.056 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:OpenClosedState => open
                                2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:Memorized1PositionState => 49
                                2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:TargetClosureState => 0
                                2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.states.core:TargetClosureState:slow => 0
                                2021-08-01 21:01:14.057 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.close => false
                                2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.close:slow => false
                                2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.down => false
                                2021-08-01 21:01:14.058 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.down:slow => false
                                2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.getName => false
                                2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.identify => false
                                2021-08-01 21:01:14.059 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.my => false
                                2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.open => false
                                2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.open:slow => false
                                2021-08-01 21:01:14.060 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.startIdentify => false
                                2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.stop => false
                                2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.stopIdentify => false
                                2021-08-01 21:01:14.061 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.up => false
                                2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.up:slow => false
                                2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.062 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.sendIOKey => false
                                2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.5__Wohnzimmer.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:14.063 - debug: tahoma.0 (16504) setState devices.Sunis => 0
                                2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.deviceURL => io://xxxx-xxxx-xxxx/3700079
                                2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:StatusState => available
                                2021-08-01 21:01:14.064 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.069 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:RSSILevelState => 68
                                2021-08-01 21:01:14.070 - debug: tahoma.0 (16504) setState devices.Sunis.states.core:LuminanceState => 120
                                2021-08-01 21:01:14.070 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2 => 0
                                2021-08-01 21:01:14.071 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.deviceURL => io://xxxx-xxxx-xxxx/3802238
                                2021-08-01 21:01:14.071 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:SmokeState => notDetected
                                2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.io:MaintenanceRadioPartBatteryState => normal
                                2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.io:MaintenanceSensorPartBatteryState => normal
                                2021-08-01 21:01:14.072 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:StatusState => available
                                2021-08-01 21:01:14.073 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.073 - debug: tahoma.0 (16504) setState devices.1_OG_Kinderzimmer_2.states.core:RSSILevelState => 78
                                2021-08-01 21:01:14.074 - debug: tahoma.0 (16504) setState devices.4__Balkontüre => 0
                                2021-08-01 21:01:14.074 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.deviceURL => io://xxxx-xxxx-xxxx/5209602
                                2021-08-01 21:01:14.075 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:NameState => 4. Balkontüre
                                2021-08-01 21:01:14.075 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:14.076 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:StatusState => available
                                2021-08-01 21:01:14.076 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.077 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:RSSILevelState => 100
                                2021-08-01 21:01:14.077 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:MovingState => false
                                2021-08-01 21:01:14.078 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ManufacturerSettingsState => [object Object]
                                2021-08-01 21:01:14.079 - error: tahoma.0 (16504) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-01 21:01:14.080 - error: tahoma.0 (16504) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.081 - error: tahoma.0 (16504) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.081 - error: tahoma.0 (16504) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:14.083 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ClosureState => 0
                                2021-08-01 21:01:14.084 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:ClosureState:slow => 0
                                2021-08-01 21:01:14.084 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:OpenClosedState => open
                                2021-08-01 21:01:14.085 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:Memorized1PositionState => 48
                                2021-08-01 21:01:14.086 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:TargetClosureState => 0
                                2021-08-01 21:01:14.087 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.states.core:TargetClosureState:slow => 0
                                2021-08-01 21:01:14.088 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.close => false
                                2021-08-01 21:01:14.089 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.close:slow => false
                                2021-08-01 21:01:14.089 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.down => false
                                2021-08-01 21:01:14.090 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.down:slow => false
                                2021-08-01 21:01:14.095 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.getName => false
                                2021-08-01 21:01:14.095 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.identify => false
                                2021-08-01 21:01:14.096 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.my => false
                                2021-08-01 21:01:14.097 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.open => false
                                2021-08-01 21:01:14.098 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.open:slow => false
                                2021-08-01 21:01:14.099 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:14.100 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.startIdentify => false
                                2021-08-01 21:01:14.101 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.stop => false
                                2021-08-01 21:01:14.102 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.stopIdentify => false
                                2021-08-01 21:01:14.103 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.up => false
                                2021-08-01 21:01:14.104 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.up:slow => false
                                2021-08-01 21:01:14.105 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.106 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.sendIOKey => false
                                2021-08-01 21:01:14.107 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.107 - debug: tahoma.0 (16504) setState devices.4__Balkontüre.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:14.108 - debug: tahoma.0 (16504) setState devices.Sunis_2 => 0
                                2021-08-01 21:01:14.108 - debug: tahoma.0 (16504) setState devices.Sunis_2.deviceURL => io://xxxx-xxxx-xxxx/5728116
                                2021-08-01 21:01:14.109 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:StatusState => available
                                2021-08-01 21:01:14.109 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:14.110 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:RSSILevelState => 100
                                2021-08-01 21:01:14.110 - debug: tahoma.0 (16504) setState devices.Sunis_2.states.core:LuminanceState => 73
                                2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche => 0
                                2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche.deviceURL => io://xxxx-xxxx-xxxx/7806987
                                2021-08-01 21:01:14.111 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:NameState => 1. Küche
                                2021-08-01 21:01:14.112 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:14.112 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:StatusState => available
                                2021-08-01 21:01:14.113 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:DiscreteRSSILevelState => normal
                                2021-08-01 21:01:14.113 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:RSSILevelState => 72
                                2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:MovingState => false
                                2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:ClosureState => 0
                                2021-08-01 21:01:14.114 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:OpenClosedState => open
                                2021-08-01 21:01:14.115 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:Memorized1PositionState => 46
                                2021-08-01 21:01:14.115 - debug: tahoma.0 (16504) setState devices.1__Küche.states.core:TargetClosureState => 0
                                2021-08-01 21:01:14.116 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.close => false
                                2021-08-01 21:01:14.116 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.down => false
                                2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.getName => false
                                2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.identify => false
                                2021-08-01 21:01:14.117 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.my => false
                                2021-08-01 21:01:14.118 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.open => false
                                2021-08-01 21:01:14.118 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:14.119 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.startIdentify => false
                                2021-08-01 21:01:14.119 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.stop => false
                                2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.stopIdentify => false
                                2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.up => false
                                2021-08-01 21:01:14.120 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.121 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.sendIOKey => false
                                2021-08-01 21:01:14.121 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.1__Küche.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.OGP_(00000BE8) => 0
                                2021-08-01 21:01:14.122 - debug: tahoma.0 (16504) setState devices.OGP_(00000BE8).deviceURL => ogp://xxxx-xxxx-xxxx/00000BE8
                                2021-08-01 21:01:14.123 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge => 0
                                2021-08-01 21:01:14.123 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.deviceURL => ogp://xxxx-xxxx-xxxx/039575E9
                                2021-08-01 21:01:14.124 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.states.core:NameState => OGP Siegenia Bridge
                                2021-08-01 21:01:14.124 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.commands.discover => false
                                2021-08-01 21:01:14.125 - debug: tahoma.0 (16504) setState devices.OGP_Siegenia_Bridge.commands.identify => false
                                2021-08-01 21:01:14.125 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge => 0
                                2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.deviceURL => ogp://xxxx-xxxx-xxxx/09E45393
                                2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.states.core:NameState => OGP Intesis Bridge
                                2021-08-01 21:01:14.126 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.commands.discover => false
                                2021-08-01 21:01:14.127 - debug: tahoma.0 (16504) setState devices.OGP_Intesis_Bridge.commands.identify => false
                                2021-08-01 21:01:14.131 - debug: tahoma.0 (16504) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/logout with payload:{}
                                2021-08-01 21:01:14.409 - info: tahoma.0 (16504) terminating
                                2021-08-01 21:01:14.411 - warn: tahoma.0 (16504) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2021-08-01 21:01:15.382 - error: tahoma.0 (16504) Cannot find view "system" for search "state" : Connection is closed.
                                2021-08-01 21:01:47.146 - debug: tahoma.0 (16558) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2021-08-01 21:01:47.202 - debug: tahoma.0 (16558) Objects client ready ... initialize now
                                2021-08-01 21:01:47.205 - debug: tahoma.0 (16558) Objects create System PubSub Client
                                2021-08-01 21:01:47.206 - debug: tahoma.0 (16558) Objects create User PubSub Client
                                2021-08-01 21:01:47.207 - debug: tahoma.0 (16558) Objects client initialize lua scripts
                                2021-08-01 21:01:47.223 - debug: tahoma.0 (16558) Objects connected to redis: 127.0.0.1:9001
                                2021-08-01 21:01:47.233 - debug: tahoma.0 (16558) objectDB connected
                                2021-08-01 21:01:47.235 - debug: tahoma.0 (16558) Redis States: Use Redis connection: 127.0.0.1:9000
                                2021-08-01 21:01:47.243 - debug: tahoma.0 (16558) States create System PubSub Client
                                2021-08-01 21:01:47.245 - debug: tahoma.0 (16558) States create User PubSub Client
                                2021-08-01 21:01:47.252 - debug: tahoma.0 (16558) States connected to redis: 127.0.0.1:9000
                                2021-08-01 21:01:47.254 - debug: tahoma.0 (16558) statesDB connected
                                2021-08-01 21:01:47.490 - info: tahoma.0 (16558) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.2, js-controller: 3.3.14
                                2021-08-01 21:01:47.523 - info: tahoma.0 (16558) [START] Starting adapter tahoma v0.3.3
                                2021-08-01 21:01:47.557 - info: tahoma.0 (16558) [INFO] Configured polling interval: 50000
                                2021-08-01 21:01:47.557 - debug: tahoma.0 (16558) [START] Started Adapter
                                2021-08-01 21:01:47.569 - debug: tahoma.0 (16558) POST request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/login with payload: +++redacted+++
                                2021-08-01 21:01:47.757 - debug: tahoma.0 (16558) stateChange tahoma.0.update {"val":false,"ack":true,"ts":1627844507752,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551065625}
                                2021-08-01 21:01:47.897 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/enduser/mainAccount with payload:{}
                                2021-08-01 21:01:47.921 - debug: tahoma.0 (16558) stateChange tahoma.0.info.connection {"val":true,"ack":true,"ts":1627844507918,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1627844507918}
                                2021-08-01 21:01:47.990 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup with payload:{}
                                2021-08-01 21:01:47.995 - debug: tahoma.0 (16558) GET request on https://www.tahomalink.com/enduser-mobile-web/enduserAPI/actionGroups with payload:{}
                                2021-08-01 21:01:48.084 - debug: tahoma.0 (16558) setState actionGroups.Öffnen.oid => 10aa67c7-a17e-4ab2-96f0-f98656463d9c
                                2021-08-01 21:01:48.084 - debug: tahoma.0 (16558) setState actionGroups.Öffnen.commands.execute => false
                                2021-08-01 21:01:48.085 - debug: tahoma.0 (16558) setState actionGroups.Schließen.oid => 171e14e2-a1fa-4a51-a874-dc72a4f9dd09
                                2021-08-01 21:01:48.086 - debug: tahoma.0 (16558) setState actionGroups.Schließen.commands.execute => false
                                2021-08-01 21:01:48.086 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_ein.oid => a5b7218e-9378-4dfe-8b16-6237dcf1c2b7
                                2021-08-01 21:01:48.087 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_ein.commands.execute => false
                                2021-08-01 21:01:48.087 - debug: tahoma.0 (16558) setState actionGroups.Lüften.oid => a69a2669-a0db-4f54-a4f5-96a9eed64628
                                2021-08-01 21:01:48.088 - debug: tahoma.0 (16558) setState actionGroups.Lüften.commands.execute => false
                                2021-08-01 21:01:48.093 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_aus.oid => f811d8aa-c0ca-4347-9739-9cdf4b1424c9
                                2021-08-01 21:01:48.094 - debug: tahoma.0 (16558) setState actionGroups.Lüftung_aus.commands.execute => false
                                2021-08-01 21:01:48.109 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Öffnen.oid {"val":"10aa67c7-a17e-4ab2-96f0-f98656463d9c","ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                                2021-08-01 21:01:48.111 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Öffnen.commands.execute {"val":false,"ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066072}
                                2021-08-01 21:01:48.115 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Schließen.oid {"val":"171e14e2-a1fa-4a51-a874-dc72a4f9dd09","ack":true,"ts":1627844508101,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                                2021-08-01 21:01:48.118 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Schließen.commands.execute {"val":false,"ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066073}
                                2021-08-01 21:01:48.119 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_ein.oid {"val":"a5b7218e-9378-4dfe-8b16-6237dcf1c2b7","ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                                2021-08-01 21:01:48.119 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_ein.commands.execute {"val":false,"ack":true,"ts":1627844508102,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066074}
                                2021-08-01 21:01:48.127 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüften.oid {"val":"a69a2669-a0db-4f54-a4f5-96a9eed64628","ack":true,"ts":1627844508104,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066075}
                                2021-08-01 21:01:48.129 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüften.commands.execute {"val":false,"ack":true,"ts":1627844508105,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066101}
                                2021-08-01 21:01:48.137 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_aus.oid {"val":"f811d8aa-c0ca-4347-9739-9cdf4b1424c9","ack":true,"ts":1627844508117,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066102}
                                2021-08-01 21:01:48.138 - debug: tahoma.0 (16558) stateChange tahoma.0.actionGroups.Lüftung_aus.commands.execute {"val":false,"ack":true,"ts":1627844508129,"q":0,"from":"system.adapter.tahoma.0","user":"system.user.admin","lc":1626551066232}
                                2021-08-01 21:01:48.310 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.gatewayId => xxxx-xxxx-xxxx
                                2021-08-01 21:01:48.310 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.type => 29
                                2021-08-01 21:01:48.311 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.subType => 14
                                2021-08-01 21:01:48.312 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.placeOID => b80f5c61-7e8e-4862-9705-1a1fc4b2e4ff
                                2021-08-01 21:01:48.312 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.alive => false
                                2021-08-01 21:01:48.313 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.timeReliable => false
                                2021-08-01 21:01:48.313 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.connectivity.status => OK
                                2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.connectivity.protocolVersion => 2021.2.4
                                2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.upToDate => false
                                2021-08-01 21:01:48.314 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.updateStatus => UP_TO_DATE
                                2021-08-01 21:01:48.315 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.syncInProgress => false
                                2021-08-01 21:01:48.315 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.mode => ACTIVE
                                2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState xxxx-xxxx-xxxx.functions => INTERNET_AUTHORIZATION,SCENARIO_DOWNLOAD,SCENARIO_AUTO_LAUNCHING,SCENARIO_TELECO_LAUNCHING,INTERNET_UPLOAD,INTERNET_UPDATE,TRIGGERS_SENSORS
                                2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState location.creationTime => 1469357137000
                                2021-08-01 21:01:48.316 - debug: tahoma.0 (16558) setState location.lastUpdateTime => 1619290314000
                                2021-08-01 21:01:48.317 - debug: tahoma.0 (16558) setState location.city => Traumland
                                2021-08-01 21:01:48.317 - debug: tahoma.0 (16558) setState location.country => Germany
                                2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.postalCode => 66666
                                2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.addressLine1 => Himmelstor 7
                                2021-08-01 21:01:48.318 - debug: tahoma.0 (16558) setState location.addressLine2 => 0
                                2021-08-01 21:01:48.319 - debug: tahoma.0 (16558) setState location.timezone => Europe/Berlin
                                2021-08-01 21:01:48.319 - debug: tahoma.0 (16558) setState location.longitude => 11.5713
                                2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.latitude => 49.9456
                                2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.twilightMode => 2
                                2021-08-01 21:01:48.320 - debug: tahoma.0 (16558) setState location.twilightAngle => CIVIL
                                2021-08-01 21:01:48.321 - debug: tahoma.0 (16558) setState location.twilightCity => berlin
                                2021-08-01 21:01:48.321 - debug: tahoma.0 (16558) setState location.summerSolsticeDuskMinutes => 1290
                                2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.winterSolsticeDuskMinutes => 990
                                2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.twilightOffsetEnabled => false
                                2021-08-01 21:01:48.322 - debug: tahoma.0 (16558) setState location.dawnOffset => 0
                                2021-08-01 21:01:48.323 - debug: tahoma.0 (16558) setState location.duskOffset => -15
                                2021-08-01 21:01:48.323 - debug: tahoma.0 (16558) setState location.countryCode => DE
                                2021-08-01 21:01:48.324 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack) => 0
                                2021-08-01 21:01:48.324 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack).deviceURL => homekit://xxxx-xxxx-xxxx/stack
                                2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.HOMEKIT_(stack).commands.deleteControllers => false
                                2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.Alarm => 0
                                2021-08-01 21:01:48.325 - debug: tahoma.0 (16558) setState devices.Alarm.deviceURL => internal://xxxx-xxxx-xxxx/alarm/0
                                2021-08-01 21:01:48.326 - debug: tahoma.0 (16558) setState devices.Alarm.states.core:NameState => TSK Alarm
                                2021-08-01 21:01:48.326 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:CurrentAlarmModeState => off
                                2021-08-01 21:01:48.327 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:AlarmDelayState => 60
                                2021-08-01 21:01:48.330 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:TargetAlarmModeState => off
                                2021-08-01 21:01:48.331 - debug: tahoma.0 (16558) setState devices.Alarm.states.internal:IntrusionDetectedState => notDetected
                                2021-08-01 21:01:48.331 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmOff => false
                                2021-08-01 21:01:48.332 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmOn => false
                                2021-08-01 21:01:48.332 - debug: tahoma.0 (16558) setState devices.Alarm.commands.arm => false
                                2021-08-01 21:01:48.333 - debug: tahoma.0 (16558) setState devices.Alarm.commands.disarm => false
                                2021-08-01 21:01:48.333 - debug: tahoma.0 (16558) setState devices.Alarm.commands.getName => false
                                2021-08-01 21:01:48.334 - debug: tahoma.0 (16558) setState devices.Alarm.commands.off => false
                                2021-08-01 21:01:48.334 - debug: tahoma.0 (16558) setState devices.Alarm.commands.on => false
                                2021-08-01 21:01:48.335 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshAlarmDelay => false
                                2021-08-01 21:01:48.335 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshCurrentAlarmMode => false
                                2021-08-01 21:01:48.336 - debug: tahoma.0 (16558) setState devices.Alarm.commands.refreshIntrusionDetected => false
                                2021-08-01 21:01:48.336 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmPartial1 => false
                                2021-08-01 21:01:48.337 - debug: tahoma.0 (16558) setState devices.Alarm.commands.alarmPartial2 => false
                                2021-08-01 21:01:48.337 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste => 0
                                2021-08-01 21:01:48.338 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.deviceURL => internal://xxxx-xxxx-xxxx/pod/0
                                2021-08-01 21:01:48.338 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:NameState => Box
                                2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.internal:BatteryStatusState => no
                                2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:CyclicButtonState => stop
                                2021-08-01 21:01:48.339 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.internal:LightingLedPodModeState => 0.2
                                2021-08-01 21:01:48.340 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:CountryCodeState => DE
                                2021-08-01 21:01:48.340 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.states.core:LocalIPv4AddressState => 192.168.2.140
                                2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.getName => false
                                2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.update => false
                                2021-08-01 21:01:48.341 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.activateCalendar => false
                                2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.deactivateCalendar => false
                                2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshBatteryStatus => false
                                2021-08-01 21:01:48.342 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshPodMode => false
                                2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.refreshUpdateStatus => false
                                2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.setPodLedOff => false
                                2021-08-01 21:01:48.343 - debug: tahoma.0 (16558) setState devices.Sensitive_Taste.commands.setPodLedOn => false
                                2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe => 0
                                2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe.deviceURL => io://xxxx-xxxx-xxxx/11816111
                                2021-08-01 21:01:48.344 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:NameState => Stehlampe
                                2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:StatusState => available
                                2021-08-01 21:01:48.345 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:RSSILevelState => 88
                                2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.states.core:OnOffState => off
                                2021-08-01 21:01:48.346 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.getName => false
                                2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.identify => false
                                2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.off => false
                                2021-08-01 21:01:48.347 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.on => false
                                2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.startIdentify => false
                                2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.stopIdentify => false
                                2021-08-01 21:01:48.348 - debug: tahoma.0 (16558) setState devices.Stehlampe.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer => 0
                                2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.deviceURL => io://xxxx-xxxx-xxxx/1211100
                                2021-08-01 21:01:48.349 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:NameState => 3. Esszimmer
                                2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:PriorityLockTimerState => 0
                                2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:StatusState => available
                                2021-08-01 21:01:48.350 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:RSSILevelState => 100
                                2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:MovingState => false
                                2021-08-01 21:01:48.351 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ManufacturerSettingsState => [object Object]
                                2021-08-01 21:01:48.353 - error: tahoma.0 (16558) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-01 21:01:48.354 - error: tahoma.0 (16558) unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:48.357 - error: tahoma.0 (16558) Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23)
                                at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21)
                                at processImmediate (internal/timers.js:463:21)
                                2021-08-01 21:01:48.357 - error: tahoma.0 (16558) The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                2021-08-01 21:01:48.358 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ClosureState => 0
                                2021-08-01 21:01:48.359 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:ClosureState:slow => 0
                                2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:OpenClosedState => open
                                2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:Memorized1PositionState => 41
                                2021-08-01 21:01:48.360 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:TargetClosureState => 0
                                2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.states.core:TargetClosureState:slow => 0
                                2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.close => false
                                2021-08-01 21:01:48.361 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.close:slow => false
                                2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.down => false
                                2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.down:slow => false
                                2021-08-01 21:01:48.362 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.getName => false
                                2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.identify => false
                                2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.my => false
                                2021-08-01 21:01:48.363 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.open => false
                                2021-08-01 21:01:48.364 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.open:slow => false
                                2021-08-01 21:01:48.364 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.refreshMemorized1Position => false
                                2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.startIdentify => false
                                2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.stop => false
                                2021-08-01 21:01:48.365 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.stopIdentify => false
                                2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.up => false
                                2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.up:slow => false
                                2021-08-01 21:01:48.366 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.keepOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.sendIOKey => false
                                2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.unpairAllOneWayControllersAndDeleteNode => false
                                2021-08-01 21:01:48.367 - debug: tahoma.0 (16558) setState devices.3__Esszimmer.commands.unpairAllOneWayControllers => false
                                2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe => 0
                                2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.deviceURL => io://xxxx-xxxx-xxxx/12362917
                                2021-08-01 21:01:48.368 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:NameState => 2. Küche Türe
                                2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.io:PriorityLockOriginatorState => user
                                2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:PriorityLockTimerState => 7650
                                2021-08-01 21:01:48.369 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.io:PriorityLockLevelState => userLevel2
                                2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:StatusState => available
                                2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:DiscreteRSSILevelState => good
                                2021-08-01 21:01:48.370 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:RSSILevelState => 84
                                2021-08-01 21:01:48.371 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:MovingState => false
                                2021-08-01 21:01:48.371 - debug: tahoma.0 (16558) setState devices.2__Küche_Türe.states.core:ClosureState => 0
                                Vielen Dank für deine Unterstützung.
                                Gruß Willi
                                W Offline
                                W Offline
                                Willi-Wunder
                                #155
                                Hier mal der reine error log:
                                143
                                Log-Größe: 90.7 KB
                                Zeit
                                Nachricht
                                tahoma.0
                                	2021-08-01 21:02:22.427	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                tahoma.0
                                	2021-08-01 21:02:22.196	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.195	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
                                tahoma.0
                                	2021-08-01 21:02:22.195	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.195	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                tahoma.0
                                	2021-08-01 21:02:22.173	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.172	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
                                tahoma.0
                                	2021-08-01 21:02:22.172	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.172	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                tahoma.0
                                	2021-08-01 21:02:22.110	error	The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.110	error	Error: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6004:23) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:659:23) at processImmediate (internal/timers.js:463:21)
                                tahoma.0
                                	2021-08-01 21:02:22.107	error	unhandled promise rejection: The state contains the forbidden properties discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, smart_protect, unroll_end_limit_state, security_level!
                                tahoma.0
                                	2021-08-01 21:02:22.106	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                tahoma.0
                                	2021-08-01 21:01:48.676	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                ExcodiburE 1 Antwort Letzte Antwort
                                • W Willi-Wunder
                                  143
                                  Log-Größe: 90.7 KB
                                  Zeit
                                  Nachricht
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  tahoma.0
                                  ExcodiburE Offline
                                  ExcodiburE Offline
                                  Excodibur
                                  #156
                                  @willi-wunder Danke, ich hoffe ich komme dazu es mir die nächsten Tage mal genauer anzuschauen.
                                  Ich vermute es hat damit zu tun, dass die Tahoma-API für ManufacturerSettingsState statt eines einfachen Wertes (Zahl, Boolean) eine ganze Liste an Werten (discreet_mode_speed, roll_end_limit_state, setting_state, open_level, soft_start, current_position, soft_stop, nominal_mode_speed, unroll_end_limit_state, security_level) zurückgibt, die der Adapter dann alle in einem IOBroker State versucht abzuspeichern, was nicht geht. Daraufhin kommen dann die Fehlermeldungen. Wenn sich dass dann noch häuft, vermute ich mal, das der Adapter ein Problem bekommt.
                                  Bei mir und meinen IO Rolläden ist dieser State nur "undefined", d.h. er wird nicht gepflegt und führt dann auch nicht zu Fehlern im Adapter-Code. Vielleicht hast du da neuere Somfy Komponenten eingebunden, die mehr Daten liefern, als die klassischen und das bringt den Adapter ins Stocken.
                                  Als Entwickler ist es immer schwer, wenn man nicht die gleichen Geräte zur Verfügung hat, um solche Szenarien nachzustellen und zu beheben. Die Somfy-Doku ist an dieser Stelle auch quasi nicht existent. Ich überlege mal, was man da machen kann.
                                  W 1 Antwort Letzte Antwort
                                  • ExcodiburE Excodibur
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    #157
                                    @excodibur
                                    Hi, ja habe auch ein paar RS100 io Motoren laufen, diese sind deutlich leiser als der normale io Motor und man könnte mehr Daten auslesen........ Rauchmelder, Temperatur- und Sonnensensor hängen auch dran. Damals hatte ich noch keinen iobroker und da gab es für mich nur die Somfy Sachen. Mittlerweile würde ich dies etwas anders lösen.....aber mit Tahoma funktioniert dies ja eigentlich ganz ordentlich. Wäre super wenn du hier helfen könntest. Wünsche dir einen schönen Restsonntag.
                                    Gruß Willi
                                    • W Willi-Wunder
                                      @excodibur
                                      Gruß Willi
                                      ExcodiburE Offline
                                      ExcodiburE Offline
                                      Excodibur
                                      #158
                                      @willi-wunder Wäre es möglich, dass du dir meine Version (https://github.com/Excodibur/ioBroker.tahoma) mal installierst, den Log auf "debug" stellst, und mir alle "Response:" - Einträge schickst? Gerne auch per PN.
                                      Bitte schaue vorher nochmal drüber, dass keine personenbezogenen Daten drin sind. An einigen Stellen könnte deine private Mailaddresse, oder unter location deine private Anschrift aus der Tahoma-Box stehen. Am besten vorher ersetzen, oder löschen.
                                      Ich habe bei mir die Antworten von Somfy/Tahoma für meinen Account ebenfalls erfasst und könnte dann auf der Basis vergleichen, wie sich deine Device-Daten von meinen unterscheiden und isolieren, wo es im Adapter hängt. Genauer noch suche ich nach der Response die den String "SETUP-" enthält - dort stehen alle deine Geräte/Devices drin.
                                        W Offline
                                        W Offline
                                        Willi-Wunder
                                        #159
                                        @excodibur
                                        Herzlichen Dank an dich, funktioniert jetzt wieder 💪 👍 👍
                                        Schick dir noch den aktuellen Log per Mail nach deiner Anpassung, vielleicht als Feedback ganz nützlich. Woran lag es nun? Interessiert bestimmt die anderen auch. 😁 Machst du eine neue Version mit der Anpassung? Heißt es nun, dass der Adapter wieder lebt und einen neuen "Macher" hat? 🍻
                                        -1
                                        • W Willi-Wunder
                                          @excodibur
                                          ExcodiburE Offline
                                          ExcodiburE Offline
                                          Excodibur
                                          #160
                                          @willi-wunder Wie vermutet, lag es an der zusätzlichen Komplexität des Somfy-Gerätes. Ich würde gerne ein neues Release des Adapters ausrollen, muss mich dazu aber erst mal mit seinem Schöpfer in Verbindung setzen, zwecks Berechtigungen. :-)
