  3. Off Topic
  4. Pflege des Betriebssystems
  5. Update Adapter Worx Landroid v3.2.0 auf 3.2.6 Axios Fehler
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
6 Beiträge 4 Kommentatoren 495 Aufrufe 3 Beobachtet
    Powertrain01
    Ich bekomme das Update vom Worx adapter nicht hin bekomme immer einen Axios Fehler das er Axiom 1.9.0 nicht findet.
    Job update und uprgade habe ich schon mehrfach gemacht ebenso Lob fix
    ich hab auch schon nodes 20 neu installieren lasen.
    hier mal die ausgabe vom iob diag:
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 5.10.103-v7l+
        Architecture: arm
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     08:53:30 up 13 days, 19:57,  2 users,  load average: 1.01, 1.74, 2.16
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-07-13 08:53:31 CEST
               Universal time: Sun 2025-07-13 06:53:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.3G        2.2G        4.5G        1.1M        1.7G        6.1G
    Swap:           209M          0B        209M
    Total:          8.5G        2.2G        4.8G
    Active iob-Instances:   36
             7898 M total memory
             2080 M used memory
              888 M active memory
             2471 M inactive memory
             4336 M free memory
              333 M buffer memory
             1334 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 08:53:31 up 13 days, 19:57,  2 users,  load average: 1.25, 1.77, 2.17
    Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 11.1 us, 22.2 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7898.7 total,   4335.0 free,   2082.4 used,   1668.0 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5816.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    56 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    /dev/root      ext4       59G   17G   40G  30% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sun Jun 29 12:55:55 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D7:62:FF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=3c507973-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sun Jun 29 12:55:56 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jun 29 12:55:56 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Jun 29 12:55:59 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.1G    /var/
    1.5G    /var/log/journal/8e58b1ab43b84d8f9f6cff709545957b
    1.5G    /var/log
    230M    /var/lib
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    610M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    635M    /opt/iobroker/iobroker-data/files/vis-2-beta
    545M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    543M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
    106M    /opt/iobroker/iobroker-data/states.jsonl
    49M     /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.1
    /usr/bin/node           v20.19.1
    /usr/bin/npm            11.4.2
    /usr/bin/npx            11.4.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         20.19.0-1nodesource1 600
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main armhf Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1034)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     2
    +-- iobroker.euhome@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#084d3e93ea1dac3784775ef7f2e7b9a18b21f2eb)
    +-- iobroker.time-switch@2.2.1 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#f24abb3a0b416bc21e7315e7cfa10ba3261f4bfe)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.euhome.0                 : euhome                : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.mclighting.0             : mclighting            : raspberrypi                              - disabled, port: 81
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sun2000.0                : sun2000               : raspberrypi                              - disabled, port: 502
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
    + system.adapter.xterm.0                  : xterm                 : raspberrypi                              -  enabled, port: 8099, bind: 0.0.0.0
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "asterisk"     : 2.0.3    , installed 2.0.3
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fhem"         : 3.0.0    , installed 3.0.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mclighting"   : 0.2.0    , installed 0.2.0
    Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "shelly"       : 10.0.0   , installed 10.0.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sun2000"      : 1.4.0    , installed 1.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "worx"         : 3.2.6    , installed 3.2.0  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "xterm"        : 2.0.1    , installed 2.0.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        36236
    States:         31146
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11401402   22155/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12046      538/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14523      721/influxd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13675      985/exim4
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11403342   21614/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11399436   21558/io.sonoff.0
    tcp        0      0 0.0.0.0:44417           0.0.0.0:*               LISTEN      1001       11400545   21895/io.yahka.0
    tcp        0      0 0.0.0.0:41061           0.0.0.0:*               LISTEN      1001       11400543   21895/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11395832   21295/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11396289   21295/iobroker.js-c
    tcp        0      0 127.0.0.1:36877         0.0.0.0:*               LISTEN      1001       11402568   21895/io.yahka.0
    tcp        0      0 127.0.0.1:34319         0.0.0.0:*               LISTEN      1001       11402572   21895/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11396368   21313/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11401317   21747/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14573      721/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12048      538/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       11401346   21976/io.simple-api
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13676      985/exim4
    tcp6       0      0 :::8099                 :::*                    LISTEN      1001       11399662   21677/io.xterm.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11400211   21441/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11400212   21441/io.tuya.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11972      370/avahi-daemon: r
    udp        0      0 0.0.0.0:54104           0.0.0.0:*                           108        11974      370/avahi-daemon: r
    udp6       0      0 fe80::d118:265b:8cb:546 :::*                                0          14375      495/NetworkManager
    udp6       0      0 :::5353                 :::*                                108        11973      370/avahi-daemon: r
    udp6       0      0 :::35153                :::*                                108        11975      370/avahi-daemon: r
    2025-07-13 08:50:32.541  - info: dwd.0 (22819) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.1, js-controller: 7.0.6
    2025-07-13 08:50:33.853  - info: dwd.0 (22819) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-07-13 08:50:34.336  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:50:34.337  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:50:34.387  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 22819 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-07-13 08:51:11.670  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:51:11.673  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:51:34.847  - info: shelly.0 (21614) [MQTT] Client Error: 192.168.89.59 (shellyswitch25 / shellyswitch25-E8DB84ABDD39 / SHSW-25#E8DB84ABDD39#1) (Error: read ECONNRESET)
    2025-07-13 08:51:36.812  - info: shelly.0 (21614) [MQTT] Device with client id "shellyswitch25-E8DB84ABDD39" connected from 192.168.89.59!
    2025-07-13 08:51:41.692  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:51:41.693  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:52:12.801  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:52:12.802  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:52:42.824  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:52:42.827  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:53:12.931  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:53:12.932  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:53:44.128  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:53:44.130  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:54:01.944  - info: shelly.0 (21614) [MQTT] Client Error: 192.168.89.59 (shellyswitch25 / shellyswitch25-E8DB84ABDD39 / SHSW-25#E8DB84ABDD39#1) (Error: read ECONNRESET)
    2025-07-13 08:54:04.088  - info: shelly.0 (21614) [MQTT] Device with client id "shellyswitch25-E8DB84ABDD39" connected from 192.168.89.59!
    2025-07-13 08:54:21.296  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    2025-07-13 08:54:21.298  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:54:58.497  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
    2025-07-13 08:54:58.498  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
    iob diag has finished.
    Danke für die Unterstützung.
    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
    • P Powertrain01
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm
      OS is similar to:
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               7898 M total memory
               2080 M used memory
                888 M active memory
               4336 M free memory
                333 M buffer memory
               1334 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      2.1G    /var/
      1.5G    /var/log
      230M    /var/lib
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            11.4.2
      /usr/bin/npx            11.4.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        36236
      States:         31146
      Pending Updates: 0
      @powertrain01
      Das Betriebssystem ist falsch aufgesetzt. Haste von einer Vorversion versucht per 'inline'-Update auf 'Bookworm zu hieven.
      Funktioniert aber nicht.
      Installier da komplett neu das aktuelle RaspberryOS-Lite-64Bit.
      P 1 Antwort Letzte Antwort
      • P Powertrain01
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
        OS is similar to:
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 7898 M total memory
                 2080 M used memory
                  888 M active memory
                 4336 M free memory
                  333 M buffer memory
                 1334 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        2.1G    /var/
        1.5G    /var/log
        230M    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            11.4.2
        /usr/bin/npx            11.4.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        36236
        States:         31146
        Pending Updates: 0
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @powertrain01
        Du hast lt. iob diag worx 3.2.0 installiert.
        Bitte zeig wann du welche Fehlermeldung bezüglich axios erhälts, also bei der Installation oder beim Adapterstart oder ,.. Gib auch an von wo du installierst (github, nom, latest / stable Repo ...)
        Und zeig die vollständigen Fehlerinformatione / Logfile dazu.
        worx verlangt übrigends axios >= 1.10.0. Insofern ist deine Angabe 1.9.0 nicht auf Anhieb nachvollziehbar.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          @powertrain01
          @mcm1957 sagte in Update Adapter Worx Landroid v3.2.0 auf 3.2.6 Axios Fehler:
          https://forum.iobroker.net/post/1282831
            @powertrain01
            Powertrain01
            schrieb am zuletzt editiert von Powertrain01
            das habe ich fast schon befürchtet das das wohl der weg sein wird.
            würdest du in diesem Zusammenhang dann gleich auf docker wechseln?
            hab hier noch einen neuen Raspberry dann werde ich den wohl nächste Woche mal Installieren.
            • P Powertrain01
              @powertrain01
              Dann kannst du auch gleich die anderen Kinken angehehn.
              Stromversorgung, Zigbee-Gerät usw.
