  4. Uralt System updaten oder Umzug
    2.9k
    5.0k
148 Beiträge 13 Kommentatoren 17.9k Aufrufe 11 Beobachtet
    Mr.X
    Nicht schimpfen.
    ich gelobe zukünftig mehrmals im Jahr alles upzugraden.......
    Falls hier noch was zu retten ist.
    Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
    • M Mr.X
      Ich versuche es. Schon mal an ALLE BESTEN DANK.
      Kann sein, dass ich erst morgen reagieren kann.
      nodejs und npm scheinen OK zu sein. aber ich konnte nie den js.controller updaten.
      Kann es daran liegen, dass ich die Adapter etc. nicht mehr updaten kann?
      Script v.2025-02-23
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       21:50:51 up 11:31,  1 user,  load average: 1.07, 1.47, 0.86
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'buster' is the current oldstable version. Please upgrade to the latest stable release '' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-05-08 21:50:51 CEST
                 Universal time: Thu 2025-05-08 19:50:51 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        180M        2.9G         16M        793M        3.5G
      Swap:           99M          0B         99M
      Total:         3.9G        180M        3.0G
      Active iob-Instances:   1
               3837 M total memory
                180 M used memory
                469 M active memory
                333 M inactive memory
               2862 M free memory
                211 M buffer memory
                582 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 21:50:51 up 11:31,  1 user,  load average: 1.07, 1.47, 0.86
      Tasks: 153 total,   1 running, 152 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  2.9 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3837.7 total,   2862.4 free,    181.0 used,    794.4 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3483.7 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       28G  6.2G   21G  23% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Thu May  8 10:19:10 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:22:A7:57 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Thu May  8 10:19:12 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu May  8 10:19:12 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu May  8 10:19:14 2025] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda2 ext4   rw,noatime
      |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      625M    /var/lib
      536M    /var/cache
      531M    /var/cache/apt
      517M    /var/lib/piVCCU3
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      156M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      302M    /opt/iobroker/iobroker-data/
      141M    /opt/iobroker/iobroker-data/files
      120M    /opt/iobroker/iobroker-data/backup-objects
      41M     /opt/iobroker/iobroker-data/files/javascript.admin
      31M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/objects.json.migrated
      11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      8.0M    /opt/iobroker/iobroker-data/files/jarvis/static/js/11.443f46f8.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.8fd7d552.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.18.1
      /usr/bin/node           v16.18.1
      /usr/bin/npm            8.19.2
      /usr/bin/npx            8.19.2
      /usr/bin/corepack       0.14.1
      nodejs:
        Installed: 16.18.1-deb-1nodesource1
        Candidate: 16.20.2-deb-1nodesource1
        Version table:
           16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
       *** 16.18.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      broker-slave        broker-slave (version: 3.1.6, hostname: broker-slave  ,  dead, uptime: 24)
      raspberrypi         raspberrypi (version: 4.0.23, hostname: raspberrypi   ,  dead, uptime: 39247)
      Core adapters versions
      js-controller:  4.0.23
      admin:          4.2.2
      javascript:     4.11.0
      nodejs modules from github:     4
      +-- iobroker.blockly-plus@0.0.1 invalid: "https://github.com/excal-foley/ioBroker.blockly-plus/tarball/8487239d69fc53c13853013110da15b42bc487e9" from the root project
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      +-- iobroker.jarvis@3.1.2 invalid: "https://github.com/Zefau/ioBroker.jarvis/tarball/master" from the root project
      | `-- socksv5@0.0.6 invalid: "https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9" from node_modules/iobroker.telegram
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.blockly-plus.0           : blockly-plus          : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 2010
        system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
        system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
        system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
        system.adapter.zigbee.1                 : zigbee                : broker-slave                             -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Adapters
      Adapter    "admin"        : 7.6.3    , installed 4.2.2  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
      Adapter    "amazon-dash"  : 1.2.0    , installed 1.1.0  [Updatable]
      Adapter    "backitup"     : 3.0.31   , installed 2.5.9  [Updatable]
      Adapter    "broadlink2"   : 2.3.0    , installed 2.1.5  [Updatable]
      Adapter    "cloud"        : 5.0.1    , installed 4.3.0  [Updatable]
      Adapter    "devices"      : 1.1.5    , installed 0.3.16 [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 2.8.0  [Updatable]
      Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
      Adapter    "habpanel"     : 0.5.0    , installed 0.4.3  [Updatable]
      Adapter    "ham"          : 5.3.1    , installed 5.3.0  [Updatable]
      Adapter    "history"      : 3.0.1    , installed 1.11.1 [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 2.6.25 [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.15 [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 1.12.5 [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
      Adapter    "javascript"   : 8.8.3    , installed 4.11.0 [Updatable]
      Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
      Adapter    "lovelace"     : 4.1.15   , installed 1.5.0  [Updatable]
      Adapter    "milight"      : 0.4.0    , installed 0.3.6  [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 2.7.4  [Updatable]
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.3.13 [Updatable]
      Adapter    "nuki-extended": 2.7.0    , installed 2.6.5  [Updatable]
      Adapter    "openweathermap": 1.1.2   , installed 0.1.0  [Updatable]
      Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
      Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
      Adapter    "shelly"       : 9.2.0    , installed 4.1.2  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
      Adapter    "socketio"     : 6.7.1    , installed 3.1.5  [Updatable]
      Adapter    "sonoff"       : 3.1.2    , installed 2.5.1  [Updatable]
      Adapter    "statistics"   : 2.4.0    , installed 1.1.1  [Updatable]
      Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
      Adapter    "telegram"     : 4.1.0    , installed 1.15.2 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
      Adapter    "tuya"         : 3.16.0   , installed 3.10.2 [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
      Adapter    "weatherunderground": 3.7.0, installed 3.4.2 [Updatable]
      Adapter    "web"          : 7.0.8    , installed 3.4.16 [Updatable]
      Adapter    "zigbee"       : 2.0.5    , installed 1.8.7  [Updatable]
      Objects and States
      Objects:        9414
      States:         8048
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Hit:4 https://www.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 174
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          16283      593/sshd
      tcp6       0      0 :::22                   :::*                    LISTEN        0          16285      593/sshd
      udp        0      0 0.0.0.0:38918           0.0.0.0:*        108        16743      398/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*        0          13992      447/dhclient
      udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        16741      398/avahi-daemon: r
      udp6       0      0 :::41490                :::*        108        16744      398/avahi-daemon: r
      udp6       0      0 :::5353                 :::*        108        16742      398/avahi-daemon: r
      2025-05-08 21:45:44.450  - info: host.raspberrypi instance system.adapter.backit        up.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-05-08 21:45:44.522  - info: host.raspberrypi instance system.adapter.statis        tics.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-05-08 21:45:44.523  - info: host.raspberrypi instance system.adapter.alexa2        .0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-05-08 21:45:44.590  - info: host.raspberrypi instance system.adapter.web.0        terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-05-08 21:45:44.590  - info: host.raspberrypi All instances are stopped.
      2025-05-08 21:45:44.822  - warn: host.raspberrypi Cannot get view: Connection is        closed.
      2025-05-08 21:45:44.823  - warn: host.raspberrypi Cannot get view: Connection is        closed.
      2025-05-08 21:45:44.823  - error: host.raspberrypi Cannot find view "system" for        search "instance" : Connection is closed.
      2025-05-08 21:45:44.826  - warn: host.raspberrypi instance system.adapter.javasc        ript.0 terminated due to SIGTERM
      2025-05-08 21:45:44.827  - info: host.raspberrypi instance system.adapter.javasc        ript.0 terminated with code null ()
      2025-05-08 21:45:44.827  - info: host.raspberrypi All instances are stopped.
      2025-05-08 21:45:44.827  - warn: host.raspberrypi instance system.adapter.tanker        koenig.0 terminated due to SIGTERM
      2025-05-08 21:45:44.828  - info: host.raspberrypi instance system.adapter.tanker        koenig.0 terminated with code null ()
      2025-05-08 21:45:44.828  - info: host.raspberrypi All instances are stopped.
      2025-05-08 21:45:44.828  - warn: host.raspberrypi instance system.adapter.telegr        am.0 terminated due to SIGTERM
      2025-05-08 21:45:44.829  - info: host.raspberrypi instance system.adapter.telegr        am.0 terminated with code null ()
      2025-05-08 21:45:44.829  - info: host.raspberrypi All instances are stopped.
      2025-05-08 21:45:44.829  - warn: host.raspberrypi instance system.adapter.zigbee        .0 terminated due to SIGTERM
      2025-05-08 21:45:44.829  - info: host.raspberrypi instance system.adapter.zigbee        .0 terminated with code null ()
      2025-05-08 21:45:44.830  - info: host.raspberrypi All instances are stopped.
      2025-05-08 21:45:44.830  - info: host.raspberrypi instance system.adapter.histor        y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2025-05-08 21:45:44.902  - info: host.raspberrypi terminated
      @mr-x
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      iob nodejs-update 18
      iob update
      iob upgrade all -y
      iob upgrade self
      cd /opt/iobroker
      npm install iobroker.js-controller@5.0.0
      iob start
      iob stop
      iob update
      iob upgrade all -y
      iob upgrade self
      cd /opt/iobroker
      npm install iobroker.js-controller@6.0.0
      iob start
      iob stop
      iob update
      iob upgrade all -y
      iob upgrade self
      cd /opt/iobroker
      npm install iobroker.js-controller@latest
      iob start
      iob update
      iob upgrade all -y
      Und dann noch mal die Ausgabe von iob diag, damit man den Stand sieht.
      Das ganze kann geraume Zeit dauern.
        Mr.X
        Besten Dank, ihr seid die Besten.
        Ich melde mich morgen mit dem Resultat.
        • M Mr.X
          Nicht schimpfen.
          @mr-x sagte in Uralt System updaten oder Umzug:
          Nimm dir mehrmals im Monat vor. Und auch das Betriebssystem nicht vergessen. Das muss auch aktuell gehalten werden.
            Mr.X
            Guten morgen, bin wieder da und würde gerne einen kleinen zwischenstand liefern, da ich errors bekommen haben beim upgrade vom
            js.controller.
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-crontroller@5.0.0
            npm error code E404
            npm error 404 Not Found - GET https://registry.npmjs.org/iobroker.js-crontroller - Not found
            npm error 404
            npm error 404  'iobroker.js-crontroller@5.0.0' is not in this registry.
            npm error 404
            npm error 404 Note that you can also install from a
            npm error 404 tarball, folder, http url, or git url.
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-05-09T07_08_45_905Z-debug-0.log
            • M Mr.X
              js.controller.
              npm error code E404
              npm error 404
              npm error 404
              CodierknechtC Online
              Codierknecht
              @mr-x
              Das Ding heißt "js-controller" und nicht "js-crontroller" !!!
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
                Mr.X
                Peinlich.
                Leider kriege ich es trotzdem nicht hin. Offenbar gibts die 5.0.0 nicht???
                pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.0
                npm error code ETARGET
                npm error notarget No matching version found for iobroker.js-controller@5.0.0.
                npm error notarget In most cases you or one of your dependencies are requesting
                npm error notarget a package version that doesn't exist.
                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-05-09T07_24_45_164Z-debug-0.log
                • M Mr.X
                  Peinlich.
                  durchaus möglich.
                  du solltest die letzte 5.x nehmen
                  EDIT nach Suche
                  @mcm1957 sagte in Problem beim Aktualisieren des Admin Adapters:
                  5.0.19 ist der letzte aktuelle 5er.
                  Ob 5.0.0 jemals online ging kann ich mich nicht erinnern
                    Mr.X
                    pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.19
                    npm error code EBADENGINE
                    npm error engine Unsupported engine
                    npm error engine Not compatible with your version of node/npm: iobroker.jarvis@3.2.0-rc.17
                    npm error notsup Not compatible with your version of node/npm: iobroker.jarvis@3.2.0-rc.17
                    npm error notsup Required: {"node":">= 20","npm":">= 9.3.1","yarn":">= 1.21.1"}
                    npm error notsup Actual:   {"npm":"10.8.2","node":"v18.20.8"}
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-05-09T07_39_00_228Z-debug-0.log
                    • M Mr.X
                      @mr-x noch kein node v20 drauf?
                        @mr-x
                        iob stop
                        sudo apt update
                        sudo reboot
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob stop
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob stop
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob update
                        iob upgrade all -y
                        Mr.X
                        schrieb am zuletzt editiert von Mr.X
                        @Homoran
                        thomas-braun sagte in Uralt System updaten oder Umzug:
                        iob stop
                        sudo apt update
                        sudo reboot
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob stop
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob stop
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        cd /opt/iobroker
                        iob start
                        iob update
                        iob upgrade all -y
                        Ich habe mich jetzt an diese Anleitung gehalten und bin mit Node auf
                        pi@raspberrypi:/opt/iobroker $ node -v
                        v18.20.8
                        • M Mr.X
                          @Homoran
                          iob stop
                          sudo apt update
                          sudo reboot
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          cd /opt/iobroker
                          iob start
                          iob stop
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          cd /opt/iobroker
                          iob start
                          iob stop
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          cd /opt/iobroker
                          iob start
                          iob update
                          iob upgrade all -y
                          v18.20.8
                          @mr-x dann geht controller v5 nicht
                          sorry!
                          jarvis sxheint das Problem zu sein
                            Mr.X
                            @Homoran
                            @Thomas-Braun
                            D.h. ohne Jarvis zu deinstallieren gehts nicht weiter?
                            Auf andere Adapter könnte ich verzichten, aber ausgerechnet Jarvis nutze ich aktiv.
                              sorry!
                              Mr.X
                              @homoran sagte in Uralt System updaten oder Umzug:
                              sorry!
                              Laut der Github Seit müsste js-controller 5 mit Node 16 gehen.
                              Compatibility
                              js-controller 7.x (Lucy) works with Node.js 18.x, 20.x and probably 22.x
                              js-controller 6.x (Kiera) works with Node.js 18.x, 20.x and probably 22.x
                              js-controller 5.x works with Node.js 16.x, 18.x and probably 20.x
                              • M Mr.X
                                sorry!
                                Compatibility
                                ja, deswegen die Korrektur
                                oder downgraden, oder später wieder installieren
                                  Mr.X
                                  @Homoran
                                  OK. ich mache alles, was ihr vorschlagt. Ohne euch bin ich verloren und wollte schon zu HA wechseln (aber HA ist kacke).
                                  hiermit deinstallieren?
                                  Delete adapter "jarvis"
                                  und danach nochmal versuchen?
                                  BTW: wollte nochmal eine aktuelle Jarvis Sicherung machen und sehe,dass der Zigbee Adapter nicht mehr verbindet und auch der Zugriff auf Google Drive nicht mehr geht.
                                  Das liegt vermutlich an den Bereits durchgeführten Updates, oder?
                                  • M Mr.X
                                    @Homoran
                                    da ich den aktuellen Zustand nicht kenne kann ich dazu gar nichts sagen.
                                    Selbst wenn ich den kennen würde, wäre es mit dem bunt gewürfelten Mix an Versionen sehr schwierig etwas definitives zu sagen.
                                    Ich verstehe auch nicht, wie da bereits eine Jarvis Version installiert sein kann, die nicht erfüllte Abhängigkeiten hat.
                                    wenn, dann iob del jarvis
                                    • M Mr.X
                                      "node":"v18.20.8"}
                                      Edit:
                                      Das sind die Auswirkungen, wenn man die Kisten nicht permanent pflegt...
                                      • M Mr.X
                                        @Homoran
                                        @mr-x
                                        Du wirst dann jetzt öfters die Ausgaben von
                                        iob diag
                                        posten müssen. Nur damit kann man sehen, was da gerade der Stand ist.
                                          Mr.X
                                          @Thomas-Braun
                                          pi@raspberrypi:/opt/iobroker $ iob del jarvis
                                          host.raspberrypi Counted 2 states (system.adapter.jarvis.*) from states
                                          host.raspberrypi object jarvis deleted
                                          host.raspberrypi object jarvis.admin deleted
                                          host.raspberrypi Deleting 2 state(s).
                                          Error deleting adapter jarvis from disk: Cannot find module 'iobroker.jarvis/io-package.json'
                                          Require stack:
                                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                          You might have to delete it yourself!
                                          Mit fileZilla löschen?
