  4. über Port 8081 und 8082 kann ich ioBroker nicht aufrufen
77 Beiträge 5 Kommentatoren 9.7k Aufrufe 4 Beobachtet
  • T Thorsten4-71
    @mcm1957 said in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
    iob diag
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:15:07 up 9 min,  4 users,  load average: 0.43, 0.76, 0.62
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-02-01 16:15:07 CET
               Universal time: Sat 2025-02-01 15:15:07 UTC
                     RTC time: Sat 2025-02-01 15:15:07
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    shthorsten
    HOME=/home/shthorsten
    GROUPS=shthorsten adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.2G        2.0G        1.2G         24M        1.2G        2.3G
    Swap:           155M          0B        155M
    Total:          4.4G        2.0G        1.3G
    Active iob-Instances:   30
             4045 M total memory
             1875 M used memory
             1926 M active memory
              714 M inactive memory
             1105 M free memory
               91 M buffer memory
             1061 M swap cache
              148 M total swap
                0 M used swap
              148 M free swap
    top - 16:15:07 up 9 min,  4 users,  load average: 0.43, 0.76, 0.62
    Tasks: 239 total,   1 running, 238 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 60.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4045.0 total,   1104.7 free,   1875.8 used,   1153.3 buff/cache
    MiB Swap:    148.6 total,    148.6 free,      0.0 used.   2169.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    30 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     405M  5.9M  399M   2% /run
    /dev/mmcblk0p2 ext4       15G   14G  150M  99% /
    tmpfs          tmpfs     2.0G  288K  2.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
    tmpfs          tmpfs     405M  192K  405M   1% /run/user/1000
    [Sat Feb  1 16:05:53 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:3F:D8:81 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=fc87ad5e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sat Feb  1 16:05:54 2025] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
    [Sat Feb  1 16:05:55 2025] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    1.1G    /var/log/journal/404274c0b2bb418589be89042d5b9a67
    1.1G    /var/log
    995M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    859M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    37M     /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
         20.18.2-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
     *** 20.18.1-1nodesource1 600
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 543)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     3
    +-- gigaset-elements-api@0.5.2 (git+ssh://git@github.com/matthsc/gigaset-elements-api.git#c5508721b086232133d74e611a6dc3c92dc6d587)
    +-- iobroker.fritzbox@0.6.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fritzbox.git#0c5b36684af3391deca2ad094489c3915b6868c9)
    +-- iobroker.radar-trap@2.2.2 (git+ssh://git@github.com/Steiger04/ioBroker.radar-trap.git#57af772463c65406bc84e4042732fd606ef9faf5)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
      system.adapter.hmip.0                   : hmip                  : raspberrypi                              - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.71.55
    + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.pylontech.0              : pylontech             : raspberrypi                              - disabled, port: 8899
      system.adapter.radar-trap.0             : radar-trap            : raspberrypi                              - disabled
      system.adapter.radar2.0                 : radar2                : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: raspberrypi                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "alarm"        : 3.6.7    , installed 3.6.4  [Updatable]
    Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 3.4.1  [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "deyeidc"      : 0.1.1    , installed 0.1.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "growatt"      : 3.3.1    , installed 3.2.5  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hmip"         : 1.25.0   , installed 1.24.3 [Updatable]
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iqontrol"     : 3.0.0    , installed 2.3.0  [Updatable]
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "openligadb"   : 1.8.0    , installed 1.7.0  [Updatable]
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "pylontech"    : 0.0.10   , installed 0.0.10
    Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "rpi2"         : 2.3.1    , installed 2.2.1  [Updatable]
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.5.0  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
    Objects and States
    Objects:        6483
    States:         6151
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 92
    *** Listening Ports ***
    tcp        0      0 192.168.71.55:1883      0.0.0.0:*               LISTEN      1001       11134      2159/io.mqtt.0
    tcp        0      0 192.168.71.55:2001      0.0.0.0:*               LISTEN      1001       14346      2269/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5918       890/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7161       866/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8492       867/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8497       867/iobroker.js-con
    tcp        0      0 192.168.71.55:8701      0.0.0.0:*               LISTEN      1001       12443      2237/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12052      2121/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5920       890/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7160       866/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      112        6101       957/xrdp
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          5907       876/xrdp-sesman
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       12839      2500/io.web.0
    udp        0      0 0.0.0.0:59086           0.0.0.0:*                           104        7616       670/avahi-daemon: r
    udp        0      0 0.0.0.0:38640           0.0.0.0:*                           1001       15431      2345/io.broadlink2.
    udp        0      0 0.0.0.0:39058           0.0.0.0:*                           1001       14440      2345/io.broadlink2.
    udp        0      0 0.0.0.0:37314           0.0.0.0:*                           1001       15484      2345/io.broadlink2.
    udp        0      0 0.0.0.0:41484           0.0.0.0:*                           1001       15388      2345/io.broadlink2.
    udp        0      0 0.0.0.0:39487           0.0.0.0:*                           1001       15436      2345/io.broadlink2.
    udp        0      0 0.0.0.0:41566           0.0.0.0:*                           1001       15482      2345/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       12691      2345/io.broadlink2.
    udp        0      0 0.0.0.0:33523           0.0.0.0:*                           1001       15439      2345/io.broadlink2.
    udp        0      0 0.0.0.0:39971           0.0.0.0:*                           1001       15456      2345/io.broadlink2.
    udp        0      0 0.0.0.0:46197           0.0.0.0:*                           1001       15483      2345/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11168      2179/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7614       670/avahi-daemon: r
    udp        0      0 0.0.0.0:40179           0.0.0.0:*                           1001       14473      2345/io.broadlink2.
    udp        0      0 0.0.0.0:34090           0.0.0.0:*                           1001       14471      2345/io.broadlink2.
    udp        0      0 0.0.0.0:50579           0.0.0.0:*                           1001       14472      2345/io.broadlink2.
    udp        0      0 0.0.0.0:40364           0.0.0.0:*                           1001       14439      2345/io.broadlink2.
    udp6       0      0 fe80::2c7c:a66:e1e9:546 :::*                                0          9337       827/NetworkManager
    udp6       0      0 :::60425                :::*                                104        7617       670/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        7615       670/avahi-daemon: r
    2025-02-01 16:08:07.802  - info: tvspielfilm.0 (2312) Terminated (NO_ERROR): Without reason
    2025-02-01 16:08:08.043  - info: vis-2.0 (2536) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:08:08.250  - info: vis-2.0 (2536) vis-2 license is OK.
    2025-02-01 16:08:08.345  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2025-02-01 16:08:11.180  - info: host.raspberrypi instance system.adapter.growatt.0 in version "3.2.5" started with pid 2554
    2025-02-01 16:08:12.564  - info: growatt.0 (2554) starting. Version 3.2.5 in /opt/iobroker/node_modules/iobroker.growatt, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:08:15.068  - info: host.raspberrypi instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 2569
    2025-02-01 16:08:15.945  - info: vis-inventwo.0 (2569) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:08:19.034  - info: host.raspberrypi instance system.adapter.openligadb.0 in version "1.7.0" started with pid 2584
    2025-02-01 16:08:19.993  - info: openligadb.0 (2584) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.openligadb, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:08:23.056  - info: host.raspberrypi instance system.adapter.yahoo-stock-market.0 in version "0.0.7" started with pid 2599
    2025-02-01 16:08:24.723  - info: yahoo-stock-market.0 (2599) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.yahoo-stock-market, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:08:24.731  - info: yahoo-stock-market.0 (2599) initialize yahoo-stock-market adapter
    2025-02-01 16:08:27.128  - info: host.raspberrypi instance system.adapter.parser.0 in version "2.2.4" started with pid 2614
    2025-02-01 16:08:28.175  - info: parser.0 (2614) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.parser, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:10:16.009  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 2778
    2025-02-01 16:10:16.956  - info: tvspielfilm.0 (2778) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:10:18.996  - info: tvspielfilm.0 (2778) objects written
    2025-02-01 16:10:29.502  - info: tvspielfilm.0 (2778) Terminated (NO_ERROR): Without reason
    2025-02-01 16:10:30.014  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 having pid 2778 terminated with code 0 (NO_ERROR)
    2025-02-01 16:15:16.007  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 3481
    2025-02-01 16:15:17.063  - info: tvspielfilm.0 (3481) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.1, js-controller: 7.0.6
    2025-02-01 16:15:19.099  - info: tvspielfilm.0 (3481) objects written
    2025-02-01 16:15:29.603  - info: tvspielfilm.0 (3481) Terminated (NO_ERROR): Without reason
    2025-02-01 16:15:30.127  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 having pid 3481 terminated with code 0 (NO_ERROR)
    iob diag has finished.
    #41
    @thorsten4-71 sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
    zu schwaches Netzteil?
    zu warm geworden?
    2x admin, beide deaktiviert
    so kommst du nie via :8081 drauf.
    web auf 8083, da kommst du auch nicht mit 8082 drauf
    Da passiert also das, was eingestellt ist
      zu warm geworden?
      Thorsten4-71
      #42
      @homoran Vielen Dank. Ich werde jetzt mal das Netzteil tauschen. Der PI5 hat ein Kühlrippengehäuse. Wie bekomme ich Admin aktiviert über die Befehlszeile. über iob fix habe ich nichts gesehen bzw. verstanden, was ich machen könnte. Wenn die Kiste wieder läuft, kann ich einmal Admin Instanz löschen? Mit 8083 komme ich noch auf die VIS.
      • T Thorsten4-71
        iob diag
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        shthorsten
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           155M          0B        155M
                 4045 M total memory
                 1875 M used memory
                 1105 M free memory
                   91 M buffer memory
                 1061 M swap cache
                  148 M total swap
                    0 M used swap
                  148 M free swap
        *** FILESYSTEM ***
        /var:
        2.4G    /var/
        1.1G    /var/log
        995M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6483
        States:         6151
        Pending Updates: 92
        #43
        @thorsten4-71
        sudo systemctl set-default multi-user.target
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        iob update
        iob upgrade all
        Schau dir die Fehler an
        Dann musst du die Spannungsversorgung stabilisieren.
        Richtiges Netzteil am Start? Ein Handyladegerät ist KEIN stabiles Netzteil.
        Von den beiden admin-Instanzen läuft keine.
        iob start admin.0
        admin.1 würde ich löschen.
        • T Thorsten4-71
          #44
          iob start admin.0
            @thorsten4-71
            iob stop
            sudo apt update
            sudo reboot
            iob update
            iob upgrade all
            iob start admin.0
            Thorsten4-71
            #45
            @thomas-braun Danke Euch alles, ich werde meine Hausaufgaben machen und Euch berichten. Zuerst habe ich mal den Admin aktiviert und kann Port 8081 wieder aufrufen. aber ich bekomme Folgende Fehlermeldung:
            admin.0
            2025-02-01 16:37:28.427 warn Cannot read file ("admin.admin"/"admin.svg"): Not exists
            In der Instanz fehlt das Icon und kann die Admin Instanz nicht aufrufen. Ist aber grün.
            Ich muß jetzt weg, ich werde nachher nachschauen ob Ihr noch eine Idee für mich habt. Vielen Lieben Dank und ein schönes Wochenende.
            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
            • T Thorsten4-71
              admin.0
              #46
              Nachdem die Grundlagen gefixt wurden.
                Thorsten4-71
                #47
                @thomas-braun Sorry wenn ich frage, was bedeudet das Grundlage gefixt wurde? Gestern waren die Fehlermeldungen noch nicht, jetzt als ich Admin aktiviert habe und wieder auf den iobroker komme, kamen diese fehlermeldungen.
                Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                • T Thorsten4-71
                  #48
                  @thorsten4-71
                  Die Updates eingespielt, der Display-Server ausgeknipst usw.
                  Siehe Hausaufgabenliste oben.
                  • T Thorsten4-71
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #49
                    @thorsten4-71
                    Und noch was zum Nachdenken:
                    Warum installierst du auf einem produktiven System Adapter von Github?
                    Davon wird explizit abgeraten.
                    Insbesondere bei einem Adapter aus der iobroker-community-adapters orga sollte es dafür absolut keinen Grund geben. Und ob bei dir gigaset-elements-api noch viel sinnvolles tun kann (da gigaset ja die Cloud eingestellt hat) bezweifle ich auch.
                    Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                    GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                    Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                    Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                    Und falls es irgendwie unklar ist:
                    ioBroker unterstützt folgende Arten von Installation:
                    • aus dem STABLE Repository
                      Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                    • aus dem LATEST Repository
                      Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                    • direkt von GITHUB
                      Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                    • direkt von npm
                      Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                    Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                    @mcm1957
                    Comment
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • T Thorsten4-71
                      admin.0
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #50
                      admin.0
                      Da fehlt der Upload des Admin Adapters.
                      A.
                      HomoranH T 2 Antworten Letzte Antwort
                      • AsgothianA Asgothian
                        admin.0
                        A.
                        #51
                        @asgothian sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
                        aber warum?
                        Da war doch nur die Instanz deaktiviert.
                        @Thorsten4-71
                        oder hattest du noch was anderes gemacht
                          aber warum?
                          @Thorsten4-71
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #52
                          @homoran sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
                          aber warum?
                          @Thorsten4-71
                          Da kommt mein Misstrauen in die “User” durch. Ich bin fast sicher das da irgendwo irgendwann irgendwer etwas installiert, deinstalliert oder gelöscht hat - absichtlich, unabsichtlich oder beim Versuch was zu retten.
                          A.
                            aber warum?
                            @Thorsten4-71
                            A.
                            #53
                            @asgothian kenne ich!
                            nach 11 Jahren iob Forum und noch 4 Jahre HM hab ich auch gelernt erst mal alles in Frage zu stellen!
                            Mittlerweile bin ich aber soweit immer erst zu versuchen alle Fakten zu bekommen, bevor ich ins blaue hinein Lösungen für die wahrscheinlichsten 5 der möglichen 100 Ursachen zu geben.
                            • mcm1957M mcm1957
                              @thorsten4-71
                              • direkt von GITHUB
                              • direkt von npm
                              @mcm1957
                              Comment
                              Thorsten4-71
                              #54
                              @mcm1957 Ich hatte mir den PI5 gekauft, weil Gigaset Elements insolvenz angemeldet hat und die Cloud im April 24 eingestellt hat. Ich hatte zuvor Foren über Gigaset durchforstet aber das ganze falsch verstanden. Da ich jetzt nunmal den PI5 hatte, habe ich im Oktober angefangen das Ding auszuprobieren und auch über Github diesen Adapter installiert.
                                @thorsten4-71
                                Thorsten4-71
                                #55
                                @thomas-braun Ich wollte den Adapter Admin updaten und habe folgende Meldung erhalten: Upgrade process exited with code: 25
                                Ich hoffe, ich muß nicht neu aufsetzen und einstellen.
                                • T Thorsten4-71
                                  #56
                                  @thorsten4-71
                                  Da gint es Meldungen davor.
                                  iob fix
                                  ist aber der erste Ansatz.
                                    admin.0
                                    A.
                                    Thorsten4-71
                                    #57
                                    @asgothian Ich war dabei ein JS für Ical auszuprobieren und mußte dann schnell weg. Als ich den Rechner runtergefahren hatte, hat noch alles funktioniert. Ich habe nichts deinstalliert, gelöscht oder sonstiges.
                                      @thorsten4-71
                                      iob fix
                                      Thorsten4-71
                                      #58
                                      @thomas-braun Was kann ich jetzt noch machen?
                                      • T Thorsten4-71
                                        #59
                                        @thorsten4-71
                                        Hausaufgaben erledigt?
                                        iob fix ausgeführt?
                                          @thorsten4-71
                                          iob fix ausgeführt?
                                          Thorsten4-71
                                          #60
                                          @thomas-braun said in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
                                          iob fix
                                          Ich habe erst den Adapter Admin updaten wollen und da bin ich hängen geblieben.
                                          shthorsten@raspberrypi:~ $ iob fix
                                          library: loaded
                                          Library version=2024-10-22
                                          ioBroker or some processes are still running:
                                          864 iobroker.js-con
                                          2088 io.telegram.0
                                          2141 io.history.0
                                          2231 io.javascript.0
                                          2278 io.ping.0
                                          2340 io.echarts.0
                                          2352 io.mqtt.0
                                          2369 io.deyeidc.0
                                          2380 io.chromecast.0
                                          2394 io.shelly.0
                                          2451 io.cloud.0
                                          2518 io.broadlink2.0
                                          2538 io.discovery.0
                                          2557 io.fritzdect.0
                                          2579 io.web.0
                                          2612 io.iqontrol.0
                                          2623 io.hm-rpc.2
                                          2630 io.hm-rpc.0
                                          2637 io.hm-rega.0
                                          2660 io.vis-2.0
                                          2687 io.accuweather.
                                          2694 io.rpi2.0
                                          2701 io.tankerkoenig
                                          2708 io.tr-064.0
                                          2727 io.growatt.0
                                          2738 io.fritzbox.0
                                          2820 io.vis-inventwo
                                          2839 io.openligadb.0
                                          2854 io.yahoo-stock-
                                          2869 io.parser.0
                                          3988 io.admin.0
                                          Please stop them first and try again!
                                          shthorsten@raspberrypi:~ $ sudo cp off /sys/class/backlight/rpi_backlight/bl_power
                                          cp: der Aufruf von stat für 'off' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
