  4. Fehler Nach update Judo soft Adapter
15 Beiträge 5 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • marcel-drzalM Offline
    marcel-drzal
    Nach update Fehlermeldung im Judo Soft Adapter
    Bitte um Hilfe Danke
    ed063ce9-2917-443e-a8dd-cbd4da1a9ad5-image.png code_text
    2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) terminating
    2025-01-13 20:49:07.826 - info: judoisoft.0 (1334) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:08.326 - info: judoisoft.0 (1334) terminating
    2025-01-13 20:49:08.349 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:08.349 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:09.285 - info: influxdb.0 (442) Do not store value "{"Time":"2025-01-13T20:49:08","Haus":{"Tariflos":18648.6654,"Power_cur":2560,"Power_p1":184,"Power_p2":158,"Power_p3":2217},"Heizung":{"Tariflos":9223.6689,"Power_cur":1300,"Power_p1":2,"Power_p2":0,"Power_p3":1298}}" for StromHaus because no number
    2025-01-13 20:49:12.502 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: {"Time":"2025-01-13T20:49:12","Switch1":"OFF","DHT11":{"Temperature":8.3,"Humidity":88.0,"DewPoint":6.4},"TempUnit":"C"}
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 8.3
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 88
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 6.4
    2025-01-13 20:49:16.022 - info: admin.0 (346) <== Disconnect system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:19.297 - info: host.iobroker "system.adapter.judoisoft.0" disabled
    2025-01-13 20:49:20.466 - info: host.iobroker "system.adapter.judoisoft.0" enabled
    2025-01-13 20:49:20.754 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1349
    2025-01-13 20:49:21.224 - info: judoisoft.0 (1349) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:49:21.421 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:21.470 - info: judoisoft.0 (1349) reconnect 1736797761469
    2025-01-13 20:49:21.531 - error: judoisoft.0 (1349) getInfosCloud ERROR reconnect wait 5 min
    2025-01-13 20:49:21.531 - warn: judoisoft.0 (1349) Restart initiated
    2025-01-13 20:49:21.532 - info: judoisoft.0 (1349) cleaned everything up...
    2025-01-13 20:49:21.533 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) terminating
    2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:22.034 - info: judoisoft.0 (1349) terminating
    2025-01-13 20:49:22.058 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:22.058 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:25.655 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:30.781 - info: host.iobroker "system.adapter.judoisoft.0" disabled
    2025-01-13 20:49:31.748 - info: host.iobroker "system.adapter.judoisoft.0" enabled
    2025-01-13 20:49:31.984 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1364
    2025-01-13 20:49:32.476 - info: judoisoft.0 (1364) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:49:32.693 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:32.741 - info: judoisoft.0 (1364) reconnect 1736797772741
    2025-01-13 20:49:32.792 - error: judoisoft.0 (1364) getInfosCloud ERROR reconnect wait 5 min
    2025-01-13 20:49:32.792 - warn: judoisoft.0 (1364) Restart initiated
    2025-01-13 20:49:32.793 - info: judoisoft.0 (1364) cleaned everything up...
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) terminating
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:33.294 - info: judoisoft.0 (1364) terminating
    2025-01-13 20:49:33.322 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:33.322 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:48.524 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1379
    2025-01-13 20:49:48.999 - info: judoisoft.0 (1379) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    arteckA mcm1957M 2 Antworten Letzte Antwort
    • marcel-drzalM marcel-drzal
      arteckA Offline
      arteckA Offline
      arteck
      @marcel-drzal sagte in Fehler Nach update Judo soft Adapter:
      die Daten können nicht abgeholt werden..warum auch immer
      • arteckA arteck
        SmartHomer 0
        schrieb am zuletzt editiert von SmartHomer 0
        @arteck
        Ich denke, das passt auch zu diesem Problem in diesem Thread:
        judo i-soft+ Adapter
        Auch bei mir funktioniert es wieder nicht mehr, sieht aus als ob judo erneut was gemacht hat.
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @marcel-drzal
          Aktuelle Version ist 1.1.2. Keine Ahnung ob da was gefixed wurde, aber ein Test kann wahrscheinlich nicht schaden,
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • mcm1957M mcm1957
            @marcel-drzal
            SmartHomer 0
            @mcm1957
            Korrekt, mit 1.1.2 hatte es auch eine Zeit lang funktioniert, aber zwischenzeitlich eben auch nicht mehr.
            Ich vermute, dass seitens judo zwischenzeitlich der Datenabruf via Portal gesperrt wurde und die Server den ioBroker-Adapter blocken... 😕
            Müsste man also vermutlich für ioBroker-Abfragen eine Lösung über die dafür gedachte API bauen (wer immer dazu in der Lage ist)...
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              @smarthomer-0
              OK - scheingt auch als Issue registriert zu sein. (https://github.com/arteck/ioBroker.judoisoft/issues/75)
              Das ist ein Adapter von arteck und er kann (und wird sicher auch) da was anpassen.
              ER hat das Problem ja auch schon wie hier zu lesen war gesehen.
              • arteckA Offline
                arteckA Offline
                arteck
                hab mal blind gemacht
                https://github.com/arteck/ioBroker.judoisoft/tarball/header
                musste von jemanden getestet werden..
                sonst brauch ich login Daten von jemanden
                Fredi Van WensenF 3 Antworten Letzte Antwort
                • arteckA arteck
                  Fredi Van WensenF Offline
                  Fredi Van Wensen
                  @arteck Ich versuche es diesen Tage mal. Habe gerade erst alles von Windows auf Linux umgestellt, deswegen war es kurz ruhig hier.
                  Fredi Van WensenF 1 Antwort Letzte Antwort
                  • Fredi Van WensenF Fredi Van Wensen
                    Fredi Van Wensen
                    @fredi-van-wensen Welche Version soll man installieren?
                    • arteckA arteck
                      Fredi Van Wensen
                      @arteck 1.1.2
                      • arteckA arteck
                        Fredi Van Wensen
                        @arteck Hat bei mir leider nicht funktioniert.
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          dann brauch ich deine Login daten.. da ich keine judo hier habe
                          • arteckA arteck
                            Fredi Van Wensen
                            @arteck Wie soll ich die dir zukommen lassen?
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @fredi-van-wensen
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                @fredi-van-wensen so jetzt aber
                                alles da
