  4. Fehler Nach update Judo soft Adapter
15 Beiträge 5 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • marcel-drzalM marcel-drzal
    Nach update Fehlermeldung im Judo Soft Adapter
    Bitte um Hilfe Danke
    ed063ce9-2917-443e-a8dd-cbd4da1a9ad5-image.png code_text
    2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:07.825 - info: judoisoft.0 (1334) terminating
    2025-01-13 20:49:07.826 - info: judoisoft.0 (1334) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:08.326 - info: judoisoft.0 (1334) terminating
    2025-01-13 20:49:08.349 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:08.349 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:09.285 - info: influxdb.0 (442) Do not store value "{"Time":"2025-01-13T20:49:08","Haus":{"Tariflos":18648.6654,"Power_cur":2560,"Power_p1":184,"Power_p2":158,"Power_p3":2217},"Heizung":{"Tariflos":9223.6689,"Power_cur":1300,"Power_p1":2,"Power_p2":0,"Power_p3":1298}}" for StromHaus because no number
    2025-01-13 20:49:12.502 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: {"Time":"2025-01-13T20:49:12","Switch1":"OFF","DHT11":{"Temperature":8.3,"Humidity":88.0,"DewPoint":6.4},"TempUnit":"C"}
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 8.3
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 88
    2025-01-13 20:49:12.854 - info: javascript.0 (387) script.js.common.Heizung_Klima.Garage_Temperaturangleich_: 6.4
    2025-01-13 20:49:16.022 - info: admin.0 (346) <== Disconnect system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:19.297 - info: host.iobroker "system.adapter.judoisoft.0" disabled
    2025-01-13 20:49:20.466 - info: host.iobroker "system.adapter.judoisoft.0" enabled
    2025-01-13 20:49:20.754 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1349
    2025-01-13 20:49:21.224 - info: judoisoft.0 (1349) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:49:21.421 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:21.470 - info: judoisoft.0 (1349) reconnect 1736797761469
    2025-01-13 20:49:21.531 - error: judoisoft.0 (1349) getInfosCloud ERROR reconnect wait 5 min
    2025-01-13 20:49:21.531 - warn: judoisoft.0 (1349) Restart initiated
    2025-01-13 20:49:21.532 - info: judoisoft.0 (1349) cleaned everything up...
    2025-01-13 20:49:21.533 - info: judoisoft.0 (1349) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) terminating
    2025-01-13 20:49:21.534 - info: judoisoft.0 (1349) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:22.034 - info: judoisoft.0 (1349) terminating
    2025-01-13 20:49:22.058 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:22.058 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:25.655 - info: admin.0 (346) ==> Connected system.user.admin from ::ffff:172.16.0.166
    2025-01-13 20:49:30.781 - info: host.iobroker "system.adapter.judoisoft.0" disabled
    2025-01-13 20:49:31.748 - info: host.iobroker "system.adapter.judoisoft.0" enabled
    2025-01-13 20:49:31.984 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1364
    2025-01-13 20:49:32.476 - info: judoisoft.0 (1364) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    2025-01-13 20:49:32.693 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:32.741 - info: judoisoft.0 (1364) reconnect 1736797772741
    2025-01-13 20:49:32.792 - error: judoisoft.0 (1364) getInfosCloud ERROR reconnect wait 5 min
    2025-01-13 20:49:32.792 - warn: judoisoft.0 (1364) Restart initiated
    2025-01-13 20:49:32.793 - info: judoisoft.0 (1364) cleaned everything up...
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) State value to set for "judoisoft.0.Connection status" has to be type "boolean" but received type "string"
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) terminating
    2025-01-13 20:49:32.795 - info: judoisoft.0 (1364) Terminated (NO_ERROR): Without reason
    2025-01-13 20:49:33.294 - info: judoisoft.0 (1364) terminating
    2025-01-13 20:49:33.322 - info: host.iobroker instance system.adapter.judoisoft.0 terminated with code 0 (NO_ERROR)
    2025-01-13 20:49:33.322 - info: host.iobroker Restart adapter system.adapter.judoisoft.0 because enabled
    2025-01-13 20:49:48.524 - info: host.iobroker instance system.adapter.judoisoft.0 in version "1.1.1" started with pid 1379
    2025-01-13 20:49:48.999 - info: judoisoft.0 (1379) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.judoisoft, node: v20.18.1, js-controller: 7.0.6
    arteckA Offline
    arteckA Offline
    arteck
    @marcel-drzal sagte in Fehler Nach update Judo soft Adapter:
    die Daten können nicht abgeholt werden..warum auch immer
    • arteckA arteck
      SmartHomer 0
      schrieb am zuletzt editiert von SmartHomer 0
      @arteck
      Ich denke, das passt auch zu diesem Problem in diesem Thread:
      judo i-soft+ Adapter
      Auch bei mir funktioniert es wieder nicht mehr, sieht aus als ob judo erneut was gemacht hat.
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @marcel-drzal
        Aktuelle Version ist 1.1.2. Keine Ahnung ob da was gefixed wurde, aber ein Test kann wahrscheinlich nicht schaden,
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          @marcel-drzal
          SmartHomer 0
          @mcm1957
          Korrekt, mit 1.1.2 hatte es auch eine Zeit lang funktioniert, aber zwischenzeitlich eben auch nicht mehr.
          Ich vermute, dass seitens judo zwischenzeitlich der Datenabruf via Portal gesperrt wurde und die Server den ioBroker-Adapter blocken... 😕
          Müsste man also vermutlich für ioBroker-Abfragen eine Lösung über die dafür gedachte API bauen (wer immer dazu in der Lage ist)...
          • mcm1957M Online
            mcm1957M Online
            mcm1957
            @smarthomer-0
            OK - scheingt auch als Issue registriert zu sein. (https://github.com/arteck/ioBroker.judoisoft/issues/75)
            Das ist ein Adapter von arteck und er kann (und wird sicher auch) da was anpassen.
            ER hat das Problem ja auch schon wie hier zu lesen war gesehen.
            • arteckA Offline
              arteckA Offline
              arteck
              hab mal blind gemacht
              https://github.com/arteck/ioBroker.judoisoft/tarball/header
              musste von jemanden getestet werden..
              sonst brauch ich login Daten von jemanden
              Fredi Van WensenF 3 Antworten Letzte Antwort
              • arteckA arteck
                Fredi Van WensenF Offline
                Fredi Van Wensen
                @arteck Ich versuche es diesen Tage mal. Habe gerade erst alles von Windows auf Linux umgestellt, deswegen war es kurz ruhig hier.
                Fredi Van WensenF 1 Antwort Letzte Antwort
                • Fredi Van WensenF Fredi Van Wensen
                  Fredi Van Wensen
                  @fredi-van-wensen Welche Version soll man installieren?
                  • arteckA arteck
                    Fredi Van Wensen
                    @arteck 1.1.2
                    • arteckA arteck
                      Fredi Van Wensen
                      @arteck Hat bei mir leider nicht funktioniert.
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        dann brauch ich deine Login daten.. da ich keine judo hier habe
                        • arteckA arteck
                          Fredi Van Wensen
                          @arteck Wie soll ich die dir zukommen lassen?
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @fredi-van-wensen
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              @fredi-van-wensen so jetzt aber
                              alles da
