  4. [Gelöst] Inbetriebnahme cod.m Koordinator mit Error
24 Beiträge 5 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • pmayerP pmayer
    @mf19862 bin leider bis 13.1. in Urlaub….
    Router geht schon. Es fehlt noch die Firmware für den P7 für Thread. Sind wir dran.
    David G.D Online
    David G.D Online
    David G.
    @pmayer
    Ich wollte den Koordinator gerade in Betrieb nehmen.
    Leider möchte es nicht ganz.
    • Zigbee-Adapter gestoppt
    • /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0 gegen tcp://192.168.99.4:6638 ausgetauscht und gespeichert.
    Beim Adapterstart kommt im Log in dauerschleife
    zigbee.0
    2025-01-08 09:00:10.254	error	Error herdsman start
    zigbee.0
    2025-01-08 09:00:10.254	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 09:00:10.254	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2025-01-08 09:00:08.131	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 09:00:08.129	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 09:00:08.129	info	Try to reconnect.
    zigbee.0
    2025-01-08 08:59:58.127	error	Error herdsman start
    zigbee.0
    2025-01-08 08:59:58.127	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 08:59:58.127	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2025-01-08 08:59:55.664	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 08:59:55.662	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 08:59:55.661	info	Try to reconnect.
    zigbee.0
    2025-01-08 08:59:45.660	error	Error herdsman start
    zigbee.0
    2025-01-08 08:59:45.659	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 08:59:45.659	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2025-01-08 08:59:43.189	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 08:59:43.180	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 08:59:43.178	info	Try to reconnect.
    Wenn ich wieder in die Settings gehe kommt
    • David G.D David G.
      @pmayer
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @david-g Deine Konfiguration ist unsauber. Sagt das Log zumindest. Nutz mal das Diag Skript aus diesem Thread um dir Anzeigen zu lassen was da drin steht, und pass dann deine Konfiguration an das an was erwartet wird.
      A.
      • AsgothianA Asgothian
        A.
        David G.D Online
        David G.D Online
        David G.
        @asgothian
        Gerne
        *** BASE SYSTEM ***                                                         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
        Operating System: Debian GNU/Linux 12 (bookworm)                                     Kernel: Linux 6.1.0-18-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
        OS is similar to:
        model name      : 12th Gen Intel(R) Core(TM) i3-12100
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         09:26:12 up 2 days, 20:16,  1 user,  load average: 0.29, 0.33, 0.30
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-01-08 09:26:12 CET
                   Universal time: Wed 2025-01-08 08:26:12 UTC
                         RTC time: Wed 2025-01-08 08:26:12
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        david
        HOME=/home/david
        GROUPS=david sudo users iobroker
        iobroker
        [sudo] password for david:
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.3G        5.1G        1.7G        516K        1.7G        3.2G
        Swap:           1.0G        274K        1.0G
        Total:          9.3G        5.1G        2.7G
        Active iob-Instances:   53
                 7940 M total memory
                 4902 M used memory
                  716 M active memory
                 5211 M inactive memory
                 1645 M free memory
                  205 M buffer memory
                 1456 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 09:26:22 up 2 days, 20:16,  1 user,  load average: 0.24, 0.32, 0.30
        Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7940.7 total,   1645.1 free,   4903.1 used,   1661.6 buff/cache
        MiB Swap:    975.0 total,    974.7 free,      0.3 used.   3037.7 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     795M  528K  794M   1% /run
        /dev/sda1      ext4       31G   19G   11G  63% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     795M     0  795M   0% /run/user/1001
        [Sun Jan  5 13:09:56 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jan  5 13:09:57 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        4.3G    /var/
        3.1G    /var/log/journal/c2f62aa20c614a09b8a2622bde83939a
        3.1G    /var/log
        1.1G    /var/cache/apt
        Archived and active journals take up 1.5G in the file system.
        /opt/iobroker/backups:
        1.4G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.3G    /opt/iobroker/iobroker-data/
        1.5G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
        63M     /opt/iobroker/iobroker-data/objects.jsonl
        57M     /opt/iobroker/iobroker-data/states.jsonl
        41M     /opt/iobroker/iobroker-data/mymedia/smoke.mp4
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        USB-Devices by-id:
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.1
        /usr/bin/node           v20.18.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        nodejs:
          Installed: 20.18.1-1nodesource1
          Candidate: 20.18.1-1nodesource1
          Version table:
         *** 20.18.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 245773)
        Core adapters versions
        js-controller:  7.0.3
        admin:          7.2.6
        javascript:     8.8.3
        nodejs modules from github:     4
        +-- iobroker.ai-assistant@0.0.2 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-assistant.git#c1fab08203c28ed2e613b42ca6f93ed991bab809)
        +-- iobroker.ai-toolbox@0.0.6 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-toolbox.git#19f6fe2be84574d473703bb6470ba8c5b8f026a3)
        +-- iobroker.google-sharedlocations@2.1.4 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#73e87eafd1922418a4829d93697b2268eacada2a)
        +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
        + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
        + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
        + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
        + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          system.adapter.daswetter.1              : daswetter             : iobroker                                 - disabled
          system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.iceroad.0                : iceroad               : iobroker                                 - disabled
        + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.kisshome-research.0      : kisshome-research     : iobroker                                 - disabled
        + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
          system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
        + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
        + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
          system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          system.adapter.parser.0                 : parser                : iobroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.places.0                 : places                : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
        + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
          system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
          system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
          system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.99.4:6638
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Instances
        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
        Adapter    "adb"          : 0.0.7    , installed 0.0.7
        Adapter    "adguard"      : 1.0.1    , installed 1.0.1
        Adapter    "admin"        : 7.4.10   , installed 7.2.6  [Updatable]
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
        Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
        Adapter    "countdown"    : 2.3.0    , installed 2.3.0
        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hmip"         : 1.25.0   , installed 1.25.0
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "imap"         : 0.3.0    , installed 0.3.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
        Adapter    "kisshome-research": 1.2.5, installed 1.2.5
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "notification-manager": 1.2.1, installed 1.2.1
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "parser"       : 2.2.4    , installed 2.2.4
        Adapter    "places"       : 1.2.0    , installed 1.2.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
        Adapter    "reolink"      : 1.1.2    , installed 1.1.2
        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
        Adapter    "roborock"     : 0.6.17   , installed 0.6.17
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "schedule-switcher": 0.0.9, installed 0.0.9
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "telegram-menu": 2.1.7    , installed 2.1.7
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
        Objects and States
        Objects:        31346
        States:         28456
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InReleaseReading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1000       19705      1013/io.hm-rpc.1
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16999      1077/io.mqtt.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1818828    127453/node-red
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       19056      1190/io.sonoff.0
        tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1000       18914      998/io.hm-rpc.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15531      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16490      584/sshd: /usr/sbin
        tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1000       1816933    127395/io.shelly.0
        tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       20820      1320/adb
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15149      572/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       16495      572/iobroker.js-con
        tcp6       0      0 :::1980                 :::*                    LISTEN      1000       1818830    127453/node-red
        tcp6       0      0 :::111                  :::*                    LISTEN      0          379        1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16492      584/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       21336      1862/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15198      602/io.admin.0
        tcp6       0      0 :::8083                 :::*                    LISTEN      1000       26013      1961/io.web.1
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       22884      1945/io.web.0
        tcp6       0      0 :::8092                 :::*                    LISTEN      1000       2527826    177780/io.lovelace.
        tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2528769    177764/io.lovelace.
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1084       1/init
        udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1000       19139      1221/io.tr-064.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1816935    127402/io.shelly.1
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       26700      1997/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          1085       1/init
        2025-01-08 09:25:20.494  - error: zigbee.0 (216202) Error herdsman start
        2025-01-08 09:25:30.497  - info: zigbee.0 (216202) Try to reconnect.
        2025-01-08 09:25:30.498  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:30.507  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
        2025-01-08 09:25:30.651  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Error while opening socket"
        2025-01-08 09:25:30.652  - error: zigbee.0 (216202) Failed to start Zigbee
        2025-01-08 09:25:30.652  - error: zigbee.0 (216202) Error herdsman start
        2025-01-08 09:25:40.655  - info: zigbee.0 (216202) Try to reconnect.
        2025-01-08 09:25:40.656  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:40.663  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
        2025-01-08 09:25:40.846  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Error while opening socket"
        2025-01-08 09:25:40.846  - error: zigbee.0 (216202) Failed to start Zigbee
        2025-01-08 09:25:40.848  - error: zigbee.0 (216202) Error herdsman start
        2025-01-08 09:25:50.849  - info: zigbee.0 (216202) Try to reconnect.
        2025-01-08 09:25:50.850  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:50.862  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
        2025-01-08 09:26:10.027  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2025-01-08 09:26:10.028  - error: zigbee.0 (216202) Failed to start Zigbee
        2025-01-08 09:26:10.028  - error: zigbee.0 (216202) Error herdsman start
        2025-01-08 09:26:20.030  - info: zigbee.0 (216202) Try to reconnect.
        2025-01-08 09:26:20.031  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:26:20.039  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
        2025-01-08 09:26:39.212  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        2025-01-08 09:26:39.213  - error: zigbee.0 (216202) Failed to start Zigbee
        2025-01-08 09:26:39.213  - error: zigbee.0 (216202) Error herdsman start
        Edit
        Kann es sein, dass die Meldung kommt weil der alte Koordinator noch im USB steckt?
        Hab gtad auf der Arbeit Zeit und wollte den codm schonmal einrichten.
        Sehe jetzt nicht groß, was erwartet wird. By ID gibt's ja beim Netzwerkkoordinator nicht.
        EDIT 2
        Die Meldung hat sich glaube verändert
        zigbee.0
        2025-01-08 09:45:49.609	error	Error herdsman start
        zigbee.0
        2025-01-08 09:45:49.609	error	Failed to start Zigbee
        zigbee.0
        2025-01-08 09:45:49.608	error	Starting zigbee-herdsman problem : "Error while opening socket"
        zigbee.0
        2025-01-08 09:45:49.511	info	Installed Version: iobroker.zigbee@1.10.14
        zigbee.0
        2025-01-08 09:45:49.500	info	Starting Zigbee npm ...
        zigbee.0
        2025-01-08 09:45:49.499	info	Try to reconnect.
        zigbee.0
        2025-01-08 09:45:39.498	error	Error herdsman start
        zigbee.0
        2025-01-08 09:45:39.498	error	Failed to start Zigbee
        zigbee.0
        2025-01-08 09:45:39.497	error	Starting zigbee-herdsman problem : "Error while opening socket"
        zigbee.0
        2025-01-08 09:45:39.281	info	Installed Version: iobroker.zigbee@1.10.14
        zigbee.0
        2025-01-08 09:45:39.275	info	Starting Zigbee npm ...
        zigbee.0
        2025-01-08 09:45:39.274	info	Try to reconnect.
        zigbee.0
        2025-01-08 09:45:29.272	error	Error herdsman start
        zigbee.0
        2025-01-08 09:45:29.272	error	Failed to start Zigbee
        zigbee.0
        2025-01-08 09:45:29.271	error	Starting zigbee-herdsman problem : "Error while opening socket"
        zigbee.0
        2025-01-08 09:45:29.129	info	Installed Version: iobroker.zigbee@1.10.14
        zigbee.0
        2025-01-08 09:45:29.121	info	Starting Zigbee npm ...
        zigbee.0
        2025-01-08 09:45:29.120	info	Try to reconnect.
          @asgothian
          Gerne
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          david
          HOME=/home/david
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   7940 M total memory
                   4902 M used memory
                    716 M active memory
                   1645 M free memory
                    205 M buffer memory
                   1456 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          4.3G    /var/
          3.1G    /var/log
          1.1G    /var/cache/apt
          USB-Devices by-id:
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.2.6
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        31346
          States:         28456
          Pending Updates: 0
          Edit
          EDIT 2
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          @david-g sagte in cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany:
          hast du beim cod.m etwas in den security Einstellungen bezüglich socket gemacht?
          läuft der cod.m?
          EDIT:
          Hab das mal aus dem Marktplatz abgetrennt
          bitte ggf. den provisorischen Threadtitel anpassen
            läuft der cod.m?
            EDIT:
            David G.D Online
            David G.D Online
            David G.
            Nein, alles default bis auf das Verhalten der LED und dass ich die IP statisch gesetzt habe.
            Hab auch gtad mal reingeschaut, keine Option aktiviert bei den Sicherheitseinstellungen.
            Edit
            Danke fürs verschieben.
            EDIT 2
            Wenn ich am codm die Zigbeeverbindung prüfe kommt:
            [937395] -> fe 00 21 01 20
            [937399] <- fe 02 61 01 59 06 3d
            [937462] -> fe 00 21 02 23
            [937469] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
            [937530] -> fe 02 21 13 82 00 b2
            [937540] <- fe 02 61 13 18 00 68
            [937608] -> fe 04 21 1c 82 00 00 00 bb
            [937626] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
            [937692] -> fe 02 21 13 60 00 50
            [937699] <- fe 02 61 13 01 00 71
            [937765] -> fe 04 21 1c 60 00 00 00 59
            [937774] <- fe 03 61 1c 00 01 55 2a
            [937836] -> fe 02 21 13 21 00 11
            [937848] <- fe 02 61 13 74 00 04
            [937921] -> fe 04 21 1c 21 00 00 00 18
            [937946] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
            [938032] -> fe 02 21 13 62 00 52
            [938041] <- fe 02 61 13 10 00 60
            [938109] -> fe 04 21 1c 62 00 00 00 5b
            [938144] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
            [938223] -> fe 02 21 13 3a 00 0a
            [938233] <- fe 02 61 13 11 00 61
            [938311] -> fe 04 21 1c 3a 00 00 00 03
            [938327] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [938401] -> fe 02 21 13 3b 00 0b
            [938418] <- fe 02 61 13 11 00 61
            [938483] -> fe 04 21 1c 3b 00 00 00 02
            [938500] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [939989] | [ZB] Chip: CC2652P7
            [939990] | [ZB] IEEE: 00:12:4B:00:2E:10:4F:F0
            [940000] | [ZB] Flash size: 704 KB
            [940564] <- a9 a5 a5 a5 a5 81 81 81 81 81 01 20 00
            [942449] <- fe 06 41 80 00 02 01 02 07 01 c0
            [948713] | Connected client 2 from 192.168.99.33
            [948714] -> ef
            [949729] -> fe 00 21 01 20
            [949737] <- fe 02 61 01 59 06 3d
            [949792] -> fe 00 21 02 23
            [949797] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
            [949832] -> fe 02 21 13 82 00 b2
            [949841] <- fe 02 61 13 18 00 68
            [949914] -> fe 04 21 1c 82 00 00 00 bb
            [949931] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
            [949996] -> fe 02 21 13 60 00 50
            [950004] <- fe 02 61 13 01 00 71
            [950068] -> fe 04 21 1c 60 00 00 00 59
            [950078] <- fe 03 61 1c 00 01 55 2a
            [950146] -> fe 02 21 13 21 00 11
            [950155] <- fe 02 61 13 74 00 04
            [950202] -> fe 04 21 1c 21 00 00 00 18
            [950232] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
            [950303] -> fe 02 21 13 62 00 52
            [950312] <- fe 02 61 13 10 00 60
            [950376] -> fe 04 21 1c 62 00 00 00 5b
            [950397] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
            [950489] -> fe 02 21 13 3a 00 0a
            [950499] <- fe 02 61 13 11 00 61
            [950564] -> fe 04 21 1c 3a 00 00 00 03
            [950579] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [950678] -> fe 02 21 13 3b 00 0b
            [950687] <- fe 02 61 13 11 00 61
            [950775] -> fe 04 21 1c 3b 00 00 00 02
            [950790] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [955953] | [ZB] Chip: CC2652P7
            [955954] | [ZB] IEEE: 00:12:4B:00:2E:10:4F:F0
            [955964] | [ZB] Flash size: 704 KB
            [956529] <- ad a5 a5 a5 a5 a5 81 81 81 81 81 81 81 01 00 00
            [957954] <- fe 06 41 80 00 02 01 02 07 01 c0
            [960977] | Connected client 3 from 192.168.99.33
            [960978] -> ef
            [962031] -> fe 00 21 01 20
            [962036] <- fe 02 61 01 59 06 3d
            [962126] -> fe 00 21 02 23
            [962132] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
            [962226] -> fe 02 21 13 82 00 b2
            [962233] <- fe 02 61 13 18 00 68
            [962308] -> fe 04 21 1c 82 00 00 00 bb
            [962320] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
            [962412] -> fe 02 21 13 60 00 50
            [962423] <- fe 02 61 13 01 00 71
            [962534] -> fe 04 21 1c 60 00 00 00 59
            [962551] <- fe 03 61 1c 00 01 55 2a
            [962659] -> fe 02 21 13 21 00 11
            [962666] <- fe 02 61 13 74 00 04
            [962795] -> fe 04 21 1c 21 00 00 00 18
            [962815] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
            [963308] -> fe 02 21 13 62 00 52
            [963315] <- fe 02 61 13 10 00 60
            [963408] -> fe 04 21 1c 62 00 00 00 5b
            [963419] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
            [963521] -> fe 02 21 13 3a 00 0a
            [963529] <- fe 02 61 13 11 00 61
            [963615] -> fe 04 21 1c 3a 00 00 00 03
            [963626] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [964071] -> fe 02 21 13 3b 00 0b
            [964077] <- fe 02 61 13 11 00 61
            [964128] -> fe 04 21 1c 3b 00 00 00 02
            [964139] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [974423] | Connected client 4 from 192.168.99.33
            [974424] -> ef
            [975394] -> fe 00 21 01 20
            [975399] <- fe 02 61 01 59 06 3d
            [975461] -> fe 00 21 02 23
            [975466] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
            [975491] -> fe 02 21 13 82 00 b2
            [975497] <- fe 02 61 13 18 00 68
            [975525] -> fe 04 21 1c 82 00 00 00 bb
            [975537] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
            [975547] -> fe 02 21 13 60 00 50
            [975559] <- fe 02 61 13 01 00 71
            [975595] -> fe 04 21 1c 60 00 00 00 59
            [975613] <- fe 03 61 1c 00 01 55 2a
            [975634] -> fe 02 21 13 21 00 11
            [975641] <- fe 02 61 13 74 00 04
            [975647] -> fe 04 21 1c 21 00 00 00 18
            [975667] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
            [975676] -> fe 02 21 13 62 00 52
            [975682] <- fe 02 61 13 10 00 60
            [975692] -> fe 04 21 1c 62 00 00 00 5b
            [975702] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
            [975707] -> fe 02 21 13 3a 00 0a
            [975713] <- fe 02 61 13 11 00 61
            [975728] -> fe 04 21 1c 3a 00 00 00 03
            [975740] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            [975757] -> fe 02 21 13 3b 00 0b
            [975763] <- fe 02 61 13 11 00 61
            [975771] -> fe 04 21 1c 3b 00 00 00 02
            [975781] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
            Man findet öfters die IP 192.168.99.33.
            Das ist mein iobroker.
            Damit kam @pmayer bestimmt was anfangen.
            EDIT 3
            Angeblich bestehen 4 Verbindungen
            Wenn ich den Zigbee Adapter neu starte fängt er an die Verbindungen von nicht verbunden bis 5 hochzuzählen innerhalb weniger Sekunden.
            EDIT 4
            @Asgothian
            Hab das Script jetzt unzensiert laufen lassen.
            Jetzt sieht man einen Fehler:
            Extended Pan ID:
            xxx
            Pan ID:
            ./iob_diag.sh: line 715: printf: 0x6c",: invalid hex number
            108
            Channel:
            Aber warum? Wenn ich auf den USB Dongle stelle läuft es....
            EDIT 5
            Hab die Pan ID nochmal uberspeichert. Da hat der Adapter auch nicht gestartet.
            Hab dann den NVRAM gelöscht. Danach war es lange still beim Adapterstart. Dann irgendwann ist er grün geworden.
            Heute Abend sehe ich dann, welche Geräte (nicht) klappen.
            Bisher zeigt der Admin nur die batteriebetriebenen Geräte grün.
              Edit
              EDIT 2
              [948714] -> ef
              [960978] -> ef
              [974424] -> ef
              EDIT 3
              EDIT 4
              @Asgothian
              Extended Pan ID:
              xxx
              Pan ID:
              108
              Channel:
              EDIT 5
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @david-g sagte in Inbetriebnahme cod.m Koordinator mit Error:
              Du darfst davon ausgehen das kein Gerät geht - da du den nvram gelöscht hast und nun mit geänderter verschlüsselung arbeitest.
              Was du tun solltest :
              • in der nvbackup.json die folgenden Zeilen finden:
                "pan_id": "1a62",
                "extended_pan_id": "adfdcdab76983412",
                "nwk_update_id": 1,
                "security_level": 5,
                "channel": 11,
              Danach sicherstellen das die Einstellungen in der Oberfläche diesen entsprechen. ggf. musst du die pan_id noch von hex in dezimal umrechnen.
              Wichtig: Adapter anhalten - Konfiguration anpassen - adapter starten
              Sollte es weitere Meldungen mit "Error while opening socket" geben musst du schauen ob noch Prozesse des Zigbee-Adapters hängen die den Port blockieren.
              A.
                  "pan_id": "1a62",
                  "nwk_update_id": 1,
                  "channel": 11,
                A.
                David G.D Online
                David G.D Online
                David G.
                @asgothian sagte in Inbetriebnahme cod.m Koordinator mit Error:
                Ein Thermometer in der Kühltruhe übermittelt Werte, das sehe ich schonmal von der Arbeit aus.
                War eben auch kurz zu Hause meinen Sohn abgeben. Da konnte ich das Licht im Flur schalten. 2 Andere Birnen nicht, obwohl eine Verbindung besteht. Mal sehen wie es heute Abend aussieht.
                Sonst erstmal Snapshot einspielen und dann sollte ja alles wieder gehen ^^.
                EDIT
                Kann es sein, dass manche Geräte Funktion, wenn die Verschlüsselung geändert worden ist?
                Verstehe noch nicht ganz, warum manche Sachen verbunden sind und klappen und andere verbunden und disconnectet.
                  EDIT
                  David G.D Online
                  David G.D Online
                  David G.
                  @Asgothian @arteck
                  Habe jetzt einen Snapshot eingespielt den ich vor dem Wechsel gemacht habe.
                  Nun läuft alles wieder mit dem Sonoff.
                  Wie gehe ich nun am besten vor?
                  Muss ich am Codm was zurücksetzen?
                  Gruppen konnte ich mit steuern, Werte von Sensoren Empfangen aber keine Lampen schalten.
                    @Asgothian @arteck
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Das steht weiter oben schon. Du musst die PanID, ExtPanID und den Kanal heraus finden die dein System wirklich nutzt. Insbesondere bei Installationen mit einer ExtPanID DDDDDDDDDDDDDDDD kann die im System genutzte von der aus der Konfiguration abweichen, da in diesem Fall die IEEE des Koordinators genutzt wird. Diese ist Hardwarespezifisch.
                    A.
                      A.
                      David G.D Online
                      David G.D Online
                      David G.
                      @asgothian
                      Okay, dank dir.
                      Die ExtPanID hatte ich bei Ersteinrichtung auf was eigenes geändert.
                      Also Adapter stoppen.
                      • Wieder den Codm eintragen
                      • Unter "Erweiterte Pan ID" die "extended_pan_id" aus dem Backup eibtragen
                      • Unter Pan ID die pan_id auf dem Backup
                      • Das selbe für den Chnnel
                      • Meine Pan ID im Backup hat nur eine Zahl und einen Buchstaben, dann vermutlich umrechnen?
                      Die coordinator_ieee aus dem Backup nirgends eintragen und den Transportschlüssel im Adapter belassen?
                      Passt das so? Bevor ich da wieder rumeiere in einer Lücke von keiner meckert wenn etwas nicht geht 🤣
                        @asgothian
                        Okay, dank dir.
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @david-g so sollte es passen, ja. Ggf. Musst du noch auf dem Code das nvram löschen - den kenn ich nicht im detail
                          David G.D Online
                          David G.D Online
                          David G.
                          @asgothian
                          Okay
                          Wenn ich die Pan ID umrechne kommt da meine alte raus ohne führende 0.
                          Lasse ich die dann weg?
                          Hab es grad nochmal getestet. Ohne die 0.
                          Gruppen lassen sich schalten. Einzelne Geräte nicht.
                          Mit 0 kommt der Fehler im Adapter mit der Konfiguration.
                          • pmayerP Offline
                            pmayerP Offline
                            pmayer
                            Sers,
                            bin eben aus dem Urlaub zurück. David hatte glaube auch schon ne Mail an uns geschrieben.
                            Ist das Problem mittlerweile behoben - gebe zu, steige nicht komplett durch.
                            Gruß,
                            Patrik
                              @asgothian
                              Okay
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              alle nicht, oder einige nicht ?
                              Bei denen die nicht schalten - was kommt an Meldungen wenn du in den State zigbee.0.info.debugmessages die ieee der geräte (ohne 0x, mit ; getrennt) einträgst und dann versuchst diese zu schalten
                              A.
                              • David G.D Online
                                David G.D Online
                                David G.
                                @pmayer sagte in Inbetriebnahme cod.m Koordinator mit Error:
                                Sers,
                                Gruß,
                                Patrik
                                Ich hoffe der Urlaub war erholsam, das neue Jahr kann beginnen.
                                Nein, ich habe eich dazu nicht angeschrieben.
                                Das Problem besteht leider noch.
                                A.
                                Ich meine alle nicht.
                                Schalten konnte ich NUR Gruppen. Empfangen von Thermometern in Kühltruhe und Kühlschrank.
                                Werde ich morgen testen. Da habe ich "Sturmfrei :-D"
                                Bisher kam beim normalen schalten dann glaube ich, dass die Route nicht gefunden wurde.
                                pmayerP AsgothianA 2 Antworten Letzte Antwort
                                  Sers,
                                  Gruß,
                                  Patrik
                                  A.
                                  pmayerP Offline
                                  pmayerP Offline
                                  pmayer
                                  Ich kann momentan nicht sagen ob da was an unserem Coordinator liegt. Weil der ist nur der verlängerte Arm vom zigbee-adapter.
                                  Wenn die Connection aufgebaut ist wird der C2652P7 direkt vom zigbee-adapter angesprochen. Der Coordinator stellt nur die Verbindung vom seriellen Gerät per Netzwerk bereit.
                                  Kannst du den Coordinator mal an einer neuen Testinstallation ausprobieren?
                                    Sers,
                                    Gruß,
                                    Patrik
                                    A.
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    Der Fehler das die Route nicht gefunden wurde deutet darauf hin das die Netzwerk-Struktur nicht sauber übernommen wurde. Ich würde dem Netzwerk einige Stunden Zeit geben, und die Router jeweils (wenn möglich) einmal kurz vom Strom trennen und wieder anschliessen, nachdem du das Netz aufgemacht hast. Das hilft zumeist dabei das Netz wieder zu stabilisieren.
                                    Ansonsten dürfte nur neu anlernen helfen.
                                    A.
                                      A.
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @asgothian
                                      Dann gehe ich es morgen nochmal wie weiter oben beschrieben an und trenne dann mal alles vom Strom, sollte bei 90% der Lampen und Steckdosen gehen.
                                      Auch die Erweiterte Pan ID wie im Backup und nicht vorher im Adapter. Ebenso die Pan ID ohne die vorangesgellte 0 da diese scheinbar bei der Konvertierung verloren geht.
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        So,
                                        hab grad nochmal alles durchgemacht.
                                        Eigentlich GENAU woe zuvor.
                                        Hab nur kurz bevor ich die Zigbee Instanz gestartet hab den NVRAM gelöscht und den Koordinator neugestartet. Zuvor nur den NVRAM gelöscht. Dann noch nach dem Start des Adapters alle Geräte mit 230V (bis auf eins) kurz vom Strom getrennt.
                                        Hab noch kein Gerät gefunden was Probleme macht.
                                        Die Geräte mit Batterie haben sich auch nach und nach gemeldet.
                                        @pmayer
                                        Evtl kann man es in euer iobroker how to aufnehmen mit den Daten aus dem Backup für Kunden die (von Kompatibler Hardware mit dem selbem Chip) zu Euch wechseln.
                                        • pmayerP Offline
                                          pmayerP Offline
                                          pmayer
                                          @david-g sagte in [Gelöst] Inbetriebnahme cod.m Koordinator mit Error:
                                          Das ist eine gute Idee.... guck ich mir am Montag an.
                                          R 1 Antwort Letzte Antwort
