  4. [Gelöst] Inbetriebnahme cod.m Koordinator mit Error
24 Beiträge 5 Kommentatoren 3.0k Aufrufe 4 Beobachtet
  • AsgothianA Asgothian
    @david-g Deine Konfiguration ist unsauber. Sagt das Log zumindest. Nutz mal das Diag Skript aus diesem Thread um dir Anzeigen zu lassen was da drin steht, und pass dann deine Konfiguration an das an was erwartet wird.
    A.
    David G.D Online
    David G.D Online
    David G.
    @asgothian
    Gerne
    *** BASE SYSTEM ***                                                         Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
    Operating System: Debian GNU/Linux 12 (bookworm)                                     Kernel: Linux 6.1.0-18-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : 12th Gen Intel(R) Core(TM) i3-12100
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:26:12 up 2 days, 20:16,  1 user,  load average: 0.29, 0.33, 0.30
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-01-08 09:26:12 CET
               Universal time: Wed 2025-01-08 08:26:12 UTC
                     RTC time: Wed 2025-01-08 08:26:12
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    david
    HOME=/home/david
    GROUPS=david sudo users iobroker
    iobroker
    [sudo] password for david:
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.3G        5.1G        1.7G        516K        1.7G        3.2G
    Swap:           1.0G        274K        1.0G
    Total:          9.3G        5.1G        2.7G
    Active iob-Instances:   53
             7940 M total memory
             4902 M used memory
              716 M active memory
             5211 M inactive memory
             1645 M free memory
              205 M buffer memory
             1456 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 09:26:22 up 2 days, 20:16,  1 user,  load average: 0.24, 0.32, 0.30
    Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7940.7 total,   1645.1 free,   4903.1 used,   1661.6 buff/cache
    MiB Swap:    975.0 total,    974.7 free,      0.3 used.   3037.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  528K  794M   1% /run
    /dev/sda1      ext4       31G   19G   11G  63% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     795M     0  795M   0% /run/user/1001
    [Sun Jan  5 13:09:56 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jan  5 13:09:57 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    4.3G    /var/
    3.1G    /var/log/journal/c2f62aa20c614a09b8a2622bde83939a
    3.1G    /var/log
    1.1G    /var/cache/apt
    Archived and active journals take up 1.5G in the file system.
    /opt/iobroker/backups:
    1.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.3G    /opt/iobroker/iobroker-data/
    1.5G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
    63M     /opt/iobroker/iobroker-data/objects.jsonl
    57M     /opt/iobroker/iobroker-data/states.jsonl
    41M     /opt/iobroker/iobroker-data/mymedia/smoke.mp4
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 245773)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.2.6
    javascript:     8.8.3
    nodejs modules from github:     4
    +-- iobroker.ai-assistant@0.0.2 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-assistant.git#c1fab08203c28ed2e613b42ca6f93ed991bab809)
    +-- iobroker.ai-toolbox@0.0.6 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-toolbox.git#19f6fe2be84574d473703bb6470ba8c5b8f026a3)
    +-- iobroker.google-sharedlocations@2.1.4 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#73e87eafd1922418a4829d93697b2268eacada2a)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
    + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
    + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.daswetter.1              : daswetter             : iobroker                                 - disabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.iceroad.0                : iceroad               : iobroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.kisshome-research.0      : kisshome-research     : iobroker                                 - disabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.parser.0                 : parser                : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.places.0                 : places                : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
      system.adapter.schedule-switcher.0      : schedule-switcher     : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.99.4:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.4.10   , installed 7.2.6  [Updatable]
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
    Adapter    "countdown"    : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hmip"         : 1.25.0   , installed 1.25.0
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "imap"         : 0.3.0    , installed 0.3.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
    Adapter    "kisshome-research": 1.2.5, installed 1.2.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "places"       : 1.2.0    , installed 1.2.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "roborock"     : 0.6.17   , installed 0.6.17
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "schedule-switcher": 0.0.9, installed 0.0.9
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 2.1.7    , installed 2.1.7
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Objects and States
    Objects:        31346
    States:         28456
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InReleaseReading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1000       19705      1013/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16999      1077/io.mqtt.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1818828    127453/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       19056      1190/io.sonoff.0
    tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1000       18914      998/io.hm-rpc.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15531      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16490      584/sshd: /usr/sbin
    tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1000       1816933    127395/io.shelly.0
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       20820      1320/adb
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15149      572/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       16495      572/iobroker.js-con
    tcp6       0      0 :::1980                 :::*                    LISTEN      1000       1818830    127453/node-red
    tcp6       0      0 :::111                  :::*                    LISTEN      0          379        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16492      584/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       21336      1862/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15198      602/io.admin.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       26013      1961/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       22884      1945/io.web.0
    tcp6       0      0 :::8092                 :::*                    LISTEN      1000       2527826    177780/io.lovelace.
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       2528769    177764/io.lovelace.
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1084       1/init
    udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1000       19139      1221/io.tr-064.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1816935    127402/io.shelly.1
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       26700      1997/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          1085       1/init
    2025-01-08 09:25:20.494  - error: zigbee.0 (216202) Error herdsman start
    2025-01-08 09:25:30.497  - info: zigbee.0 (216202) Try to reconnect.
    2025-01-08 09:25:30.498  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:30.507  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
    2025-01-08 09:25:30.651  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Error while opening socket"
    2025-01-08 09:25:30.652  - error: zigbee.0 (216202) Failed to start Zigbee
    2025-01-08 09:25:30.652  - error: zigbee.0 (216202) Error herdsman start
    2025-01-08 09:25:40.655  - info: zigbee.0 (216202) Try to reconnect.
    2025-01-08 09:25:40.656  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:40.663  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
    2025-01-08 09:25:40.846  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Error while opening socket"
    2025-01-08 09:25:40.846  - error: zigbee.0 (216202) Failed to start Zigbee
    2025-01-08 09:25:40.848  - error: zigbee.0 (216202) Error herdsman start
    2025-01-08 09:25:50.849  - info: zigbee.0 (216202) Try to reconnect.
    2025-01-08 09:25:50.850  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:25:50.862  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
    2025-01-08 09:26:10.027  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2025-01-08 09:26:10.028  - error: zigbee.0 (216202) Failed to start Zigbee
    2025-01-08 09:26:10.028  - error: zigbee.0 (216202) Error herdsman start
    2025-01-08 09:26:20.030  - info: zigbee.0 (216202) Try to reconnect.
    2025-01-08 09:26:20.031  - info: zigbee.0 (216202) Starting Zigbee  npm ...2025-01-08 09:26:20.039  - info: zigbee.0 (216202) Installed Version: iobroker.zigbee@1.10.14
    2025-01-08 09:26:39.212  - error: zigbee.0 (216202) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2025-01-08 09:26:39.213  - error: zigbee.0 (216202) Failed to start Zigbee
    2025-01-08 09:26:39.213  - error: zigbee.0 (216202) Error herdsman start
    Edit
    Kann es sein, dass die Meldung kommt weil der alte Koordinator noch im USB steckt?
    Hab gtad auf der Arbeit Zeit und wollte den codm schonmal einrichten.
    Sehe jetzt nicht groß, was erwartet wird. By ID gibt's ja beim Netzwerkkoordinator nicht.
    EDIT 2
    Die Meldung hat sich glaube verändert
    zigbee.0
    2025-01-08 09:45:49.609	error	Error herdsman start
    zigbee.0
    2025-01-08 09:45:49.609	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 09:45:49.608	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.0
    2025-01-08 09:45:49.511	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 09:45:49.500	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 09:45:49.499	info	Try to reconnect.
    zigbee.0
    2025-01-08 09:45:39.498	error	Error herdsman start
    zigbee.0
    2025-01-08 09:45:39.498	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 09:45:39.497	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.0
    2025-01-08 09:45:39.281	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 09:45:39.275	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 09:45:39.274	info	Try to reconnect.
    zigbee.0
    2025-01-08 09:45:29.272	error	Error herdsman start
    zigbee.0
    2025-01-08 09:45:29.272	error	Failed to start Zigbee
    zigbee.0
    2025-01-08 09:45:29.271	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.0
    2025-01-08 09:45:29.129	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-01-08 09:45:29.121	info	Starting Zigbee npm ...
    zigbee.0
    2025-01-08 09:45:29.120	info	Try to reconnect.
    • David G.D David G.
      @asgothian
      Gerne
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      david
      HOME=/home/david
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               7940 M total memory
               4902 M used memory
                716 M active memory
               1645 M free memory
                205 M buffer memory
               1456 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      4.3G    /var/
      3.1G    /var/log
      1.1G    /var/cache/apt
      USB-Devices by-id:
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.2.6
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        31346
      States:         28456
      Pending Updates: 0
      Edit
      EDIT 2
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @david-g sagte in cod.m ZigBee Coordinator (PoE/non-PoE) - made in Germany:
      hast du beim cod.m etwas in den security Einstellungen bezüglich socket gemacht?
      läuft der cod.m?
      EDIT:
      Hab das mal aus dem Marktplatz abgetrennt
      bitte ggf. den provisorischen Threadtitel anpassen
        läuft der cod.m?
        EDIT:
        David G.D Online
        David G.D Online
        David G.
        Nein, alles default bis auf das Verhalten der LED und dass ich die IP statisch gesetzt habe.
        Hab auch gtad mal reingeschaut, keine Option aktiviert bei den Sicherheitseinstellungen.
        Edit
        Danke fürs verschieben.
        EDIT 2
        Wenn ich am codm die Zigbeeverbindung prüfe kommt:
        [937395] -> fe 00 21 01 20
        [937399] <- fe 02 61 01 59 06 3d
        [937462] -> fe 00 21 02 23
        [937469] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
        [937530] -> fe 02 21 13 82 00 b2
        [937540] <- fe 02 61 13 18 00 68
        [937608] -> fe 04 21 1c 82 00 00 00 bb
        [937626] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
        [937692] -> fe 02 21 13 60 00 50
        [937699] <- fe 02 61 13 01 00 71
        [937765] -> fe 04 21 1c 60 00 00 00 59
        [937774] <- fe 03 61 1c 00 01 55 2a
        [937836] -> fe 02 21 13 21 00 11
        [937848] <- fe 02 61 13 74 00 04
        [937921] -> fe 04 21 1c 21 00 00 00 18
        [937946] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
        [938032] -> fe 02 21 13 62 00 52
        [938041] <- fe 02 61 13 10 00 60
        [938109] -> fe 04 21 1c 62 00 00 00 5b
        [938144] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
        [938223] -> fe 02 21 13 3a 00 0a
        [938233] <- fe 02 61 13 11 00 61
        [938311] -> fe 04 21 1c 3a 00 00 00 03
        [938327] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [938401] -> fe 02 21 13 3b 00 0b
        [938418] <- fe 02 61 13 11 00 61
        [938483] -> fe 04 21 1c 3b 00 00 00 02
        [938500] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [939989] | [ZB] Chip: CC2652P7
        [939990] | [ZB] IEEE: 00:12:4B:00:2E:10:4F:F0
        [940000] | [ZB] Flash size: 704 KB
        [940564] <- a9 a5 a5 a5 a5 81 81 81 81 81 01 20 00
        [942449] <- fe 06 41 80 00 02 01 02 07 01 c0
        [948713] | Connected client 2 from 192.168.99.33
        [948714] -> ef
        [949729] -> fe 00 21 01 20
        [949737] <- fe 02 61 01 59 06 3d
        [949792] -> fe 00 21 02 23
        [949797] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
        [949832] -> fe 02 21 13 82 00 b2
        [949841] <- fe 02 61 13 18 00 68
        [949914] -> fe 04 21 1c 82 00 00 00 bb
        [949931] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
        [949996] -> fe 02 21 13 60 00 50
        [950004] <- fe 02 61 13 01 00 71
        [950068] -> fe 04 21 1c 60 00 00 00 59
        [950078] <- fe 03 61 1c 00 01 55 2a
        [950146] -> fe 02 21 13 21 00 11
        [950155] <- fe 02 61 13 74 00 04
        [950202] -> fe 04 21 1c 21 00 00 00 18
        [950232] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
        [950303] -> fe 02 21 13 62 00 52
        [950312] <- fe 02 61 13 10 00 60
        [950376] -> fe 04 21 1c 62 00 00 00 5b
        [950397] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
        [950489] -> fe 02 21 13 3a 00 0a
        [950499] <- fe 02 61 13 11 00 61
        [950564] -> fe 04 21 1c 3a 00 00 00 03
        [950579] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [950678] -> fe 02 21 13 3b 00 0b
        [950687] <- fe 02 61 13 11 00 61
        [950775] -> fe 04 21 1c 3b 00 00 00 02
        [950790] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [955953] | [ZB] Chip: CC2652P7
        [955954] | [ZB] IEEE: 00:12:4B:00:2E:10:4F:F0
        [955964] | [ZB] Flash size: 704 KB
        [956529] <- ad a5 a5 a5 a5 a5 81 81 81 81 81 81 81 01 00 00
        [957954] <- fe 06 41 80 00 02 01 02 07 01 c0
        [960977] | Connected client 3 from 192.168.99.33
        [960978] -> ef
        [962031] -> fe 00 21 01 20
        [962036] <- fe 02 61 01 59 06 3d
        [962126] -> fe 00 21 02 23
        [962132] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
        [962226] -> fe 02 21 13 82 00 b2
        [962233] <- fe 02 61 13 18 00 68
        [962308] -> fe 04 21 1c 82 00 00 00 bb
        [962320] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
        [962412] -> fe 02 21 13 60 00 50
        [962423] <- fe 02 61 13 01 00 71
        [962534] -> fe 04 21 1c 60 00 00 00 59
        [962551] <- fe 03 61 1c 00 01 55 2a
        [962659] -> fe 02 21 13 21 00 11
        [962666] <- fe 02 61 13 74 00 04
        [962795] -> fe 04 21 1c 21 00 00 00 18
        [962815] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
        [963308] -> fe 02 21 13 62 00 52
        [963315] <- fe 02 61 13 10 00 60
        [963408] -> fe 04 21 1c 62 00 00 00 5b
        [963419] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
        [963521] -> fe 02 21 13 3a 00 0a
        [963529] <- fe 02 61 13 11 00 61
        [963615] -> fe 04 21 1c 3a 00 00 00 03
        [963626] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [964071] -> fe 02 21 13 3b 00 0b
        [964077] <- fe 02 61 13 11 00 61
        [964128] -> fe 04 21 1c 3b 00 00 00 02
        [964139] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [974423] | Connected client 4 from 192.168.99.33
        [974424] -> ef
        [975394] -> fe 00 21 01 20
        [975399] <- fe 02 61 01 59 06 3d
        [975461] -> fe 00 21 02 23
        [975466] <- fe 0a 61 02 02 01 02 07 01 46 d9 34 01 00 c4
        [975491] -> fe 02 21 13 82 00 b2
        [975497] <- fe 02 61 13 18 00 68
        [975525] -> fe 04 21 1c 82 00 00 00 bb
        [975537] <- fe 1a 61 1c 00 18 00 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 b3 cf 97 77 3d 09 00 13
        [975547] -> fe 02 21 13 60 00 50
        [975559] <- fe 02 61 13 01 00 71
        [975595] -> fe 04 21 1c 60 00 00 00 59
        [975613] <- fe 03 61 1c 00 01 55 2a
        [975634] -> fe 02 21 13 21 00 11
        [975641] <- fe 02 61 13 74 00 04
        [975647] -> fe 04 21 1c 21 00 00 00 18
        [975667] <- fe 76 61 1c 00 74 c1 05 02 33 0f 33 00 1e 00 00 00 01 05 01 8f 00 08 00 02 0d 02 00 00 00 0b 00 00 00 00 00 00 00 00 00 00 00 6c 00 08 00 00 08 00 00 0f 0f 04 00 01 00 00 00 01 00 00 00 00 13 cf 19 5a 74 b4 cb 62 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0f 05 00 01 3c 0a 01 00 00 00 00 00 00 00 8f
        [975676] -> fe 02 21 13 62 00 52
        [975682] <- fe 02 61 13 10 00 60
        [975692] -> fe 04 21 1c 62 00 00 00 5b
        [975702] <- fe 12 61 1c 00 10 b3 cf 97 ca b6 73 21 e5 44 b7 f3 65 9b e9 43 b0 bb
        [975707] -> fe 02 21 13 3a 00 0a
        [975713] <- fe 02 61 13 11 00 61
        [975728] -> fe 04 21 1c 3a 00 00 00 03
        [975740] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        [975757] -> fe 02 21 13 3b 00 0b
        [975763] <- fe 02 61 13 11 00 61
        [975771] -> fe 04 21 1c 3b 00 00 00 02
        [975781] <- fe 13 61 1c 00 11 00 01 03 05 07 09 0b 0d 0f 00 02 04 06 08 0a 0c 0d 7c
        Man findet öfters die IP 192.168.99.33.
        Das ist mein iobroker.
        Damit kam @pmayer bestimmt was anfangen.
        EDIT 3
        Angeblich bestehen 4 Verbindungen
        Wenn ich den Zigbee Adapter neu starte fängt er an die Verbindungen von nicht verbunden bis 5 hochzuzählen innerhalb weniger Sekunden.
        EDIT 4
        @Asgothian
        Hab das Script jetzt unzensiert laufen lassen.
        Jetzt sieht man einen Fehler:
        Extended Pan ID:
        xxx
        Pan ID:
        ./iob_diag.sh: line 715: printf: 0x6c",: invalid hex number
        108
        Channel:
        Aber warum? Wenn ich auf den USB Dongle stelle läuft es....
        EDIT 5
        Hab die Pan ID nochmal uberspeichert. Da hat der Adapter auch nicht gestartet.
        Hab dann den NVRAM gelöscht. Danach war es lange still beim Adapterstart. Dann irgendwann ist er grün geworden.
        Heute Abend sehe ich dann, welche Geräte (nicht) klappen.
        Bisher zeigt der Admin nur die batteriebetriebenen Geräte grün.
          Edit
          EDIT 2
          [948714] -> ef
          [960978] -> ef
          [974424] -> ef
          EDIT 3
          EDIT 4
          @Asgothian
          Extended Pan ID:
          xxx
          Pan ID:
          108
          Channel:
          EDIT 5
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @david-g sagte in Inbetriebnahme cod.m Koordinator mit Error:
          Du darfst davon ausgehen das kein Gerät geht - da du den nvram gelöscht hast und nun mit geänderter verschlüsselung arbeitest.
          Was du tun solltest :
          • in der nvbackup.json die folgenden Zeilen finden:
            "pan_id": "1a62",
            "extended_pan_id": "adfdcdab76983412",
            "nwk_update_id": 1,
            "security_level": 5,
            "channel": 11,
          Danach sicherstellen das die Einstellungen in der Oberfläche diesen entsprechen. ggf. musst du die pan_id noch von hex in dezimal umrechnen.
          Wichtig: Adapter anhalten - Konfiguration anpassen - adapter starten
          Sollte es weitere Meldungen mit "Error while opening socket" geben musst du schauen ob noch Prozesse des Zigbee-Adapters hängen die den Port blockieren.
          A.
              "pan_id": "1a62",
              "nwk_update_id": 1,
              "channel": 11,
            A.
            David G.D Online
            David G.D Online
            David G.
            @asgothian sagte in Inbetriebnahme cod.m Koordinator mit Error:
            Ein Thermometer in der Kühltruhe übermittelt Werte, das sehe ich schonmal von der Arbeit aus.
            War eben auch kurz zu Hause meinen Sohn abgeben. Da konnte ich das Licht im Flur schalten. 2 Andere Birnen nicht, obwohl eine Verbindung besteht. Mal sehen wie es heute Abend aussieht.
            Sonst erstmal Snapshot einspielen und dann sollte ja alles wieder gehen ^^.
            EDIT
            Kann es sein, dass manche Geräte Funktion, wenn die Verschlüsselung geändert worden ist?
            Verstehe noch nicht ganz, warum manche Sachen verbunden sind und klappen und andere verbunden und disconnectet.
              EDIT
              David G.D Online
              David G.D Online
              David G.
              @Asgothian @arteck
              Habe jetzt einen Snapshot eingespielt den ich vor dem Wechsel gemacht habe.
              Nun läuft alles wieder mit dem Sonoff.
              Wie gehe ich nun am besten vor?
              Muss ich am Codm was zurücksetzen?
              Gruppen konnte ich mit steuern, Werte von Sensoren Empfangen aber keine Lampen schalten.
                @Asgothian @arteck
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                Das steht weiter oben schon. Du musst die PanID, ExtPanID und den Kanal heraus finden die dein System wirklich nutzt. Insbesondere bei Installationen mit einer ExtPanID DDDDDDDDDDDDDDDD kann die im System genutzte von der aus der Konfiguration abweichen, da in diesem Fall die IEEE des Koordinators genutzt wird. Diese ist Hardwarespezifisch.
                A.
                  A.
                  David G.D Online
                  David G.D Online
                  David G.
                  @asgothian
                  Okay, dank dir.
                  Die ExtPanID hatte ich bei Ersteinrichtung auf was eigenes geändert.
                  Also Adapter stoppen.
                  • Wieder den Codm eintragen
                  • Unter "Erweiterte Pan ID" die "extended_pan_id" aus dem Backup eibtragen
                  • Unter Pan ID die pan_id auf dem Backup
                  • Das selbe für den Chnnel
                  • Meine Pan ID im Backup hat nur eine Zahl und einen Buchstaben, dann vermutlich umrechnen?
                  Die coordinator_ieee aus dem Backup nirgends eintragen und den Transportschlüssel im Adapter belassen?
                  Passt das so? Bevor ich da wieder rumeiere in einer Lücke von keiner meckert wenn etwas nicht geht 🤣
                    @asgothian
                    Okay, dank dir.
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @david-g so sollte es passen, ja. Ggf. Musst du noch auf dem Code das nvram löschen - den kenn ich nicht im detail
                      David G.D Online
                      David G.D Online
                      David G.
                      @asgothian
                      Okay
                      Wenn ich die Pan ID umrechne kommt da meine alte raus ohne führende 0.
                      Lasse ich die dann weg?
                      Hab es grad nochmal getestet. Ohne die 0.
                      Gruppen lassen sich schalten. Einzelne Geräte nicht.
                      Mit 0 kommt der Fehler im Adapter mit der Konfiguration.
                      • pmayerP Offline
                        pmayerP Offline
                        pmayer
                        Sers,
                        bin eben aus dem Urlaub zurück. David hatte glaube auch schon ne Mail an uns geschrieben.
                        Ist das Problem mittlerweile behoben - gebe zu, steige nicht komplett durch.
                        Gruß,
                        Patrik
                          @asgothian
                          Okay
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          alle nicht, oder einige nicht ?
                          Bei denen die nicht schalten - was kommt an Meldungen wenn du in den State zigbee.0.info.debugmessages die ieee der geräte (ohne 0x, mit ; getrennt) einträgst und dann versuchst diese zu schalten
                          A.
                          • David G.D Online
                            David G.D Online
                            David G.
                            @pmayer sagte in Inbetriebnahme cod.m Koordinator mit Error:
                            Sers,
                            Gruß,
                            Patrik
                            Ich hoffe der Urlaub war erholsam, das neue Jahr kann beginnen.
                            Nein, ich habe eich dazu nicht angeschrieben.
                            Das Problem besteht leider noch.
                            A.
                            Ich meine alle nicht.
                            Schalten konnte ich NUR Gruppen. Empfangen von Thermometern in Kühltruhe und Kühlschrank.
                            Werde ich morgen testen. Da habe ich "Sturmfrei :-D"
                            Bisher kam beim normalen schalten dann glaube ich, dass die Route nicht gefunden wurde.
                            pmayerP AsgothianA 2 Antworten Letzte Antwort
                              Sers,
                              Gruß,
                              Patrik
                              A.
                              pmayerP Offline
                              pmayerP Offline
                              pmayer
                              Ich kann momentan nicht sagen ob da was an unserem Coordinator liegt. Weil der ist nur der verlängerte Arm vom zigbee-adapter.
                              Wenn die Connection aufgebaut ist wird der C2652P7 direkt vom zigbee-adapter angesprochen. Der Coordinator stellt nur die Verbindung vom seriellen Gerät per Netzwerk bereit.
                              Kannst du den Coordinator mal an einer neuen Testinstallation ausprobieren?
                                Sers,
                                Gruß,
                                Patrik
                                A.
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                Der Fehler das die Route nicht gefunden wurde deutet darauf hin das die Netzwerk-Struktur nicht sauber übernommen wurde. Ich würde dem Netzwerk einige Stunden Zeit geben, und die Router jeweils (wenn möglich) einmal kurz vom Strom trennen und wieder anschliessen, nachdem du das Netz aufgemacht hast. Das hilft zumeist dabei das Netz wieder zu stabilisieren.
                                Ansonsten dürfte nur neu anlernen helfen.
                                A.
                                  A.
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @asgothian
                                  Dann gehe ich es morgen nochmal wie weiter oben beschrieben an und trenne dann mal alles vom Strom, sollte bei 90% der Lampen und Steckdosen gehen.
                                  Auch die Erweiterte Pan ID wie im Backup und nicht vorher im Adapter. Ebenso die Pan ID ohne die vorangesgellte 0 da diese scheinbar bei der Konvertierung verloren geht.
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    So,
                                    hab grad nochmal alles durchgemacht.
                                    Eigentlich GENAU woe zuvor.
                                    Hab nur kurz bevor ich die Zigbee Instanz gestartet hab den NVRAM gelöscht und den Koordinator neugestartet. Zuvor nur den NVRAM gelöscht. Dann noch nach dem Start des Adapters alle Geräte mit 230V (bis auf eins) kurz vom Strom getrennt.
                                    Hab noch kein Gerät gefunden was Probleme macht.
                                    Die Geräte mit Batterie haben sich auch nach und nach gemeldet.
                                    @pmayer
                                    Evtl kann man es in euer iobroker how to aufnehmen mit den Daten aus dem Backup für Kunden die (von Kompatibler Hardware mit dem selbem Chip) zu Euch wechseln.
                                    • pmayerP Offline
                                      pmayerP Offline
                                      pmayer
                                      @david-g sagte in [Gelöst] Inbetriebnahme cod.m Koordinator mit Error:
                                      Das ist eine gute Idee.... guck ich mir am Montag an.
                                      R 1 Antwort Letzte Antwort
                                      • pmayerP pmayer
                                        reutli
                                        @pmayer sagte in [Gelöst] Inbetriebnahme cod.m Koordinator mit Error:
                                        Genau das würde mich interessieren, also eine Anleitung wie man beispielsweise in iobroker vom SONOFF Stick (USB) zu Eurem wechselt. Werde meinen die Tage bekommen und wüsste gerne wie ich das anstelle...
                                        Habe gerade noch einen PI als Slave, daran den SONOFF über USB und möchte jetzt auf die Ethernet-Variante von Euch umstellen...
                                        Die Anleitung für die (Erst-)Installation ist da, aber für den Wechsel....
                                        iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                        *Wer freundlich ist, dem wird freundlich geholfen *
                                        pmayerP 1 Antwort Letzte Antwort
                                        • R reutli
                                          pmayerP Offline
                                          pmayerP Offline
                                          pmayer
                                          @reutli Mein Stand:
                                          Einfach port: auf die IP ändern. Wenn startup failed - configuration-adapter mismatch - see logs above for more information kommt, das NVRAM auf dem Coordinator leeren, wie hier beschrieben: https://docs.codm.de/zigbee/faq/#startup-failed-configuration-adapter-mismatch
                                          Wenn das nicht funktionieren sollte, können wir wegen IEEE nochmal gucken.
                                          So lange du jetzt schon adapter: zstack hast, sehe ich aber kein Problem.
                                          Natürlich abhängig von dem was @david-g sagt.
