  4. js-controller Update aus Admin schlägt fehlt
11 Beiträge 2 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • Merlin123M Offline
    Merlin123M Offline
    Merlin123
    Auf Wunsch von @foxriver76 und @Thomas-Braun hier die Diagausgabe zu dem Problem, dass ein js-controller Update aus dem Admin den Fehler
    SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
    bringt
                            v.2024-10-19
     Static hostname: iobrokervm
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-27-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    Recommended versions are nodejs 20.18.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:             12G        4.6G        4.1G        561K        3.9G        7.6G
    Swap:           5.1G          0B        5.1G
    Total:           17G        4.6G        9.2G
    Active iob-Instances:   70
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.2
                            admin                   7.3.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.1                  : admin                 : iobrokervm                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iobrokervm                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                28605
    States:                 23764
    Size of iob-Database:
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/states.jsonl
    Operating System is the current Debian stable version codenamed 'bookworm'!
    Beta-Tester
    • Merlin123M Merlin123
      bringt
                              v.2024-10-19
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:           5.1G          0B        5.1G
                              admin                   7.3.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                28605
      States:                 23764
      @merlin123
      Die Langfassung bitte.
      Merlin123M 1 Antwort Letzte Antwort
        @merlin123
        Merlin123M Offline
        Merlin123M Offline
        Merlin123
        schrieb am zuletzt editiert von Merlin123
        Sorry.... Hier komplett
        Script v.2024-10-19
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        model name	: Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         13:50:49 up 5 days, 21:24,  2 users,  load average: 0.47, 0.45, 0.49
        CPU threads: 8
        *** LIFE CYCLE STATUS ***
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2024-11-15 13:50:50 CET
                   Universal time: Fri 2024-11-15 12:50:50 UTC
                         RTC time: Fri 2024-11-15 12:50:50
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        oliver
        HOME=/home/oliver
        GROUPS=oliver cdrom floppy sudo audio dip video plugdev netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Mem:             12G        4.6G        4.0G        569K        3.9G        7.6G
        Swap:           5.1G          0B        5.1G
                11676 M total memory
                 4387 M used memory
                 1527 M active memory
                 5476 M inactive memory
                 3852 M free memory
                  455 M buffer memory
                 3298 M swap cache
                 4881 M total swap
                    0 M used swap
                 4881 M free swap
        top - 13:50:50 up 5 days, 21:24,  2 users,  load average: 0.47, 0.45, 0.49
        Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11676.7 total,   3852.8 free,   4387.0 used,   3754.0 buff/cache
        MiB Swap:   4881.2 total,   4881.2 free,      0.0 used.   7289.7 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  5.7G     0  5.7G   0% /dev
        tmpfs          tmpfs     1.2G  556K  1.2G   1% /run
        /dev/sda1      ext4      141G   33G  103G  24% /
        tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
        [Sat Nov  9 16:26:43 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Nov  9 16:26:43 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        2.7G	/var/
        1.5G	/var/log
        1021M	/var/cache
        1013M	/var/cache/apt
        937M	/var/cache/apt/archives
        Archived and active journals take up 178.1M in the file system.
        /opt/iobroker/backups:
        177M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.1G	/opt/iobroker/iobroker-data/
        1.9G	/opt/iobroker/iobroker-data/files
        617M	/opt/iobroker/iobroker-data/files/javascript.admin
        560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        63M	/opt/iobroker/iobroker-data/states.jsonl
        41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        37M	/opt/iobroker/iobroker-data/objects.jsonl
        37M	/opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08a893a38329ec11ba4c6f7840c9ce8d-if00-port0
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        *** NodeJS-Installation ***
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobrokervm          iobrokervm (version: 7.0.2, hostname: iobrokervm    , alive, uptime: 3047)
        Core adapters versions
        js-controller: 	7.0.2
        admin: 		7.3.1
        javascript: 	8.8.3
        nodejs modules from github: 	6
        +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
        +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
        +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75)
        +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1)
        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
        Adapter State
        + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobrokervm                               -  enabled
        + system.adapter.alexa2.0                 : alexa2                : iobrokervm                               -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobrokervm                               - disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iobrokervm                               -  enabled
        + system.adapter.backitup.0               : backitup              : iobrokervm                               -  enabled
        + system.adapter.chromecast.0             : chromecast            : iobrokervm                               -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobrokervm                               -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobrokervm                               -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobrokervm                               -  enabled
          system.adapter.devices.0                : devices               : iobrokervm                               - disabled
        + system.adapter.discovery.0              : discovery             : iobrokervm                               -  enabled
        + system.adapter.doorbird.0               : doorbird              : iobrokervm                               -  enabled
        + system.adapter.drops-weather.0          : drops-weather         : iobrokervm                               -  enabled
          system.adapter.dwd.0                    : dwd                   : iobrokervm                               -  enabled
        + system.adapter.echarts.0                : echarts               : iobrokervm                               -  enabled
        + system.adapter.email.0                  : email                 : iobrokervm                               -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : iobrokervm                               -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobrokervm                               -  enabled
        + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobrokervm                               -  enabled
        + system.adapter.evcc.0                   : evcc                  : iobrokervm                               -  enabled, port: 7070
          system.adapter.flot.0                   : flot                  : iobrokervm                               - disabled
        + system.adapter.followthesun.0           : followthesun          : iobrokervm                               -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : iobrokervm                               -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobrokervm                               -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobrokervm                               -  enabled
        + system.adapter.go-e.0                   : go-e                  : iobrokervm                               -  enabled
        + system.adapter.harmony.0                : harmony               : iobrokervm                               -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : iobrokervm                               -  enabled
        + system.adapter.hue.0                    : hue                   : iobrokervm                               -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : iobrokervm                               -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobrokervm                               -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : iobrokervm                               -  enabled
        + system.adapter.javascript.0             : javascript            : iobrokervm                               -  enabled
          system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobrokervm                               - disabled
          system.adapter.klipper-moonraker.1      : klipper-moonraker     : iobrokervm                               - disabled
        + system.adapter.knx.0                    : knx                   : iobrokervm                               -  enabled, bind: 192.168.0.251
          system.adapter.labcom.0                 : labcom                : iobrokervm                               -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : iobrokervm                               -  enabled
          system.adapter.life360.0                : life360               : iobrokervm                               - disabled
        + system.adapter.linux-control.0          : linux-control         : iobrokervm                               -  enabled
        + system.adapter.logparser.0              : logparser             : iobrokervm                               -  enabled
          system.adapter.material.0               : material              : iobrokervm                               - disabled
          system.adapter.mobile.0                 : mobile                : iobrokervm                               - disabled
        + system.adapter.modbus.0                 : modbus                : iobrokervm                               -  enabled
          system.adapter.mqtt.0                   : mqtt                  : iobrokervm                               - disabled, port: 1884, bind: 0.0.0.0
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokervm                               - disabled
        + system.adapter.nina.0                   : nina                  : iobrokervm                               -  enabled
          system.adapter.node-red.0               : node-red              : iobrokervm                               - disabled, port: 1880, bind: 0.0.0.0
          system.adapter.nuki-extended.0          : nuki-extended         : iobrokervm                               - disabled
        + system.adapter.nuki.0                   : nuki                  : iobrokervm                               -  enabled
        + system.adapter.nut.0                    : nut                   : iobrokervm                               -  enabled
          system.adapter.octoprint.0              : octoprint             : iobrokervm                               - disabled
        + system.adapter.onvif.0                  : onvif                 : iobrokervm                               -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
          system.adapter.openknx.0                : openknx               : iobrokervm                               - disabled
          system.adapter.openweathermap.0         : openweathermap        : iobrokervm                               -  enabled
        + system.adapter.ping.0                   : ping                  : iobrokervm                               -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobrokervm                               -  enabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : iobrokervm                               -  enabled
        + system.adapter.radar-trap.0             : radar-trap            : iobrokervm                               -  enabled
          system.adapter.reolink.0                : reolink               : iobrokervm                               - disabled
        + system.adapter.reolink.1                : reolink               : iobrokervm                               -  enabled
        + system.adapter.reolink.2                : reolink               : iobrokervm                               -  enabled
        + system.adapter.rest-api.0               : rest-api              : iobrokervm                               -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
        + system.adapter.sainlogic.0              : sainlogic             : iobrokervm                               -  enabled, port: 45000, bind: 0.0.0.0
        + system.adapter.scenes.0                 : scenes                : iobrokervm                               -  enabled
        + system.adapter.scheduler.0              : scheduler             : iobrokervm                               -  enabled
        + system.adapter.shelly.0                 : shelly                : iobrokervm                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobrokervm                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.slideshow.0              : slideshow             : iobrokervm                               -  enabled
        + system.adapter.slideshow.1              : slideshow             : iobrokervm                               -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobrokervm                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobrokervm                               -  enabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokervm                               - disabled
        + system.adapter.synology.0               : synology              : iobrokervm                               -  enabled, port: 5000
        + system.adapter.telegram.0               : telegram              : iobrokervm                               -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobrokervm                               -  enabled
        + system.adapter.tibberlink.0             : tibberlink            : iobrokervm                               -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobrokervm                               -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobrokervm                               -  enabled
        + system.adapter.tronity.0                : tronity               : iobrokervm                               -  enabled
          system.adapter.uv-protect.0             : uv-protect            : iobrokervm                               -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobrokervm                               -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobrokervm                               -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobrokervm                               -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobrokervm                               -  enabled
          system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: iobrokervm                               -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : iobrokervm                               -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobrokervm                               - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokervm                               - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokervm                               - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokervm                               - disabled
          system.adapter.vis-history.0            : vis-history           : iobrokervm                               - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokervm                               - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokervm                               - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokervm                               -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokervm                               - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokervm                               -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobrokervm                               -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokervm                               - disabled
          system.adapter.vis.0                    : vis                   : iobrokervm                               -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobrokervm                               -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobrokervm                               -  enabled
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokervm                               -  enabled
        + system.adapter.worx.0                   : worx                  : iobrokervm                               -  enabled
        + system.adapter.ws.0                     : ws                    : iobrokervm                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : iobrokervm                               -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 7.3.1    , installed 7.3.1
        Adapter    "alexa-timer-vis": 2.0.6  , installed 2.0.6
        Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
        Adapter    "backitup"     : 3.0.27   , installed 3.0.27
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "ems-esp"      : 5.0.4    , installed 5.0.4
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
        Adapter    "followthesun" : 0.5.1    , installed 0.5.1
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "go-e"         : 1.0.41   , installed 1.0.41
        Adapter    "harmony"      : 1.5.0    , installed 1.5.0
        Adapter    "homeconnect"  : 1.4.2    , installed 1.4.2
        Adapter    "hue"          : 3.13.1   , installed 3.13.1
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "iot"          : 3.4.3    , installed 3.4.3
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.3    , installed 7.0.2  [Updatable]
        Adapter    "knx"          : 2.0.28   , installed 2.0.28
        Adapter    "lg-thinq"     : 1.0.2    , installed 1.0.2
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mytime"       : 1.2.0    , installed 1.2.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openknx"      : 0.9.0    , installed 0.9.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "pvforecast"   : 4.0.1    , installed 4.0.1
        Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
        Adapter    "reolink"      : 1.1.2    , installed 1.1.2
        Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
        Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
        Adapter    "shelly"       : 8.4.0    , installed 8.4.0
        Adapter    "slideshow"    : 0.2.0    , installed 0.1.4  [Updatable]
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tibberlink"   : 3.5.2    , installed 3.5.2
        Adapter    "trashschedule": 3.4.0    , installed 3.4.0
        Adapter    "tronity"      : 1.1.1    , installed 1.1.1
        Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
        Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
        Adapter    "vis-2-widgets-jaeger-design": 1.3.1, installed 1.3.1
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 6.3.1    , installed 6.3.1
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "worx"         : 3.1.1    , installed 3.1.1
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
        Objects and States
        Objects: 	28605
        States: 	23764
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25804182   1315726/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       25804630   1315872/io.shelly.1
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14529      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16710      463/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       25812761   1316641/io.sainlogi
        tcp        0      0 192.168.0.251:8100      0.0.0.0:*               LISTEN      1001       25806421   1316066/io.doorbird
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25802820   1315299/iobroker.js
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25801317   1315299/iobroker.js
        tcp        0      0 192.168.0.251:9092      0.0.0.0:*               LISTEN      1001       25803370   1315628/io.nuki.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          12965      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16712      463/sshd: /usr/sbin
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       25802494   1315741/io.sonos.0
        tcp6       0      0 :::3040                 :::*                    LISTEN      1001       25816844   1317037/io.radar-tr
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       25808586   1316125/io.fullybro
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       25803154   1315538/io.harmony.
        tcp6       0      0 :::8093                 :::*                    LISTEN      1001       25814158   1316759/io.rest-api
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25813914   1316821/io.ws.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25810572   1316610/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25802013   1315321/io.admin.1
        udp        0      0 192.168.0.251:56134     0.0.0.0:*                           1001       25899271   1315598/io.knx.0
        udp        0      0 192.168.0.251:47945     0.0.0.0:*                           1001       25936324   1315598/io.knx.0
        udp        0      0 192.168.0.251:39820     0.0.0.0:*                           1001       25829580   1315598/io.knx.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14530      1/init
        udp        0      0 192.168.0.251:51416     0.0.0.0:*                           1001       25905749   1315598/io.knx.0
        udp        0      0 192.168.0.251:44966     0.0.0.0:*                           1001       25924697   1315598/io.knx.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       25803155   1315538/io.harmony.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25808193   1316006/io.chromeca
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25804143   1315704/io.shelly.0
        udp        0      0 192.168.0.251:55534     0.0.0.0:*                           1001       25801697   1315598/io.knx.0
        udp        0      0 192.168.0.251:55556     0.0.0.0:*                           1001       25846077   1315598/io.knx.0
        udp6       0      0 :::111                  :::*                                0          13452      1/init
            at listOnTimeout (node:internal/timers:581:17)
            at processTimers (node:internal/timers:519:7)
        2024-11-15 13:50:28.257  - info: chromecast.0 (1316006) AI PONT DE - client disconnected
        2024-11-15 13:50:28.258  - info: chromecast.0 (1316006) AI PONT DE - Detached player
        2024-11-15 13:50:28.817  - info: openweathermap.0 (1325167) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.18.0, js-controller: 7.0.2
        2024-11-15 13:50:31.320  - info: chromecast.0 (1316006) TVMarleen - Connected client
        2024-11-15 13:50:31.333  - info: chromecast.0 (1316006) AI PONT DE - Connected client
        2024-11-15 13:50:31.368  - info: chromecast.0 (1316006) TVMarleen - Try to join player
        2024-11-15 13:50:31.369  - info: chromecast.0 (1316006) TVMarleen - Connected player
        2024-11-15 13:50:31.369  - info: chromecast.0 (1316006) TVMarleen - Player joint
        2024-11-15 13:50:31.374  - info: chromecast.0 (1316006) AI PONT DE - Try to join player
        2024-11-15 13:50:31.375  - info: chromecast.0 (1316006) AI PONT DE - Connected player
        2024-11-15 13:50:31.375  - info: chromecast.0 (1316006) AI PONT DE - Player joint
        2024-11-15 13:50:31.399  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
        2024-11-15 13:50:31.407  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
        2024-11-15 13:50:31.415  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
        2024-11-15 13:50:31.419  - info: chromecast.0 (1316006) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.cac"}],"senderConnected":true,"sessionId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","statusText":"","transportId":"753e6cb6-5cd1-4d50-9a54-adf525a7d85c","universalAppId":"E8C28D3C"}
        2024-11-15 13:50:32.048  - debug: homeconnect.0 (1315553) [object Object]
        2024-11-15 13:50:39.634  - info: web.0 (1316610) <== Disconnect system.user.admin from ::ffff:192.168.0.125
        2024-11-15 13:50:39.753  - info: web.0 (1316610) ==> Connected system.user.admin from ::ffff:192.168.0.125
        2024-11-15 13:50:58.136  - info: openweathermap.0 (1325167) Terminated (NO_ERROR): Without reason
        2024-11-15 13:50:58.647  - info: host.iobrokervm instance system.adapter.openweathermap.0 having pid 1325167 terminated with code 0 (NO_ERROR)
        Beta-Tester
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 8
                        NTP service: active
                    RTC in local TZ: no
          oliver
          HOME=/home/oliver
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:           5.1G          0B        5.1G
                   4387 M used memory
                   3852 M free memory
                    455 M buffer memory
                   3298 M swap cache
                   4881 M total swap
                      0 M used swap
                   4881 M free swap
          *** FILESYSTEM ***
          /var:
          2.7G	/var/
          1.5G	/var/log
          1021M	/var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin: 		7.3.1
          javascript: 	8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	28605
          States: 	23764
          Pending Updates: 0
          @merlin123
          Okay, dann bitte noch die Ausgabe von
          egrep 'oliver|iobroker' /etc/passwd
            @merlin123
            Merlin123M Offline
            Merlin123M Offline
            Merlin123
            oliver@iobrokervm:~$ egrep 'oliver|iobroker' /etc/passwd
            oliver:x:1000:1000:Oliver,,,:/home/oliver:/bin/bash
            iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
            Beta-Tester
              @merlin123
              Okay, da hatte ich eigentlich was anderes erwartet, aber /usr/sbin/nologin stimmt für den iobroker.
              PAM dürfte dann aber eigentlich auch nicht nach einem Passwort für den user fragen.
                @merlin123
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                @thomas-braun ok.... Hätte mich auch gewundert, wenn das nicht gestimmt hätte. Hatte mich an die Anleitung gehalten...
                Und jetzt? Noch eine Idee?
                Beta-Tester
                  @merlin123
                  Ich vermute, rein über die Kommandozeile funktioniert es?
                    @merlin123
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    @thomas-braun jup. Absolut problemlos bisher. 7.0.2 auf 7.0.3 habe ich jetzt natürlich noch nicht gemacht ;)
                    Beta-Tester
                      @merlin123
                      Als Testszenario würde ich mal folgendes probieren:
                      Per Kommandozeile wie üblich upgraden.
                      iob update
                      iob stop
                      iob upgrade self
                      Dann im Log anschauen, wie das abgelaufen ist.
                      Danach dann wieder eine der Vorversionen (7.0.2 z. B.) installieren und dann per GUI updaten. Auch hier wieder in das Log schauen, was da im einzelnen passiert.
                      Log am besten per
                      iob logs --watch
                      in Echtzeit in einem zweiten Terminal beobachten.
                        Merlin123M Offline
                        Merlin123
                        Geht nicht wirklich :(
                        beim Update via Kommandozeile zeigt iob logs nichts an.
                        Im Systemlog steht bei downgrade auf 7.0.2 und anschließendem auto upgrade auf 7.0.3
                        Nov 15 17:30:13 iobrokervm sudo[1357756]:   oliver : TTY=pts/2 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/npm install iobroker.js-controller@7.0.2
                        Nov 15 17:30:13 iobrokervm sudo[1357756]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by oliver(uid=1000)
                        Nov 15 17:30:40 iobrokervm sudo[1357756]: pam_unix(sudo:session): session closed for user iobroker
                        Nov 15 17:30:55 iobrokervm sudo[1357806]:   oliver : TTY=pts/2 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade self
                        Nov 15 17:30:55 iobrokervm sudo[1357806]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by oliver(uid=1000)
                        Wenn ich nachträglich in iob logs schaue ist für die Zeit kein Eintrag drin.
                        Wenn ich das Update aus der GUI starte steht da:
                        2024-11-15 17:42:45.225  - info: host.iobrokervm Controller will upgrade itself to version 7.0.3
                        Beta-Tester
