  4. npm Fehlermeldung
npm Fehlermeldung
npm errinstallinstall adapter update
17 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    MyMeyer
    Hallo ,
    leider kann ich den Adapter "EgiGeoZone2" nicht aktualisieren.
    Siehe Fehlermeldung:
    $ iobroker upgrade egigeozone2@1.0.7 --debug
    Update egigeozone2 from @1.0.6 to @1.0.7
    NPM version: 10.8.2
    Installing iobroker.egigeozone2@1.0.7... (System call)
    npm error code 1npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > @serialport/bindings@9.2.8 installnpm error > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm errornpm errornpm error make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build� wird betretennpm error CXX(target) Release/obj.target/bindings/src/serialport.onpm error make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build� wird verlassen
    npm error npm warn using --force Recommended protections disabled.npm error prebuild-install WARN install No prebuilt binaries found (target=20.18.0 runtime=node arch=x64 libc= platform=linux)npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@10.1.0npm error gyp info using node@20.18.0 | linux | x64npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindings',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error In file included from ../../../nan/nan.h:180,npm error from ../src/./serialport.h:13,npm error from ../src/serialport.cpp:1:npm error ../../../nan/nan_callbacks.h:55:23: error: 'AccessorSignature' is not a member of 'v8'npm error 55 | typedef v8::Localv8::AccessorSignature Sig;npm error | ^~~~~~~~~~~~~~~~~npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalidnpm error 55 | typedef v8::Localv8::AccessorSignature Sig;npm error | ^npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from 'void ()(uv_work_t)' {aka 'void ()(uv_work_s)'} to 'uv_after_work_cb' {aka 'void ()(uv_work_s, int)'} [-Wcast-function-type]npm error 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error ../src/serialport.cpp: At global scope:npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]npm error 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {npm error | ^npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]npm error 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {npm error | ^npm error In file included from ../../../nan/nan.h:60,npm error from ../src/./serialport.h:13,npm error from ../src/serialport.cpp:1:npm error /home/iobroker/.cache/node-gyp/20.18.0/include/node/node.h:1232:7: warning: cast between incompatible function types from 'void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void ()(v8::Localv8::Object)'} to 'node::addon_register_func' {aka 'void ()(v8::Localv8::Object, v8::Localv8::Value, void)'} [-Wcast-function-type]npm error 1232 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /home/iobroker/.cache/node-gyp/20.18.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_X'npm error 1266 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/serialport.cpp:486:1: note: in expansion of macro 'NODE_MODULE'npm error 486 | NODE_MODULE(serialport, init);npm error | ^~~~~~~~~~~npm error make: *** [bindings.target.mk:111: Release/obj.target/bindings/src/serialport.o] Fehler 1npm error gyp ERR! build error npm error gyp ERR! stack Error: make failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 5.10.0-33-amd64npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindingsnpm error gyp ERR! node -v v20.18.0npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not ok npm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneUJsdpa/node_modules/@serialport/bindingsnpm error npm error command failednpm error npm error command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildnpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T08_35_15_677Z-debug-0.lognpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T08_34_58_960Z-debug-0.log
    upload [13] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/egigeozone.png egigeozone.png image/png
    upload [11] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [7] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [6] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [0] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/words.js words.js application/javascript
    Process exited with code 0
    iobroker fix , habe ich bereits laufen lassen. Hat aber nicht gebracht.
    Ich hänge nochmal das Log mit an:
    2024-10-29T20_22_48_970Z-debug-0.log
    MyMeyer
    Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MyMeyer
      Hallo ,
      NPM version: 10.8.2
      @mymeyer
      Da kann serialport nicht gebaut werden.
      Build Environment vorhanden?
      Grundsätzlich ist der Adapter nämlich installierbar:
      $ iobroker add egigeozone2 auto --host chet --debug
      (node:39336) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
      Support for loading ES Module in require() is an experimental feature and might change at any time(Use `node --trace-warnings ...` to show where the warning was created)
      added 1 package in 25s
      215 packages are looking for funding run `npm fund` for details
      host.chet install adapter egigeozone2
      upload [12] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [9] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [5] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [4] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [3] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [2] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] egigeozone2.admin /opt/iobroker/node_modules/iobroker.egigeozone2/admin/jsonConfig.json jsonConfig.json application/json
      Updating objects from io-package.json for adapter "egigeozone2" with version "1.0.7"
      host.chet object system.adapter.egigeozone2.0.connected created
      host.chet object system.adapter.egigeozone2.0.compactMode created
      host.chet object system.adapter.egigeozone2.0.cpu created
      host.chet object system.adapter.egigeozone2.0.cputime created
      host.chet object system.adapter.egigeozone2.0.memHeapUsed created
      host.chet object system.adapter.egigeozone2.0.memHeapTotal created
      host.chet object system.adapter.egigeozone2.0.memRss created
      host.chet object system.adapter.egigeozone2.0.uptime created
      host.chet object system.adapter.egigeozone2.0.inputCount created
      host.chet object system.adapter.egigeozone2.0.outputCount created
      host.chet object system.adapter.egigeozone2.0.sigKill created
      host.chet object system.adapter.egigeozone2.0.logLevel created
      host.chet object egigeozone2.0.info created
      host.chet object egigeozone2.0.info.connection created
      host.chet object egigeozone2.0.atHome created
      host.chet object egigeozone2.0.atHomeCount created
      host.chet Set default value of egigeozone2.0.info.connection: false
      host.chet Set default value of egigeozone2.0.atHome:
      host.chet Set default value of egigeozone2.0.atHomeCount: 0
      host.chet object system.adapter.egigeozone2.0 created
        @mymeyer
        MyMeyer
        @thomas-braun sagte in npm Fehlermeldung:
        Build Environment
        Hi Sorry "Build Environment" sagt mir nichts gerade. Was kann ich wo prüfen ?
        MyMeyer
        • M MyMeyer
          Build Environment
          @mymeyer
          Wie und wo biste denn da unterwegs? Die Ausgabe von
          iob diag
          wäre hilfreich.
          M 2 Antworten Letzte Antwort
            @mymeyer
            iob diag
            wäre hilfreich.
            MyMeyer
            @thomas-braun :-) na dann schaue ich mal. Ähh den "iob diag" kannte ich. ✌
            MyMeyer
              @mymeyer
              iob diag
              wäre hilfreich.
              MyMeyer
              schrieb am zuletzt editiert von MyMeyer
              Hmm...sieht für mich alles normal aus.
              Script v.2024-10-19
              *** BASE SYSTEM ***
                 Static hostname: iobroker
                       Icon name: computer-vm
                         Chassis: vm
                  Virtualization: kvm
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 5.10.0-33-amd64
                    Architecture: x86-64
              OS is similar to:
              model name	: Common KVM processor
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
              CPU threads: 12
              *** LIFE CYCLE STATUS ***
              Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
              *** TIME AND TIMEZONES ***
                             Local time: Sat 2024-11-09 20:18:54 CET
                         Universal time: Sat 2024-11-09 19:18:54 UTC
                               RTC time: Sat 2024-11-09 19:18:55
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              michael
              HOME=/home/michael
              GROUPS=michael cdrom floppy sudo audio dip video plugdev netdev redis iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev redis
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Mem:             15G        4.1G        9.7G        0.0K        2.2G         11G
              Swap:           4.1G          0B        4.1G
              Total:           20G        4.1G         13G
              Active iob-Instances: 	52
                      15996 M total memory
                       4140 M used memory
                       1089 M active memory
                       4554 M inactive memory
                       9699 M free memory
                        481 M buffer memory
                       1674 M swap cache
                       4093 M total swap
                          0 M used swap
                       4093 M free swap
              top - 20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
              Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  2.1 us,  1.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  1.1 st
              MiB Mem :  15996.4 total,   9699.5 free,   4140.7 used,   2156.2 buff/cache
              MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11524.8 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  7.8G     0  7.8G   0% /dev
              tmpfs          tmpfs     1.6G  560K  1.6G   1% /run
              /dev/sda1      ext4       28G   20G  6.6G  75% /
              tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
              [Thu Oct 31 10:35:09 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Oct 31 10:35:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
              Show mounted filesystems:
              TARGET SOURCE    FSTYPE OPTIONS
              /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
              /var:
              2.1G	/var/
              993M	/var/cache
              984M	/var/cache/apt
              934M	/var/log
              915M	/var/cache/apt/archives
                    Users in the 'systemd-journal' group can see all messages. Pass -q to
                    turn off this notice.
              Archived and active journals take up 264.0M in the file system.
              /opt/iobroker/backups:
              84M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.8G	/opt/iobroker/iobroker-data/
              1.2G	/opt/iobroker/iobroker-data/files
              617M	/opt/iobroker/iobroker-data/files/javascript.admin
              560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
              558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
              78M	/opt/iobroker/iobroker-data/objects.jsonl
              51M	/opt/iobroker/iobroker-data/states.json.old
              46M	/opt/iobroker/iobroker-data/objects.json.migrated
              46M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              HINT:
              Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v20.18.0
              /usr/bin/node 		v20.18.0
              /usr/bin/npm 		10.8.2
              /usr/bin/npx 		10.8.2
              /usr/bin/corepack 	0.29.3
              nodejs:
                Installed: 20.18.0-1nodesource1
                Candidate: 20.18.0-1nodesource1
                Version table:
               *** 20.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u5 500
                      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: redis
              Hosts:
              iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 38811)
              iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 812218)
              Core adapters versions
              js-controller: 	6.0.11
              admin: 		7.1.5
              javascript: 	8.8.3
              nodejs modules from github: 	7
              +-- iobroker.blink4home@0.1.1 invalid: "https://github.com/Flashy-GER/ioBroker.blink4home/tarball/37aaf54baf0ac76931d00a71459bcb4e47d96b43" from the root project
              +-- iobroker.broadlink@0.1.5 invalid: "https://github.com/hieblmedia/ioBroker.broadlink/tarball/master" from the root project
              +-- iobroker.fully-tablet-control@0.3.3-beta.0 invalid: "https://github.com/xXBJXx/ioBroker.fully-tablet-control/tarball/e8c40673053e31ce4621d33e3ad38bcaae6b452d" from the root project
              |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
              +-- iobroker.repetierserver@0.0.3 invalid: "https://github.com/Baumert7269/ioBroker.repetierserver/tarball/256b927316a6394475c990026b7ce27c5d32abe8" from the root project
              | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
                  `-- @rjsf/bootstrap-5@4.2.0 invalid: "https://github.com/nurikk/fileshare/blob/main/rjsf-bootstrap-5-4.2.0.tgz?raw=true" from node_modules/zigbee2mqtt-frontend
              Adapter State
              + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.39, run as: admin
              + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
              + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
              + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker-slave                           -  enabled
              + system.adapter.egigeozone2.0            : egigeozone2           : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
              + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
                system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
              + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.2          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
              + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
              + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
              + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.1.39
              + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
              + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
              + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
              + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
              + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.39
              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.1.39, run as: admin
              + system.adapter.smartmeter.0             : smartmeter            : iobroker-slave                           -  enabled
              + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.39
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
              + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
              + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.175:6638
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name               │ url                                                     │ auto upgrade │
              │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
              │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
              Upgrade policy: none
              Installed ioBroker-Instances
              Adapter    "adguard"      : 0.0.8    , installed 0.0.8
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alarm"        : 3.6.2    , installed 3.6.2
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
              Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
              Adapter    "egigeozone2"  : 1.0.7    , installed 1.0.6  [Updatable]
              Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
              Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
              Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "hue"          : 3.12.0   , installed 3.12.0
              Adapter    "ical"         : 1.15.0   , installed 1.15.0
              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
              Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
              Adapter    "icons-material-png": 0.1.0, installed 0.1.0
              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
              Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 6.0.11   , installed 6.0.11
              Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "logparser"    : 2.2.2    , installed 2.2.2
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "nuki"         : 2.0.0    , installed 2.0.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "nut"          : 1.6.0    , installed 1.6.0
              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
              Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
              Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
              Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
              Adapter    "ring"         : 6.2.1    , installed 5.1.0  [Updatable]
              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
              Adapter    "shelly"       : 8.2.1    , installed 8.2.1
              Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
              Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
              Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
              Adapter    "vis-material" : 0.1.3    , installed 0.1.3
              Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
              Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
              Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
              Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
              Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
              Adapter    "wled"         : 0.7.2    , installed 0.7.2
              Adapter    "worx"         : 3.1.0    , installed 3.1.0
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
              Objects and States
              Objects: 	47876
              States: 	41930
              Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
              Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11528      741/sshd: /usr/sbin
              tcp        0      0 192.168.1.39:8087       0.0.0.0:*               LISTEN      1001       22880486   3440656/io.simple-a
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13006      734/exim4
              tcp        0      0 0.0.0.0:1082            0.0.0.0:*               LISTEN      1000       23807780   3845793/nc
              tcp        0      0 192.168.1.39:2010       0.0.0.0:*               LISTEN      1001       22875511   3438603/io.hm-rpc.1
              tcp        0      0 192.168.1.39:1883       0.0.0.0:*               LISTEN      1001       22874812   3438557/io.sonoff.0
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       22870917   3437481/io.mqtt.0
              tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       22870918   3437481/io.mqtt.0
              tcp        0      0 192.168.1.39:1888       0.0.0.0:*               LISTEN      1001       22874750   3437564/io.mqtt.1
              tcp        0      0 192.168.1.39:1889       0.0.0.0:*               LISTEN      1001       22874751   3437564/io.mqtt.1
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22867654   3435624/iobroker.js
              tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        14138      444/redis-server 0.
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13951      1/init
              tcp        0      0 192.168.1.39:2001       0.0.0.0:*               LISTEN      1001       22871328   3436705/io.hm-rpc.0
              tcp        0      0 192.168.1.39:8081       0.0.0.0:*               LISTEN      1001       22870433   3435654/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          11530      741/sshd: /usr/sbin
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13007      734/exim4
              tcp6       0      0 :::7999                 :::*                    LISTEN      1001       22878403   3439671/io.egigeozo
              tcp6       0      0 :::111                  :::*                    LISTEN      0          10224      1/init
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22880563   3440933/io.web.0
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22883504   3441852/io.socketio
              tcp6       0      0 :::51989                :::*                    LISTEN      1001       23790698   3838359/io.nuki-ext
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       22874451   3437357/io.mihome-v
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       22876614   3439250/io.mihome-v
              udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       22874993   3439302/io.mihome-v
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22877109   3441031/io.wled.0
              udp        0      0 192.168.1.39:5353       0.0.0.0:*                           1001       22876423   3438564/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        12925      438/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22875538   3438550/io.shelly.0
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22874839   3438565/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22874840   3438565/io.tuya.0
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       22870612   3436350/io.broadlin
              udp        0      0 0.0.0.0:48705           0.0.0.0:*                           1001       23628756   3436350/io.broadlin
              udp        0      0 0.0.0.0:57115           0.0.0.0:*                           1001       22866935   3436350/io.broadlin
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11336      1/init
              udp        0      0 0.0.0.0:33498           0.0.0.0:*                           107        12927      438/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                107        12926      438/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          1967       1/init
              udp6       0      0 :::42604                :::*                                107        12928      438/avahi-daemon: r
              2024-11-09 20:17:05.010  - info: labcom.0 (3842960) cleaned everything up...
              2024-11-09 20:17:05.015  - info: labcom.0 (3842960) Terminated (NO_ERROR): Without reason
              2024-11-09 20:17:05.527  - info: host.iobroker instance system.adapter.labcom.0 having pid 3842960 terminated with code 0 (NO_ERROR)
              2024-11-09 20:17:14.006  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3842976
              2024-11-09 20:17:14.772  - info: daswetter.0 (3842976) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
              2024-11-09 20:17:19.421  - info: daswetter.0 (3842976) still wrong data structure from server received! repaired...
              2024-11-09 20:17:20.002  - info: ring.0 (3440535) Device 45172445 ("Haustür"): Cronjob Auto save HD Snapshot starts
              2024-11-09 20:17:20.005  - info: ring.0 (3440535) Device 45172445 ("Haustür"): is offline --> won't take HD Snapshot
              2024-11-09 20:17:20.825  - info: daswetter.0 (3842976) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2024-11-09 20:17:21.329  - info: daswetter.0 (3842976) cleaned everything up...
              2024-11-09 20:17:21.336  - info: host.iobroker instance system.adapter.daswetter.0 having pid 3842976 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-11-09 20:18:04.051  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3843922
              2024-11-09 20:18:04.883  - info: labcom.0 (3843922) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
              2024-11-09 20:18:04.891  - info: labcom.0 (3843922) LabCom adapter - started
              2024-11-09 20:18:05.121  - info: labcom.0 (3843922) LabCom adapter - fetching data completed
              2024-11-09 20:18:05.121  - info: labcom.0 (3843922) cleaned everything up...
              2024-11-09 20:18:05.126  - info: labcom.0 (3843922) Terminated (NO_ERROR): Without reason
              2024-11-09 20:18:05.637  - info: host.iobroker instance system.adapter.labcom.0 having pid 3843922 terminated with code 0 (NO_ERROR)
              2024-11-09 20:19:04.006  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3845502
              2024-11-09 20:19:04.901  - info: labcom.0 (3845502) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
              2024-11-09 20:19:04.908  - info: labcom.0 (3845502) LabCom adapter - started
              2024-11-09 20:19:05.147  - info: labcom.0 (3845502) LabCom adapter - fetching data completed
              2024-11-09 20:19:05.147  - info: labcom.0 (3845502) cleaned everything up...
              2024-11-09 20:19:05.152  - info: labcom.0 (3845502) Terminated (NO_ERROR): Without reason
              2024-11-09 20:19:05.662  - info: host.iobroker instance system.adapter.labcom.0 having pid 3845502 terminated with code 0 (NO_ERROR)
              [/s]
              MyMeyer
              • M MyMeyer
                Script v.2024-10-19
                *** BASE SYSTEM ***
                           Chassis: vm
                    Virtualization: kvm
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 12
                              NTP service: active
                          RTC in local TZ: no
                michael
                HOME=/home/michael
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Swap:           4.1G          0B        4.1G
                Total:           20G        4.1G         13G
                         4140 M used memory
                         9699 M free memory
                          481 M buffer memory
                         1674 M swap cache
                         4093 M total swap
                            0 M used swap
                         4093 M free swap
                *** FILESYSTEM ***
                /var:
                2.1G	/var/
                993M	/var/cache
                984M	/var/cache/apt
                934M	/var/log
                USB-Devices by-id:
                HINT:
                tcp
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                Hosts:
                admin: 		7.1.5
                javascript: 	8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	47876
                States: 	41930
                Pending Updates: 0
                [/s]
                @mymeyer
                Sieht für mich nicht normal aus, da fehlt nämlich mindestens 90% der Ausgabe.
                  @mymeyer
                  MyMeyer
                  @thomas-braun Sorry jetzt aber...
                  MyMeyer
                  • M MyMeyer
                    HomoranH Offline
                    HomoranH Offline
                    @mymeyer sagte in npm Fehlermeldung:
                    • M MyMeyer
                      @mymeyer
                      Die ganzen
                      Einträge deuten auf eine verschobene npm-Struktur hin.
                      Installier mal einen der dort genannten Adapter ordentlich, d.h. nicht als GitHub-Installation.
                        MyMeyer
                        @thomas-braun ich habe jetzt mal alle mit Fehler neuinstalliert "nicht über Git". Nun sagt Diag das:
                         2024-11-09 20:41:31.387  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-11-09 20:41:31.387  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                        2024-11-09 20:42:01.669  - info: host.iobroker instance system.adapter.blink4home.0 in version "0.1.1" started with pid 3864381
                        2024-11-09 20:42:02.189  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.blink4home/main.js:24
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		this.log.debug('begin setup adapter');
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		         ^
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'debug')
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
                        2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: Node.js v20.18.0
                        2024-11-09 20:42:02.190  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-11-09 20:42:02.190  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
                        2024-11-09 20:42:04.007  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3864665
                        2024-11-09 20:42:05.124  - info: labcom.0 (3864665) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
                        2024-11-09 20:42:05.132  - info: labcom.0 (3864665) LabCom adapter - started
                        2024-11-09 20:42:05.354  - info: labcom.0 (3864665) LabCom adapter - fetching data completed
                        2024-11-09 20:42:05.355  - info: labcom.0 (3864665) cleaned everything up...
                        2024-11-09 20:42:05.359  - info: labcom.0 (3864665) Terminated (NO_ERROR): Without reason
                        2024-11-09 20:42:05.870  - info: host.iobroker instance system.adapter.labcom.0 having pid 3864665 terminated with code 0 (NO_ERROR)
                        MyMeyer
                          @mymeyer
                          Die ganzen
                          MyMeyer
                          @mymeyer
                          Die ganzen
                          Sach wie kann denn sowas passieren das sich die Struktur verschoben hat ? Habe eigentlich nichts grosses in letzter Zeit gemacht außer die Update. Selbst das deinstallieren von den Adapter geht nicht mehr. Auch manuell nicht.
                          Was kann man jetzt machen ? Neuinstallation ?
                          michael@iobroker:/opt/iobroker$ iob del egigeozone
                          Delete adapter "egigeozone"
                          host.iobroker object egigeozone deleted
                          host.iobroker object egigeozone.admin deleted
                          host.iobroker Deleting 1 object(s).
                          Error deleting adapter egigeozone from disk: Cannot find module 'iobroker.egigeozone/io-package.json'
                          Require stack:
                          - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupInstall.js
                          You might have to delete it yourself!
                          MyMeyer
                          • M MyMeyer
                            @mymeyer
                            Die ganzen
                            Require stack:
                            Durch übermäßige Verwendung von GitHub-Installationen...
                            Wie schaut denn nun
                            cd /opt/iobroker && npm ls
                            aus?
                              Wie schaut denn nun
                              aus?
                              MyMeyer
                              michael@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
                              [sudo] Passwort f�r michael:
                              iobroker.inst@1.1.2 /opt/iobroker
                              +-- @iobroker-javascript.0/country-list-js@npm:country-list-js@3.1.8
                              +-- @iobroker-javascript.0/exec@npm:exec@0.2.1
                              +-- @iobroker-javascript.0/ffmpeg@npm:ffmpeg@0.0.4
                              +-- @iobroker-javascript.0/fs@npm:fs@0.0.1-security
                              +-- @iobroker-javascript.0/node-hue-api@npm:node-hue-api@5.0.0-beta.16
                              +-- @iobroker-javascript.0/require@npm:require@2.4.20
                              +-- @iobroker-javascript.0/simple-ssh@npm:simple-ssh@1.1.1
                              +-- @iobroker-javascript.0/suncalc@npm:suncalc@1.9.0
                              +-- iobroker.adguard@0.0.8
                              +-- iobroker.admin@7.1.5
                              +-- iobroker.alarm@3.6.2
                              +-- iobroker.alexa2@3.26.5
                              +-- iobroker.alias-manager@1.2.6
                              +-- iobroker.apsystems-ecu@0.2.1 invalid: "github:npeter/ioBroker.apsystems-ecu#9d583384f1d72f0147fde2abcd67d4e9281b7347" from the root project
                              +-- iobroker.backitup@3.0.25
                              +-- iobroker.binance@1.1.3 invalid: "github:Kartax/ioBroker.binance#54f362ef6e0775d7cd696a3dff701e2dd6de2404" from the root project
                              +-- iobroker.bosch-ebike@0.1.7 invalid: "github:TA2k/ioBroker.bosch-ebike" from the root project
                              +-- iobroker.broadlink2@2.3.0
                              +-- iobroker.cloud@5.0.1
                              +-- iobroker.daswetter@3.1.16
                              +-- iobroker.egigeozone2@1.0.6
                              +-- iobroker.energiefluss@3.6.1
                              +-- iobroker.feiertage@1.2.0
                              +-- iobroker.flot@1.12.0
                              +-- iobroker.fritzbox@0.6.0
                              +-- iobroker.fullybrowser@3.0.12
                              +-- iobroker.heatingcontrol@2.12.10
                              +-- iobroker.hm-rega@5.1.0
                              +-- iobroker.hm-rpc@2.0.2
                              +-- iobroker.hue@3.12.0
                              +-- iobroker.ical@1.15.0
                              +-- iobroker.icons-addictive-flavour-png@0.1.0
                              +-- iobroker.icons-fatcow-hosting@0.1.0
                              +-- iobroker.icons-icons8@0.0.1
                              +-- iobroker.icons-material-png@0.1.0
                              +-- iobroker.icons-material-svg@0.1.0
                              +-- iobroker.icons-mfd-png@1.2.1
                              +-- iobroker.icons-mfd-svg@1.2.0
                              +-- iobroker.icons-open-icon-library-png@0.1.2
                              +-- iobroker.icons-ultimate-png@1.0.1
                              +-- iobroker.influxdb@4.0.2
                              +-- iobroker.iot@3.3.0
                              +-- iobroker.javascript@8.8.3
                              +-- iobroker.js-controller@6.0.11
                              +-- iobroker.labcom@0.1.4 invalid: "github:100prznt/ioBroker.labcom#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75" from the root project
                              +-- iobroker.landroid@1.0.3
                              +-- iobroker.lgtv11@1.0.5
                              +-- iobroker.life360@0.2.22 invalid: "github:MiGoller/ioBroker.life360#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1" from the root project
                              +-- iobroker.linkeddevices@1.5.5
                              +-- iobroker.linux-control@1.1.5
                              +-- iobroker.logparser@2.2.2
                              +-- iobroker.mihome-vacuum@4.2.0
                              +-- iobroker.mihome@1.4.0
                              +-- iobroker.modbus@6.3.2
                              +-- iobroker.mqtt@6.1.2
                              +-- iobroker.nina@0.0.25
                              +-- iobroker.nuki-extended@2.7.0
                              +-- iobroker.nuki@2.0.0
                              +-- iobroker.nut@1.6.0
                              +-- iobroker.octoprint@5.1.0
                              +-- iobroker.opendtu@2.0.0
                              +-- iobroker.ph803w@1.2.0
                              +-- iobroker.primelab@1.0.2 invalid: "github:Apollon77/iobroker.primelab#95f1af76d05d464b08b8ee3cb40ceb2b20d778d3" from the root project
                              +-- iobroker.pvforecast@3.0.0
                              +-- iobroker.ring@5.1.0
                              +-- iobroker.scenes@3.2.3
                              +-- iobroker.shelly@8.2.1
                              +-- iobroker.shuttercontrol@1.8.3
                              +-- iobroker.simple-api@2.8.0
                              +-- iobroker.smartcontrol@2.0.1
                              +-- iobroker.socketio@6.7.1
                              +-- iobroker.sonoff@3.1.2
                              +-- iobroker.sourceanalytix@0.4.15-alpha.1 invalid: "github:DrozmotiX/ioBroker.sourceanalytix#fd3b7f9f362a348741cbe18d70a130d2bfee6727" from the root project
                              +-- iobroker.synology@3.1.0
                              +-- iobroker.telegram@3.9.0
                              +-- iobroker.terminal@1.0.0
                              +-- iobroker.tr-064@4.3.0
                              +-- iobroker.tuya@3.16.0
                              +-- iobroker.unifi@0.7.0
                              +-- iobroker.vis-bars@0.1.4
                              +-- iobroker.vis-colorpicker@2.0.3
                              +-- iobroker.vis-fancyswitch@1.1.0
                              +-- iobroker.vis-google-fonts@1.0.4
                              +-- iobroker.vis-hqwidgets@1.5.1
                              +-- iobroker.vis-jqui-mfd@1.1.1
                              +-- iobroker.vis-justgage@2.1.0
                              +-- iobroker.vis-map@1.1.2
                              +-- iobroker.vis-material@0.1.3
                              +-- iobroker.vis-materialdesign@0.5.94 invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                              +-- iobroker.vis-metro@1.2.0
                              +-- iobroker.vis-players@0.1.6
                              +-- iobroker.vis-plumb@1.0.2
                              +-- iobroker.vis-rgraph@0.0.2
                              +-- iobroker.vis-timeandweather@1.2.2
                              +-- iobroker.vis@1.5.6
                              +-- iobroker.wallpanel@0.3.11
                              +-- iobroker.weatherunderground@3.7.0
                              +-- iobroker.web@6.2.5
                              +-- iobroker.wireguard@1.7.0
                              +-- iobroker.wled@0.7.2
                              +-- iobroker.worx@3.1.0 invalid: "github:iobroker-community-adapters/ioBroker.worx" from the root project
                              +-- iobroker.ws@2.6.2
                              +-- iobroker.zigbee@1.10.10 invalid: "github:ioBroker/ioBroker.zigbee#fedc314a875044c84ff790a19dfd42d7373bb61e" from the root project
                              `-- zigbee2mqtt@1.27.0 invalid: "github:Koenkk/zigbee2mqtt#a9b8808237554316c5c97e9d9c990048733779e8" from the root project
                              npm error code ELSPROBLEMS
                              npm error invalid: iobroker.apsystems-ecu@0.2.1 /opt/iobroker/node_modules/iobroker.apsystems-ecu
                              npm error invalid: iobroker.binance@1.1.3 /opt/iobroker/node_modules/iobroker.binance
                              npm error invalid: iobroker.blink4home@0.1.1 /opt/iobroker/node_modules/iobroker.blink4home
                              npm error invalid: iobroker.bosch-ebike@0.1.7 /opt/iobroker/node_modules/iobroker.bosch-ebike
                              npm error invalid: iobroker.broadlink@0.1.5 /opt/iobroker/node_modules/iobroker.broadlink
                              npm error invalid: iobroker.fully-tablet-control@0.3.3-beta.0 /opt/iobroker/node_modules/iobroker.fully-tablet-control
                              npm error invalid: iobroker.labcom@0.1.4 /opt/iobroker/node_modules/iobroker.labcom
                              npm error invalid: iobroker.life360@0.2.22 /opt/iobroker/node_modules/iobroker.life360
                              npm error invalid: iobroker.primelab@1.0.2 /opt/iobroker/node_modules/iobroker.primelab
                              npm error invalid: iobroker.repetierserver@0.0.3 /opt/iobroker/node_modules/iobroker.repetierserver
                              npm error invalid: iobroker.sourceanalytix@0.4.15-alpha.1 /opt/iobroker/node_modules/iobroker.sourceanalytix
                              npm error invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                              npm error invalid: iobroker.worx@3.1.0 /opt/iobroker/node_modules/iobroker.worx
                              npm error invalid: iobroker.zigbee@1.10.10 /opt/iobroker/node_modules/iobroker.zigbee
                              npm error invalid: zigbee2mqtt@1.27.0 /opt/iobroker/node_modules/zigbee2mqtt
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T20_47_47_845Z-debug-0.log
                              MyMeyer
                              • M MyMeyer
                                @mymeyer
                                Joh...
                                Siehste selber, oder?
                                Installier alle Adapter bei denen das möglich ist eine Version aus einem Repo, NICHT aus GitHub.
                                Warum haste da eigentlich so viel Alpha-Versions-Zeuch drin? Hast du das alles vom Maintainer zum testen gegeben bekommen? Wenn nein, fahr da stabile Versionen.
                                  @mymeyer
                                  Joh...
                                  MyMeyer
                                  Kann ich dir gar nicht sagen. Habe vor 3 -4 Jahren angefangen mit iob. Da versucht man schon einiges :-) Ich werde mir mal die Tage gedanken machen wie ich die Sache angehe.
                                  Vielleicht einfach mal bei NULL anfangen und das rüber holen was so geht.
                                  Danke Dir erstmal und schönen Abend noch...
                                  MyMeyer
                                  • M MyMeyer
                                    @mymeyer
                                    Sauber muss das so aussehen:
                                    echad@chet:~ $ cd /opt/iobroker/ && npm ls
                                    (node:50931) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    ├── iobroker.admin@7.2.6
                                    ├── iobroker.alexa2@3.26.7
                                    ├── iobroker.alias-manager@2.0.0
                                    ├── iobroker.awtrix-light@1.3.0
                                    ├── iobroker.backitup@3.0.26
                                    ├── iobroker.cloud@5.0.1
                                    ├── iobroker.devices@1.1.5
                                    ├── iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
                                    ├── iobroker.echarts@1.9.2
                                    ├── iobroker.firetv@2.1.0
                                    ├── iobroker.followthesun@0.5.1
                                    ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                                    ├── iobroker.govee-local@0.2.7
                                    ├── iobroker.history@3.0.1
                                    ├── iobroker.ical@1.16.1
                                    ├── iobroker.iceroad@1.2.1
                                    ├── iobroker.iot@3.4.3
                                    ├── iobroker.javascript@8.8.3
                                    ├── iobroker.js-controller@7.0.2
                                    ├── iobroker.kisshome-research@1.1.1
                                    ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                                    ├── iobroker.mihome-cloud@0.1.1
                                    ├── iobroker.mihome-vacuum@4.2.0
                                    ├── iobroker.mihome@1.4.0
                                    ├── iobroker.mqtt@6.1.2
                                    ├── iobroker.nina@0.0.26
                                    ├── iobroker.notification-manager@1.3.0
                                    ├── iobroker.nuki-extended@2.7.0
                                    ├── iobroker.nuki@2.0.0
                                    ├── iobroker.nut@1.6.0
                                    ├── iobroker.opendtu@3.0.1
                                    ├── iobroker.openweathermap@1.1.2
                                    ├── iobroker.parcel@0.2.8
                                    ├── iobroker.sainlogic@0.11.4
                                    ├── iobroker.samsung_tizen@1.1.0
                                    ├── iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
                                    ├── iobroker.simple-api@2.8.0
                                    ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                                    ├── iobroker.tado@0.6.1
                                    ├── iobroker.tankerkoenig@3.4.0
                                    ├── iobroker.tr-064@4.3.0
                                    ├── iobroker.tradfri@3.1.3
                                    ├── iobroker.trashschedule@3.4.0
                                    ├── iobroker.tuya@3.16.0
                                    ├── iobroker.weather-warnings@0.6.7
                                    ├── iobroker.web@6.3.1
                                    ├── iobroker.whatsapp-cmb@0.3.0
                                    └── iobroker.zigbee@1.10.12
                                    echad@chet:/opt/iobroker $
                                    Adapter aus dem GitHub sind nicht invalid und es gibt lediglich Einträge in der Form iobroker.adaptername@1.2.3
