  4. npm Fehlermeldung
npm Fehlermeldung
npm errinstallinstall adapter update
17 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • M MyMeyer
    Hmm...sieht für mich alles normal aus.
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-33-amd64
          Architecture: x86-64
    OS is similar to:
    model name	: Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
    CPU threads: 12
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2024-11-09 20:18:54 CET
               Universal time: Sat 2024-11-09 19:18:54 UTC
                     RTC time: Sat 2024-11-09 19:18:55
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael cdrom floppy sudo audio dip video plugdev netdev redis iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:             15G        4.1G        9.7G        0.0K        2.2G         11G
    Swap:           4.1G          0B        4.1G
    Total:           20G        4.1G         13G
    Active iob-Instances: 	52
            15996 M total memory
             4140 M used memory
             1089 M active memory
             4554 M inactive memory
             9699 M free memory
              481 M buffer memory
             1674 M swap cache
             4093 M total swap
                0 M used swap
             4093 M free swap
    top - 20:18:54 up 9 days,  9:43,  0 users,  load average: 0.25, 0.34, 0.34
    Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.1 us,  1.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  1.1 st
    MiB Mem :  15996.4 total,   9699.5 free,   4140.7 used,   2156.2 buff/cache
    MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11524.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  560K  1.6G   1% /run
    /dev/sda1      ext4       28G   20G  6.6G  75% /
    tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Thu Oct 31 10:35:09 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Oct 31 10:35:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.1G	/var/
    993M	/var/cache
    984M	/var/cache/apt
    934M	/var/log
    915M	/var/cache/apt/archives
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 264.0M in the file system.
    /opt/iobroker/backups:
    84M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G	/opt/iobroker/iobroker-data/
    1.2G	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    78M	/opt/iobroker/iobroker-data/objects.jsonl
    51M	/opt/iobroker/iobroker-data/states.json.old
    46M	/opt/iobroker/iobroker-data/objects.json.migrated
    46M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.0
    /usr/bin/node 		v20.18.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 38811)
    iobroker-slave      iobroker-slave (version: 6.0.11, hostname: iobroker-slave, alive, uptime: 812218)
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	7
    +-- iobroker.blink4home@0.1.1 invalid: "https://github.com/Flashy-GER/ioBroker.blink4home/tarball/37aaf54baf0ac76931d00a71459bcb4e47d96b43" from the root project
    +-- iobroker.broadlink@0.1.5 invalid: "https://github.com/hieblmedia/ioBroker.broadlink/tarball/master" from the root project
    +-- iobroker.fully-tablet-control@0.3.3-beta.0 invalid: "https://github.com/xXBJXx/ioBroker.fully-tablet-control/tarball/e8c40673053e31ce4621d33e3ad38bcaae6b452d" from the root project
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    +-- iobroker.repetierserver@0.0.3 invalid: "https://github.com/Baumert7269/ioBroker.repetierserver/tarball/256b927316a6394475c990026b7ce27c5d32abe8" from the root project
    | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
        `-- @rjsf/bootstrap-5@4.2.0 invalid: "https://github.com/nurikk/fileshare/blob/main/rjsf-bootstrap-5-4.2.0.tgz?raw=true" from node_modules/zigbee2mqtt-frontend
    Adapter State
    + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.39, run as: admin
    + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-slave                           -  enabled
    + system.adapter.egigeozone2.0            : egigeozone2           : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.labcom.0                 : labcom                : iobroker                                 -  enabled
      system.adapter.lgtv11.0                 : lgtv11                : iobroker                                 - disabled, port: 8080
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.2          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 192.168.1.39
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
      system.adapter.ph803w.0                 : ph803w                : iobroker                                 - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.39
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.1.39, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker-slave                           -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.39
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.175:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alarm"        : 3.6.2    , installed 3.6.2
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
    Adapter    "egigeozone2"  : 1.0.7    , installed 1.0.6  [Updatable]
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "heatingcontrol": 2.12.10 , installed 2.12.10
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
    Adapter    "ring"         : 6.2.1    , installed 5.1.0  [Updatable]
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "worx"         : 3.1.0    , installed 3.1.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
    Objects and States
    Objects: 	47876
    States: 	41930
    Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://ftp.de.debian.org/debian bullseye InRelease
    Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11528      741/sshd: /usr/sbin
    tcp        0      0 192.168.1.39:8087       0.0.0.0:*               LISTEN      1001       22880486   3440656/io.simple-a
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13006      734/exim4
    tcp        0      0 0.0.0.0:1082            0.0.0.0:*               LISTEN      1000       23807780   3845793/nc
    tcp        0      0 192.168.1.39:2010       0.0.0.0:*               LISTEN      1001       22875511   3438603/io.hm-rpc.1
    tcp        0      0 192.168.1.39:1883       0.0.0.0:*               LISTEN      1001       22874812   3438557/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       22870917   3437481/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       22870918   3437481/io.mqtt.0
    tcp        0      0 192.168.1.39:1888       0.0.0.0:*               LISTEN      1001       22874750   3437564/io.mqtt.1
    tcp        0      0 192.168.1.39:1889       0.0.0.0:*               LISTEN      1001       22874751   3437564/io.mqtt.1
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22867654   3435624/iobroker.js
    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        14138      444/redis-server 0.
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13951      1/init
    tcp        0      0 192.168.1.39:2001       0.0.0.0:*               LISTEN      1001       22871328   3436705/io.hm-rpc.0
    tcp        0      0 192.168.1.39:8081       0.0.0.0:*               LISTEN      1001       22870433   3435654/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11530      741/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13007      734/exim4
    tcp6       0      0 :::7999                 :::*                    LISTEN      1001       22878403   3439671/io.egigeozo
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10224      1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22880563   3440933/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22883504   3441852/io.socketio
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       23790698   3838359/io.nuki-ext
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       22874451   3437357/io.mihome-v
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       22876614   3439250/io.mihome-v
    udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       22874993   3439302/io.mihome-v
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22877109   3441031/io.wled.0
    udp        0      0 192.168.1.39:5353       0.0.0.0:*                           1001       22876423   3438564/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        12925      438/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22875538   3438550/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22874839   3438565/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22874840   3438565/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       22870612   3436350/io.broadlin
    udp        0      0 0.0.0.0:48705           0.0.0.0:*                           1001       23628756   3436350/io.broadlin
    udp        0      0 0.0.0.0:57115           0.0.0.0:*                           1001       22866935   3436350/io.broadlin
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11336      1/init
    udp        0      0 0.0.0.0:33498           0.0.0.0:*                           107        12927      438/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                107        12926      438/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1967       1/init
    udp6       0      0 :::42604                :::*                                107        12928      438/avahi-daemon: r
    2024-11-09 20:17:05.010  - info: labcom.0 (3842960) cleaned everything up...
    2024-11-09 20:17:05.015  - info: labcom.0 (3842960) Terminated (NO_ERROR): Without reason
    2024-11-09 20:17:05.527  - info: host.iobroker instance system.adapter.labcom.0 having pid 3842960 terminated with code 0 (NO_ERROR)
    2024-11-09 20:17:14.006  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 3842976
    2024-11-09 20:17:14.772  - info: daswetter.0 (3842976) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 6.0.11
    2024-11-09 20:17:19.421  - info: daswetter.0 (3842976) still wrong data structure from server received! repaired...
    2024-11-09 20:17:20.002  - info: ring.0 (3440535) Device 45172445 ("Haustür"): Cronjob Auto save HD Snapshot starts
    2024-11-09 20:17:20.005  - info: ring.0 (3440535) Device 45172445 ("Haustür"): is offline --> won't take HD Snapshot
    2024-11-09 20:17:20.825  - info: daswetter.0 (3842976) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-11-09 20:17:21.329  - info: daswetter.0 (3842976) cleaned everything up...
    2024-11-09 20:17:21.336  - info: host.iobroker instance system.adapter.daswetter.0 having pid 3842976 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-09 20:18:04.051  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3843922
    2024-11-09 20:18:04.883  - info: labcom.0 (3843922) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
    2024-11-09 20:18:04.891  - info: labcom.0 (3843922) LabCom adapter - started
    2024-11-09 20:18:05.121  - info: labcom.0 (3843922) LabCom adapter - fetching data completed
    2024-11-09 20:18:05.121  - info: labcom.0 (3843922) cleaned everything up...
    2024-11-09 20:18:05.126  - info: labcom.0 (3843922) Terminated (NO_ERROR): Without reason
    2024-11-09 20:18:05.637  - info: host.iobroker instance system.adapter.labcom.0 having pid 3843922 terminated with code 0 (NO_ERROR)
    2024-11-09 20:19:04.006  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3845502
    2024-11-09 20:19:04.901  - info: labcom.0 (3845502) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
    2024-11-09 20:19:04.908  - info: labcom.0 (3845502) LabCom adapter - started
    2024-11-09 20:19:05.147  - info: labcom.0 (3845502) LabCom adapter - fetching data completed
    2024-11-09 20:19:05.147  - info: labcom.0 (3845502) cleaned everything up...
    2024-11-09 20:19:05.152  - info: labcom.0 (3845502) Terminated (NO_ERROR): Without reason
    2024-11-09 20:19:05.662  - info: host.iobroker instance system.adapter.labcom.0 having pid 3845502 terminated with code 0 (NO_ERROR)
    [/s]
    @mymeyer
    Sieht für mich nicht normal aus, da fehlt nämlich mindestens 90% der Ausgabe.
      @mymeyer
      MyMeyer
      @thomas-braun Sorry jetzt aber...
      MyMeyer
      Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
      HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
      • M MyMeyer
        @mymeyer sagte in npm Fehlermeldung:
        • M MyMeyer
          @mymeyer
          Die ganzen
          Einträge deuten auf eine verschobene npm-Struktur hin.
          Installier mal einen der dort genannten Adapter ordentlich, d.h. nicht als GitHub-Installation.
            MyMeyer
            @thomas-braun ich habe jetzt mal alle mit Fehler neuinstalliert "nicht über Git". Nun sagt Diag das:
             2024-11-09 20:41:31.387  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-11-09 20:41:31.387  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
            2024-11-09 20:42:01.669  - info: host.iobroker instance system.adapter.blink4home.0 in version "0.1.1" started with pid 3864381
            2024-11-09 20:42:02.189  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.blink4home/main.js:24
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		this.log.debug('begin setup adapter');
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: 		         ^
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'debug')
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at new Blink4home (/opt/iobroker/node_modules/iobroker.blink4home/main.js:24:12)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.blink4home/main.js:235:2)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
            2024-11-09 20:42:02.190  - error: host.iobroker Caught by controller[0]: Node.js v20.18.0
            2024-11-09 20:42:02.190  - error: host.iobroker instance system.adapter.blink4home.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-11-09 20:42:02.190  - info: host.iobroker Restart adapter system.adapter.blink4home.0 because enabled
            2024-11-09 20:42:04.007  - info: host.iobroker instance system.adapter.labcom.0 in version "0.1.4" started with pid 3864665
            2024-11-09 20:42:05.124  - info: labcom.0 (3864665) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.labcom, node: v20.18.0, js-controller: 6.0.11
            2024-11-09 20:42:05.132  - info: labcom.0 (3864665) LabCom adapter - started
            2024-11-09 20:42:05.354  - info: labcom.0 (3864665) LabCom adapter - fetching data completed
            2024-11-09 20:42:05.355  - info: labcom.0 (3864665) cleaned everything up...
            2024-11-09 20:42:05.359  - info: labcom.0 (3864665) Terminated (NO_ERROR): Without reason
            2024-11-09 20:42:05.870  - info: host.iobroker instance system.adapter.labcom.0 having pid 3864665 terminated with code 0 (NO_ERROR)
            MyMeyer
              @mymeyer
              Die ganzen
              MyMeyer
              @thomas-braun sagte in npm Fehlermeldung:
              @mymeyer
              Die ganzen
              Sach wie kann denn sowas passieren das sich die Struktur verschoben hat ? Habe eigentlich nichts grosses in letzter Zeit gemacht außer die Update. Selbst das deinstallieren von den Adapter geht nicht mehr. Auch manuell nicht.
              Was kann man jetzt machen ? Neuinstallation ?
              michael@iobroker:/opt/iobroker$ iob del egigeozone
              Delete adapter "egigeozone"
              host.iobroker object egigeozone deleted
              host.iobroker object egigeozone.admin deleted
              host.iobroker Deleting 1 object(s).
              Error deleting adapter egigeozone from disk: Cannot find module 'iobroker.egigeozone/io-package.json'
              Require stack:
              - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupInstall.js
              You might have to delete it yourself!
              MyMeyer
              • M MyMeyer
                @mymeyer
                Die ganzen
                Require stack:
                Durch übermäßige Verwendung von GitHub-Installationen...
                Wie schaut denn nun
                cd /opt/iobroker && npm ls
                aus?
                  Wie schaut denn nun
                  aus?
                  MyMeyer
                  michael@iobroker:/opt/iobroker$ cd /opt/iobroker && npm ls
                  [sudo] Passwort f�r michael:
                  iobroker.inst@1.1.2 /opt/iobroker
                  +-- @iobroker-javascript.0/country-list-js@npm:country-list-js@3.1.8
                  +-- @iobroker-javascript.0/exec@npm:exec@0.2.1
                  +-- @iobroker-javascript.0/ffmpeg@npm:ffmpeg@0.0.4
                  +-- @iobroker-javascript.0/fs@npm:fs@0.0.1-security
                  +-- @iobroker-javascript.0/node-hue-api@npm:node-hue-api@5.0.0-beta.16
                  +-- @iobroker-javascript.0/require@npm:require@2.4.20
                  +-- @iobroker-javascript.0/simple-ssh@npm:simple-ssh@1.1.1
                  +-- @iobroker-javascript.0/suncalc@npm:suncalc@1.9.0
                  +-- iobroker.adguard@0.0.8
                  +-- iobroker.admin@7.1.5
                  +-- iobroker.alarm@3.6.2
                  +-- iobroker.alexa2@3.26.5
                  +-- iobroker.alias-manager@1.2.6
                  +-- iobroker.apsystems-ecu@0.2.1 invalid: "github:npeter/ioBroker.apsystems-ecu#9d583384f1d72f0147fde2abcd67d4e9281b7347" from the root project
                  +-- iobroker.backitup@3.0.25
                  +-- iobroker.binance@1.1.3 invalid: "github:Kartax/ioBroker.binance#54f362ef6e0775d7cd696a3dff701e2dd6de2404" from the root project
                  +-- iobroker.bosch-ebike@0.1.7 invalid: "github:TA2k/ioBroker.bosch-ebike" from the root project
                  +-- iobroker.broadlink2@2.3.0
                  +-- iobroker.cloud@5.0.1
                  +-- iobroker.daswetter@3.1.16
                  +-- iobroker.egigeozone2@1.0.6
                  +-- iobroker.energiefluss@3.6.1
                  +-- iobroker.feiertage@1.2.0
                  +-- iobroker.flot@1.12.0
                  +-- iobroker.fritzbox@0.6.0
                  +-- iobroker.fullybrowser@3.0.12
                  +-- iobroker.heatingcontrol@2.12.10
                  +-- iobroker.hm-rega@5.1.0
                  +-- iobroker.hm-rpc@2.0.2
                  +-- iobroker.hue@3.12.0
                  +-- iobroker.ical@1.15.0
                  +-- iobroker.icons-addictive-flavour-png@0.1.0
                  +-- iobroker.icons-fatcow-hosting@0.1.0
                  +-- iobroker.icons-icons8@0.0.1
                  +-- iobroker.icons-material-png@0.1.0
                  +-- iobroker.icons-material-svg@0.1.0
                  +-- iobroker.icons-mfd-png@1.2.1
                  +-- iobroker.icons-mfd-svg@1.2.0
                  +-- iobroker.icons-open-icon-library-png@0.1.2
                  +-- iobroker.icons-ultimate-png@1.0.1
                  +-- iobroker.influxdb@4.0.2
                  +-- iobroker.iot@3.3.0
                  +-- iobroker.javascript@8.8.3
                  +-- iobroker.js-controller@6.0.11
                  +-- iobroker.labcom@0.1.4 invalid: "github:100prznt/ioBroker.labcom#2cbc14b6c33d01fcc29003e3648fcb0c4d917f75" from the root project
                  +-- iobroker.landroid@1.0.3
                  +-- iobroker.lgtv11@1.0.5
                  +-- iobroker.life360@0.2.22 invalid: "github:MiGoller/ioBroker.life360#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1" from the root project
                  +-- iobroker.linkeddevices@1.5.5
                  +-- iobroker.linux-control@1.1.5
                  +-- iobroker.logparser@2.2.2
                  +-- iobroker.mihome-vacuum@4.2.0
                  +-- iobroker.mihome@1.4.0
                  +-- iobroker.modbus@6.3.2
                  +-- iobroker.mqtt@6.1.2
                  +-- iobroker.nina@0.0.25
                  +-- iobroker.nuki-extended@2.7.0
                  +-- iobroker.nuki@2.0.0
                  +-- iobroker.nut@1.6.0
                  +-- iobroker.octoprint@5.1.0
                  +-- iobroker.opendtu@2.0.0
                  +-- iobroker.ph803w@1.2.0
                  +-- iobroker.primelab@1.0.2 invalid: "github:Apollon77/iobroker.primelab#95f1af76d05d464b08b8ee3cb40ceb2b20d778d3" from the root project
                  +-- iobroker.pvforecast@3.0.0
                  +-- iobroker.ring@5.1.0
                  +-- iobroker.scenes@3.2.3
                  +-- iobroker.shelly@8.2.1
                  +-- iobroker.shuttercontrol@1.8.3
                  +-- iobroker.simple-api@2.8.0
                  +-- iobroker.smartcontrol@2.0.1
                  +-- iobroker.socketio@6.7.1
                  +-- iobroker.sonoff@3.1.2
                  +-- iobroker.sourceanalytix@0.4.15-alpha.1 invalid: "github:DrozmotiX/ioBroker.sourceanalytix#fd3b7f9f362a348741cbe18d70a130d2bfee6727" from the root project
                  +-- iobroker.synology@3.1.0
                  +-- iobroker.telegram@3.9.0
                  +-- iobroker.terminal@1.0.0
                  +-- iobroker.tr-064@4.3.0
                  +-- iobroker.tuya@3.16.0
                  +-- iobroker.unifi@0.7.0
                  +-- iobroker.vis-bars@0.1.4
                  +-- iobroker.vis-colorpicker@2.0.3
                  +-- iobroker.vis-fancyswitch@1.1.0
                  +-- iobroker.vis-google-fonts@1.0.4
                  +-- iobroker.vis-hqwidgets@1.5.1
                  +-- iobroker.vis-jqui-mfd@1.1.1
                  +-- iobroker.vis-justgage@2.1.0
                  +-- iobroker.vis-map@1.1.2
                  +-- iobroker.vis-material@0.1.3
                  +-- iobroker.vis-materialdesign@0.5.94 invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                  +-- iobroker.vis-metro@1.2.0
                  +-- iobroker.vis-players@0.1.6
                  +-- iobroker.vis-plumb@1.0.2
                  +-- iobroker.vis-rgraph@0.0.2
                  +-- iobroker.vis-timeandweather@1.2.2
                  +-- iobroker.vis@1.5.6
                  +-- iobroker.wallpanel@0.3.11
                  +-- iobroker.weatherunderground@3.7.0
                  +-- iobroker.web@6.2.5
                  +-- iobroker.wireguard@1.7.0
                  +-- iobroker.wled@0.7.2
                  +-- iobroker.worx@3.1.0 invalid: "github:iobroker-community-adapters/ioBroker.worx" from the root project
                  +-- iobroker.ws@2.6.2
                  +-- iobroker.zigbee@1.10.10 invalid: "github:ioBroker/ioBroker.zigbee#fedc314a875044c84ff790a19dfd42d7373bb61e" from the root project
                  `-- zigbee2mqtt@1.27.0 invalid: "github:Koenkk/zigbee2mqtt#a9b8808237554316c5c97e9d9c990048733779e8" from the root project
                  npm error code ELSPROBLEMS
                  npm error invalid: iobroker.apsystems-ecu@0.2.1 /opt/iobroker/node_modules/iobroker.apsystems-ecu
                  npm error invalid: iobroker.binance@1.1.3 /opt/iobroker/node_modules/iobroker.binance
                  npm error invalid: iobroker.blink4home@0.1.1 /opt/iobroker/node_modules/iobroker.blink4home
                  npm error invalid: iobroker.bosch-ebike@0.1.7 /opt/iobroker/node_modules/iobroker.bosch-ebike
                  npm error invalid: iobroker.broadlink@0.1.5 /opt/iobroker/node_modules/iobroker.broadlink
                  npm error invalid: iobroker.fully-tablet-control@0.3.3-beta.0 /opt/iobroker/node_modules/iobroker.fully-tablet-control
                  npm error invalid: iobroker.labcom@0.1.4 /opt/iobroker/node_modules/iobroker.labcom
                  npm error invalid: iobroker.life360@0.2.22 /opt/iobroker/node_modules/iobroker.life360
                  npm error invalid: iobroker.primelab@1.0.2 /opt/iobroker/node_modules/iobroker.primelab
                  npm error invalid: iobroker.repetierserver@0.0.3 /opt/iobroker/node_modules/iobroker.repetierserver
                  npm error invalid: iobroker.sourceanalytix@0.4.15-alpha.1 /opt/iobroker/node_modules/iobroker.sourceanalytix
                  npm error invalid: iobroker.vis-materialdesign@0.5.94 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                  npm error invalid: iobroker.worx@3.1.0 /opt/iobroker/node_modules/iobroker.worx
                  npm error invalid: iobroker.zigbee@1.10.10 /opt/iobroker/node_modules/iobroker.zigbee
                  npm error invalid: zigbee2mqtt@1.27.0 /opt/iobroker/node_modules/zigbee2mqtt
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-09T20_47_47_845Z-debug-0.log
                  MyMeyer
                  • M MyMeyer
                    @mymeyer
                    Joh...
                    Siehste selber, oder?
                    Installier alle Adapter bei denen das möglich ist eine Version aus einem Repo, NICHT aus GitHub.
                    Warum haste da eigentlich so viel Alpha-Versions-Zeuch drin? Hast du das alles vom Maintainer zum testen gegeben bekommen? Wenn nein, fahr da stabile Versionen.
                      @mymeyer
                      Joh...
                      MyMeyer
                      Kann ich dir gar nicht sagen. Habe vor 3 -4 Jahren angefangen mit iob. Da versucht man schon einiges :-) Ich werde mir mal die Tage gedanken machen wie ich die Sache angehe.
                      Vielleicht einfach mal bei NULL anfangen und das rüber holen was so geht.
                      Danke Dir erstmal und schönen Abend noch...
                      MyMeyer
                      • M MyMeyer
                        @mymeyer
                        Sauber muss das so aussehen:
                        echad@chet:~ $ cd /opt/iobroker/ && npm ls
                        (node:50931) ExperimentalWarning: CommonJS module /usr/lib/node_modules/npm/node_modules/debug/src/node.js is loading ES Module /usr/lib/node_modules/npm/node_modules/supports-color/index.js using require().
                        Support for loading ES Module in require() is an experimental feature and might change at any time
                        (Use `node --trace-warnings ...` to show where the warning was created)
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├── iobroker.admin@7.2.6
                        ├── iobroker.alexa2@3.26.7
                        ├── iobroker.alias-manager@2.0.0
                        ├── iobroker.awtrix-light@1.3.0
                        ├── iobroker.backitup@3.0.26
                        ├── iobroker.cloud@5.0.1
                        ├── iobroker.devices@1.1.5
                        ├── iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
                        ├── iobroker.echarts@1.9.2
                        ├── iobroker.firetv@2.1.0
                        ├── iobroker.followthesun@0.5.1
                        ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
                        ├── iobroker.govee-local@0.2.7
                        ├── iobroker.history@3.0.1
                        ├── iobroker.ical@1.16.1
                        ├── iobroker.iceroad@1.2.1
                        ├── iobroker.iot@3.4.3
                        ├── iobroker.javascript@8.8.3
                        ├── iobroker.js-controller@7.0.2
                        ├── iobroker.kisshome-research@1.1.1
                        ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                        ├── iobroker.mihome-cloud@0.1.1
                        ├── iobroker.mihome-vacuum@4.2.0
                        ├── iobroker.mihome@1.4.0
                        ├── iobroker.mqtt@6.1.2
                        ├── iobroker.nina@0.0.26
                        ├── iobroker.notification-manager@1.3.0
                        ├── iobroker.nuki-extended@2.7.0
                        ├── iobroker.nuki@2.0.0
                        ├── iobroker.nut@1.6.0
                        ├── iobroker.opendtu@3.0.1
                        ├── iobroker.openweathermap@1.1.2
                        ├── iobroker.parcel@0.2.8
                        ├── iobroker.sainlogic@0.11.4
                        ├── iobroker.samsung_tizen@1.1.0
                        ├── iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
                        ├── iobroker.simple-api@2.8.0
                        ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                        ├── iobroker.tado@0.6.1
                        ├── iobroker.tankerkoenig@3.4.0
                        ├── iobroker.tr-064@4.3.0
                        ├── iobroker.tradfri@3.1.3
                        ├── iobroker.trashschedule@3.4.0
                        ├── iobroker.tuya@3.16.0
                        ├── iobroker.weather-warnings@0.6.7
                        ├── iobroker.web@6.3.1
                        ├── iobroker.whatsapp-cmb@0.3.0
                        └── iobroker.zigbee@1.10.12
                        echad@chet:/opt/iobroker $
                        Adapter aus dem GitHub sind nicht invalid und es gibt lediglich Einträge in der Form iobroker.adaptername@1.2.3
