  4. Test Adapter EnOcean v0.3.x
    6.4k
enocean
265 Beiträge 31 Kommentatoren 88.9k Aufrufe 12 Beobachtet
  • Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    #141
    Welche Version des Admin Adapters hast du?
    Admin v2 wird nicht mehr Unterstützt.
    Gesendet von meinem m8 mit Tapatalk
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
      Rhaegar
      #142
      Vielen Dank für die Antwort.
      Das hatte ich schon probiert, ändert leider aber nichts an dem Problem.
      Hier die Ausgabe des Konsolenaufrufs:
      got /opt/iobroker/node_modules/iobroker.enocean/admin
      upload [14] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
      upload [13] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
      upload [12] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/img/readyOn.png img/readyOn.png image/png
      upload [11] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/img/ready.png img/ready.png image/png
      upload [10] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/img/delete.png img/delete.png image/png
      upload [9] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/img/add.png img/add.png image/png
      upload [8] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/EnOcean.png EnOcean.png image/png
      Gibt es weitere Dinge, die ich prüfen / probieren kann?
      • Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        #143
        @Rhaegar:
        Gibt es weitere Dinge, die ich prüfen / probieren kann? `
        @Jey Cee:
        Admin v2 wird nicht mehr Unterstützt. `
          Rhaegar
          #144
          Okay, super, das klappt schon mal. Es war noch default, nutze jetzt latest. Habe alle Updates gemacht und das Enocean-Modul neu installiert. Jetzt wird mir die Konfigurationsseite angezeigt. :)
          Mir ist noch nicht ganz klar, wie ich jetzt ein Gerät anlernen kann. In dem Screenshot auf der ersten Seite gab es noch einen Haken für den Anlernmodus. Wie starte ich ihn jetzt, bzw. wie gehe ich hier konkret vor?
          Oder muss ich das Gerät händisch über "Geräte –> Gerät hinzufügen" selbst hinzufügen?
          Ich möchte einen Eltako Fensterkontakt Typ TF-FKE einbinden.
          Ich habe mal die Instanz neu geladen und dann innerhalb von 60 Sekunden den Fensterkontakt ausgelöst, aber dadurch ist kein Gerät erschienen.
          Bin wie gesagt neu bei iobroker, manche Dinge sind vielleicht selbstverständlich, für mich allerdings nicht. ;)
          • Jey CeeJ Offline
            Jey CeeJ Offline
            Jey Cee
            #145
            Automatische Erkennung gibt es derzeit nicht. Das Problem ist nämlich das Profile gibt sogenannte EEP's die im enocean standard definiert sind. Es möglich das Geräte mehrere EEP's haben und dann ist keine eindeutige Erkennung möglich.
            Das heisst du musst die ID deines Geräts kennen. Und dann entsprechend das Gerät Auswählen. Der TF-FKE ist bisher aber noch nicht angelegt. Auf die schnelle konnte ich nicht herausfinden welche EEP er benutzt. In einem Dokument steht ähnlich EEP F6-10-00, die kannst du mal ausprobieren.
            • MichaM Offline
              MichaM Offline
              Micha
              #146
              Hallo Jey Cee,
              Habe heute meinen iobroker neu aufgesetzt und den enocean Adapter aufgespielt.
              Leider stürzt jetzt iobroker ständig ab.
              Ist dir diese Verhalten bekannt ?
              VG Micha
              • Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                #147
                @Micha:
                Ist dir diese Verhalten bekannt ? ` Nein, kannst du bitte das Log hier posten damit ich sehen kann was da los ist.
                • 9 Offline
                  9 Offline
                  9_Mad-Max_5
                  #148
                  Ist zu erwarten das das Senden in den nächsten Monaten implementiert wird?
                  • MichaM Offline
                    MichaM Offline
                    Micha
                    #149
                    @Jey Cee:
                    @Micha:
                    Ist dir diese Verhalten bekannt ? Nein, kannst du bitte das Log hier posten damit ich sehen kann was da los ist.
                    Es lag an einer fehlenden Lib für den usb 300 Adapter.
                    Jetzt funktioniert es.
                    Ich habe hier Permundo Geräte (psc 234) die leider keine Id auf dem Gerät haben. Gibt es da eine Möglichkeit diese anzulernen ?
                    Die automatische Erkennung ist ja leider nicht mehr da .<emoji seq="1f648">🙈</emoji>
                    VG Micha
                    • Jey CeeJ Offline
                      Jey CeeJ Offline
                      Jey Cee
                      #150
                      @9_Mad-Max_5 kann ich nicht versprechen.
                      @Micha spontan fällt mir nur ein das LogLevel des Adapters auf Debug zu stellen.
                      Der PSC234 ist nur teilweise implementiert, Daten lesen geht, schalten nicht.
                      • MichaM Offline
                        MichaM Offline
                        Micha
                        #151
                        @jaycee
                        Okay wie stelle ich den Debug beim Adapter ein?
                        Gibt es die Möglichkeit die Daten mitzuschreiben die
                        der USB-Stick empfängt?
                        Deine Deviceliste ist ja noch im Aufbau. Wenn ich die erweitern würde mit den entsprechenden EEP und die EEP nicht in deiner Liste sind , gibt es dann einen Fehler ?
                        VG Micha
                        • Jey CeeJ Offline
                          Jey CeeJ Offline
                          Jey Cee
                          #152
                          In der Instanzenen Übersicht auf Expertenmodus stellen dann kannst du das LogLevel ändern.
                          HM möglich das alle Datentelegramme ins Log geschrieben werden.
                          Du kannst die Liste ohne weiteres erweitern. Schön wäre wenn du sie mir dann zur Verfügung stellst das ich sie in den Adapter aufnehmen kann.
                          • Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            #153
                            Ich hab mal wieder am EnOcean Adapter weiter gearbeitet.
                            Es gibt jetzt wieder eine Automatische Erkennung von Geräten, es werden nur Geräte erkannt die 4BS Telegramme senden.
                            Das sind Geräte mit einer A5-xx-xx EEP.
                            Aber auch hier können nur die erkannt werden die auch die nötigen Informationen mitschicken.
                            Bei allen anderen Geräten werden die ID und soweit möglich die Art von Telegramm in das Log von ioBroker geschrieben. So wird das manuelle Anlegen eines Geräts erleichtert.
                            Außerdem wurde das Profil der EEP A5-02-05 gefixt.
                            Eine weiter Neuerung unter der Haube ist eine Liste mit den Hersteller IDs. Die Liste ist für die Automatische Erkennung Notwendig.
                            Durch die Einführung der Liste wurden die Namen der Hersteller in der Geräte Liste angepasst.
                            Ich hoffe es finden sich ein paar Tester.
                            • Jey CeeJ Offline
                              Jey CeeJ Offline
                              Jey Cee
                              #154
                              Ich hatte es gar nicht vor, aber mir war heute danach:
                              Die Automatische Erkennung sollte jetzt etwa 50% der Geräte erkennen können.
                              • UTE (Unidirektional) eingebaut
                              • Rocker Switches werden jetzt erkannt
                              • PSC234 read only support vervollständigt
                              • Multi-EEP support Vervollständigt
                              Achtung: Alle die eine ältere Version des Adapters nutzen müssen den Adapter erst löschen und dann alle Geräte neu anlernen.
                              Die Neuerungen haben ein paar größere Änderungen erfordert, weshalb jetzt das Handling der Geräte inkompatibel ist.
                                ak68
                                #155
                                ich bin ioBroker-Neuling und möchte hiermit meine KNX/ Edomi-Installation ergänzen.
                                Als ersten Schritt möchte ichMaco/ Winkhaus/ Elktako Fenasterkontakte FTKB-hg per EnOcean Pi anbinden.
                                Folgende Schritte habe ich durchgeführt:
                                1. Adapter per Github und Instanz angelegt:
                                2. Schnittstelle wird erkannt:
                                3. Geräteerkennung:
                                -> leider schlägt diese Fehl, Fenterkontakt wird nicht erkannt (per Magnet in Erkennungsmodus geschaltet !)
                                Auch eine manuelle Erkennung ist nicht möglich, da ich keine ID finden kann
                                4. Log:
                                Offensichtlich erfolgt zumindest mit dem Adapter eine Kommunikation, leider stürzt jedoch der PI seit Installation des Adapters ständig ab (mit Kringel) und ist nur durch Strom AUS wieder zu wecken- ich weiss: suboptimal, aber per SSH-Verbindung habe ich keinen Zugriff mehr.
                                Wer kann mir hier weiterhelfen ?
                                Vielen Dank schon einmal
                                Andreas
                                ioBroker auf QNAP TVS-473
                                Visu und Logiken mit node-red
                                Anbindung an KNX per openKNX
                                • Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  #156
                                  @ak68:
                                  Als ersten Schritt möchte ichMaco/ Winkhaus/ Elktako Fenasterkontakte FTKB-hg per EnOcean Pi anbinden. ` Das Profil für die Dinger ist noch nicht im Adapter. Mach ich aber sobald du den Adapter bei dir zum laufen bekommen hast.
                                  @ak68:
                                  Auch eine manuelle Erkennung ist nicht möglich, da ich keine ID finden kann ` Steht dann im Log. Sollte aber nicht nötig sein wenn das Profil im Adapter ist.
                                  @ak68:
                                  4. Log: `
                                  Muss dich enttäuschen, das ist die Ereignisanzeige nicht das Log.
                                  Ich brauch das Log um Überhaupt eine Chance zu haben den Grund für den absturz zu finden, aber eigentlich kann ein Adapter gar nicht den ganzen ioBroker zum Abstruz bringen.
                                  Das Log kannst du im Log Tab herunterladen oder wenn das nicht möglich ist, findest du das Log in /opt/iobroker/log auf dem Pi.
                                    ak68
                                    #157
                                    Hallo Jey,
                                    hab die Log-Datei angehängt in der Hoffnung, dass Du den Fehler findest (Pi-Neustart 20:54/ manueller Neustart von ioBroker, Versuch, enocean-Gerät zu erkennen, Absturz ca, 20:55)
                                    Ich habe heute außer dem Adapter keine weitere Software installiert (außer den dazugehörigen Paketen)
                                    Vielen Dank für deine Bemühungen
                                    Andreas
                                    PS: Die Funksensoren verwenden das Protokoll EEP A5-14-0A
                                    8873_log_iobroker.txt
                                    • Jey CeeJ Offline
                                      Jey CeeJ Offline
                                      Jey Cee
                                      #158
                                      Also ich kann jetzt keine Eindeutigen Grund für den Absturz erkennen, aber was auffällt ist das einige Adapter bereits laufen.
                                      `2018-09-21 20:55:02.783  - [31merror[39m: socketio.0 already running
                                      2018-09-21 20:55:02.807  - [31merror[39m: fritzdect.0 already running
                                      2018-09-21 20:55:02.813  - [31merror[39m: history.0 already running
                                      2018-09-21 20:55:03.068  - [33mwarn[39m: javascript.0 Reconnection to DB.
                                      2018-09-21 20:55:03.198  - [31merror[39m: email.0 already running[/code]`
                                      Das sollte nicht sein, vor allem nicht nach einem Neustart.
                                      Dann hab ich das hier gefunden:
                                      `~~[code]~~2018-09-21 20:55:17.353  - [31merror[39m: admin.0 port 8081 already in use
                                      2018-09-21 20:55:17.395  - [31merror[39m: host.Raspberrypi instance system.adapter.admin.0 terminated with code 1 ()[/code]`
                                      Das dürfte dein Vermeintlicher absturz sein. Der Admin Adapter wird beendet und du hast keinen Zugriff mehr auf die Weboberfläche, ioBroker läuft aber noch. Vom EnOcean Adapter ist jedoch nichts zu sehen.
                                      Irgendwas ist in deinem System Komplett durcheinander.
                                      Mach mal einen eigenen Thread dazu auf.[/code]
                                      • Jey CeeJ Offline
                                        Jey CeeJ Offline
                                        Jey Cee
                                        #159
                                        @ak68:
                                        Die Funksensoren verwenden das Protokoll EEP A5-14-0A ` Hab ich hinzugefügt. Adapter neu von Github Installieren dann ist es da.
                                        Eine Rückmeldung ob es funktioniert wäre super.
                                          ak68
                                          #160
                                          Danke, werde ich machen- wenn ioBroker wieder ohne Abstürze läuft !
