  4. [geloest] npm Cache kann nicht geleert werden
6 Beiträge 4 Kommentatoren 791 Aufrufe 3 Beobachtet
  • L Offline
    lessthanmore
    schrieb am zuletzt editiert von lessthanmore
    Moin zusammen,
    per ncdu ist mir aufgefallen, dass der Ordner /home/iobroker/.npm/_cacache immer größer wird und nicht geleert werden kann.
    --- /home/iobroker/.npm -------------------------------------------------------------------------------------------------------
    .   2.7 GiB [##################] /_cacache
       12.9 MiB [                  ] /_libvips
      944.0 KiB [                  ] /_npx
      404.0 KiB [                  ] /_prebuilds
      172.0 KiB [                  ] /_logs
    e   4.0 KiB [                  ] /_locks
        4.0 KiB [                  ]  anonymous-cli-metrics.json
        0.0   B [                  ]  _update-notifier-last-checked
    Ein
    npm cache clean --force
    bringt hier keine Änderung.
    iob diag:
    Skript v.2024-08-12
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-2-pve
        Architecture: x86-64
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     08:38:54 up 27 days, 21:11,  2 users,  load average: 0.10, 0.18, 0.17
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Wed 2024-10-16 08:38:55 CEST
               Universal time: Wed 2024-10-16 06:38:55 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    michael
    HOME=/home/michael
    GROUPS=michael tty dialout sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev redis
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            8.6G        2.5G        2.5G        184K        3.5G        6.0G
    Swap:           4.3G         24K        4.3G
    Total:           12G        2.5G        6.8G
    Active iob-Instances: 	19
             8192 M total memory
             2428 M used memory
             2055 M active memory
             3201 M inactive memory
             2395 M free memory
                0 M buffer memory
             3367 M swap cache
             4096 M total swap
                0 M used swap
             4095 M free swap
    top - 08:38:55 up 27 days, 21:11,  2 users,  load average: 0.10, 0.18, 0.17
    Tasks:  57 total,   1 running,  56 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   2394.2 free,   2430.1 used,   3367.9 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   5761.9 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * certbot.service                      loaded failed failed Certbot
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    4 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       15G   10G  4.0G  72% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       96G   58G   34G  63% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  120K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--1                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    636M	/var/
    528M	/var/lib
    275M	/var/lib/redis
    143M	/var/lib/apt/lists
    143M	/var/lib/apt
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    1.3G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    74M	/opt/iobroker/iobroker-data/
    73M	/opt/iobroker/iobroker-data/node-red
    72M	/opt/iobroker/iobroker-data/node-red/node_modules
    9.8M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email
    9.7M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules
    2.0M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/js/app.min.js
    620K	/opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.js
    616K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/css/app.min.css
    552K	/opt/iobroker/iobroker-data/backitup/backitup.0.log
    544K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules/imap/deps/encoding/encoding-indexes.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.0
    /usr/bin/node 		v20.18.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.1.5
    javascript: 	8.8.3
    nodejs modules from github: 	1
    +-- iobroker.bmw@2.8.0 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#a490aabba5709c560626c225ee3a66d4bb97049f)
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 10.0.1.11
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Instances
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json":
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "tibberlink"   : 3.4.10   , installed 3.4.10
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee2mqtt"  : 2.13.10  , installed 2.13.10
    Objects and States
    Objects: 	4202
    States: 	4244
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:42871         0.0.0.0:*               LISTEN      1000       85894076   38917/io.yahka.0
    tcp        0      0 10.0.1.11:8080          0.0.0.0:*               LISTEN      1001       85895517   39153/node
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          39521      830/nginx: master p
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          34219      1/init
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          39523      830/nginx: master p
    tcp        0      0 127.0.0.1:45901         0.0.0.0:*               LISTEN      1000       85894080   38917/io.yahka.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       85891832   38728/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       85891909   38796/io.zigbee2mqt
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          35794      826/master
    tcp        0      0 127.0.0.1:39439         0.0.0.0:*               LISTEN      1000       85894084   38917/io.yahka.0
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        24496      152/redis-server 12
    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        24497      152/redis-server 12
    tcp6       0      0 :::39251                :::*                    LISTEN      1000       85896241   38917/io.yahka.0
    tcp6       0      0 :::40551                :::*                    LISTEN      1000       85896243   38917/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       85893568   38611/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       85896216   38902/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       85895323   38962/io.simple-api
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       85899279   38932/io.lovelace.0
    tcp6       0      0 :::80                   :::*                    LISTEN      0          39522      830/nginx: master p
    tcp6       0      0 :::111                  :::*                    LISTEN      0          34221      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          24429      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          35795      826/master
    tcp6       0      0 :::45057                :::*                    LISTEN      1000       85896245   38917/io.yahka.0
    udp        0      0 10.0.1.11:54336         0.0.0.0:*                           1000       85891864   38728/node-red
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          34220      1/init
    udp        0      0 0.0.0.0:36864           0.0.0.0:*                           110        24475      98/avahi-daemon: ru
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        24473      98/avahi-daemon: ru
    udp6       0      0 :::111                  :::*                                0          34222      1/init
    udp6       0      0 :::5353                 :::*                                110        24474      98/avahi-daemon: ru
    udp6       0      0 :::43447                :::*                                110        24476      98/avahi-daemon: ru
    @Thomas-Braun Ist dir so etwas schon einmal untergekommen?
    Lieben Dank vorab!
    arteckA Thomas BraunT 2 Antworten Letzte Antwort
    • L lessthanmore
      Moin zusammen,
        944.0 KiB [                  ] /_npx
      Ein
      iob diag:
      Skript v.2024-08-12
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      michael
      HOME=/home/michael
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.3G         24K        4.3G
               8192 M total memory
               2428 M used memory
               2395 M free memory
                  0 M buffer memory
               3367 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /var:
      636M	/var/
      528M	/var/lib
      275M	/var/lib/redis
      143M	/var/lib/apt
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: redis
      States  type: redis
      admin: 		7.1.5
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4202
      States: 	4244
      Pending Updates: 0
      Lieben Dank vorab!
      arteckA Offline
      arteckA Offline
      arteck
      @lessthanmore sagte in npm Cache kann nicht geleert werden:
      dann machs richtig
      sudo -H -u iobroker npm cache clean --force
      die pakete liegen unnter User iobroker
      L 1 Antwort Letzte Antwort
      • arteckA arteck
        dann machs richtig
        lessthanmore
        @arteck Vielen Dank!
        • L lessthanmore
          Moin zusammen,
            944.0 KiB [                  ] /_npx
          Ein
          iob diag:
          Skript v.2024-08-12
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          michael
          HOME=/home/michael
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           4.3G         24K        4.3G
                   8192 M total memory
                   2428 M used memory
                   2395 M free memory
                      0 M buffer memory
                   3367 M swap cache
                   4096 M total swap
                      0 M used swap
                   4095 M free swap
          *** FILESYSTEM ***
          /var:
          636M	/var/
          528M	/var/lib
          275M	/var/lib/redis
          143M	/var/lib/apt
          USB-Devices by-id:
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: redis
          States  type: redis
          admin: 		7.1.5
          javascript: 	8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	4202
          States: 	4244
          Pending Updates: 0
          Lieben Dank vorab!
          @lessthanmore sagte in [geloest] npm Cache kann nicht geleert werden:
          Nein, ich verwende gleich den passenden User. :-D
            lessthanmore
            @thomas-braun root? :-D
            • L lessthanmore
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              @lessthanmore @arteck hatte dir folgendes geschrieben:
              sudo wechselt den Benutzer,
              -H wechselt/nutzt in das Home-Verzeichnis des Benutzers
              -u gibt an zu welchen Benutzer denn gewechselt werden soll
              iobroker => wir haben einen Gewinner!
              npm ... der Befehl der ausgeführt werden soll samt Parameter und Optionen
              Edit: ok, dem Smiley habe ich jetzt erst bewusst gesehen, sorry für die Belehrung. Vielleicht kann der nächste was damit anfangen
