  4. Probleme mit InMemDB, Databases, IOB in Endlosschleife
11 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • N Offline
    N Offline
    Nunca
    Nachdem nun meine ioBroker Installation seit gut zwei Jahren recht problemlos auf meinem Raspberry PI 3b lief, habe ich nun massive Probleme nach Adapterupdates.
    So sieht mein Log aus und das wieder holt sich so auf ewig.
    2024-10-02 21:10:20.834  - info: host.raspberrypi received SIGTERM
    2024-10-02 21:10:21.004  - info: host.raspberrypi terminated. Could not reset alive status for instances
    2024-10-02 21:10:38.469  - info: host.raspberrypi iobroker.js-controller version 6.0.11 js-controller starting
    2024-10-02 21:10:38.480  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-10-02 21:10:38.481  - info: host.raspberrypi hostname: raspberrypi, node: v20.17.0
    2024-10-02 21:10:38.483  - info: host.raspberrypi ip addresses: 192.168.178.84 2003:dc:d723:aa00:a86b:fc4a:ae7b:bb4 fe80::85b9:f7dd:e95f:f45c
    2024-10-02 21:10:38.635  - warn: host.raspberrypi-Server Objects 127.0.0.1:49638 Error from InMemDB: Error: auth NOT SUPPORTED
        at RedisHandler._handleCommand (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:141:40)
        at Resp.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:59:45)
        at Resp.emit (node:events:519:28)
        at Resp.write (/opt/iobroker/node_modules/respjs/index.js:129:12)
        at Socket.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:69:23)
        at Socket.emit (node:events:519:28)
        at addChunk (node:internal/streams/readable:559:12)
        at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
        at Readable.push (node:internal/streams/readable:390:5)
        at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
    2024-10-02 21:11:37.195  - error: host.raspberrypi No connection to databases possible, restart
    2024-10-02 21:11:37.221  - info: host.raspberrypi iobroker _restart
    2024-10-02 21:11:45.797  - info: host.raspberrypi iobroker.js-controller version 6.0.11 js-controller starting
    2024-10-02 21:11:45.808  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-10-02 21:11:45.809  - info: host.raspberrypi hostname: raspberrypi, node: v20.17.0
    2024-10-02 21:11:45.811  - info: host.raspberrypi ip addresses: 192.168.178.84 2003:dc:d723:aa00:a86b:fc4a:ae7b:bb4 fe80::85b9:f7dd:e95f:f45c
    2024-10-02 21:11:45.945  - warn: host.raspberrypi-Server Objects 127.0.0.1:59836 Error from InMemDB: Error: auth NOT SUPPORTED
    Ein Systemupdate habe ich bereits ausgeführt ("sudo apt-get update" und "sudo apt-get upgrade" gefolgt von "sudo apt-get autoremove"). Das läuft ohne Probleme durch.
    Ein "iob fix" hat nicht geholfen. Mehrfaches Rebooten auch nicht.
    iob diag liefert folgendes:
    Skript v.2024-08-12
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     20:59:23 up 27 min,  2 users,  load average: 0.51, 0.93, 0.71
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Wed 2024-10-02 20:59:24 CEST
               Universal time: Wed 2024-10-02 18:59:24 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    ulli
    HOME=/home/ulli
    GROUPS=ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            922M         98M         74M        1.0M        749M        757M
    Swap:            99M        1.0M         98M
    Total:          1.0G         99M        173M
    Active iob-Instances:   0
              922 M total memory
               98 M used memory
              333 M active memory
              382 M inactive memory
               74 M free memory
              190 M buffer memory
              559 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    top - 20:59:24 up 27 min,  2 users,  load average: 0.51, 0.93, 0.71
    Tasks: 136 total,   1 running, 135 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.9 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    922.3 total,     74.3 free,     98.2 used,    749.8 buff/cache
    MiB Swap:    100.0 total,     99.0 free,      1.0 used.    758.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       27G   11G   15G  42% /
    devtmpfs       devtmpfs  429M     0  429M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     185M  1.9M  183M   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/mmcblk0p6 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
    [Wed Oct  2 20:31:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Oct  2 20:31:56 2024] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Oct  2 20:31:56 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
    [Wed Oct  2 20:32:00 2024] EXT4-fs (mmcblk0p7): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p7 ext4   rw,noatime
    `-/boot /dev/mmcblk0p6 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.3G    /var/
    1.1G    /var/log/journal/dc6f242a0db443ce92b468f9abbf9ea6
    1.1G    /var/log
    908M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    29M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    837M    /opt/iobroker/iobroker-data/
    581M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
     Unable to increase LUA script timeout: Error auth NOT SUPPORTED
     Cannot determine Set feature status: Connection is closed.
    Server Objects 127.0.0.1:50972 Error from InMemDB: Error: auth NOT SUPPORTED
    No connection to databases possible ...
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.1.5
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
    Server Objects 127.0.0.1:39744 Error from InMemDB: Error: auth NOT SUPPORTED
    ioBroker-Repositories
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/node_modules/iobroker.js-controller/admin/objects.jsonl"!
    Installed ioBroker-Instances
    Server Objects 127.0.0.1:48412 Error from InMemDB: Error: auth NOT SUPPORTED
    Objects and States
    Objects:        1
    States:         3
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13721      473/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          13852      617/smbd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          13851      617/smbd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26565      4155/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13723      473/sshd: /usr/sbin
    tcp6       0      0 :::139                  :::*                    LISTEN      0          13850      617/smbd
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          11879      1/init
    tcp6       0      0 :::445                  :::*                    LISTEN      0          13849      617/smbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        611        338/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13679      435/dhcpcd
    udp        0      0 0.0.0.0:51308           0.0.0.0:*                           108        613        338/avahi-daemon: r
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          12075      459/nmbd
    udp        0      0 192.168.178.84:137      0.0.0.0:*                           0          12074      459/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          12035      459/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          12077      459/nmbd
    udp        0      0 192.168.178.84:138      0.0.0.0:*                           0          12076      459/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          12036      459/nmbd
    udp6       0      0 :::5353                 :::*                                108        612        338/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13734      435/dhcpcd
    udp6       0      0 :::58522                :::*                                108        614        338/avahi-daemon: r
    2024-10-02 21:06:19.387  - error: host.raspberrypi No connection to databases possible, restart
    2024-10-02 21:06:19.412  - info: host.raspberrypi iobroker _restart
    2024-10-02 21:06:27.855  - info: host.raspberrypi iobroker.js-controller version 6.0.11 js-controller starting
    2024-10-02 21:06:27.866  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-10-02 21:06:27.868  - info: host.raspberrypi hostname: raspberrypi, node: v20.17.0
    2024-10-02 21:06:27.870  - info: host.raspberrypi ip addresses: 192.168.178.84 2003:dc:d723:aa00:a86b:fc4a:ae7b:bb4 fe80::85b9:f7dd:e95f:f45c
    2024-10-02 21:06:28.021  - warn: host.raspberrypi-Server Objects 127.0.0.1:42154 Error from InMemDB: Error: auth NOT SUPPORTED
    Mit der Summary:
                            v.2024-08-12
    Terminal:       tty
    *** MEMORY ***
    Swap:            99M        1.0M         98M
              922 M total memory
               98 M used memory
              333 M active memory
               74 M free memory
              190 M buffer memory
              559 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    *** FILESYSTEM ***
    /var:
    2.3G    /var/
    1.1G    /var/log
    908M    /var/cache
    Archived and active journals take up 1.0G in the fil   Static hostname: raspberrypi
             Icon name: computer
          Architecture: arm
    Installation:           native
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    Pending OS-Updates:     0
    Ich würde mich wirklich über etwas Hilfe freuen. Ich bin nicht ganz unbedarft, was Computer und Elektronik angeht, komme hier jedoch gerade massiv an meine Grenzen.
    Grüße
    Ulli
    • N Nunca
      Skript v.2024-08-12
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ulli
      HOME=/home/ulli
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M        1.0M         98M
                922 M total memory
                 98 M used memory
                333 M active memory
                 74 M free memory
                190 M buffer memory
                559 M swap cache
                 99 M total swap
                  1 M used swap
                 98 M free swap
      *** FILESYSTEM ***
      /var:
      2.3G    /var/
      1.1G    /var/log
      908M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      admin:          7.1.5
      javascript:     8.7.6
      Adapter State
      Objects and States
      Objects:        1
      States:         3
      Pending Updates: 0
      Mit der Summary:
                              v.2024-08-12
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M        1.0M         98M
                922 M total memory
                 98 M used memory
                333 M active memory
                 74 M free memory
                190 M buffer memory
                559 M swap cache
                 99 M total swap
                  1 M used swap
                 98 M free swap
      *** FILESYSTEM ***
      /var:
      2.3G    /var/
      1.1G    /var/log
      908M    /var/cache
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      Grüße
      Ulli
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @nunca said in Probleme mit InMemDB, Databases, IOB in Endlosschleife:
      In jedem Fall verwend mal ein besseres / originales Netzteil
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • N Offline
        N Offline
        Nunca
        @mcm1957 Danke fürs draufschauen. Am Netzteil sollte das doch nicht liegen, zumal das System jetzt zwei Jahre in diese Hardware-Konfiguration sehr gut lief. Nach Adapterupdates ist das Problem aufgetaucht.
        • N Nunca
          @nunca sagte in Probleme mit InMemDB, Databases, IOB in Endlosschleife:
          Instabile Spannungsversorgung kann zu allen möglichen Fehlerrn führen. Setz da ein richtig dimensioniertes NETZTEIL (kein Ladegerät!) ein.
          Und dann bringst du das per Neuinstallation auf ein 64Bit-Release. Am besten dann auf Hardware mit mehr als 1GB RAM.
          N 1 Antwort Letzte Antwort
            N Offline
            N Offline
            Nunca
            schrieb am zuletzt editiert von Nunca
            @thomas-braun Ich habe ein regelbares Netzteil von Meanwell im Einsatz und das auch vorhin mal etwas hochgedreht. Du meinst ich komme um eine Neuinstallation nicht herum? Wenn, dann werde ich aber gerne bei der 32 bit Version und meinem 1GB RPi 3 bleiben wollen, da so solide auf der Hutschiene verbaut.
            • N Nunca
              Nein, da es keinen funktionierenden Upgrade-Pfad auf RaspberryOS 12 'Bookworm' gibt.
              Der RPi3 kommt auch mit 64Bit parat, das hat auch mit einer Hutschiene nix zu tun.
                N Offline
                N Offline
                Nunca
                @thomas-braun Ich mache mir eher Sorgen wg. meinem Limit von 1 GB RAM. Ich gehe davon aus, dass die 64bit Version etwas mehr RAM benötigt als die 32bit Version. Bei mir läuft zwar nur IOB und Samba, aber etwas Reserve ist mir schon lieb.
                • N Nunca
                  @nunca
                  1GB RAM ist so oder so ein wenig knapp. Da macht dann ein 64Bit-OS auch keinen Unterschied mehr.
                    @nunca
                    N Offline
                    N Offline
                    Nunca
                    @thomas-braun das stimmt, aber ich möchte gerne das nutzen was ich hier habe (wenn es denn eben ausreicht) und für die Software, die ich laufen lasse, sollte doch auch ein 32 bit OS absolut ausreichen.
                    Du siehst keine Chance, das System zu retten?
                    • N Nunca
                      Was heißt 'retten'. Bring das Ding auf RaspberryOS 12, musst du eh bald machen. Da das ganze aber nur per Neuinstallation geht kannst du das auch jetzt machen. Und dann halt die 64Bit-Version, da die erfahrungsgemäß auch besser gepflegt wird.
                        N Offline
                        N Offline
                        Nunca
                        @thomas-braun Okay. Ich gebe nach ;-) Backups der Daten, JS, und NodeRed Flows sind vorhanden, habe trotzdem ein wenig Angst, dass das ganze nachher auch wieder so schön läuft wie vorher bzw. ich beim neu Aufsetzen irgendwo scheitere. Ich steuere/überwache hier die Stromflüsse und Heizungen im Haus über IOB. Es gibt Failsave-Modi, daher kein "wirkliches" Problem.
