  4. Shelly Plus Uni: Objekte?
23 Beiträge 7 Kommentatoren 3.4k Aufrufe 7 Beobachtet
  • D Dieter_P
    @crunchip
    Gibt es schon neue Erkenntnisse dazu? Auf Github erkenne ich kein eindeutiges Bild und scheint noch offen zu sein.
    Nachdem ich heute auf Stable 8.2.1 des Shelly Adapters upgedated hab, bekkomme ich auch die Mqtt Meldungen für alle Shellys die in der Instanz laufen.
    2024-10-07 09:39:26.868 - info: shelly.1 (2185738) [MQTT] Client Close: (shelly1pmminig3 / shelly1pmminig3-34b7dac7c8a1 / shelly1pmminig3#34b7dac7c8a1#1) (false)
    2024-10-07 09:39:27.705 - info: shelly.1 (2185738) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-a8032ab62a30 / shellyplus2pm#a8032ab62a30#1) (false)
    2024-10-07 09:39:28.330 - info: shelly.1 (2185738) [MQTT] Client Close: (shelly1pmminig3 / shelly1pmminig3-84fce63839fc / shelly1pmminig3#84fce63839fc#1) (false)
    2024-10-07 09:39:40.633 - info: shelly.1 (2185738) [MQTT] Device with client id "shellypro2-30c6f784b55c" connected!
    2024-10-07 09:39:43.020 - info: shelly.1 (2185738) [MQTT] Device with client id "shelly1pmminig3-34b7dac7c8a0" connected!
    2024-10-07 09:39:43.977 - info: shelly.1 (2185738) [MQTT] Device with client id "shellyplus2pm-a8032ab62a30" connected!
    2024-10-07 09:39:48.150 - info: shelly.1 (2185738) [MQTT] Device with client id "shelly1pmminig3-84fce63839fc" connected!
    2024-10-07 09:39:50.619 - info: shelly.1 (2185738) [MQTT] Client Close: (shellypro2 / shellypro2-30c6f784b55c / shellypro2#30c6f784b55c#1) (false)
    2024-10-07 09:39:52.696 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a8032ab62a30"
    2024-10-07 09:39:53.001 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-84fce63839fc"
    2024-10-07 09:39:53.009 - info: shelly.1 (2185738) [MQTT] Client Close: (shelly1pmminig3 / shelly1pmminig3-34b7dac7c7a0 / shelly1pmminig3#34b7dac7c7a0#1) (false)
    2024-10-07 09:39:53.104 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-34b7dac7c9a0"
    2024-10-07 09:39:53.298 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f784b56c"
    2024-10-07 09:39:53.388 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-34b7dac7c7a0"
    2024-10-07 09:39:53.432 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shellypro2-30c6f784b56c"
    2024-10-07 09:39:53.952 - info: shelly.1 (2185738) [MQTT] Client Close: 192.168.7.165 (shellyplus2pm / shellyplus2pm-a8032ab62a40 / shellyplus2pm#a8032ab62a20#1) (false)
    2024-10-07 09:39:54.815 - error: shelly.1 (2185738) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
    2024-10-07 09:39:54.817 - error: shelly.1 (2185738) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-a8032ab62a40"
    2024-10-07 09:40:17.887 - info: shelly.1 (2185738) [MQTT] Device with client id "shellypro2-30c6f784b55c" connected!
    2024-10-07 09:40:23.812 - info: shelly.1 (2185738) [MQTT] Device with client id "shellyplus2pm-a8032ab62a20" connected!
    2024-10-07 09:40:27.969 - info: shelly.1 (2185738) [MQTT] Device with client id "shelly1pmminig3-34b7dac7c7a0" connected!
    crunchipC Abwesend
    crunchipC Abwesend
    @dieter_p sagte in Shelly Plus Uni: Objekte?:
    nein
    hast du alle Varianten, die genannt worden sind, mal ausprobiert?
      nein
      Dieter_P
      @crunchip said in Shelly Plus Uni: Objekte?:
      Es werde mehrere Beobachtungen geschildert. Da ich bereits auf der neuesten Shelly FW unterwegs war, hab ich es nun mal mit dem "Standard" versucht. Reboot für die Shellys und der Instanz. Aktuell habe ich danach noch einmal die Meldung für den 2PM gefunden. die Anderen waren still. Beobachte nun.
      • D Dieter_P
        siporax
        schrieb am zuletzt editiert von siporax
        @dieter_p
        Hänge mich mal hier an da es wunderbar hier her passt.
        Habe den Shelly uni plus nun erfolgreich in den IoBroker eingebunden.
        Erst nach mehrfachen reboot hat er mir die Objekte im IoBroker dann auch angelegt.
        Zum Problem:
        Leider finde ich keine Werte vom Volteingang und Temperatursensor im IoBroker nicht.
        Obwohl in der App alles angezeigt wird.
        Firmenware vom Uni wurde über die App gemacht jetzt ist da drauf die :20241011-114444/1.4.4-g6d2a586
        Alles im Broker auf dem neusten Stand.
        Sind die nich da oder muss ich was noch was aktivieren das ich das sehen kann.
