  3. Off Topic
  4. Pflege des Betriebssystems
  5. Einige Betriebssystempakete können aktualisiert werden.
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
updateiobrokermeldung
35 Beiträge 11 Kommentatoren 6.6k Aufrufe 7 Beobachtet
    Rushmed
    ich bekomme aktuell Meldungen dass Betriebssystempakete aktualisiert werden können.
    raspberrypi-sys-mods/stable 20240807 arm64 [upgradable from: 20240624]
    wpasupplicant/stable-security 2:2.10-12+deb12u2 arm64 [upgradable from: 2:2.10-12+deb12u1]
    Meine Update Ausgabe sieht so aus:
    pi@Smartazamba:~ $ sudo apt update && iob stop && sudo apt full-upgrade --yes && sudo reboot
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Ign:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://apt.grafana.com stable InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    N: Repository 'Debian bookworm' changed its 'non-free component' value from 'non-free' to 'non-free non-free-firmware'
    N: More information about this can be found online in the Release notes at: https://www.debian.org/releases/bookworm/arm64/release-notes/ch-information.html#non-free-split
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libcamera0.2 linux-headers-6.1.0-rpi8-common-rpi linux-headers-6.6.20+rpt-common-rpi linux-kbuild-6.1
      linux-kbuild-6.6.20+rpt
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Broadcast message from root@Smartazamba on pts/1 (Fri 2024-08-09 18:03:55 CEST):
    The system will reboot now!
    Wie kann ich die Meldung im ioBroker loswerden. Generell würde ich im iobroker lieber nur Meldungen bekommen die den ioBroker direkt betreffen. Kann ich das iregndwo einstellen?
    sigi234S da_WoodyD 2 Antworten Letzte Antwort
    • R Rushmed
      sigi234S Online
      sigi234S Online
      sigi234
      @rushmed
      https://forum.iobroker.net/topic/75693/betriebssystem-paket-updates-linux-ist-auf-neustem-stand?_=1723219892317
      Immer Daten sichern!
      • R Rushmed
        da_WoodyD Offline
        da_WoodyD Offline
        da_Woody
        @rushmed steht doch in der Ausgabe.
        sudo apt remove
        Würde integriert damit man aufmerksam gemacht wird, daß dein System versauert.
        gruß vom Woody
        R 1 Antwort Letzte Antwort
        • da_WoodyD da_Woody
          sudo apt remove
          Rushmed
          @da_woody sagte in Einige Betriebssystempakete können aktualisiert werden.:
          sudo apt remove
          In der Ausgabe steht dass alles aktuell ist.
          MartinPM HomoranH da_WoodyD 3 Antworten Letzte Antwort
          • R Rushmed
            sudo apt remove
            MartinPM Online
            MartinPM Online
            MartinP
            @rushmed und trotz des Reboot gibt es weiterhin diese Meldung im Iobroker?
            • R Rushmed
              sudo apt remove
              @rushmed sagte in Einige Betriebssystempakete können aktualisiert werden.:
              jetzt?
              nachdem du
              gemacht hattest?
              @martinp sagte in Einige Betriebssystempakete können aktualisiert werden.:
              Auch nach löschen des Browsercache?
              Wenn ja, bitte die Langfassung von iob diag
              • R Rushmed
                sudo apt remove
                da_WoodyD Offline
                da_WoodyD Offline
                da_Woody
                @rushmed alles lesen hilft...
                gruß vom Woody
                • MartinPM MartinP
                  Rushmed
                  @martinp Ja, kommt jedes mal wieder wenn ich im Chrome strg+F5 drücke.
                  • R Rushmed
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @rushmed
                    Versuch mal "nach Updates suchen" im Adapter Tab anzuklicken.
                    Ist aber eher ein Schuss ins Blaue. Schaden kanns allerdings nicht.
                    "Bestätigen" od "Bestätigen und Schließen" hast du ja wahrscheinlich schon angeklickt. (Sorry wenn die Frage blöd rüber kommt - aber es gibt hier manchmal auch Dinge die es nicht gibt :-) )
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                      jetzt?
                      nachdem du
                      gemacht hattest?
                      Rushmed
                      @homoran sagte in Einige Betriebssystempakete können aktualisiert werden.:
                      sudo apt autoremove
                      Mit anschließendem reboot hat nich geholfen.
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: Smartazamba
                             Icon name: computer
                                Kernel: Linux 6.6.31+rpt-rpi-v8
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:24:41 up 16 min,  2 users,  load average: 2.60, 3.87, 2.94
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Fri 2024-08-09 19:24:41 CEST
                                 Universal time: Fri 2024-08-09 17:24:41 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      *** Display-Server-Setup ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            8.2G        2.9G        2.8G        3.0M        2.5G        5.3G
                      Swap:             0B          0B          0B
                      Total:          8.2G        2.9G        2.8G
                      Active iob-Instances:   36
                               7809 M total memory
                               2800 M used memory
                               3529 M active memory
                               1286 M inactive memory
                               2712 M free memory
                                373 M buffer memory
                               2055 M swap cache
                                  0 M total swap
                                  0 M used swap
                                  0 M free swap
                      top - 19:24:41 up 16 min,  2 users,  load average: 2.60, 3.87, 2.94
                      Tasks: 220 total,   2 running, 218 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 66.7 us, 33.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   7809.0 total,   2701.2 free,   2811.7 used,   2429.1 buff/cache
                      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4997.3 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4      110G   24G   83G  23% /
                      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     1.6G  2.9M  1.6G   1% /run
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/sda1      vfat      253M   44M  209M  18% /boot/firmware
                      /dev/sdc       ext4      5.5T  3.5T  1.8T  67% /media/HDD2
                      /dev/sdb1      ext4      4.6T  3.5T  875G  81% /media/HDD1
                      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
                      [Fri Aug  9 19:08:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Fri Aug  9 19:08:36 2024] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
                      [Fri Aug  9 19:08:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Fri Aug  9 19:08:52 2024] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w. Quota mode: none.
                      [Fri Aug  9 19:08:55 2024] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
                      [Fri Aug  9 19:08:56 2024] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
                      Show mounted filesystems:
                      TARGET                                                  SOURCE      FSTYPE      OPTIONS
                      /                                                       /dev/sda2   ext4        rw,noatime
                      |-/dev                                                  devtmpfs    devtmpfs    rw,relatime,size=3733652k,nr_inodes=933413,mode=755
                      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
                      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                      |-/proc                                                 proc        proc        rw,relatime
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3405
                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                      | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                      |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,size=1599292k,nr_inodes=819200,mode=755
                      | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                      | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
                      |-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      |-/media/HDD2                                           /dev/sdc    ext4        rw,nosuid,nodev,noexec,relatime
                      `-/media/HDD1                                           /dev/sdb1   ext4        rw,nosuid,nodev,noexec,relatime
                      /var:
                      6.6G    /var/
                      3.4G    /var/log
                      2.7G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
                      616M    /var/cache
                      Archived and active journals take up 2.6G in the file system.
                      /opt/iobroker/backups:
                      2.6G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      987M    /opt/iobroker/iobroker-data/
                      650M    /opt/iobroker/iobroker-data/files
                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      60M     /opt/iobroker/iobroker-data/states.jsonl
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      36M     /opt/iobroker/iobroker-data/objects.jsonl
                      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
                      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
                      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                      HINT:
                      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                      tcp
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.16.0
                      /usr/bin/node           v20.16.0
                      /usr/bin/npm            10.8.1
                      /usr/bin/npx            10.8.1
                      /usr/bin/corepack       0.28.2
                      nodejs:
                        Installed: 20.16.0-1nodesource1
                        Candidate: 20.16.0-1nodesource1
                        Version table:
                       *** 20.16.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                              100 /var/lib/dpkg/status
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  6.0.9
                      admin:          7.0.22
                      javascript:     8.7.6
                      nodejs modules from github:     2
                      +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#6b97f67d1d1ce6af3a0e598ba77eec8f570a0854)
                      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
                      + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
                      + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
                      + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
                        system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
                      + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
                      + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
                        system.adapter.esphome.0                : esphome               : Smartazamba                              - disabled
                        system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
                        system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
                      + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
                        system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
                      + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
                      + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
                        system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
                      + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                      + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
                      + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
                      + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
                        system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
                        system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
                      + system.adapter.proxmox.0                : proxmox               : Smartazamba                              -  enabled, port: 8006
                      + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
                      + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
                      + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
                      + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
                      + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
                      + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
                        system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
                      + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
                      + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                      + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
                      + instance is alive
                      ioBroker-Repositories
                      │ (index) │ name               │ url                                                     │ auto upgrade │
                      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                      │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                      Upgrade policy: none
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 7.0.22   , installed 7.0.22
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                      Adapter    "awtrix-light" : 1.2.1    , installed 1.2.1
                      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                      Adapter    "denon"        : 1.15.12  , installed 1.15.12
                      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                      Adapter    "deyeidc"      : 0.0.16   , installed 0.0.16
                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                      Adapter    "hass"         : 1.4.0    , installed 1.4.0
                      Adapter    "hue"          : 3.11.0   , installed 3.11.0
                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                      Controller "js-controller": 6.0.9    , installed 6.0.9
                      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                      Adapter    "pixelit"      : 1.1.3    , installed 1.1.3
                      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                      Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "windows-control": 0.1.5  , installed 0.1.5
                      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                      Objects and States
                      Objects:        23225
                      States:         16314
                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                      Ign:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:6 https://apt.grafana.com stable InRelease
                      Hit:7 https://repos.influxdata.com/debian stable InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6850       822/smbd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5761       643/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       20643      4353/iobroker.js-co
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       20648      4353/iobroker.js-co
                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6851       822/smbd
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       25376      5248/io.shelly.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       22678      5217/io.mqtt.0
                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       21440      5602/io.sonoff.0
                      tcp6       0      0 :::445                  :::*                    LISTEN      0          6848       822/smbd
                      tcp6       0      0 :::21                   :::*                    LISTEN      0          1791       634/vsftpd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          5763       643/sshd: /usr/sbin
                      tcp6       0      0 :::139                  :::*                    LISTEN      0          6849       822/smbd
                      tcp6       0      0 :::3000                 :::*                    LISTEN      109        6901       952/grafana
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       21773      4399/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       27718      6439/io.web.0
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1002       26075      6757/io.ws.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        1966       742/influxd
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1002       26660      6403/io.simple-api.
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       23492      6469/io.wled.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3851       492/avahi-daemon: r
                      udp        0      0 0.0.0.0:56360           0.0.0.0:*                           108        3853       492/avahi-daemon: r
                      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          4939       799/nmbd
                      udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          4938       799/nmbd
                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          4926       799/nmbd
                      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          4941       799/nmbd
                      udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          4940       799/nmbd
                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          4927       799/nmbd
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       25089      5648/io.mihome-vacu
                      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       23094      5668/io.mihome-vacu
                      udp6       0      0 :::58325                :::*                                108        3854       492/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        3852       492/avahi-daemon: r
                      udp6       0      0 fe80::7572:1640:817:546 :::*                                0          1926       578/NetworkManager
                      2024-08-09 19:21:30.472  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001039118.roomFanPower
                      2024-08-09 19:21:30.473  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001043945.roomFanPower
                      2024-08-09 19:21:30.474  - info: mihome-vacuum.0 (5648) change states from State control.fan_power mihome-vacuum.0.rooms.275001043946.roomFanPower
                      2024-08-09 19:22:01.200  - info: alexa2.0 (4856) Unknown Device, but enabling commands, Try it and report back if commands work.
                      2024-08-09 19:22:01.208  - info: alexa2.0 (4856) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                      2024-08-09 19:22:01.209  - info: alexa2.0 (4856)     Device-type:A203FC0H3THJQH - Kateryna's Alexa app for WearOS watch (Alexa on Wear) (SPEECH_RECOGNIZER_USS,DIALOG_INTERFACE_VERSION,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SUPPORTS_LOCALE_SWITCH,PEONY,ADAPTIVE_LISTENING,SET_LOCALE,ASCENDING_ALARM_VOLUME,REMINDERS,SUPPORTS_LOCALE,SOUND_SETTINGS,VOLUME_SETTING,GEOLOCATION,SET_TIME_ZONE,CUSTOM_ALARM_TONE,TIMERS_AND_ALARMS,MULTI_WAKEWORDS_SUPPORTED,EARCONS)
                      2024-08-09 19:23:02.830  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                      2024-08-09 19:23:02.832  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                      2024-08-09 19:23:02.834  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                      2024-08-09 19:23:02.835  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                      2024-08-09 19:23:02.837  - error: javascript.0 (4799) script.js.Alexa: Cannot parse "": SyntaxError: Unexpected end of JSON input
                      2024-08-09 19:23:03.094  - error: javascript.0 (4799) script.js.Alexa: TypeError: Cannot read properties of null (reading 'indexOf')
                      2024-08-09 19:23:03.096  - error: javascript.0 (4799)     at Object.<anonymous> (script.js.Alexa:41:84)
                      2024-08-09 19:23:03.096  - error: javascript.0 (4799)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
                      2024-08-09 19:23:03.097  - error: javascript.0 (4799)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                      2024-08-09 19:23:03.097  - error: javascript.0 (4799)     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11053:62)
                      2024-08-09 19:23:03.098  - error: javascript.0 (4799)     at processImmediate (node:internal/timers:483:21)
                      2024-08-09 19:23:06.092  - info: alexa2.0 (4856) Subscribing to states...
                      2024-08-09 19:23:08.440  - info: alexa2.0 (4856) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2024-08-09 19:23:40.106  - info: alexa2.0 (4856) Initialization Done ...
                      2024-08-09 19:25:21.649  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 14168
                      2024-08-09 19:25:32.942  - info: weatherunderground.0 (14168) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.16.0, js-controller: 6.0.9
                      2024-08-09 19:25:46.938  - info: weatherunderground.0 (14168) Terminated (NO_ERROR): Without reason
                      2024-08-09 19:25:47.454  - warn: weatherunderground.0 (14168) get state error: Connection is closed.
                      2024-08-09 19:25:47.542  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 14168 terminated with code 0 (NO_ERROR)
                      • R Rushmed
                        sudo apt autoremove
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:             0B          0B          0B
                                 7809 M total memory
                                 2800 M used memory
                                 2712 M free memory
                                  373 M buffer memory
                                 2055 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        *** FILESYSTEM ***
                        /var:
                        6.6G    /var/
                        3.4G    /var/log
                        616M    /var/cache
                        USB-Devices by-id:
                        HINT:
                        tcp
                        /usr/bin/npm            10.8.1
                        /usr/bin/npx            10.8.1
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.0.22
                        javascript:     8.7.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        23225
                        States:         16314
                        Pending Updates: 0
                        Pending Updates: 0
                        da ist nichts mehr offen.
                        Warum der admin darauf besteht ist mir ein Rätsel
                        Auch sonst sehe ich nichts besorgniserregendes, lediglich ein kleiner Hinweis
                        tcp
                        dürfte aber ein LAN Interface sein, oder?
                          Pending Updates: 0
                          tcp
                          Rushmed
                          Ja genau. Danke für die Prüfung.
                          • R Rushmed
                            @rushmed
                            Und wenn du die Meldung einfach nur 'Bestätigst'?
                            Die dürfte aktuell dann nicht mehr aufpoppen.
                            OT: Ich freu mich, das der Code für zigbee-Sticks auch in komplexeren Setups funktioniert.
                            Das konnte ich nämlich nicht so gut testen.
                            MartinPM R 2 Antworten Letzte Antwort
                              @rushmed
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              @thomas-braun fehlt da ggfs eine apt paketquelle?
                              • MartinPM MartinP
                                @martinp
                                Ich denke, da lügt einfach mal wieder die GUI.
                                Die Meldungen zu Updates werden nicht in 'Echtzeit' abgeglichen. Ich glaube, die setzen sich nicht mal von alleine zurück. Da muss man aktiv 'Bestätigen und schließen' klick0rn.
                                  @rushmed
                                  Rushmed
                                  @thomas-braun sagte in Einige Betriebssystempakete können aktualisiert werden.:
                                  Das hat geklappt.
                                  • R Rushmed
                                    Das hat geklappt.
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    Ja
                                    Notifications (nicht nur bezüglich Updates) müssen bestätigt werden und verschwinden nicht von selbst.
                                      Rushmed
                                      Kurze Frage noch. Wäre mein Updatebefehl so okay oder mache ich mir da etwas kaputt?
                                      sudo apt update && iob stop && sudo apt full-upgrade --yes && sudo apt autoremove -y && sudo reboot
                                      • R Rushmed
                                        @rushmed
                                        Technisch funktionert das.
                                        Würde ich aber niemals so machen lassen. Da gibst du viel zu sehr die Zügel aus der Hand.
                                        Gerade beim autoremove besser 2x hinschauen, was da entfernt werden soll. Manchmal haut es dir nämlich auch wesentliche Pakete raus.
                                        L 1 Antwort Letzte Antwort
                                          @rushmed
                                          Linedancer
                                          Und wie erkenne ich als Nichtfachmann welche Pakete wesentlich sind?
                                          Ciao, Gerhard
