  4. Nach Update auf js-controller 6.0.9 startet ECharts nicht
9 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • JoJo58J Online
    JoJo58J Online
    JoJo58
    Moin Zusammen
    ich habe eben auf meinem Raspberry den js-controller auf die Version 6.0.9 aktualisiert und seit dem startet der EChart Adapter nicht mehr.
    Es kommen folgende Meldungen im Protokoll:
    host.raspi4gb	2024-08-07 16:34:40.329	info	Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.raspi4gb	2024-08-07 16:34:40.329	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: Node.js v20.16.0
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: }
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspi4gb	2024-08-07 16:34:40.328	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:986:27)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
    host.raspi4gb	2024-08-07 16:34:40.327	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
    host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: Require stack:
    host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: ^
    host.raspi4gb	2024-08-07 16:34:40.326	error	Caught by controller[0]: throw err;
    host.raspi4gb	2024-08-07 16:34:40.325	error	Caught by controller[0]: node:internal/modules/cjs/loader:1148
    host.raspi4gb	2024-08-07 16:34:39.909	info	instance system.adapter.echarts.0 in version "1.7.2" started with pid 3032
    Was kann ich da tun? Ich würde den ungerne deinstallieren und neu installieren, oder wären dann die vorhandenen Charts noch da?
    Gruß, Johannes
    Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
    Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
    Einfach ein tolles Hobby :-)
    • JoJo58J JoJo58
      Moin Zusammen
      Gruß, Johannes
      @jojo58 sagte in Nach Update auf js-controller 6.0.9 startet ECharts nicht:
      Ich vermute, hier könnte mal die Beta-Version des Adapters angezeigt sein. Installier mal die
      latest: 1.9.0
      JoJo58J 1 Antwort Letzte Antwort
        latest: 1.9.0
        JoJo58J Online
        JoJo58J Online
        JoJo58
        Die Beta-Version und ein Reboot haben geholfen. Adapter ist wieder grün. Das Blöde ist, die angelegten Presets sind weg, kein einziger Chart mehr da 😧 😖
        M haus-automatisierungH 2 Antworten Letzte Antwort
        • JoJo58J JoJo58
          M Online
          M Online
          Maddm
          @jojo58 @Thomas-Braun
          Ich habe glaube genau den gleichen Fehler:
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: node:internal/modules/cjs/loader:1228
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: throw err;
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: ^
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: Require stack:
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
          2024-08-28 12:37:02.920 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[0]: }
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 Caught by controller[1]: Node.js v20.17.0
          2024-08-28 12:37:02.921 - error: host.gm-ESPRIMO-Q556 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-08-28 12:37:02.921 - info: host.gm-ESPRIMO-Q556 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
          2024-08-28 12:37:02.921 - info: host.gm-ESPRIMO-Q556 system.adapter.echarts.0 will be rebuilt
          2024-08-28 12:37:02.921 - warn: host.gm-ESPRIMO-Q556 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
          Interessanterweise werden alle meine Charts weiterhin geschrieben und aktualisiert...
          Wenn ich jetzt auf eine andere Version gehe (Beta, wie geht das?) und meine Presets weg sind und damit auch meine Charts - wäre es dann nicht einfacher zu warten, bis eine neue "stable" Version von echarts erscheint, bei dem der Fehler dann nicht mehr da ist?
          • JoJo58J JoJo58
            haus-automatisierungH Offline
            Presets sind ja auch nur Objekte im System vom Typ chart. Expertenmodus einschalten und schauen, ob die Objekte wirklich nicht mehr da sind.
            📚 Meine Dokumentation
              M Online
              M Online
              Maddm
              @haus-automatisierung
              Danke fürs schnelle Feedback.
              Mir ist gerade aufgefallen: im Forum gibts Beiträge über echarts 1.84 und echarts 1.90 --> habe "nur" die 1.72 und mir wird auch keine aktuellere Version angeboten, woher kommt die Diskrepanz?
              Thomas BraunT haus-automatisierungH 2 Antworten Letzte Antwort
              • M Maddm
                @maddm
                echarts
                github:	1.9.0
                latest:	1.9.0 for 22 days
                stable:	1.7.2 for 9 months
                Alles > 1.7.2 ist also eine Beta-Version.
                • M Maddm
                  @maddm Grundlagen zu Repositories anschauen (beta vs. stable). Und wie man ggf die neuesten Versionen von npm installieren kann.
                  metaxaM 1 Antwort Letzte Antwort
                    metaxaM Offline
                    metaxaM Offline
                    metaxa
                    Bei mir hat die npm installation auf 1.9.0 den Erfolg gebracht! Adapter ist wieder grün, charts laden nach wie vor aktuell.
