  4. BUG - sayit geht nicht mehr !
    6.8k
errorsayit
116 Beiträge 15 Kommentatoren 15.2k Aufrufe 9 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    Der Fehler kommt auch weiterhin:
    sayit.4
    2024-07-06 20:53:48.033	error	Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 108. This version of Node.js requires NODE_MODULE_VERSION 115. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
    Danke.
    Thomas BraunT 3 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      sayit.4
      @bahnuhr
      Versuch es mal mit der Beta 4.0.1 des Adapters.
      • bahnuhrB bahnuhr
        sayit.4
        @bahnuhr
        Bzw:
        https://github.com/ioBroker/ioBroker.sayit/issues/320
        • bahnuhrB bahnuhr
          sayit.4
          @bahnuhr
          Ich vermute es hakt bei mDNS/avahi/bonjour.
          2024-07-06 20:52:35.644  - error: host.chet Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
          2024-07-06 20:52:35.645  - error: host.chet Caught by controller[0]: *** WARNING *** Please fix your application to use the native API of Avahi!
          2024-07-06 20:52:35.645  - error: host.chet Caught by controller[0]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
          2024-07-06 20:52:35.647  - error: host.chet Caught by controller[0]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
          2024-07-06 20:52:35.647  - error: host.chet Caught by controller[0]: *** WARNING *** Please fix your application to use the native API of Avahi!
          2024-07-06 20:52:35.648  - error: host.chet Caught by controller[0]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
          Da wird wohl im Adapter was angepasst werden müssen.
            @bahnuhr
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @thomas-braun sagte in BUG - sayit geht nicht mehr !:
            Hatte ich oben schon probiert.
            Da geht dann gar nichts.
            Selbst FFFFFFFF geht dann nicht.
            Danke.
              @bahnuhr
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              könnte sein.
              Ich frage mich halt immer warum sowas nicht geprüft wird.
              Danke.
              • bahnuhrB bahnuhr
                könnte sein.
                @bahnuhr
                Weil ein Developer nicht alles auf seinen Systemen testen kann.
                Insbesondere nicht, wenn ein Adapter wie dieser mannigfaltige Konfigurationen und Konstellationen möglich macht.
                Dafür gibt es dann halt die Beta-Releases.
                • wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  Hier kursieren mittlerweile Alternativen zu sayit weil es scheinbar bei einigen nicht mehr geht.
                  Nur macht scheinbar nicht jeder ein issue auf sondern nimmt es so hin.
                  Ich hoffe das es vielleicht irgendwann mal wieder funktioniert.
                  • bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @wendy2702
                    Sehe ich auch so.
                    @Homoran
                    @Bluefox
                    @apollon77
                    Könnte ihr sagen ob man da dran ist ?
                    Sayit ist doch Standard und sollte nicht verschwinden !
                    Eine Rückinfo wäre gut.
                    Danke.
                    • wendy2702W wendy2702
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @wendy2702 sagte in BUG - sayit geht nicht mehr !:
                      irgendwann
                      Das wäre mir zu lange.
                      Das muss kurzfristig realisiert werden.
                      Ansonsten wieder einmal Suche nach ner Alternative.
                      Danke.
                      • bahnuhrB bahnuhr
                        irgendwann
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        @bahnuhr tja,
                        Ich nutze dafür mittlerweile HASS.
                          @bahnuhr tja,
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          @bahnuhr tja,
                          wasn das ?
                          Auch ein Adapter.
                          Ich benutze sayit aber auch um Texte in mp3 zu speichern und diese dann an yamaha Lautsprecher zu senden.
                          Kann das der HASS auch ?
                          Danke.
                          Samson71S wendy2702W 2 Antworten Letzte Antwort
                          • bahnuhrB bahnuhr
                            @bahnuhr tja,
                            wasn das ?
                            Auch ein Adapter.
                            Samson71S Offline
                            Samson71S Offline
                            Samson71
                            @bahnuhr sagte in BUG - sayit geht nicht mehr !:
                            wasn das ?
                            Home Assistant
                            Markus
                            Bitte beachten:
                            • Samson71S Samson71
                              wasn das ?
                              Home Assistant
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @samson71 sagte in BUG - sayit geht nicht mehr !:
                              wasn das ?
                              Home Assistant
                              Das ist aber doch ein ganz anderes System.
                              oder ?
                              Danke.
                              • bahnuhrB bahnuhr
                                wasn das ?
                                Home Assistant
                                oder ?
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                @bahnuhr
                                Korrekt. Dort eingebundene Geräte lassen sich über den Adapter aus Home Assistant in ioBroker integrieren. Das wird wohl der Fingerzeig gewesen sein.
                                Markus
                                Bitte beachten:
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  @samson71
                                  Ja, von Home Assistant hört man nur gutes.
                                  Obwohl ich iob immer verteidigt habe.
                                  Und ich auch nicht was neues noch anfangen wollte.
                                  Aber wie von mir schon öfters erwähnt; ich halte die Entwicklung von eq3 und iob für falsch:
                                  (und dies ist meine Meinung)
                                  • eq3 stellt homematic ein
                                  • VIS.1 wird nicht weiterentwickelt
                                  • VIS.2 funktioniert nicht mit meinen zahlreichen widgets.
                                  • und ständig funktioniert etwas nicht; und dabei stößt man dann immer durch Zufall drauf.
                                    (wenn Frauchen sagt, die Kiste im Wohnzimmer sagt nichts mehr !)
                                  • und dann wird zum Schluss noch Geld für manche Adapter genommen
                                  Aber dies ist ein anderes Thema.
                                  Wollte die Punkte eigentlich gar nicht mehr erwähnen.
                                  Aber naja;
                                  wenn ich gar nichts mehr sagen; dann wird es kritisch.
                                  mfg
                                  Dieter
                                  Danke.
                                  Samson71S W 2 Antworten Letzte Antwort
                                  • bahnuhrB bahnuhr
                                    @samson71
                                    Aber naja;
                                    mfg
                                    Dieter
                                    Samson71S Offline
                                    Samson71S Offline
                                    Samson71
                                    Mein erster Gehversuch war ne Katastrophe. Gibt es auch nen Post zu. Ich habe das Thema daher für mich erstmal wieder direkt beerdigt und die Anbindung, die ich über den Umweg HASS machen wollte, erfolgreich anders gelöst.
                                    Markus
                                    Bitte beachten:
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Ich will ja auch gar kein anderes System.
                                      Komme ja eigentlich ganz gut zurecht mit iob.
                                      Aber wenn ständig etwas nicht geht, das nervt schon.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        @samson71
                                        Aber naja;
                                        mfg
                                        Dieter
                                        W Offline
                                        W Offline
                                        Wildbill
                                        @bahnuhr Nix für ungut, aber ich habe das Gefühl, Du forderst hier ein bißchen viel und barsch. Wieviel hast Du. bislang fr die Software iobroker ausgegeben? Ich meine nicht das ganze Hardware-Drumherum, nur die Software! Nix? Siehst Du. Das tun Freiwillige ganz für lau für Dich, die wohl alle in ihrem Leben einem Job nachgehene und ihren Lebensunterhalt verdienen und nebenbei in der Freizeit was programmieren und anderen umsonst zur Verfügung stellen.
                                        Wenn es Dir nicht schnell genug geht, lerne programmieren und mach es selbst und besser und schneller. Wenn Du das nicht willst, dann halt die Füße still und warte ab, anstatt hier irgendwie Druck aufbauen zu wollen.
                                        Wenn Dir iobroker immer mehr missfällt, dann wechsle das System. Oder fahre mehrere parallel. Homeassistant wurde angesprochen, es gibt beispielsweise auch noch FHEM. Ich habe alle drei miteinander laufen, iobroker macht die ganze Logik, die anderen beiden eben das, was iobroker noch nicht oder nicht so gut kann. Das Beste aus allen Welten.
                                        Ach ja, bei Homeassistant arbeiten im Hintergrund einige bezahte Programmieren. Hatte ich schon erwähnt, dass das bei iobroker von Freiwilligen für umsonst gemacht wird? Die paar, die sich das bei iobroker nun monetarisieren lassen wollen, werden da IMHO noch böse aus der Wäsche schauen. Es gibt genug Alternativen, als dass man auf einen bestimmten Adapter bei iobroker angewiesen ist.
                                        Sorry, falls das nun barsch rüberkommt, aber dieses Fordern von Dingen, als wäre es eine Selbstverständlichkeit, nervt mich irgendwie.
                                        Gruss, Jürgen
                                        • bahnuhrB bahnuhr
                                          Samson71S Offline
                                          Samson71S Offline
                                          Samson71
                                          @bahnuhr
                                          Cool bleiben. Kein System ist perfekt. Mich überzeugt trotzdem bisher die breite und vielfältige Aufstellung. Kein System bleibt ewig über Jahrzehnte unverändert. Von HM-Classic musste ich mich nach knapp 15 Jahren auch verabschieden.
                                          Markus
                                          Bitte beachten:
