  4. BUG - sayit geht nicht mehr !
    6.8k
errorsayit
116 Beiträge 15 Kommentatoren 15.2k Aufrufe 9 Beobachtet
    @bahnuhr
    Setzt den dieter in die Gruppe adm rein. Wird benötigt, um Logs zu lesen.
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    alles klar
    mach ich
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      Der Fehler kommt auch weiterhin:
      sayit.4
      2024-07-06 20:53:48.033	error	Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 108. This version of Node.js requires NODE_MODULE_VERSION 115. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
      Danke.
      Thomas BraunT 3 Antworten Letzte Antwort
      • bahnuhrB bahnuhr
        sayit.4
        @bahnuhr
        Versuch es mal mit der Beta 4.0.1 des Adapters.
        • bahnuhrB bahnuhr
          sayit.4
          @bahnuhr
          Bzw:
          https://github.com/ioBroker/ioBroker.sayit/issues/320
          • bahnuhrB bahnuhr
            sayit.4
            @bahnuhr
            Ich vermute es hakt bei mDNS/avahi/bonjour.
            2024-07-06 20:52:35.644  - error: host.chet Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
            2024-07-06 20:52:35.645  - error: host.chet Caught by controller[0]: *** WARNING *** Please fix your application to use the native API of Avahi!
            2024-07-06 20:52:35.645  - error: host.chet Caught by controller[0]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
            2024-07-06 20:52:35.647  - error: host.chet Caught by controller[0]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
            2024-07-06 20:52:35.647  - error: host.chet Caught by controller[0]: *** WARNING *** Please fix your application to use the native API of Avahi!
            2024-07-06 20:52:35.648  - error: host.chet Caught by controller[0]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
            Da wird wohl im Adapter was angepasst werden müssen.
              @bahnuhr
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @thomas-braun sagte in BUG - sayit geht nicht mehr !:
              Hatte ich oben schon probiert.
              Da geht dann gar nichts.
              Selbst FFFFFFFF geht dann nicht.
              Danke.
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                könnte sein.
                Ich frage mich halt immer warum sowas nicht geprüft wird.
                Danke.
                • bahnuhrB bahnuhr
                  könnte sein.
                  @bahnuhr
                  Weil ein Developer nicht alles auf seinen Systemen testen kann.
                  Insbesondere nicht, wenn ein Adapter wie dieser mannigfaltige Konfigurationen und Konstellationen möglich macht.
                  Dafür gibt es dann halt die Beta-Releases.
                  • wendy2702W Online
                    wendy2702W Online
                    Hier kursieren mittlerweile Alternativen zu sayit weil es scheinbar bei einigen nicht mehr geht.
                    Nur macht scheinbar nicht jeder ein issue auf sondern nimmt es so hin.
                    Ich hoffe das es vielleicht irgendwann mal wieder funktioniert.
                    • bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @wendy2702
                      Sehe ich auch so.
                      @Homoran
                      @Bluefox
                      @apollon77
                      Könnte ihr sagen ob man da dran ist ?
                      Sayit ist doch Standard und sollte nicht verschwinden !
                      Eine Rückinfo wäre gut.
                      Danke.
                      • wendy2702W wendy2702
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @wendy2702 sagte in BUG - sayit geht nicht mehr !:
                        irgendwann
                        Das wäre mir zu lange.
                        Das muss kurzfristig realisiert werden.
                        Ansonsten wieder einmal Suche nach ner Alternative.
                        Danke.
                        • bahnuhrB bahnuhr
                          irgendwann
                          wendy2702W Online
                          wendy2702W Online
                          @bahnuhr tja,
                          Ich nutze dafür mittlerweile HASS.
                            @bahnuhr tja,
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @bahnuhr tja,
                            wasn das ?
                            Auch ein Adapter.
                            Ich benutze sayit aber auch um Texte in mp3 zu speichern und diese dann an yamaha Lautsprecher zu senden.
                            Kann das der HASS auch ?
                            Danke.
                            Samson71S wendy2702W 2 Antworten Letzte Antwort
                            • bahnuhrB bahnuhr
                              @bahnuhr tja,
                              wasn das ?
                              Auch ein Adapter.
                              Samson71S Offline
                              Samson71S Offline
                              Samson71
                              @bahnuhr sagte in BUG - sayit geht nicht mehr !:
                              wasn das ?
                              Home Assistant
                              Markus
                              Bitte beachten:
                              • Samson71S Samson71
                                wasn das ?
                                Home Assistant
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                @samson71 sagte in BUG - sayit geht nicht mehr !:
                                wasn das ?
                                Home Assistant
                                Das ist aber doch ein ganz anderes System.
                                oder ?
                                Danke.
                                • bahnuhrB bahnuhr
                                  wasn das ?
                                  Home Assistant
                                  oder ?
                                  Samson71S Offline
                                  Samson71S Offline
                                  Samson71
                                  @bahnuhr
                                  Korrekt. Dort eingebundene Geräte lassen sich über den Adapter aus Home Assistant in ioBroker integrieren. Das wird wohl der Fingerzeig gewesen sein.
                                  Markus
                                  Bitte beachten:
                                    @bahnuhr
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    @samson71
                                    Ja, von Home Assistant hört man nur gutes.
                                    Obwohl ich iob immer verteidigt habe.
                                    Und ich auch nicht was neues noch anfangen wollte.
                                    Aber wie von mir schon öfters erwähnt; ich halte die Entwicklung von eq3 und iob für falsch:
                                    (und dies ist meine Meinung)
                                    • eq3 stellt homematic ein
                                    • VIS.1 wird nicht weiterentwickelt
                                    • VIS.2 funktioniert nicht mit meinen zahlreichen widgets.
                                    • und ständig funktioniert etwas nicht; und dabei stößt man dann immer durch Zufall drauf.
                                      (wenn Frauchen sagt, die Kiste im Wohnzimmer sagt nichts mehr !)
                                    • und dann wird zum Schluss noch Geld für manche Adapter genommen
                                    Aber dies ist ein anderes Thema.
                                    Wollte die Punkte eigentlich gar nicht mehr erwähnen.
                                    Aber naja;
                                    wenn ich gar nichts mehr sagen; dann wird es kritisch.
                                    mfg
                                    Dieter
                                    Danke.
                                    Samson71S W 2 Antworten Letzte Antwort
                                    • bahnuhrB bahnuhr
                                      @samson71
                                      Aber naja;
                                      mfg
                                      Dieter
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      Mein erster Gehversuch war ne Katastrophe. Gibt es auch nen Post zu. Ich habe das Thema daher für mich erstmal wieder direkt beerdigt und die Anbindung, die ich über den Umweg HASS machen wollte, erfolgreich anders gelöst.
                                      Markus
                                      Bitte beachten:
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        Ich will ja auch gar kein anderes System.
                                        Komme ja eigentlich ganz gut zurecht mit iob.
                                        Aber wenn ständig etwas nicht geht, das nervt schon.
                                        Danke.
                                        • bahnuhrB bahnuhr
                                          @samson71
                                          Aber naja;
                                          mfg
                                          Dieter
                                          W Offline
                                          W Offline
                                          Wildbill
                                          @bahnuhr Nix für ungut, aber ich habe das Gefühl, Du forderst hier ein bißchen viel und barsch. Wieviel hast Du. bislang fr die Software iobroker ausgegeben? Ich meine nicht das ganze Hardware-Drumherum, nur die Software! Nix? Siehst Du. Das tun Freiwillige ganz für lau für Dich, die wohl alle in ihrem Leben einem Job nachgehene und ihren Lebensunterhalt verdienen und nebenbei in der Freizeit was programmieren und anderen umsonst zur Verfügung stellen.
                                          Wenn es Dir nicht schnell genug geht, lerne programmieren und mach es selbst und besser und schneller. Wenn Du das nicht willst, dann halt die Füße still und warte ab, anstatt hier irgendwie Druck aufbauen zu wollen.
                                          Wenn Dir iobroker immer mehr missfällt, dann wechsle das System. Oder fahre mehrere parallel. Homeassistant wurde angesprochen, es gibt beispielsweise auch noch FHEM. Ich habe alle drei miteinander laufen, iobroker macht die ganze Logik, die anderen beiden eben das, was iobroker noch nicht oder nicht so gut kann. Das Beste aus allen Welten.
                                          Ach ja, bei Homeassistant arbeiten im Hintergrund einige bezahte Programmieren. Hatte ich schon erwähnt, dass das bei iobroker von Freiwilligen für umsonst gemacht wird? Die paar, die sich das bei iobroker nun monetarisieren lassen wollen, werden da IMHO noch böse aus der Wäsche schauen. Es gibt genug Alternativen, als dass man auf einen bestimmten Adapter bei iobroker angewiesen ist.
                                          Sorry, falls das nun barsch rüberkommt, aber dieses Fordern von Dingen, als wäre es eine Selbstverständlichkeit, nervt mich irgendwie.
                                          Gruss, Jürgen
