  4. zigbee "error while opening socket"
zigbee socket
4 Beiträge 2 Kommentatoren 441 Aufrufe 2 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    schrieb am zuletzt editiert von amg_666
    Habe grade gemerkt, dass meine zigbee Instanz "gelb" ist.
    Im Protokoll steht
    zigbee.2
    	2024-06-05 20:26:02.004	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.2
    	2024-06-05 20:26:01.980	error	Error herdsman start
    zigbee.2
    	2024-06-05 20:26:01.980	error	Failed to start Zigbee
    zigbee.2
    	2024-06-05 20:26:01.979	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.2
    	2024-06-05 20:24:00.916	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.2
    	2024-06-05 20:24:00.911	info	Starting Zigbee npm ...
    zigbee.2
    	2024-06-05 20:24:00.910	info	Try to reconnect.
    zigbee.2
    	2024-06-05 20:23:50.908	error	Error herdsman start
    zigbee.2
    	2024-06-05 20:23:50.907	error	Failed to start Zigbee
    zigbee.2
    	2024-06-05 20:23:50.907	error	Starting zigbee-herdsman problem : "Error while opening socket"
    Das ist nur ein kurzer Ausschnitt, das hat sich im Protkoll bis eben so wiederholt.
    Ich habe die Instanz dann manuell neu gestartet, danach lief es wieder
    zigbee.2
    	2024-06-05 20:27:10.105	info	Zigbee started
    zigbee.2
    	2024-06-05 20:27:10.104	info	0xa4c13857375d7b75 (addr 44818): TS0502B - TuYa Light controller (Router)
    zigbee.2
    	2024-06-05 20:27:10.102	info	0x804b50fffe20319a (addr 29559): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.2
    	2024-06-05 20:27:10.101	info	0x00158d000232cbea (addr 22263): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.100	info	0xa4c138ff5d8ed635 (addr 14773): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.2
    	2024-06-05 20:27:10.098	info	0x842e14fffe163f01 (addr 21016): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.097	info	0xa4c138fb6312d1ea (addr 49596): L1(ZW) - TuYa Light dimmer 0-10V (Router)
    zigbee.2
    	2024-06-05 20:27:10.096	info	0x00158d0006d50943 (addr 15532): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.094	info	0x00158d0006e49411 (addr 24941): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.093	info	0x00158d0006d667b4 (addr 37207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.092	info	0x00158d0006e3bb69 (addr 60535): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.091	info	0x00124b00234cdf26 (addr 54690): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
    zigbee.2
    	2024-06-05 20:27:10.089	info	0x84fd27fffecf6567 (addr 53920): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
    zigbee.2
    	2024-06-05 20:27:10.087	info	0x00158d00024905e0 (addr 31049): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.086	info	0xa4c13896f124a5e3 (addr 45147): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.2
    	2024-06-05 20:27:10.083	info	0xbc33acfffe8663a9 (addr 4579): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.082	info	0x54ef44100025ce21 (addr 5858): MCCGQ14LM - Aqara Door and window sensor E1 (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.080	info	0x84fd27fffe9b5e43 (addr 13249): E1746 - IKEA TRADFRI signal repeater (Router)
    zigbee.2
    	2024-06-05 20:27:10.079	info	0xa4c138442eb7c935 (addr 6635): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
    zigbee.2
    	2024-06-05 20:27:10.076	info	0x00158d00024375aa (addr 74): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.075	info	0x00158d000232979b (addr 4151): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.073	info	0x04cf8cdf3c7d7c69 (addr 20132): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.071	info	0x04cf8cdf3c7dcc26 (addr 29290): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.069	info	0x5c0272fffe96fa2a (addr 7999): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
    zigbee.2
    	2024-06-05 20:27:10.067	info	0x00124b00234c6ba9 (addr 60438): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
    zigbee.2
    	2024-06-05 20:27:10.065	info	0x00124b00235279d6 (addr 3321): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
    zigbee.2
    	2024-06-05 20:27:10.063	info	0x00124b0023528715 (addr 35049): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
    zigbee.2
    	2024-06-05 20:27:10.061	info	0x54ef44100017a66e (addr 57020): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.059	info	0x842e14fffe602b98 (addr 14854): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.2
    	2024-06-05 20:27:10.057	info	0xa4c1388e4fb7d6d8 (addr 59225): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
    zigbee.2
    	2024-06-05 20:27:10.049	info	0x54ef4410001c5ee0 (addr 4247): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    zigbee.2
    	2024-06-05 20:27:09.942	info	Currently 30 devices are joined:
    zigbee.2
    	2024-06-05 20:27:09.713	info	--> transmitPower : high+
    zigbee.2
    	2024-06-05 20:27:09.691	info	Unable to disable LED, unsupported function.
    zigbee.2
    	2024-06-05 20:27:09.674	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
    zigbee.2
    	2024-06-05 20:27:08.060	info	Installed Version: iobroker.zigbee@1.10.3
    zigbee.2
    	2024-06-05 20:27:07.445	info	Starting Zigbee npm ...
    Beta-Repository, node.js 18.20.3, npm 10.7.0, js-controller 5.0.19 und zigbee 1.10.3
    iob läuft unter proxmox/Debian, zigbee stick ist ein cc2652p Modul mit LAN Port.
    Jetzt läuft zwar alles wieder, aber nach Murphy passiert sowas eigentlich immer, wenn ich mal nicht zuhause bin /Zugriff habe, daher würde ich das natürlich gerne fixen, falls es ein HW/Konfig/... Problem ist.
    hat hier jemand eine Idee woran es liegen kann bzw wie man das Problem eingrenzt?
    • amg_666A amg_666
      Im Protokoll steht
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      zigbee.2
      arteckA Offline
      arteckA Offline
      arteck
      @amg_666 sagte in zigbee "error while opening socket":
      ist der switch kurz ausgestiegen ?
      • arteckA arteck
        amg_666A Offline
        amg_666A Offline
        amg_666
        @arteck Könnte sein, an der Steckdose hatte ich schonmal nen Wackelkontakt...
        Kann man das irgendwo im Protokoll sehen, ob der ausgestiegen ist?Oder nur "indirket" über die herdsman-Fehlermeldung?
        • amg_666A amg_666
          arteckA Offline
          arteckA Offline
          arteck
          @amg_666 der steigt immer dann aus wenn der coordinator fehlt..
          dann moppert der herdsman .. jo
