  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. /dev/serial/by-id: No such file or directory
    2.8k
    4.9k
    4.1k
27 Beiträge 6 Kommentatoren 6.0k Aufrufe 5 Beobachtet
    @minta79 sagte in /dev/serial/by-id: No such file or directory:
    Das habe ich alles gemacht
    Also hattest Du die fehlerhafte Version?
    Minta79
    schrieb am zuletzt editiert von Minta79
    @haus-automatisierung said in /dev/serial/by-id: No such file or directory:
    Das ist mein aktueller Stand:
    pi@raspberrypi:~ $ apt policy udev
    udev:
      Installed: 247.3-7+rpi1+deb11u2
      Candidate: 247.3-7+rpi1+deb11u2
      Version table:
     *** 247.3-7+rpi1+deb11u2 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            100 /var/lib/dpkg/status
    Ist die fehlerhafte oder?
    • M Minta79
      udev:
        Version table:
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @minta79 hast Du die Datei
      bullseye-proposed-updates.list
      nach dem Editieren auch gespeichert ?
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        Minta79
        @djmarc75 said in /dev/serial/by-id: No such file or directory:
        Copy to Clipboardbullseye-proposed-updates.list
        Ja
        pi@raspberrypi:~ $ sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Get:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        Reading package lists... Done
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/backports.list:2 and /etc/apt/sources.list.d/bullseye-proposed-updates.list:2
        W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/backports.list:2 and /etc/apt/sources.list.d/bullseye-proposed-updates.list:2
        W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/backports.list:2 and /etc/apt/sources.list.d/bullseye-proposed-updates.list:2
        W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/backports.list:2 and /etc/apt/sources.list.d/bullseye-proposed-updates.list:2
        Fehler: Err:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        • M Minta79
          Ja
          Minta79
          Hit:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
          Get:3 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Get:6 http://deb.debian.org/debian bullseye-backports/main armhf Packages [399 kB]
          Get:7 http://deb.debian.org/debian bullseye-backports/main Translation-en [347 kB]
          Fetched 795 kB in 1s (622 kB/s)
          Building dependency tree... Done
          44 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@raspberrypi:~ $ sudo apt -t bullseye-proposed-updates install udev
          udev is already the newest version (247.3-7+rpi1+deb11u2).
          M MartinPM 2 Antworten Letzte Antwort
          • M Minta79
            Minta79
            pi@raspberrypi:~ $ sudo apt -t bullseye-backports install udev
            DAS HAT DAS PROBLEM GELÖST - neue Version installiert - PROBLEM BEHOBEN!!!
            Danke für eure Hilfe
            • M Minta79
              pi@raspberrypi:~ $ sudo lsusb
              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
              Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
              Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
              Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
              pi@raspberrypi:~ $ sudo ls -la /dev/serial/by-id
              ls: cannot access '/dev/serial/by-id': No such file or directory
              Operating System: Raspbian GNU/Linux 11 (bullseye)
              Kernel: Linux 6.1.21-v8+
              Architecture: arm64
              Userland: 32 bit
              Bring das auf einen aktuellen Stand. Also Raspberry OS 12 'Bookworm' in der 64Bit-Lite-Version. Die Übung musst du eh irgendwann machen, dann kannst du es auch jetzt tun.
              Und das System (auch den ioBroker) auf Stand halten.
              Würdest du das regelmäßig machen hättest du jetzt auch nicht das Problem mit dem kaputten udev-Paket. Als das nämlich 'frisch' war konnte man das noch ohne Klimmzüge gerade ziehen.
              • M Minta79
                MartinPM Online
                MartinPM Online
                MartinP
                Hmm, vielleicht ist der naheliegenste Rat, bevor man hier weiter bastelt, gleich Nägel mit Köpfen zu machen, und Bullseye zu ersetzen...
