  4. Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion
    5.1k
26 Beiträge 6 Kommentatoren 4.4k Aufrufe 6 Beobachtet
  • G Offline
    Gaunt
    Moin,
    ich habe in meinem ZigbeeNetzwerk neuerdings eine Steckdose im Einsatz.
    TuYa TS011F @Amazon
    Allerdings bin ich mit dieser nicht besonders zufrieden, da diese nach ca. 2 Tagen sich verabschiedet hat und seitdem nicht mehr funktioniert.
    Die letzten Logmeldungen:
    	Zeile  3769: 2024-05-26 03:32:33.221  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
    	Zeile  8770: 2024-05-26 08:22:12.090  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
    	Zeile  9512: 2024-05-26 08:56:16.882  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
    	Zeile 11660: 2024-05-26 10:44:07.686  - error: zigbee2mqtt.0 (1877) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SREQ '--> ZDO - extRouteDisc - {"dstAddr":58704,"options":0,"radius":30}' failed with status '(0xc7: NWK_TABLE_FULL)' (expected '(0x00: SUCCESS)'))'
    	Zeile 12896: 2024-05-26 11:41:44.820  - error: zigbee2mqtt.0 (1877) Default response to 0xa4c138ee2956659f failed
    Aktuelle Meldung:
    Zeile 24008: 2024-05-26 19:35:21.475  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
    	Zeile 24606: 2024-05-26 20:07:58.523  - error: zigbee2mqtt.0 (2100) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
    	Zeile 24611: 2024-05-26 20:08:11.142  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
    	Zeile 24635: 2024-05-26 20:09:39.015  - error: zigbee2mqtt.0 (2100) Publish 'set' 'state' to '0xa4c138ee2956659f' failed: 'Error: ZCL command 0xa4c138ee2956659f/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
    	Zeile 24655: 2024-05-26 20:10:45.705  - error: zigbee2mqtt.0 (2100) Default response to 0xa4c138ee2956659f failed
    Ich bekomme das Gerät ins Netzwerk hinein jedoch funktioniert es nicht korrekt. Schalter können nicht geschaltet werden (nur am Gerät). Die Strom- und Leistungsmessung funktioniert irgendwie. Ich hatte bei einem Strom von 0.03A und einer Spannung von 235V eine Leistung von 635W.
    Das ist inzwischen die dritte Steckdose welche ich testweise ausprobiere. Bisher hatte ich folgende bereits ohne Erfolg im Einsatz:
    Aqara Zigbee Steckdose @Amazon
    SURFOU Zigbee Steckdose
    Die Aqara Steckdose hat sich leider selbstständig und ungewollt nach einer zufälligen Zeit ausgeschaltet (Auto Off war deaktiviert. das wurde nach dem 1 aus überprüft) und das Verbraucher eingesteckt hat leider nicht funktioniert.
    Die Steckdose von Surfou hat auch nicht getan was sie sollte, da sind mir leider die Gründe nicht mehr bekannt.
    Kennt ihr diese Probleme und/oder konntet ihr sie lösen.
    Sind meine Einstellungen vom Zigbee2mqtt ggf fehlerhaft.
    Gibt es aktuelle Fehler im Adapter vom IOB welche das Problem erzeugen?
    Welche Zigbeesteckdosen habt ihr im Einsatz (gerne mit Verlinkung) und seit ihr mit diesen Steckdosen dann zufrieden und würdet diese weiter empfehlen?
    D crunchipC 2 Antworten Letzte Antwort
    • G Gaunt
      Moin,
      TuYa TS011F @Amazon
      Aktuelle Meldung:
      Dragon
      @gaunt Gut, günstig und einfach zu beziehen, wären die Lidl Steckdosen, allerdings ohne Leistungsmessung. Falls du die benötigst müssten wir noch mal schauen...
      G 1 Antwort Letzte Antwort
      • G Gaunt
        Moin,
        TuYa TS011F @Amazon
        Aktuelle Meldung:
        crunchipC Offline
        crunchipC Offline
        @gaunt sagte in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
        Dazu könnte man erst etwas sagen, wenn die benötigten Informationen vorhanden wären.
        • WintermuteW Offline
          WintermuteW Offline
          Wintermute
          Ich benutze neben den Tradfri-Dingern von Ikea noch die Nous A1Z (ZB https://www.amazon.de/NOUS-A1Z-Stromverbrauch-Verbrauchsmessung-Zigbee2MQTT/dp/B0054PSH0G), wenn ich Leistungsmessung brauche. Laufen bis jetzt ohne Probleme bei mir.
          Iobroker als Windows-VM auf einem Supermicro-Server
          arteckA G 2 Antworten Letzte Antwort
          • WintermuteW Wintermute
            arteckA Offline
            arteckA Offline
            arteck
            @wintermute welcher koordiantor und welche Firmwareversion ?
            G WintermuteW 2 Antworten Letzte Antwort
            • arteckA arteck
              Gaunt
              @arteck
              Das ist mein Daten aus dem Zigbee2MQTT
              Zigbee2MQTT-Version: 1.37.1 commit: cda867a3
              Coordinator-Typ: zStack3x0
              Coordinator-Version: 20210708
              Frontend-Version: 0.6.167
              Zigbee Herdsman Konverter Version: 19.37.2
              Zigbee Herdsman Version: 0.46.6
              Zigbee2MQTT Adapter IOB: 2.13.6
              Ich verwende den Sonoff Zigbee 3.0 USB Dongle Plus Basierend auf dem CC2652P und CP2102(N).
              Mit meinen Ledvance Leuchten, Sonoff und Aqara Temperatur/Motion Sensoren funktioniert das prima. Nur die Steckdosen wollen scheinbar nicht so richtig 🤣
              crunchipC arteckA 2 Antworten Letzte Antwort
              • arteckA arteck
                WintermuteW Offline
                WintermuteW Offline
                Wintermute
                @arteck sagte in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                Ein Conbee II mit dem dconz-Adapter.
                  Gaunt
                  @crunchip said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                  Hier ist einmal der Auszug aus der configuration.yaml den networkkey, panid, ext Pan id und die Geräte am ende habe ich mal rausgenommen um es übersichtlicher zu machen.
                  Gibt es noch weitere Einstellungen die relevant sind?
                  homeassistant: false
                  frontend: true
                  mqtt:
                    base_topic: zigbee2mqtt
                    server: mqtt://127.0.0.1:1884
                  serial:
                    port: >-
                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_521bfe7ad08bed1194da7b7937e930e3-if00-port0
                  advanced:
                    homeassistant_legacy_entity_attributes: false
                    legacy_api: false
                    legacy_availability_payload: false
                    cache_state: false
                    output: json
                    log_syslog:
                      app_name: Zigbee2MQTT
                      eol: /n
                      host: localhost
                      localhost: localhost
                      path: /dev/log
                      pid: process.pid
                      port: 514
                      protocol: udp4
                      type: '5424'
                    last_seen: ISO_8601_local
                  device_options:
                    legacy: false
                    availability: true
                  devices:
                  Die Darstellung der Anwesenheit der Geräte (egal ob Batterie oder Stromversorgt) funktioniert auch nicht immer korrekt. aber da wollte ich mich bei anderer Gelegenheit mal mit beschäftigen :-)
                  • D Dragon
                    Gaunt
                    @dragon said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                    Das klingt interessant. ich habe die mal bei Lidl online gerade angesehen. Laut Webseite gibt es diese im 3er Packet mit Leistungsmessung. Als einzelpacket nur ohne Leistungmessung. Die mit Messung sind sogar im Stückpreis geringer.
                    Hier der Link zu diesen:
                    3er SmartPlug Silvercrest
                      Gaunt
                      @wintermute said in Zigbee Steckdosen Modellalternativen aufgrund Fehlfunktion:
                      Die Ikea Tradfri sind mir von der Bauform zu groß da würde ich mir zu viel Platz um die Steckdosen . Aber die Tretakt haben eine gute Größe. die werde ich auch mal in meine weiteren Test mit einbeziehen.
                      Die Nous Geräte habe ich auch schon gesehen. Von diesen habe ich die Wifi Version im Einsatz und bin mit diesen nicht so wirklich zufrieden. Die Funktionieren technisch jedoch summen die Steckdosen im 50Hz takt und das in einer Lautstärke, das man es im Schlafzimmer nicht störend ist, jedoch wahrnehmbar.
                      Summen deine Steckdosen in der Zigbee version von Nous auch?
                      Sonst würde ich diese auch mal testen
                      • G Gaunt
                        @arteck
                        crunchipC Offline
                        crunchipC Offline
                        @gaunt bis auf den Adapter nicht auf aktuellem/neusten Stand, vor allem die Firmware
                          Gaunt
                          @crunchip
                          Alles klar, das ist natürlich doof und durchaus eine Mögliche Ursache der Probleme. Dann werde ich mich mal dran machen und die Firmware aktualisieren. Wenn du eine gute Verlinkung hast wie ich die Firmware der Geräte hochziehen kann wäre ich dir dankbar. Ich mache mich sonst selber mal auf die Suche wie das funktioniert.
                            Gaunt
                            @crunchip ok das habe ich geschafft . Jetzt ist die Version auf 20230507. Das ist die neuste die ich gefunden habe.
                            Mal gucken wie sich die Geräte jetzt verhalten.
                            DuffyD 1 Antwort Letzte Antwort
                              Dragon
                              Die A1Z habe ich auch. Passen die zusätzlich gelieferten Werte nicht so ganz. Bin mir grad nicht sicher, aber entweder Leistung oder Strom lieferte völlig konfuse Werte. Ich meine es war die Stromstärke die nicht passte.
                              • G Gaunt
                                @arteck
                                arteckA Offline
                                arteckA Offline
                                arteck
                                20210708
                                der ist zu alt.. flash den mal auf was aktuelles
                                • arteckA arteck
                                  20210708
                                  crunchipC Offline
                                  crunchipC Offline
                                  @arteck hat er doch schon, siehe 2 Post davor
                                  • G Gaunt
                                    DuffyD Offline
                                    DuffyD Offline
                                    Duffy
                                    @gaunt
                                    Funktioniert die Steckdose jetzt?
                                    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                                    Node.js: v22.23.1
                                    NPM: 10.9.4
                                    js-controller 7.1.2
                                    Linux: Trixie
                                    • DuffyD Duffy
                                      @gaunt
                                      Gaunt
                                      @duffy
                                      Moin,
                                      ich habe jetzt die aktuelleste Version auf dem Stick installiert.
                                      Im Einsatz habei ch bisher die Steckdose von Nous, welche bisher ausreichend gut funktioniert.
                                      Die Leistungsmessung funktioniert und Messdaten für Strom und Spannung und Leistung passen zusammen. Das ist schonmal gut, und besser als mit den alten Steckdosen.
                                      etwas verwirrt bin ich noch über die Häufigkeit der Übertragung der Messdaten bei Stromverbrauch:
                                      Da wundert mich der Zeitverlauf z.B. das um 18:38 bis bei 103 W gewesen ist und erst um 18:55 auf der gleichen Schwellwert gewesen hin.
                                      Ich werde mit einem anderen Gerät mal überprüfen ob das realistische ist. Aber im groben und ganzen ist mit dieser Steckdose (und dem Update) die Funktion schon deutlich besser.
                                      Ich habe jetzt zusätzlich noch die SURFOU Zigbee Steckdose hier liegen und werde diese nochmal prüfen. Ggf ist da ja jetzt ein besseres Ergebnis. Ikea konnte ich leider noch nicht testen. Und gegen die Steckdose von Silvercrest habe ich mich doch gegen entschieden da diese etwas schlechtere Reichweite haben sollen.
                                      • G Gaunt
                                        @duffy
                                        Moin,
                                        DuffyD Offline
                                        DuffyD Offline
                                        Duffy
                                        schrieb am zuletzt editiert von Duffy
                                        @gaunt
                                        Werde dann wohl auch mal ei n Update auf den Stick spielen.
                                        Ich habe 3 Aqara Steckdosen aber die Spannungsanzeige schwankt, je nach Dose zwischen 224 und 229 Volt.
                                        Gibt es einen Weg das zu kalibrieren wie es auch bei Tasmota möglich ist?
                                        VG
                                        Node.js: v22.23.1
                                        NPM: 10.9.4
                                        js-controller 7.1.2
                                        Linux: Trixie
                                        • DuffyD Duffy
                                          @gaunt
                                          VG
                                          Gaunt
                                          @duffy
                                          Ja in den geräten unter Einstellungen gibt es was zum kalibrieren.
                                          Kann später mal nen Screenshot reinstellen.
