  5. [gelöst] Datenpunkte aus json erstellen
    6.4k
88 Beiträge 7 Kommentatoren 14.1k Aufrufe 3 Beobachtet
  • K Offline
    Klaus 0
    schrieb am zuletzt editiert von Klaus 0
    ich bin absoluter iobroker Neuling. Ich versuche aus meiner Wetterstation die per Wlan angebunden ist,
    die Jsondaten als Datenpunkte in Iobroker zu bekommen. Habe schon viel gelesen aber irgendwie weiss
    ich nicht wo ich überhaupt anfangen soll. die Daten von der Wetterstation sehen so aus:
    "mac": "8caab5519234",
    "ssid": "Holodeck2.4",
    "bssid": "04b4fec0ad5f",
    "ip": "192.168.178.49",
    "firmversion": "2.0",
    "dcftime": "17:48",
    "dcfdate": "21.05.2024",
    "windspeed": "0",
    "windspeed10": "0",
    "windspeed60": "3",
    "windspeed24": "8",
    "windchill": "24.3",
    "winddir": "315",
    "rain": "0",
    "rainh": "0.0",
    "rain1": "0.0",
    "rain10": "0.0",
    "raind": "0.0",
    "rainw": "0.0",
    "pressure": "1006",
    "owmicon": "04d",
    "sunset": "1716319516",
    "sunrise": "1716262171",
    "temperature1": "24.3",
    "temperature2": "0.0",
    "temperature3": "0.0",
    "humidity1": "55",
    "humidity2": "0",
    "humidity3": "0",
    "lowbat1": "0",
    "lowbat2": "0",
    "lowbat3": "0",
    "id1": "FD",
    "id2": "00",
    "id3": "00",
    "dewpoint1": "14.8",
    "dewpoint2": "0.0",
    "dewpoint3": "0.0",
    "targeturl": ["http://192.xxx.xxx.xxx:8087/control?wdata=11,~temp1~,~hum1~,0,0,~lowbat1~,~windspeed~,~winddir~,~rainh~,159,~id1~"]
    Wie und womit sollte ich anfangen?
    LG
    Klaus
    HomoranH mickymM 2 Antworten Letzte Antwort
    • K Klaus 0
      "dcftime": "17:48",
      "windspeed": "0",
      "windspeed10": "0",
      "windspeed60": "3",
      "windspeed24": "8",
      "winddir": "315",
      "rain": "0",
      "rainh": "0.0",
      "rain1": "0.0",
      "rain10": "0.0",
      "raind": "0.0",
      "rainw": "0.0",
      "pressure": "1006",
      "owmicon": "04d",
      "humidity1": "55",
      "humidity2": "0",
      "humidity3": "0",
      "lowbat1": "0",
      "lowbat2": "0",
      "lowbat3": "0",
      "id1": "FD",
      "id2": "00",
      "id3": "00",
      "dewpoint2": "0.0",
      "dewpoint3": "0.0",
      LG
      Klaus
      HomoranH Offline
      HomoranH Offline
      @klaus-0 sagte in Datenpunkte aus json erstellen:
      Wie
      wahlweise als alias oder Script/Blockly/node-red flow
      womit
      welche Werte brauchst du denn?
      da du in Blockly gepostet hast, musst du z.B. einfach deinen eigenen Zieldatenpunkt mit "Attribut temperature1 von JSON" aktualisieren
      K 1 Antwort Letzte Antwort
      • K Klaus 0
        "dcftime": "17:48",
        "windspeed": "0",
        "windspeed10": "0",
        "windspeed60": "3",
        "windspeed24": "8",
        "winddir": "315",
        "rain": "0",
        "rainh": "0.0",
        "rain1": "0.0",
        "rain10": "0.0",
        "raind": "0.0",
        "rainw": "0.0",
        "pressure": "1006",
        "owmicon": "04d",
        "humidity1": "55",
        "humidity2": "0",
        "humidity3": "0",
        "lowbat1": "0",
        "lowbat2": "0",
        "lowbat3": "0",
        "id1": "FD",
        "id2": "00",
        "id3": "00",
        "dewpoint2": "0.0",
        "dewpoint3": "0.0",
        LG
        Klaus
        mickymM Offline
        mickymM Offline
        mickym
        @klaus-0 Ansonsten kann ich Dir meinen NodeRed Flow empfehlen. ;)
        https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
          Wie
          womit
          Klaus 0
          hi, danke für die schnelle Antwort.
          Also ich bevorzuge Blockly, ist glaub ich am einfachsten wenn man wenig Plan von Java hat.
          Zitat: " musst du z.B. einfach deinen eigenen Zieldatenpunkt mit "Attribut temperature1 von JSON" aktualisieren"
          Hab kein plan wie das umzusetzen ist. Wie sehe das als Beispiel mit Blockly denn aus? Am liebsten wäre es mir wenn ich
          da dann unter Objekte die passenden Datenpunkte hätte. Brauchte da ja auch nur ein paar wie z.B. Temperatur, Windspeed, rain. Die dann in Intervallen von 5 Minuten oder so zum aktualisieren. Dann könnte ich ja einfach mit Verschiedenen Scripten drauf zu greifen.
          Oder Vielleicht denke ich auch zu Kompliziert?
          • mickymM mickym
            Klaus 0
            @mickym
            Danke für den Tip,
            hab aber mal mir den Link kurz angeschaut und gedacht ich bleibe lieber bei Blockly :)
            Bis ich damit was anfangen kann und das kapiert habe wird wahrscheinlich das Beamen schon erfunden ein:))
            LG
            Klaus
            • K Klaus 0
              HomoranH Offline
              HomoranH Offline
              Da die notwendigen Informationen fehlen, hier mal allgemein:
              OBJECT ID mit deinem Datenpunkt ersetzen und JSON mit dem JSON, bzw. dort ein Block WERT von ObjectID hin mit Referenz auf den Datenpunkt mit dem JSON
                Klaus 0
                dann sieht das so aus. Weiß aber auch nicht was du mit Block WERT meinst. Bin halt noch nicht so in dem Thema.
                • K Klaus 0
                  HomoranH Offline
                  HomoranH Offline
                  du musst dir erst einmal das Json holen.
                  ich dachte das liegt in einem Datenpunkt.
                  Da würdest du es mit
                  herausholen.
                  Wenn du das JSON direkt frisch abholen willst, müsstest du es mit dem neuen httpGet Baustein machen
                    herausholen.
                    Klaus 0
                    Habe mich jetzt mal mit dem httpGet Baustein beschäftigt.
                    Aber als Anfänger ist das mir irgendwie zu hoch. Bekomme das nicht hin. Kommt immer die Fehlermeldung.
                    • K Klaus 0
                      HomoranH Offline
                      HomoranH Offline
                      vom objekt Data
                      den block gibt es unter dem httpGet Block
                      • K Klaus 0
                        @klaus-0
                        metaxaM K 2 Antworten Letzte Antwort
                          @klaus-0
                          metaxaM Offline
                          metaxaM Offline
                          metaxa
                          @paul53 Ich versuche gerade Ähnliches, bekomme aber die Fehlermeldung "undefined"
                          javascript.0	21:50:59.113	info	Stopping script script.js.common.800-850_Energie.840_Spritpreise_updaten
                          javascript.0	21:50:59.161	info	Start JavaScript script.js.common.800-850_Energie.840_Spritpreise_updaten (Blockly)
                          javascript.0	21:50:59.170	info	script.js.common.800-850_Energie.840_Spritpreise_updaten: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          javascript.1	21:50:59.335	info	Stop script script.js.common.800-850_Energie.840_Spritpreise_updaten
                          javascript.0	21:50:59.492	info	script.js.common.800-850_Energie.840_Spritpreise_updaten: undefined
                          Die geholten Daten schauen so aus:
                              "id": 33395,
                              "name": "SOCAR Perchtoldsdorf",
                              "location": {
                                "address": "Ketzergasse 191a",
                                "postalCode": "2380",
                                "city": "Perchtoldsdorf",
                                "latitude": 48.1301731,
                                "longitude": 16.2919418
                              "contact": {
                                "telephone": "4318674570",
                                "fax": "4318674804",
                                "mail": "office-at@socarenergy.com",
                                "website": "https://www.socarenergy.at/"
                              "openingHours": [
                                  "day": "MO",
                                  "label": "Montag",
                                  "order": 1,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "DI",
                                  "label": "Dienstag",
                                  "order": 2,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "MI",
                                  "label": "Mittwoch",
                                  "order": 3,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "DO",
                                  "label": "Donnerstag",
                                  "order": 4,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "FR",
                                  "label": "Freitag",
                                  "order": 5,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "SA",
                                  "label": "Samstag",
                                  "order": 6,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "SO",
                                  "label": "Sonntag",
                                  "order": 7,
                                  "from": "00:00",
                                  "to": "24:00"
                                  "day": "FE",
                                  "label": "Feiertag",
                                  "order": 8,
                                  "from": "00:00",
                                  "to": "24:00"
                              "offerInformation": {
                                "service": false,
                                "selfService": true,
                                "unattended": true
                              "paymentMethods": {
                                "cash": true,
                                "debitCard": true,
                                "creditCard": true,
                                "others": "UTA, DKV, Socarcard"
                              "paymentArrangements": {
                                "cooperative": false,
                                "clubCard": false
                              "position": 1,
                              "open": true,
                              "distance": 4.24828720258133,
                              "prices": [
                                  "fuelType": "DIE",
                                  "amount": 1.554,
                                  "label": "Diesel"
                              "id": 7812,
                              "name": "Vivod",
                          Kannst du mir da event. bitte helfen?
                          • metaxaM metaxa
                                "id": 33395,
                                "location": {
                                "contact": {
                                "openingHours": [
                                    "day": "MO",
                                    "label": "Montag",
                                    "order": 1,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "DI",
                                    "order": 2,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "MI",
                                    "order": 3,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "DO",
                                    "order": 4,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "FR",
                                    "label": "Freitag",
                                    "order": 5,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "SA",
                                    "label": "Samstag",
                                    "order": 6,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "SO",
                                    "label": "Sonntag",
                                    "order": 7,
                                    "from": "00:00",
                                    "to": "24:00"
                                    "day": "FE",
                                    "order": 8,
                                    "from": "00:00",
                                    "to": "24:00"
                                  "service": false,
                                  "unattended": true
                                "paymentMethods": {
                                  "cash": true,
                                  "debitCard": true,
                                  "creditCard": true,
                                  "clubCard": false
                                "position": 1,
                                "open": true,
                                "prices": [
                                    "fuelType": "DIE",
                                    "amount": 1.554,
                                    "label": "Diesel"
                                "id": 7812,
                                "name": "Vivod",
                            @metaxa sagte: Daten schauen so aus:
                            Das ist ein Array --> Attribut "0.name".
                            metaxaM 1 Antwort Letzte Antwort
                              @klaus-0
                              Klaus 0
                              @paul53 Danke für die schnelle Anwort. Jetzt kommen die Fehlermeldungen. Screenshot 2024-05-27 220424.png
                              • K Klaus 0
                                @klaus-0
                                In Data wird offenbar null geliefert. Debugge mal den Status code
                                  metaxaM Offline
                                  metaxaM Offline
                                  metaxa
                                  schrieb am zuletzt editiert von metaxa
                                  @paul53 sagte in Datenpunkte aus json erstellen:
                                  Das ist ein Array
                                  Herzlichen Dank! somit ist mir auch klar wie ich an die weiteren Einträge komme (1.name, 2.name....)
                                    @klaus-0
                                    Klaus 0
                                    @paul53 Ist dann auch das gleiche Problem. muss ich vielleicht erst Irgendwas Parsen oder so?Screenshot 2024-05-27 221527.png
                                    • K Klaus 0
                                      @klaus-0 sagte: Ist dann auch das gleiche Problem.
                                      Den Status code ohne "Attribut" debuggen. Er enthält normalerweise eine Zahl (200 bei Erfolg).
                                      Die URL stimmt? Im Web-Browser kommt das JSON mit dieser URL?
                                        Klaus 0
                                        @paul53 Im Web-Browser sieht das so aus
                                        Beim Status code ohne Attribut kommt das
                                        paul53P HomoranH 2 Antworten Letzte Antwort
                                        • K Klaus 0
                                          @klaus-0
                                          Mit der Fehlermeldung kann ich nichts anfangen. Da muss ein ITler ran.
                                          Hast Du es mal mit dem request-Block (und der Variablen result) versucht?
