  4. Nach Backup lässt iobroker nicht mehr starten
16 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    djsirius
    ich habe eben das letzte Backup eingespielt. Leider funktioniert der iobroker nun nicht mehr.
    Kann mir jemand sagen, was ich machen kann?
    Den Fixer habe ich schon drüber laufen lassen, leider startet danach der iobroker immer noch nicht.
    Skript v.2024-04-21
    *** BASE SYSTEM ***
       Static hostname: debian
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-28-amd64
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:39:27 up 17 min,  1 user,  load average: 0.08, 0.18, 0.30
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Fri 2024-05-03 18:39:27 CEST
               Universal time: Fri 2024-05-03 16:39:27 UTC
                     RTC time: Fri 2024-05-03 16:39:27
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
    js-controller is not running
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        200M        6.5G        5.0M        1.1G        7.4G
    Swap:           4.0G          0B        4.0G
    Total:           11G        200M         10G
    Active iob-Instances:   0
             7864 M total memory
              200 M used memory
              502 M active memory
              548 M inactive memory
             6534 M free memory
              175 M buffer memory
              954 M swap cache
             4015 M total swap
                0 M used swap
             4015 M free swap
    top - 18:39:27 up 17 min,  1 user,  load average: 0.08, 0.18, 0.30
    Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.6 us,  0.0 sy,  0.0 ni, 98.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7864.9 total,   6534.8 free,    200.3 used,   1129.8 buff/cache
    MiB Swap:   4016.0 total,   4016.0 free,      0.0 used.   7361.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * media-fritzbox.mount loaded failed failed /media/fritzbox
    * iobroker.service     loaded failed failed ioBroker Server
    2 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     787M  2.5M  785M   1% /run
    /dev/sda2      ext4      454G   45G  386G  11% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    /dev/sda1      vfat      511M  5.8M  506M   2% /boot/efi
    tmpfs          tmpfs     787M   40K  787M   1% /run/user/1000
    [Fri May  3 18:22:03 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri May  3 18:22:10 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems:
    TARGET                        SOURCE     FSTYPE     OPTIONS
    /                             /dev/sda2  ext4       rw,relatime,errors=remount-ro
    |-/sys                        sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security      securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup            cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore            pstore     pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/firmware/efi/efivars efivarfs   efivarfs   rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf               none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/tracing       tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/debug         debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections  fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config        configfs   configfs   rw,nosuid,nodev,noexec,relatime
    |-/proc                       proc       proc       rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc  systemd-1  autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15049
    |-/dev                        udev       devtmpfs   rw,nosuid,relatime,size=3988540k,nr_inodes=997135,mode=755
    | |-/dev/pts                  devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                  tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/hugepages            hugetlbfs  hugetlbfs  rw,relatime,pagesize=2M
    | `-/dev/mqueue               mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
    |-/run                        tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=805368k,mode=755
    | |-/run/lock                 tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs           sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1000            tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=805364k,nr_inodes=201341,mode=700,uid=1000,gid=1000
    `-/boot/efi                   /dev/sda1  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    7.7G    /var/
    4.5G    /var/log
    4.2G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
    2.5G    /var/cache/apt
    Archived and active journals take up 3.7G in the file system.
    /opt/iobroker/backups:
    279M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    850M    /opt/iobroker/iobroker-data/
    412M    /opt/iobroker/iobroker-data/files
    362M    /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    49M     /opt/iobroker/iobroker-data/files/vis.0
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
         18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
     *** 18.19.1-1nodesource1 1001
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.19.1
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.19.1
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.19.1
    admin:
      throw err;
      requireStack: []
    Node.js v18.19.1
    javascript:
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.19.1
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.19.1
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://ftp.de.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:5 http://ftp.de.debian.org/debian bullseye-updates InRelease
    Hit:6 https://packages.sury.org/php bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 17
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15768      508/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12916      474/cupsd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13021      794/exim4
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          13062      802/smbd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          13063      802/smbd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1167       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15770      508/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12915      474/cupsd
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13022      794/exim4
    tcp6       0      0 :::443                  :::*                    LISTEN      0          15882      781/apache2
    tcp6       0      0 :::445                  :::*                    LISTEN      0          13060      802/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          13061      802/smbd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1171       1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          15878      781/apache2
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1168       1/init
    udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          15980      533/nmbd
    udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          15979      533/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15960      533/nmbd
    udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          15982      533/nmbd
    udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          15981      533/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15961      533/nmbd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17660      513/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        16652      438/avahi-daemon: r
    udp        0      0 0.0.0.0:38124           0.0.0.0:*                           112        16654      438/avahi-daemon: r
    udp6       0      0 :::43853                :::*                                112        16655      438/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1174       1/init
    udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          17673      441/NetworkManager
    udp6       0      0 :::5353                 :::*                                112        16653      438/avahi-daemon: r
    2024-05-03 18:21:22.238  - info: host.debian stopInstance system.adapter.trashschedule.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.upnp.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.viessmannapi.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-bars.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-history.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
    2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-metro.0 (force=false, process=false)
    2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-plumb.0 (force=false, process=false)
    2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
    2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-weather.0 (force=false, process=false)
    2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis.0 (force=false, process=false)
    2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.web.0 (force=false, process=false)
    2024-05-03 18:21:24.102  - info: history.0 (97309) Terminated (NO_ERROR): Without reason
    2024-05-03 18:21:28.943  - error: history.0 (97309) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2024-05-03 18:21:28.946  - warn: history.0 (97309) get state error: Connection is closed.
    2024-05-03 18:21:28.950  - info: history.0 (97309) terminating
    2024-05-03 18:21:33.937  - warn: history.0 (97309) get state error: Connection is closed.
    2024-05-03 18:21:33.938  - info: history.0 (97309) terminating
    2024-05-03 18:21:33.952  - error: history.0 (97309) Cannot find view "system" for search "instance" : Connection is closed.
    Vielen Dank!
    djsirius
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • D djsirius
      Skript v.2024-04-21
      *** BASE SYSTEM ***
                 Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           4.0G          0B        4.0G
      Total:           11G        200M         10G
               7864 M total memory
                200 M used memory
                502 M active memory
               6534 M free memory
                175 M buffer memory
                954 M swap cache
               4015 M total swap
                  0 M used swap
               4015 M free swap
      *** FILESYSTEM ***
      /var:
      7.7G    /var/
      4.5G    /var/log
      2.5G    /var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.1
      javascript:
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 17
      Vielen Dank!
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @djsirius sagte in Nach Backup lässt iobroker nicht mehr starten:
      aber sicher nicht auf ein neu aufgesetztes Debian.
      Wahrscheinlich drüber gebügelt ?!
      Wenn Backitup dann auf ein frisches und aktuelles Bookworm ;)
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        @djmarc75 sagte in Nach Backup lässt iobroker nicht mehr starten:
        Und mit einem Standarduser, der nicht 'iobroker' heißt...
          djsirius
          @thomas-braun also soll ich erst Bookworm installieren und dann das Backup?
          djsirius
          • D djsirius
            Skript v.2024-04-21
            *** BASE SYSTEM ***
                       Chassis: desktop
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           4.0G          0B        4.0G
            Total:           11G        200M         10G
                     7864 M total memory
                      200 M used memory
                      502 M active memory
                     6534 M free memory
                      175 M buffer memory
                      954 M swap cache
                     4015 M total swap
                        0 M used swap
                     4015 M free swap
            *** FILESYSTEM ***
            /var:
            7.7G    /var/
            4.5G    /var/log
            2.5G    /var/cache/apt
            USB-Devices by-id:
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
            js-controller:
              throw err;
              requireStack: []
            Node.js v18.19.1
            admin:
              throw err;
              requireStack: []
            Node.js v18.19.1
            javascript:
            Adapter State
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
            Objects and States
            Objects:        0
            States:         0
            Pending Updates: 17
            Vielen Dank!
            @djsirius
            Patch die Kiste auf Stand.
            sudo apt update
            sudo apt full-upgrade
            dann
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            • D djsirius
              Das wäre die gescheiteste Lösung. Bullseye läuft in wenigen Wochen eh aus.
              Und installier das System diesmal gleich von vorneherein ohne Desktop. Und mit einem Username ungleich 'iobroker'. Gibt doch so schöne Vornamen. Oder Forennicks...
                djsirius
                @thomas-braun said in Nach Backup lässt iobroker nicht mehr starten:
                Hab alles gemacht. Der iobroker war kurz erreichbar. Dann wieder nicht. :(
                djsirius
                  djsirius
                  Dann muss ich da wohl mal ran! :-(
                  djsirius
                  • D djsirius
                    @djsirius
                    Aktuelles
                    iob diag
                    Ich würde aber so oder so eine Neuinstallation von Debian 12 'Bookworm' empfehlen. Wenn du da ohnehin schon schraubst...
                    • D djsirius
                      djsirius
                      iobroker@debian:/opt/iobroker$ iobroker start all
                      code_texnode:internal/modules/cjs/loader:1143
                        throw err;
                      Error: Cannot find module '@iobroker/js-controller-cli'
                      Require stack:
                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                          at Module._load (node:internal/modules/cjs/loader:981:27)
                          at Module.require (node:internal/modules/cjs/loader:1231:19)
                          at require (node:internal/modules/helpers:177:18)
                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js:1:1)
                          at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          at Module.load (node:internal/modules/cjs/loader:1203:32)
                          at Module._load (node:internal/modules/cjs/loader:1019:12)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:128:12) {
                        requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js        ' ]
                      Node.js v18.20.2
                      djsirius
                      • D djsirius
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                        djsirius
                        Skript v.2024-04-21
                        *** BASE SYSTEM ***
                                   Chassis: desktop
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         19:09:15 up 47 min,  1 user,  load average: 0.28, 1.18, 0.95
                        CPU threads: 4
                                       Local time: Fri 2024-05-03 19:09:15 CEST
                                   Universal time: Fri 2024-05-03 17:09:15 UTC
                                         RTC time: Fri 2024-05-03 17:09:15
                                      NTP service: active
                                  RTC in local TZ: no
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.9G        225M        5.8G        5.0M        1.9G        7.3G
                        Swap:           4.0G          0B        4.0G
                        Total:           11G        225M        9.8G
                                 7864 M total memory
                                  225 M used memory
                                  892 M active memory
                                  868 M inactive memory
                                 5761 M free memory
                                  164 M buffer memory
                                 1713 M swap cache
                                 4015 M total swap
                                    0 M used swap
                                 4015 M free swap
                        top - 19:09:15 up 47 min,  1 user,  load average: 0.28, 1.18, 0.95
                        Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  1.6 sy,  1.6 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7864.9 total,   5761.1 free,    225.1 used,   1878.7 buff/cache
                        MiB Swap:   4016.0 total,   4016.0 free,      0.0 used.   7336.6 avail Mem
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/sda2      ext4      454G   44G  387G  11% /
                        /var:
                        7.7G    /var/
                        4.5G    /var/log
                        2.5G    /var/cache/apt
                        USB-Devices by-id:
                        /usr/bin/nodejs         v18.20.2
                        /usr/bin/node           v18.20.2
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        /usr/bin/corepack       0.25.2
                        nodejs:
                          Installed: 18.20.2-1nodesource1
                          Version table:
                         *** 18.20.2-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                          throw err;
                        Require stack:
                            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                          requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
                        Node.js v18.20.2
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                        js-controller:
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                        admin:
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                        javascript:
                        Adapter State
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                          throw err;
                        Require stack:
                        Node.js v18.20.2
                        Objects and States
                        Objects:        0
                        States:         0
                        Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                        Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Hit:7 https://packages.sury.org/php bullseye InRelease
                        Pending Updates: 0
                        2024-05-03 19:06:33.548  - info: telegram.0 (29653) Got terminate signal TERMINATE_YOURSELF
                        2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.javascript.0 send kill signal
                        2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.telegram.0 send kill signal
                        2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.backitup.0 send kill signal
                        2024-05-03 19:06:33.556  - info: javascript.0 (29556) Got terminate signal TERMINATE_YOURSELF
                        2024-05-03 19:06:33.564  - info: javascript.0 (29556) terminating
                        2024-05-03 19:06:33.565  - info: javascript.0 (29556) Terminated (NO_ERROR): Without reason
                        2024-05-03 19:06:33.594  - info: backitup.0 (29743) terminating
                        2024-05-03 19:06:33.596  - info: backitup.0 (29743) Terminated (NO_ERROR): Without reason
                        2024-05-03 19:06:34.016  - info: backitup.0 (29743) terminating
                        2024-05-03 19:06:34.018  - info: javascript.0 (29556) terminating
                        2024-05-03 19:06:34.025  - info: telegram.0 (29653) terminating
                        2024-05-03 19:06:34.026  - info: telegram.0 (29653) Terminated (NO_ERROR): Without reason
                        2024-05-03 19:06:34.186  - info: host.debian instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                        2024-05-03 19:06:34.276  - info: host.debian instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                        2024-05-03 19:06:34.539  - warn: host.debian startInstance cannot find adapter "feiertage@1.2.0". Try to install it... 1 attempt
                        2024-05-03 19:06:34.540  - info: host.debian iobroker install feiertage@1.2.0 using installedFrom
                        2024-05-03 19:06:34.609  - error: host.debian iobroker npm-install: node:internal/modules/cjs/loader:1143  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)    at Module._load (node:internal/modules/cjs/loader:981:27)    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)    at node:internal/main/run_main_module:28:49 {  code: 'MODULE_NOT_FOUND',  requireStack: []}Node.js v18.20.2
                        2024-05-03 19:06:34.610  - info: host.debian iobroker npm-install: exit 1
                        2024-05-03 19:06:34.629  - info: host.debian instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                        2024-05-03 19:06:35.424  - info: history.0 (29452) terminating
                        2024-05-03 19:06:35.425  - info: history.0 (29452) Terminated (NO_ERROR): Without reason
                        2024-05-03 19:06:36.018  - info: host.debian instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                        2024-05-03 19:06:36.018  - info: host.debian All instances are stopped.
                        2024-05-03 19:06:36.196  - info: host.debian terminated
                        djsirius
                        • D djsirius
                          Skript v.2024-04-21
                          *** BASE SYSTEM ***
                                     Chassis: desktop
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                                        NTP service: active
                                    RTC in local TZ: no
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           4.0G          0B        4.0G
                                   7864 M total memory
                                    225 M used memory
                                    892 M active memory
                                   5761 M free memory
                                    164 M buffer memory
                                   1713 M swap cache
                                   4015 M total swap
                                      0 M used swap
                                   4015 M free swap
                          *** FILESYSTEM ***
                          /var:
                          7.7G    /var/
                          4.5G    /var/log
                          2.5G    /var/cache/apt
                          USB-Devices by-id:
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          js-controller:
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          admin:
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          javascript:
                          Adapter State
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          Objects and States
                          Objects:        0
                          States:         0
                          Pending Updates: 0
                          @djsirius
                          systemctl status iobroker.service
                          sagt?
                            @djsirius
                            sagt?
                            djsirius
                            iobroker@debian:/opt/iobroker$ systemctl status iobroker.service
                            ● iobroker.service - ioBroker Server
                                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                                 Active: activating (auto-restart) (Result: exit-code) since Fri 2024-05-03 19:23:41 CEST; 1s ago
                                   Docs: http://iobroker.net
                                Process: 35747 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                               Main PID: 35747 (code=exited, status=1/FAILURE)
                                    CPU: 56ms
                            Mai 03 19:23:44 debian bash[35757]: /opt/iobroker/node_modules/iobroker.js-controller/build/main.js:1200
                            Mai 03 19:23:44 debian bash[35757]:                     logger.error(`${hostLogPrefix} Invalid versions: ${(_j = (_h = (_g = a === null || a === void 0 ? void 0 : a.value) === null || _g =>
                            Mai 03 19:23:44 debian bash[35757]:        >
                            Mai 03 19:23:44 debian bash[35757]: SyntaxError: Unexpected end of input
                            Mai 03 19:23:44 debian bash[35757]:     at internalCompileFunction (node:internal/vm:76:18)
                            Mai 03 19:23:44 debian bash[35757]:     at wrapSafe (node:internal/modules/cjs/loader:1283:20)
                            Mai 03 19:23:44 debian bash[35757]:     at Module._compile (node:internal/modules/cjs/loader:1328:27)
                            Mai 03 19:23:44 debian bash[35757]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            Mai 03 19:23:44 debian bash[35757]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            Mai 03 19:23:44 debian bash[35757]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            Mai 03 19:23:44 debian bash[35757]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            Mai 03 19:23:44 debian bash[35757]:     at require (node:internal/modules/helpers:177:18)
                            Mai 03 19:23:44 debian bash[35757]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:9:1)
                            Mai 03 19:23:44 debian bash[35757]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            Mai 03 19:23:44 debian bash[35757]: Node.js v18.20.2
                            djsirius
                            • D djsirius
                                      CPU: 56ms
                              djsirius
                              So hab jetzt alles neu installiert. Es läuft auch soweit alles außer:
                              Der Info Adapter
                              djsirius
                              • D djsirius
                                Der Info Adapter
                                @djsirius
                                Der ist auch abgekündigt. Deinstallier den, der wird nicht mehr verwendet.
                                  djsirius
                                  @thomas-braun Dann hatte ich das doch richtig in Erinnerung.
                                  Ist deinstalliert! Vielen Dank!
                                  djsirius
