  4. Lovelace start PRoblem
    6.0k
33 Beiträge 4 Kommentatoren 4.3k Aufrufe 3 Beobachtet
    @esmax666 sagte in Lovelace start PRoblem:
    war das nicht richtig?
    Keine Ahnung was du da gemacht hast.
    Aber reboote die Kiste mal sauber, in den 200 Tagen uptime war mit Sicherheit auch ein Update dazwischen, das einen Neustart benötigt.
    iob stop
    sudo reboot
    Esmax666
    sudo apt update && sudo apt full-upgrade
    Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
    Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
    Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
    Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Building dependency tree... Done
    All packages are up to date.
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    ioBroker nodejs updater 2023-10-13
    Recommended nodejs-version is: 18.20.2
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1ubuntu2 500
            500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    Nothing to do - Your version is the recommended one.
    You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
    Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
    • E Esmax666
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
      @esmax666
      Dein 'Lunar Lobster' ist ohnehin verendet. Installier da die aktuelle LTS-Version von ubuntu. Oder das aktuelle Debian-Release.
      E 1 Antwort Letzte Antwort
      • David G.D Online
        David G.D Online
        David G.
        da hast du ein Adpater noch dazu oder
        Hab grad nochmal geschaut. Ist wirklich wohl kein Standarte. Dann inszallier ihn einfach ganz normal nach. Der ist es
        https://github.com/ioBroker/ioBroker.devices
        Findest du ganz normal im iobroker Repro.
          @esmax666
          Esmax666
          @thomas-braun Lunar ist doch noch weiter updated, aber ist egal habe ich aktuliasert
          nodeversion ist auch jetzt updated
          Hit:1 http://ports.ubuntu.com/ubuntu-ports noble InRelease
          Hit:2 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease
          Hit:3 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease
          Hit:4 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Version table:
               18.19.1+dfsg-6ubuntu5 500
                  500 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 Packages
          You can now keep your whole system up-to-date using the usual 'sudo apt update &                & sudo apt full-upgrade' commands.
          • E Esmax666
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
            Nein, der hat im Januar 2024 sein EndOfLife gehabt.
            Und lass das nodesource-Repo aktiv! Bzw. leg das wieder an.
            • David G.D David G.
              Esmax666
              @david-g said in Lovelace start PRoblem:
              Also das heisst "lovelace" funtionniert nur mit Device adapter ? slstam ich irgenwo ein Video gesehen wo jemand auch alias arbeitet und trotzdem ein paar gerät erkennt hat :/
                Esmax666
                @thomas-braun said in Lovelace start PRoblem:
                Was habe ich gemacht ? 🙄 und wie mache das wieder an, k.a was das ist :/
                • E Esmax666
                  Das weiß ich nicht. Jedenfalls hat du kein nodesource.list file auf deiner Kiste.
                  iob nodejs-update 18
                    Esmax666
                    ok fertig
                    ich hoffe das es jetzt ok ist
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Version table:
                    • E Esmax666
                      David G.D Online
                      David G.D Online
                      David G.
                      Jain,
                      es liegt daran welche Geräte man hat und wie diese eingebunden sind.
                      Woher soll lovelace wissen was es für ein Gerät ist und welche Datenpunkte dazu gehören, wenn es keine anhaltspunkte hat was was ist?
                      Dein z-wave legt wie es aussieht eine sehr wilde Datenstruktur an und die DPs haben auch keine entsprechenden Rollen. Woher soll da welcher Adapter auch immer was zuordnen können?
                      Ich nutze HomaticIP über eine CCU. Der Adapter legt alles sauber an und es klappt, sobald ich einen Raum vergebe.
                      Das wird dann auch gefunden.
                      Falls du deine Geräte in Alexa oder Google Home bringen möchtest, hast du genau das selbe Vorgehen wie bei lovelace. Auch diese Adapter benötigen ein paar Infos.....
                      Bei Geräten mir nur einem DP, ist es natürlich über das Zahnrad viel leichter.
                        Jain,
                        Esmax666
                        @david-g
                        ok ich werde das adapter später probieren :)
                        Das heisst in Home assistant zum beispiel die müssen auch dann mit "Alias" arbeiten oder ?
                        Hast du auch HeatingControl ?
                        könntest du etwas machen für Lovelece ? da ich eher weniger skript erfahung habe denke ich am ende muss VIS + Lovelece haben
                        • E Esmax666
                          @david-g
                          David G.D Online
                          David G.D Online
                          David G.
                          @esmax666
                          HA geht mit den Sachen ganz anders um.
                          Da sind die Integration (deren Adapter) schon so geschrieben, dass das alles funktioniert.
                          Iobroker hatte diesen Ansatz früher noch nicht. So weit ich weiß, wird da aber dran gearbeitet.
                          Heating Control nutze ich nicht. Aber das hat ja auch nichts mit einer Visualisierung zu tun.
                          Ich denke, man sollte sich für eins entscheiden. Vis oder lovelace (oder sonst was).
                            @esmax666
                            Esmax666
                            @david-g ach so ok, ja ich habe das heute früh probiert,
                            also loveless + HA macht das wirklich alles automatisch das ist wirklich crazy, alles zwave geräte sind schon da und sogar auf dashboard. die haben das wirklich gut gemacht aber mit VIS1/2 kann man besser personalisieren (finde ich)
                            ich will nur ein bisschen beide probieren :)
