  4. IoBroker zerschossen, nach Update
10 Beiträge 2 Kommentatoren 934 Aufrufe 2 Beobachtet
  • HomeWolfH Offline
    HomeWolfH Offline
    HomeWolf
    ich habe heute manuell nach der Anleitung IoBroker ein update durchgeführt. IoBroker läuft unter Windows.
    Leider startet jetzt nichts mehr. Hier ist das Log
    0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
    1 info using npm@9.6.7
    2 info using node@v18.17.1
    3 timing npm:load:whichnode Completed in 3ms
    4 timing config:load:defaults Completed in 2ms
    5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 5ms
    6 timing config:load:builtin Completed in 6ms
    7 timing config:load:cli Completed in 2ms
    8 timing config:load:env Completed in 0ms
    9 timing config:load:file:C:\ioBroker\.npmrc Completed in 6ms
    10 timing config:load:project Completed in 8ms
    11 timing config:load:file:C:\Users\Administrator\.npmrc Completed in 0ms
    12 timing config:load:user Completed in 0ms
    13 timing config:load:file:C:\Users\Administrator\AppData\Roaming\npm\etc\npmrc Completed in 0ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 1ms
    16 timing config:load Completed in 20ms
    17 timing npm:load:configload Completed in 20ms
    18 timing npm:load:mkdirpcache Completed in 0ms
    19 timing npm:load:mkdirplogs Completed in 0ms
    20 verbose title npm exec @iobroker/fix
    21 verbose argv "exec" "--" "@iobroker/fix"
    22 timing npm:load:setTitle Completed in 1ms
    23 timing config:load:flatten Completed in 3ms
    24 timing npm:load:display Completed in 4ms
    25 verbose logfile logs-max:10 dir:C:\Users\Administrator\AppData\Local\npm-cache\_logs\2024-04-14T09_13_50_586Z-
    26 verbose logfile C:\Users\Administrator\AppData\Local\npm-cache\_logs\2024-04-14T09_13_50_586Z-debug-0.log
    27 timing npm:load:logFile Completed in 13ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 43ms
    31 silly logfile start cleaning logs, removing 4 files
    32 timing arborist:ctor Completed in 1ms
    33 silly logfile done cleaning log files
    34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    35 http fetch GET 200 https://registry.npmjs.org/@iobroker%2ffix 1713ms (cache miss)
    36 timing arborist:ctor Completed in 0ms
    37 timing arborist:ctor Completed in 1ms
    Das ist das Ergebnis, wenn ich iobroker Status abfrage.
    C:\ioBroker>iobroker status
    C:\ioBroker\node_modules\iobroker.js-controller\lib\objects.js:12
        throw 'Unknown objects type: ' + config.objects.type;
    Unknown objects type: jsonl
    (Use `node --trace-uncaught ...` to show where the exception was thrown)
    Node.js v18.17.1
    Kann mir jemand helfen?
    • HomeWolfH HomeWolf
      Node.js v18.17.1
      sigi234S Online
      sigi234S Online
      sigi234
      @homewolf sagte in IoBroker zerschossen, nach Update:
      Warum nicht mit dem Installer?
      https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
      Immer Daten sichern!
      HomeWolfH 1 Antwort Letzte Antwort
      • sigi234S sigi234
        HomeWolfH Offline
        HomeWolfH Offline
        HomeWolf
        @sigi234 said in IoBroker zerschossen, nach Update:
        Gute Frage, da es in der Weboberfläche so angezeigt wurde.
        Meinst du es macht sin, jetzt die Installer noch mal drüber laufen zulassen oder verschlimmert das nur die Situation ?
          sigi234S Online
          sigi234S Online
          sigi234
          Nein, iob stoppen , iobroker-data Ordner kopieren und extern sichern
          iob neu installieren aber den Host anders benennen und bei der Installation mit dem Installer den gesicherten iobroker-data Ordner auswählen.
          https://github.com/ioBroker/ioBroker.build/blob/master/Windows-Installer.md
          • sigi234S sigi234
            HomeWolfH Offline
            HomeWolfH Offline
            HomeWolf
            schrieb am zuletzt editiert von HomeWolf
            @sigi234 danke schon mal, habe ich nun gemacht und der neue IoBroker läuft wieder... ich schaue jetzt mal ob alles läuft und alles beim alten ist. Danke schon mal vorab
              HomeWolfH Offline
              HomeWolfH Offline
              HomeWolf
              @homewolf said in IoBroker zerschossen, nach Update:
              Also bis jetzt läuft alles. Ich weiß nicht ob ich das falsch verstanden hatte, aber ich habe die neue Installation im Ordner iobroker_neu gemacht. Wenn alles geht, kann ich dann einfach den alten Ordner löschen und den Ordner iobroker_neu umbennen in iobroker?
                sigi234S Online
                sigi234S Online
                sigi234
                Nein
                • sigi234S sigi234
                  Nein
                  HomeWolfH Offline
                  HomeWolfH Offline
                  HomeWolf
                  @sigi234 ok...
                  beides nein oder kann man den alten Ordner wenigstens löschen ?
                    @sigi234 ok...
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    @sigi234 ok...
                    Mit dem Installer deinstallieren
                    • sigi234S sigi234
                      @sigi234 ok...
                      HomeWolfH Offline
                      HomeWolfH Offline
                      HomeWolf
                      @sigi234 ich bekomme da nirgends die Möglichkeit, zu deinstallierte ?
                      Zu deinem Bild, das habe ich so ausgewählt, nur das ich vorab halt einen andern Ordner gewählt hatte.
