  4. Windows "Der Name für den Dienst ist ungültig"
2 Beiträge 2 Kommentatoren 515 Aufrufe 2 Beobachtet
  • G Offline
    gooflo
    Hallo, ich wollte iobroker zunächst mal auf Windwos kurz testen, bevor es auf einen Raspi geht. Leider schlägt die Installation fehl. Weiß jemand Rat?
    Npm prefix path exists: C:\Users\flori\AppData\Roaming\npm
    Windows installation starting... (fixing = false)
    NPM version: 10.2.4
    npm WARN config production Use --omit=dev instead.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 568 packages, and audited 569 packages in 34s
    60 packages are looking for funding
    run npm fund for details
    25 vulnerabilities (1 low, 20 moderate, 4 high)
    To address issues that do not require attention, run:
    npm audit fix
    To address all issues (including breaking changes), run:
    npm audit fix --force
    Run npm audit for details.
    Write "iobroker start" to start the ioBroker
    npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
    up to date, audited 569 packages in 2s
    npm audit fix
    npm install dotenv@^16.0.3 --force --loglevel error --production --save --prefix "C:/ioBroker"
    changed 1 package, and audited 569 packages in 2s
    59 packages are looking for funding
    npm audit fix
    npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
    npm audit fix
    Written iobnodevars.bat successfully.
    Startmenu folder C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform created!
    loc: 'winsw.js ~line 77',
    xml: [
    { id: 'iobroker.exe' },
    { name: 'ioBroker' },
    { description: 'ioBroker service.' },
    { executable: 'C:\Program Files\nodejs\node.exe' },
    { argument: '--harmony' },
    argument: 'C:\ioBroker\node_modules\node-windows\lib\wrapper.js'
    config: {
    nodeOptions: '--harmony',
    script: 'C:\ioBroker\node_modules\node-windows\lib\wrapper.js',
    scriptOptions: '',
    wrapperArgs: [
    '--file',
    'C:\ioBroker\controller.js',
    '--scriptoptions=',
    '--log',
    'ioBroker wrapper',
    '--grow',
    0.25,
    '--wait',
    1,
    '--maxrestarts',
    3,
    '--abortonerror',
    'n',
    '--stopparentfirst',
    undefined
    description: 'ioBroker service.',
    logpath: null,
    env: { name: 'NODE_ENV', value: 'production' },
    execPath: null,
    logOnAs: {
    account: null,
    password: null,
    domain: 'SNOOPY4',
    mungeCredentialsAfterInstall: true
    workingdirectory: 'C:\ioBroker',
    stopparentfirst: undefined,
    stoptimeout: 30,
    logmode: 'rotate',
    logging: undefined,
    allowServiceLogon: undefined
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
    ioBroker started!
    Visit http://127.0.0.1:8081 to configure it.
    Running Admin shell
    ioBroker service name: ioBroker
    Der Name fr den Dienst ist ungltig.
    Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 2185 eingeben.
    ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
    To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
    • G gooflo
      NPM version: 10.2.4
      npm audit fix
      npm audit fix
      npm audit fix
      npm audit fix
      xml: [
      config: {
      scriptOptions: '',
      wrapperArgs: [
      '--file',
      '--scriptoptions=',
      '--log',
      'ioBroker wrapper',
      '--grow',
      0.25,
      '--wait',
      1,
      '--maxrestarts',
      3,
      '--abortonerror',
      'n',
      undefined
      logpath: null,
      execPath: null,
      logOnAs: {
      account: null,
      password: null,
      domain: 'SNOOPY4',
      stoptimeout: 30,
      logmode: 'rotate',
      logging: undefined,
      ioBroker started!
      Running Admin shell
      sigi234S Online
      sigi234S Online
      sigi234
      @gooflo
      Warum nimmst du nicht den Installer?
      https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
      Immer Daten sichern!
