  4. Bekomme öfters "warn get state error: Connection is closed"
2 Beiträge 2 Kommentatoren 433 Aufrufe 2 Beobachtet
  • Chris76eC Offline
    Chris76eC Offline
    Chris76e
    was beudetet die Warnung? Bekomme das sehr oft, meistens bei ical instanzen.
    iceroad.0	2024-03-11 18:00:52.080	warn	get state error: Connection is closed.
    iceroad.0	2024-03-11 18:00:51.576	info	Terminated (NO_ERROR): Without reason
    iceroad.0	2024-03-11 18:00:50.814	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.iceroad, node: v18.19.0, js-controller: 5.0.19
    ical.4	2024-03-11 18:34:09.387	warn	get state error: Connection is closed.
    ical.4	2024-03-11 18:34:08.880	info	Terminated (NO_ERROR): Without reason
    ical.4	2024-03-11 18:34:03.719	info	processing URL: Musikverein https://calendar
    ical.4	2024-03-11 18:34:03.635	info	processing URL: Abfall https://calendar.google.
    ical.4	2024-03-11 18:34:03.469	info	processing URL: Christian https://calendar
    ical.4	2024-03-11 18:34:03.373	info	processing URL: Geburtstage https://calendar.google.com
    ical.4	2024-03-11 18:34:03.189	info	processing URL: Feiertage https://calendar.google.com/
    ical.4	2024-03-11 18:34:02.526	info	starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
    ical.7	2024-03-11 18:00:25.369	warn	get state error: Connection is closed.
    ical.7	2024-03-11 18:00:24.801	info	Terminated (NO_ERROR): Without reason
    ical.7	2024-03-11 18:00:19.659	info	processing URL: calendar1 https:/
    ical.7	2024-03-11 18:00:19.113	info	starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
    • CodierknechtC Offline
      Codierknecht
      Ich bringe den Beitrag mal wieder nach vorne.
      Tritt bei mir ebenfalls regelmäßig auf:
      ical.0    2024-05-03 06:02:06.328	warn	get state error: Connection is closed.
      ical.1    2024-05-03 00:04:07.050	warn	get state error: Connection is closed.
      Da wird wohl versucht etwas zu lesen, nachdem die Verbindung zur DB bereits geschlossen wurde.
      Das passende Issue dazu hat @wendy2702 ja bereits erzeugt:
      https://github.com/iobroker-community-adapters/ioBroker.ical/issues/630
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
