  4. Harmony Adapter versagt seinen Dienst !
94 Beiträge 9 Kommentatoren 15.4k Aufrufe 6 Beobachtet
  • S Springreiter
    @codierknecht ```
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-28-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     13:53:23 up 43 min,  2 users,  load average: 0.82, 0.39, 0.26
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-18 13:53:23 CET
               Universal time: Sun 2024-02-18 12:53:23 UTC
                     RTC time: Sun 2024-02-18 12:53:24
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dw
    /home/dw
    dw cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            6.8G        1.5G        4.4G        0.0K        897M        5.0G
    Swap:           974M          0B        974M
    Total:          7.8G        1.5G        5.4G
             6779 M total memory
             1504 M used memory
              337 M active memory
             1712 M inactive memory
             4376 M free memory
              180 M buffer memory
              717 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.3G     0  3.3G   0% /dev
    tmpfs          tmpfs     678M  540K  678M   1% /run
    /dev/sda1      ext4       39G   11G   26G  30% /
    tmpfs          tmpfs     3.4G     0  3.4G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     678M     0  678M   0% /run/user/1000
    [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Feb 18 13:09:46 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems \(real ones only\):
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    2.5G    /var/
    2.0G    /var/log
    1.9G    /var/log/journal/355caa6989dc454583274fa76a04282b
    405M    /var/cache
    Archived and active journals take up 136.0M in the file system.
    /opt/iobroker/backups:
    187M    /opt/iobroker/backups/
    572K    /opt/iobroker/backups/Testumgebung
    376K    /opt/iobroker/backups/common
    288K    /opt/iobroker/backups/Rollosteuerung
    176K    /opt/iobroker/backups/Anrufe
    /opt/iobroker/iobroker-data:
    1010M   /opt/iobroker/iobroker-data/
    711M    /opt/iobroker/iobroker-data/files
    207M    /opt/iobroker/iobroker-data/backup-objects
    150M    /opt/iobroker/iobroker-data/files/vis-2
    78M     /opt/iobroker/iobroker-data/files/vis-2/static
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   9
    Adapter State
      system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.hyperion_ng.0            : hyperion_ng           : iobroker                                 - disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.km200.0                  : km200                 : iobroker                                 - disabled
      system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 - disabled
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
      system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
      system.adapter.rssfeed.0                : rssfeed               : iobroker                                 - disabled
      system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
      system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
      system.adapter.web.2                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "ems-esp"      : 2.8.0    , installed 2.8.0
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
    Adapter    "radar2"       : 2.1.0    , installed 2.1.0
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "vw-connect"   : 0.0.67   , installed 0.2.2
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        17333
    States:         12967
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://ftp.de.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.de.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.59:2001     0.0.0.0:*               LISTEN      1001       102886     60347/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13387      480/sshd: /usr/sbin
    tcp        0      0 192.168.178.59:2010     0.0.0.0:*               LISTEN      1001       102920     60362/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       104105     60407/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       102973     60392/io.mqtt.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       101345     60142/iobroker.js-c
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        12992      442/redis-server 12
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10634      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       102423     60160/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13408      480/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       106247     61395/io.harmony.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      108        12993      442/redis-server 12
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10639      1/init
    udp        0      0 192.168.178.59:5353     0.0.0.0:*                           1001       104237     60567/io.tr-064.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12794      400/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11657      1/init
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       106248     61395/io.harmony.0
    udp6       0      0 :::111                  :::*                                0          11662      1/init
    2024-02-18 13:53:44.514  - error: javascript.0 (60217)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
    2024-02-18 13:53:44.514  - error: javascript.0 (60217)     at processImmediate (node:internal/timers:476:21)
    2024-02-18 13:53:47.222  - info: host.iobroker instance scheduled system.adapter.daswetter.0 */15 * * * *
    2024-02-18 13:53:47.226  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 60733
    2024-02-18 13:53:48.431  - info: daswetter.0 (60733) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 13:53:51.168  - info: host.iobroker instance system.adapter.device-reminder.0 started with pid 60763
    2024-02-18 13:53:53.301  - warn: zigbee.0 (60592) DeviceAvailability:Failed to ping 0x00158d00053aceb8 tint-ColorTemperature
    2024-02-18 13:53:54.004  - info: device-reminder.0 (60763) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 13:53:55.147  - info: host.iobroker instance scheduled system.adapter.dwd.0 */5 * * * *
    2024-02-18 13:53:55.150  - info: host.iobroker instance system.adapter.dwd.0 started with pid 60785
    2024-02-18 13:53:56.961  - info: dwd.0 (60785) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 13:53:57.581  - info: dwd.0 (60785) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-02-18 13:53:58.171  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-18 13:53:59.132  - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 60811
    2024-02-18 13:53:59.493  - info: daswetter.0 (60733) still wrong data structure from server received! repaired...
    2024-02-18 13:54:00.697  - info: fullybrowser.0 (60811) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 13:54:00.732  - warn: fullybrowser.0 (60811) Adapter instance settings: REST API timeout of undefined ms is not allowed, set to default of 10000ms
    2024-02-18 13:54:00.734  - info: fullybrowser.0 (60811) 🗸 192.168.178.109 (192.168.178.109): Config successfully verified.
    2024-02-18 13:54:01.601  - info: fullybrowser.0 (60811) 🚀 Start RESTApi request intervall
    2024-02-18 13:54:02.061  - info: daswetter.0 (60733) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-02-18 13:54:02.569  - info: daswetter.0 (60733) cleaned everything up...
    2024-02-18 13:54:02.638  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-18 13:54:03.128  - info: host.iobroker instance system.adapter.harmony.0 started with pid 61395
    2024-02-18 13:54:04.165  - info: harmony.0 (61395) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 13:54:04.197  - info: harmony.0 (61395) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #41
    @springreiter
    Ich bin jetzt auch kein Kind von Traurigkeit was Adapter aus dem "Beta-Repo" angeht, aber Du bist ja im Stable und dann:
    @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
    Ebenso kommt mir der Port 6379 in Deinem LOG (Harmony-Adapter) nicht ganz korrekt vor:
    Da kenn ich mich aber nicht so gut aus, vll weiß da jemand weiter ;)
    Lehrling seit 1975 !!!
    S HomoranH 2 Antworten Letzte Antwort
    • DJMarc75D DJMarc75
      @springreiter
      Springreiter
      #42
      @djmarc75 said in Harmony Adapter versagt seinen Dienst !:
      6379
      Eigentlich läuft das System seit Jahren problemlos, der Harmony Adapter hat lediglich seit Donnerstag oder Freitag den Dienst versagt, nach dem einige Adapter (der Harmony nicht) ganz normal aktualisiert wurden. ( Mqtt, Zigbee u.a.) Das der eine oder andere Adapter mal über Github installiert wurde ist wohl historisch bedingt, dass System läuft ja schon einige Jahre.
        @springreiter
        HomoranH Offline
        HomoranH Offline
        #43
        @djmarc75 sagte in Harmony Adapter versagt seinen Dienst !:
        wo siehst du das?
        6379 ist redis
        darüber die 61991 bei ipv6 ist harmony, aber warum?
          wo siehst du das?
          6379 ist redis
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #44
          @homoran sagte in Harmony Adapter versagt seinen Dienst !:
          wo siehst du das?
          2024-02-18 11:38:31.091 - debug: harmony.0 (4156085) States connected to redis: 127.0.0.1:6379
          edit: aber wie geschrieben kenn ich mich mit Ports & Co nicht aus
            wo siehst du das?
            Springreiter
            #45
            IPv6 ist schon komisch, benutze eigentlich nur ipv4
              wo siehst du das?
              HomoranH Offline
              HomoranH Offline
              #46
              der Adapter verbindet sich beim Start mit der DB! und die läuft auf 6379
              Das ist ok
              • Thomas BraunT Online
                #47
                Dein System verwendet richtigerweise beides.
                Räum die Repos auf.
                iob repo del sources
                iob repo del online
                • S Springreiter
                  #48
                  @springreiter
                  Und setz den User noch in die Gruppe adm rein.
                    @springreiter
                    Springreiter
                    #49
                    @thomas-braun also erst einmal die beiden Befehle eingeben?
                    • S Springreiter
                      #50
                      @springreiter
                      Ja.
                        @springreiter
                        Ja.
                        Springreiter
                        #51
                        @thomas-braun erledigt, und den user adm mit /usr/sbin/usermod -aG adm ?
                        • S Springreiter
                          #52
                          @springreiter
                          sudo usermod -a -G adm dw
                          S 2 Antworten Letzte Antwort
                            @springreiter
                            Springreiter
                            #53
                              @springreiter
                              Springreiter
                              #54
                              @thomas-braun mein Harmony - Adapter baut aber immer noch kein Baum auf
                              • S Springreiter
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #55
                                @springreiter hast du das loggen der Instanz mal auf Debug gestellt und kannst das dann als Text hier in Code Tags posten.
                                Den Hub mal neu gestartet?
                                S 3 Antworten Letzte Antwort
                                • wendy2702W wendy2702
                                  Springreiter
                                  #56
                                  @wendy2702
                                  armony.0
                                  2024-02-18 19:13:03.026	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
                                  harmony.0
                                  2024-02-18 19:13:03.015	debug	[START] Subnet: 255.255.255.255, Discovery interval: 10000
                                  harmony.0
                                  2024-02-18 19:13:03.001	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
                                  harmony.0
                                  2024-02-18 19:13:02.882	debug	States connected to redis: 127.0.0.1:6379
                                  harmony.0
                                  2024-02-18 19:13:02.877	debug	States create User PubSub Client
                                  harmony.0
                                  2024-02-18 19:13:02.877	debug	States create System PubSub Client
                                  harmony.0
                                  2024-02-18 19:13:02.872	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                  harmony.0
                                  2024-02-18 19:13:02.840	debug	Objects connected to redis: 127.0.0.1:9001
                                  harmony.0
                                  2024-02-18 19:13:02.836	debug	Objects client initialize lua scripts
                                  harmony.0
                                  2024-02-18 19:13:02.778	debug	Objects create User PubSub Client
                                  harmony.0
                                  2024-02-18 19:13:02.777	debug	Objects create System PubSub Client
                                  harmony.0
                                  2024-02-18 19:13:02.772	debug	Objects client ready ... initialize now
                                  harmony.0
                                  2024-02-18 19:13:02.739	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  harmony.0
                                  2024-02-18 19:12:59.322	info	terminating
                                  harmony.0
                                  2024-02-18 19:12:58.820	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  harmony.0
                                  2024-02-18 19:12:58.820	info	terminating
                                    Springreiter
                                    #57
                                    @wendy2702 Hub hatte ich schon mehrmals neu gestartet
                                      Springreiter
                                      #58
                                      @wendy2702
                                      2024-02-18 19:13:01.891 - info: host.iobroker instance system.adapter.harmony.0 started with pid 510833
                                      2024-02-18 19:13:02.739 - debug: harmony.0 (510833) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2024-02-18 19:13:02.772 - debug: harmony.0 (510833) Objects client ready ... initialize now
                                      2024-02-18 19:13:02.777 - debug: harmony.0 (510833) Objects create System PubSub Client
                                      2024-02-18 19:13:02.778 - debug: harmony.0 (510833) Objects create User PubSub Client
                                      2024-02-18 19:13:02.836 - debug: harmony.0 (510833) Objects client initialize lua scripts
                                      2024-02-18 19:13:02.840 - debug: harmony.0 (510833) Objects connected to redis: 127.0.0.1:9001
                                      2024-02-18 19:13:02.872 - debug: harmony.0 (510833) Redis States: Use Redis connection: 127.0.0.1:6379
                                      2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create System PubSub Client
                                      2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create User PubSub Client
                                      2024-02-18 19:13:02.882 - debug: harmony.0 (510833) States connected to redis: 127.0.0.1:6379
                                      2024-02-18 19:13:03.001 - info: harmony.0 (510833) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
                                      2024-02-18 19:13:03.015 - debug: harmony.0 (510833) [START] Subnet: 255.255.255.255, Discovery interval: 10000
                                      2024-02-18 19:13:03.026 - info: harmony.0 (510833) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
                                      MOD EDIT: CODE TAGS Korrigiert
                                      wendy2702W FredFF 2 Antworten Letzte Antwort
                                      • S Springreiter
                                        @wendy2702
                                        armony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        harmony.0
                                        CodierknechtC Offline
                                        Codierknecht
                                        #59
                                        @springreiter
                                        Die 3 Backticks für die Code-Tags müssen jeweils in eigenen Zeilen stehen.
                                        HmIP|ZigBee|Tasmota|Unifi
                                        Zabbix Certified Specialist
                                        • S Springreiter
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          wendy2702
                                          #60
                                          Was kommt nach den 10000msec im log ?
