  3. Einsteigerfragen
  4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
30 Beiträge 6 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • R raVsu
    @glasfaser
    iob stop
    iob fix
    iob start
    dann
    iob nodejs-update
    durchgeführt
    ioBroker nodejs updater 2023-10-13
    Recommended nodejs-version is: 18.19.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
    /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
    /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
    *** nodejs is NOT correctly installed ***
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
            100 /var/lib/dpkg/status
         18.13.0+dfsg1-1 500
         14.21.3-deb-1nodesource1 1001
            500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
    Your nodejs-Installation seems to be faulty. Shall we try to fix it?
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting  ***
    rm: cannot remove '': No such file or directory
    *** Deleting  ***
    Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
    Nothing to do - Your version is the recommended one.
    You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
    Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
    jetzt wird folgendes angezeigt:
    @ravsu
    https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
    R 1 Antwort Letzte Antwort
    • R raVsu
      @glasfaser
      iob stop
      iob fix
      iob start
      dann
      iob nodejs-update
      durchgeführt
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      *** Deleting  ***
      *** Deleting  ***
      @ravsu
      bitte in code-tags setzen!
      bitte nicht nur selektierte Ausschnitte posten!
        @ravsu
        raVsu
        Danke für den Link.
        Bei dem Befehl
        sudo apt install nodejs=18.19.0-1nodesource1
        wird am ende eine Fehlermeldung geliefert:
        E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
        pi@iobroker:~$ apt policy nodejs
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
        sudo apt update
        iob stop
        sudo apt remove npm
        iob restart
        Package: nodejs
        Pin-Priority: 1001
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
        Fetched 4586 B in 1s (4087 B/s)
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        Package 'npm' is not installed, so not removed
        The following packages were automatically installed and are no longer required:
          distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
          libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
          libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
          libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
          libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
          libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
          libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
          libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
          liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
          libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
          libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
          libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
          libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
          libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
          libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
          linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
          node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
          node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
          node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
          node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
          node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
          node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
          node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
          node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
          node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
          node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
          node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
          node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
          node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
          node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
          node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
          node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
          node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
          node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
          node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
          node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
          node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
          node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
          node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
          node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
          node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
          node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
          node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
          node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
          node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
          node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
          node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
          node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
          node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
          node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
          node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
          node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
          node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
          node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
          node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
          node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
          node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
          node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
          node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
          node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
          node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
          node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
          node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
          node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
          node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
          node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
          pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
          xdg-utils zutty
        Use 'sudo apt autoremove' to remove them.
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Package nodejs is not available, but is referred to by another package.
        This may mean that the package is missing, has been obsoleted, or
        is only available from another source
        However the following packages replace it:
          nodejs-doc
        • R raVsu
          Danke für den Link.
          Bei dem Befehl
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          sudo apt update
          iob stop
          sudo apt remove npm
          iob restart
          Package: nodejs
          Pin-Priority: 1001
            xdg-utils zutty
            nodejs-doc
          @ravsu
          Da fehlt die nodesource.list
          iob nodejs-update 18
          legt die aber eigentlich an.
          Zuvor
          sudo apt autoremove
          sudo apt remove node-* nodejs-doc
          dann
          sollte zu einer richtigen Installation führen.
            @ravsu
            raVsu
            danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
            • R raVsu
              @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
              das und noch viel mehr nützliches steht hier
                @ravsu
                Zuvor
                sudo apt autoremove
                dann
                raVsu
                Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                Besseren support kann man nicht haben.
                Danke an alle.
                • R raVsu
                  Danke an alle.
                  Und was sagt ein erneutes
                  iob nodejs-update
                  Und ein
                  apt policy nodejs
                  liefert?
                    iob nodejs-update
                    Und ein
                    apt policy nodejs
                    liefert?
                    raVsu
                    schrieb am zuletzt editiert von raVsu
                    @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                    iob nodejs-update
                    Alles bestens 😄
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0+dfsg1-1 500
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Nothing to do - Your installation is using the correct paths.
                    • R raVsu
                      iob nodejs-update
                      Alles bestens 😄
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      @ravsu
                      Ja, jetzt passt es.
