  4. Node-Red
  5. Wie kann ich Zwei Analogwerte vergleichen.
    6.4k
node-red
18 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    Armin 2
    Ich versuche Zwei Analogwerte zu vergleichen und eine Ausgang zu setzen, wie geht das.
            "id": "11059b537c80fb33",
            "type": "tab",
            "label": "Flow 2",
            "disabled": false,
            "info": "",
            "env": []
            "id": "bcdb24e1da584220",
            "type": "Comparator",
            "z": "11059b537c80fb33",
            "name": "Comparator",
            "property": "payload",
            "math": ">=",
            "topic1": "alpha-ess.0.Realtime.Battery_SOC",
            "topic2": "???",
            "x": 750,
            "y": 320,
            "wires": [
                    "e3bc9953db368ee5"
            "id": "e3bc9953db368ee5",
            "type": "StatusUltimate",
            "name": "Ausgang",
            "x": 940,
            "y": 320,
            "wires": [
            "id": "5172b14316cef3e5",
            "type": "ioBroker in",
            "name": "",
            "attrname": "payload",
            "topic": "alpha-ess.0.Realtime.Battery_SOC",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 280,
            "y": 260,
            "wires": [
                    "bcdb24e1da584220"
            "id": "a0a95ab389b49c0f",
            "type": "change",
            "name": "zweiter Wert",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": " 90",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 410,
            "y": 360,
            "wires": [
                    "bcdb24e1da584220"
            "id": "a7f2b0a13a124068",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 200,
            "y": 360,
            "wires": [
                    "a0a95ab389b49c0f"
    HomoranH mickymM 2 Antworten Letzte Antwort
    • A Armin 2
              "type": "tab",
              "label": "Flow 2",
              "disabled": false,
              "info": "",
              "env": []
              "math": ">=",
              "topic2": "???",
              "x": 750,
              "y": 320,
              "wires": [
                      "e3bc9953db368ee5"
              "name": "Ausgang",
              "x": 940,
              "y": 320,
              "wires": [
              "name": "",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 280,
              "y": 260,
              "wires": [
                      "bcdb24e1da584220"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": " 90",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 410,
              "y": 360,
              "wires": [
                      "bcdb24e1da584220"
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 200,
              "y": 360,
              "wires": [
                      "a0a95ab389b49c0f"
      HomoranH Offline
      HomoranH Offline
      @armin-2 und was genau willst du jetzt wissen?
      • A Armin 2
                "type": "tab",
                "label": "Flow 2",
                "disabled": false,
                "info": "",
                "env": []
                "math": ">=",
                "topic2": "???",
                "x": 750,
                "y": 320,
                "wires": [
                        "e3bc9953db368ee5"
                "name": "Ausgang",
                "x": 940,
                "y": 320,
                "wires": [
                "name": "",
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 280,
                "y": 260,
                "wires": [
                        "bcdb24e1da584220"
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": " 90",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 410,
                "y": 360,
                "wires": [
                        "bcdb24e1da584220"
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "",
                "x": 200,
                "y": 360,
                "wires": [
                        "a0a95ab389b49c0f"
        mickymM Offline
        mickymM Offline
        mickym
        @armin-2 um 2 Werte zu vergleichen musst du diese in ein Nachrichtenobjekt aufnehmen
        und keine komischen Nodes verwenden
        sondern lieber Standard Nodes
          Armin 2
          @mickym
          Und wie geht das, kannst du meinen flow vielleicht mal anpassen??
          • A Armin 2
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @armin-2 Na ja aus Deinem Flow kann man nicht sehr viel entnehmen. Der 2. Werte ist ja auch noch ein String und 90 mit dem Du das vergleichst. Ausserdem schreibst Du überhaupt nichts was triggern soll und wiw gesagt - diese Nodes zum Vergleichen werde ich sicher nicht installieren.
            Also wenn Du 2 Zahlen vergleichen willst musst Du auch bitte Zahlen nicht mit Strings vergleichen sondern auch mit einer Zahl
            Also Datentyp beachten.
            Du hast grundsätzlich mehrere Möglichkeiten Werte zu vergleichen. Da ich von Dir weder was triggered noch den Hintergrund erfahre überlege ich mir selbst einfach mal Szenarien.
            1. Möglichkeit - arbeiten über den Kontext.
            Nehmen wir einmal an Du möchtest mehrere Werte mit einem dynamisch festgelegten Schwellenwert laufen lassen.
            Die beiden Werte von fiktiven Temperatursensoren (sensor1 und sensor2) sollen also mit einem Schwellenwert aus dem Datenpunkt Wert verglichen werden. Für sowas bietet sich der Kontext an, da sich der Schwellenwert ja nicht so häufig ändert (man muss den aber ggf. initialisieren) also in jedem Fall Fire on Start in der iobroker-In auswählen.
            Legen wir also mal fest, dass bei >= 25 °C der Flow verzweigt werden soll.
            Wir lesen also den Schwellenwert sofort aus, wenn der Flow gestartet ist:
            Diesen Schwellenwert speichern wir im Flow Kontext:
            Wenn nun einer der fiktivien Temperatursensoren triggert, dann vergleichen wir diese Temperatur mit dem Schwellenwert - sagen wir mal >=25 und <25
            Die beiden werden also nicht gegeneinander sondern gegen den Schwellenwert also einer 3. Zahl verglichen, die aber ebenfalls dynamisch aus den Objekten genutzt werden.
            Man sieht also jeder Sensorwert wird mit dem Schwellenwert im Kontext verglichen und dann an den entsprechenden Ausgang geschickt.
            1. Die nächste Möglichkeit ist, dass die beiden Datenpunkte unabhängig von einander triggern lässt und sofort den 2. zu vergleichenden Wert holt.
            Wir vergleichen also wieder Temperatur1 mit Temperatur2 und wollen sofort das Ergebnis haben.
            Wir müssen also immer den 2. Wert aktiv holen, das macht man mit einer iobroker-get Node.
            Damit das besser unterscheiden kann, werden wir die payload der Nachrichteneigenschaft der iobroker-In Node gleich in unterschiedliche Nachrichteneigenschaften gepackt.
            Wir packen also sowohl in der iobroker-IN-Node als auch in der iobroker-GET Node - die Werte in die Nachrichteneigenschaft temp1 und temp2
            Hier mal die iobroker-In des 1. fiktivien Sensors als temp1.
            In der nachfolgenden Get Node holen wir uns den 2. Wert in das gleiche Nachrichtenobjekt:
            Schaut man sich also den Status an, so wird in das gleiche Nachrichtenobjekt der jeweils andere Wert geholt.
            In einer switch Node kann ich nun wieder diese beiden Nachrichteneigenschaften des Nachrichtenobjektes vergleichen.
            Ist also temp1 größer gleich temp2 wird an den 1. Ausgang geschickt, ist temp1 kleiner als temp2 an den 2. Ausgang geschickt.
            1. Die letzte Möglichkeit ist immer zu warten bis beide Werte einmal trigger - kann man ja auch gleich zu Beginn machen und diese in einer JOIN Node sammeln.
            Wir lesen also die Werte gleich von Beginn an aus und dann lässt man sie triggern. In diesem Fall können wir beides Mal die Werte in die payload schreiben lassen:
            Man sammelt nun beide Werte in einer JOIN Node - wartet bis wirklich beide Werte angekommen sind und vergleicht dann mit jeder neuen Nachricht.
            Wichtig ist also dass wir dieses Mal ein Objekt als payload erstellen lassen und das topic als Nachrichteneigenschaft verwenden und dann auch noch 2 Nachrichten abwarten (also damit von jedem Sensor eine Nachricht vorhanden ist).
            Aufgrund der Zusammenfassung in der JOIN Node - haben wir beide Werte nun nicht nur in einem Nachrichtenobjekt sondern auch zusammen in einer payload
            die kann ich nun wieder vergleichen.
            Der Vergleich in der switch Node erfolgt also auf die gleiche Weise wie unter Möglichkeit 2 nur dass in diesem Fall 2 Eigenschaften des payload OBJEKTES verglichen werden.
            In diesem Fall muss die payload Eigenschaft in Hochkomma gesetzt werden, da die Eigenschaften Sonderzeichen enthält.
            Es empfiehlt sich also das topic vor der Change Node noch zu kürzen.
            Der Vergleich fällt aber identisch aus.
            FAZIT:
            Ich habe Dir nun alle 3 Möglichkeiten im Detail beschrieben und hier aufgelistet:
            Hier nun alle Flows zum Import und zur eigenen Verwendung.
                   "id": "e43dab1a908ef99f",
                   "type": "group",
                   "name": "Arbeiten mit Kontext",
                   "style": {
                       "label": true,
                       "fill": "#d1d1d1",
                       "color": "#000000"
                   "nodes": [
                       "07e3bee668e661e8",
                       "536cdc0dd2ef4fc2",
                       "a812d72bf198664f",
                       "5156eeca9b1dfcd8",
                       "efdc35d6e89451f0",
                       "5e85fcd342811a7e",
                       "cbb692cab8385ab7"
                   "x": 54,
                   "y": 459,
                   "w": 892,
                   "h": 242
                   "id": "07e3bee668e661e8",
                   "g": "e43dab1a908ef99f",
                   "name": "Wert",
                   "topic": "0_userdata.0.Test.Wert",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "fireOnStart": "true",
                   "x": 130,
                   "y": 500,
                   "wires": [
                           "536cdc0dd2ef4fc2"
                   "id": "536cdc0dd2ef4fc2",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "Schwellenwert",
                           "pt": "flow",
                           "to": "payload",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 350,
                   "y": 500,
                   "wires": [
                   "id": "a812d72bf198664f",
                   "name": "temperature von sensor1",
                   "topic": "0_userdata.0.Test.sensor1.temperature",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 580,
                   "wires": [
                           "efdc35d6e89451f0"
                   "id": "5156eeca9b1dfcd8",
                   "name": "temperature von sensor2",
                   "topic": "0_userdata.0.Test.sensor2.temperature",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 660,
                   "wires": [
                           "efdc35d6e89451f0"
                   "id": "efdc35d6e89451f0",
                   "type": "switch",
                   "name": "",
                   "propertyType": "msg",
                   "rules": [
                           "t": "gte",
                           "v": "Schwellenwert",
                           "vt": "flow"
                           "t": "lt",
                           "vt": "flow"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 430,
                   "y": 620,
                   "wires": [
                           "5e85fcd342811a7e"
                           "cbb692cab8385ab7"
                   "id": "5e85fcd342811a7e",
                   "type": "debug",
                   "name": "Temperatur größer gleich Schwellenwert",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "payload",
                   "targetType": "msg",
                   "statusVal": "",
                   "statusType": "auto",
                   "x": 740,
                   "y": 580,
                   "wires": []
                   "id": "cbb692cab8385ab7",
                   "type": "debug",
                   "name": "Temperatur kleiner Schwellenwert",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 720,
                   "y": 660,
                   "wires": []
                   "id": "197ddec297942ef4",
                   "type": "group",
                   "name": "Direkter Vergleich zweiter Werte",
                   "style": {
                       "fill": "#d1d1d1",
                       "label": true,
                       "color": "#000000"
                   "nodes": [
                       "374170f7e818615b",
                       "9b651c44257923a0",
                       "28eaaa4924577109",
                       "faa596cc35e87dcc",
                       "9c7b90390bea547f",
                       "2e1e027da8fe5673",
                       "1ab827d91b9b50fe"
                   "x": 54,
                   "y": 799,
                   "w": 952,
                   "h": 162
                   "id": "374170f7e818615b",
                   "g": "197ddec297942ef4",
                   "attrname": "temp1",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 840,
                   "wires": [
                           "28eaaa4924577109"
                   "id": "9b651c44257923a0",
                   "attrname": "temp2",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 920,
                   "wires": [
                           "faa596cc35e87dcc"
                   "id": "28eaaa4924577109",
                   "type": "ioBroker get",
                   "errOnInvalidState": "nothing",
                   "x": 450,
                   "y": 840,
                   "wires": [
                           "9c7b90390bea547f"
                   "id": "faa596cc35e87dcc",
                   "x": 450,
                   "y": 920,
                   "wires": [
                           "9c7b90390bea547f"
                   "id": "9c7b90390bea547f",
                   "type": "switch",
                   "name": "",
                   "property": "temp1 >= temp2",
                   "propertyType": "jsonata",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 690,
                   "y": 880,
                   "wires": [
                           "2e1e027da8fe5673"
                           "1ab827d91b9b50fe"
                   "id": "2e1e027da8fe5673",
                   "type": "debug",
                   "name": "temp1 >= temp2",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "targetType": "full",
                   "statusVal": "",
                   "x": 880,
                   "y": 860,
                   "wires": []
                   "id": "1ab827d91b9b50fe",
                   "type": "debug",
                   "name": "temp1 < temp2",
                   "active": false,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "complete": "true",
                   "statusVal": "",
                   "x": 880,
                   "y": 900,
                   "wires": []
                   "id": "087028a59590157a",
                   "type": "group",
                   "name": "Sammeln der Daten in JOIN Node",
                   "style": {
                       "fill": "#d1d1d1",
                       "label": true,
                       "color": "#000000"
                   "nodes": [
                       "fce2c0c80ed59f3e",
                       "57ca2644567701fb",
                       "3705ae40eba76f65",
                       "563fcce325a86928",
                       "15e78a6fbc574f2f",
                       "8c7ff661db7201e8"
                   "x": 54,
                   "y": 1039,
                   "w": 892,
                   "h": 162
                   "id": "fce2c0c80ed59f3e",
                   "g": "087028a59590157a",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 1080,
                   "wires": [
                           "3705ae40eba76f65"
                   "id": "57ca2644567701fb",
                   "onlyack": "",
                   "func": "all",
                   "gap": "",
                   "x": 190,
                   "y": 1160,
                   "wires": [
                           "3705ae40eba76f65"
                   "id": "3705ae40eba76f65",
                   "type": "join",
                   "name": "",
                   "mode": "custom",
                   "build": "object",
                   "key": "topic",
                   "joiner": "\\n",
                   "joinerType": "str",
                   "accumulate": true,
                   "timeout": "",
                   "count": "2",
                   "reduceRight": false,
                   "reduceExp": "",
                   "reduceInit": "",
                   "reduceInitType": "",
                   "reduceFixup": "",
                   "x": 450,
                   "y": 1120,
                   "wires": [
                           "563fcce325a86928"
                   "id": "563fcce325a86928",
                   "type": "switch",
                   "name": "",
                   "property": "payload.'0_userdata/0/Test/sensor1/temperature' >= payload.'0_userdata/0/Test/sensor2/temperature'",
                   "rules": [
                           "t": "true"
                           "t": "false"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 630,
                   "y": 1120,
                   "wires": [
                           "15e78a6fbc574f2f"
                           "8c7ff661db7201e8"
                   "id": "15e78a6fbc574f2f",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 820,
                   "y": 1100,
                   "wires": []
                   "id": "8c7ff661db7201e8",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 820,
                   "y": 1140,
                   "wires": []
              Armin 2
              Danke für die Mühe, aber das passt so noch nicht.
              Hier nochmal mein Problem.
              Ich möchte einen Wert von IO-Broker mit einem Wert "change" vergleichen und ein Bit z.B. im IOBroker setzen.
              "id": "32ca1d3d3965fa09",
              "type": "tab",
              "label": "Flow 2",
              "disabled": false,
              "info": "",
              "env": []
              "id": "1a1283bbbd4c8410",
              "type": "ioBroker out",
              "z": "32ca1d3d3965fa09",
              "name": "Battery Charging enabled [gridCharge]",
              "topic": "alpha-ess.0.Settings_Charge.Battery_Charging_enabled",
              "ack": "false",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1050,
              "y": 340,
              "wires": []
              "id": "a2d7ca6eafbe6e71",
              "name": " alpha-ess.0.Realtime.Battery_SOC",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 300,
              "y": 260,
              "wires": [
              "id": "92f11862fdebb1a9",
              "type": "change",
              "name": "SOC 20",
              "rules": [
              "t": "set",
              "p": "payload",
              "pt": "msg",
              "to": "20",
              "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 380,
              "y": 340,
              "wires": [
              "id": "82df9544976c9930",
              "type": "inject",
              "name": "",
              "props": [
              "p": "payload"
              "p": "topic",
              "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 160,
              "y": 340,
              "wires": [
              "92f11862fdebb1a9"
              "id": "ba6a0a91683436e9",
              "type": "switch",
              "name": "",
              "rules": [
              "t": "true"
              "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 750,
              "y": 340,
              "wires": [
              "1a1283bbbd4c8410",
              "33fca06d3914b1cb"
              "id": "33fca06d3914b1cb",
              "type": "debug",
              "name": "Charging Einschalten",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1000,
              "y": 260,
              "wires": []
              • A Armin 2
                "type": "tab",
                "label": "Flow 2",
                "disabled": false,
                "info": "",
                "env": []
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1050,
                "y": 340,
                "wires": []
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 300,
                "y": 260,
                "wires": [
                "type": "change",
                "name": "SOC 20",
                "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "20",
                "tot": "num"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 380,
                "y": 340,
                "wires": [
                "type": "inject",
                "name": "",
                "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "",
                "x": 160,
                "y": 340,
                "wires": [
                "92f11862fdebb1a9"
                "type": "switch",
                "name": "",
                "rules": [
                "t": "true"
                "t": "false"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 750,
                "y": 340,
                "wires": [
                "1a1283bbbd4c8410",
                "33fca06d3914b1cb"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 1000,
                "y": 260,
                "wires": []
                mickymM Offline
                mickymM Offline
                mickym
                So korrigiert - siehe nächster Post.
                A 1 Antwort Letzte Antwort
                • mickymM mickym
                  Armin 2
                  @mickym
                  Ich möchte einen Wert von IO-Broker mit einem Wert aus "change" vergleichen, der aus einem andern Flow kommt und ein Bit z.B. im IOBroker setzen, wenn der Wert aus dem IOBroker >= dem Wert aus dem "change" ist.
                  • A Armin 2
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    Mach das mit dem Kontext. Der zweite Wert wird über die Change Node im Flow Kontext gespeichert.
                    Wird Batterie_SOC getriggert wird der Kontext wieder in das Nachrichtenobjekt in die Eigenschaft value geladen.
                    Hier zum Import:
                           "id": "313b5fce557e4aef",
                           "z": "8cf2ddd0a8460b51",
                           "name": "",
                           "onlyack": "",
                           "func": "all",
                           "gap": "",
                           "x": 360,
                           "y": 480,
                           "wires": [
                                   "30bc38cb790891f0"
                           "id": "2ce9c640efa3e18c",
                           "type": "switch",
                           "name": "",
                           "property": "payload > value",
                           "rules": [
                                   "t": "true"
                                   "t": "false"
                           "checkall": "true",
                           "repair": false,
                           "outputs": 2,
                           "x": 870,
                           "y": 480,
                           "wires": [
                           "id": "3333b79ff893ca32",
                           "type": "change",
                           "rules": [
                                   "t": "set",
                                   "p": "zweiterWert",
                                   "pt": "flow",
                                   "to": "payload",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 470,
                           "y": 580,
                           "wires": [
                           "type": "inject",
                           "name": "",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "90",
                           "payloadType": "num",
                           "x": 290,
                           "y": 580,
                           "wires": [
                                   "3333b79ff893ca32"
                           "id": "30bc38cb790891f0",
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "value",
                                   "pt": "msg",
                                   "to": "zweiterWert",
                                   "tot": "flow"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 640,
                           "y": 480,
                           "wires": [
                                   "2ce9c640efa3e18c"
                    Bzw. (s. nächster Post) aus dem anderen Flow den Wert direkt im globalen Kontext speichern.
                    • A Armin 2
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @armin-2 Du kannst es auch aus dem anderen Flow - im globalen Kontext speichern!!! So würde ich es machen. Aber ich kenne ja den anderen Flow nicht.
                      In dem anderen Flow speicherst Du im globalen Kontext
                      Dann kannst Du den globalen Kontext in der Change Node wieder aus der Variablen einlesen:
                      Dann brauchst Du die Flows NICHT zu verlinken, sondern tauscht über den globalen Kontext aus.
                        Armin 2
                        Das passt immer noch nicht. Hier mein ganzer Flow mit Beschreibung, vielleicht hilft das.
                        "id": "93f485839dfa27a8",
                        "type": "subflow",
                        "name": "Solar forecast",
                        "info": "This subflow uses the http request node to fetch solar forecasts for geographical positions, using the API from https://forecast.solar/. Please check their website and consider getting a paid account.\n\nDo note that, on a free account, you are limited in the number of requests to do. Also note that the data only gets updated once every 15 minutes, so there is no reason to query more often. There is rate limiting built in the subflow not to perform requests more than once every 15 minutes.\n\n# Configuration\n\nIt uses the parameters as described on: http://doc.forecast.solar/doku.php\n\n - :apikey - personal API key for registered users\n - :lat - latitude of location, -90 (south) … 90 (north); Internal precission is 0.0001 or abt. 10 m\n - :lon - longitude of location, -180 (west) … 180 (east); Internal precission is 0.0001 or abt. 10 m\n - :dec - plane declination, 0 (horizontal) … 90 (vertical); Internal precission is integer\n - :az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north); Internal precission is integer\n - :kwp - installed modules power in kilo watt peak (kWp)\n\nYou can choose between 3 different type of requests. Note that only estimate is available on the free plan.\n\n- estimate - this is the forecasted estimate that your panels should produce (given the right parameter settings)\n- history - historical data showing the long term averages for the days to come. See https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en for where the data is fetched from.\n- clear sky - estimate given if there would be a clear sky tomorrow\n\nIn case of estimates, one of the following options can be selected:\n- watts - Watts (power) average for the period\n- watt_hours_period - Watt hours (energy) for the period\n- watt_hours - Watt hours (energy) summarized over the day\n- watt_hours_day - Watt hours (energy) summarized for each day\n\nFor the graph output there are some extra settings available:\n\n- Output in kWh - when checked output can be set to kWh instead of Wh\n- Show todays forecast - whether or not to include todays forecast\n- Days to forecast - the number of days to forecast (excluding today). Note that you can not get more days forecasted than your API key allows.\n- Widen graph - widen the graph to only show non-zero values\n\n# Input \n\nThe input is for triggering the solar forecast request. \nIt triggers when injecting a message into the node.\n\n# Output\n\nThere are two outputs. The first output is an object with the result and a status message stored into the msg.payload.\n\nMost important is the msg.payload.result, which contains the estimated production of the panels. E.g.:\n\n\npayload: object\n result: object\n 2022-11-28: 23\n 2022-11-29: 35\n\n\nThe msg.payload.message gives information on how successful the query was, the exitcode of the query and the status of the rate limit (how many queries you have left).\n\nThe second output can be directly linked to a line or a bar chart, quickly giving a once-glance overview for the predicted forecast.\n\n# Status\n\nInitially the status of the note will be a blue dot, showing "Unknown limit", as it is unaware of the set ratelmits. After the first request, the returned ratelimit will be put in the text in the form of remaining/limit. If more than half the limit is remaining, the dot will be green. If less then half the limit is remaining, the dot will be yellow. If no limit is left, the dot will turn red.\nPlease keep in mind that the ratelimit will be reset after one hour, so you can send a new request after that hour.\n\nIf something is wrong in the API request, the dot will turn red\nand the message will contain the msg.payload with the error. This\nhappens typically when the API is temporally down for maintenance.",
                        "category": "",
                        "in": [
                        "x": 240,
                        "y": 100,
                        "wires": [
                        "id": "c8dc6aa14b9f3e92"
                        "out": [
                        "x": 760,
                        "y": 260,
                        "wires": [
                        "id": "2f42837904c91d73",
                        "port": 0
                        "id": "fcc8d69a3ab88e6d",
                        "port": 0
                        "x": 770,
                        "y": 340,
                        "wires": [
                        "id": "5b0a430fb61e70e7",
                        "port": 0
                        "env": [
                        "name": "latitude",
                        "type": "num",
                        "value": "51.3",
                        "ui": {
                        "icon": "font-awesome/fa-location-arrow",
                        "type": "input",
                        "opts": {
                        "types": [
                        "num"
                        "name": "longitude",
                        "type": "num",
                        "value": "5.6",
                        "ui": {
                        "type": "input",
                        "opts": {
                        "types": [
                        "num"
                        "name": "declination",
                        "type": "num",
                        "value": "37",
                        "ui": {
                        "icon": "font-awesome/fa-chevron-up",
                        "type": "input",
                        "opts": {
                        "types": [
                        "num"
                        "name": "azimuth",
                        "type": "num",
                        "value": "0",
                        "ui": {
                        "icon": "font-awesome/fa-compass",
                        "type": "spinner",
                        "opts": {
                        "min": -180,
                        "max": 180
                        "name": "modules power",
                        "type": "num",
                        "value": "1",
                        "ui": {
                        "icon": "font-awesome/fa-power-off",
                        "type": "input",
                        "opts": {
                        "types": [
                        "num"
                        "name": "apikey",
                        "type": "cred",
                        "ui": {
                        "icon": "font-awesome/fa-key",
                        "type": "input",
                        "opts": {
                        "types": [
                        "cred"
                        "name": "type",
                        "type": "str",
                        "value": "estimate",
                        "ui": {
                        "label": {
                        "en-US": "type"
                        "type": "select",
                        "opts": {
                        "opts": [
                        "l": {
                        "en-US": "Estimate"
                        "v": "estimate"
                        "l": {
                        "en-US": "History"
                        "v": "history"
                        "l": {
                        "en-US": "Clear sky"
                        "v": "clearsky"
                        "name": "watt",
                        "type": "str",
                        "value": "watts",
                        "ui": {
                        "icon": "font-awesome/fa-question-circle-o",
                        "type": "select",
                        "opts": {
                        "opts": [
                        "l": {
                        "en-US": "Watts (power) average for the period"
                        "v": "watts"
                        "l": {
                        "en-US": "Watt hours (energy) for the period"
                        "v": "watt_hours_period"
                        "l": {
                        "en-US": "Watt hours (energy) summarized over the day"
                        "v": "watt_hours"
                        "l": {
                        "en-US": "Watt hours (energy) summarized for each day"
                        "v": "watt_hours_day"
                        "name": "kwhoutput",
                        "type": "bool",
                        "value": "false",
                        "ui": {
                        "label": {
                        "en-US": "Output in kWh (in the graph)"
                        "type": "checkbox"
                        "name": "showtoday",
                        "type": "bool",
                        "value": "true",
                        "ui": {
                        "label": {
                        "en-US": "Show todays forecast"
                        "type": "checkbox"
                        "name": "daystoforecast",
                        "type": "str",
                        "value": "-1",
                        "ui": {
                        "label": {
                        "en-US": "Days to forecast"
                        "type": "select",
                        "opts": {
                        "opts": [
                        "l": {
                        "en-US": "Max"
                        "v": "-1"
                        "l": {
                        "en-US": "0"
                        "v": "0"
                        "l": {
                        "en-US": "1"
                        "v": "1"
                        "l": {
                        "en-US": "2"
                        "v": "2"
                        "l": {
                        "en-US": "3"
                        "v": "3"
                        "l": {
                        "en-US": "4"
                        "v": "4"
                        "l": {
                        "en-US": "5"
                        "v": "5"
                        "l": {
                        "en-US": "6"
                        "v": "6"
                        "name": "widengraph",
                        "type": "bool",
                        "value": "true",
                        "ui": {
                        "label": {
                        "en-US": "Widen graph"
                        "type": "checkbox"
                        "meta": {
                        "module": "Solar Forecast",
                        "version": "0.0.9",
                        "author": "dfaber@victronenergy.com",
                        "desc": "Get solar forecasting per location",
                        "keywords": "solar,forecast,api",
                        "license": "GPL-3.0"
                        "color": "#FFCC66",
                        "inputLabels": [
                        "trigger"
                        "outputLabels": [
                        "output",
                        "graph"
                        "icon": "font-awesome/fa-sun-o",
                        "status": {
                        "x": 680,
                        "y": 560,
                        "wires": [
                        "id": "1bfc1cde3ee94e4b",
                        "port": 0
                        "id": "a798fbe66cf133d5",
                        "port": 0
                        "id": "c706820c0d61f023",
                        "type": "http request",
                        "z": "93f485839dfa27a8",
                        "name": "",
                        "method": "GET",
                        "ret": "txt",
                        "paytoqs": "ignore",
                        "url": "",
                        "tls": "",
                        "persist": false,
                        "proxy": "",
                        "insecureHTTPParser": false,
                        "authType": "",
                        "senderr": false,
                        "headers": [],
                        "x": 390,
                        "y": 180,
                        "wires": [
                        "1b5ccaa05d54f7c3"
                        "id": "b9488734852cd0ca",
                        "type": "function",
                        "name": "create forecast.solar url",
                        "func": "msg.url = 'https://api.forecast.solar/';\n\nif (env.get('apikey')) {\n msg.url += env.get('apikey') + '/';\n }\n\nmsg.url += env.get('type') + '/';\n\nmsg.url += env.get('watt') + '/';\n\nmsg.url += env.get('latitude') + '/' +\n env.get('longitude') + '/' +\n env.get('declination') + '/' +\n env.get('azimuth') + '/' +\n env.get('modules power');\n\nmsg.topic = 'solar forecast: '+(env.get('type') || '');\nmsg.topic += (' '+env.get('watt') || '');\nif (env.get('kwhoutput')) {\n msg.topic += ' (kWh)';\n}\nreturn msg;",
                        "outputs": 1,
                        "timeout": "",
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 630,
                        "y": 100,
                        "wires": [
                        "975daf96f15cfb61"
                        "id": "1b5ccaa05d54f7c3",
                        "type": "json",
                        "name": "Convert to json",
                        "action": "",
                        "pretty": false,
                        "x": 680,
                        "y": 180,
                        "wires": [
                        "e718a22973cc2864"
                        "id": "559391d1288f762a",
                        "type": "function",
                        "name": "update ratelimit",
                        "func": "var remaining = msg.payload.message.ratelimit.remaining || 0;\nvar limit = msg.payload.message.ratelimit.limit;\n\nflow.set('forecast.solar.ratelimit.remaining', remaining)\nflow.set('forecast.solar.ratelimit.limit', limit)\n\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 520,
                        "y": 480,
                        "wires": [
                        "e56826252134b93a"
                        "id": "e718a22973cc2864",
                        "type": "link out",
                        "name": "link out 1",
                        "mode": "link",
                        "links": [
                        "3fa24f2d08195961",
                        "0a20e852662c8cec"
                        "x": 815,
                        "y": 180,
                        "wires": []
                        "id": "3fa24f2d08195961",
                        "type": "link in",
                        "name": "link in 1",
                        "links": [
                        "e718a22973cc2864"
                        "x": 385,
                        "y": 480,
                        "wires": [
                        "559391d1288f762a"
                        "id": "0a20e852662c8cec",
                        "type": "link in",
                        "name": "link in 2",
                        "links": [
                        "e718a22973cc2864"
                        "x": 225,
                        "y": 260,
                        "wires": [
                        "fcc8d69a3ab88e6d"
                        "id": "4734b6f403e1f03e",
                        "type": "inject",
                        "name": "",
                        "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": true,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "",
                        "x": 530,
                        "y": 440,
                        "wires": [
                        "e56826252134b93a"
                        "type": "function",
                        "name": "update status",
                        "func": "var remaining = flow.get('forecast.solar.ratelimit.remaining') || -1;\nvar limit = flow.get('forecast.solar.ratelimit.limit') || -1\n\nvar text = remaining.toString() + '/' + limit.toString();\nvar fill = "green";\n\nif (remaining == 0) {\n fill = "red";\n text = "Limit used";\n}\n\nif (remaining > 0 && remaining < limit / 2) {\n fill = "yellow"\n}\n\nif (remaining == -1 ) {\n fill = "blue"\n text = "Limits unknown"\n}\n\nmsg.payload = ({ fill: fill, text: text });\n\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 520,
                        "y": 580,
                        "wires": [
                        "id": "a18e96179ec2d987",
                        "type": "function",
                        "name": "Create graph output",
                        "func": "var m = {};\nm.labels = [];\nm.data = [];\n\nm.series = [];\nm.data = [];\nm.labels = [];\n\nfor (let j = 0; j <= msg.days; j++) {\n m.data[j] = [];\n}\n\nif (msg.watt === 'watt_hours_day') {\n var i = 0;\n m.series.push("Watt hours per day");\n for (const key in msg.payload.result) {\n m.labels.push(key);\n if (msg.kwhoutput) {\n m.data[i] = +(Math.round(msg.payload.result[key]/100).1).toFixed(1);\n } else {\n m.data[i] = msg.payload.result[key];\n }\n i++;\n }\n m.data = [m.data];\n return { payload: [m] };\n}\n\nfor (let i = 0; i <= 23; i++) {\n\n m.labels.push(i.toString()+':00');\n if (msg.resolution === 4) {\n m.labels.push(i.toString()+':15');\n }\n if (msg.resolution === 2 || msg.resolution == 4) {\n m.labels.push(i.toString()+':30');\n }\n if (msg.resolution === 4) {\n m.labels.push(i.toString()+':45');\n }\n\n for (let j = 0; j <= msg.days; j++) {\n m.data[j].push(0);\n if (msg.resolution === 4) {\n m.data[j].push(0)\n }\n if (msg.resolution === 2 || msg.resolution == 4) {\n m.data[j].push(0)\n }\n if (msg.resolution === 4) {\n m.data[j].push(0)\n }\n\n }\n}\n\nvar offset = 0;\nfor (const key in msg.payload.result) {\n var d = new Date(key)\n if (m.series.indexOf(d.toISOString().split('T')[0]) === -1) {\n m.series.push(d.toISOString().split('T')[0])\n }\n\n var h = d.getHours();\n var minutes = d.getMinutes();\n\n if (minutes === 0 ) {\n offset = 0;\n } else {\n offset++;\n }\n\n if (msg.kwhoutput) {\n m.data[m.series.length - 1][hmsg.resolution+offset] = +(Math.round(msg.payload.result[key]/100).1).toFixed(1);\n } else {\n m.data[m.series.length - 1][hmsg.resolution+offset] = msg.payload.result[key];\n }\n}\n\nreturn { payload: [m] };\n",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 360,
                        "y": 340,
                        "wires": [
                        "5b0a430fb61e70e7"
                        "id": "975daf96f15cfb61",
                        "type": "link out",
                        "name": "link out 7",
                        "mode": "link",
                        "links": [
                        "14f2e68e572f4ef8"
                        "x": 805,
                        "y": 100,
                        "wires": []
                        "id": "14f2e68e572f4ef8",
                        "type": "link in",
                        "name": "link in 18",
                        "links": [
                        "975daf96f15cfb61"
                        "x": 245,
                        "y": 180,
                        "wires": [
                        "c706820c0d61f023"
                        "id": "c4307905e114824f",
                        "type": "catch",
                        "name": "",
                        "scope": null,
                        "uncaught": false,
                        "x": 260,
                        "y": 440,
                        "wires": [
                        "f427f19392c399ce"
                        "id": "e56826252134b93a",
                        "type": "link out",
                        "name": "link out 8",
                        "mode": "link",
                        "links": [
                        "dbaf8f5f5a920686"
                        "x": 685,
                        "y": 480,
                        "wires": []
                        "id": "dbaf8f5f5a920686",
                        "type": "link in",
                        "name": "link in 19",
                        "links": [
                        "e56826252134b93a"
                        "x": 385,
                        "y": 580,
                        "wires": [
                        "1bfc1cde3ee94e4b"
                        "id": "f427f19392c399ce",
                        "type": "link out",
                        "name": "link out 9",
                        "mode": "link",
                        "links": [
                        "2ded0c14a222b4d9",
                        "2f42837904c91d73"
                        "x": 375,
                        "y": 440,
                        "wires": []
                        "id": "2ded0c14a222b4d9",
                        "type": "link in",
                        "name": "link in 20",
                        "links": [
                        "f427f19392c399ce"
                        "x": 385,
                        "y": 540,
                        "wires": [
                        "a798fbe66cf133d5"
                        "type": "function",
                        "name": "Set error status",
                        "func": "node.warn(msg.payload)\nmsg.payload = ({ fill: "red", text: msg.payload });\n\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 520,
                        "y": 540,
                        "wires": [
                        "type": "link in",
                        "name": "link in 21",
                        "links": [
                        "f427f19392c399ce"
                        "x": 665,
                        "y": 280,
                        "wires": [
                        "type": "function",
                        "name": "Processed info",
                        "func": "msg.resolution = 60;\nmsg.days = 1;\nmsg.type = env.get('type');\nmsg.watt = env.get('watt');\nmsg.kwhoutput = env.get('kwhoutput');\n\nvar key1 = Object.keys(msg.payload.result)[1];\nvar key2 = Object.keys(msg.payload.result)[2];\nvar key3 = Object.keys(msg.payload.result)[Object.keys(msg.payload.result).length-1];\n\nvar d1 = new Date(key1);\nvar d2 = new Date(key2); \nvar d3 = new Date(key3);\nmsg.resolution = 3600000 / (d2.getTime() - d1.getTime());\n\nmsg.days = Math.floor((d3.getTime() - d1.getTime()) / (1000 * 3600 * 24));\n\nif (msg.watt === 'watt_hours_day') {\n msg.resolution = null;\n}\n\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 360,
                        "y": 260,
                        "wires": [
                        "a18e96179ec2d987"
                        "info": "Function to process the result from forecast.solar to add\nextra information, which is handy for either graphing or\nto store in a database.\n\n\nThe extra values added:\n- msg.resolution - The number of measurements per hour. If\nno API key is used, this will be 1. Other values may be 2 or 4.\n- msg.days - The number of days in the forcast. If no API\n- key is used this will be 1. Other values may be 3 or 6."
                        "type": "function",
                        "name": "Filter graph",
                        > 0) {\n remove = false;\n }\n }\n if (remove) {\n msg.payload[0].labels.splice(x, 1);\n for (d = 0; d < msg.payload[0].data.length; d++) {\n msg.payload[0].data[d].splice(x, 1);\n }\n x--;\n }\n x++;\n }\n // Still the first and last datapoints should be zero, so\n // add those again\n msg.payload[0].labels.unshift('');\n msg.payload[0].labels.push('');\n for (d = 0; d < msg.payload[0].data.length; d++) {\n msg.payload[0].data[d].unshift(0);\n msg.payload[0].data[d].push(0);\n } \n}\n\nreturn msg;",
                        "outputs": 1,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 590,
                        "y": 340,
                        "wires": [
                        "id": "c8dc6aa14b9f3e92",
                        "type": "delay",
                        "name": "5 msg/15 minutes",
                        "pauseType": "rate",
                        "timeout": "5",
                        "timeoutUnits": "seconds",
                        "rate": "5",
                        "nbRateUnits": "15",
                        "rateUnits": "minute",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "randomUnits": "seconds",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 390,
                        "y": 100,
                        "wires": [
                        "b9488734852cd0ca"
                        "type": "tab",
                        "label": "Flow 2",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "id": "93511f47e1f57f02",
                        "type": "group",
                        "style": {
                        "fill": "#d1d1d1",
                        "label": true,
                        "color": "#000000"
                        "nodes": [
                        "9aecc09bd88aa42a",
                        "5dc336ee1d2a02da",
                        "008ab1d49e4bb116"
                        "x": 154,
                        "y": 99,
                        "w": 672,
                        "h": 82
                        "id": "47a4cf54866c5a93",
                        "type": "inject",
                        "name": "",
                        "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "",
                        "x": 120,
                        "y": 460,
                        "wires": [
                        "206c8fbe5daa2c1e"
                        "id": "206c8fbe5daa2c1e",
                        "type": "subflow:93f485839dfa27a8",
                        "name": "Süd",
                        "env": [
                        "name": "latitude",
                        "value": "51.0618535",
                        "type": "num"
                        "value": "7.376629",
                        "type": "num"
                        "value": "40",
                        "type": "num"
                        "name": "azimuth",
                        "value": "182",
                        "type": "num"
                        "value": "9",
                        "type": "num"
                        "name": "apikey",
                        "type": "cred"
                        "name": "watt",
                        "value": "watt_hours_day",
                        "type": "str"
                        "type": "bool",
                        "value": "false"
                        "value": "1",
                        "type": "str"
                        "type": "bool",
                        "value": "false"
                        "x": 310,
                        "y": 460,
                        "wires": [
                        "57dc8d4b5bbeaa7f"
                        "id": "57dc8d4b5bbeaa7f",
                        "type": "function",
                        "name": "function 16",
                        "func": "var pvf = msg.payload;\nvar date = moment().tz("Europe/Berlin");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nreturn msg;",
                        "outputs": 1,
                        "timeout": "",
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [
                        "var": "moment",
                        "module": "moment"
                        "x": 530,
                        "y": 460,
                        "wires": [
                        "15b38fae77d09de8"
                        "id": "15b38fae77d09de8",
                        "type": "switch",
                        "name": "",
                        "rules": [
                        "t": "lt",
                        "v": "2000",
                        "vt": "str"
                        "t": "btwn",
                        "v": "2000",
                        "vt": "num",
                        "v2": "5000",
                        "v2t": "num"
                        "t": "btwn",
                        "v": "5000",
                        "vt": "num",
                        "v2": "8000",
                        "v2t": "num"
                        "t": "gt",
                        "v": "8000",
                        "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 4,
                        "x": 690,
                        "y": 460,
                        "wires": [
                        "d05020b1296929fc"
                        "6109976a13173762"
                        "7b0b92dc28fd1808"
                        "0aaf3b0d4e58724e"
                        "id": "d05020b1296929fc",
                        "type": "change",
                        "name": "SOC 100",
                        "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "100",
                        "tot": "num"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 860,
                        "y": 400,
                        "wires": [
                        "236747505d6180f7",
                        "5f11d27a7408ff35",
                        "5dc336ee1d2a02da"
                        "id": "6109976a13173762",
                        "type": "change",
                        "name": "SOC 60",
                        "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "60",
                        "tot": "num"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 860,
                        "y": 440,
                        "wires": [
                        "236747505d6180f7",
                        "5f11d27a7408ff35",
                        "5dc336ee1d2a02da"
                        "id": "7b0b92dc28fd1808",
                        "type": "change",
                        "name": "SOC 40",
                        "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "40",
                        "tot": "num"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 860,
                        "y": 480,
                        "wires": [
                        "236747505d6180f7",
                        "5f11d27a7408ff35",
                        "5dc336ee1d2a02da"
                        "id": "0aaf3b0d4e58724e",
                        "type": "change",
                        "name": "SOC 20",
                        "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "20",
                        "tot": "num"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 860,
                        "y": 520,
                        "wires": [
                        "236747505d6180f7",
                        "5f11d27a7408ff35",
                        "5dc336ee1d2a02da"
                        "id": "9aecc09bd88aa42a",
                        "g": "93511f47e1f57f02",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 290,
                        "y": 140,
                        "wires": [
                        "5dc336ee1d2a02da"
                        "id": "5dc336ee1d2a02da",
                        "type": "join",
                        "name": "",
                        "mode": "custom",
                        "build": "object",
                        "key": "topic",
                        "joiner": "\n",
                        "accumulate": true,
                        "timeout": "",
                        "count": "2",
                        "reduceExp": "",
                        "reduceInit": "",
                        "reduceFixup": "",
                        "x": 590,
                        "y": 140,
                        "wires": [
                        "008ab1d49e4bb116"
                        "id": "008ab1d49e4bb116",
                        "type": "switch",
                        "name": "",
                        "rules": [
                        "t": "true"
                        "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 750,
                        "y": 140,
                        "wires": [
                        "b4c362324a598e06",
                        "0e44e66f0eb20551"
                        "id": "32a2eb3db62922d1",
                        "type": "comment",
                        "name": "solar forecast lesen",
                        "info": "",
                        "x": 330,
                        "y": 400,
                        "wires": []
                        "id": "f8f09c0fbe1d0129",
                        "type": "comment",
                        "name": "daten für den Tag aufbereiten",
                        "info": "",
                        "x": 540,
                        "y": 400,
                        "wires": []
                        "id": "2560460ee7ece326",
                        "type": "comment",
                        "name": "Daten jede Stunde lesen",
                        "info": "",
                        "x": 130,
                        "y": 400,
                        "wires": []
                        "id": "92f7dcf1abe763bc",
                        "type": "comment",
                        "name": "je nach Leistung SOC für Batterie festlegen",
                        "info": "",
                        "x": 820,
                        "y": 580,
                        "wires": []
                        "id": "236747505d6180f7",
                        "name": "Discharging Cutoff SOC [batUseCap]",
                        "topic": "alpha-ess.0.Settings_Discharge.Discharging_Cutoff_SOC",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1170,
                        "y": 400,
                        "wires": []
                        "id": "5f11d27a7408ff35",
                        "payloadType": "object",
                        "x": 1170,
                        "y": 480,
                        "wires": [
                        "id": "4036c9e7d228d42d",
                        "type": "comment",
                        "name": "Wert an IOBroker geben",
                        "info": "",
                        "x": 1150,
                        "y": 580,
                        "wires": []
                        "id": "280378479ef948d1",
                        "type": "comment",
                        "name": "vergleichen ob Batterieladung größe als berechneter Wert Ist",
                        "info": "",
                        "x": 640,
                        "y": 220,
                        "wires": []
                        "id": "55de461857057e67",
                        "type": "comment",
                        "name": "SOC Wert von Batterie",
                        "info": "",
                        "x": 280,
                        "y": 220,
                        "wires": []
                        "id": "b4c362324a598e06",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1110,
                        "y": 60,
                        "wires": []
                        "id": "0e44e66f0eb20551",
                        "x": 1110,
                        "y": 120,
                        "wires": [
                        "id": "199bac5fd12314a5",
                        "type": "comment",
                        "name": "Batterie laden EIN/Aus",
                        "info": "",
                        "x": 1060,
                        "y": 220,
                        "wires": []
                        • mickymM Offline
                          mickymM Offline
                          mickym
                          Ja ich könnte mir das Anschauen, wenn Du Deinen Flow in ein Code-Tags packst - sowas ist nutzlos !!!
                            Armin 2
                            Ist das so Richtig?
                                    "type": "subflow",
                                    "info": "This subflow uses the http request node to fetch solar forecasts for geographical positions, using the API from https://forecast.solar/. Please check their website and consider getting a paid account.\n\nDo note that, on a free account, you are limited in the number of requests to do. Also note that the data only gets updated once every 15 minutes, so there is no reason to query more often. There is rate limiting built in the subflow not to perform requests more than once every 15 minutes.\n\n# Configuration\n\nIt uses the parameters as described on: http://doc.forecast.solar/doku.php\n\n - `:apikey` - personal API key for registered users\n - `:lat` - latitude of location, -90 (south) … 90 (north); Internal precission is 0.0001 or abt. 10 m\n - `:lon` - longitude of location, -180 (west) … 180 (east); Internal precission is 0.0001 or abt. 10 m\n - `:dec` - plane declination, 0 (horizontal) … 90 (vertical); Internal precission is integer\n - `:az` - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north); Internal precission is integer\n - `:kwp` - installed modules power in kilo watt peak (kWp)\n\nYou can choose between 3 different type of requests. Note that only `estimate` is available on the free plan.\n\n- `estimate` - this is the forecasted estimate that your panels should produce (given the right parameter settings)\n- `history` - historical data showing the long term averages for the days to come. See [https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en](https://joint-research-centre.ec.europa.eu/pvgis-online-tool/pvgis-data-download/cm-saf-solar-radiation_en) for where the data is fetched from.\n- `clear sky` - estimate given if there would be a clear sky tomorrow\n\nIn case of estimates, one of the following options can be selected:\n- `watts` - Watts (power) average for the period\n- `watt_hours_period` - Watt hours (energy) for the period\n- `watt_hours` - Watt hours (energy) summarized over the day\n- `watt_hours_day` - Watt hours (energy) summarized for each day\n\nFor the graph output there are some extra settings available:\n\n- _Output in kWh_ - when checked output can be set to kWh instead of Wh\n- _Show todays forecast_ - whether or not to include todays forecast\n- _Days to forecast_ - the number of days to forecast (excluding today). Note that you can not get more days forecasted than your API key allows.\n- _Widen graph_ - widen the graph to only show non-zero values\n\n# Input \n\nThe input is for triggering the solar forecast request. \nIt triggers when injecting a message into the node.\n\n# Output\n\nThere are two outputs. The first output is an object with the result and a status message stored into the `msg.payload`.\n\nMost important is the `msg.payload.result`, which contains the estimated production of the panels. E.g.:\n\n```\npayload: object\n  result: object\n    2022-11-28: 23\n    2022-11-29: 35\n```\n\nThe `msg.payload.message` gives information on how successful the query was, the exitcode of the query and the status of the rate limit (how many queries you have left).\n\nThe **second** output can be directly linked to a line or a bar chart, quickly giving a once-glance overview for the predicted forecast.\n\n# Status\n\nInitially the status of the note will be a blue dot, showing \"_Unknown limit_\", as it is unaware of the set ratelmits. After the first request, the returned ratelimit will be put in the text in the form of `remaining/limit`. If more than half the limit is remaining, the dot will be green. If less then half the limit is remaining, the dot will be yellow. If no limit is left, the dot will turn red.\nPlease keep in mind that the ratelimit will be reset after one hour, so you can send a new request after that hour.\n\nIf something is wrong in the API request, the dot will turn red\nand the message will contain the msg.payload with the error. This\nhappens typically when the API is temporally down for maintenance.",
                                    "category": "",
                                    "in": [
                                            "x": 240,
                                            "y": 100,
                                            "wires": [
                                    "out": [
                                            "x": 760,
                                            "y": 260,
                                            "wires": [
                                                    "port": 0
                                                    "port": 0
                                            "x": 770,
                                            "y": 340,
                                            "wires": [
                                                    "port": 0
                                    "env": [
                                            "name": "latitude",
                                            "type": "num",
                                            "value": "51.3",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "type": "num",
                                            "value": "5.6",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "type": "num",
                                            "value": "37",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "azimuth",
                                            "type": "num",
                                            "value": "0",
                                            "ui": {
                                                "type": "spinner",
                                                "opts": {
                                                    "min": -180,
                                                    "max": 180
                                            "type": "num",
                                            "value": "1",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "num"
                                            "name": "apikey",
                                            "type": "cred",
                                            "ui": {
                                                "type": "input",
                                                "opts": {
                                                    "types": [
                                                        "cred"
                                            "name": "type",
                                            "type": "str",
                                            "ui": {
                                                "label": {
                                                    "en-US": "type"
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
        "en-US": "Estimate"
                                                            "v": "estimate"
                                                            "l": {
        "en-US": "History"
                                                            "v": "history"
                                                            "l": {
                                                            "v": "clearsky"
                                            "name": "watt",
                                            "type": "str",
                                            "value": "watts",
                                            "ui": {
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
                                                            "v": "watts"
                                                            "l": {
                                                            "l": {
                                                            "v": "watt_hours"
                                                            "l": {
                                            "type": "bool",
                                            "value": "false",
                                            "ui": {
                                                "label": {
                                                "type": "checkbox"
                                            "type": "bool",
                                            "value": "true",
                                            "ui": {
                                                "label": {
                                                "type": "checkbox"
                                            "type": "str",
                                            "value": "-1",
                                            "ui": {
                                                "label": {
                                                "type": "select",
                                                "opts": {
                                                    "opts": [
                                                            "l": {
        "en-US": "Max"
                                                            "v": "-1"
                                                            "l": {
        "en-US": "0"
                                                            "v": "0"
                                                            "l": {
        "en-US": "1"
                                                            "v": "1"
                                                            "l": {
        "en-US": "2"
                                                            "v": "2"
                                                            "l": {
        "en-US": "3"
                                                            "v": "3"
                                                            "l": {
        "en-US": "4"
                                                            "v": "4"
                                                            "l": {
        "en-US": "5"
                                                            "v": "5"
                                                            "l": {
        "en-US": "6"
                                                            "v": "6"
                                            "type": "bool",
                                            "value": "true",
                                            "ui": {
                                                "label": {
                                                "type": "checkbox"
                                    "meta": {
                                        "version": "0.0.9",
                                    "color": "#FFCC66",
                                    "inputLabels": [
                                        "trigger"
                                    "outputLabels": [
                                        "output",
                                        "graph"
                                    "status": {
                                        "x": 680,
                                        "y": 560,
                                        "wires": [
                                                "port": 0
                                                "port": 0
                                    "name": "",
                                    "method": "GET",
                                    "ret": "txt",
                                    "url": "",
                                    "tls": "",
                                    "persist": false,
                                    "proxy": "",
                                    "authType": "",
                                    "senderr": false,
                                    "headers": [],
                                    "x": 390,
                                    "y": 180,
                                    "wires": [
                                            "1b5ccaa05d54f7c3"
                                    "type": "function",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 630,
                                    "y": 100,
                                    "wires": [
                                            "975daf96f15cfb61"
                                    "type": "json",
                                    "action": "",
                                    "pretty": false,
                                    "x": 680,
                                    "y": 180,
                                    "wires": [
                                            "e718a22973cc2864"
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 480,
                                    "wires": [
                                            "e56826252134b93a"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "3fa24f2d08195961",
                                        "0a20e852662c8cec"
                                    "x": 815,
                                    "y": 180,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "e718a22973cc2864"
                                    "x": 385,
                                    "y": 480,
                                    "wires": [
                                            "559391d1288f762a"
                                    "type": "link in",
                                    "links": [
                                        "e718a22973cc2864"
                                    "x": 225,
                                    "y": 260,
                                    "wires": [
                                            "fcc8d69a3ab88e6d"
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                            "p": "payload"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": true,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 530,
                                    "y": 440,
                                    "wires": [
                                            "e56826252134b93a"
                                    "type": "function",
                                    "func": "var remaining = flow.get('forecast.solar.ratelimit.remaining') || -1;\nvar limit = flow.get('forecast.solar.ratelimit.limit') || -1\n\nvar text = remaining.toString() + '/' + limit.toString();\nvar fill = \"green\";\n\nif (remaining == 0) {\n    fill = \"red\";\n    text = \"Limit used\";\n}\n\nif (remaining > 0 && remaining < limit / 2) {\n    fill = \"yellow\"\n}\n\nif (remaining == -1 ) {\n    fill = \"blue\"\n    text = \"Limits unknown\"\n}\n\nmsg.payload = ({ fill: fill, text: text });\n\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 580,
                                    "wires": [
                                    "type": "function",
                                    "func": "var m = {};\nm.labels = [];\nm.data = [];\n\nm.series = [];\nm.data = [];\nm.labels = [];\n\nfor (let j = 0; j <= msg.days; j++) {\n    m.data[j] = [];\n}\n\nif (msg.watt === 'watt_hours_day') {\n    var i = 0;\n    m.series.push(\"Watt hours per day\");\n    for (const key in msg.payload.result) {\n        m.labels.push(key);\n        if (msg.kwhoutput) {\n            m.data[i] = +(Math.round(msg.payload.result[key]/100)*.1).toFixed(1);\n        } else {\n            m.data[i] = msg.payload.result[key];\n        }\n        i++;\n    }\n    m.data = [m.data];\n    return { payload: [m] };\n}\n\nfor (let i = 0; i <= 23; i++) {\n\n    m.labels.push(i.toString()+':00');\n    if (msg.resolution === 4) {\n       m.labels.push(i.toString()+':15');\n    }\n    if (msg.resolution === 2 || msg.resolution == 4) {\n       m.labels.push(i.toString()+':30');\n    }\n    if (msg.resolution === 4) {\n       m.labels.push(i.toString()+':45');\n    }\n\n    for (let j = 0; j <= msg.days; j++) {\n        m.data[j].push(0);\n        if (msg.resolution === 4) {\n           m.data[j].push(0)\n        }\n        if (msg.resolution === 2 || msg.resolution == 4) {\n           m.data[j].push(0)\n        }\n        if (msg.resolution === 4) {\n           m.data[j].push(0)\n        }\n\n    }\n}\n\nvar offset = 0;\nfor (const key in msg.payload.result) {\n    var d = new Date(key)\n    if (m.series.indexOf(d.toISOString().split('T')[0]) === -1) {\n        m.series.push(d.toISOString().split('T')[0])\n    }\n\n    var h = d.getHours();\n    var minutes = d.getMinutes();\n\n    if (minutes === 0 ) {\n        offset = 0;\n    } else {\n        offset++;\n    }\n\n    if (msg.kwhoutput) {\n        m.data[m.series.length - 1][h*msg.resolution+offset] = +(Math.round(msg.payload.result[key]/100)*.1).toFixed(1);\n    } else {\n        m.data[m.series.length - 1][h*msg.resolution+offset] = msg.payload.result[key];\n    }\n}\n\nreturn { payload: [m] };\n",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 360,
                                    "y": 340,
                                    "wires": [
                                            "5b0a430fb61e70e7"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "14f2e68e572f4ef8"
                                    "x": 805,
                                    "y": 100,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "975daf96f15cfb61"
                                    "x": 245,
                                    "y": 180,
                                    "wires": [
                                            "c706820c0d61f023"
                                    "type": "catch",
                                    "name": "",
                                    "scope": null,
                                    "uncaught": false,
                                    "x": 260,
                                    "y": 440,
                                    "wires": [
                                            "f427f19392c399ce"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "dbaf8f5f5a920686"
                                    "x": 685,
                                    "y": 480,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "e56826252134b93a"
                                    "x": 385,
                                    "y": 580,
                                    "wires": [
                                            "1bfc1cde3ee94e4b"
                                    "type": "link out",
                                    "mode": "link",
                                    "links": [
                                        "2ded0c14a222b4d9",
                                        "2f42837904c91d73"
                                    "x": 375,
                                    "y": 440,
                                    "wires": []
                                    "type": "link in",
                                    "links": [
                                        "f427f19392c399ce"
                                    "x": 385,
                                    "y": 540,
                                    "wires": [
                                            "a798fbe66cf133d5"
                                    "type": "function",
                                    "func": "node.warn(msg.payload)\nmsg.payload = ({ fill: \"red\", text: msg.payload });\n\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 520,
                                    "y": 540,
                                    "wires": [
                                    "type": "link in",
                                    "links": [
                                        "f427f19392c399ce"
                                    "x": 665,
                                    "y": 280,
                                    "wires": [
                                    "type": "function",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 360,
                                    "y": 260,
                                    "wires": [
                                            "a18e96179ec2d987"
                                    "info": "Function to process the result from forecast.solar to add\nextra information, which is handy for either graphing or\nto store in a database.\n\n\nThe extra values added:\n- `msg.resolution` - The number of measurements per hour. If\nno API key is used, this will be 1. Other values may be 2 or 4.\n- `msg.days` - The number of days in the forcast. If no API\n- key is used this will be 1. Other values may be 3 or 6."
                                    "type": "function",
                                    "func": "var forecasted = msg.payload[0].series.length;\n\nif ((env.get('daystoforecast') > -1) && (env.get('daystoforecast') < forecasted)) {\n    for (i = 1; i < (forecasted - env.get('daystoforecast')); i++ ) {\n        msg.payload[0].data.pop();\n        msg.payload[0].series.pop();\n    }\n}\n\nif (env.get('watt') === 'watt_hours_day' ) {\n    forecasted = msg.payload[0].labels.length;\n    for (i = 1; i < (forecasted - env.get('daystoforecast')); i++ ) {\n        msg.payload[0].labels.pop();\n        msg.payload[0].data[0].pop();\n    }\n}\n\nif (!env.get('showtoday')) {\n    msg.payload[0].data.shift();\n    msg.payload[0].series.shift();\n}\n\nif (env.get('widengraph')) {\n    var c = msg.payload[0].labels.length;\n    var x = 0;\n    for (i = 0; i < c; i++) {\n        var remove = true;\n        for (d = 0; d < msg.payload[0].data.length; d++) {\n            if (msg.payload[0].data[d][x] > 0) {\n                remove = false;\n            }\n        }\n        if (remove) {\n            msg.payload[0].labels.splice(x, 1);\n            for (d = 0; d < msg.payload[0].data.length; d++) {\n                 msg.payload[0].data[d].splice(x, 1);\n            }\n            x--;\n        }\n        x++;\n    }\n    // Still the first and last datapoints should be zero, so\n    // add those again\n    msg.payload[0].labels.unshift('');\n    msg.payload[0].labels.push('');\n    for (d = 0; d < msg.payload[0].data.length; d++) {\n         msg.payload[0].data[d].unshift(0);\n         msg.payload[0].data[d].push(0);\n    }   \n}\n\nreturn msg;",
                                    "outputs": 1,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 590,
                                    "y": 340,
                                    "wires": [
                                    "type": "delay",
                                    "timeout": "5",
                                    "rate": "5",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 390,
                                    "y": 100,
                                    "wires": [
                                            "b9488734852cd0ca"
                                    "type": "tab",
                                    "label": "an foren",
                                    "disabled": false,
                                    "info": "",
                                    "env": []
                                    "type": "group",
                                    "style": {
                                        "fill": "#d1d1d1",
                                        "label": true,
                                        "color": "#000000"
                                    "nodes": [
                                        "9aecc09bd88aa42a",
                                        "5dc336ee1d2a02da",
                                        "008ab1d49e4bb116"
                                    "x": 154,
                                    "y": 99,
                                    "w": 672,
                                    "h": 82
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                            "p": "payload"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 120,
                                    "y": 460,
                                    "wires": [
                                            "206c8fbe5daa2c1e"
                                    "name": "Süd",
                                    "env": [
                                            "name": "latitude",
                                            "type": "num"
                                            "type": "num"
                                            "value": "40",
                                            "type": "num"
                                            "name": "azimuth",
                                            "value": "182",
                                            "type": "num"
                                            "value": "9",
                                            "type": "num"
                                            "name": "apikey",
                                            "type": "cred"
                                            "name": "watt",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                            "value": "1",
                                            "type": "str"
                                            "type": "bool",
                                            "value": "false"
                                    "x": 310,
                                    "y": 460,
                                    "wires": [
                                            "57dc8d4b5bbeaa7f"
                                    "type": "function",
                                    "func": "var pvf = msg.payload;\nvar date = moment().tz(\"Europe/Berlin\");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nreturn msg;",
                                    "outputs": 1,
                                    "timeout": "",
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [
                                            "var": "moment",
                                            "module": "moment"
                                    "x": 530,
                                    "y": 460,
                                    "wires": [
                                            "15b38fae77d09de8"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "lt",
                                            "v": "2000",
                                            "vt": "str"
                                            "t": "btwn",
                                            "v": "2000",
                                            "vt": "num",
                                            "v2": "5000",
                                            "v2t": "num"
                                            "t": "btwn",
                                            "v": "5000",
                                            "vt": "num",
                                            "v2": "8000",
                                            "v2t": "num"
                                            "t": "gt",
                                            "v": "8000",
                                            "vt": "str"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 4,
                                    "x": 690,
                                    "y": 460,
                                    "wires": [
                                            "d05020b1296929fc"
                                            "6109976a13173762"
                                            "7b0b92dc28fd1808"
                                            "0aaf3b0d4e58724e"
                                    "type": "change",
                                    "name": "SOC 100",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "100",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 860,
                                    "y": 400,
                                    "wires": [
                                            "236747505d6180f7",
                                            "5f11d27a7408ff35",
                                            "5dc336ee1d2a02da"
                                    "type": "change",
                                    "name": "SOC 60",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "60",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 860,
                                    "y": 440,
                                    "wires": [
                                            "236747505d6180f7",
                                            "5f11d27a7408ff35",
                                            "5dc336ee1d2a02da"
                                    "type": "change",
                                    "name": "SOC 40",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "40",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 860,
                                    "y": 480,
                                    "wires": [
                                            "236747505d6180f7",
                                            "5f11d27a7408ff35",
                                            "5dc336ee1d2a02da"
                                    "type": "change",
                                    "name": "SOC 20",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "20",
                                            "tot": "num"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 860,
                                    "y": 520,
                                    "wires": [
                                            "236747505d6180f7",
                                            "5f11d27a7408ff35",
                                            "5dc336ee1d2a02da"
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 290,
                                    "y": 140,
                                    "wires": [
                                            "5dc336ee1d2a02da"
                                    "type": "join",
                                    "name": "",
                                    "mode": "custom",
                                    "build": "object",
                                    "key": "topic",
                                    "joiner": "\\n",
                                    "accumulate": true,
                                    "timeout": "",
                                    "count": "2",
                                    "reduceExp": "",
                                    "reduceInit": "",
                                    "reduceFixup": "",
                                    "x": 590,
                                    "y": 140,
                                    "wires": [
                                            "008ab1d49e4bb116"
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 750,
                                    "y": 140,
                                    "wires": [
                                            "b4c362324a598e06",
                                            "0e44e66f0eb20551"
                                    "type": "comment",
                                    "info": "",
                                    "x": 330,
                                    "y": 400,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 540,
                                    "y": 400,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 130,
                                    "y": 400,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 820,
                                    "y": 580,
                                    "wires": []
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1170,
                                    "y": 400,
                                    "wires": []
                                    "x": 1170,
                                    "y": 480,
                                    "wires": [
                                    "type": "comment",
                                    "info": "",
                                    "x": 1150,
                                    "y": 580,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 640,
                                    "y": 220,
                                    "wires": []
                                    "type": "comment",
                                    "info": "",
                                    "x": 280,
                                    "y": 220,
                                    "wires": []
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1110,
                                    "y": 60,
                                    "wires": []
                                    "x": 1110,
                                    "y": 120,
                                    "wires": [
                                    "type": "comment",
                                    "info": "",
                                    "x": 1060,
                                    "y": 220,
                                    "wires": []
                            • mickymM Offline
                              mickymM Offline
                              mickym
                              Ja jetzt kann ich damit was anfangen.
                              • mickymM Offline
                                mickymM Offline
                                mickym
                                So ich habs mal so geändert wie ich es für sinnvoll halte - was Deine getNodes da sollen weiß ich nicht. Du kannst die Debug node (check) bei Bedarf auch aktivieren, um die Werte zu sehen:
                                Hier zum Import:
                                       "id": "9ff1adc1f1d7f345",
                                       "type": "group",
                                       "name": "Batterie laden",
                                       "style": {
                                           "fill": "#e3f3d3",
                                           "label": true
                                       "nodes": [
                                           "9aecc09bd88aa42a",
                                           "5dc336ee1d2a02da",
                                           "008ab1d49e4bb116",
                                           "280378479ef948d1",
                                           "55de461857057e67",
                                           "b4c362324a598e06",
                                           "199bac5fd12314a5",
                                           "a0eb0619db94c4eb",
                                           "d9b7d0cba2770204",
                                           "9007e4e2286d3099",
                                           "d5fdbbd7c183f956"
                                       "x": 54,
                                       "y": 39,
                                       "w": 1412,
                                       "h": 202
                                       "g": "9ff1adc1f1d7f345",
                                       "name": "SOC von Batterie",
                                       "onlyack": "",
                                       "func": "all",
                                       "gap": "",
                                       "x": 160,
                                       "y": 120,
                                       "wires": [
                                               "a0eb0619db94c4eb"
                                       "type": "join",
                                       "name": "",
                                       "mode": "custom",
                                       "build": "object",
                                       "key": "topic",
                                       "joiner": "\\n",
                                       "accumulate": true,
                                       "timeout": "",
                                       "count": "2",
                                       "reduceExp": "",
                                       "reduceInit": "",
                                       "reduceFixup": "",
                                       "x": 590,
                                       "y": 120,
                                       "wires": [
                                               "008ab1d49e4bb116",
                                               "d9b7d0cba2770204"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "jsonata_exp",
                                               "v": "payload.batterie < payload.soll",
                                               "vt": "jsonata"
                                               "t": "jsonata_exp",
                                               "v": "payload.batterie >= payload.soll",
                                               "vt": "jsonata"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 750,
                                       "y": 120,
                                       "wires": [
                                               "9007e4e2286d3099"
                                               "d5fdbbd7c183f956"
                                       "type": "comment",
                                       "info": "",
                                       "x": 600,
                                       "y": 200,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 240,
                                       "y": 200,
                                       "wires": []
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 1290,
                                       "y": 120,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 1060,
                                       "y": 200,
                                       "wires": []
                                       "id": "a0eb0619db94c4eb",
                                       "type": "change",
                                       "name": "topic = batterie",
                                       "rules": [
                                               "t": "set",
                                               "p": "topic",
                                               "pt": "msg",
                                               "to": "batterie",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 380,
                                       "y": 120,
                                       "wires": [
                                               "5dc336ee1d2a02da"
                                       "id": "d9b7d0cba2770204",
                                       "type": "debug",
                                       "name": "check",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 750,
                                       "y": 80,
                                       "wires": []
                                       "id": "9007e4e2286d3099",
                                       "type": "change",
                                       "name": "Enable battery charge",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "true",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 980,
                                       "y": 100,
                                       "wires": [
                                               "b4c362324a598e06"
                                       "id": "d5fdbbd7c183f956",
                                       "type": "change",
                                       "name": "Disable battery charge",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 980,
                                       "y": 140,
                                       "wires": [
                                               "b4c362324a598e06"
                                       "id": "d7e7bb5a646b4ae4",
                                       "type": "group",
                                       "name": "Batterie SOC festlegen",
                                       "style": {
                                           "fill": "#ffffbf",
                                           "label": true
                                       "nodes": [
                                           "47a4cf54866c5a93",
                                           "206c8fbe5daa2c1e",
                                           "57dc8d4b5bbeaa7f",
                                           "15b38fae77d09de8",
                                           "d05020b1296929fc",
                                           "6109976a13173762",
                                           "7b0b92dc28fd1808",
                                           "0aaf3b0d4e58724e",
                                           "32a2eb3db62922d1",
                                           "f8f09c0fbe1d0129",
                                           "2560460ee7ece326",
                                           "92f7dcf1abe763bc",
                                           "236747505d6180f7",
                                           "4036c9e7d228d42d",
                                           "c1bbed615c6ed975",
                                           "5a7dd1be9fc513dc"
                                       "x": 54,
                                       "y": 359,
                                       "w": 1412,
                                       "h": 262
                                       "type": "subflow",
                                       "category": "",
                                       "in": [
                                               "x": 240,
                                               "y": 100,
                                               "wires": [
                                       "out": [
                                               "x": 760,
                                               "y": 260,
                                               "wires": [
                                                       "port": 0
                                                       "port": 0
                                               "x": 770,
                                               "y": 340,
                                               "wires": [
                                                       "port": 0
                                       "env": [
                                               "name": "latitude",
                                               "type": "num",
                                               "value": "51.3",
                                               "ui": {
                                                   "type": "input",
                                                   "opts": {
                                                       "types": [
                                                           "num"
                                               "type": "num",
                                               "value": "5.6",
                                               "ui": {
                                                   "type": "input",
                                                   "opts": {
                                                       "types": [
                                                           "num"
                                               "type": "num",
                                               "value": "37",
                                               "ui": {
                                                   "type": "input",
                                                   "opts": {
                                                       "types": [
                                                           "num"
                                               "name": "azimuth",
                                               "type": "num",
                                               "value": "0",
                                               "ui": {
                                                   "type": "spinner",
                                                   "opts": {
                                                       "min": -180,
                                                       "max": 180
                                               "type": "num",
                                               "value": "1",
                                               "ui": {
                                                   "type": "input",
                                                   "opts": {
                                                       "types": [
                                                           "num"
                                               "name": "apikey",
                                               "type": "cred",
                                               "ui": {
                                                   "type": "input",
                                                   "opts": {
                                                       "types": [
                                                           "cred"
                                               "name": "type",
                                               "type": "str",
                                               "ui": {
                                                   "label": {
                                                       "en-US": "type"
                                                   "type": "select",
                                                   "opts": {
                                                       "opts": [
                                                               "l": {
        "en-US": "Estimate"
                                                               "v": "estimate"
                                                               "l": {
        "en-US": "History"
                                                               "v": "history"
                                                               "l": {
                                                               "v": "clearsky"
                                               "name": "watt",
                                               "type": "str",
                                               "value": "watts",
                                               "ui": {
                                                   "type": "select",
                                                   "opts": {
                                                       "opts": [
                                                               "l": {
                                                               "v": "watts"
                                                               "l": {
                                                               "l": {
                                                               "v": "watt_hours"
                                                               "l": {
                                               "type": "bool",
                                               "value": "false",
                                               "ui": {
                                                   "label": {
                                                   "type": "checkbox"
                                               "type": "bool",
                                               "value": "true",
                                               "ui": {
                                                   "label": {
                                                   "type": "checkbox"
                                               "type": "str",
                                               "value": "-1",
                                               "ui": {
                                                   "label": {
                                                   "type": "select",
                                                   "opts": {
                                                       "opts": [
                                                               "l": {
        "en-US": "Max"
                                                               "v": "-1"
                                                               "l": {
        "en-US": "0"
                                                               "v": "0"
                                                               "l": {
        "en-US": "1"
                                                               "v": "1"
                                                               "l": {
        "en-US": "2"
                                                               "v": "2"
                                                               "l": {
        "en-US": "3"
                                                               "v": "3"
                                                               "l": {
        "en-US": "4"
                                                               "v": "4"
                                                               "l": {
        "en-US": "5"
                                                               "v": "5"
                                                               "l": {
        "en-US": "6"
                                                               "v": "6"
                                               "type": "bool",
                                               "value": "true",
                                               "ui": {
                                                   "label": {
                                                   "type": "checkbox"
                                       "meta": {
                                           "version": "0.0.9",
                                       "color": "#FFCC66",
                                       "inputLabels": [
                                           "trigger"
                                       "outputLabels": [
                                           "output",
                                           "graph"
                                       "status": {
                                           "x": 680,
                                           "y": 560,
                                           "wires": [
                                                   "port": 0
                                                   "port": 0
                                       "name": "",
                                       "method": "GET",
                                       "ret": "txt",
                                       "url": "",
                                       "tls": "",
                                       "persist": false,
                                       "proxy": "",
                                       "authType": "",
                                       "senderr": false,
                                       "headers": [],
                                       "x": 390,
                                       "y": 180,
                                       "wires": [
                                               "1b5ccaa05d54f7c3"
                                       "type": "function",
                                       "outputs": 1,
                                       "timeout": "",
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 630,
                                       "y": 100,
                                       "wires": [
                                               "975daf96f15cfb61"
                                       "type": "json",
                                       "property": "payload",
                                       "action": "",
                                       "pretty": false,
                                       "x": 680,
                                       "y": 180,
                                       "wires": [
                                               "e718a22973cc2864"
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 520,
                                       "y": 480,
                                       "wires": [
                                               "e56826252134b93a"
                                       "type": "link out",
                                       "mode": "link",
                                       "links": [
                                           "3fa24f2d08195961",
                                           "0a20e852662c8cec"
                                       "x": 815,
                                       "y": 180,
                                       "wires": []
                                       "type": "link in",
                                       "links": [
                                           "e718a22973cc2864"
                                       "x": 385,
                                       "y": 480,
                                       "wires": [
                                               "559391d1288f762a"
                                       "type": "link in",
                                       "links": [
                                           "e718a22973cc2864"
                                       "x": 225,
                                       "y": 260,
                                       "wires": [
                                               "fcc8d69a3ab88e6d"
                                       "type": "inject",
                                       "name": "",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": true,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "",
                                       "payloadType": "date",
                                       "x": 530,
                                       "y": 440,
                                       "wires": [
                                               "e56826252134b93a"
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 520,
                                       "y": 580,
                                       "wires": [
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 360,
                                       "y": 340,
                                       "wires": [
                                               "5b0a430fb61e70e7"
                                       "type": "link out",
                                       "mode": "link",
                                       "links": [
                                           "14f2e68e572f4ef8"
                                       "x": 805,
                                       "y": 100,
                                       "wires": []
                                       "type": "link in",
                                       "links": [
                                           "975daf96f15cfb61"
                                       "x": 245,
                                       "y": 180,
                                       "wires": [
                                               "c706820c0d61f023"
                                       "type": "catch",
                                       "name": "",
                                       "scope": null,
                                       "uncaught": false,
                                       "x": 260,
                                       "y": 440,
                                       "wires": [
                                               "f427f19392c399ce"
                                       "type": "link out",
                                       "mode": "link",
                                       "links": [
                                           "dbaf8f5f5a920686"
                                       "x": 685,
                                       "y": 480,
                                       "wires": []
                                       "type": "link in",
                                       "links": [
                                           "e56826252134b93a"
                                       "x": 385,
                                       "y": 580,
                                       "wires": [
                                               "1bfc1cde3ee94e4b"
                                       "type": "link out",
                                       "mode": "link",
                                       "links": [
                                           "2ded0c14a222b4d9",
                                           "2f42837904c91d73"
                                       "x": 375,
                                       "y": 440,
                                       "wires": []
                                       "type": "link in",
                                       "links": [
                                           "f427f19392c399ce"
                                       "x": 385,
                                       "y": 540,
                                       "wires": [
                                               "a798fbe66cf133d5"
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 520,
                                       "y": 540,
                                       "wires": [
                                       "type": "link in",
                                       "links": [
                                           "f427f19392c399ce"
                                       "x": 665,
                                       "y": 280,
                                       "wires": [
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 360,
                                       "y": 260,
                                       "wires": [
                                               "a18e96179ec2d987"
                                       "type": "function",
                                       "outputs": 1,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 590,
                                       "y": 340,
                                       "wires": [
                                       "type": "delay",
                                       "timeout": "5",
                                       "rate": "5",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 390,
                                       "y": 100,
                                       "wires": [
                                               "b9488734852cd0ca"
                                       "type": "inject",
                                       "g": "d7e7bb5a646b4ae4",
                                       "name": "",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "",
                                       "x": 180,
                                       "y": 460,
                                       "wires": [
                                               "206c8fbe5daa2c1e"
                                       "name": "Süd",
                                       "env": [
                                               "name": "latitude",
                                               "type": "num"
                                               "type": "num"
                                               "value": "40",
                                               "type": "num"
                                               "name": "azimuth",
                                               "value": "182",
                                               "type": "num"
                                               "value": "9",
                                               "type": "num"
                                               "name": "apikey",
                                               "type": "cred"
                                               "name": "watt",
                                               "type": "str"
                                               "type": "bool",
                                               "value": "false"
                                               "value": "1",
                                               "type": "str"
                                               "type": "bool",
                                               "value": "false"
                                       "x": 370,
                                       "y": 460,
                                       "wires": [
                                               "57dc8d4b5bbeaa7f"
                                       "type": "function",
                                       "outputs": 1,
                                       "timeout": "",
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [
                                               "var": "moment",
                                               "module": "moment"
                                       "x": 590,
                                       "y": 460,
                                       "wires": [
                                               "15b38fae77d09de8"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "lt",
                                               "v": "2000",
                                               "vt": "str"
                                               "t": "btwn",
                                               "v": "2000",
                                               "vt": "num",
                                               "v2": "5000",
                                               "v2t": "num"
                                               "t": "btwn",
                                               "v": "5000",
                                               "vt": "num",
                                               "v2": "8000",
                                               "v2t": "num"
                                               "t": "gt",
                                               "v": "8000",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 4,
                                       "x": 750,
                                       "y": 460,
                                       "wires": [
                                               "d05020b1296929fc"
                                               "6109976a13173762"
                                               "7b0b92dc28fd1808"
                                               "0aaf3b0d4e58724e"
                                       "type": "change",
                                       "name": "SOC 100",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "100",
                                               "tot": "num"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 920,
                                       "y": 400,
                                       "wires": [
                                               "5a7dd1be9fc513dc"
                                       "type": "change",
                                       "name": "SOC 60",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "60",
                                               "tot": "num"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 920,
                                       "y": 440,
                                       "wires": [
                                               "5a7dd1be9fc513dc"
                                       "type": "change",
                                       "name": "SOC 40",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "40",
                                               "tot": "num"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 920,
                                       "y": 480,
                                       "wires": [
                                               "5a7dd1be9fc513dc"
                                       "type": "change",
                                       "name": "SOC 20",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "20",
                                               "tot": "num"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 920,
                                       "y": 520,
                                       "wires": [
                                               "5a7dd1be9fc513dc"
                                       "type": "comment",
                                       "info": "",
                                       "x": 390,
                                       "y": 400,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 600,
                                       "y": 400,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 190,
                                       "y": 400,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 880,
                                       "y": 580,
                                       "wires": []
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 1290,
                                       "y": 460,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 1210,
                                       "y": 580,
                                       "wires": []
                                       "id": "c1bbed615c6ed975",
                                       "type": "change",
                                       "name": "topic = soll",
                                       "rules": [
                                               "t": "set",
                                               "p": "topic",
                                               "pt": "msg",
                                               "to": "soll",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1170,
                                       "y": 400,
                                       "wires": [
                                               "5dc336ee1d2a02da"
                                       "id": "5a7dd1be9fc513dc",
                                       "type": "junction",
                                       "x": 1060,
                                       "y": 460,
                                       "wires": [
                                               "c1bbed615c6ed975",
                                               "236747505d6180f7"
                                Im Übrigen, WENN das so klappt - warum postest Du eigentlich nicht von Anfang an Deinen Flow und wir mühen uns ab, weil wir nicht wissen, was Du machen willst?
                                  Armin 2
                                  Vielen Dank , So klappt es.
                                  Ich bin neue hier, und wusste nicht genau was Ihr braucht.
                                  Bei der nächsten Frage klappt es hoffentlich besser.
                                  Aber jetzt haben wir es ja.
                                  Das zweite Schreiben an den IOBroker, ist zum Setzen des Bestätigung Bits auf true.
                                  Sonst wird der Wert nicht verschickt.
                                  Nochmal vielen Dank, wieder viel dazu gelernt.
                                  Armin
                                  • A Armin 2
                                    Armin
                                    Armin 2
                                    @armin-2
                                    Hallo hier doch nochmal eine Frage, welcher Fehler ist in dem Teil Werte addieren, den ich dazwichen geschoben habe?
                                    Ich habe drei verschiedene Solarausrichtungen.
                                            "type": "subflow",
                                            "category": "",
                                            "in": [
                                                    "x": 240,
                                                    "y": 100,
                                                    "wires": [
                                            "out": [
                                                    "x": 760,
                                                    "y": 260,
                                                    "wires": [
                                                            "port": 0
                                                            "port": 0
                                                    "x": 770,
                                                    "y": 340,
                                                    "wires": [
                                                            "port": 0
                                            "env": [
                                                    "name": "latitude",
                                                    "type": "num",
                                                    "value": "51.3",
                                                    "ui": {
                                                        "type": "input",
                                                        "opts": {
                                                            "types": [
        "num"
                                                    "type": "num",
                                                    "value": "5.6",
                                                    "ui": {
                                                        "type": "input",
                                                        "opts": {
                                                            "types": [
        "num"
                                                    "type": "num",
                                                    "value": "37",
                                                    "ui": {
                                                        "type": "input",
                                                        "opts": {
                                                            "types": [
        "num"
                                                    "name": "azimuth",
                                                    "type": "num",
                                                    "value": "0",
                                                    "ui": {
                                                        "type": "spinner",
                                                        "opts": {
                                                            "min": -180,
                                                            "max": 180
                                                    "type": "num",
                                                    "value": "1",
                                                    "ui": {
                                                        "type": "input",
                                                        "opts": {
                                                            "types": [
        "num"
                                                    "name": "apikey",
                                                    "type": "cred",
                                                    "ui": {
                                                        "type": "input",
                                                        "opts": {
                                                            "types": [
        "cred"
                                                    "name": "type",
                                                    "type": "str",
                                                    "ui": {
                                                        "label": {
                                                            "en-US": "type"
                                                        "type": "select",
                                                        "opts": {
                                                            "opts": [
        "l": {
        "en-US": "Estimate"
        "v": "estimate"
        "l": {
        "en-US": "History"
        "v": "history"
        "l": {
        "v": "clearsky"
                                                    "name": "watt",
                                                    "type": "str",
                                                    "value": "watts",
                                                    "ui": {
                                                        "type": "select",
                                                        "opts": {
                                                            "opts": [
        "l": {
        "v": "watts"
        "l": {
        "l": {
        "v": "watt_hours"
        "l": {
                                                    "type": "bool",
                                                    "value": "false",
                                                    "ui": {
                                                        "label": {
                                                        "type": "checkbox"
                                                    "type": "bool",
                                                    "value": "true",
                                                    "ui": {
                                                        "label": {
                                                        "type": "checkbox"
                                                    "type": "str",
                                                    "value": "-1",
                                                    "ui": {
                                                        "label": {
                                                        "type": "select",
                                                        "opts": {
                                                            "opts": [
        "l": {
        "en-US": "Max"
        "v": "-1"
        "l": {
        "en-US": "0"
        "v": "0"
        "l": {
        "en-US": "1"
        "v": "1"
        "l": {
        "en-US": "2"
        "v": "2"
        "l": {
        "en-US": "3"
        "v": "3"
        "l": {
        "en-US": "4"
        "v": "4"
        "l": {
        "en-US": "5"
        "v": "5"
        "l": {
        "en-US": "6"
        "v": "6"
                                                    "type": "bool",
                                                    "value": "true",
                                                    "ui": {
                                                        "label": {
                                                        "type": "checkbox"
                                            "meta": {
                                                "version": "0.0.9",
                                            "color": "#FFCC66",
                                            "inputLabels": [
                                                "trigger"
                                            "outputLabels": [
                                                "output",
                                                "graph"
                                            "status": {
                                                "x": 680,
                                                "y": 560,
                                                "wires": [
                                                        "port": 0
                                                        "port": 0
                                            "name": "",
                                            "method": "GET",
                                            "ret": "txt",
                                            "url": "",
                                            "tls": "",
                                            "persist": false,
                                            "proxy": "",
                                            "authType": "",
                                            "senderr": false,
                                            "headers": [],
                                            "x": 390,
                                            "y": 180,
                                            "wires": [
                                                    "1b5ccaa05d54f7c3"
                                            "type": "function",
                                            "outputs": 1,
                                            "timeout": "",
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 630,
                                            "y": 100,
                                            "wires": [
                                                    "975daf96f15cfb61"
                                            "type": "json",
                                            "action": "",
                                            "pretty": false,
                                            "x": 680,
                                            "y": 180,
                                            "wires": [
                                                    "e718a22973cc2864"
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 520,
                                            "y": 480,
                                            "wires": [
                                                    "e56826252134b93a"
                                            "type": "link out",
                                            "mode": "link",
                                            "links": [
                                                "3fa24f2d08195961",
                                                "0a20e852662c8cec"
                                            "x": 815,
                                            "y": 180,
                                            "wires": []
                                            "type": "link in",
                                            "links": [
                                                "e718a22973cc2864"
                                            "x": 385,
                                            "y": 480,
                                            "wires": [
                                                    "559391d1288f762a"
                                            "type": "link in",
                                            "links": [
                                                "e718a22973cc2864"
                                            "x": 225,
                                            "y": 260,
                                            "wires": [
                                                    "fcc8d69a3ab88e6d"
                                            "type": "inject",
                                            "name": "",
                                            "props": [
                                                    "p": "payload"
                                                    "p": "topic",
                                                    "vt": "str"
                                            "repeat": "",
                                            "crontab": "",
                                            "once": true,
                                            "onceDelay": 0.1,
                                            "topic": "",
                                            "payload": "",
                                            "x": 530,
                                            "y": 440,
                                            "wires": [
                                                    "e56826252134b93a"
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 520,
                                            "y": 580,
                                            "wires": [
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 360,
                                            "y": 340,
                                            "wires": [
                                                    "5b0a430fb61e70e7"
                                            "type": "link out",
                                            "mode": "link",
                                            "links": [
                                                "14f2e68e572f4ef8"
                                            "x": 805,
                                            "y": 100,
                                            "wires": []
                                            "type": "link in",
                                            "links": [
                                                "975daf96f15cfb61"
                                            "x": 245,
                                            "y": 180,
                                            "wires": [
                                                    "c706820c0d61f023"
                                            "type": "catch",
                                            "name": "",
                                            "scope": null,
                                            "uncaught": false,
                                            "x": 260,
                                            "y": 440,
                                            "wires": [
                                                    "f427f19392c399ce"
                                            "type": "link out",
                                            "mode": "link",
                                            "links": [
                                                "dbaf8f5f5a920686"
                                            "x": 685,
                                            "y": 480,
                                            "wires": []
                                            "type": "link in",
                                            "links": [
                                                "e56826252134b93a"
                                            "x": 385,
                                            "y": 580,
                                            "wires": [
                                                    "1bfc1cde3ee94e4b"
                                            "type": "link out",
                                            "mode": "link",
                                            "links": [
                                                "2ded0c14a222b4d9",
                                                "2f42837904c91d73"
                                            "x": 375,
                                            "y": 440,
                                            "wires": []
                                            "type": "link in",
                                            "links": [
                                                "f427f19392c399ce"
                                            "x": 385,
                                            "y": 540,
                                            "wires": [
                                                    "a798fbe66cf133d5"
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 520,
                                            "y": 540,
                                            "wires": [
                                            "type": "link in",
                                            "links": [
                                                "f427f19392c399ce"
                                            "x": 665,
                                            "y": 280,
                                            "wires": [
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 360,
                                            "y": 260,
                                            "wires": [
                                                    "a18e96179ec2d987"
                                            "type": "function",
                                            "outputs": 1,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 590,
                                            "y": 340,
                                            "wires": [
                                            "type": "delay",
                                            "timeout": "5",
                                            "rate": "5",
                                            "randomFirst": "1",
                                            "randomLast": "5",
                                            "drop": false,
                                            "allowrate": false,
                                            "outputs": 1,
                                            "x": 390,
                                            "y": 100,
                                            "wires": [
                                                    "b9488734852cd0ca"
                                            "id": "11da2ee7fe92bba9",
                                            "type": "tab",
                                            "label": "Batterie Laden",
                                            "disabled": false,
                                            "info": "",
                                            "env": []
                                            "id": "882f920692db15ac",
                                            "type": "group",
                                            "z": "11da2ee7fe92bba9",
                                            "style": {
                                                "fill": "#d1d1d1",
                                                "label": true,
                                                "color": "#0070c0"
                                            "nodes": [
                                                "d2960c5258a6aa87",
                                                "0e02a8c5b8713878",
                                                "a556e20d6775b89e",
                                                "eaa7a8710b8bd555",
                                                "5dd7f104e86726b9",
                                                "87926d98a6caa2b7",
                                                "86a568bb366b5a53",
                                                "4951b0f4623d4bba",
                                                "d9368294d9621a30",
                                                "6c3cb62857c3f0cc",
                                                "3ccafa7058527caf",
                                                "b99a5fcf56fa30db"
                                            "x": 14,
                                            "y": 39,
                                            "w": 1532,
                                            "h": 222
                                            "id": "8885f238d46c98d4",
                                            "type": "group",
                                            "style": {
                                                "fill": "#d1d1d1",
                                                "label": true,
                                                "color": "#0070c0"
                                            "nodes": [
                                                "cc1bdb4e806c49d3",
                                                "08f1fa9012a05ea5",
                                                "c4d7dd8d06fa28f9",
                                                "0e39db21507d2496",
                                                "db9a8c492c1eacbf",
                                                "af5c4e99e154bf35",
                                                "0d520e8869dda085",
                                                "162844c501bda2cb",
                                                "29adc486d67dc5b4",
                                                "70bc14a931ad4c71",
                                                "df70959a7049e70c",
                                                "0740f2f6d8be4dc3",
                                                "c0f098512f61f09e",
                                                "db2f79c5ba46ec03",
                                                "8cdb8e157b315411",
                                                "3d56edb712404a94",
                                                "7dcab65894d85d27",
                                                "805b9497e42fd964",
                                                "af50b69abaa6e3f2",
                                                "0217fa6ea639b794",
                                                "6def2e19d5482654",
                                                "a3feba0d2f7707c9",
                                                "1d46f7e375b6f7e2",
                                                "043c5238cb193231",
                                                "98639d190c555169",
                                                "bb6880f6962e941b"
                                            "x": 14,
                                            "y": 379,
                                            "w": 1532,
                                            "h": 302
                                            "id": "3d56edb712404a94",
                                            "type": "junction",
                                            "g": "8885f238d46c98d4",
                                            "x": 1140,
                                            "y": 480,
                                            "wires": [
                                                    "8cdb8e157b315411"
                                            "id": "d2960c5258a6aa87",
                                            "type": "ioBroker in",
                                            "g": "882f920692db15ac",
                                            "attrname": "payload",
                                            "topic": "alpha-ess.0.Realtime.Battery_SOC",
                                            "payloadType": "value",
                                            "onlyack": "",
                                            "func": "all",
                                            "gap": "",
                                            "fireOnStart": "true",
                                            "outFormat": "MQTT",
                                            "x": 120,
                                            "y": 140,
                                            "wires": [
                                                    "4951b0f4623d4bba"
                                            "id": "0e02a8c5b8713878",
                                            "type": "join",
                                            "name": "",
                                            "mode": "custom",
                                            "build": "object",
                                            "propertyType": "msg",
                                            "key": "topic",
                                            "joiner": "\\n",
                                            "joinerType": "str",
                                            "accumulate": true,
                                            "timeout": "",
                                            "count": "2",
                                            "reduceRight": false,
                                            "reduceExp": "",
                                            "reduceInit": "",
                                            "reduceInitType": "",
                                            "reduceFixup": "",
                                            "x": 490,
                                            "y": 140,
                                            "wires": [
                                                    "a556e20d6775b89e"
                                            "id": "a556e20d6775b89e",
                                            "type": "switch",
                                            "name": "",
                                            "rules": [
                                                    "t": "jsonata_exp",
                                                    "vt": "jsonata"
                                                    "t": "jsonata_exp",
                                                    "vt": "jsonata"
                                            "checkall": "true",
                                            "repair": false,
                                            "outputs": 2,
                                            "x": 630,
                                            "y": 140,
                                            "wires": [
                                                    "d9368294d9621a30"
                                                    "6c3cb62857c3f0cc"
                                            "id": "eaa7a8710b8bd555",
                                            "type": "comment",
                                            "info": "",
                                            "x": 560,
                                            "y": 220,
                                            "wires": []
                                            "id": "5dd7f104e86726b9",
                                            "type": "comment",
                                            "info": "",
                                            "x": 200,
                                            "y": 220,
                                            "wires": []
                                            "id": "87926d98a6caa2b7",
                                            "type": "ioBroker out",
                                            "name": "Battery Charging enabled [gridCharge]",
                                            "topic": "alpha-ess.0.Settings_Charge.Battery_Charging_enabled",
                                            "ack": "false",
                                            "autoCreate": "false",
                                            "stateName": "",
                                            "role": "",
                                            "payloadType": "",
                                            "readonly": "",
                                            "stateUnit": "",
                                            "stateMin": "",
                                            "stateMax": "",
                                            "x": 1330,
                                            "y": 140,
                                            "wires": []
                                            "id": "86a568bb366b5a53",
                                            "type": "comment",
                                            "info": "",
                                            "x": 1020,
                                            "y": 220,
                                            "wires": []
                                            "id": "4951b0f4623d4bba",
                                            "type": "change",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "topic",
                                                    "pt": "msg",
                                                    "to": "batterie",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 320,
                                            "y": 140,
                                            "wires": [
                                                    "0e02a8c5b8713878"
                                            "id": "d9368294d9621a30",
                                            "type": "change",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "true",
                                                    "tot": "bool"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 820,
                                            "y": 120,
                                            "wires": [
                                                    "b99a5fcf56fa30db"
                                            "id": "6c3cb62857c3f0cc",
                                            "type": "change",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "false",
                                                    "tot": "bool"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 820,
                                            "y": 160,
                                            "wires": [
                                                    "b99a5fcf56fa30db"
                                            "id": "cc1bdb4e806c49d3",
                                            "type": "inject",
                                            "name": "Set",
                                            "props": [
                                                    "p": "payload"
                                                    "p": "topic",
                                                    "vt": "str"
                                            "repeat": "",
                                            "crontab": "",
                                            "once": false,
                                            "onceDelay": 0.1,
                                            "topic": "",
                                            "payload": "",
                                            "x": 110,
                                            "y": 480,
                                            "wires": [
                                                    "08f1fa9012a05ea5",
                                                    "7dcab65894d85d27",
                                                    "805b9497e42fd964"
                                            "id": "08f1fa9012a05ea5",
                                            "name": "Süd",
                                            "env": [
                                                    "name": "latitude",
                                                    "type": "num"
                                                    "type": "num"
                                                    "value": "40",
                                                    "type": "num"
                                                    "name": "azimuth",
                                                    "value": "182",
                                                    "type": "num"
                                                    "value": "9",
                                                    "type": "num"
                                                    "name": "apikey",
                                                    "type": "cred"
                                                    "name": "watt",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                                    "value": "1",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                            "x": 230,
                                            "y": 480,
                                            "wires": [
                                                    "c4d7dd8d06fa28f9"
                                            "id": "c4d7dd8d06fa28f9",
                                            "type": "function",
                                            "name": "f1",
                                            "outputs": 1,
                                            "timeout": "",
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [
                                                    "var": "moment",
                                                    "module": "moment"
                                            "x": 390,
                                            "y": 460,
                                            "wires": [
                                                    "1d46f7e375b6f7e2"
                                            "id": "0e39db21507d2496",
                                            "type": "switch",
                                            "name": "",
                                            "rules": [
                                                    "t": "lt",
                                                    "v": "2000",
                                                    "vt": "str"
                                                    "t": "btwn",
                                                    "v": "2000",
                                                    "vt": "num",
                                                    "v2": "5000",
                                                    "v2t": "num"
                                                    "t": "btwn",
                                                    "v": "5000",
                                                    "vt": "num",
                                                    "v2": "8000",
                                                    "v2t": "num"
                                                    "t": "gt",
                                                    "v": "8000",
                                                    "vt": "str"
                                            "checkall": "true",
                                            "repair": false,
                                            "outputs": 4,
                                            "x": 890,
                                            "y": 480,
                                            "wires": [
                                                    "db9a8c492c1eacbf"
                                                    "af5c4e99e154bf35"
                                                    "0d520e8869dda085"
                                                    "162844c501bda2cb"
                                            "id": "db9a8c492c1eacbf",
                                            "type": "change",
                                            "name": "SOC 100",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "100",
                                                    "tot": "num"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 1040,
                                            "y": 420,
                                            "wires": [
                                                    "3d56edb712404a94"
                                            "id": "af5c4e99e154bf35",
                                            "type": "change",
                                            "name": "SOC 60",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "60",
                                                    "tot": "num"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 1040,
                                            "y": 460,
                                            "wires": [
                                                    "3d56edb712404a94"
                                            "id": "0d520e8869dda085",
                                            "type": "change",
                                            "name": "SOC 40",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "40",
                                                    "tot": "num"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 1040,
                                            "y": 500,
                                            "wires": [
                                                    "3d56edb712404a94"
                                            "id": "162844c501bda2cb",
                                            "type": "change",
                                            "name": "SOC 20",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "20",
                                                    "tot": "num"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 1040,
                                            "y": 540,
                                            "wires": [
                                                    "3d56edb712404a94"
                                            "id": "29adc486d67dc5b4",
                                            "type": "comment",
                                            "info": "",
                                            "x": 230,
                                            "y": 420,
                                            "wires": []
                                            "id": "70bc14a931ad4c71",
                                            "type": "comment",
                                            "info": "",
                                            "x": 460,
                                            "y": 640,
                                            "wires": []
                                            "id": "df70959a7049e70c",
                                            "type": "comment",
                                            "info": "",
                                            "x": 170,
                                            "y": 640,
                                            "wires": []
                                            "id": "0740f2f6d8be4dc3",
                                            "type": "comment",
                                            "info": "",
                                            "x": 1020,
                                            "y": 620,
                                            "wires": []
                                            "id": "c0f098512f61f09e",
                                            "ack": "false",
                                            "stateName": "",
                                            "role": "",
                                            "payloadType": "",
                                            "readonly": "",
                                            "stateUnit": "",
                                            "stateMin": "",
                                            "stateMax": "",
                                            "x": 1330,
                                            "y": 480,
                                            "wires": []
                                            "id": "db2f79c5ba46ec03",
                                            "type": "comment",
                                            "info": "",
                                            "x": 1310,
                                            "y": 620,
                                            "wires": []
                                            "id": "8cdb8e157b315411",
                                            "type": "change",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "topic",
                                                    "pt": "msg",
                                                    "to": "soll",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 1250,
                                            "y": 420,
                                            "wires": [
                                                    "0e02a8c5b8713878",
                                                    "bb6880f6962e941b"
                                            "id": "3ccafa7058527caf",
                                            "type": "debug",
                                            "name": "Charging",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "complete": "payload",
                                            "targetType": "msg",
                                            "statusVal": "",
                                            "statusType": "auto",
                                            "x": 1440,
                                            "y": 80,
                                            "wires": []
                                            "id": "bb6880f6962e941b",
                                            "type": "debug",
                                            "name": "Cutoff",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "statusVal": "",
                                            "x": 1450,
                                            "y": 420,
                                            "wires": []
                                            "id": "b99a5fcf56fa30db",
                                            "type": "rbe",
                                            "name": "Nur einmal",
                                            "func": "rbe",
                                            "gap": "",
                                            "start": "",
                                            "inout": "out",
                                            "septopics": true,
                                            "topi": "topic",
                                            "x": 1030,
                                            "y": 120,
                                            "wires": [
                                                    "3ccafa7058527caf"
                                            "id": "7dcab65894d85d27",
                                            "name": "Ost",
                                            "env": [
                                                    "name": "latitude",
                                                    "type": "num"
                                                    "type": "num"
                                                    "value": "45",
                                                    "type": "num"
                                                    "name": "azimuth",
                                                    "value": "90",
                                                    "type": "num"
                                                    "value": "2",
                                                    "type": "num"
                                                    "name": "apikey",
                                                    "type": "cred"
                                                    "name": "watt",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                                    "value": "1",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                            "x": 230,
                                            "y": 540,
                                            "wires": [
                                                    "af50b69abaa6e3f2"
                                            "id": "805b9497e42fd964",
                                            "name": "West",
                                            "env": [
                                                    "name": "latitude",
                                                    "type": "num"
                                                    "type": "num"
                                                    "value": "45",
                                                    "type": "num"
                                                    "name": "azimuth",
                                                    "value": "270",
                                                    "type": "num"
                                                    "value": "3",
                                                    "type": "num"
                                                    "name": "apikey",
                                                    "type": "cred"
                                                    "name": "watt",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                                    "value": "1",
                                                    "type": "str"
                                                    "type": "bool",
                                                    "value": "false"
                                            "x": 230,
                                            "y": 600,
                                            "wires": [
                                                    "0217fa6ea639b794"
                                            "id": "af50b69abaa6e3f2",
                                            "type": "function",
                                            "name": "f2",
                                            "func": "var pvf = msg.payload;\nvar date = moment().tz(\"Europe/Berlin\");\nvar today = date.format('YYYY-MM-DD');\nvar hourEntries = Object.keys(pvf.result);\nvar todaysEntries = hourEntries.filter(x => x.startsWith(today));\nvar expectedEarning = pvf.result[todaysEntries[todaysEntries.length -1]];\nmsg.payload = expectedEarning;\nmsg.topic = expectedEarning;\nreturn msg;",
                                            "outputs": 1,
                                            "timeout": "",
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [
                                                    "var": "moment",
                                                    "module": "moment"
                                            "x": 390,
                                            "y": 520,
                                            "wires": [
                                                    "6def2e19d5482654"
                                            "id": "0217fa6ea639b794",
                                            "type": "function",
                                            "name": "f3",
                                            "outputs": 1,
                                            "timeout": "",
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [
                                                    "var": "moment",
                                                    "module": "moment"
                                            "x": 390,
                                            "y": 580,
                                            "wires": [
                                                    "a3feba0d2f7707c9"
                                            "id": "a3feba0d2f7707c9",
                                            "type": "change",
                                            "name": "L3",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "topic",
                                                    "pt": "msg",
                                                    "to": "L3",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 550,
                                            "y": 580,
                                            "wires": [
                                                    "043c5238cb193231"
                                            "id": "6def2e19d5482654",
                                            "type": "change",
                                            "name": " L2",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "topic",
                                                    "pt": "msg",
                                                    "to": "L2",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 550,
                                            "y": 520,
                                            "wires": [
                                                    "043c5238cb193231"
                                            "id": "1d46f7e375b6f7e2",
                                            "type": "change",
                                            "name": "L1",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "topic",
                                                    "pt": "msg",
                                                    "to": "L1",
                                                    "tot": "str"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 550,
                                            "y": 460,
                                            "wires": [
                                                    "043c5238cb193231"
                                            "id": "043c5238cb193231",
                                            "type": "join",
                                            "name": "",
                                            "mode": "custom",
                                            "build": "object",
                                            "key": "topic",
                                            "joiner": "\\n",
                                            "accumulate": true,
                                            "timeout": "",
                                            "count": "3",
                                            "reduceExp": "",
                                            "reduceInit": "",
                                            "reduceFixup": "",
                                            "x": 730,
                                            "y": 480,
                                            "wires": [
                                                    "0e39db21507d2496"
                                            "id": "98639d190c555169",
                                            "type": "comment",
                                            "name": "werte addieren",
                                            "info": "",
                                            "x": 620,
                                            "y": 420,
                                            "wires": []
                                    • A Armin 2
                                      @armin-2
                                              "id": "93f485839dfa27a8",
                                              "type": "subflow",
                                              "name": "Solar forecast",
                                              "category": "",
                                              "in": [
                                                      "x": 240,
                                                      "y": 100,
                                                      "wires": [
                                              "out": [
                                                      "x": 760,
                                                      "y": 260,
                                                      "wires": [
                                                              "id": "2f42837904c91d73",
                                                              "port": 0
                                                              "id": "fcc8d69a3ab88e6d",
                                                              "port": 0
                                                      "x": 770,
                                                      "y": 340,
                                                      "wires": [
                                                              "id": "5b0a430fb61e70e7",
                                                              "port": 0
                                              "env": [
                                                      "name": "latitude",
                                                      "type": "num",
                                                      "value": "51.3",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-location-arrow",
                                                          "type": "input",
                                                          "opts": {
                                                              "types": [
        "num"
                                                      "name": "longitude",
                                                      "type": "num",
                                                      "value": "5.6",
                                                      "ui": {
                                                          "type": "input",
                                                          "opts": {
                                                              "types": [
        "num"
                                                      "name": "declination",
                                                      "type": "num",
                                                      "value": "37",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-chevron-up",
                                                          "type": "input",
                                                          "opts": {
                                                              "types": [
        "num"
                                                      "name": "azimuth",
                                                      "type": "num",
                                                      "value": "0",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-compass",
                                                          "type": "spinner",
                                                          "opts": {
                                                              "min": -180,
                                                              "max": 180
                                                      "name": "modules power",
                                                      "type": "num",
                                                      "value": "1",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-power-off",
                                                          "type": "input",
                                                          "opts": {
                                                              "types": [
        "num"
                                                      "name": "apikey",
                                                      "type": "cred",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-key",
                                                          "type": "input",
                                                          "opts": {
                                                              "types": [
        "cred"
                                                      "name": "type",
                                                      "type": "str",
                                                      "value": "estimate",
                                                      "ui": {
                                                          "label": {
                                                              "en-US": "type"
                                                          "type": "select",
                                                          "opts": {
                                                              "opts": [
        "l": {
        "en-US": "Estimate"
        "v": "estimate"
        "l": {
        "en-US": "History"
        "v": "history"
        "l": {
        "en-US": "Clear sky"
        "v": "clearsky"
                                                      "name": "watt",
                                                      "type": "str",
                                                      "value": "watts",
                                                      "ui": {
                                                          "icon": "font-awesome/fa-question-circle-o",
                                                          "type": "select",
                                                          "opts": {
                                                              "opts": [
        "l": {
        "en-US": "Watts (power) average for the period"
        "v": "watts"
        "l": {
        "en-US": "Watt hours (energy) for the period"
        "v": "watt_hours_period"
        "l": {
        "en-US": "Watt hours (energy) summarized over the day"
        "v": "watt_hours"
        "l": {
        "en-US": "Watt hours (energy) summarized for each day"
        "v": "watt_hours_day"
                                                      "name": "kwhoutput",
                                                      "type": "bool",
                                                      "value": "false",
                                                      "ui": {
                                                          "label": {
                                                              "en-US": "Output in kWh (in the graph)"
                                                          "type": "checkbox"
                                                      "name": "showtoday",
                                                      "type": "bool",
                                                      "value": "true",
                                                      "ui": {
                                                          "label": {
                                                              "en-US": "Show todays forecast"
                                                          "type": "checkbox"
                                                      "name": "daystoforecast",
                                                      "type": "str",
                                                      "value": "-1",
                                                      "ui": {
                                                          "label": {
                                                              "en-US": "Days to forecast"
                                                          "type": "select",
                                                          "opts": {
                                                              "opts": [
        "l": {
        "en-US": "Max"
        "v": "-1"
        "l": {
        "en-US": "0"
        "v": "0"
        "l": {
        "en-US": "1"
        "v": "1"
        "l": {
        "en-US": "2"
        "v": "2"
        "l": {
        "en-US": "3"
        "v": "3"
        "l": {
        "en-US": "4"
        "v": "4"
        "l": {
        "en-US": "5"
        "v": "5"
        "l": {
        "en-US": "6"
        "v": "6"
                                                      "name": "widengraph",
                                                      "type": "bool",
                                                      "value": "true",
                                                      "ui": {
                                                          "label": {
                                                              "en-US": "Widen graph"
                                                          "type": "checkbox"
                                              "meta": {
                                                  "module": "Solar Forecast",
                                                  "version": "0.0.9",
                                                  "author": "dfaber@victronenergy.com",
                                                  "desc": "Get solar forecasting per location",
                                                  "keywords": "solar,forecast,api",
                                                  "license": "GPL-3.0"
                                              "color": "#FFCC66",
                                              "inputLabels": [
                                                  "trigger"
                                              "outputLabels": [
                                                  "output",
                                                  "graph"
                                              "icon": "font-awesome/fa-sun-o",
                                              "status": {
                                                  "x": 680,
                                                  "y": 560,
                                                  "wires": [
                                                          "id": "1bfc1cde3ee94e4b",
                                                          "port": 0
                                                          "id": "a798fbe66cf133d5",
                                                          "port": 0
                                              "id": "c706820c0d61f023",
                                              "type": "http request",
                                              "z": "93f485839dfa27a8",
                                              "name": "",
                                              "method": "GET",
                                              "ret": "txt",
                                              "paytoqs": "ignore",
                                              "url": "",
                                              "tls": "",
                                              "persist": false,
                                              "proxy": "",
                                              "insecureHTTPParser": false,
                                              "authType": "",
                                              "senderr": false,
                                              "headers": [],
                                              "x": 390,
                                              "y": 180,
                                              "wires": [
                                                      "1b5ccaa05d54f7c3"
                                              "id": "b9488734852cd0ca",
                                              "type": "function",
                                              "name": "create forecast.solar url",
                                              "func": "msg.url = 'https://api.forecast.solar/';\n\nif (env.get('apikey')) {\n    msg.url += env.get('apikey') + '/';\n    }\n\nmsg.url += env.get('type') + '/';\n\nmsg.url += env.get('watt') + '/';\n\nmsg.url += env.get('latitude') + '/' +\n           env.get('longitude') + '/' +\n           env.get('declination') + '/' +\n           env.get('azimuth') + '/' +\n           env.get('modules power');\n\nmsg.topic = 'solar forecast: '+(env.get('type') || '');\nmsg.topic += (' '+env.get('watt') || '');\nif (env.get('kwhoutput')) {\n    msg.topic += ' (kWh)';\n}\nreturn msg;",
                                              "outputs": 1,
                                              "timeout": "",
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 630,
                                              "y": 100,
                                              "wires": [
                                                      "975daf96f15cfb61"
                                              "id": "1b5ccaa05d54f7c3",
                                              "type": "json",
                                              "name": "Convert to json",
                                              "action": "",
                                              "pretty": false,
                                              "x": 680,
                                              "y": 180,
                                              "wires": [
                                                      "e718a22973cc2864"
                                              "id": "559391d1288f762a",
                                              "type": "function",
                                              "name": "update ratelimit",
                                              "func": "var remaining = msg.payload.message.ratelimit.remaining || 0;\nvar limit = msg.payload.message.ratelimit.limit;\n\nflow.set('forecast.solar.ratelimit.remaining', remaining)\nflow.set('forecast.solar.ratelimit.limit', limit)\n\nreturn msg;",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 520,
                                              "y": 480,
                                              "wires": [
                                                      "e56826252134b93a"
                                              "id": "e718a22973cc2864",
                                              "type": "link out",
                                              "name": "link out 1",
                                              "mode": "link",
                                              "links": [
                                                  "3fa24f2d08195961",
                                                  "0a20e852662c8cec"
                                              "x": 815,
                                              "y": 180,
                                              "wires": []
                                              "id": "3fa24f2d08195961",
                                              "type": "link in",
                                              "name": "link in 1",
                                              "links": [
                                                  "e718a22973cc2864"
                                              "x": 385,
                                              "y": 480,
                                              "wires": [
                                                      "559391d1288f762a"
                                              "id": "0a20e852662c8cec",
                                              "type": "link in",
                                              "name": "link in 2",
                                              "links": [
                                                  "e718a22973cc2864"
                                              "x": 225,
                                              "y": 260,
                                              "wires": [
                                                      "fcc8d69a3ab88e6d"
                                              "id": "4734b6f403e1f03e",
                                              "type": "inject",
                                              "name": "",
                                              "props": [
                                                      "p": "payload"
                                                      "p": "topic",
                                                      "vt": "str"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": true,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "",
                                              "x": 530,
                                              "y": 440,
                                              "wires": [
                                                      "e56826252134b93a"
                                              "type": "function",
                                              "name": "update status",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 520,
                                              "y": 580,
                                              "wires": [
                                              "id": "a18e96179ec2d987",
                                              "type": "function",
                                              "name": "Create graph output",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 360,
                                              "y": 340,
                                              "wires": [
                                                      "5b0a430fb61e70e7"
                                              "type": "link out",
                                              "mode": "link",
                                              "links": [
                                                  "14f2e68e572f4ef8"
                                              "x": 805,
                                              "y": 100,
                                              "wires": []
                                              "type": "link in",
                                              "links": [
                                                  "975daf96f15cfb61"
                                              "x": 245,
                                              "y": 180,
                                              "wires": [
                                                      "c706820c0d61f023"
                                              "type": "catch",
                                              "name": "",
                                              "scope": null,
                                              "uncaught": false,
                                              "x": 260,
                                              "y": 440,
                                              "wires": [
                                                      "f427f19392c399ce"
                                              "type": "link out",
                                              "mode": "link",
                                              "links": [
                                                  "dbaf8f5f5a920686"
                                              "x": 685,
                                              "y": 480,
                                              "wires": []
                                              "type": "link in",
                                              "links": [
                                                  "e56826252134b93a"
                                              "x": 385,
                                              "y": 580,
                                              "wires": [
                                                      "1bfc1cde3ee94e4b"
                                              "type": "link out",
                                              "mode": "link",
                                              "links": [
                                                  "2ded0c14a222b4d9",
                                                  "2f42837904c91d73"
                                              "x": 375,
                                              "y": 440,
                                              "wires": []
                                              "type": "link in",
                                              "links": [
                                                  "f427f19392c399ce"
                                              "x": 385,
                                              "y": 540,
                                              "wires": [
                                                      "a798fbe66cf133d5"
                                              "type": "function",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 520,
                                              "y": 540,
                                              "wires": [
                                              "type": "link in",
                                              "links": [
                                                  "f427f19392c399ce"
                                              "x": 665,
                                              "y": 280,
                                              "wires": [
                                              "type": "function",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 360,
                                              "y": 260,
                                              "wires": [
                                                      "a18e96179ec2d987"
                                              "type": "function",
                                              "outputs": 1,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 590,
                                              "y": 340,
                                              "wires": [
                                              "type": "delay",
                                              "timeout": "5",
                                              "rate": "5",
                                              "randomFirst": "1",
                                              "randomLast": "5",
                                              "drop": false,
                                              "allowrate": false,
                                              "outputs": 1,
                                              "x": 390,
                                              "y": 100,
                                              "wires": [
                                                      "b9488734852cd0ca"
                                              "type": "tab",
                                              "disabled": false,
                                              "info": "",
                                              "env": []
                                              "type": "group",
                                              "style": {
                                                  "fill": "#d1d1d1",
                                                  "label": true,
                                                  "color": "#0070c0"
                                              "nodes": [
                                                  "d2960c5258a6aa87",
                                                  "0e02a8c5b8713878",
                                                  "a556e20d6775b89e",
                                                  "eaa7a8710b8bd555",
                                                  "5dd7f104e86726b9",
                                                  "87926d98a6caa2b7",
                                                  "86a568bb366b5a53",
                                                  "4951b0f4623d4bba",
                                                  "d9368294d9621a30",
                                                  "6c3cb62857c3f0cc",
                                                  "3ccafa7058527caf",
                                                  "b99a5fcf56fa30db"
                                              "x": 14,
                                              "y": 39,
                                              "w": 1532,
                                              "h": 222
                                              "type": "group",
                                              "style": {
                                                  "fill": "#d1d1d1",
                                                  "label": true,
                                                  "color": "#0070c0"
                                              "nodes": [
                                                  "cc1bdb4e806c49d3",
                                                  "08f1fa9012a05ea5",
                                                  "c4d7dd8d06fa28f9",
                                                  "0e39db21507d2496",
                                                  "db9a8c492c1eacbf",
                                                  "af5c4e99e154bf35",
                                                  "0d520e8869dda085",
                                                  "162844c501bda2cb",
                                                  "29adc486d67dc5b4",
                                                  "70bc14a931ad4c71",
                                                  "df70959a7049e70c",
                                                  "0740f2f6d8be4dc3",
                                                  "c0f098512f61f09e",
                                                  "db2f79c5ba46ec03",
                                                  "8cdb8e157b315411",
                                                  "3d56edb712404a94",
                                                  "7dcab65894d85d27",
                                                  "805b9497e42fd964",
                                                  "af50b69abaa6e3f2",
                                                  "0217fa6ea639b794",
                                                  "6def2e19d5482654",
                                                  "a3feba0d2f7707c9",
                                                  "1d46f7e375b6f7e2",
                                                  "043c5238cb193231",
                                                  "98639d190c555169",
                                                  "bb6880f6962e941b"
                                              "x": 14,
                                              "y": 379,
                                              "w": 1532,
                                              "h": 302
                                              "type": "junction",
                                              "x": 1140,
                                              "y": 480,
                                              "wires": [
                                                      "8cdb8e157b315411"
                                              "onlyack": "",
                                              "func": "all",
                                              "gap": "",
                                              "x": 120,
                                              "y": 140,
                                              "wires": [
                                                      "4951b0f4623d4bba"
                                              "type": "join",
                                              "name": "",
                                              "mode": "custom",
                                              "build": "object",
                                              "key": "topic",
                                              "joiner": "\\n",
                                              "accumulate": true,
                                              "timeout": "",
                                              "count": "2",
                                              "reduceExp": "",
                                              "reduceInit": "",
                                              "reduceFixup": "",
                                              "x": 490,
                                              "y": 140,
                                              "wires": [
                                                      "a556e20d6775b89e"
                                              "type": "switch",
                                              "name": "",
                                              "rules": [
                                                      "t": "jsonata_exp",
                                                      "vt": "jsonata"
                                                      "t": "jsonata_exp",
                                                      "vt": "jsonata"
                                              "checkall": "true",
                                              "repair": false,
                                              "outputs": 2,
                                              "x": 630,
                                              "y": 140,
                                              "wires": [
                                                      "d9368294d9621a30"
                                                      "6c3cb62857c3f0cc"
                                              "type": "comment",
                                              "info": "",
                                              "x": 560,
                                              "y": 220,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 200,
                                              "y": 220,
                                              "wires": []
                                              "ack": "false",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "readonly": "",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 1330,
                                              "y": 140,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 1020,
                                              "y": 220,
                                              "wires": []
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "batterie",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 320,
                                              "y": 140,
                                              "wires": [
                                                      "0e02a8c5b8713878"
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "true",
                                                      "tot": "bool"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 820,
                                              "y": 120,
                                              "wires": [
                                                      "b99a5fcf56fa30db"
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "false",
                                                      "tot": "bool"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 820,
                                              "y": 160,
                                              "wires": [
                                                      "b99a5fcf56fa30db"
                                              "type": "inject",
                                              "name": "Set",
                                              "props": [
                                                      "p": "payload"
                                                      "p": "topic",
                                                      "vt": "str"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": false,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "",
                                              "x": 110,
                                              "y": 480,
                                              "wires": [
                                                      "08f1fa9012a05ea5",
                                                      "7dcab65894d85d27",
                                                      "805b9497e42fd964"
                                              "name": "Süd",
                                              "env": [
                                                      "name": "latitude",
                                                      "type": "num"
                                                      "type": "num"
                                                      "value": "40",
                                                      "type": "num"
                                                      "name": "azimuth",
                                                      "value": "182",
                                                      "type": "num"
                                                      "value": "9",
                                                      "type": "num"
                                                      "name": "apikey",
                                                      "type": "cred"
                                                      "name": "watt",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                                      "value": "1",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                              "x": 230,
                                              "y": 480,
                                              "wires": [
                                                      "c4d7dd8d06fa28f9"
                                              "type": "function",
                                              "name": "f1",
                                              "outputs": 1,
                                              "timeout": "",
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [
                                                      "var": "moment",
                                                      "module": "moment"
                                              "x": 390,
                                              "y": 460,
                                              "wires": [
                                                      "1d46f7e375b6f7e2"
                                              "type": "switch",
                                              "name": "",
                                              "rules": [
                                                      "t": "lt",
                                                      "v": "2000",
                                                      "vt": "str"
                                                      "t": "btwn",
                                                      "v": "2000",
                                                      "vt": "num",
                                                      "v2": "5000",
                                                      "v2t": "num"
                                                      "t": "btwn",
                                                      "v": "5000",
                                                      "vt": "num",
                                                      "v2": "8000",
                                                      "v2t": "num"
                                                      "t": "gt",
                                                      "v": "8000",
                                                      "vt": "str"
                                              "checkall": "true",
                                              "repair": false,
                                              "outputs": 4,
                                              "x": 890,
                                              "y": 480,
                                              "wires": [
                                                      "db9a8c492c1eacbf"
                                                      "af5c4e99e154bf35"
                                                      "0d520e8869dda085"
                                                      "162844c501bda2cb"
                                              "type": "change",
                                              "name": "SOC 100",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "100",
                                                      "tot": "num"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1040,
                                              "y": 420,
                                              "wires": [
                                                      "3d56edb712404a94"
                                              "type": "change",
                                              "name": "SOC 60",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "60",
                                                      "tot": "num"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1040,
                                              "y": 460,
                                              "wires": [
                                                      "3d56edb712404a94"
                                              "type": "change",
                                              "name": "SOC 40",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "40",
                                                      "tot": "num"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1040,
                                              "y": 500,
                                              "wires": [
                                                      "3d56edb712404a94"
                                              "type": "change",
                                              "name": "SOC 20",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "20",
                                                      "tot": "num"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1040,
                                              "y": 540,
                                              "wires": [
                                                      "3d56edb712404a94"
                                              "type": "comment",
                                              "info": "",
                                              "x": 230,
                                              "y": 420,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 460,
                                              "y": 640,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 170,
                                              "y": 640,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 1020,
                                              "y": 620,
                                              "wires": []
                                              "ack": "false",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "readonly": "",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 1330,
                                              "y": 480,
                                              "wires": []
                                              "type": "comment",
                                              "info": "",
                                              "x": 1310,
                                              "y": 620,
                                              "wires": []
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "soll",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 1250,
                                              "y": 420,
                                              "wires": [
                                                      "0e02a8c5b8713878",
                                                      "bb6880f6962e941b"
                                              "type": "debug",
                                              "name": "Charging",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 1440,
                                              "y": 80,
                                              "wires": []
                                              "type": "debug",
                                              "name": "Cutoff",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 1450,
                                              "y": 420,
                                              "wires": []
                                              "type": "rbe",
                                              "func": "rbe",
                                              "gap": "",
                                              "start": "",
                                              "inout": "out",
                                              "septopics": true,
                                              "topi": "topic",
                                              "x": 1030,
                                              "y": 120,
                                              "wires": [
                                                      "3ccafa7058527caf"
                                              "type": "subflow:93f485839dfa27a8",
                                              "name": "Ost",
                                              "env": [
                                                      "name": "latitude",
                                                      "value": "51.0618535",
                                                      "type": "num"
                                                      "value": "7.376629",
                                                      "type": "num"
                                                      "value": "45",
                                                      "type": "num"
                                                      "name": "azimuth",
                                                      "value": "90",
                                                      "type": "num"
                                                      "value": "2",
                                                      "type": "num"
                                                      "name": "apikey",
                                                      "type": "cred"
                                                      "name": "watt",
                                                      "value": "watt_hours_day",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                                      "value": "1",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                              "x": 230,
                                              "y": 540,
                                              "wires": [
                                                      "af50b69abaa6e3f2"
                                              "name": "West",
                                              "env": [
                                                      "name": "latitude",
                                                      "type": "num"
                                                      "type": "num"
                                                      "value": "45",
                                                      "type": "num"
                                                      "name": "azimuth",
                                                      "value": "270",
                                                      "type": "num"
                                                      "value": "3",
                                                      "type": "num"
                                                      "name": "apikey",
                                                      "type": "cred"
                                                      "name": "watt",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                                      "value": "1",
                                                      "type": "str"
                                                      "type": "bool",
                                                      "value": "false"
                                              "x": 230,
                                              "y": 600,
                                              "wires": [
                                                      "0217fa6ea639b794"
                                              "type": "function",
                                              "name": "f2",
                                              "outputs": 1,
                                              "timeout": "",
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [
                                                      "var": "moment",
                                                      "module": "moment"
                                              "x": 390,
                                              "y": 520,
                                              "wires": [
                                                      "6def2e19d5482654"
                                              "type": "function",
                                              "name": "f3",
                                              "outputs": 1,
                                              "timeout": "",
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [
                                                      "var": "moment",
                                                      "module": "moment"
                                              "x": 390,
                                              "y": 580,
                                              "wires": [
                                                      "a3feba0d2f7707c9"
                                              "type": "change",
                                              "name": "L3",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "L3",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 550,
                                              "y": 580,
                                              "wires": [
                                                      "043c5238cb193231"
                                              "type": "change",
                                              "name": " L2",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "L2",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 550,
                                              "y": 520,
                                              "wires": [
                                                      "043c5238cb193231"
                                              "type": "change",
                                              "name": "L1",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "L1",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 550,
                                              "y": 460,
                                              "wires": [
                                                      "043c5238cb193231"
                                              "type": "join",
                                              "name": "",
                                              "mode": "custom",
                                              "build": "object",
                                              "key": "topic",
                                              "joiner": "\\n",
                                              "accumulate": true,
                                              "timeout": "",
                                              "count": "3",
                                              "reduceExp": "",
                                              "reduceInit": "",
                                              "reduceFixup": "",
                                              "x": 730,
                                              "y": 480,
                                              "wires": [
                                                      "0e39db21507d2496"
                                              "type": "comment",
                                              "info": "",
                                              "x": 620,
                                              "y": 420,
                                              "wires": []
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @armin-2
                                      Also Du fügst in der JOIN Node ja nur die 3 Werte in ein Objekt zusammen. Wenn Du eine DebugNode hinter die JOIN Node machen würdest würdest Du sehen, wie das Objekt zusammengesetzt wird.
                                      Also die Verwendung von Debug Nodes hilft in der Regel immer.
                                      Die JOIN Node setzt also die topics nur zusammen, addiert diese aber nicht, dass musst Du mit einer anschliessenden ChangeNode noch machen.
                                      das kannst Du entweder in diesem Fall mit der Summenfunktion von JSONATA machen:
                                      oder in dem Du die Werte einzeln mit JSONATA addierst:
                                      Also in JSONATA in der ChangeNode entweder:
                                      payload.L1 + payload.L2 +payload.L3
                                      oder
                                      $sum(payload.*)
                                      hier die Change node
                                             "id": "0eeff7bfe9f566bd",
                                             "type": "change",
                                             "z": "c38a1eccc4954015",
                                             "g": "f6a3a84cec843ef8",
                                             "name": "summieren",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "$sum(payload.*)",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 890,
                                             "y": 480,
                                             "wires": [
                                                     "bc12eec763ba10c2",
                                                     "2942bca022679e0e"
